path: root/include/linux
2006-08-06Merge branch 'for-linus' of ↵Linus Torvalds
master.kernel.org:/pub/scm/linux/kernel/git/dtor/input * 'for-linus' of master.kernel.org:/pub/scm/linux/kernel/git/dtor/input: (24 commits) Input: ati_remote - use msec instead of jiffies Input: ati_remote - add missing input_sync() Input: ati_remote - relax permissions sysfs module parameters Input: ati_remote - make filter time a module parameter Input: atkbd - restore repeat rate when resuming Input: trackpoint - activate protocol when resuming Input: logips2pp - fix button mapping for MX300 Input: keyboard - change to use kzalloc Input: serio/gameport - check whether driver core calls succeeded Input: spaceball - make 4000FLX Lefty work Input: keyboard - simplify emulate_raw() implementation Input: keyboard - remove static variable and clean up initialization Input: hiddev - use standard list implementation Input: add missing handler->start() call Input: HID - fix potential out-of-bound array access Input: fix list iteration in input_release_device() Input: iforce - add Trust Force Feedback Race Master support Input: iforce - check array bounds before accessing elements Input: libps2 - warn instead of oopsing when passed bad arguments Input: fm801-gp - fix use after free ...
2006-08-06[PATCH] debug_locks.h: add "struct task_struct;"Alexey Dobriyan
Removes many, many "declared inside parameter list" warnings on parisc. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-08-06[PATCH] fix vmstat per cpu usageJan Blunck
The per cpu variables are used incorrectly in vmstat.h. Signed-off-by: Jan Blunck <jblunck@suse.de> Cc: Christoph Lameter <clameter@engr.sgi.com> Acked-by: Steve Fox <drfickle@us.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-08-06[PATCH] Make suspend possible with a traced process at a breakpointRafael J. Wysocki
It should be possible to suspend, either to RAM or to disk, if there's a traced process that has just reached a breakpoint. However, this is a special case, because its parent process might have been frozen already and then we are unable to deliver the "freeze" signal to the traced process. If this happens, it's better to cancel the freezing of the traced process. Ref. http://bugzilla.kernel.org/show_bug.cgi?id=6787 Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Acked-by: Pavel Machek <pavel@ucw.cz> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-08-04Merge rsync://rsync.kernel.org/pub/scm/linux/kernel/git/torvalds/linux-2.6 ↵Dmitry Torokhov
into for-linus
2006-08-04Merge branch 'fixes' of git://git.linux-nfs.org/pub/linux/nfs-2.6Linus Torvalds
* 'fixes' of git://git.linux-nfs.org/pub/linux/nfs-2.6: SUNRPC: Fix obvious refcounting bugs in rpc_pipefs. RPC: Ensure that we disconnect TCP socket when client requests error out NLM/lockd: remove b_done NFS: make 2 functions static NFS: Release dcache_lock in an error path of nfs_path
2006-08-03RPC: Ensure that we disconnect TCP socket when client requests error outTrond Myklebust
If we're part way through transmitting a TCP request, and the client errors, then we need to disconnect and reconnect the TCP socket in order to avoid confusing the server. Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com> (cherry picked from 031a50c8b9ea82616abd4a4e18021a25848941ce commit)
2006-08-03NLM/lockd: remove b_doneJ. Bruce Fields
We never actually set the b_done field any more; it's always zero. Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com> (cherry picked from af8412d4283ef91356e65e0ed9b025b376aebded commit)
2006-08-03NFS: make 2 functions staticAdrian Bunk
nfs_writedata_free() and nfs_readdata_free() can now become static. Signed-off-by: Adrian Bunk <bunk@stusta.de> Cc: Trond Myklebust <trond.myklebust@fys.uio.no> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com> (cherry picked from 5e1ce40f0c3c8f67591aff17756930d7a18ceb1a commit)
2006-08-03PCI: docking station: remove dock ueventsKristen Carlson Accardi
