As suggested by Linus, align functions should return the start
of a resource, not void. An update of "res->start" is no longer
necessary.
Cc: Bjorn Helgaas <bjorn.helgaas@hp.com>
Cc: Yinghai Lu <yhlu.kernel@gmail.com>
Signed-off-by: Dominik Brodowski <linux@dominikbrodowski.net>
Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
This patch adds the Intel Cougar Point (PCH) LPC and SMBus Controller DeviceIDs.
Signed-off-by: Seth Heasley <seth.heasley@intel.com>
Currently, drivers/pci/quirks.c is built unconditionally, but if
CONFIG_PCI_QUIRKS is unset, the only things actually built in this
file are definitions of global variables and empty functions (due to
the #ifdef CONFIG_PCI_QUIRKS embracing all of the code inside the
file). This is not particularly nice and if someone overlooks
the #ifdef CONFIG_PCI_QUIRKS, build errors are introduced.
To clean that up, move the definitions of the global variables in
quirks.c that are always built to pci.c, move the definitions of
the empty functions (compiled when CONFIG_PCI_QUIRKS is unset) to
headers (additionally make these functions static inline) and modify
drivers/pci/Makefile so that quirks.c is only built if
CONFIG_PCI_QUIRKS is set.
Add the 8.0 GT/s speed.
Signed-off-by: Matthew Wilcox <willy@linux.intel.com>
Take advantage of some gaps in the table to fit in support for AGP speeds.
Move the max_bus_speed and cur_bus_speed into the pci_bus. Expose the
values through the PCI slot driver instead of the hotplug slot driver.
Update all the hotplug drivers to use the pci_bus instead of their own
data structures.
These enums must not overlap anyway, since we only have a single
pci_bus_speed_strings array. Use a single enum, and move it to
pci.h. Add 'SPEED' to the pcie names to make it clear what they are.
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs-2.6
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs-2.6:
CacheFiles: Fix a race in cachefiles_delete_object() vs rename
vfs: don't call ima_file_check() unconditionally in nfsd_open()
fs: inode - remove 8 bytes of padding on 64bits allowing 1 more objects/slab under slub
Switch proc/self to nd_set_link()
fix LOOKUP_FOLLOW on automount "symlinks"
This fixes the filepath encoded in <linux/amba/bus.h> and adds
some documentation as to what this bus really means.
Signed-off-by: Linus Walleij <linus.walleij@stericsson.com>
under slub
This removes 8 bytes of padding from struct inode on 64bit builds, and
so allows 1 more object/slab in the inode_cache when using slub.
Signed-off-by: Richard Kennedy <richard@rsk.demon.co.uk>
patch against 2.6.33-rc8
compiled & tested on x86_64 AMDX2
I've been running this patch for over a week with no obvious problems
regards
Richard
git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input:
Input: add KEY_RFKILL
Input: i8042 - fix KBC jam during hibernate
Most laptops have keys that are intended to toggle all device state, not
just wifi. These are currently generally mapped to KEY_WLAN. As a result,
rfkill will only kill or enable wifi in response to the key press. This
confuses users and can make it difficult for them to enable bluetooth
and wwan devices.
This patch adds a new keycode, KEY_RFKILL. It indicates that the system
should toggle the state of all rfkillable devices.
Acked-by: Marcel Holtmann <marcel@holtmann.org>
This patch fixes following sparse warnings:
include/linux/kfifo.h:127:25: warning: Using plain integer as NULL pointer
kernel/kfifo.c:83:21: warning: Using plain integer as NULL pointer
Signed-off-by: Anton Vorontsov <avorontsov@ru.mvista.com>
Acked-by: Stefani Seibold <stefani@seibold.net>
* 'perf-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip:
perf top: Fix help text alignment
perf: Fix hypervisor sample reporting
perf: Make bp_len type to u64 generic across the arch
ima_path_check actually deals with files! call it ima_file_check instead.
Signed-off-by: Eric Paris <eparis@redhat.com>
Acked-by: Mimi Zohar <zohar@linux.vnet.ibm.com>
The "Untangling ima mess, part 2 with counters" patch messed
up the counters. Based on conversations with Al Viro, this patch
streamlines ima_path_check() by removing the counter maintaince.
