This reverts commit 7681bfeeccff5efa9eb29bf09249a3c400b15327.
include/linux/genhd.h
It has numerous issues with the cleanup path and non-elevator
devices. Revert it for now so we can come up with a clean
version without rushing things.
Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next-2.6: (1699 commits)
bnx2/bnx2x: Unsupported Ethtool operations should return -EINVAL.
vlan: Calling vlan_hwaccel_do_receive() is always valid.
tproxy: use the interface primary IP address as a default value for --on-ip
tproxy: added IPv6 support to the socket match
cxgb3: function namespace cleanup
tproxy: added IPv6 support to the TPROXY target
tproxy: added IPv6 socket lookup function to nf_tproxy_core
be2net: Changes to use only priority codes allowed by f/w
tproxy: allow non-local binds of IPv6 sockets if IP_TRANSPARENT is enabled
tproxy: added tproxy sockopt interface in the IPV6 layer
tproxy: added udp6_lib_lookup function
tproxy: added const specifiers to udp lookup functions
tproxy: split off ipv6 defragmentation to a separate module
l2tp: small cleanup
nf_nat: restrict ICMP translation for embedded header
can: mcp251x: fix generation of error frames
can: mcp251x: fix endless loop in interrupt handler if CANINTF_MERRF is set
can-raw: add msg_flags to distinguish local traffic
9p: client code cleanup
rds: make local functions/variables static
Fix up conflicts in net/core/dev.c, drivers/net/pcmcia/smc91c92_cs.c and
drivers/net/wireless/ath/ath9k/debug.c as per David
'x86-numa-for-linus', 'x86-quirks-for-linus', 'x86-setup-for-linus', 'x86-uv-for-linus' and 'x86-vm86-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip
* 'softirq-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip:
softirqs: Make wakeup_softirqd static
* 'x86-debug-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip:
x86, asm: Restore parentheses around one pushl_cfi argument
x86, asm: Fix ancient-GAS workaround
x86, asm: Fix CFI macro invocations to deal with shortcomings in gas
* 'x86-numa-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip:
x86, numa: Assign CPUs to nodes in round-robin manner on fake NUMA
* 'x86-quirks-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip:
x86: HPET force enable for CX700 / VIA Epia LT
* 'x86-setup-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip:
x86, setup: Use string copy operation to optimze copy in kernel compression
* 'x86-uv-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip:
x86, UV: Use allocated buffer in tlb_uv.c:tunables_read()
* 'x86-vm86-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip:
x86, vm86: Fix preemption bug for int1 debug and int3 breakpoint handlers.
git://git.kernel.org/pub/scm/linux/kernel/git/ryusuke/nilfs2
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/ryusuke/nilfs2: (36 commits)
nilfs2: eliminate sparse warning - "context imbalance"
nilfs2: eliminate sparse warnings - "symbol not declared"
nilfs2: get rid of bdi from nilfs object
nilfs2: change license of exported header file
nilfs2: add bdev freeze/thaw support
nilfs2: accept 64-bit checkpoint numbers in cp mount option
nilfs2: remove own inode allocator and destructor for metadata files
nilfs2: get rid of back pointer to writable sb instance
nilfs2: get rid of mi_nilfs back pointer to nilfs object
nilfs2: see state of root dentry for mount check of snapshots
nilfs2: use iget for all metadata files
nilfs2: get rid of GCDAT inode
nilfs2: add routines to redirect access to buffers of DAT file
nilfs2: add routines to roll back state of DAT file
nilfs2: add routines to save and restore bmap state
nilfs2: do not allocate nilfs_mdt_info structure to gc-inodes
nilfs2: allow nilfs_clear_inode to clear metadata file inodes
nilfs2: get rid of snapshot mount flag
nilfs2: simplify life cycle management of nilfs object
nilfs2: do not allocate multiple super block instances for a device
git://git.kernel.org/pub/scm/linux/kernel/git/jwessel/linux-2.6-kgdb
* 'for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jwessel/linux-2.6-kgdb:
kdb,debug_core: adjust master cpu switch logic against new debug_core locking
debug_core: refactor locking for master/slave cpus
x86,kgdb: remove unnecessary call to kgdb_correct_hw_break()
debug_core: disable hw_breakpoints on all cores in kgdb_cpu_enter()
kdb,kgdb: fix sparse fixups
kdb: Fix oops in kdb_unregister
kdb,ftdump: Remove reference to internal kdb include
kdb: Allow kernel loadable modules to add kdb shell functions
debug_core: stop rcu warnings on kernel resume
debug_core: move all watch dog syncs to a single function
x86,kgdb: fix debugger hw breakpoint test regression in 2.6.35
* git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb-2.6: (141 commits)
USB: mct_u232: fix broken close
USB: gadget: amd5536udc.c: fix error path
USB: imx21-hcd - fix off by one resource size calculation
usb: gadget: fix Kconfig warning
usb: r8a66597-udc: Add processing when USB was removed.
