path: root/include/linux
2008-01-31Move usbnet.h and rndis_host.h to include/linux/usbJussi Kivilinna
Move headers usbnet.h and rndis_host.h to include/linux/usb and fix includes for drivers/net/usb modules. Headers are moved because rndis_wlan will be outside drivers/net/usb in drivers/net/wireless and yet need these headers. Signed-off-by: Jussi Kivilinna <jussi.kivilinna@mbnet.fi> Acked-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: John W. Linville <linville@tuxdriver.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-31rfkill: add the WiMAX radio typeIñaky Pérez-González
Teach rfkill about wimax radios. Had to define a KEY_WIMAX as a 'key for disabling only wimax radios', as other radio technologies have. This makes sense as hardware has specific keys for disabling specific radios. The RFKILL enabling part is, otherwise, a copy and paste of any other radio technology. Signed-off-by: Inaky Perez-Gonzalez <inaky@linux.intel.com> Signed-off-by: Ivo van Doorn <IvDoorn@gmail.com> Signed-off-by: John W. Linville <linville@tuxdriver.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-02-01Merge branch 'task_killable' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/willy/misc * 'task_killable' of git://git.kernel.org/pub/scm/linux/kernel/git/willy/misc: (22 commits) Remove commented-out code copied from NFS NFS: Switch from intr mount option to TASK_KILLABLE Add wait_for_completion_killable Add wait_event_killable Add schedule_timeout_killable Use mutex_lock_killable in vfs_readdir Add mutex_lock_killable Use lock_page_killable Add lock_page_killable Add fatal_signal_pending Add TASK_WAKEKILL exit: Use task_is_* signal: Use task_is_* sched: Use task_contributes_to_load, TASK_ALL and TASK_NORMAL ptrace: Use task_is_* power: Use task_is_* wait: Use TASK_NORMAL proc/base.c: Use task_is_* proc/array.c: Use TASK_REPORT perfmon: Use task_is_* ... Fixed up conflicts in NFS/sunrpc manually..
2008-01-31asm-generic/tlb.h: build fixIngo Molnar
bring back the avr32, blackfin, sh, sparc architectures into working order, by reverting the effects of this change that came in via the x86 tree: commit a5a19c63f4e55e32dc0bc3d936d7f94793d8b380 Author: Jeremy Fitzhardinge <jeremy@goop.org> Date: Wed Jan 30 13:33:39 2008 +0100 x86: demacro asm-x86/pgalloc_32.h Sorry about that! Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-01-31Merge branch 'for-2.6.25' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/paulus/powerpc * 'for-2.6.25' of git://git.kernel.org/pub/scm/linux/kernel/git/paulus/powerpc: (454 commits) [POWERPC] Cell IOMMU fixed mapping support [POWERPC] Split out the ioid fetching/checking logic [POWERPC] Add support to cell_iommu_setup_page_tables() for multiple windows [POWERPC] Split out the IOMMU logic from cell_dma_dev_setup() [POWERPC] Split cell_iommu_setup_hardware() into two parts [POWERPC] Split out the logic that allocates struct iommus [POWERPC] Allocate the hash table under 1G on cell [POWERPC] Add set_dma_ops() to match get_dma_ops() [POWERPC] 83xx: Clean up / convert mpc83xx board DTS files to v1 format. [POWERPC] 85xx: Only invalidate TLB0 and TLB1 [POWERPC] 83xx: Fix typo in mpc837x compatible entries [POWERPC] 85xx: convert sbc85* boards to use machine_device_initcall [POWERPC] 83xx: rework platform Kconfig [POWERPC] 85xx: rework platform Kconfig [POWERPC] 86xx: Remove unused IRQ defines [POWERPC] QE: Explicitly set address-cells and size cells for muram [POWERPC] Convert StorCenter DTS file to /dts-v1/ format. [POWERPC] 86xx: Convert all 86xx DTS files to /dts-v1/ format. [PPC] Remove 85xx from arch/ppc [PPC] Remove 83xx from arch/ppc ...
