For the quite common 'skb->nh.raw - skb->data' sequence.
Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
For the common, open coded 'skb->nh.raw = skb->data' operation, so that we can
later turn skb->nh.raw into a offset, reducing the size of struct sk_buff in
64bit land while possibly keeping it as a pointer on 32bit.
This one touches just the most simple case, next will handle the slightly more
"complex" cases.
For consistency with all the other skb->nh.raw accessors.
Also do some really obvious simplifications in pppoe_recvmsg, well the
kfree_skb one is not so obvious, but free() and kfree() have the same behaviour
(hint :-) ).
For the places where we need a pointer to the mac header, it is still legal to
touch skb->mac.raw directly if just adding to, subtracting from or setting it
to another layer header.
This one also converts some more cases to skb_reset_mac_header() that my
regex missed as it had no spaces before nor after '=', ugh.
For the cases where we want to set skb->mac.raw to an offset from skb->data.
Simple cases first, the memmove ones and specially pktgen will be left for later.
For the common, open coded 'skb->mac.raw = skb->data' operation, so that we can
later turn skb->mac.raw into a offset, reducing the size of struct sk_buff in
"complex" cases.
Covert network warning messages from a compile time to runtime choice.
Removes kernel config option and replaces it with new /proc/sys/net/core/warnings.
Signed-off-by: Stephen Hemminger <shemminger@linux-foundation.org>
This patch eliminates some duplicate code for the verification of
receive checksums between UDP-Lite and UDP. It does this by
introducing __skb_checksum_complete_head which is identical to
__skb_checksum_complete_head apart from the fact that it takes
a length parameter rather than computing the first skb->len bytes.
As a result UDP-Lite will be able to use hardware checksum offload
for packets which do not use partial coverage checksums. It also
means that UDP-Lite loopback no longer does unnecessary checksum
verification.
If any NICs start support UDP-Lite this would also start working
automatically.
This patch removes the assumption that msg_flags has MSG_TRUNC clear
upon entry in recvmsg.
Nominally an autoconfigured IPv6 address is added to an interface in the
Tentative state (as per RFC 2462). Addresses in this state remain in this
state while the Duplicate Address Detection process operates on them to
determine their uniqueness on the network. During this period, these
tentative addresses may not be used for communication, increasing the time
before a node may be able to communicate on a network. Using Optimistic
Duplicate Address Detection, autoconfigured addresses may be used
immediately for communication on the network, as long as certain rules are
followed to avoid conflicts with other nodes during the Duplicate Address
Detection process.
Signed-off-by: Neil Horman <nhorman@tuxdriver.com>
Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org>
We currently use a special structure (struct skb_timeval) and plain
'struct timeval' to store packet timestamps in sk_buffs and struct
sock.
This has some drawbacks :
- Fixed resolution of micro second.
- Waste of space on 64bit platforms where sizeof(struct timeval)=16
I suggest using ktime_t that is a nice abstraction of high resolution
time services, currently capable of nanosecond resolution.
As sizeof(ktime_t) is 8 bytes, using ktime_t in 'struct sock' permits
a 8 byte shrink of this structure on 64bit architectures. Some other
structures also benefit from this size reduction (struct ipq in
ipv4/ip_fragment.c, struct frag_queue in ipv6/reassembly.c, ...)
Once this ktime infrastructure adopted, we can more easily provide
nanosecond resolution on top of it. (ioctl SIOCGSTAMPNS and/or
SO_TIMESTAMPNS/SCM_TIMESTAMPNS)
Note : this patch includes a bug correction in
compat_sock_get_timestamp() where a "err = 0;" was missing (so this
syscall returned -ENOENT instead of 0)
Signed-off-by: Eric Dumazet <dada1@cosmosbay.com>
CC: Stephen Hemminger <shemminger@linux-foundation.org>
CC: John find <linux.kernel@free.fr>
New sysctl tcp_frto_response is added to select amongst these
responses:
- Rate halving based; reuses CA_CWR state (default)
- Very conservative; used to be the only one available (=1)
- Undo cwr; undoes ssthresh and cwnd reductions (=2)
The response with rate halving requires a new parameter to
tcp_enter_cwr because FRTO has already reduced ssthresh and
doing a second reduction there has to be prevented. In addition,
to keep things nice on 80 cols screen, a local variable was
added.