mxc_udc: add workaround for ENGcm09152 for i.MX35
USB: ftdi_sio: add device ids for ScienceScope
USB: musb: AM35x: Workaround for fifo read issue
USB: musb: add musb support for AM35x
USB: AM35x: Add musb support
usb: Fix linker errors with CONFIG_PM=n
USB: ohci-sh - use resource_size instead of defining its own resource_len macro
USB: isp1362-hcd - use resource_size instead of defining its own resource_len macro
USB: isp116x-hcd - use resource_size instead of defining its own resource_len macro
USB: xhci: Fix compile error when CONFIG_PM=n
USB: accept some invalid ep0-maxpacket values
USB: xHCI: PCI power management implementation
USB: xHCI: bus power management implementation
USB: xHCI: port remote wakeup implementation
USB: xHCI: port power management implementation
Manually fix up (non-data) conflict: the SCSI merge gad renamed the
'hw_sector_size' member to 'physical_block_size', and the USB tree
brought a new use of it.
* git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/tty-2.6: (49 commits)
serial8250: ratelimit "too much work" error
serial: bfin_sport_uart: speed up sport RX sample rate to be 3% faster
serial: abstraction for 8250 legacy ports
serial/imx: check that the buffer is non-empty before sending it out
serial: mfd: add more baud rates support
jsm: Remove the uart port on errors
Alchemy: Add UART PM methods.
8250: allow platforms to override PM hook.
altera_uart: Don't use plain integer as NULL pointer
altera_uart: Fix missing prototype for registering an early console
altera_uart: Fixup type usage of port flags
altera_uart: Make it possible to use Altera UART and 8250 ports together
altera_uart: Add support for different address strides
altera_uart: Add support for getting mapbase and IRQ from resources
altera_uart: Add support for polling mode (IRQ-less)
serial: Factor out uart_poll_timeout() from 8250 driver
serial: mark the 8250 driver as maintained
serial: 8250: Don't delay after transmitter is ready.
tty: MAINTAINERS: add drivers/serial/jsm/ as maintained driver
vcs: invoke the vt update callback when /dev/vcs* is written to
* git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core-2.6: (31 commits)
driver core: Display error codes when class suspend fails
Driver core: Add section count to memory_block struct
Driver core: Add mutex for adding/removing memory blocks
Driver core: Move find_memory_block routine
hpilo: Despecificate driver from iLO generation
driver core: Convert link_mem_sections to use find_memory_block_hinted.
driver core: Introduce find_memory_block_hinted which utilizes kset_find_obj_hinted.
kobject: Introduce kset_find_obj_hinted.
driver core: fix build for CONFIG_BLOCK not enabled
driver-core: base: change to new flag variable
sysfs: only access bin file vm_ops with the active lock
sysfs: Fail bin file mmap if vma close is implemented.