The counters are now updated independently, from measuring the file,
in __dentry_open() and alloc_file() by calling ima_counts_get().
ima_path_check() is called from nfsd and do_filp_open().
It also did not measure all files that should have been measured.
Reason: ima_path_check() got bogus value passed as mask.
[AV: mea culpa]
[AV: add missing nfsd bits]
Signed-off-by: Mimi Zohar <zohar@us.ibm.com>
git://git.kernel.org/pub/scm/linux/kernel/git/jgarzik/libata-dev
* 'upstream-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jgarzik/libata-dev:
[libata] Call flush_dcache_page after PIO data transfers in libata-sff.c
ahci: add Acer G725 to broken suspend list
libata: fix ata_id_logical_per_physical_sectors
libata-scsi passthru: fix bug which truncated LBA48 return values
This is to make the annotation of percpu variables during the next merge
window less painfull.
Extracted from a patch by Rusty Russell.
Acked-by: Tejun Heo <tj@kernel.org>
* 'core-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip:
futex: Handle futex value corruption gracefully
futex: Handle user space corruption gracefully
futex_lock_pi() key refcnt fix
softlockup: Add sched_clock_tick() to avoid kernel warning on kgdb resume
The value we get from the low byte of the ATA_ID_SECTOR_SIZE word is not not
a plain multiple, but the log of it, so fix the helper to give the correct
answer. Without this we'll get an incorrect minimal I/O size in the block
limits VPD page for 4k sector drives.
Also change the return value of ata_id_logical_per_physical_sectors to u16
for the unlikely case of very large logical sectors.
Change 'bp_len' type to __u64 to make it work across archs as
the s390 architecture watch point length can be upto 2^64.
reference:
http://lkml.org/lkml/2010/1/25/212
This is an ABI change that is not backward compatible with
the previous hardware breakpoint info layout integrated in this
development cycle, a rebuilt of perf tools is necessary for
versions based on 2.6.33-rc1 - 2.6.33-rc6 to work with a
kernel based on this patch.
Signed-off-by: Mahesh Salgaonkar <mahesh@linux.vnet.ibm.com>
Acked-by: Peter Zijlstra <peterz@infradead.org>
Cc: Ananth N Mavinakayanahalli <ananth@in.ibm.com>
Cc: "K. Prasad" <prasad@linux.vnet.ibm.com>
Cc: Maneesh Soni <maneesh@in.ibm.com>
Cc: Martin <schwidefsky@de.ibm.com>
LKML-Reference: <20100130045518.GA20776@in.ibm.com>
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6: (23 commits)
connector: Delete buggy notification code.
be2net: use eq-id to calculate cev-isr reg offset
Bluetooth: Use the control channel for raw HID reports
Bluetooth: Add DFU driver for Atheros Bluetooth chipset AR3011
Bluetooth: Redo checks in IRQ handler for shared IRQ support
Bluetooth: Fix memory leak in L2CAP
Bluetooth: Remove double free of SKB pointer in L2CAP
cdc_ether: Partially revert "usbnet: Set link down initially ..."
be2net: Fix memset() arg ordering.
bonding: bond_open error return value
ixgbe: if ixgbe_copy_dcb_cfg is going to fail learn about it early
ixgbe: set the correct DCB bit for pg tx settings
igbvf: fix issue w/ mapped_as_page being left set after unmap
drivers/net: ks8851_mll ethernet network driver
be2net: Bug fix to support newer generation of BE ASIC
starfire: clean up properly if firmware loading fails
mac80211: fix NULL pointer dereference when ftrace is enabled
netfilter: ctnetlink: fix expectation mask dump
ipv6: conntrack: Add member of user to nf_ct_frag6_queue structure
ath9k: fix eeprom INI values override for 2GHz-only cards
On Tue, Feb 02, 2010 at 02:57:14PM -0800, Greg KH (gregkh@suse.de) wrote:
> > There are at least two ways to fix it: using a big cannon and a small
> > one. The former way is to disable notification registration, since it is
> > not used by anyone at all. Second way is to check whether calling
> > process is root and its destination group is -1 (kind of priveledged
> > one) before command is dispatched to workqueue.