2008-01-31Merge git://git.kernel.org/pub/scm/linux/kernel/git/x86/linux-2.6-x86Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/x86/linux-2.6-x86: alpha: fix x86.git merge build error ia64: on UP percpu variables are not small memory model x86: fix arch/x86/kernel/test_nx.c modular build bug s390: use generic percpu linux-2.6.git POWERPC: use generic per cpu ia64: use generic percpu SPARC64: use generic percpu percpu: change Kconfig to HAVE_SETUP_PER_CPU_AREA modules: fold percpu_modcopy into module.c x86: export copy_from_user_ll_nocache[_nozero] x86: fix duplicated TIF on 64-bit
2008-01-31Merge branch 'linux-2.6'Paul Mackerras
2008-01-31Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jmorris/selinux-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jmorris/selinux-2.6: security: compile capabilities by default selinux: make selinux_set_mnt_opts() static SELinux: Add warning messages on network denial due to error SELinux: Add network ingress and egress control permission checks NetLabel: Add auditing to the static labeling mechanism NetLabel: Introduce static network labels for unlabeled connections SELinux: Allow NetLabel to directly cache SIDs SELinux: Enable dynamic enable/disable of the network access checks SELinux: Better integration between peer labeling subsystems SELinux: Add a new peer class and permissions to the Flask definitions SELinux: Add a capabilities bitmap to SELinux policy version 22 SELinux: Add a network node caching mechanism similar to the sel_netif_*() functions SELinux: Only store the network interface's ifindex SELinux: Convert the netif code to use ifindex values NetLabel: Add IP address family information to the netlbl_skbuff_getattr() function NetLabel: Add secid token support to the NetLabel secattr struct NetLabel: Consolidate the LSM domain mapping/hashing locks NetLabel: Cleanup the LSM domain hash functions NetLabel: Remove unneeded RCU read locks
2008-01-31Merge git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-2.6: PPC: Fix powerpc vio_find_name to not use devices_subsys Driver core: add bus_find_device_by_name function Module: check to see if we have a built in module with the same name x86: fix runtime error in arch/x86/kernel/cpu/mcheck/mce_amd_64.c Driver core: Fix up build when CONFIG_BLOCK=N
2008-01-30ia64: use generic percputravis@sgi.com
ia64 has a special processor specific mapping that can be used to locate the offset for the current per cpu area. Cc: linux-ia64@vger.kernel.org Signed-off-by: Mike Travis <travis@sgi.com> Acked-by: Tony Luck <tony.luck@intel.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-01-30KVM: Move apic timer migration away from critical sectionAvi Kivity
Migrating the apic timer in the critical section is not very nice, and is absolutely horrible with the real-time port. Move migration to the regular vcpu execution path, triggered by a new bitflag. Cc: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Avi Kivity <avi@qumranet.com>
2008-01-30KVM: Put kvm_para.h include outside __KERNEL__Glauber de Oliveira Costa
kvm_para.h potentially contains definitions that are to be used by userspace, so it should not be included inside the __KERNEL__ block. To protect its own data structures, kvm_para.h already includes its own __KERNEL__ block. Signed-off-by: Glauber de Oliveira Costa <gcosta@redhat.com> Acked-by: Amit Shah <amit.shah@qumranet.com> Signed-off-by: Avi Kivity <avi@qumranet.com>
2008-01-30KVM: Portability: Move kvm_fpu to asm-x86/kvm.hChristian Ehrhardt
This patch moves kvm_fpu asm-x86/kvm.h to allow every architecture to define an own representation used for KVM_GET_FPU/KVM_SET_FPU. Signed-off-by: Christian Ehrhardt <ehrhardt@linux.vnet.ibm.com> Acked-by: Carsten Otte <cotte@de.ibm.com> Acked-by: Zhang Xiantao <xiantao.zhang@intel.com> Signed-off-by: Avi Kivity <avi@qumranet.com>
2008-01-30KVM: MMU: Switch to mmu spinlockMarcelo Tosatti
Convert the synchronization of the shadow handling to a separate mmu_lock spinlock. Also guard fetch() by mmap_sem in read-mode to protect against alias and memslot changes. Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com> Signed-off-by: Avi Kivity <avi@qumranet.com>
2008-01-30KVM: Add kvm_read_guest_atomic()Marcelo Tosatti
In preparation for a mmu spinlock, add kvm_read_guest_atomic() and use it in fetch() and prefetch_page(). Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com> Signed-off-by: Avi Kivity <avi@qumranet.com>
