Pull irq cleanups from Ingo Molnar:
"This is a multi-arch cleanup series from Thomas Gleixner, which we
kept to near the end of the merge window, to not interfere with
architecture updates.
This series (motivated by the -rt kernel) unifies more aspects of IRQ
handling and generalizes PREEMPT_ACTIVE"
* 'irq-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip:
preempt: Make PREEMPT_ACTIVE generic
sparc: Use preempt_schedule_irq
ia64: Use preempt_schedule_irq
m32r: Use preempt_schedule_irq
hardirq: Make hardirq bits generic
m68k: Simplify low level interrupt handling code
genirq: Prevent spurious detection for unconditionally polled interrupts
git://git.kernel.org/pub/scm/linux/kernel/git/wsa/linux
Pull i2c changes from Wolfram Sang:
- new drivers for exynos5, bcm kona, and st micro
- bigger overhauls for drivers mxs and rcar
- typical driver bugfixes, cleanups, improvements
- got rid of the superfluous 'driver' member in i2c_client struct This
touches a few drivers in other subsystems. All acked.
* 'i2c/for-next' of git://git.kernel.org/pub/scm/linux/kernel/git/wsa/linux: (38 commits)
i2c: bcm-kona: fix error return code in bcm_kona_i2c_probe()
i2c: i2c-eg20t: do not print error message in syslog if no ACK received
i2c: bcm-kona: Introduce Broadcom I2C Driver
i2c: cbus-gpio: Fix device tree binding
i2c: wmt: add missing clk_disable_unprepare() on error
i2c: designware: add new ACPI IDs
i2c: i801: Add Device IDs for Intel Wildcat Point-LP PCH
i2c: exynos5: Remove incorrect clk_disable_unprepare
i2c: i2c-st: Add ST I2C controller
i2c: exynos5: add High Speed I2C controller driver
i2c: rcar: fixup rcar type naming
i2c: scmi: remove some bogus NULL checks
i2c: sh_mobile & rcar: Enable the driver on all ARM platforms
i2c: sh_mobile: Convert to clk_prepare/unprepare
i2c: mux: gpio: use reg value for i2c_add_mux_adapter
i2c: mux: gpio: use gpio_set_value_cansleep()
i2c: Include linux/of.h header
i2c: mxs: Fix PIO mode on i.MX23
i2c: mxs: Rework the PIO mode operation
i2c: mxs: distinguish i.MX23 and i.MX28 based I2C controller
git://git.kernel.org/pub/scm/linux/kernel/git/roland/infiniband
Pull infiniband/rdma updates from Roland Dreier:
- Re-enable flow steering verbs with new improved userspace ABI
- Fixes for slow connection due to GID lookup scalability
- IPoIB fixes
- Many fixes to HW drivers including mlx4, mlx5, ocrdma and qib
- Further improvements to SRP error handling
- Add new transport type for Cisco usNIC
* tag 'rdma-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/roland/infiniband: (66 commits)
IB/core: Re-enable create_flow/destroy_flow uverbs
IB/core: extended command: an improved infrastructure for uverbs commands
IB/core: Remove ib_uverbs_flow_spec structure from userspace
IB/core: Use a common header for uverbs flow_specs
IB/core: Make uverbs flow structure use names like verbs ones
IB/core: Rename 'flow' structs to match other uverbs structs
IB/core: clarify overflow/underflow checks on ib_create/destroy_flow
IB/ucma: Convert use of typedef ctl_table to struct ctl_table
IB/cm: Convert to using idr_alloc_cyclic()
IB/mlx5: Fix page shift in create CQ for userspace
IB/mlx4: Fix device max capabilities check
IB/mlx5: Fix list_del of empty list
IB/mlx5: Remove dead code
IB/core: Encorce MR access rights rules on kernel consumers
IB/mlx4: Fix endless loop in resize CQ
RDMA/cma: Remove unused argument and minor dead code
RDMA/ucma: Discard events for IDs not yet claimed by user space
IB/core: Add Cisco usNIC rdma node and transport types
RDMA/nes: Remove self-assignment from nes_query_qp()
IB/srp: Report receive errors correctly
Pull battery updates from Anton Vorontsov:
"Highlights:
- A new driver for TI BQ24735 Battery Chargers, courtesy of NVidia.
- Device tree bindings for TWL4030 chips.