Remove uevent dock notifications. There are no consumers of these events at present, and uevents are likely not the correct way to send this type of event anyway. Until I get some kind of idea if anyone in userspace cares about dock events, I will just not send any. Signed-off-by: Kristen Carlson Accardi <kristen.c.accardi@intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-08-03PCI: Unhide the SMBus on Asus PU-DLSJean Delvare
Unhide the SMBus controller on the Asus PU-DLS board. This fixes bug #6763. Signed-off-by: Jean Delvare <khali@linux-fr.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-08-03[PATCH] don't bother with aux entires for dummy contextAl Viro
2006-08-03[PATCH] mark context of syscall entered with no rules as dummyAl Viro
2006-08-03[PATCH] introduce audit rules counterAl Viro
2006-08-03[PATCH] fix missed create event for directory auditAmy Griffis
When an object is created via a symlink into an audited directory, audit misses the event due to not having collected the inode data for the directory. Modify __audit_inode_child() to copy the parent inode data if a parent wasn't found in audit_names[]. Signed-off-by: Amy Griffis <amy.griffis@hp.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2006-08-03[PATCH] fix faulty inode data collection for open() with O_CREATAmy Griffis
When the specified path is an existing file or when it is a symlink, audit collects the wrong inode number, which causes it to miss the open() event. Adding a second hook to the open() path fixes this. Also add audit_copy_inode() to consolidate some code. Signed-off-by: Amy Griffis <amy.griffis@hp.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2006-08-02Merge master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6Linus Torvalds
* master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6: (32 commits) [NET]: Fix more per-cpu typos [SECURITY]: Fix build with CONFIG_SECURITY disabled. [I/OAT]: Remove CPU hotplug lock from net_dma_rebalance [DECNET]: Fix for routing bug [AF_UNIX]: Kernel memory leak fix for af_unix datagram getpeersec patch [NET]: skb_queue_lock_key() is no longer used. [NET]: Remove lockdep_set_class() call from skb_queue_head_init(). [IPV6]: SNMPv2 "ipv6IfStatsOutFragCreates" counter error [IPV6]: SNMPv2 "ipv6IfStatsInHdrErrors" counter error [NET]: Kill the WARN_ON() calls for checksum fixups. [NETFILTER]: xt_hashlimit/xt_string: missing string validation [NETFILTER]: SIP helper: expect RTP streams in both directions [E1000]: Convert to netdev_alloc_skb [TG3]: Convert to netdev_alloc_skb [NET]: Add netdev_alloc_skb(). [TCP]: Process linger2 timeout consistently. [SECURITY] secmark: nul-terminate secdata [NET] infiniband: Cleanup ib_addr module to use the netevents [NET]: Core net changes to generate netevents [NET]: Network Event Notifier Mechanism. ...
2006-08-02Revert "[PATCH] USB: move usb_device_class class devices to be real devices"Greg Kroah-Hartman
This reverts c182274ffe1277f4e7c564719a696a37cacf74ea commit because it required a newer version of udev to work properly than what is currently documented in Documentation/Changes. Cc: Kay Sievers <kay.sievers@vrfy.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-08-02Revert "[PATCH] USB: convert usb class devices to real devices"Greg Kroah-Hartman
This reverts bd00949647ddcea47ce4ea8bb2cfcfc98ebf9f2a commit because it required a newer version of udev to work properly than what is currently documented in Documentation/Changes. Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-08-02usb-storage: Add US_FL_IGNORE_DEVICE flag; ignore ZyXEL G220FDaniel Drake
This patch adds a new unusual_devs flag for when usb-storage needs to ignore a device that it would otherwise claim. We need to ignore the ZyXEL G220F as it is a virtual CDROM drive which includes the windows driver for this USB-WLAN adapter. After the windows driver is installed on a windows system, it converts it into a WLAN adapter (by ejecting the virtual disc). The virtual CDROM is of no interest to Linux users. The zd1211rw driver will automatically perform the eject operation, we just need to ensure that usb-storage does not claim the device. Signed-off-by: Daniel Drake <dsd@gentoo.org> Signed-off-by: Matthew Dharm <mdharm-usb@one-eyed-alien.net> Signed-off-by: Phil Dibowitz <phil@ipom.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-08-02[SECURITY]: Fix build with CONFIG_SECURITY disabled.David S. Miller