> Well if no one is using it, removing it makes the most sense, right?
> No objection from me, care to make up a patch either way for this?
Getting it is not used, let's drop support for notifications about
(un)registered events from connector.
Another option was to check credentials on receiving, but we can always
restore it without bugs if needed, but genetlink has a wider code base
and none complained, that userspace can not get notification when some
other clients were (un)registered.
Kudos for Sebastian Krahmer <krahmer@suse.de>, who found a bug in the
code.
Signed-off-by: Evgeniy Polyakov <zbr@ioremap.net>
perf, hw_breakpoint, kgdb: Do not take mutex for kernel debugger
x86, hw_breakpoints, kgdb: Fix kgdb to use hw_breakpoint API
hw_breakpoints: Release the bp slot if arch_validate_hwbkpt_settings() fails.
perf: Ignore perf.data.old
perf report: Fix segmentation fault when running with '-g none'
git://git.kernel.org/pub/scm/linux/kernel/git/benh/powerpc
* 'merge' of git://git.kernel.org/pub/scm/linux/kernel/git/benh/powerpc:
powerpc: TIF_ABI_PENDING bit removal
powerpc/pseries: Fix xics build without CONFIG_SMP
powerpc/4xx: Add pcix type 1 transactions
powerpc/pci: Add missing call to header fixup
powerpc/pci: Add missing hookup to pci_slot
powerpc/pci: Add calls to set_pcie_port_type() and set_pcie_hotplug_bridge()
powerpc/40x: Update the PowerPC 40x board defconfigs
powerpc/44x: Update PowerPC 44x board defconfigs
When CONFIG_HAVE_UNSTABLE_SCHED_CLOCK is set, sched_clock() gets
the time from hardware such as the TSC on x86. In this
configuration kgdb will report a softlock warning message on
resuming or detaching from a debug session.
Sequence of events in the problem case:
1) "cpu sched clock" and "hardware time" are at 100 sec prior
to a call to kgdb_handle_exception()
2) Debugger waits in kgdb_handle_exception() for 80 sec and on
exit the following is called ... touch_softlockup_watchdog() -->
__raw_get_cpu_var(touch_timestamp) = 0;
3) "cpu sched clock" = 100s (it was not updated, because the
interrupt was disabled in kgdb) but the "hardware time" = 180 sec
4) The first timer interrupt after resuming from
kgdb_handle_exception updates the watchdog from the "cpu sched clock"
update_process_times() { ... run_local_timers() -->
softlockup_tick() --> check (touch_timestamp == 0) (it is "YES"
here, we have set "touch_timestamp = 0" at kgdb) -->
__touch_softlockup_watchdog() ***(A)--> reset "touch_timestamp"
to "get_timestamp()" (Here, the "touch_timestamp" will still be
set to 100s.) ...
scheduler_tick() ***(B)--> sched_clock_tick() (update "cpu sched
clock" to "hardware time" = 180s) ... }
5) The Second timer interrupt handler appears to have a large
jump and trips the softlockup warning.
softlockup_tick() --> "cpu sched clock" - "touch_timestamp" =
180s-100s > 60s --> printk "soft lockup error messages" ... }
note: ***(A) reset "touch_timestamp" to
"get_timestamp(this_cpu)"
Why is "touch_timestamp" 100 sec, instead of 180 sec?
When CONFIG_HAVE_UNSTABLE_SCHED_CLOCK is set, the call trace of
get_timestamp() is:
-->cpu_clock(this_cpu)
-->sched_clock_cpu(this_cpu)
-->__update_sched_clock(sched_clock_data, now)
The __update_sched_clock() function uses the GTOD tick value to
create a window to normalize the "now" values. So if "now"
value is too big for sched_clock_data, it will be ignored.