FW_LOADER: fix kconfig dependency warning on HOTPLUG
uio: Statically allocate uio_class and use class .dev_attrs.
uio: Support 2^MINOR_BITS minors
uio: Cleanup irq handling.
uio: Don't clear driver data
uio: Fix lack of locking in init_uio_class
SYSFS: Allow boot time switching between deprecated and modern sysfs layout
driver core: remove CONFIG_SYSFS_DEPRECATED_V2 but keep it for block devices
* git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi-misc-2.6: (84 commits)
[SCSI] be2iscsi: SGE Len == 64K
[SCSI] be2iscsi: Remove premature free of cid
[SCSI] be2iscsi: More time for FW
[SCSI] libsas: fix bug for vacant phy
[SCSI] sd: Fix overflow with big physical blocks
[SCSI] st: add MTWEOFI to write filemarks without flushing drive buffer
[SCSI] libsas: Don't issue commands to devices that have been hot-removed
[SCSI] megaraid_sas: Add Online Controller Reset to MegaRAID SAS drive
[SCSI] lpfc 8.3.17: Update lpfc driver version to 8.3.17
[SCSI] lpfc 8.3.17: Replace function reset methodology
[SCSI] lpfc 8.3.17: SCSI fixes
[SCSI] lpfc 8.3.17: BSG fixes
[SCSI] lpfc 8.3.17: SLI Additions and Fixes
[SCSI] lpfc 8.3.17: Code Cleanup and Locking fixes
[SCSI] zfcp: Remove scsi_cmnd->serial_number from debug traces
[SCSI] ipr: fix array error logging
[SCSI] aha152x: enable PCMCIA on 64bit
[SCSI] scsi_dh_alua: Handle all states correctly
[SCSI] cxgb4i: connection and ddp setting update
[SCSI] cxgb3i: fixed connection over vlan
git://git.kernel.org/pub/scm/linux/kernel/git/teigland/dlm
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/teigland/dlm:
dlm: Fix dlm lock status block comment in dlm.h
dlm: Don't send callback to node making lock request when "try 1cb" fails
git://git.kernel.org/pub/scm/linux/kernel/git/tj/percpu
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tj/percpu:
percpu: update comments to reflect that percpu allocations are always zero-filled
percpu: Optimize __get_cpu_var()
x86, percpu: Optimize this_cpu_ptr
percpu: clear memory allocated with the km allocator
percpu: fix build breakage on s390 and cleanup build configuration tests
percpu: use percpu allocator on UP too
percpu: reduce PCPU_MIN_UNIT_SIZE to 32k
vmalloc: pcpu_get/free_vm_areas() aren't needed on UP
Fixed up trivial conflicts in include/linux/percpu.h
This allows other projects to carry copies of the header file related
to ABI and disk format (i.e. "nilfs2_fs.h") without it or distributors
having to worry about effects on the project's overall license terms.
It's also desired for switching the license of nilfs library to LGPL.
Jiro SEKIBA pointed out these license issues (Message-ID:
<87tylo7msw.wl%jir@sekiba.com>), and he suggested switching license of
the library and nilfs2_fs.h to GNU Lesser General Public License. We
take in his suggestion to avoid the license issues.
Signed-off-by: Ryusuke Konishi <konishi.ryusuke@lab.ntt.co.jp>
Cc: Jiro SEKIBA <jir@unicus.jp>
Cc: linux-nilfs <linux-nilfs@vger.kernel.org>
This flag is a fake used to distinguish type of super block instance.
And, it got obsolete by the unification of sb.
The previous export operations cannot handle multiple versions of
a filesystem if they belong to the same sb instance.
This adds a new type of file handle and extends export operations so
that they can get the inode specified by a checkpoint number as well
as an inode number and a generation number.
On-memory inode structures of nilfs have a member "i_cno" which stores
a checkpoint number related to the inode. For gc-inodes, this field
indicates version of data each gc-inode caches for GC. Log writer
temporarily uses "i_cno" to transfer the latest checkpoint number.
This stops the latter use and lets only gc-inodes use it.
The purpose of this patch is to allow the successive change use
"i_cno" for inode lookup.
Compatibility of nilfs partitions is now managed with three feature
sets. This changes old compatibility check with revision number so
that it can accept future revisions.
Note that we can stop support of experimental versions of nilfs that
doesn't know the feature sets by incrementing NILFS_CURRENT_REV. We
don't have to do it soon, but it would be a possible option whenever
the need arises.