2008-01-30KVM: Accelerated apic supportAvi Kivity
This adds a mechanism for exposing the virtual apic tpr to the guest, and a protocol for letting the guest update the tpr without causing a vmexit if conditions allow (e.g. there is no interrupt pending with a higher priority than the new tpr). Signed-off-by: Avi Kivity <avi@qumranet.com>
2008-01-30KVM: local APIC TPR access reporting facilityAvi Kivity
Add a facility to report on accesses to the local apic tpr even if the local apic is emulated in the kernel. This is basically a hack that allows userspace to patch Windows which tends to bang on the tpr a lot. Signed-off-by: Avi Kivity <avi@qumranet.com>
2008-01-30KVM: Expose ioapic to ia64 save/restore APIsZhang Xiantao
IA64 also needs to see ioapic structure in irqchip. Signed-off-by: xiantao.zhang@intel.com <xiantao.zhang@intel.com> Signed-off-by: Avi Kivity <avi@qumranet.com>
2008-01-30KVM: Move kvm_vcpu_kick() to x86.cZhang Xiantao
Moving kvm_vcpu_kick() to x86.c. Since it should be common for all archs, put its declarations in <linux/kvm_host.h> Signed-off-by: Zhang Xiantao <xiantao.zhang@intel.com> Signed-off-by: Avi Kivity <avi@qumranet.com>
2008-01-30KVM: Move arch dependent files to new directory arch/x86/kvm/Avi Kivity
This paves the way for multiple architecture support. Note that while ioapic.c could potentially be shared with ia64, it is also moved. Signed-off-by: Avi Kivity <avi@qumranet.com>
2008-01-30KVM: Export include/linux/kvm.h only if $ARCH actually supports KVMAvi Kivity
Currently, make headers_check barfs due to <asm/kvm.h>, which <linux/kvm.h> includes, not existing. Rather than add a zillion <asm/kvm.h>s, export kvm.h only if the arch actually supports it. Signed-off-by: Avi Kivity <avi@qumranet.com>
2008-01-30KVM: Add ifdef in irqchip struct for x86 only structuresJerone Young
This patch fixes a small issue where sturctures: kvm_pic_state kvm_ioapic_state are defined inside x86 specific code and may or may not be defined in anyway for other architectures. The problem caused is one cannot compile userspace apps (ex. libkvm) for other archs since a size cannot be determined for these structures. Signed-off-by: Jerone Young <jyoung5@us.ibm.com> Signed-off-by: Avi Kivity <avi@qumranet.com>
2008-01-30KVM: Enhance guest cpuid managementDan Kenigsberg
The current cpuid management suffers from several problems, which inhibit passing through the host feature set to the guest: - No way to tell which features the host supports While some features can be supported with no changes to kvm, others need explicit support. That means kvm needs to vet the feature set before it is passed to the guest. - No support for indexed or stateful cpuid entries Some cpuid entries depend on ecx as well as on eax, or on internal state in the processor (running cpuid multiple times with the same input returns different output). The current cpuid machinery only supports keying on eax. - No support for save/restore/migrate The internal state above needs to be exposed to userspace so it can be saved or migrated. This patch adds extended cpuid support by means of three new ioctls: - KVM_GET_SUPPORTED_CPUID: get all cpuid entries the host (and kvm) supports - KVM_SET_CPUID2: sets the vcpu's cpuid table - KVM_GET_CPUID2: gets the vcpu's cpuid table, including hidden state [avi: fix original KVM_SET_CPUID not removing nx on non-nx hosts as it did before] Signed-off-by: Dan Kenigsberg <danken@qumranet.com> Signed-off-by: Avi Kivity <avi@qumranet.com>
2008-01-30KVM: Portability: Move cpuid structures to <asm/kvm.h>Jerone Young
This patch moves structures: kvm_cpuid_entry kvm_cpuid from include/linux/kvm.h to include/asm-x86/kvm.h Signed-off-by: Jerone Young <jyoung5@us.ibm.com> Signed-off-by: Avi Kivity <avi@qumranet.com>
2008-01-30KVM: Portability: Move kvm_sregs and msr structures to <asm/kvm.h>Jerone Young
Move structures: kvm_sregs kvm_msr_entry kvm_msrs kvm_msr_list from include/linux/kvm.h to include/asm-x86/kvm.h Signed-off-by: Avi Kivity <avi@qumranet.com>
2008-01-30KVM: Portability: Move kvm_segment & kvm_dtable structure to <asm/kvm.h>Jerone Young
This patch moves structures: kvm_segment kvm_dtable from include/linux/kvm.h to include/asm-x86/kvm.h Signed-off-by: Jerone Young <jyoung5@us.ibm.com> Signed-off-by: Avi Kivity <avi@qumranet.com>