The fix is to invoke sched_clock_tick() to update "cpu sched
clock" in order to recover from this state. This is done by
introducing the function touch_softlockup_watchdog_sync(). This
allows kgdb to request that the sched clock is updated when the
watchdog thread runs the first time after a resume from kgdb.
[yong.zhang0@gmail.com: Use per cpu instead of an array]
Signed-off-by: Jason Wessel <jason.wessel@windriver.com>
Signed-off-by: Dongdong Deng <Dongdong.Deng@windriver.com>
Cc: kgdb-bugreport@lists.sourceforge.net
Cc: peterz@infradead.org
LKML-Reference: <1264631124-4837-2-git-send-email-jason.wessel@windriver.com>
This patch fixes the regression in functionality where the
kernel debugger and the perf API do not nicely share hw
breakpoint reservations.
The kernel debugger cannot use any mutex_lock() calls because it
can start the kernel running from an invalid context.
A mutex free version of the reservation API needed to get
created for the kernel debugger to safely update hw breakpoint
reservations.
The possibility for a breakpoint reservation to be concurrently
processed at the time that kgdb interrupts the system is
improbable. Should this corner case occur the end user is
warned, and the kernel debugger will prohibit updating the
hardware breakpoint reservations.
Any time the kernel debugger reserves a hardware breakpoint it
will be a system wide reservation.
Acked-by: Frederic Weisbecker <fweisbec@gmail.com>
Cc: K.Prasad <prasad@linux.vnet.ibm.com>
Cc: Alan Stern <stern@rowland.harvard.edu>
Cc: torvalds@linux-foundation.org
LKML-Reference: <1264719883-7285-3-git-send-email-jason.wessel@windriver.com>
Input: update multi-touch protocol documentation
Input: add the ABS_MT_PRESSURE event
Input: winbond-cir - remove dmesg spam
Input: lifebook - add another Lifebook DMI signature
Input: ad7879 - support auxiliary GPIOs via gpiolib
'flush_old_exec()' is the point of no return when doing an execve(), and
it is pretty badly misnamed. It doesn't just flush the old executable
environment, it also starts up the new one.
Which is very inconvenient for things like setting up the new
personality, because we want the new personality to affect the starting
of the new environment, but at the same time we do _not_ want the new
personality to take effect if flushing the old one fails.
As a result, the x86-64 '32-bit' personality is actually done using this
insane "I'm going to change the ABI, but I haven't done it yet" bit
(TIF_ABI_PENDING), with SET_PERSONALITY() not actually setting the
personality, but just the "pending" bit, so that "flush_thread()" can do
the actual personality magic.
This patch in no way changes any of that insanity, but it does split the
'flush_old_exec()' function up into a preparatory part that can fail
(still called flush_old_exec()), and a new part that will actually set
up the new exec environment (setup_new_exec()). All callers are changed
to trivially comply with the new world order.
Signed-off-by: H. Peter Anvin <hpa@zytor.com>
Cc: stable@kernel.org
For pressure-based multi-touch devices, a direct way to send sensor
intensity data per finger is needed. This patch adds the ABS_MT_PRESSURE
event to the MT protocol.
Requested-by: Yoonyoung Shim <jy0922.shim@samsung.com>
Requested-by: Mika Kuoppala <mika.kuoppala@nokia.com>
Requested-by: Peter Hutterer <peter.hutterer@who-t.net>
Signed-off-by: Henrik Rydberg <rydberg@euromail.se>
We are missing these when building the pci_dev from scratch off
the Open Firmware device-tree
Acked-by: Jesse Barnes <jbarnes@virtuousgeek.org>
git://git.kernel.org/pub/scm/linux/kernel/git/ieee1394/linux1394-2.6
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/ieee1394/linux1394-2.6:
firewire: ohci: fix crashes with TSB43AB23 on 64bit systems
firewire: core: fix use-after-free regression in FCP handler
firewire: cdev: add_descriptor documentation fix
firewire: core: add_descriptor size check
It's a simplified 'read_cache_page()' which takes a page allocation
flag, so that different paths can control how aggressive the memory
allocations are that populate a address space.