- Random fixes and cleanups"
* tag 'for-v3.13' of git://git.infradead.org/battery-2.6:
pm2301-charger: Remove unneeded NULL checks
twl4030_charger: Add devicetree support
power_supply: Fix documentation for TEMP_*ALERT* properties
max17042_battery: Support regmap to access device's registers
max17042_battery: Use SIMPLE_DEV_PM_OPS
charger-manager : Replace kzalloc to devm_kzalloc and remove uneccessary code
bq2415x_charger: Fix max battery regulation voltage
tps65090-charger: Use "IS_ENABLED(CONFIG_OF)" for DT code
tps65090-charger: Drop devm_free_irq of devm_ allocated irq
power_supply: Add support for bq24735 charger
pm2301-charger: Staticize pm2xxx_charger_die_therm_mngt
pm2301-charger: Check return value of regulator_enable
ab8500-charger: Remove redundant break
ab8500-charger: Check return value of regulator_enable
isp1704_charger: Fix driver to work with changes introduced in v3.5
git://git.kernel.org/pub/scm/linux/kernel/git/cjb/mmc
Pull MMC updates from Chris Ball:
"MMC highlights for 3.13:
Core:
- Improve runtime PM support, remove mmc_{suspend,resume}_host().
- Add MMC_CAP_RUNTIME_RESUME, for delaying MMC resume until we're
outside of the resume sequence (in runtime_resume) to decrease
system resume time.
Drivers:
- dw_mmc: Support HS200 mode.
- sdhci-eshdc-imx: Support SD3.0 SDR clock tuning, DDR on IMX6.
- sdhci-pci: Add support for Intel Clovertrail and Merrifield"
* tag 'mmc-updates-for-3.13-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/cjb/mmc: (108 commits)
mmc: wbsd: Silence compiler warning
mmc: core: Silence compiler warning in __mmc_switch
mmc: sh_mmcif: Convert to clk_prepare|unprepare
mmc: sh_mmcif: Convert to PM macros when defining dev_pm_ops
mmc: dw_mmc: exynos: Revert the sdr_timing assignment
mmc: sdhci: Avoid needless loop while handling SDIO interrupts in sdhci_irq
mmc: core: Add MMC_CAP_RUNTIME_RESUME to resume at runtime_resume
mmc: core: Improve runtime PM support during suspend/resume for sd/mmc
mmc: core: Remove redundant mmc_power_up|off at runtime callbacks
mmc: Don't force card to active state when entering suspend/shutdown
MIPS: db1235: Don't use MMC_CLKGATE
mmc: core: Remove deprecated mmc_suspend|resume_host APIs
mmc: mmci: Move away from using deprecated APIs
mmc: via-sdmmc: Move away from using deprecated APIs
mmc: tmio: Move away from using deprecated APIs
mmc: sh_mmcif: Move away from using deprecated APIs
mmc: sdricoh_cs: Move away from using deprecated APIs
mmc: rtsx: Remove redundant suspend and resume callbacks
mmc: wbsd: Move away from using deprecated APIs
mmc: pxamci: Remove redundant suspend and resume callbacks
git://git.kernel.org/pub/scm/linux/kernel/git/rostedt/linux-trace
Pull tracing update from Steven Rostedt:
"This batch of changes is mostly clean ups and small bug fixes. The
only real feature that was added this release is from Namhyung Kim,
who introduced "set_graph_notrace" filter that lets you run the
function graph tracer and not trace particular functions and their
call chain.
Tom Zanussi added some updates to the ftrace multibuffer tracing that
made it more consistent with the top level tracing.
One of the fixes for perf function tracing required an API change in
RCU; the addition of "rcu_is_watching()". As Paul McKenney is pushing
that change in this release too, he gave me a branch that included all
the changes to get that working, and I pulled that into my tree in
order to complete the perf function tracing fix"
* tag 'trace-3.13' of git://git.kernel.org/pub/scm/linux/kernel/git/rostedt/linux-trace:
tracing: Add rcu annotation for syscall trace descriptors
tracing: Do not use signed enums with unsigned long long in fgragh output
tracing: Remove unused function ftrace_off_permanent()
tracing: Do not assign filp->private_data to freed memory
tracing: Add helper function tracing_is_disabled()
tracing: Open tracer when ftrace_dump_on_oops is used
tracing: Add support for SOFT_DISABLE to syscall events
tracing: Make register/unregister_ftrace_command __init
tracing: Update event filters for multibuffer
recordmcount.pl: Add support for __fentry__
ftrace: Have control op function callback only trace when RCU is watching
rcu: Do not trace rcu_is_watching() functions
ftrace/x86: skip over the breakpoint for ftrace caller
trace/trace_stat: use rbtree postorder iteration helper instead of opencoding
ftrace: Add set_graph_notrace filter
ftrace: Narrow down the protected area of graph_lock
ftrace: Introduce struct ftrace_graph_data
ftrace: Get rid of ftrace_graph_filter_enabled
tracing: Fix potential out-of-bounds in trace_get_user()
tracing: Show more exact help information about snapshot
git://git.kernel.org/pub/scm/linux/kernel/git/thierry.reding/linux-pwm
Pull pwm changes from Thierry Reding:
"Mostly bug fixes and clean up. There is a new driver, which is
actually moving a custom PWM driver from drivers/misc.