include/linux/security.h: In function ‘security_release_secctx’: include/linux/security.h:2757: warning: ‘return’ with a value, in function returning void Signed-off-by: David S. Miller <davem@davemloft.net>
2006-08-02[AF_UNIX]: Kernel memory leak fix for af_unix datagram getpeersec patchCatherine Zhang
From: Catherine Zhang <cxzhang@watson.ibm.com> This patch implements a cleaner fix for the memory leak problem of the original unix datagram getpeersec patch. Instead of creating a security context each time a unix datagram is sent, we only create the security context when the receiver requests it. This new design requires modification of the current unix_getsecpeer_dgram LSM hook and addition of two new hooks, namely, secid_to_secctx and release_secctx. The former retrieves the security context and the latter releases it. A hook is required for releasing the security context because it is up to the security module to decide how that's done. In the case of Selinux, it's a simple kfree operation. Acked-by: Stephen Smalley <sds@tycho.nsa.gov> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-08-02[NET]: skb_queue_lock_key() is no longer used.Adrian Bunk
Signed-off-by: Adrian Bunk <bunk@stusta.de> Acked-by: Arjan van de Ven <arjan@linux.intel.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-08-02[NET]: Remove lockdep_set_class() call from skb_queue_head_init().Arjan van de Ven
The skb_queue_head_init() function is used both in drivers for private use and in the core networking code. The usage models are vastly set of functions that is only softirq safe; while the driver usage tends to be more limited to a few hardirq safe accessor functions. Rather than annotating all 133+ driver usages, for now just split this lock into a per queue class. This change is obviously safe and probably should make 2.6.18. Signed-off-by: Arjan van de Ven <arjan@linux.intel.com> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-08-02[NET]: Add netdev_alloc_skb().Christoph Hellwig
Add a dev_alloc_skb variant that takes a struct net_device * paramater. For now that paramater is unused, but I'll use it to allocate the skb from node-local memory in a follow-up patch. Also there have been some other plans mentioned on the list that can use it. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-08-02[NETFILTER]: include/linux/netfilter_bridge.h: header cleanupAlexey Dobriyan
Header doesn't use anything from atomic.h. It fixes headers_check warning: include/linux/netfilter_bridge.h requires asm/atomic.h, which does not exist Compile tested on alpha arm i386-up sparc sparc64-up x86_64 alpha-up i386 sparc64 sparc-up x86_64-up Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-08-02Merge master.kernel.org:/pub/scm/linux/kernel/git/mchehab/v4l-dvbLinus Torvalds
* master.kernel.org:/pub/scm/linux/kernel/git/mchehab/v4l-dvb: (26 commits) V4L/DVB (4380): Bttv: Revert VBI_OFFSET to previous value, it works better V4L/DVB (4379): Videodev: Check return value of class_device_register() correctly V4L/DVB (4373): Correctly handle sysfs error leg file removal in pvrusb2 V4L/DVB (4368): Bttv: use class_device_create_file and handle errors V4L/DVB (4367): Videodev: Handle class_device related errors V4L/DVB (4365): OVERLAY flag were enabled by mistake V4L/DVB (4344): Fix broken dependencies on media Kconfig V4L/DVB (4343): Fix for compilation without V4L1 or V4L1_COMPAT V4L/DVB (4342): Fix ext_controls align on 64 bit architectures V4L/DVB (4341): VIDIOCSMICROCODE were missing on compat_ioctl32 V4L/DVB (4322): Fix dvb-pll autoprobing V4L/DVB (4311): Fix possible dvb-pll oops V4L/DVB (4337): Refine dead code elimination in pvrusb2 V4L/DVB (4323): [budget/budget-av/budget-ci/budget-patch drivers] fixed DMA start/stop code V4L/DVB (4316): Check __must_check warnings V4L/DVB (4314): Set the Auxiliary Byte when tuning LG H06xF in analog mode V4L/DVB (4313): Bugfix for keycode calculation on NPG remotes V4L/DVB (4310): Saa7134: rename dmasound_{init, exit} V4L/DVB (4306): Support non interlaced capture by default for saa713x V4L/DVB (4298): Check all __must_check warnings in bttv. ...