In particular, the intel GPU object mapping code wants to be able to do
a certain amount of own internal memory management by automatically
shrinking the address space when memory starts getting tight. This
allows it to dynamically use different memory allocation policies on a
per-allocation basis, rather than depend on the (static) address space
gfp policy.
The actual new function is a one-liner, but re-organizing the helper
functions to the point where you can do this with a single line of code
is what most of the patch is all about.
Tested-by: Chris Wilson <chris@chris-wilson.co.uk>
struct fw_cdev_add_descriptor.length is in quadlets, not in bytes.
Also remove any doubts about the endianess of descriptor data.
Signed-off-by: Stefan Richter <stefanr@s5r6.in-berlin.de>
* 'kvm-updates/2.6.33' of git://git.kernel.org/pub/scm/virt/kvm/kvm:
KVM: x86: Fix leak of free lapic date in kvm_arch_vcpu_init()
KVM: x86: Fix probable memory leak of vcpu->arch.mce_banks
KVM: S390: fix potential array overrun in intercept handling
KVM: fix spurious interrupt with irqfd
eventfd - allow atomic read and waitqueue remove
KVM: MMU: bail out pagewalk on kvm_read_guest error
KVM: properly check max PIC pin in irq route setup
KVM: only allow one gsi per fd
KVM: x86: Fix host_mapping_level()
KVM: powerpc: Show timing option only on embedded
KVM: Fix race between APIC TMR and IRR
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6: (42 commits)
virtio_net: Make delayed refill more reliable
sfc: Use fixed-size buffers for MCDI NVRAM requests
sfc: Add workspace for GMAC bug workaround to MCDI MAC_STATS buffer
tcp_probe: avoid modulus operation and wrap fix
qlge: Only free resources if they were allocated
netns xfrm: deal with dst entries in netns
sky2: revert config space change
vlan: fix vlan_skb_recv()
netns xfrm: fix "ip xfrm state|policy count" misreport
sky2: Enable/disable WOL per hardware device
net: Fix IPv6 GSO type checks in Intel ethernet drivers
igb/igbvf: cleanup exception handling in tx_map_adv
MAINTAINERS: Add Intel igbvf maintainer
e1000/e1000e: don't use small hardware rx buffers
fmvj18x_cs: add new id (Panasonic lan & modem card)
be2net: swap only first 2 fields of mcc_wrb
Please add support for Microsoft MN-120 PCMCIA network card
be2net: fix bug in rx page posting
wimax/i2400m: Add support for more i6x50 SKUs
e1000e: enhance frame fragment detection
KVM needs a wait to atomically remove themselves from the eventfd ->poll()
wait queue head, in order to handle correctly their IRQfd deassign
operation.
This patch introduces such API, plus a way to read an eventfd from its
context.
Signed-off-by: Davide Libenzi <davidel@xmailserver.org>
Signed-off-by: Avi Kivity <avi@redhat.com>
* git://git.infradead.org/~dwmw2/mtd-2.6.33:
mtd: tests: fix read, speed and stress tests on NOR flash
mtd: Really add ARM pismo support
kmsg_dump: Dump on crash_kexec as well
perf: x86: Add support for the ANY bit
perf: Change the is_software_event() definition
perf: Honour event state for aux stream data
perf: Fix perf_event_do_pending() fallback callsite
perf kmem: Print usage help for unknown commands
perf kmem: Increase "Hit" column length
hw-breakpoints, perf: Fix broken mmiotrace due to dr6 by reference change
perf timechart: Use tid not pid for COMM change
* 'sched-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip:
sched: Reassign prev and switch_count when reacquire_kernel_lock() fail
sched: Fix vmark regression on big machines
* git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb-2.6:
USB: isp1362: fix build failure on ARM systems via irq_flags cleanup
USB: isp1362: better 64bit printf warning fixes
USB: fix usbstorage for 2770:915d delivers no FAT
USB: Fix level of isp1760 Reloading ptd error message
USB: FHCI: avoid NULL pointer dereference
USB: Fix duplicate sysfs problem after device reset.