The majority of the patches are enhancements to the device tree
support in the pwm-backlight driver. Backlights can now additionally
be powered using a regulator and enabled using a GPIO in addition to
just the PWM input"
* tag 'pwm/for-3.13-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/thierry.reding/linux-pwm: (30 commits)
Documentation/pwm: Update supported SoC name for pwm-samsung
pwm: samsung: Fix kernel warning while unexporting a channel
MAINTAINERS: Move PWM subsystem tree to kernel.org
Documentation/pwm: Fix trivial typos
pwm-backlight: Remove unused variable
pwm_backlight: avoid short blank screen while doing hibernation
pwm-backlight: Fix brightness adjustment
pwm: add ep93xx PWM support
pwm-backlight: Allow for non-increasing brightness levels
pwm-backlight: Add power supply support
pwm-backlight: Use new enable_gpio field
unicore32: Initialize PWM backlight enable_gpio field
ARM: shmobile: Initialize PWM backlight enable_gpio field
ARM: SAMSUNG: Initialize PWM backlight enable_gpio field
ARM: pxa: Initialize PWM backlight enable_gpio field
ARM: OMAP: Initialize PWM backlight enable_gpio field
pwm-backlight: Add optional enable GPIO
pwm-backlight: Track enable state
pwm-backlight: Refactor backlight power on/off
pwm-backlight: Improve readability
Pull nfsd changes from Bruce Fields:
"This includes miscellaneous bugfixes and cleanup and a performance fix
for write-heavy NFSv4 workloads.
(The most significant nfsd-relevant change this time is actually in
the delegation patches that went through Viro, fixing a long-standing
bug that can cause NFSv4 clients to miss updates made by non-nfs users
of the filesystem. Those enable some followup nfsd patches which I
have queued locally, but those can wait till 3.14)"
* 'nfsd-next' of git://linux-nfs.org/~bfields/linux: (24 commits)
nfsd: export proper maximum file size to the client
nfsd4: improve write performance with better sendspace reservations
svcrpc: remove an unnecessary assignment
sunrpc: comment typo fix
Revert "nfsd: remove_stid can be incorporated into nfs4_put_delegation"
nfsd4: fix discarded security labels on setattr
NFSD: Add support for NFS v4.2 operation checking
nfsd4: nfsd_shutdown_net needs state lock
NFSD: Combine decode operations for v4 and v4.1
nfsd: -EINVAL on invalid anonuid/gid instead of silent failure
nfsd: return better errors to exportfs
nfsd: fh_update should error out in unexpected cases
nfsd4: need to destroy revoked delegations in destroy_client
nfsd: no need to unhash_stid before free
nfsd: nfs4_open_delegation needs to remove_stid rather than unhash_stid
nfsd: nfs4_free_stid
nfsd: fix Kconfig syntax
sunrpc: trim off EC bytes in GSSAPI v2 unwrap
gss_krb5: document that we ignore sequence number
Pull trivial tree updates from Jiri Kosina:
"Usual earth-shaking, news-breaking, rocket science pile from
trivial.git"
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (23 commits)
doc: usb: Fix typo in Documentation/usb/gadget_configs.txt
doc: add missing files to timers/00-INDEX
timekeeping: Fix some trivial typos in comments
mm: Fix some trivial typos in comments
irq: Fix some trivial typos in comments
NUMA: fix typos in Kconfig help text
mm: update 00-INDEX
doc: Documentation/DMA-attributes.txt fix typo
DRM: comment: `halve' -> `half'
Docs: Kconfig: `devlopers' -> `developers'
doc: typo on word accounting in kprobes.c in mutliple architectures
treewide: fix "usefull" typo
treewide: fix "distingush" typo
mm/Kconfig: Grammar s/an/a/
kexec: Typo s/the/then/
Documentation/kvm: Update cpuid documentation for steal time and pv eoi
treewide: Fix common typo in "identify"