Signed-off-by: Ilpo Järvinen <ilpo.jarvinen@helsinki.fi>
I noticed in oprofile study a cache miss in tcp_rcv_established() to read
copied_seq.
ffffffff80400a80 <tcp_rcv_established>: /* tcp_rcv_established total: 4034293
2.0400 */
55493 0.0281 :ffffffff80400bc9: mov 0x4c8(%r12),%eax copied_seq
543103 0.2746 :ffffffff80400bd1: cmp 0x3e0(%r12),%eax rcv_nxt
if (tp->copied_seq == tp->rcv_nxt &&
len - tcp_header_len <= tp->ucopy.len) {
In this function, the cache line 0x4c0 -> 0x500 is used only for this
reading 'copied_seq' field.
rcv_wup and copied_seq should be next to rcv_nxt field, to lower number of
active cache lines in hot paths. (tcp_rcv_established(), tcp_poll(), ...)
As you suggested, I changed tcp_create_openreq_child() so that these fields
are changed together, to avoid adding a new store buffer stall.
Patch is 64bit friendly (no new hole because of alignment constraints)
sysctl_tcp_max_ssthresh.
Signed-off-by: John Heffner <jheffner@psc.edu>
* master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6:
[BNX2]: Fix occasional NETDEV WATCHDOG on 5709.
[IPV6]: Disallow RH0 by default.
[XFRM]: beet: fix pseudo header length value
[TCP]: Congestion control initialization.
A security issue is emerging. Disallow Routing Header Type 0 by default
as we have been doing for IPv4.
Note: We allow RH2 by default because it is harmless.
We broke the the alignment of members of taskstats to the 8 byte boundary
with the CSA patches. In the current kernel, the taskstats structure is
not suitable for use by 32 bit applications in a 64 bit kernel.
On x86_64
Offsets of taskstats' members (64 bit kernel, 64 bit application)
@taskstats'offsetof[@taskstats'indices] = (
0, # version
4, # ac_exitcode
8, # ac_flag
9, # ac_nice
16, # cpu_count
24, # cpu_delay_total
32, # blkio_count
40, # blkio_delay_total
48, # swapin_count
56, # swapin_delay_total
64, # cpu_run_real_total
72, # cpu_run_virtual_total
80, # ac_comm
112, # ac_sched
113, # ac_pad
116, # ac_uid
120, # ac_gid
124, # ac_pid
128, # ac_ppid
132, # ac_btime
136, # ac_etime
144, # ac_utime
152, # ac_stime
160, # ac_minflt
168, # ac_majflt
176, # coremem
184, # virtmem
192, # hiwater_rss
200, # hiwater_vm
208, # read_char
216, # write_char
224, # read_syscalls
232, # write_syscalls
240, # read_bytes
248, # write_bytes
256, # cancelled_write_bytes
Offsets of taskstats' members (64 bit kernel, 32 bit application)
0, # version
4, # ac_exitcode
8, # ac_flag
9, # ac_nice
12, # cpu_count
20, # cpu_delay_total
28, # blkio_count
36, # blkio_delay_total
44, # swapin_count
52, # swapin_delay_total
60, # cpu_run_real_total
68, # cpu_run_virtual_total
76, # ac_comm
108, # ac_sched
109, # ac_pad
112, # ac_uid
116, # ac_gid
120, # ac_pid
124, # ac_ppid
128, # ac_btime
132, # ac_etime
140, # ac_utime
148, # ac_stime
156, # ac_minflt
164, # ac_majflt
172, # coremem
180, # virtmem
188, # hiwater_rss
196, # hiwater_vm
204, # read_char
212, # write_char
220, # read_syscalls
228, # write_syscalls
236, # read_bytes
244, # write_bytes
252, # cancelled_write_bytes
This is one way to solve the problem without re-arranging structure members
is to pack the structure. The patch adds an __attribute__((aligned(8))) to
the taskstats structure members so that 32 bit applications using taskstats
can work with a 64 bit kernel.
Using __attribute__((packed)) would break the 64 bit alignment of members.