2008-01-30KVM: Portability: Move structure lapic_state to <asm/kvm.h>Jerone Young
This patch moves structure lapic_state from include/linux/kvm.h to include/asm-x86/kvm.h Signed-off-by: Jerone Young <jyoung5@us.ibm.com> Signed-off-by: Avi Kivity <avi@qumranet.com>
2008-01-30KVM: Portability: Move kvm_regs to <asm/kvm.h>Jerone Young
This patch moves structure kvm_regs to include/asm-x86/kvm.h. Each architecture will need to create there own version of this structure. Signed-off-by: Jerone Young <jyoung5@us.ibm.com> Signed-off-by: Avi Kivity <avi@qumranet.com>
2008-01-30KVM: Portability: Move x86 pic strutcturesJerone Young
This patch moves structures: kvm_pic_state kvm_ioapic_state to inclue/asm-x86/kvm.h. Signed-off-by: Jerone Young <jyoung5@us.ibm.com> Signed-off-by: Avi Kivity <avi@qumranet.com>
2008-01-30KVM: Portability: Move kvm_memory_alias to asm/kvm.hJerone Young
This patch moves sturct kvm_memory_alias from include/linux/kvm.h to include/asm-x86/kvm.h. Also have include/linux/kvm.h include include/asm/kvm.h. Signed-off-by: Jerone Young <jyoung5@us.ibm.com> Signed-off-by: Avi Kivity <avi@qumranet.com>
2008-01-30KVM: Add ioctl to tss address from userspace,Izik Eidus
Currently kvm has a wart in that it requires three extra pages for use as a tss when emulating real mode on Intel. This patch moves the allocation internally, only requiring userspace to tell us where in the physical address space we can place the tss. Signed-off-by: Izik Eidus <izike@qumranet.com> Signed-off-by: Avi Kivity <avi@qumranet.com>
2008-01-30KVM: Per-architecture hypercall definitionsChristian Borntraeger
Currently kvm provides hypercalls only for x86* architectures. To provide hypercall infrastructure for other kvm architectures I split kvm_para.h into a generic header file and architecture specific definitions. Signed-off-by: Christian Borntraeger <borntraeger@de.ibm.com> Signed-off-by: Avi Kivity <avi@qumranet.com>
2008-01-30KVM: Support assigning userspace memory to the guestIzik Eidus
Instead of having the kernel allocate memory to the guest, let userspace allocate it and pass the address to the kernel. This is required for s390 support, but also enables features like memory sharing and using hugetlbfs backed memory. Signed-off-by: Izik Eidus <izike@qumranet.com> Signed-off-by: Avi Kivity <avi@qumranet.com>
2008-01-30KVM: Allow dynamic allocation of the mmu shadow cache sizeIzik Eidus
The user is now able to set how many mmu pages will be allocated to the guest. Signed-off-by: Izik Eidus <izike@qumranet.com> Signed-off-by: Avi Kivity <avi@qumranet.com>
2008-01-30KVM: Refactor hypercall infrastructure (v3)Anthony Liguori
This patch refactors the current hypercall infrastructure to better support live migration and SMP. It eliminates the hypercall page by trapping the UD exception that would occur if you used the wrong hypercall instruction for the underlying architecture and replacing it with the right one lazily. A fall-out of this patch is that the unhandled hypercalls no longer trap to userspace. There is very little reason though to use a hypercall to communicate with userspace as PIO or MMIO can be used. There is no code in tree that uses userspace hypercalls. [avi: fix #ud injection on vmx] Signed-off-by: Anthony Liguori <aliguori@us.ibm.com> Signed-off-by: Avi Kivity <avi@qumranet.com>
2008-01-30x86: early boot debugging via FireWire (ohci1394_dma=early)Bernhard Kaindl
This patch adds a new configuration option, which adds support for a new early_param which gets checked in arch/x86/kernel/setup_{32,64}.c:setup_arch() to decide wether OHCI-1394 FireWire controllers should be initialized and enabled for physical DMA access to allow remote debugging of early problems like issues ACPI or other subsystems which are executed very early. If the config option is not enabled, no code is changed, and if the boot paramenter is not given, no new code is executed, and independent of that, all new code is freed after boot, so the config option can be even enabled in standard, non-debug kernels. With specialized tools, it is then possible to get debugging information from machines which have no serial ports (notebooks) such as the printk buffer contents, or any data which can be referenced from global pointers, if it is stored below the 4GB limit and even memory dumps of