path: root/include/linux
2009-06-16Merge branch 'for_linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-2.6 * 'for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-2.6: (425 commits) V4L/DVB (11870): gspca - main: VIDIOC_ENUM_FRAMESIZES ioctl added. V4L/DVB (12004): poll method lose race condition V4L/DVB (11894): flexcop-pci: dmesg visible names broken V4L/DVB (11892): Siano: smsendian - declare function as extern V4L/DVB (11891): Siano: smscore - bind the GPIO SMS protocol V4L/DVB (11890): Siano: smscore - remove redundant code V4L/DVB (11889): Siano: smsdvb - add DVB v3 events V4L/DVB (11888): Siano: smsusb - remove redundant ifdef V4L/DVB (11887): Siano: smscards - add board (target) events V4L/DVB (11886): Siano: smscore - fix some new GPIO definitions names V4L/DVB (11885): Siano: Add new GPIO management interface V4L/DVB (11884): Siano: smssdio - revert to stand alone module V4L/DVB (11883): Siano: cards - add two additional (USB) devices V4L/DVB (11824): Siano: smsusb - change exit func debug msg V4L/DVB (11823): Siano: smsusb - fix typo in module description V4L/DVB (11822): Siano: smscore - bug fix at get_device_mode V4L/DVB (11821): Siano: smscore - fix isdb-t firmware name V4L/DVB (11820): Siano: smscore - fix byte ordering bug V4L/DVB (11819): Siano: smscore - fix get_common_buffer bug V4L/DVB (11818): Siano: smscards - assign gpio to HPG targets ...
2009-06-16Merge branch 'akpm'Linus Torvalds
* akpm: (182 commits) fbdev: bf54x-lq043fb: use kzalloc over kmalloc/memset fbdev: *bfin*: fix __dev{init,exit} markings fbdev: *bfin*: drop unnecessary calls to memset fbdev: bfin-t350mcqb-fb: drop unused local variables fbdev: blackfin has __raw I/O accessors, so use them in fb.h fbdev: s1d13xxxfb: add accelerated bitblt functions tcx: use standard fields for framebuffer physical address and length fbdev: add support for handoff from firmware to hw framebuffers intelfb: fix a bug when changing video timing fbdev: use framebuffer_release() for freeing fb_info structures radeon: P2G2CLK_ALWAYS_ONb tested twice, should 2nd be P2G2CLK_DAC_ALWAYS_ONb? s3c-fb: CPUFREQ frequency scaling support s3c-fb: fix resource releasing on error during probing carminefb: fix possible access beyond end of carmine_modedb[] acornfb: remove fb_mmap function mb862xxfb: use CONFIG_OF instead of CONFIG_PPC_OF mb862xxfb: restrict compliation of platform driver to PPC Samsung SoC Framebuffer driver: add Alpha Channel support atmel-lcdc: fix pixclock upper bound detection offb: use framebuffer_alloc() to allocate fb_info struct ... Manually fix up conflicts due to kmemcheck in mm/slab.c
2009-06-16fbdev: blackfin has __raw I/O accessors, so use them in fb.hMike Frysinger
Signed-off-by: Mike Frysinger <vapier@gentoo.org> Cc: Krzysztof Helt <krzysztof.h1@poczta.fm> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-06-16fbdev: add support for handoff from firmware to hw framebuffersDave Airlie
With KMS we have ran into an issue where we really want the KMS fb driver to be the one running the console, so panics etc can be shown by switching out of X etc. However with vesafb/efifb built-in, we end up with those on fb0 and the KMS fb driver on fb1, driving the same piece of hw, so this adds an fb info flag to denote a firmware fbdev, and adds a new aperture base/size range which can be compared when the hw drivers are installed to see if there is a conflict with a firmware driver, and if there is the firmware driver is unregistered and the hw driver takes over. It uses new aperture_base/size members instead of comparing on the fix smem_start/length, as smem_start/length might for example only cover the first 1MB of the PCI aperture, and we could allocate the kms fb from 8MB into the aperture, thus they would never overlap. [akpm@linux-foundation.org: coding-style fixes] Signed-off-by: Dave Airlie <airlied@redhat.com> Acked-by: Peter Jones <pjones@redhat.com> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Cc: Krzysztof Helt <krzysztof.h1@poczta.fm> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-06-16fbdev: move logo externs to header fileGeert Uytterhoeven
Now we have __initconst, we can finally move the external declarations for the various Linux logo structures to <linux/linux_logo.h>. James' ack dates back to the previous submission (way to long ago), when the logos were still __initdata, which caused failures on some platforms with some toolchain versions. Signed-off-by: Geert Uytterhoeven <Geert.Uytterhoeven@sonycom.com> Acked-by: James Simmons <jsimmons@infradead.org> Cc: Krzysztof Helt <krzysztof.h1@poczta.fm> Cc: Sam Ravnborg <sam@ravnborg.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-06-16lis3: add click functionDaniel Mack
The LIS302DL accelerometer chip has a 'click' feature which can be used to detect sudden motion on any of the three axis. Configuration data is passed via spi platform_data and no action is taken if that's not specified, so it won't harm any existing platform. To make the configuration effective, the IRQ lines need to be set up appropriately. This patch also adds a way to do that from board support code. The DD_* definitions were factored out to an own enum because they are specific to LIS3LV02D devices. Signed-off-by: Daniel Mack <daniel@caiaq.de> Acked-by: Pavel Machek <pavel@ucw.cz> Acked-by: Eric Piel <eric.piel@tremplin-utc.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-06-16drivers: add support for the TI VLYNQ busFlorian Fainelli
Add support for the TI VLYNQ high-speed, serial and packetized bus. This bus allows external devices to be connected to the System-on-Chip and appear in the main system memory just like any memory mapped peripheral. It is widely used in TI's networking and multimedia SoC, including the AR7 SoC. Signed-off-by: Eugene Konev <ejka@imfi.kspu.ru> Signed-off-by: Florian Fainelli <florian@openwrt.org> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: Alan Cox <alan@lxorguk.ukuu.org.uk> Cc: Greg KH <greg@kroah.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-06-16syscalls.h: remove duplicated declarations for sys_pipe2Masatake YAMATO
sys_pipe2 is declared twice in include/linux/syscalls.h. Signed-off-by: Masatake YAMATO <yamato@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-06-16remove put_cpu_no_resched()Thomas Gleixner