__page_to_pfn: Fix typo in comment
Correct some typos for word frequency
clk: fixed-factor: Fix a trivial typo
git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input
Pull input updates from Dmitry Torokhov:
"Updates for the input subsystem. You will get an new drivers for
Hyper-V synthetic keyboard and for Neonode zForce touchscreens, plus a
bunch of driver fixes and cleanups"
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input: (49 commits)
Revert "Input: ALPS - add support for model found on Dell XT2"
arm: dts: am335x sk: add touchscreen support
Input: ti_am335x_tsc - fix spelling mistake in TSC/ADC DT binding
Input: cyttsp4 - replace IS_ERR and PTR_ERR with PTR_ERR_OR_ZERO
Input: mma8450 - add missing i2c_set_clientdata() in mma8450_probe()
Input: mpu3050 - add missing i2c_set_clientdata() in mpu3050_probe()
Input: tnetv107x-keypad - make irqs signed for error handling
Input: add driver for Neonode zForce based touchscreens
Input: sh_keysc - enable the driver on all ARM platforms
Input: remove a redundant max() call
Input: mousedev - allow disabling even without CONFIG_EXPERT
Input: allow deselecting serio drivers even without CONFIG_EXPERT
Input: i8042 - add PNP modaliases
Input: evdev - fall back to vmalloc for client event buffer
Input: cypress_ps2 - do not consider data bad if palm is detected
Input: cypress_ps2 - remove useless cast
Input: fix PWM-related undefined reference errors
Input: ALPS - change secondary device's name
Input: wacom - not all multi-interface devices support touch
Input: nspire-keypad - add missing clk_disable_unprepare() on error path
git://git.kernel.org/pub/scm/linux/kernel/git/sameo/mfd-next
Pull MFD updates from Samuel Ortiz:
"For the 3.13 merge window we have a couple of new drivers for the AMS
AS3722 PMIC and for STMicroelectronics STw481x PMIC.
Although this is a smaller update than usual, we also have:
- Device tree support for the max77693 driver
- linux/of.h inclusion for all DT compatible MFD drivers, to avoid
build breakage in the future
- Support for Intel Wildcat Point-LP PCH through the lpc_ich driver
- A small arizona update for new wm5110 DSP registers and a few fixes
- A small palmas update as well, including an of_device table
addition and a few minor fixes
- Two small mfd-core changes, one including a memory leak fix for
when mfd_add_device() fails
- Our usual round of minor cleanups and janitorial fixes"
* tag 'mfd-3.13-1' of git://git.kernel.org/pub/scm/linux/kernel/git/sameo/mfd-next: (63 commits)
Documentation: mfd: Update s2mps11.txt
mfd: pm8921: Potential NULL dereference in pm8921_remove()
mfd: Fix memory leak in mfd_add_devices()
mfd: Stop setting refcounting pointers in original mfd_cell arrays
mfd: wm5110: Enable micd clamp functionality
mfd: lpc_ich: Add Device IDs for Intel Wildcat Point-LP PCH
mfd: max77693: Fix up bug of wrong interrupt number
mfd: as3722: Don't export the regmap config
mfd: twl6040: Remove obsolete cleanup for i2c clientdata
mfd: tps65910: Remove warning during dt node parsing
mfd: lpc_sch: Ignore resource conflicts when adding mfd cells
mfd: ti_am335x_tscadc: Avoid possible deadlock of reg_lock
mfd: syscon: Return -ENOSYS if CONFIG_MFD_SYSCON is not enabled
mfd: Add support for ams AS3722 PMIC
mfd: max77693: Include linux/of.h header
mfd: tc3589x: Detect the precise version
mfd: omap-usb: prepare/unprepare clock while enable/disable
mfd: max77686: Include linux/of.h header
mfd: max8907: Include linux/of.h header
mfd: max8997: Include linux/of.h header
Pull drm updates from Dave Airlie:
"This is a combo of -next and some -fixes that came in in the
intervening time.