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tj/wq:
workqueue: remove in_workqueue_context()
workqueue: Clarify that schedule_on_each_cpu is synchronous
memory_hotplug: drop spurious calls to flush_scheduled_work()
shpchp: update workqueue usage
pciehp: update workqueue usage
isdn/eicon: don't call flush_scheduled_work() from diva_os_remove_soft_isr()
workqueue: add and use WQ_MEM_RECLAIM flag
workqueue: fix HIGHPRI handling in keep_working()
workqueue: add queue_work and activate_work trace points
workqueue: prepare for more tracepoints
workqueue: implement flush[_delayed]_work_sync()
workqueue: factor out start_flush_work()
workqueue: cleanup flush/cancel functions
workqueue: implement alloc_ordered_workqueue()
Fix up trivial conflict in fs/gfs2/main.c as per Tejun
* 'for-2.6.37/barrier' of git://git.kernel.dk/linux-2.6-block: (46 commits)
xen-blkfront: disable barrier/flush write support
Added blk-lib.c and blk-barrier.c was renamed to blk-flush.c
block: remove BLKDEV_IFL_WAIT
aic7xxx_old: removed unused 'req' variable
block: remove the BH_Eopnotsupp flag
block: remove the BLKDEV_IFL_BARRIER flag
block: remove the WRITE_BARRIER flag
swap: do not send discards as barriers
fat: do not send discards as barriers
ext4: do not send discards as barriers
jbd2: replace barriers with explicit flush / FUA usage
jbd2: Modify ASYNC_COMMIT code to not rely on queue draining on barrier
jbd: replace barriers with explicit flush / FUA usage
nilfs2: replace barriers with explicit flush / FUA usage
reiserfs: replace barriers with explicit flush / FUA usage
gfs2: replace barriers with explicit flush / FUA usage
btrfs: replace barriers with explicit flush / FUA usage
xfs: replace barriers with explicit flush / FUA usage
block: pass gfp_mask and flags to sb_issue_discard
dm: convey that all flushes are processed as empty
* 'for-2.6.37/drivers' of git://git.kernel.dk/linux-2.6-block: (95 commits)
cciss: fix PCI IDs for new Smart Array controllers
drbd: add race-breaker to drbd_go_diskless
drbd: use dynamic_dev_dbg to optionally log uuid changes
dynamic_debug.h: Fix dynamic_dev_dbg() macro if CONFIG_DYNAMIC_DEBUG not set
drbd: cleanup: change "<= 0" to "== 0"
drbd: relax the grace period of the md_sync timer again
drbd: add some more explicit drbd_md_sync
drbd: drop wrong debug asserts, fix recently introduced race
drbd: cleanup useless leftover warn/error printk's
drbd: add explicit drbd_md_sync to drbd_resync_finished
drbd: Do not log an ASSERT for P_OV_REQUEST packets while C_CONNECTED
drbd: fix for possible deadlock on IO error during resync
drbd: fix unlikely access after free and list corruption
drbd: fix for spurious fullsync (uuids rotated too fast)
drbd: allow for explicit resync-finished notifications
drbd: preparation commit, using full state in receive_state()
drbd: drbd_send_ack_dp must not rely on header information
drbd: Fix regression in recv_bm_rle_bits (compressed bitmap)
drbd: Fixed a stupid copy and paste error
drbd: Allow larger values for c-fill-target.
Fix up trivial conflict in drivers/block/ataflop.c due to BKL removal
* 'for-2.6.37/core' of git://git.kernel.dk/linux-2.6-block: (39 commits)
cfq-iosched: Fix a gcc 4.5 warning and put some comments
block: Turn bvec_k{un,}map_irq() into static inline functions
block: fix accounting bug on cross partition merges
block: Make the integrity mapped property a bio flag
block: Fix double free in blk_integrity_unregister
block: Ensure physical block size is unsigned int
blkio-throttle: Fix possible multiplication overflow in iops calculations
blkio-throttle: limit max iops value to UINT_MAX
blkio-throttle: There is no need to convert jiffies to milli seconds
blkio-throttle: Fix link failure failure on i386
blkio: Recalculate the throttled bio dispatch time upon throttle limit change
blkio: Add root group to td->tg_list
blkio: deletion of a cgroup was causes oops
blkio: Do not export throttle files if CONFIG_BLK_DEV_THROTTLING=n
block: set the bounce_pfn to the actual DMA limit rather than to max memory
block: revert bad fix for memory hotplug causing bounces
Fix compile error in blk-exec.c for !CONFIG_DETECT_HUNG_TASK
block: Prevent hang_check firing during long I/O
cfq: improve fsync performance for small files
Fix up trivial conflicts due to __rcu sparse annotation in include/linux/genhd.h
Fix the following sparse warnings:
kdb_main.c:328:5: warning: symbol 'kdbgetu64arg' was not declared. Should it be static?