of the physical RAM region below the 4GB limit can be taken without any cooperation from the CPU of the host, so the machine can be crashed early, it does not matter. In the extreme, even kernel debuggers can be accessed in this way. I wrote a small kgdb module and an accompanying gdb stub for FireWire which allows to gdb to talk to kgdb using remote remory reads and writes over FireWire. An version of the gdb stub fore FireWire is able to read all global data from a system which is running a a normal kernel without any kernel debugger, without any interruption or support of the system's CPU. That way, e.g. the task struct and so on can be read and even manipulated when the physical DMA access is granted. A HOWTO is included in this patch, in Documentation/debugging-via-ohci1394.txt and I've put a copy online at ftp://ftp.suse.de/private/bk/firewire/docs/debugging-via-ohci1394.txt It also has links to all the tools which are available to make use of it another copy of it is online at: ftp://ftp.suse.de/private/bk/firewire/kernel/ohci1394_dma_early-v2.diff Signed-Off-By: Bernhard Kaindl <bk@suse.de> Tested-By: Thomas Renninger <trenn@suse.de> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2008-01-30x86: do not PSE on CONFIG_DEBUG_PAGEALLOC=yIngo Molnar
get more testing of the c_p_a() code done by not turning off PSE on DEBUG_PAGEALLOC. this simplifies the early pagetable setup code, and tests the largepage-splitup code quite heavily. In the end, all the largepages will be split up pretty quickly, so there's no difference to how DEBUG_PAGEALLOC worked before. Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2008-01-30x86: demacro asm-x86/pgalloc_32.hJeremy Fitzhardinge
Convert macros into inline functions, for better type-checking. This patch required a little bit of fiddling with headers in order to make __(pte|pmd)_free_tlb inline rather than macros. asm-generic/tlb.h includes asm/pgalloc.h, though it doesn't directly use any pgalloc definitions. I removed this include to avoid an include cycle, but it may cause secondary compile failures by things depending on the indirect inclusion; arch/x86/mm/hugetlbpage.c was one such place; there may be others. Signed-off-by: Jeremy Fitzhardinge <jeremy@xensource.com> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2008-01-30pci: add PCI identifiers for the RDC devicesFlorian Fainelli
This patch defines the PCI identifiers found in the RDC R-321x System-on-Chip. Signed-off-by: Florian Fainelli <florian.fainelli@telecomint.eu> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2008-01-30x86: print which shared library/executable faulted in segfault etc. messages v3Andi Kleen
They now look like: hal-resmgr[13791]: segfault at 3c rip 2b9c8caec182 rsp 7fff1e825d30 error 4 in libacl.so.1.1.0[2b9c8caea000+6000] This makes it easier to pinpoint bugs to specific libraries. And printing the offset into a mapping also always allows to find the correct fault point in a library even with randomized mappings. Previously there was no way to actually find the correct code address inside the randomized mapping. Relies on earlier patch to shorten the printk formats. They are often now longer than 80 characters, but I think that's worth it. [includes fix from Eric Dumazet to check d_path error value] Signed-off-by: Andi Kleen <ak@suse.de> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2008-01-30x86: optimize lock prefix switching to run less frequentlyAndi Kleen
On VMs implemented using JITs that cache translated code changing the lock prefixes is a quite costly operation that forces the JIT to throw away and retranslate a lot of code. Previously a SMP kernel would rewrite the locks once for each CPU which is quite unnecessary. This patch changes the code to never switch at boot in the normal case (SMP kernel booting with >1 CPU) or only once for SMP kernel on UP. This makes a significant difference in boot up performance on AMD SimNow! Also I expect it to be a little faster on native systems too because a smp switch does a lot of text_poke()s which each synchronize the pipeline. v1->v2: Rename max_cpus v1->v2: Fix off by one in UP check (Thomas Gleixner) Signed-off-by: Andi Kleen <ak@suse.de> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2008-01-30x86: add ENDPROC() markersJohn Reiser