put_cpu_no_resched() is an optimization of put_cpu() which unfortunately can cause high latencies. The nfs iostats code uses put_cpu_no_resched() in a code sequence where a reschedule request caused by an interrupt between the get_cpu() and the put_cpu_no_resched() can delay the reschedule for at least HZ. The other users of put_cpu_no_resched() optimize correctly in interrupt code, but there is no real harm in using the put_cpu() function which is an alias for preempt_enable(). The extra check of the preemmpt count is not as critical as the potential source of missing a reschedule. Debugged in the preempt-rt tree and verified in mainline. Impact: remove a high latency source [akpm@linux-foundation.org: build fix] Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Acked-by: Ingo Molnar <mingo@elte.hu> Cc: Tony Luck <tony.luck@intel.com> Cc: Trond Myklebust <Trond.Myklebust@netapp.com> Cc: "J. Bruce Fields" <bfields@fieldses.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-06-16drbd: add major number to major.hPhilipp Reisner
Since we have had a LANANA major number for years, and it is documented in devices.txt, I think that this first patch can go upstream. Signed-off-by: Philipp Reisner <philipp.reisner@linbit.com> Signed-off-by: Lars Ellenberg <lars.ellenberg@linbit.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-06-16headers: move module_bug_finalize()/module_bug_cleanup() definitions into ↵Andrew Morton
module.h They're in linux/bug.h at present, which causes include order tangles. In particular, linux/bug.h cannot be used by linux/atomic.h because, according to Nikanth: linux/bug.h pulls in linux/module.h => linux/spinlock.h => asm/spinlock.h (which uses atomic_inc) => asm/atomic.h. bug.h is a pretty low-level thing and module.h is a higher-level thing, IMO. Cc: Nikanth Karthikesan <knikanth@novell.com> Cc: Rusty Russell <rusty@rustcorp.com.au> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-06-16poll: avoid extra wakeups in select/pollEric Dumazet
After introduction of keyed wakeups Davide Libenzi did on epoll, we are able to avoid spurious wakeups in poll()/select() code too. For example, typical use of poll()/select() is to wait for incoming network frames on many sockets. But TX completion for UDP/TCP frames call sock_wfree() which in turn schedules thread. When scheduled, thread does a full scan of all polled fds and can sleep again, because nothing is really available. If number of fds is large, this cause significant load. This patch makes select()/poll() aware of keyed wakeups and useless wakeups are avoided. This reduces number of context switches by about 50% on some setups, and work performed by sofirq handlers. Signed-off-by: Eric Dumazet <dada1@cosmosbay.com> Acked-by: David S. Miller <davem@davemloft.net> Acked-by: Andi Kleen <ak@linux.intel.com> Acked-by: Ingo Molnar <mingo@elte.hu> Acked-by: Davide Libenzi <davidel@xmailserver.org> Cc: Christoph Lameter <cl@linux-foundation.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-06-16utsname.h: make new_utsname fields use the proper length constantDan Smith
The members of the new_utsname structure are defined with magic numbers that *should* correspond to the constant __NEW_UTS_LEN+1. Everywhere else, code assumes this and uses the constant, so this patch makes the structure match. Originally suggested by Serge here: https://lists.linux-foundation.org/pipermail/containers/2009-March/016258.html Signed-off-by: Dan Smith <danms@us.ibm.com> Acked-by: Serge Hallyn <serue@us.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-06-16vmscan: count the number of times zone_reclaim() scans and failsMel Gorman
On NUMA machines, the administrator can configure zone_reclaim_mode that is a more targetted form of direct reclaim. On machines with large NUMA distances for example, a zone_reclaim_mode defaults to 1 meaning that clean unmapped pages will be reclaimed if the zone watermarks are not being met. There is a heuristic that determines if the scan is worthwhile but it is possible that the heuristic will fail and the CPU gets tied up scanning uselessly. Detecting the situation requires some guesswork and experimentation so this patch adds a counter "zreclaim_failed" to /proc/vmstat. If during high CPU utilisation this counter is increasing rapidly, then the resolution to the problem may be to set /proc/sys/vm/zone_reclaim_mode to 0. [akpm@linux-foundation.org: name things consistently] Signed-off-by: Mel Gorman <mel@csn.ul.ie> Reviewed-by: Rik van Riel <riel@redhat.com> Cc: Christoph Lameter <cl@linux-foundation.org> Reviewed-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Cc: Wu Fengguang <fengguang.wu@intel.com> Cc: <stable@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-06-16vmscan: report vm_flags in page_referenced()Wu Fengguang
Collect vma->vm_flags of the VMAs that actually referenced the page. This is preparing for more informed reclaim heuristics, eg. to protect executable file pages more aggressively. For now only the VM_EXEC bit will be used by the caller. Thanks to Johannes, Peter and Minchan for all the good tips. Acked-by: Peter Zijlstra <peterz@infradead.org> Reviewed-by: Rik van Riel <riel@redhat.com> Reviewed-by: Minchan Kim <minchan.kim@gmail.com> Reviewed-by: Johannes Weiner <hannes@cmpxchg.org> Signed-off-by: Wu Fengguang <fengguang.wu@intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-06-16mm cleanup: shmem_file_setup: 'char *' -> 'const char *' for name argumentSergei Trofimovich
As function shmem_file_setup does not modify/allocate/free/pass given filename - mark it as const. Signed-off-by: Sergei Trofimovich <slyfox@inbox.ru> Cc: Hugh Dickins <hugh.dickins@tiscali.co.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-06-16mm: remove file argument from swap_readpage()Minchan Kim
The file argument resulted from address_space's readpage long time ago. We don't use it any more. Let's remove unnecessary argement. Signed-off-by: Minchan Kim <minchan.kim@gmail.com> Acked-by: Hugh Dickins <hugh.dickins@tiscali.co.uk> Reviewed-by: Rik van Riel <riel@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-06-16mm: remove __invalidate_mapping_pages variantMike Waychison
Remove __invalidate_mapping_pages atomic variant now that its sole caller can sleep (fixed in eccb95cee4f0d56faa46ef22fb94dd4a3578d3eb ("vfs: fix lock inversion in drop_pagecache_sb()")). This fixes softlockups that can occur while in the drop_caches path. Signed-off-by: Mike Waychison <mikew@google.com> Cc: Jan Kara <jack@suse.cz> Cc: Wu Fengguang <fengguang.wu@intel.com> Cc: Dave Chinner <david@fromorbit.com> Cc: Nick Piggin <nickpiggin@yahoo.com.au> Acked-by: Jan Kara <jack@suse.cz> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-06-16oom: move oom_adj value from task_struct to mm_structDavid Rientjes