The fix was tested on x86_64. After the fix, we got
0, # version
4, # ac_exitcode
8, # ac_flag
9, # ac_nice
16, # cpu_count
32, # blkio_count
48, # swapin_count
80, # ac_comm
112, # ac_sched
113, # ac_pad
120, # ac_uid
124, # ac_gid
128, # ac_pid
132, # ac_ppid
136, # ac_btime
144, # ac_etime
152, # ac_utime
160, # ac_stime
168, # ac_minflt
176, # ac_majflt
184, # coremem
192, # virtmem
200, # hiwater_rss
208, # hiwater_vm
216, # read_char
224, # write_char
232, # read_syscalls
240, # write_syscalls
248, # read_bytes
256, # write_bytes
264, # cancelled_write_bytes
0, # version
4, # ac_exitcode
8, # ac_flag
9, # ac_nice
16, # cpu_count
32, # blkio_count
48, # swapin_count
80, # ac_comm
112, # ac_sched
113, # ac_pad
120, # ac_uid
124, # ac_gid
128, # ac_pid
132, # ac_ppid
136, # ac_btime
144, # ac_etime
152, # ac_utime
160, # ac_stime
168, # ac_minflt
176, # ac_majflt
184, # coremem
192, # virtmem
200, # hiwater_rss
208, # hiwater_vm
216, # read_char
224, # write_char
248, # read_bytes
256, # write_bytes
Signed-off-by: Balbir Singh <balbir@linux.vnet.ibm.com>
Cc: Jay Lan <jlan@engr.sgi.com>
Cc: Shailabh Nagar <nagar@watson.ibm.com>
Cc: <stable@kernel.org>
Get rid of the inlined #ifdefs.
Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
[BRIDGE]: Unaligned access when comparing ethernet addresses
[SCTP]: Unmap v4mapped addresses during SCTP_BINDX_REM_ADDR operation.
[SCTP]: Fix assertion (!atomic_read(&sk->sk_rmem_alloc)) failed message
[NET]: Set a separate lockdep class for neighbour table's proxy_queue
[NET]: Fix UDP checksum issue in net poll mode.
[KEY]: Fix conversion between IPSEC_MODE_xxx and XFRM_MODE_xxx.
[NET]: Get rid of alloc_skb_from_cache
Provide an dummy implementation of devm_ioport_map() and
devm_ioport_unmap() to allow drivers (eg, pata_platform) to build for
platforms where CONFIG_NO_IOPORT is selected.
Cc: Alan Cox <alan@lxorguk.ukuu.org.uk>
Cc: Jeff Garzik <jeff@garzik.org>
Make kernel-doc comments match macro names.
Correct parameter names in a few places.
Remove '#' from beginning of kernel-doc comment macro names.
Remove extra (erroneous) blank lines in kernel-doc.
Warning(plist.h:100): Cannot understand * #PLIST_HEAD_INIT - static struct plist_head initializer on line 100 - I thought it was a doc line
Warning(plist.h:112): Cannot understand * #PLIST_NODE_INIT - static struct plist_node initializer on line 112 - I thought it was a doc line
Warning(plist.h:103): No description found for parameter '_lock'
Warning(plist.h:129): No description found for parameter 'lock'
Warning(plist.h:158): No description found for parameter 'pos'
Warning(plist.h:169): No description found for parameter 'pos'
Warning(plist.h:169): No description found for parameter 'n'
Warning(plist.h:179): No description found for parameter 'mem'
This still leaves one warning & one error that need attention:
Error(plist.h:219): cannot understand prototype: '('
Warning(plist.h): no structured comments found
Acked-by: Inaky Perez-Gonzalez <inaky.perez-gonzalez@intel.com>
Cc: Daniel Walker <dwalker@mvista.com>
Cc: Oleg Nesterov <oleg@tv-sign.ru>
Otherwise the following calltrace will lead to a wrong
lockdep warning:
neigh_proxy_process()
`- lock(neigh_table->proxy_queue.lock);
arp_redo /* via tbl->proxy_redo */
arp_process
neigh_event_ns
neigh_update
skb_queue_purge
`- lock(neighbor->arp_queue.lock);
This is not a deadlock actually, as neighbor table's proxy_queue
and the neighbor's arp_queue are different queues.
Lockdep thinks there is a deadlock as both queues are initialized
with skb_queue_head_init() and thus have a common class.
Since this was added originally for Xen, and Xen has recently (~2.6.18)
stopped using this function, we can safely get rid of it. Good timing
too since this function has started to bit rot.
If the writebacks are cancelled via nfs_cancel_dirty_list, or due to the
memory allocation failing in nfs_flush_one/nfs_flush_multi, then we must
ensure that the PG_writeback flag is cleared.
Also ensure that we actually own the PG_writeback flag whenever we
schedule a new writeback by making nfs_set_page_writeback() return the
value of test_set_page_writeback().
The PG_writeback page flag ends up replacing the functionality of the
PG_FLUSHING nfs_page flag, so we rip that out too.
already handled
It is possible for the timer expiry function to run even though the
request has already been handled: ide_timer_expiry() only checks that
the handler is not NULL, but it is possible that we have handled a
request (thus clearing the handler) and then started a new request
(thus starting the timer again, and setting a handler).
A simple way to exhibit this is to set the DMA timeout to 1 jiffy and
run dd: The kernel will panic after a few minutes because
ide_timer_expiry() tries to add a timer when it's already active.