The ENDPROCs() were not used everywhere. Some code used just END() instead, while other code used nothing. um/sys-i386/checksum.S didn't #include <linux/linkage.h> . I also got confused because gcc puts the .type near the ENTRY, while ENDPROC puts it on the opposite end. Signed off by: John Reiser <jreiser@BitWagon.com> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2008-01-30x86: make early printk selectable on 64-bit as wellIngo Molnar
Enable CONFIG_EMBEDDED to select CONFIG_EARLY_PRINTK on 64-bit as well. saves ~2K: text data bss dec hex filename 7290283 3672091 1907848 12870222 c4624e vmlinux.before 7288373 3671795 1907848 12868016 c459b0 vmlinux.after Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2008-01-30x86: fix UML and -regparm=3Ingo Molnar
introduce the "asmregparm" calling convention: for functions implemented in assembly with a fixed regparm input parameters calling convention. mark the semaphore and rwsem slowpath functions with that. Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Miklos Szeredi <mszeredi@suse.cz> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2008-01-30x86: kprobes: add kprobes smoke tests that run on bootAnanth N Mavinakayanahalli
Here is a quick and naive smoke test for kprobes. This is intended to just verify if some unrelated change broke the *probes subsystem. It is self contained, architecture agnostic and isn't of any great use by itself. This needs to be built in the kernel and runs a basic set of tests to verify if kprobes, jprobes and kretprobes run fine on the kernel. In case of an error, it'll print out a message with a "BUG" prefix. This is a start; we intend to add more tests to this bucket over time. Thanks to Jim Keniston and Masami Hiramatsu for comments and suggestions. Tested on x86 (32/64) and powerpc. Signed-off-by: Ananth N Mavinakayanahalli <ananth@in.ibm.com> Acked-by: Masami Hiramatsu <mhiramat@redhat.com> Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-01-30percpu: move arch XX_PER_CPU_XX definitions into linux/percpu.htravis@sgi.com
- Special consideration for IA64: Add the ability to specify arch specific per cpu flags - remove .data.percpu attribute from DEFINE_PER_CPU for non-smp case. The arch definitions are all the same. So move them into linux/percpu.h. We cannot move DECLARE_PER_CPU since some include files just include asm/percpu.h to avoid include recursion problems. Cc: Rusty Russell <rusty@rustcorp.com.au> Cc: Andi Kleen <ak@suse.de> Signed-off-by: Christoph Lameter <clameter@sgi.com> Signed-off-by: Mike Travis <travis@sgi.com> Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-01-30x86: add _AT() macro to conditionally castJeremy Fitzhardinge
# HG changeset patch # User Jeremy Fitzhardinge <jeremy@xensource.com> # Date 1199317452 28800 # Node ID f7e7db3facd9406545103164f9be8f9ba1a2b549 # Parent 4d9a413a0f4c1d98dbea704f0366457b5117045d x86: add _AT() macro to conditionally cast Define _AT(type, value) to conditionally cast a value when compiling C code, but not when used in assembler. Signed-off-by: Jeremy Fitzhardinge <jeremy.fitzhardinge@citrix.com> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2008-01-30x86: x86 core dump TLSRoland McGrath
This makes ELF core dumps of 32-bit processes include a new note type NT_386_TLS (0x200) giving the contents of the TLS slots in struct user_desc format. This lets post mortem examination figure out what the segment registers mean like the debugger does with get_thread_area on a live process. Signed-off-by: Roland McGrath <roland@redhat.com> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2008-01-30x86: compat_sys_ptraceRoland McGrath
This adds a generic definition of compat_sys_ptrace that calls compat_arch_ptrace, parallel to sys_ptrace/arch_ptrace. Some machines needing this already define a function by that name. The new generic function is defined only on machines that put #define __ARCH_WANT_COMPAT_SYS_PTRACE into asm/ptrace.h. Signed-off-by: Roland McGrath <roland@redhat.com> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2008-01-30x86: compat_ptrace_requestRoland McGrath
This adds a compat_ptrace_request that is the analogue of ptrace_request for the things that 32-on-64 ptrace implementations can share in common. So far there are just a couple of requests handled generically. Signed-off-by: Roland McGrath <roland@redhat.com> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