The per-task oom_adj value is a characteristic of its mm more than the task itself since it's not possible to oom kill any thread that shares the mm. If a task were to be killed while attached to an mm that could not be freed because another thread were set to OOM_DISABLE, it would have needlessly been terminated since there is no potential for future memory freeing. This patch moves oomkilladj (now more appropriately named oom_adj) from struct task_struct to struct mm_struct. This requires task_lock() on a task to check its oom_adj value to protect against exec, but it's already necessary to take the lock when dereferencing the mm to find the total VM size for the badness heuristic. This fixes a livelock if the oom killer chooses a task and another thread sharing the same memory has an oom_adj value of OOM_DISABLE. This occurs because oom_kill_task() repeatedly returns 1 and refuses to kill the chosen task while select_bad_process() will repeatedly choose the same task during the next retry. Taking task_lock() in select_bad_process() to check for OOM_DISABLE and in oom_kill_task() to check for threads sharing the same memory will be removed in the next patch in this series where it will no longer be necessary. Writing to /proc/pid/oom_adj for a kthread will now return -EINVAL since these threads are immune from oom killing already. They simply report an oom_adj value of OOM_DISABLE. Cc: Nick Piggin <npiggin@suse.de> Cc: Rik van Riel <riel@redhat.com> Cc: Mel Gorman <mel@csn.ul.ie> Signed-off-by: David Rientjes <rientjes@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-06-16mm: modify swap_map and add SWAP_HAS_CACHE flagKAMEZAWA Hiroyuki
This is a part of the patches for fixing memcg's swap accountinf leak. But, IMHO, not a bad patch even if no memcg. There are 2 kinds of references to swap. - reference from swap entry - reference from swap cache Then, - If there is swap cache && swap's refcnt is 1, there is only swap cache. (*) swapcount(entry) == 1 && find_get_page(swapper_space, entry) != NULL This counting logic have worked well for a long time. But considering that we cannot know there is a _real_ reference or not by swap_map[], current usage of counter is not very good. This patch adds a flag SWAP_HAS_CACHE and recored information that a swap entry has a cache or not. This will remove -1 magic used in swapfile.c and be a help to avoid unnecessary find_get_page(). Signed-off-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Tested-by: Daisuke Nishimura <nishimura@mxp.nes.nec.co.jp> Cc: Balbir Singh <balbir@in.ibm.com> Cc: Hugh Dickins <hugh.dickins@tiscali.co.uk> Cc: Johannes Weiner <hannes@cmpxchg.org> Cc: Li Zefan <lizf@cn.fujitsu.com> Cc: Dhaval Giani <dhaval@linux.vnet.ibm.com> Cc: YAMAMOTO Takashi <yamamoto@valinux.co.jp> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-06-16mm: add swap cache interface for swap referenceKAMEZAWA Hiroyuki
In a following patch, the usage of swap cache is recorded into swap_map. This patch is for necessary interface changes to do that. 2 interfaces: - swapcache_prepare() - swapcache_free() are added for allocating/freeing refcnt from swap-cache to existing swap entries. But implementation itself is not changed under this patch. At adding swapcache_free(), memcg's hook code is moved under swapcache_free(). This is better than using scattered hooks. Signed-off-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Reviewed-by: Daisuke Nishimura <nishimura@mxp.nes.nec.co.jp> Acked-by: Balbir Singh <balbir@in.ibm.com> Cc: Hugh Dickins <hugh.dickins@tiscali.co.uk> Cc: Johannes Weiner <hannes@cmpxchg.org> Cc: Li Zefan <lizf@cn.fujitsu.com> Cc: Dhaval Giani <dhaval@linux.vnet.ibm.com> Cc: YAMAMOTO Takashi <yamamoto@valinux.co.jp> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-06-16mm: remove CONFIG_UNEVICTABLE_LRU config optionKOSAKI Motohiro
Currently, nobody wants to turn UNEVICTABLE_LRU off. Thus this configurability is unnecessary. Signed-off-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Cc: Johannes Weiner <hannes@cmpxchg.org> Cc: Andi Kleen <andi@firstfloor.org> Acked-by: Minchan Kim <minchan.kim@gmail.com> Cc: David Woodhouse <dwmw2@infradead.org> Cc: Matt Mackall <mpm@selenic.com> Cc: Rik van Riel <riel@redhat.com> Cc: Lee Schermerhorn <lee.schermerhorn@hp.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-06-16page-allocator: add inactive ratio calculation function of each zoneMinchan Kim
Factor the per-zone arithemetic inside setup_per_zone_inactive_ratio()'s loop into a a separate function, calculate_zone_inactive_ratio(). This function will be used in a later patch [akpm@linux-foundation.org: coding-style fixes] Signed-off-by: Minchan Kim <minchan.kim@gmail.com> Reviewed-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Cc: Rik van Riel <riel@redhat.com> Cc: Johannes Weiner <hannes@cmpxchg.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-06-16page-allocator: clean up functions related to pages_minMinchan Kim
Change the names of two functions. It doesn't affect behavior. Presently, setup_per_zone_pages_min() changes low, high of zone as well as min. So a better name is setup_per_zone_wmarks(). That's because Mel changed zone->pages_[hig/low/min] to zone->watermark array in "page allocator: replace the watermark-related union in struct zone with a watermark[] array". * setup_per_zone_pages_min => setup_per_zone_wmarks Of course, we have to change init_per_zone_pages_min, too. There are not pages_min any more. * init_per_zone_pages_min => init_per_zone_wmark_min [akpm@linux-foundation.org: coding-style fixes] Signed-off-by: Minchan Kim <minchan.kim@gmail.com> Acked-by: Mel Gorman <mel@csn.ul.ie> Cc: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Cc: Rik van Riel <riel@redhat.com> Cc: Johannes Weiner <hannes@cmpxchg.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-06-16page-allocator: use integer fields lookup for gfp_zone and check for errors ↵Christoph Lameter