kgdboc.c:246:12: warning: symbol 'kgdboc_early_init' was not declared. Should it be static?
kgdb.c:652:26: warning: incorrect type in argument 1 (different address spaces)
kgdb.c:652:26: expected void const *ptr
kgdb.c:652:26: got struct perf_event *[noderef] <asn:3>*pev
The one in kgdb.c required the (void * __force) because of the return
code from register_wide_hw_breakpoint looking like:
return (void __percpu __force *)ERR_PTR(err);
Signed-off-by: Jason Wessel <jason.wessel@windriver.com>
In order to allow kernel modules to dynamically add a command to the
kdb shell the kdb_register, kdb_register_repeat, kdb_unregister, and
kdb_printf need to be exported as GPL symbols.
Any kernel module that adds a dynamic kdb shell function should only
need to include linux/kdb.h.
* git://git.kernel.org/pub/scm/linux/kernel/git/arnd/asm-generic:
asm-generic/io.h: allow people to override individual funcs
bitops: remove duplicated extern declarations
bitops: make asm-generic/bitops/find.h more generic
asm-generic: kdebug.h: Checkpatch cleanup
asm-generic: fcntl: make exported headers use strict posix types
asm-generic: cmpxchg does not handle non-long arguments
asm-generic: make atomic_add_unless a function
* 'llseek' of git://git.kernel.org/pub/scm/linux/kernel/git/arnd/bkl:
vfs: make no_llseek the default
vfs: don't use BKL in default_llseek
llseek: automatically add .llseek fop
libfs: use generic_file_llseek for simple_attr
mac80211: disallow seeks in minstrel debug code
lirc: make chardev nonseekable
viotape: use noop_llseek
raw: use explicit llseek file operations
ibmasmfs: use generic_file_llseek
spufs: use llseek in all file operations
arm/omap: use generic_file_llseek in iommu_debug
lkdtm: use generic_file_llseek in debugfs
net/wireless: use generic_file_llseek in debugfs
drm: use noop_llseek
* 'vfs' of git://git.kernel.org/pub/scm/linux/kernel/git/arnd/bkl: (30 commits)
BKL: remove BKL from freevxfs
BKL: remove BKL from qnx4
autofs4: Only declare function when CONFIG_COMPAT is defined
autofs: Only declare function when CONFIG_COMPAT is defined
ncpfs: Lock socket in ncpfs while setting its callbacks
fs/locks.c: prepare for BKL removal
BKL: Remove BKL from ncpfs
BKL: Remove BKL from OCFS2
BKL: Remove BKL from squashfs
BKL: Remove BKL from jffs2
BKL: Remove BKL from ecryptfs
BKL: Remove BKL from afs
BKL: Remove BKL from USB gadgetfs
BKL: Remove BKL from autofs4
BKL: Remove BKL from isofs
BKL: Remove BKL from fat
BKL: Remove BKL from ext2 filesystem
BKL: Remove BKL from do_new_mount()
BKL: Remove BKL from cgroup
BKL: Remove BKL from NTFS
* 'config' of git://git.kernel.org/pub/scm/linux/kernel/git/arnd/bkl:
BKL: introduce CONFIG_BKL.
dabusb: remove the BKL
sunrpc: remove the big kernel lock
init/main.c: remove BKL notations
blktrace: remove the big kernel lock
rtmutex-tester: make it build without BKL
dvb-core: kill the big kernel lock
dvb/bt8xx: kill the big kernel lock
tlclk: remove big kernel lock
fix rawctl compat ioctls breakage on amd64 and itanic
uml: kill big kernel lock
parisc: remove big kernel lock
cris: autoconvert trivial BKL users
alpha: kill big kernel lock
isapnp: BKL removal
s390/block: kill the big kernel lock
hpet: kill BKL, add compat_ioctl
this patch gives the possibility to workaround bug ENGcm09152
on i.MX35 when the hardware workaround is also implemented on
the board.
