path: root/include/linux
2005-09-22[NETFILTER] Fix conntrack event cache deadlock/oopsHarald Welte
This patch fixes a number of bugs. It cannot be reasonably split up in multiple fixes, since all bugs interact with each other and affect the same function: Bug #1: The event cache code cannot be called while a lock is held. Therefore, the call to ip_conntrack_event_cache() within ip_ct_refresh_acct() needs to be moved outside of the locked section. This fixes a number of 2.6.14-rcX oops and deadlock reports. Bug #2: We used to call ct_add_counters() for unconfirmed connections without holding a lock. Since the add operations are not atomic, we could race with another CPU. Bug #3: ip_ct_refresh_acct() lost REFRESH events in some cases where refresh (and the corresponding event) are desired, but no accounting shall be performed. Both, evenst and accounting implicitly depended on the skb parameter bein non-null. We now re-introduce a non-accounting "ip_ct_refresh()" variant to explicitly state the desired behaviour. Signed-off-by: Harald Welte <laforge@netfilter.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-09-22[NETFILTER] remove unneeded structure definition from conntrack helperHarald Welte
2005-09-22[NETFILTER] Fix sparse endian warnings in pptp helperAlexey Dobriyan
Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Harald Welte <laforge@netfilter.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-09-22[PATCH] reboot: comment and factor the main reboot functionsEric W. Biederman
In the lead up to 2.6.13 I fixed a large number of reboot problems by making the calling conventions consistent. Despite checking and double checking my work it appears I missed an obvious one. This first patch simply refactors the reboot routines so all of the preparation for various kinds of reboots are in their own functions. Making it very hard to get the various kinds of reboot out of sync. Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-22[PATCH] driver core: add helper device_is_registered()Daniel Ritz
add the helper and use it instead of open coding the klist_node_attached() check (which is a layering violation IMHO) idea by Alan Stern. Signed-off-by: Daniel Ritz <daniel.ritz@gmx.ch> Cc: Alan Stern <stern@rowland.harvard.edu> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-21[PATCH] Adds sys_set_mempolicy() in include/linux/syscalls.hEric Dumazet
Signed-off-by: Eric Dumazet <dada1@cosmosbay.com> Cc: Andi Kleen <ak@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-21[PATCH] mm: add a note about partially hardcoded VM_* flagsPaolo 'Blaisorblade' Giarrusso
Hugh made me note this line for permission checking in mprotect(): if ((newflags & ~(newflags >> 4)) & 0xf) { after figuring out what's that about, I decided it's nasty enough. Btw Hugh itself didn't like the 0xf. We can safely change it to VM_READ|VM_WRITE|VM_EXEC because we never change VM_SHARED, so no need to check that. Signed-off-by: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it> Acked-by: Hugh Dickins <hugh@veritas.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-21[PATCH] mm: update stale comment for removal of page->listPaolo 'Blaisorblade' Giarrusso
Update comment for the 2.6.6-rc1 conversion from page->list and address_space->{clean,dirty,locked}_pages to radix tree tagging and ->lru. I've mostly avoided to mention page lists (at least I've shortened the comment). Signed-off-by: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it> Acked-by: Hugh Dickins <hugh@veritas.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-19[BYTEORDER]: Document alignment and byteorder macrosEd L. Cashin
This patch comments the fact that although passing le64_to_cpup et al. is within the intended use of the byteorder macros, using get_unaligned is the recommended way to go. Signed-off-by: Ed L. Cashin <ecashin@coraid.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-09-19[8021Q]: Add endian annotations.Alexey Dobriyan
Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-09-19[NETFILTER]: Rename misnamed functionPatrick McHardy
Both __ip_conntrack_expect_find and ip_conntrack_expect_find_get take a reference to the expectation, the difference is that callers of __ip_conntrack_expect_find must hold ip_conntrack_lock. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: Harald Welte <laforge@netfilter.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-09-19[NETFILTER] ip6tables: remove duplicate codeYasuyuki Kozakai
Some IPv6 matches have very similar loops to find IPv6 extension header and we can unify them. This patch introduces ipv6_find_hdr() to do it. I just checked that it can find the target headers in the packet which has dst,hbh,rt,frag,ah,esp headers. Signed-off-by: Yasuyuki Kozakai <yasuyuki.kozakai@toshiba.co.jp> Signed-off-by: Harald Welte <laforge@netfilter.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-09-19[NETFILTER]: Add new PPTP conntrack and NAT helperHarald Welte