in flags passed to the page allocator This simplifies the code in gfp_zone() and also keeps the ability of the compiler to use constant folding to get rid of gfp_zone processing. The lookup of the zone is done using a bitfield stored in an integer. So the code in gfp_zone is a simple extraction of bits from a constant bitfield. The compiler is generating a load of a constant into a register and then performs a shift and mask operation to get the zone from a gfp_t. No cachelines are touched and no branches have to be predicted by the compiler. We are doing some macro tricks here to convince the compiler to always do the constant folding if possible. Signed-off-by: Christoph Lameter <cl@linux-foundation.org> Cc: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Reviewed-by: Mel Gorman <mel@csn.ul.ie> Cc: Nick Piggin <nickpiggin@yahoo.com.au> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-06-16mm: check the argument of kunmap on architectures without highmemMatthew Wilcox
If you're using a non-highmem architecture, passing an argument with the wrong type to kunmap() doesn't give you a warning because the ifdef doesn't check the type. Using a static inline function solves the problem nicely. Reported-by: David Woodhouse <dwmw2@infradead.org> Signed-off-by: Matthew Wilcox <willy@linux.intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-06-16mm, PM/Freezer: Disable OOM killer when tasks are frozenRafael J. Wysocki
Currently, the following scenario appears to be possible in theory: * Tasks are frozen for hibernation or suspend. * Free pages are almost exhausted. * Certain piece of code in the suspend code path attempts to allocate some memory using GFP_KERNEL and allocation order less than or equal to PAGE_ALLOC_COSTLY_ORDER. * __alloc_pages_internal() cannot find a free page so it invokes the OOM killer. * The OOM killer attempts to kill a task, but the task is frozen, so it doesn't die immediately. * __alloc_pages_internal() jumps to 'restart', unsuccessfully tries to find a free page and invokes the OOM killer. * No progress can be made. Although it is now hard to trigger during hibernation due to the memory shrinking carried out by the hibernation code, it is theoretically possible to trigger during suspend after the memory shrinking has been removed from that code path. Moreover, since memory allocations are going to be used for the hibernation memory shrinking, it will be even more likely to happen during hibernation. To prevent it from happening, introduce the oom_killer_disabled switch that will cause __alloc_pages_internal() to fail in the situations in which the OOM killer would have been called and make the freezer set this switch after tasks have been successfully frozen. [akpm@linux-foundation.org: be nicer to the namespace] Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Cc: Fengguang Wu <fengguang.wu@gmail.com> Cc: David Rientjes <rientjes@google.com> Acked-by: Pavel Machek <pavel@ucw.cz> Cc: Mel Gorman <mel@csn.ul.ie> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-06-16mm: introduce follow_pfn()Johannes Weiner
Analoguous to follow_phys(), add a helper that looks up the PFN at a user virtual address in an IO mapping or a raw PFN mapping. Signed-off-by: Johannes Weiner <hannes@cmpxchg.org> Cc: Christoph Hellwig <hch@infradead.org> Acked-by: Magnus Damm <magnus.damm@gmail.com> Cc: Hans Verkuil <hverkuil@xs4all.nl> Cc: Paul Mundt <lethal@linux-sh.org> Cc: Hugh Dickins <hugh.dickins@tiscali.co.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-06-16vmscan: cleanup the scan batching codeWu Fengguang
The vmscan batching logic is twisting. Move it into a standalone function nr_scan_try_batch() and document it. No behavior change. Signed-off-by: Wu Fengguang <fengguang.wu@intel.com> Acked-by: Rik van Riel <riel@redhat.com> Cc: Nick Piggin <npiggin@suse.de> Cc: Christoph Lameter <cl@linux-foundation.org> Acked-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Acked-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-06-16vmscan: evict use-once pages firstRik van Riel
When the file LRU lists are dominated by streaming IO pages, evict those pages first, before considering evicting other pages. This should be safe from deadlocks or performance problems because only three things can happen to an inactive file page: 1) referenced twice and promoted to the active list 2) evicted by the pageout code 3) under IO, after which it will get evicted or promoted The pages freed in this way can either be reused for streaming IO, or allocated for something else. If the pages are used for streaming IO, this pageout pattern continues. Otherwise, we will fall back to the normal pageout pattern. Signed-off-by: Rik van Riel <riel@redhat.com> Reported-by: Elladan <elladan@eskimo.com> Cc: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Lee Schermerhorn <lee.schermerhorn@hp.com> Acked-by: Johannes Weiner <hannes@cmpxchg.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-06-16mm: introduce PageHuge() for testing huge/gigantic pagesWu Fengguang
A series of patches to enhance the /proc/pagemap interface and to add a userspace executable which can be used to present the pagemap data. Export 10 more flags to end users (and more for kernel developers): 11. KPF_MMAP (pseudo flag) memory mapped page 12. KPF_ANON (pseudo flag) memory mapped page (anonymous) 13. KPF_SWAPCACHE page is in swap cache 14. KPF_SWAPBACKED page is swap/RAM backed 15. KPF_COMPOUND_HEAD (*) 16. KPF_COMPOUND_TAIL (*) 17. KPF_HUGE hugeTLB pages 18. KPF_UNEVICTABLE page is in the unevictable LRU list 19. KPF_HWPOISON hardware detected corruption 20. KPF_NOPAGE (pseudo flag) no page frame at the address (*) For compound pages, exporting _both_ head/tail info enables users to tell where a compound page starts/ends, and its order. a simple demo of the page-types tool # ./page-types -h page-types [options] -r|--raw Raw mode, for kernel developers -a|--addr addr-spec Walk a range of pages -b|--bits bits-spec Walk pages with specified bits -l|--list Show page details in ranges -L|--list-each Show page details one by one -N|--no-summary Don't show summay info -h|--help Show this usage message addr-spec: N one page at offset N (unit: pages) N+M pages range from N to N+M-1 N,M pages range from N to M-1 N, pages range from N to end ,M pages range from 0 to M bits-spec: bit1,bit2 (flags & (bit1|bit2)) != 0 bit1,bit2=bit1 (flags & (bit1|bit2)) == bit1 bit1,~bit2 (flags & (bit1|bit2)) == bit1 =bit1,bit2 flags == (bit1|bit2) bit-names: locked error referenced uptodate dirty lru active slab writeback reclaim buddy mmap anonymous swapcache swapbacked compound_head compound_tail huge unevictable hwpoison nopage reserved(r) mlocked(r) mappedtodisk(r) private(r) private_2(r) owner_private(r) arch(r) uncached(r) readahead(o) slob_free(o) slub_frozen(o) slub_debug(o) (r) raw mode bits (o) overloaded bits # ./page-types flags page-count MB