It covers the workaround described on page 25 of the following Errata :
http://cache.freescale.com/files/dsp/doc/errata/IMX35CE.pdf
Signed-off-by: Eric Bénard <eric@eukrea.com>
Adding SuperSpeed usb definitions as defined by ch9 of the USB3.0 spec.
This patch is a preparation for adding SuperSpeed support to the gadget
framework.
Signed-off-by: Tatyana Brokhman <tlinder@codeaurora.org>
Some Rockbox based mp4 players will crash when ever they see a
read_capacity_16 scsi command. So add a new US_FL which tells the scsi sd
driver to not issue any read_capacity_16 scsi commands.
Cc: James Bottomley <James.Bottomley@HansenPartnership.com>
Cc: Alan Stern <stern@rowland.harvard.edu>
Cc: Matthew Dharm <mdharm-usb@one-eyed-alien.net>
Appotech ax3003 (the larger brother of the ax203) based devices are even
more buggy then the ax203. They will go of into lala land when ever they
see a READ_DISC_INFO scsi command. So add a new US_FL which tells the
scsi sr driver to not issue any READ_DISC_INFO scsi commands.
[akpm@linux-foundation.org: fix build]
Split unmap_urb_for_dma() to allow just the setup buffer
to be unmapped. This allows HCDs to use PIO for the setup
buffer if it is not suitable for DMA.
Signed-off-by: Martin Fuzzey <mfuzzey@gmail.com>
Extends FSL EHCI platform driver glue layer to support
MPC5121 USB controllers. MPC5121 Rev 2.0 silicon EHCI
registers are in big endian format. The appropriate flags
are set using the information in the platform data structure.
MPC83xx system interface registers are not available on
MPC512x, so the access to these registers is isolated in
MPC512x case. Furthermore the USB controller clocks
must be enabled before 512x register accesses which is
done by providing platform specific init callback.
The MPC512x internal USB PHY doesn't provide supply voltage.
For boards using different power switches allow specifying
DRVVBUS and PWR_FAULT signal polarity of the MPC5121 internal
PHY using "fsl,invert-drvvbus" and "fsl,invert-pwr-fault"
properties in the device tree USB nodes. Adds documentation
for this new device tree bindings.
Cc: Grant Likely <grant.likely@secretlab.ca>
Add empty functions for get/put transceiver functions too, so that
drivers that optionally use them can call them without worrying that
they might not exist, eliminating ifdefs.
Signed-off-by: Grazvydas Ignotas <notasas@gmail.com>
Acked-by: Felipe Balbi <balbi@ti.com>
The USB stack maps the buffer for DMA if the controller supports DMA.
MUSB controller can perform DMA as well as PIO transfers.
The buffer needs to be unmapped before CPU can perform
PIO data transfers.
Export unmap_urb_for_dma() so that drivers can perform
the DMA unmapping in a sane way.
Signed-off-by: Maulik Mankad <x0082077@ti.com>
Acked-by: Alan Stern <stern@rowland.harvard.edu>
Signed-off-by: Felipe Balbi <balbi@ti.com>
The libusual header file is hard to use from code that isn't part
of libusual. As the comment suggests, these definitions are moved to
their own header file, paralleling other USB classes.
Signed-off-by: Matthew Wilcox <willy@linux.intel.com>
[mina86@mina86.com: updated to use USB_ prefix and added #include guard]
Signed-off-by: Michal Nazarewicz <mina86@mina86.com>
index 0000000..d7fc910
This commit changes prefix for some of the USB mass storage
class related macros (ie. USB_SC_ for subclass and USB_PR_
for class).
Cc: Matthew Wilcox <willy@linux.intel.com>
In usb_cdc_ncm_dpe32 the fields are 32 bit long and according
to usb style (hungarian notation) should be called dwDatagramIndex
and dwDatagramLength (see CDC NCM subclass spec, 3.3.2). Actually,
they were called wDatagramIndex, wDatagramLength.
Signed-off-by: Yauheni Kaliuta <yauheni.kaliuta@nokia.com>
Make a dedicated structure for datagram pointer entry. There is no
explicit declaration in the spec, but it's used by the host
implementation and makes the structure more clear.