USB: add speed values for USB 3.0 and wireless controllers
USB: add missing delay during remote wakeup
USB: EHCI & UHCI: fix race between root-hub suspend and port resume
USB: EHCI: fix handling of unusual interrupt intervals
USB: Don't use GFP_KERNEL while we cannot reset a storage device
USB: fix bitmask merge error
usb: serial: fix memory leak in generic driver
USB: serial: fix USB serial fix kfifo_len locking
* 'for-linus' of git://git.kernel.dk/linux-2.6-block:
fs/bio.c: fix shadows sparse warning
drbd: The kernel code is now equivalent to out of tree release 8.3.7
drbd: Allow online resizing of DRBD devices while peer not reachable (needs to be explicitly forced)
drbd: Don't go into StandAlone mode when authentification failes because of network error
drivers/block/drbd/drbd_receiver.c: correct NULL test
cfq-iosched: Respect ioprio_class when preempting
genhd: overlapping variable definition
block: removed unused as_io_context
DM: Fix device mapper topology stacking
block: bdev_stack_limits wrapper
block: Fix discard alignment calculation and printing
block: Correct handling of bottom device misaligment
drbd: check on CONFIG_LBDAF, not LBD
drivers/block/drbd: Correct NULL test
drbd: Silenced an assert that could triggered after changing write ordering method
drbd: Kconfig fix
drbd: Fix for a race between IO and a detach operation [Bugz 262]
drbd: Use drbd_crypto_is_hash() instead of an open coded check
The is_software_event() definition always confuses me because its an
exclusive expression, make it an inclusive one.
LKML-Reference: <new-submission>
SD_PREFER_SIBLING is set at the CPU domain level if power saving isn't
enabled, leading to many cache misses on large machines as we traverse
looking for an idle shared cache to wake to. Change the enabler of
select_idle_sibling() to SD_SHARE_PKG_RESOURCES, and enable same at the
sibling domain level.
Reported-by: Lin Ming <ming.m.lin@intel.com>
Signed-off-by: Mike Galbraith <efault@gmx.de>
LKML-Reference: <1262612696.15495.15.camel@marge.simson.net>
Borislav Petkov reports issues with duplicate sysfs endpoint files after a
resume from a hibernate. It turns out that the code to support alternate
settings under xHCI has issues when a device with a non-default alternate
setting is reset during the hibernate:
[ 427.681810] Restarting tasks ...
[ 427.681995] hub 1-0:1.0: state 7 ports 6 chg 0004 evt 0000
[ 427.682019] usb usb3: usb resume
[ 427.682030] ohci_hcd 0000:00:12.0: wakeup root hub
[ 427.682191] hub 1-0:1.0: port 2, status 0501, change 0000, 480 Mb/s
[ 427.682205] usb 1-2: usb wakeup-resume
[ 427.682226] usb 1-2: finish reset-resume
[ 427.682886] done.
[ 427.734658] ehci_hcd 0000:00:12.2: port 2 high speed
[ 427.734663] ehci_hcd 0000:00:12.2: GetStatus port 2 status 001005 POWER sig=se0 PE CONNECT
[ 427.746682] hub 3-0:1.0: hub_reset_resume
[ 427.746693] hub 3-0:1.0: trying to enable port power on non-switchable hub
[ 427.786715] usb 1-2: reset high speed USB device using ehci_hcd and address 2
[ 427.839653] ehci_hcd 0000:00:12.2: port 2 high speed
[ 427.839666] ehci_hcd 0000:00:12.2: GetStatus port 2 status 001005 POWER sig=se0 PE CONNECT
[ 427.847717] ohci_hcd 0000:00:12.0: GetStatus roothub.portstatus [1] = 0x00010100 CSC PPS
[ 427.915497] hub 1-2:1.0: remove_intf_ep_devs: if: ffff88022f9e8800 ->ep_devs_created: 1
[ 427.915774] hub 1-2:1.0: remove_intf_ep_devs: bNumEndpoints: 1
[ 427.915934] hub 1-2:1.0: if: ffff88022f9e8800: endpoint devs removed.