symbolic-flags long-symbolic-flags 0x0000000000000000 487369 1903 _________________________________ 0x0000000000000014 5 0 __R_D____________________________ referenced,dirty 0x0000000000000020 1 0 _____l___________________________ lru 0x0000000000000024 34 0 __R__l___________________________ referenced,lru 0x0000000000000028 3838 14 ___U_l___________________________ uptodate,lru 0x0001000000000028 48 0 ___U_l_______________________I___ uptodate,lru,readahead 0x000000000000002c 6478 25 __RU_l___________________________ referenced,uptodate,lru 0x000100000000002c 47 0 __RU_l_______________________I___ referenced,uptodate,lru,readahead 0x0000000000000040 8344 32 ______A__________________________ active 0x0000000000000060 1 0 _____lA__________________________ lru,active 0x0000000000000068 348 1 ___U_lA__________________________ uptodate,lru,active 0x0001000000000068 12 0 ___U_lA______________________I___ uptodate,lru,active,readahead 0x000000000000006c 988 3 __RU_lA__________________________ referenced,uptodate,lru,active 0x000100000000006c 48 0 __RU_lA______________________I___ referenced,uptodate,lru,active,readahead 0x0000000000004078 1 0 ___UDlA_______b__________________ uptodate,dirty,lru,active,swapbacked 0x000000000000407c 34 0 __RUDlA_______b__________________ referenced,uptodate,dirty,lru,active,swapbacked 0x0000000000000400 503 1 __________B______________________ buddy 0x0000000000000804 1 0 __R________M_____________________ referenced,mmap 0x0000000000000828 1029 4 ___U_l_____M_____________________ uptodate,lru,mmap 0x0001000000000828 43 0 ___U_l_____M_________________I___ uptodate,lru,mmap,readahead 0x000000000000082c 382 1 __RU_l_____M_____________________ referenced,uptodate,lru,mmap 0x000100000000082c 12 0 __RU_l_____M_________________I___ referenced,uptodate,lru,mmap,readahead 0x0000000000000868 192 0 ___U_lA____M_____________________ uptodate,lru,active,mmap 0x0001000000000868 12 0 ___U_lA____M_________________I___ uptodate,lru,active,mmap,readahead 0x000000000000086c 800 3 __RU_lA____M_____________________ referenced,uptodate,lru,active,mmap 0x000100000000086c 31 0 __RU_lA____M_________________I___ referenced,uptodate,lru,active,mmap,readahead 0x0000000000004878 2 0 ___UDlA____M__b__________________ uptodate,dirty,lru,active,mmap,swapbacked 0x0000000000001000 492 1 ____________a____________________ anonymous 0x0000000000005808 4 0 ___U_______Ma_b__________________ uptodate,mmap,anonymous,swapbacked 0x0000000000005868 2839 11 ___U_lA____Ma_b__________________ uptodate,lru,active,mmap,anonymous,swapbacked 0x000000000000586c 30 0 __RU_lA____Ma_b__________________ referenced,uptodate,lru,active,mmap,anonymous,swapbacked total 513968 2007 # ./page-types -r flags page-count MB symbolic-flags long-symbolic-flags 0x0000000000000000 468002 1828 _________________________________ 0x0000000100000000 19102 74 _____________________r___________ reserved 0x0000000000008000 41 0 _______________H_________________ compound_head 0x0000000000010000 188 0 ________________T________________ compound_tail 0x0000000000008014 1 0 __R_D__________H_________________ referenced,dirty,compound_head 0x0000000000010014 4 0 __R_D___________T________________ referenced,dirty,compound_tail 0x0000000000000020 1 0 _____l___________________________ lru 0x0000000800000024 34 0 __R__l__________________P________ referenced,lru,private 0x0000000000000028 3794 14 ___U_l___________________________ uptodate,lru 0x0001000000000028 46 0 ___U_l_______________________I___ uptodate,lru,readahead 0x0000000400000028 44 0 ___U_l_________________d_________ uptodate,lru,mappedtodisk 0x0001000400000028 2 0 ___U_l_________________d_____I___ uptodate,lru,mappedtodisk,readahead 0x000000000000002c 6434 25 __RU_l___________________________ referenced,uptodate,lru 0x000100000000002c 47 0 __RU_l_______________________I___ referenced,uptodate,lru,readahead 0x000000040000002c 14 0 __RU_l_________________d_________ referenced,uptodate,lru,mappedtodisk 0x000000080000002c 30 0 __RU_l__________________P________ referenced,uptodate,lru,private 0x0000000800000040 8124 31 ______A_________________P________ active,private 0x0000000000000040 219 0 ______A__________________________ active 0x0000000800000060 1 0 _____lA_________________P________ lru,active,private 0x0000000000000068 322 1 ___U_lA__________________________ uptodate,lru,active 0x0001000000000068 12 0 ___U_lA______________________I___ uptodate,lru,active,readahead 0x0000000400000068 13 0 ___U_lA________________d_________ uptodate,lru,active,mappedtodisk 0x0000000800000068 12 0 ___U_lA_________________P________ uptodate,lru,active,private 0x000000000000006c 977 3 __RU_lA__________________________ referenced,uptodate,lru,active 0x000100000000006c 48 0 __RU_lA______________________I___ referenced,uptodate,lru,active,readahead 0x000000040000006c 5 0 __RU_lA________________d_________ referenced,uptodate,lru,active,mappedtodisk 0x000000080000006c 3 0 __RU_lA_________________P________ referenced,uptodate,lru,active,private 0x0000000c0000006c 3 0 __RU_lA________________dP________ referenced,uptodate,lru,active,mappedtodisk,private 0x0000000c00000068 1 0 ___U_lA________________dP________ uptodate,lru,active,mappedtodisk,private 0x0000000000004078 1 0 ___UDlA_______b__________________ uptodate,dirty,lru,active,swapbacked 0x000000000000407c 34 0 __RUDlA_______b__________________ referenced,uptodate,dirty,lru,active,swapbacked 0x0000000000000400 538 2 __________B______________________ buddy 0x0000000000000804 1 0 __R________M_____________________ referenced,mmap 0x0000000000000828 1029 4 ___U_l_____M_____________________ uptodate,lru,mmap 0x0001000000000828 43 0 ___U_l_____M_________________I___ uptodate,lru,mmap,readahead 0x000000000000082c 382 1 __RU_l_____M_____________________ referenced,uptodate,lru,mmap 0x000100000000082c 12 0 __RU_l_____M_________________I___ referenced,uptodate,lru,mmap,readahead 0x0000000000000868 192 0 ___U_lA____M_____________________ uptodate,lru,active,mmap 0x0001000000000868 12 0 ___U_lA____M_________________I___ uptodate,lru,active,mmap,readahead 0x000000000000086c 800 3 __RU_lA____M_____________________ referenced,uptodate,lru,active,mmap 0x000100000000086c 31 0 __RU_lA____M_________________I___ referenced,uptodate,lru,active,mmap,readahead 0x0000000000004878 2 0 ___UDlA____M__b__________________ uptodate,dirty,lru,active,mmap,swapbacked 0x0000000000001000 492 1 ____________a____________________ anonymous 0x0000000000005008 2 0 ___U________a_b__________________ uptodate,anonymous,swapbacked 0x0000000000005808 4 0 ___U_______Ma_b__________________ uptodate,mmap,anonymous,swapbacked 0x000000000000580c 1 0 __RU_______Ma_b__________________ referenced,uptodate,mmap,anonymous,swapbacked 0x0000000000005868 2839 11 ___U_lA____Ma_b__________________ uptodate,lru,active,mmap,anonymous,swapbacked 0x000000000000586c 29 0 __RU_lA____Ma_b__________________ referenced,uptodate,lru,active,mmap,anonymous,swapbacked total 513968 2007 # ./page-types --raw --list --no-summary --bits reserved offset count flags 0 15 _____________________r___________ 31 4 _____________________r___________ 159 97 _____________________r___________ 4096 2067 _____________________r___________ 6752 2390 _____________________r___________ 9355 3 _____________________r___________ 9728 14526 _____________________r___________ This patch: Introduce PageHuge(), which identifies huge/gigantic pages by their dedicated compound destructor functions. Also move prep_compound_gigantic_page() to hugetlb.c and make __free_pages_ok() non-static. Signed-off-by: Wu Fengguang <fengguang.wu@intel.com> Cc: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Cc: Andi Kleen <andi@firstfloor.org> Cc: Matt Mackall <mpm@selenic.com> Cc: Alexey Dobriyan <adobriyan@gmail.com> Cc: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-06-16page allocator: use a pre-calculated value instead of num_online_nodes() in ↵Christoph Lameter
fast paths num_online_nodes() is called in a number of places but most often by the page allocator when deciding whether the zonelist needs to be filtered based on cpusets or the zonelist cache. This is actually a heavy function and touches a number of cache lines. This patch stores the number of online nodes at boot time and updates the value when nodes get onlined and offlined. The value is then used in a number of important paths in place of num_online_nodes(). [rientjes@google.com: do not override definition of node_set_online() with macro] Signed-off-by: Christoph Lameter <cl@linux-foundation.org> Signed-off-by: Mel Gorman <mel@csn.ul.ie> Cc: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Cc: Pekka Enberg <penberg@cs.helsinki.fi> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Nick Piggin <nickpiggin@yahoo.com.au> Cc: Dave Hansen <dave@linux.vnet.ibm.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com> Signed-off-by: David Rientjes <rientjes@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-06-16page allocator: use allocation flags as an index to the zone watermarkMel Gorman
ALLOC_WMARK_MIN, ALLOC_WMARK_LOW and ALLOC_WMARK_HIGH determin whether pages_min, pages_low or pages_high is used as the zone watermark when allocating the pages. Two branches in the allocator hotpath determine which watermark to use. This patch uses the flags as an array index into a watermark array that is indexed with WMARK_* defines accessed via helpers. All call sites that use zone->pages_* are updated to use the helpers for accessing the values and the array offsets for setting. Signed-off-by: Mel Gorman <mel@csn.ul.ie> Reviewed-by: Christoph Lameter <cl@linux-foundation.org> Cc: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Cc: Pekka Enberg <penberg@cs.helsinki.fi> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Nick Piggin <nickpiggin@yahoo.com.au> Cc: Dave Hansen <dave@linux.vnet.ibm.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-06-16page allocator: move check for disabled anti-fragmentation out of fastpathMel Gorman
On low-memory systems, anti-fragmentation gets disabled as there is nothing it can do and it would just incur overhead shuffling pages between lists constantly. Currently the check is made in the free page fast path for every page. This patch moves it to a slow path. On machines with low memory, there will be small amount of additional overhead as pages get shuffled between lists but it should quickly settle. Signed-off-by: Mel Gorman <mel@csn.ul.ie> Reviewed-by: Christoph Lameter <cl@linux-foundation.org> Reviewed-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Cc: Pekka Enberg <penberg@cs.helsinki.fi> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Nick Piggin <nickpiggin@yahoo.com.au> Cc: Dave Hansen <dave@linux.vnet.ibm.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-06-16page allocator: do not check NUMA node ID when the caller knows the node is ↵Mel Gorman
valid Callers of alloc_pages_node() can optionally specify -1 as a node to mean "allocate from the current node". However, a number of the callers in fast paths know for a fact their node is valid. To avoid a comparison and branch, this patch adds alloc_pages_exact_node() that only checks the nid with VM_BUG_ON(). Callers that know their node is valid are then converted. Signed-off-by: Mel Gorman <mel@csn.ul.ie> Reviewed-by: Christoph Lameter <cl@linux-foundation.org> Reviewed-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Reviewed-by: Pekka Enberg <penberg@cs.helsinki.fi> Acked-by: Paul Mundt <lethal@linux-sh.org> [for the SLOB NUMA bits] Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Nick Piggin <nickpiggin@yahoo.com.au> Cc: Dave Hansen <dave@linux.vnet.ibm.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-06-16page allocator: do not sanity check order in the fast pathMel Gorman
No user of the allocator API should be passing in an order >= MAX_ORDER but we check for it on each and every allocation. Delete this check and make it a VM_BUG_ON check further down the call path. [akpm@linux-foundation.org: s/VM_BUG_ON/WARN_ON_ONCE/] Signed-off-by: Mel Gorman <mel@csn.ul.ie> Reviewed-by: Christoph Lameter <cl@linux-foundation.org> Reviewed-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Reviewed-by: Pekka Enberg <penberg@cs.helsinki.fi> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Nick Piggin <nickpiggin@yahoo.com.au> Cc: Dave Hansen <dave@linux.vnet.ibm.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-06-16page allocator: replace __alloc_pages_internal() with __alloc_pages_nodemask()Mel Gorman