Add some missed constants from the spec
This reverts commit 65e0b499105ec8ff3bc4ab7680873dec20127f9d.
Since the host and gadget implementations are different, there is
no common code for the file, remove for now.
Some typos were in the initial commit, make the spelling
according to the spec.
Add some more comments.
Also change constant names according to the style of the rest
of the file
This patch updated Kconfig for langwell otg transceiver driver.
Add ipc driver(INTEL_SCU_IPC) as a dependency. Driver version is
updated too.
Signed-off-by: Hao Wu <hao.wu@intel.com>
Signed-off-by: Alan Cox <alan@linux.intel.com>
This patch adds one new header file for the common data structure used in
Intel Penwell/Langwell MID Platform OTG Transceiver drivers. After switched
to the common data structure, Langwell/Penwell OTG Transceiver driver will
provide an unified interface to host/client driver.
Reported-by: Randy Dunlap <randy.dunlap@oracle.com>
The __ref* tags may have been confusing for new kernel
developers (I was confused by them for sure) so adding a few
more sentences to comment to clear things up for people who
see those for the first time.
Signed-off-by: Michal Nazarewicz <m.nazarewicz@samsung.com>
Acked-by: Uwe Kleine-König <u.kleine-koenig@pengutronix.de>
Acked-by: Sam Ravnborg <sam@ravnborg.org>
The bind function is most of the time only called at init time so there
is no need to save a pointer to it in the configuration structure.
This fixes many section mismatches reported by modpost.
[m.nazarewicz@samsung.com: updated for -next]
Signed-off-by: Michał Nazarewicz <m.nazarewicz@samsung.com>
is no need to save a pointer to it in the composite driver structure.
To accomplish this the function to register a gadget driver takes the bind
function as a second argument. To make things clearer rename the function
to resemble platform_driver_probe.
This fixes many section mismatches like
WARNING: drivers/usb/gadget/g_printer.o(.data+0xc): Section mismatch in
reference from the variable printer_driver to the function
.init.text:printer_bind()
The variable printer_driver references
the function __init printer_bind()
All callers are fixed.
[m.nazarewicz@samsung.com: added dbgp]
The iManufatcurer, iProduct and iSerialNumber composite module
parameters were only used when the gadget driver registers
strings for manufacturer, product and serial number. If the
gadget never bothered to set corresponding fields in USB device
descriptors those module parameters are ignored.
This commit makes the parameters work even if the strings ID
have not been assigned. It also changes the way IDs are
overridden -- what IDs are overridden is now saved in
usb_composite_dev structure -- which makes it unnecessary to
modify the string tables the way previous code did.
The commit also adds a iProduct and iManufatcurer fields to the
usb_composite_device structure. If they are set, appropriate
strings are reserved and added to device descriptor. This makes
it unnecessary for gadget drivers to maintain code for setting
those. If iProduct is not set it defaults to
usb_composite_device::name; if iManufatcurer is not set
a default "<system> <release> with <gadget-name>" is used.
The last thing is that if needs_serial field of
usb_composite_device is set and user failed to provided
iSerialNumber parameter a warning is issued.
Acked-by: David Brownell <dbrownell@users.sourceforge.net>
Acked-by: Linus Walleij <linus.walleij@stericsson.com>
Signed-off-by: Praveena Nadahally <praveen.nadahally@stericsson.com>
Signed-off-by: Parirajan Muthalagu <parirajan.muthalagu@stericsson.com>
This adds support for the USB transceiver driver in the Langwell chipset used
on the Intel MID platforms. It folds up the original patch set which includes
basic support for the device, PHY low power mode (Please notice that there is
a limitation, after we drive VBus down, 2ms delay is required from SCU FW to
sync up OTGSC register with USBCFG register), software timers (the hardware
timers do not work in low power mode), HNP, SRP.
Signed-off-by: Alek Du <alek.du@intel.com>
Not every platform that has generic legacy 8250 ports manages to have them
clocked the right way or without errata. Provide a generic interface to
allow platforms to override the default behaviour in a manner that dumps
the complexity in *their* code not the 8250 driver.
Signed-off-by: Dirk Brandewie <dirk.brandewie@gmail.com>