2006-07-31[PATCH] powermac: More powermac backlight fixesMichael Hanselmann
This patch fixes several problems: - The legacy backlight value might be set at interrupt time. Introduced a worker to prevent it from directly calling the backlight code. - via-pmu allows the backlight to be grabbed, in which case we need to prevent other kernel code from changing the brightness. - Don't send PMU requests in via-pmu-backlight when the machine is about to sleep or waking up. - More Kconfig fixes. Signed-off-by: Michael Hanselmann <linux-kernel@hansmi.ch> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: "Antonino A. Daplas" <adaplas@pol.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-07-31[PATCH] fbdev: statically link the framebuffer notification functionsAntonino A. Daplas
The backlight and lcd subsystems can be notified by the framebuffer layer of blanking events. However, these subsystems, as a whole, can function independently from the framebuffer layer. But in order to enable to the lcd and backlight subsystems, the framebuffer has to be compiled also, effectively sucking in a huge amount of unneeded code. To prevent dependency problems, separate out the framebuffer notification mechanism from the framebuffer layer and permanently link it to the kernel. Signed-off-by: Antonino Daplas <adaplas@pol.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-07-31[PATCH] Add parentheses around arguments in the SH_DIV macro.Uwe Zeisberger
There is currently no affected user in the tree, but usage is less surprising that way. Signed-off-by: Uwe Zeisberger <Uwe_Zeisberger@digi.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-07-31[PATCH] always define IRQ_PER_CPUYoichi Yuasa
Reduce the likelihood of someone accidentally introducing namespace collisions. Signed-off-by: Yoichi Yuasa <yoichi_yuasa@tripeaks.co.jp> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-07-31[PATCH] delay accounting: temporarily enable by defaultShailabh Nagar
Enable delay accounting by default so that feature gets coverage testing without requiring special measures. Earlier, it was off by default and had to be enabled via a boot time param. This patch reverses the default behaviour to improve coverage testing. It can be removed late in the kernel development cycle if its believed users shouldn't have to incur any cost if they don't want delay accounting. Or it can be retained forever if the utility of the stats is deemed common enough to warrant keeping the feature on. Signed-off-by: Shailabh Nagar <nagar@watson.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-07-31[PATCH] make taskstats sending completely independent of delay accounting ↵Shailabh Nagar
on/off status Complete the separation of delay accounting and taskstats by ignoring the return value of delay accounting functions that fill in parts of taskstats before it is sent out (either in response to a command or as part of a task exit). Also make delayacct_add_tsk return silently when delay accounting is turned off rather than treat it as an error. Signed-off-by: Shailabh Nagar <nagar@watson.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-07-31[PATCH] genirq: {en,dis}able_irq_wake() need refcounting tooDavid Brownell
IRQs need refcounting and a state flag to track whether the the IRQ should be enabled or disabled as a "normal IRQ" source after a series of calls to {en,dis}able_irq(). For shared IRQs, the IRQ must be enabled so long as at least one driver needs it active. Likewise, IRQs need the same support to track whether the IRQ should be enabled or disabled as a "wakeup event" source after a series of calls to {en,dis}able_irq_wake(). For shared IRQs, the IRQ must be enabled as a wakeup source during sleep so long as at least one driver needs it. But right now they _don't have_ that refcounting ... which means sharing a wakeup-capable IRQ can't work correctly in some configurations. This patch adds the refcount and flag mechanisms to set_irq_wake() -- which is what {en,dis}able_irq_wake() call -- and minimal documentation of what the irq wake mechanism does. Drivers relying on the older (broken) "toggle" semantics will trigger a warning; that'll be a handful of drivers on ARM systems. Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Acked-by: Ingo Molnar <mingo@elte.hu> Acked-by: Thomas Gleixner <tglx@linutronix.de> Cc: Russell King <rmk@arm.linux.org.uk> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-07-31[PATCH] Process Events: Fix biarch compatibility issue. use __u64 timestampChandra Seetharaman