This new "version 3" PPTP conntrack/nat helper is finally ready for mainline inclusion. Special thanks to lots of last-minute bugfixing by Patric McHardy. Signed-off-by: Harald Welte <laforge@netfilter.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-09-18[DCCP]: Introduce CCID getsockopt for the CCIDsArnaldo Carvalho de Melo
Allocation for the optnames is similar to the DCCP options, with a range for rx and tx half connection CCIDs. Signed-off-by: Arnaldo Carvalho de Melo <acme@mandriva.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-09-18[DCCP]: Don't use necessarily the same CCID for tx and rxArnaldo Carvalho de Melo
2005-09-18[CCID3]: Introduce include/linux/tfrc.hArnaldo Carvalho de Melo
Moving the TFRC sender and receiver variables to separate structs, so that we can copy these structs to userspace thru getsockopt, dccp_diag, etc. Signed-off-by: Arnaldo Carvalho de Melo <acme@mandriva.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-09-18[DCCP]: Move the ack vector code to net/dccp/ackvec.[ch]Arnaldo Carvalho de Melo
Isolating it, that will be used when we introduce a CCID2 (TCP-Like) implementation. Signed-off-by: Arnaldo Carvalho de Melo <acme@mandriva.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-09-18Merge master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6David S. Miller
2005-09-17[PATCH] joystick-vs-x.org fixAndrew Morton
Fix http://bugzilla.kernel.org/show_bug.cgi?id=5241 2.6.13 broke compilation of the xorg tree, which apprarently insists on including that file. Cc: Vojtech Pavlik <vojtech@suse.cz> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-17[PATCH] i2c: kill an unused i2c_adapter struct memberJean Delvare
Kill an unused member of the i2c_adapter structure. This additionally fixes a potential bug, because <linux/i2c.h> doesn't include <linux/config.h>, so different files including <linux/i2c.h> could see a different definition of the i2c_adapter structure, depending on them including <linux/config.h> (or other header files themselves including <linux/config.h>) before <linux/i2c.h>, or not. Credits go to Jörn Engel for pointing me to the problem. Signed-off-by: Jean Delvare <khali@linux-fr.org> Cc: Greg KH <greg@kroah.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-16[TG3]: Add AMD K8 to list of write-reorder chipsets.David S. Miller
Thanks to Andy Stewart for the report and testing debug patches from Michael Chan. Signed-off-by: David S. Miller <davem@davemloft.net>
2005-09-16[DCCP]: Introduce DCCP_SOCKOPT_SERVICEArnaldo Carvalho de Melo
As discussed in the dccp@vger mailing list: Now applications have to use setsockopt(DCCP_SOCKOPT_SERVICE, service[s]), prior to calling listen() and connect(). An array of unsigned ints can be passed meaning that the listening sock accepts connection requests for several services. With this we can ditch struct sockaddr_dccp and use only sockaddr_in (and sockaddr_in6 in the future). Signed-off-by: Arnaldo Carvalho de Melo <acme@mandriva.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-09-16[PATCH] cleanup whitespace in pci_ids.hKarsten Keil
Signed-off-by: Karsten Keil <kkeil@suse.de> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-16[PATCH] Add PCI IDs for Sitecom DC-105Karsten Keil
Sitecom DC-105 PCI work with hfc_pci HiSax driver Signed-off-by: Karsten Keil <kkeil@suse.de> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-14[NETLINK]: Reserve a slot for NETLINK_GENERIC.David S. Miller
As requested by Jamal. Signed-off-by: David S. Miller <davem@davemloft.net>
2005-09-14[PATCH] add PCI IDs so RME32 and RME96 drivers buildRoland Dreier
While doing an allyesconfig build, I noticed that the commit commit 8cdfd2519c6c9a1e6057dc5970b2542b35895738 Author: Takashi Iwai <tiwai@suse.de> Date: Wed Sep 7 14:08:11 2005 +0200 [ALSA] Remove superfluous PCI ID definitions broke the RME32 and RME96 drivers, since the PCI IDs they use seem to have changed names. Here's a patch to fix this -- compile tested only, since I have no idea what the hardware even is. Fix the build of the RME32 and RME96 drivers by having them use the PCI_DEVICE_ID_RME_xxx names defined in <linux/pci_ids.h> instead of the PCI_DEVICE_ID_xxx names that they used to define themselves. Also fix the typo in the id PCI_DEVICE_IDRME__DIGI96_8_PAD_OR_PST so the name is PCI_DEVICE_ID_RME_DIGI96_8_PAD_OR_PST. Signed-off-by: Roland Dreier <rolandd@cisco.com> Acked-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-13Merge master.kernel.org:/pub/scm/linux/kernel/git/chrisw/lsm-2.6 Linus Torvalds