The start of a large patch series to clean up and optimise the page allocator. The performance improvements are in a wide range depending on the exact machine but the results I've seen so fair are approximately; kernbench: 0 to 0.12% (elapsed time) 0.49% to 3.20% (sys time) aim9: -4% to 30% (for page_test and brk_test) tbench: -1% to 4% hackbench: -2.5% to 3.45% (mostly within the noise though) netperf-udp -1.34% to 4.06% (varies between machines a bit) netperf-tcp -0.44% to 5.22% (varies between machines a bit) I haven't sysbench figures at hand, but previously they were within the -0.5% to 2% range. On netperf, the client and server were bound to opposite number CPUs to maximise the problems with cache line bouncing of the struct pages so I expect different people to report different results for netperf depending on their exact machine and how they ran the test (different machines, same cpus client/server, shared cache but two threads client/server, different socket client/server etc). I also measured the vmlinux sizes for a single x86-based config with CONFIG_DEBUG_INFO enabled but not CONFIG_DEBUG_VM. The core of the .config is based on the Debian Lenny kernel config so I expect it to be reasonably typical. This patch: __alloc_pages_internal is the core page allocator function but essentially it is an alias of __alloc_pages_nodemask. Naming a publicly available and exported function "internal" is also a big ugly. This patch renames __alloc_pages_internal() to __alloc_pages_nodemask() and deletes the old nodemask function. Warning - This patch renames an exported symbol. No kernel driver is affected by external drivers calling __alloc_pages_internal() should change the call to __alloc_pages_nodemask() without any alteration of parameters. Signed-off-by: Mel Gorman <mel@csn.ul.ie> Reviewed-by: Christoph Lameter <cl@linux-foundation.org> Reviewed-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Reviewed-by: Pekka Enberg <penberg@cs.helsinki.fi> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Nick Piggin <nickpiggin@yahoo.com.au> Cc: Dave Hansen <dave@linux.vnet.ibm.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-06-16cpuset,mm: update tasks' mems_allowed in timeMiao Xie
Fix allocating page cache/slab object on the unallowed node when memory spread is set by updating tasks' mems_allowed after its cpuset's mems is changed. In order to update tasks' mems_allowed in time, we must modify the code of memory policy. Because the memory policy is applied in the process's context originally. After applying this patch, one task directly manipulates anothers mems_allowed, and we use alloc_lock in the task_struct to protect mems_allowed and memory policy of the task. But in the fast path, we didn't use lock to protect them, because adding a lock may lead to performance regression. But if we don't add a lock,the task might see no nodes when changing cpuset's mems_allowed to some non-overlapping set. In order to avoid it, we set all new allowed nodes, then clear newly disallowed ones. [lee.schermerhorn@hp.com: The rework of mpol_new() to extract the adjusting of the node mask to apply cpuset and mpol flags "context" breaks set_mempolicy() and mbind() with MPOL_PREFERRED and a NULL nodemask--i.e., explicit local allocation. Fix this by adding the check for MPOL_PREFERRED and empty node mask to mpol_new_mpolicy(). Remove the now unneeded 'nodes = NULL' from mpol_new(). Note that mpol_new_mempolicy() is always called with a non-NULL 'nodes' parameter now that it has been removed from mpol_new(). Therefore, we don't need to test nodes for NULL before testing it for 'empty'. However, just to be extra paranoid, add a VM_BUG_ON() to verify this assumption.] [lee.schermerhorn@hp.com: I don't think the function name 'mpol_new_mempolicy' is descriptive enough to differentiate it from mpol_new(). This function applies cpuset set context, usually constraining nodes to those allowed by the cpuset. However, when the 'RELATIVE_NODES flag is set, it also translates the nodes. So I settled on 'mpol_set_nodemask()', because the comment block for mpol_new() mentions that we need to call this function to "set nodes". Some additional minor line length, whitespace and typo cleanup.] Signed-off-by: Miao Xie <miaox@cn.fujitsu.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Christoph Lameter <cl@linux-foundation.org> Cc: Paul Menage <menage@google.com> Cc: Nick Piggin <nickpiggin@yahoo.com.au> Cc: Yasunori Goto <y-goto@jp.fujitsu.com> Cc: Pekka Enberg <penberg@cs.helsinki.fi> Cc: David Rientjes <rientjes@google.com> Signed-off-by: Lee Schermerhorn <lee.schermerhorn@hp.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-06-16mm: clean up get_user_pages_fast() documentationNick Piggin
Move more documentation for get_user_pages_fast into the new kerneldoc comment. Add some comments for get_user_pages as well. Also, move get_user_pages_fast declaration up to get_user_pages. It wasn't there initially because it was once a static inline function. [akpm@linux-foundation.org: coding-style fixes] Signed-off-by: Nick Piggin <npiggin@suse.de> Cc: Andy Grover <andy.grover@oracle.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-06-16radix-tree: add radix_tree_prev_hole()Wu Fengguang
The counterpart of radix_tree_next_hole(). To be used by context readahead. Signed-off-by: Wu Fengguang <fengguang.wu@intel.com> Cc: Vladislav Bolkhovitin <vst@vlnb.net> Cc: Jens Axboe <jens.axboe@oracle.com> Cc: Jeff Moyer <jmoyer@redhat.com> Cc: Nick Piggin <nickpiggin@yahoo.com.au> Cc: Ying Han <yinghan@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-06-16readahead: record mmap read-around states in file_ra_stateWu Fengguang
Mmap read-around now shares the same code style and data structure with readahead code. This also removes do_page_cache_readahead(). Its last user, mmap read-around, has been changed to call ra_submit(). The no-readahead-if-congested logic is dumped by the way. Users will be pretty sensitive about the slow loading of executables. So it's unfavorable to disabled mmap read-around on a congested queue. [akpm@linux-foundation.org: coding-style fixes] Cc: Nick Piggin <npiggin@suse.de> Signed-off-by: Fengguang Wu <wfg@mail.ustc.edu.cn> Cc: Ying Han <yinghan@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-06-16readahead: make mmap_miss an unsigned intWu Fengguang
This makes the performance impact of possible mmap_miss wrap around to be temporary and tolerable: i.e. MMAP_LOTSAMISS=100 extra readarounds. Otherwise if ever mmap_miss wraps around to negative, it takes INT_MAX cache misses to bring it back to normal state. During the time mmap readaround will be _enabled_ for whatever wild random workload. That's almost permanent performance impact. Signed-off-by: Wu Fengguang <fengguang.wu@intel.com> Cc: Ying Han <yinghan@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-06-16mm: consolidate init_mm definitionAlexey Dobriyan