Events sent by Process Events Connector from a 64-bit kernel are not binary compatible with a 32-bit userspace program because the "timestamp" field (struct timespec) is not arch independent. This affects the fields that follow "timestamp" as they will be be off by 8 bytes. This is a problem for 32-bit userspace programs running with 64-bit kernels on ppc64, s390, x86-64.. any "biarch" system. Matt had submitted a different solution to lkml as an RFC earlier. We have since switched to a solution recommended by Evgeniy Polyakov. This patch fixes the problem by changing the timestamp to be a __u64, which stores the number of nanoseconds. Tested on a x86_64 system with both 32 bit application and 64 bit application and on a i386 system. Signed-off-by: Chandra Seetharaman <sekharan@us.ibm.com> Signed-off-by: Matt Helsley <matthltc@us.ibm.com> Cc: Evgeniy Polyakov <johnpol@2ka.mipt.ru> Cc: Guillaume Thouvenin <guillaume.thouvenin@bull.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-07-31[PATCH] ext3: avoid triggering ext3_error on bad NFS file handleNeil Brown
The inode number out of an NFS file handle gets passed eventually to ext3_get_inode_block() without any checking. If ext3_get_inode_block() allows it to trigger an error, then bad filehandles can have unpleasant effect - ext3_error() will usually cause a forced read-only remount, or a panic if `errors=panic' was used. So remove the call to ext3_error there and put a matching check in ext3/namei.c where inode numbers are read off storage. [akpm@osdl.org: fix off-by-one error] Signed-off-by: Neil Brown <neilb@suse.de> Signed-off-by: Jan Kara <jack@suse.cz> Cc: Marcel Holtmann <marcel@holtmann.org> Cc: <stable@kernel.org> Cc: "Stephen C. Tweedie" <sct@redhat.com> Cc: Eric Sandeen <esandeen@redhat.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-07-29V4L/DVB (4343): Fix for compilation without V4L1 or V4L1_COMPATMauro Carvalho Chehab
Removed usage of HAVE_V4L1 Including videodev.h will just include videodev2.h if V4L1 is not supported V4L1 code at core drivers will honor CONFIG_V4L1_COMPAT stuff Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2006-07-29V4L/DVB (4342): Fix ext_controls align on 64 bit architecturesMauro Carvalho Chehab
u64 is aligned as 128bits on x86_64 architetures, requiring an special handling to ioctls that depends on v4l2_ext_control. Let's fix this before ext controls go to kernel mainstream to avoid one more compat32 stuff. Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2006-07-29Merge branch 'master' into upstream-fixesJeff Garzik
2006-07-28[PATCH] pi-futex: robust-futex exitIngo Molnar
Fix robust PI-futexes to be properly unlocked on unexpected exit. For this to work the kernel has to know whether a futex is a PI or a non-PI one, because the semantics are different. Since the space in relevant glibc data structures is extremely scarce, the best solution is to encode the 'PI' information in bit 0 of the robust list pointer. Existing (non-PI) glibc robust futexes have this bit always zero, so the ABI is kept. New glibc with PI-robust-futexes will set this bit. Further fixes from Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Ulrich Drepper <drepper@redhat.com> Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-07-28[PATCH] ide: option to disable cache flushes for buggy drivesJens Axboe
Some drives claim they support cache flushing, but get seriously confused if you try. Add this option to be able to boot with barriers enabled by default. Signed-off-by: Jens Axboe <axboe@suse.de>
2006-07-26Merge master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6Linus Torvalds
* master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6: [IPV4/IPV6]: Setting 0 for unused port field in RAW IP recvmsg(). [IPV4] ipmr: ip multicast route bug fix. [TG3]: Update version and reldate [TG3]: Handle tg3_init_rings() failures [TG3]: Add tg3_restart_hw() [IPV4]: Clear the whole IPCB, this clears also IPCB(skb)->flags. [IPV6]: Clean skb cb on IPv6 input. [NETFILTER]: Demote xt_sctp to EXPERIMENTAL [NETFILTER]: bridge netfilter: add deferred output hooks to feature-removal-schedule [NETFILTER]: xt_pkttype: fix mismatches on locally generated packets [NETFILTER]: SNMP NAT: fix byteorder confusion [NETFILTER]: conntrack: fix SYSCTL=n compile [NETFILTER]: nf_queue: handle NF_STOP and unknown verdicts in nf_reinject [NETFILTER]: H.323 helper: fix possible NULL-ptr dereference