2005-09-13Merge master.kernel.org:/pub/scm/linux/kernel/git/dwmw2/audit-2.6 Linus Torvalds
2005-09-13Merge master.kernel.org:/pub/scm/linux/kernel/git/perex/alsa-current Linus Torvalds
2005-09-13[PATCH] fbcon: constify font dataJan Beulich
const-ify the font control structures and data, to make somewhat better guarantees that these are not modified anywhere in the kernel. Specifically for a kernel debugger to share this information from the normal kernel code, such a guarantee seems rather desirable. Signed-off-by: Jan Beulich <jbeulich@novell.com> Cc: "Antonino A. Daplas" <adaplas@hotpop.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-13[PATCH] v4l: experimental Sliced VBI API supportMauro Carvalho Chehab
Adds all defines, ioctls and structs needed for the sliced VBI API VBI = Vertical Blank Interval. It is related with the way TV signals work. It sends a line, then, it has a retrace time to allow the tube to move electrons to the beginning of the next line. This was the main reason at the beginning of analog B&W TV. There is a lot of bandwidth lost on VBI. So, lots of TV systems use it to send other information such as Closed Captions and Teletext. Also, broadcasters uses this as a channel to exchange information from the content producer to their subsidiaries at each city. There's already a raw VBI interface on V4L2 api, used for Closed Captions and Teletext. The decoding is doing at userlevel space and it is mostly for analog TV signals, non encoded. Encoded signals (MPEG, for example), may need also to transmit other information (like, for example, display aspect, i.e. 4x3, widescreen...). Sliced VBI interface is a method to allow the video stream to transmit this kind of information. Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@brturbo.com.br> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-13[PATCH] nfsd4: move replay_ownerNeil Brown
It seems more natural to move the setting of the replay_owner into the relevant procedure instead of doing it in nfsv4_proc_compound. Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu> Signed-off-by: Neil Brown <neilb@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-13[PATCH] pktcdvd: BUG_ON cleanupsPeter Osterlund
Remove some redundant BUG_ON() statements in pktcdvd and move one run-time check to compile-time. Signed-off-by: Peter Osterlund <petero2@telia.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-13[PATCH] cciss: new controller pci/subsystem idsMike Miller
This patch adds new PCI and subsystem ID's that finally made the spec. It also include a name change for one controller. I know there's a lot of duplicat names but the fw folks wanted this for the different implementations. Even though the same ASIC is used it may be embedded on some platforms, standup card in others, and a mezzanine in other servers. Signed-off-by: Mike Miller <mike.miller@hp.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-13[PATCH] set_current_state() commentaryAndrew Morton
Explain the mysteries of set_current_state(). Quoth Linus: The scheduler itself never needs the memory barrier at all. The barrier is needed only if the user itself ends up testing some other thing afterwards, ie if you have set_process_state(TASK_INTERRUPTIBLE); if (still_need_to_sleep()) schedule(); then the "still_need_to_sleep()" thing may test flags and wakeup events, and then you _may_ want to (and often do) make sure that the write of TASK_INTERRUPTIBLE is serialized wrt the reads of any wakeup data (since the wakeup may have happened on another CPU). So the comment is somewhat wrong. We don't really _care_ whether the state propagates out to other CPU's since all of our actions are purely local, and there is nothing we do that is conditional on any other CPU: we're going to sleep unconditionally, and the scheduler only cares about _our_ state, not about somebody elses state. Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-13[PATCH] Make BUILD_BUG_ON fail at compile time.Andi Kleen
Force a compiler error instead of a link error, because they are easier to track down. Idea stolen from code by Jan Beulich <jbeulich@novell.com> If the argument to BUILD_BUG_ON evaluates to non-zero the compiler will do: t.c:6: error: size of array `type name' is negative (surprised that gcc doesn't have an extension for this) Signed-off-by: "Andi Kleen" <ak@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-12Merge master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 Linus Torvalds
2005-09-12[NETROM]: Implement G8PZT Circuit reset for NET/ROMRalf Baechle