[ 427.916158] hub 1-2:1.0: create_intf_ep_devs: if: ffff88022f9e8800 ->ep_devs_created: 0, ->unregistering: 0
[ 427.916434] hub 1-2:1.0: create_intf_ep_devs: bNumEndpoints: 1
[ 427.916609] ep_81: create, parent hub
[ 427.916632] ------------[ cut here ]------------
[ 427.916644] WARNING: at fs/sysfs/dir.c:477 sysfs_add_one+0x82/0x96()
[ 427.916649] Hardware name: System Product Name
[ 427.916653] sysfs: cannot create duplicate filename '/devices/pci0000:00/0000:00:12.2/usb1/1-2/1-2:1.0/ep_81'
[ 427.916658] Modules linked in: binfmt_misc kvm_amd kvm powernow_k8 cpufreq_ondemand cpufreq_powersave cpufreq_userspace freq_table cpufreq_conservative ipv6 vfat fat
+8250_pnp 8250 pcspkr ohci_hcd serial_core k10temp edac_core
[ 427.916694] Pid: 278, comm: khubd Not tainted 2.6.33-rc2-00187-g08d869a-dirty #13
[ 427.916699] Call Trace:
The problem is caused by a mismatch between the USB core's view of the
device state and the USB device and xHCI host's view of the device state.
After the device reset and re-configuration, the device and the xHCI host
think they are using alternate setting 0 of all interfaces. However, the
USB core keeps track of the old state, which may include non-zero
alternate settings. It uses intf->cur_altsetting to keep the endpoint
sysfs files for the old state across the reset.
The bandwidth allocation functions need to know what the xHCI host thinks
the current alternate settings are, so original patch set
intf->cur_altsetting to the alternate setting 0. This caused duplicate
endpoint files to be created.
The solution is to not set intf->cur_altsetting before calling
usb_set_interface() in usb_reset_and_verify_device(). Instead, we add a
new flag to struct usb_interface to tell usb_hcd_alloc_bandwidth() to use
alternate setting 0 as the currently installed alternate setting.
Signed-off-by: Sarah Sharp <sarah.a.sharp@linux.intel.com>
Tested-by: Borislav Petkov <petkovbb@googlemail.com>
commit 541cd3ee00a4fe975b22fac6a3bc846bacef37f7 ("phylib: Fix deadlock
on resume") caused TI DaVinci EMAC ethernet driver to oops upon resume:
PM: resume of devices complete after 237.098 msecs
Restarting tasks ... done.
kernel BUG at kernel/workqueue.c:354!
Unable to handle kernel NULL pointer dereference at virtual address 00000000
Backtrace:
[<c002c598>] (__bug+0x0/0x2c) from [<c0052a54>] (queue_delayed_work_on+0x74/0xf8)
[<c00529e0>] (queue_delayed_work_on+0x0/0xf8) from [<c0052b30>] (queue_delayed_work+0x2c/0x30)
The oops pops up because TI DaVinci EMAC driver detaches PHY on
suspend and attaches it back on resume. Attaching makes phylib call
phy_start_machine() that initializes a workqueue. On the other hand,
PHY's resume routine will call phy_start_machine() again, and that
will cause the oops since we just destroyed the already scheduled
workqueue.
This patch fixes the issue by moving workqueue initialization to
phy_device_create().
p.s. We don't see this oops with ucc_geth and gianfar drivers because
they perform a fine-grained suspend, i.e. they just stop the PHYs
without detaching.
Reported-by: Sekhar Nori <nsekhar@ti.com>
Tested-by: Sekhar Nori <nsekhar@ti.com>
Drop the simple fancy sysfs hooks for the aux GPIOs and expose these via
the gpiolib interface so that other drivers can use them.
Signed-off-by: Michael Hennerich <michael.hennerich@analog.com>
This patch abstracts out the CNF area code from tmio_mmc which
is not present in all hardware that can use this driver. This
is required so that we can support non-toshiba based hardware.
ASIC3 support by Philipp Zabel
Signed-off-by: Ian Molton <ian@mnementh.co.uk>
Signed-off-by: Magnus Damm <damm@opensource.se>