To fix this, we simply add a request generation count that gets
incremented at every interrupt, and check in ide_timer_expiry() that
we have not already handled a new interrupt before running the expiry
function.
Signed-off-by: Suleiman Souhlal <suleiman@google.com>
Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
Soeren Sonnenburg reported that upon resume he is getting
this backtrace:
[<c0119637>] smp_apic_timer_interrupt+0x57/0x90
[<c0142d30>] retrigger_next_event+0x0/0xb0
[<c0104d30>] apic_timer_interrupt+0x28/0x30
[<c0140068>] __kfifo_put+0x8/0x90
[<c0130fe5>] on_each_cpu+0x35/0x60
[<c0143538>] clock_was_set+0x18/0x20
[<c0135cdc>] timekeeping_resume+0x7c/0xa0
[<c02aabe1>] __sysdev_resume+0x11/0x80
[<c02ab0c7>] sysdev_resume+0x47/0x80
[<c02b0b05>] device_power_up+0x5/0x10
it turns out that on resume we mistakenly re-enable interrupts too
early. Do the timer retrigger only on the current CPU.
Acked-by: Soeren Sonnenburg <kernel@nn7.de>
Revert all this. It can cause device-mapper to receive a different major from
earlier kernels and it turns out that the Amanda backup program (via GNU tar,
apparently) checks major numbers on files when performing incremental backups.
Which is a bit broken of Amanda (or tar), but this feature isn't important
enough to justify the churn.
A device can be removed from an md array via e.g.
echo remove > /sys/block/md3/md/dev-sde/state
This will try to remove the 'dev-sde' subtree which will deadlock
since
commit e7b0d26a86943370c04d6833c6edba2a72a6e240
With this patch we run the kobject_del via schedule_work so as to
avoid the deadlock.
Cc: Alan Stern <stern@rowland.harvard.edu>
Signed-off-by: Neil Brown <neilb@suse.de>
patch 4/4:
Limit ATAPI DMA to R/W commands only for TORiSAN DRD-N216 DVD-ROM drives
(http://bugzilla.kernel.org/show_bug.cgi?id=6710)
Signed-off-by: Albert Lee <albertcc@tw.ibm.com>
Signed-off-by: Jeff Garzik <jeff@garzik.org>
patch 3/4:
The TORiSAN drive locks up when max sector == 256.
Limit max sector to 128 for the TORiSAN DRD-N216 drives.
patch 1/4:
Reorder HSM_ST_FIRST, such that the task state transition is easier decoded with human eyes.
Fix the regression resulting from the recent change of suspend code
ordering that causes systems based on Intel x86 CPUs using the microcode
driver to hang during the resume.
The problem occurs since the microcode driver uses request_firmware() in
its CPU hotplug notifier, which is called after tasks has been frozen and
hangs. It can be fixed by telling the microcode driver to use the
microcode stored in memory during the resume instead of trying to load it
from disk.
Adrian Bunk <bunk@stusta.de>
Cc: Tigran Aivazian <tigran@aivazian.fsnet.co.uk>
Cc: Pavel Machek <pavel@ucw.cz>
Cc: Maxim <maximlevitsky@gmail.com>
built-in drivers had broken sysfs links that caused bootup hangs for
certain driver unregistry sequences.
Acked-by: Kay Sievers <kay.sievers@vrfy.org>
Signed-off-by: Greg KH <greg@kroah.com>
The input_device pointer is not refcounted, which means the device may
disappear while packets are queued, causing a crash when ifb passes packets
with a stale skb->dev pointer to netif_rx().
Fix by storing the interface index instead and do a lookup where neccessary.
Acked-by: Jamal Hadi Salim <hadi@cyberus.ca>
git://git.kernel.org/pub/scm/linux/kernel/git/linville/wireless-2.6 into upstream-fixes
Johannes Berg discovered that kernel space was leaking to
userspace on 64 bit platform. He made a first patch to fix that. This
is an improved version of his patch.
Signed-off-by: Jean Tourrilhes <jt@hpl.hp.com>
* 'for-linus' of git://git.kernel.dk/data/git/linux-2.6-block:
Export __splice_from_pipe()
2/2 splice: dont readpage
1/2 splice: dont steal
make elv_register() output atomic
block: blk_max_pfn is somtimes wrong
When CONFIG_IPC_NS=n, clone(CLONE_NEWIPC) claims success, but did not actually
clone a new IPC namespace.
Fix this to return -EINVAL so the caller knows his request was denied.