* create mm/init-mm.c, move init_mm there * remove INIT_MM, initialize init_mm with C99 initializer * unexport init_mm on all arches: init_mm is already unexported on x86. One strange place is some OMAP driver (drivers/video/omap/) which won't build modular, but it's already wants get_vm_area() export. Somebody should look there. [akpm@linux-foundation.org: add missing #includes] Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Cc: Mike Frysinger <vapier.adi@gmail.com> Cc: Americo Wang <xiyou.wangcong@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-06-16firmware_map: fix hang with x86/32bitYinghai Lu
Addresses http://bugzilla.kernel.org/show_bug.cgi?id=13484 Peer reported: | The bug is introduced from kernel 2.6.27, if E820 table reserve the memory | above 4G in 32bit OS(BIOS-e820: 00000000fff80000 - 0000000120000000 | (reserved)), system will report Int 6 error and hang up. The bug is caused by | the following code in drivers/firmware/memmap.c, the resource_size_t is 32bit | variable in 32bit OS, the BUG_ON() will be invoked to result in the Int 6 | error. I try the latest 32bit Ubuntu and Fedora distributions, all hit this | bug. |====== |static int firmware_map_add_entry(resource_size_t start, resource_size_t end, | const char *type, | struct firmware_map_entry *entry) and it only happen with CONFIG_PHYS_ADDR_T_64BIT is not set. it turns out we need to pass u64 instead of resource_size_t for that. [akpm@linux-foundation.org: add comment] Reported-and-tested-by: Peer Chen <pchen@nvidia.com> Signed-off-by: Yinghai Lu <yinghai@kernel.org> Cc: Ingo Molnar <mingo@elte.hu> Acked-by: H. Peter Anvin <hpa@zytor.com> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: <stable@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-06-16time: move PIT_TICK_RATE to linux/timex.hArnd Bergmann
PIT_TICK_RATE is currently defined in four architectures, but in three different places. While linux/timex.h is not the perfect place for it, it is still a reasonable replacement for those drivers that traditionally use asm/timex.h to get CLOCK_TICK_RATE and expect it to be the PIT frequency. Note that for Alpha, the actual value changed from 1193182UL to 1193180UL. This is unlikely to make a difference, and probably can only improve accuracy. There was a discussion on the correct value of CLOCK_TICK_RATE a few years ago, after which every existing instance was getting changed to 1193182. According to the specification, it should be 1193181.818181... Signed-off-by: Arnd Bergmann <arnd@arndb.de> Cc: Richard Henderson <rth@twiddle.net> Cc: Ivan Kokshaysky <ink@jurassic.park.msu.ru> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Ingo Molnar <mingo@elte.hu> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: "H. Peter Anvin" <hpa@zytor.com> Cc: Len Brown <lenb@kernel.org> Cc: john stultz <johnstul@us.ibm.com> Cc: Dmitry Torokhov <dtor@mail.ru> Cc: Takashi Iwai <tiwai@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-06-16V4L/DVB (11239): sdio: add cards ids for sms (Siano Mobile Silicon) MDTV ↵Uri Shkolnik
receivers sdio: add cards id for sms (Siano Mobile Silicon) MDTV receivers Add SDIO vendor ID, and multiple device IDs for various SMS-based MDTV SDIO adapters. Signed-off-by: Uri Shkolnik <uris@siano-ms.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2009-06-16V4L/DVB (11970): gspca - ov519: Add support for the ov518 bridge.Hans de Goede
Signed-off-by: Hans de Goede <hdegoede@redhat.com> Signed-off-by: Jean-Francois Moine <moinejf@free.fr> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2009-06-16Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/ieee1394/linux1394-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/ieee1394/linux1394-2.6: firewire: core: use more outbound tlabels firewire: core: don't update Broadcast_Channel if RFC 2734 conditions aren't met firewire: core: prepare for non-core children of card devices firewire: core: include linux/uaccess.h instead of asm/uaccess.h firewire: add parent-of-unit accessor firewire: rename source files firewire: reorganize header files firewire: clean up includes firewire: ohci: access bus_seconds atomically firewire: also use vendor ID in root directory for driver matches firewire: share device ID table type with ieee1394 firewire: core: add sysfs attribute for easier udev rules firewire: core: check for missing struct update at build time, not run time firewire: core: improve check for local node
2009-06-16Merge branch 'for-linus2' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/vegard/kmemcheck * 'for-linus2' of git://git.kernel.org/pub/scm/linux/kernel/git/vegard/kmemcheck: (39 commits) signal: fix __send_signal() false positive kmemcheck warning fs: fix do_mount_root() false positive kmemcheck warning fs: introduce __getname_gfp() trace: annotate bitfields in struct ring_buffer_event net: annotate struct sock bitfield c2port: annotate bitfield for kmemcheck net: annotate inet_timewait_sock bitfields ieee1394/csr1212: fix false positive kmemcheck report ieee1394: annotate bitfield net: annotate bitfields in struct inet_sock net: use kmemcheck bitfields API for skbuff kmemcheck: introduce bitfield API kmemcheck: add opcode self-testing at boot x86: unify pte_hidden x86: make _PAGE_HIDDEN conditional kmemcheck: make kconfig accessible for other architectures kmemcheck: enable in the x86 Kconfig kmemcheck: add hooks for the page allocator kmemcheck: add hooks for page- and sg-dma-mappings kmemcheck: don't track page tables ...
2009-06-16Merge git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb-2.6: (143 commits) USB: xhci depends on PCI. USB: xhci: Add Makefile, MAINTAINERS, and Kconfig entries. USB: xhci: Respect critical sections. USB: xHCI: Fix interrupt moderation. USB: xhci: Remove packed attribute from structures. usb; xhci: Fix TRB offset calculations. USB: xhci: replace if-elseif-else with switch-case USB: xhci: Make xhci-mem.c include linux/dmapool.h USB: xhci: drop spinlock in xhci_urb_enqueue() error path. USB: Change names of SuperSpeed ep companion descriptor structs. USB: xhci: Avoid compiler reordering in Link TRB giveback. USB: xhci: Clean up xhci_irq() function. USB: xhci: Avoid global namespace pollution. USB: xhci: Fix Link TRB handoff bit twiddling. USB: xhci: Fix register write order. USB: xhci: fix some compiler warnings in xhci.h USB: xhci: fix lots of compiler warnings. USB: xhci: use xhci_handle_event instead of handle_event USB: xhci: URB cancellation support. USB: xhci: Scatter gather list support for bulk transfers. ...