NET/ROM is lacking a connection reset like TCP's RST flag which at times may result in a connecting having to slowly timing out instead of just being reset. An earlier attempt to reset the connection by sending a NR_CONNACK | NR_CHOKE_FLAG transport was inacceptable as it did result in crashes of BPQ systems. An alternative approach of introducing a new transport type 7 (NR_RESET) has be implemented several years ago in Paula Jayne Dowie G8PZT's Xrouter. Implement NR_RESET for Linux's NET/ROM but like any messing with the state engine consider this experimental for now and thus control it by a sysctl (net.netrom.reset) which for the time being defaults to off. Signed-off-by: Ralf Baechle DL5RB <ralf@linux-mips.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-09-12[PATCH] USB: fix usbdevice_fs header breakageHarald Welte
[USBDEVFS] fix inclusion of <linux/compat.h> to avoud header mess Without moving the include of compat.h down, userspace programs that use usbdevice_fs.h end up including half the kernel includes (and eventually fail to compile). Signed-off-by: Harald Welte <laforge@netfilter.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2005-09-12[PATCH] x86-64: Make dmi_find_device for !DMI case inlineAndi Kleen
Otherwise it will generate warnings and be generated many times. Signed-off-by: Andi Kleen <ak@suse.de> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-12[PATCH] x86-64: Some cleanup and optimization to the processor data area.Andi Kleen
- Remove unused irqrsp field - Remove pda->me - Optimize set_softirq_pending slightly Signed-off-by: Andi Kleen <ak@suse.de> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-12[PATCH] cpuset semaphore depth check optimizePaul Jackson
Optimize the deadlock avoidance check on the global cpuset semaphore cpuset_sem. Instead of adding a depth counter to the task struct of each task, rather just two words are enough, one to store the depth and the other the current cpuset_sem holder. Thanks to Nikita Danilov for the idea. Signed-off-by: Paul Jackson <pj@sgi.com> [ We may want to change this further, but at least it's now a totally internal decision to the cpusets code ] Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-12[PATCH] crc16: remove w1 specific comments.Evgeniy Polyakov
Remove w1 comments from crc16.h and move specific constants into w1_ds2433.c where they are used. Replace %d with %zd. Signed-off-by: Evgeniy Polyakov <johnpol@2ka.mipt.ru> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-12[ALSA] [PATCH] Add missing sound PCI IDs to pci_ids.hTakashi Iwai
Added missing PCI IDs for sound drivers to pci_ids.h. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2005-09-11[NET]: Add netlink connector.Evgeniy Polyakov
Kernel connector - new userspace <-> kernel space easy to use communication module which implements easy to use bidirectional message bus using netlink as it's backend. Connector was created to eliminate complex skb handling both in send and receive message bus direction. Connector driver adds possibility to connect various agents using as one of it's backends netlink based network. One must register callback and identifier. When driver receives special netlink message with appropriate identifier, appropriate callback will be called. From the userspace point of view it's quite straightforward: socket(); bind(); send(); recv(); But if kernelspace want to use full power of such connections, driver writer must create special sockets, must know about struct sk_buff handling... Connector allows any kernelspace agents to use netlink based networking for inter-process communication in a significantly easier way: int cn_add_callback(struct cb_id *id, char *name, void (*callback) (void *)); void cn_netlink_send(struct cn_msg *msg, u32 __groups, int gfp_mask); struct cb_id { __u32 idx; __u32 val; }; idx and val are unique identifiers which must be registered in connector.h for in-kernel usage. void (*callback) (void *) - is a callback function which will be called when message with above idx.val will be received by connector core. Using connector completely hides low-level transport layer from it's users. Connector uses new netlink ability to have many groups in one socket. [ Incorporating many cleanups and fixes by myself and Andrew Morton -DaveM ] Signed-off-by: Evgeniy Polyakov <johnpol@2ka.mipt.ru> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-09-11[PATCH] MCA/INIT: scheduler hooksKeith Owens
Scheduler hooks to see/change which process is deemed to be on a cpu. Signed-off-by: Keith Owens <kaos@sgi.com> Signed-off-by: Tony Luck <tony.luck@intel.com>
2005-09-10Merge master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 Linus Torvalds
2005-09-10Merge master.kernel.org:/pub/scm/linux/kernel/git/dtor/input Linus Torvalds
2005-09-10Merge davem@outer-richmond.davemloft.net:src/GIT/net-2.6/ David S. Miller
2005-09-10[PATCH] __user annotations (scsi/ch)viro@ZenIV.linux.org.uk