Signed-off-by: Serge E. Hallyn <serue@us.ibm.com>
Cc: "Eric W. Biederman" <ebiederm@xmission.com>
When CONFIG_UTS_NS=n, clone(CLONE_NEWUTS) quietly refuses. So correctly does
not unshare a new uts namespace, but also does not return -EINVAL.
UML/x86_64 needs the same packing of struct epoll_event as x86_64.
Signed-off-by: Jeff Dike <jdike@linux.intel.com>
Cc: Davide Libenzi <davidel@xmailserver.org>
Ocfs2 wants to implement it's own splice write actor so that it can better
manage cluster / page locks. This lets us re-use the rest of splice write
while only providing our own code where it's actually important.
Signed-off-by: Mark Fasheh <mark.fasheh@oracle.com>
Change prototypes for __chk_user_ptr and __chk_io_ptr to take const
void* instead of void*, so that code can pass "const void *" to them.
(Right now sparse does not warn about passing const void* to void*
functions, but that is a separate bug that I believe Josh is working on,
and once sparse does check this, the changed prototypes will be
necessary.)
Signed-off-by: Russ Cox <rsc@swtch.com>
Signed-off-by: Josh Triplett <josh@freedesktop.org>
Acked-by: Christopher Li <sparse@chrisli.org>
IDE error recovery is using IDLE IMMEDIATE if the drive is busy or has DRQ set.
This violates the ATA spec (can only send IDLEÂ IMMEDIATE when drive is not
busy) and really hoses up some drives (modern drives will not be able to
recover using this error handling). The correct thing to do is issue a SRST
followed by a SET FEATURES command. This is what Western Digital recommends
for error recovery and what Western Digital says Windows does.  It also does
not violate the ATA spec as far as I can tell.
Bart:
* port the patch over the current tree
* undo the recalibration code removal
* send SET FEATURES command after checking for good drive status
* don't check whether the current request is of REQ_TYPE_ATA_{CMD,TASK}
type because we need to send SET FEATURES before handling any requests
* some pre-ATA4 drives require INITIALIZE DEVICE PARAMETERS command before
other commands (except IDENTIFY) so send SET FEATURES only if there are
no pending drive->special requests
* update comments and patch description
* any bugs introduced by this patch are mine and not Suleiman's :-)
Acked-by: Alan Cox <alan@redhat.com>
lockdep found a bug during a run of workqueue function - this could be also
caused by a bug from other code running simultaneously.
lockdep really shouldn't be used when debug_locks == 0!
Reported-by: Folkert van Heusden <folkert@vanheusden.com>
Inspired-by: Oleg Nesterov <oleg@tv-sign.ru>
Signed-off-by: Jarek Poplawski <jarkao2@o2.pl>
Acked-by: Peter Zijlstra <a.p.zijlstra@chello.nl>
Fix unannotated variable declarations. Variables that have allocation
section annotations (such as __meminitdata) on their definitions must also
have them on their declarations as not doing so may affect the addressing
mode used by the compiler and may result in a linker error.
Acked-by: Yasunori Goto <y-goto@jp.fujitsu.com>
Since d9a9cdfb078d755e648d53ec25b7370f84ee5729 <linux/sysfs.h> is using
ENOSYS without including <linux/errno.h> if CONFIG_SYSFS is disabled.
Fixed by including <linux/errno.h>.
The maximum seconds value we can handle on 32bit is LONG_MAX.
The current NFS client congestion logic is severly broken, it marks the
backing device congested during each nfs_writepages() call but doesn't
mirror this in nfs_writepage() which makes for deadlocks. Also it
implements its own waitqueue.
Replace this by a more regular congestion implementation that puts a cap on
the number of active writeback pages and uses the bdi congestion waitqueue.
Also always use an interruptible wait since it makes sense to be able to
SIGKILL the process even for mounts without 'intr'.
Acked-by: Trond Myklebust <trond.myklebust@fys.uio.no>
Cc: Christoph Lameter <clameter@engr.sgi.com>
When the console is in VT_AUTO+KD_GRAPHICS mode, switching to the
SUSPEND_CONSOLE fails, resulting in vt_waitactive() waiting indefinitely or
until the task is interrupted. This patch tests if a console switch can
occur in set_console() and returns early if a console switch is not
possible.
[akpm@linux-foundation.org: cleanup]
Signed-off-by: Andrew Johnson <ajohnson@intrinsyc.com>
Acked-by: Pavel Machek <pavel@ucw.cz>
Cc: "Antonino A. Daplas" <adaplas@pol.net>
Cc: "Rafael J. Wysocki" <rjw@sisk.pl>