2006-07-26[PATCH] Reorganize the cpufreq cpu hotplug locking to not be totally bizareArjan van de Ven
The patch below moves the cpu hotplugging higher up in the cpufreq layering; this is needed to avoid recursive taking of the cpu hotplug lock and to otherwise detangle the mess. The new rules are: 1. you must do lock_cpu_hotplug() around the following functions: __cpufreq_driver_target __cpufreq_governor (for CPUFREQ_GOV_LIMITS operation only) __cpufreq_set_policy 2. governer methods (.governer) must NOT take the lock_cpu_hotplug() lock in any way; they are called with the lock taken already 3. if your governer spawns a thread that does things, like calling __cpufreq_driver_target, your thread must honor rule #1. 4. the policy lock and other cpufreq internal locks nest within the lock_cpu_hotplug() lock. I'm not entirely happy about how the __cpufreq_governor rule ended up (conditional locking rule depending on the argument) but basically all callers pass this as a constant so it's not too horrible. The patch also removes the cpufreq_governor() function since during the locking audit it turned out to be entirely unused (so no need to fix it) The patch works on my testbox, but it could use more testing (otoh... it can't be much worse than the current code) Signed-off-by: Arjan van de Ven <arjan@linux.intel.com> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-07-24[NETFILTER]: bridge netfilter: add deferred output hooks to ↵Patrick McHardy
feature-removal-schedule Add bridge netfilter deferred output hooks to feature-removal-schedule and disable them by default. Until their removal they will be activated by the physdev match when needed. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-07-24[NET]: Correct dev_alloc_skb kerneldocChristoph Hellwig
dev_alloc_skb is designated for RX descriptors, not TX. (Some drivers use it for the latter anyway, but that's a different story) Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-07-24[NET]: Remove CONFIG_HAVE_ARCH_DEV_ALLOC_SKBChristoph Hellwig
skbuff.h has an #ifndef CONFIG_HAVE_ARCH_DEV_ALLOC_SKB to allow architectures to reimplement __dev_alloc_skb. It's not set on any architecture and now that we have an architecture-overrideable NET_SKB_PAD there is not point at all to have one either. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-07-24Merge branch 'master' into upstream-fixesJeff Garzik
2006-07-23cpu hotplug: simplify and hopefully fix lockingLinus Torvalds
The CPU hotplug locking was quite messy, with a recursive lock to handle the fact that both the actual up/down sequence wanted to protect itself from being re-entered, but the callbacks that it called also tended to want to protect themselves from CPU events. This splits the lock into two (one to serialize the whole hotplug sequence, the other to protect against the CPU present bitmaps changing). The latter still allows recursive usage because some subsystems (ondemand policy for cpufreq at least) had already gotten too used to the lax locking, but the locking mistakes are hopefully now less fundamental, and we now warn about recursive lock usage when we see it, in the hope that it can be fixed. Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-07-21[NET]: Fix reversed error test in netif_tx_trylockHerbert Xu
A non-zero return value indicates success from spin_trylock, not error. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-07-19[PATCH] libata: improve EH action and EHI flag handlingTejun Heo
Update ata_eh_about_to_do() and ata_eh_done() to improve EH action and EHI flag handling. * There are two types of EHI flags - one which expires on successful EH and the other which expires on a successful reset. Make this distinction clear. * Unlike other EH actions, reset actions are represented by two EH action masks and a EHI modifier. Implement correct about_to_do/done semantics for resets. That is, prior to reset, related EH info is sucked in from ehi and cleared, and after reset is complete, related EH info in ehc is cleared. These changes improve consistency and remove unnecessary EH actions caused by stale EH action masks and EHI flags. Signed-off-by: Tejun Heo <htejun@gmail.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