Highlights:
New drivers:
ARM Armada driver for Marvell Armada 510 SOCs
Intel:
Broadwell initial support under a default off switch,
Stereo/3D HDMI mode support
Valleyview improvements
Displayport improvements
Haswell fixes
initial mipi dsi panel support
CRC support for debugging
build with CONFIG_FB=n
Radeon:
enable DPM on a number of GPUs by default
secondary GPU powerdown support
enable HDMI audio by default
Hawaii support
Nouveau:
dynamic pm code infrastructure reworked, does nothing major yet
GK208 modesetting support
MSI fixes, on by default again
PMPEG improvements
pageflipping fixes
GMA500:
minnowboard SDVO support
VMware:
misc fixes
MSM:
prime, plane and rendernodes support
Tegra:
rearchitected to put the drm driver into the drm subsystem.
HDMI and gr2d support for tegra 114 SoC
QXL:
oops fix, and multi-head fixes
DRM core:
sysfs lifetime fixes
client capability ioctl
further cleanups to device midlayer
more vblank timestamp fixes"
* 'drm-next' of git://people.freedesktop.org/~airlied/linux: (789 commits)
drm/nouveau: do not map evicted vram buffers in nouveau_bo_vma_add
drm/nvc0-/gr: shift wrapping bug in nvc0_grctx_generate_r406800
drm/nouveau/pwr: fix missing mutex unlock in a failure path
drm/nv40/therm: fix slowing down fan when pstate undefined
drm/nv11-: synchronise flips to vblank, unless async flip requested
drm/nvc0-: remove nasty fifo swmthd hack for flip completion method
drm/nv10-: we no longer need to create nvsw object on user channels
drm/nouveau: always queue flips relative to kernel channel activity
drm/nouveau: there is no need to reserve/fence the new fb when flipping
drm/nouveau: when bailing out of a pushbuf ioctl, do not remove previous fence
drm/nouveau: allow nouveau_fence_ref() to be a noop
drm/nvc8/mc: msi rearm is via the nvc0 method
drm/ttm: Fix vma page_prot bit manipulation
drm/vmwgfx: Fix a couple of compile / sparse warnings and errors
drm/vmwgfx: Resource evict fixes
drm/edid: compare actual vrefresh for all modes for quirks
drm: shmob_drm: Convert to clk_prepare/unprepare
drm/nouveau: fix 32-bit build
drm/i915/opregion: fix build error on CONFIG_ACPI=n
Revert "drm/radeon/audio: don't set speaker allocation on DCE4+"
git://git.kernel.org/pub/scm/linux/kernel/git/joro/iommu
Pull IOMMU updates from Joerg Roedel:
"This time the updates contain:
- Tracepoints for certain IOMMU-API functions to make their use
easier to debug
- A tracepoint for IOMMU page faults to make it easier to get them in
user space
- Updates and fixes for the new ARM SMMU driver after the first
hardware showed up
- Various other fixes and cleanups in other IOMMU drivers"
* tag 'iommu-updates-v3.13' of git://git.kernel.org/pub/scm/linux/kernel/git/joro/iommu: (26 commits)
iommu/shmobile: Enable the driver on all ARM platforms
iommu/tegra-smmu: Staticize tegra_smmu_pm_ops
iommu/tegra-gart: Staticize tegra_gart_pm_ops
iommu/vt-d: Use list_for_each_entry_safe() for dmar_domain->devices traversal
iommu/vt-d: Use for_each_drhd_unit() instead of list_for_each_entry()
iommu/vt-d: Fixed interaction of VFIO_IOMMU_MAP_DMA with IOMMU address limits
iommu/arm-smmu: Clear global and context bank fault status registers
iommu/arm-smmu: Print context fault information
iommu/arm-smmu: Check for num_context_irqs > 0 to avoid divide by zero exception
iommu/arm-smmu: Refine check for proper size of mapped region
iommu/arm-smmu: Switch to subsys_initcall for driver registration
iommu/arm-smmu: use relaxed accessors where possible
iommu/arm-smmu: replace devm_request_and_ioremap by devm_ioremap_resource
iommu: Remove stack trace from broken irq remapping warning
iommu: Change iommu driver to call io_page_fault trace event
iommu: Add iommu_error class event to iommu trace
iommu/tegra: gart: cleanup devm_* functions usage
iommu/tegra: Print phys_addr_t using %pa
iommu: No need to pass '0x' when '%pa' is used
iommu: Change iommu driver to call unmap trace event
Pull KVM changes from Paolo Bonzini:
"Here are the 3.13 KVM changes. There was a lot of work on the PPC
side: the HV and emulation flavors can now coexist in a single kernel
is probably the most interesting change from a user point of view.
On the x86 side there are nested virtualization improvements and a few
bugfixes.
ARM got transparent huge page support, improved overcommit, and
support for big endian guests.
Finally, there is a new interface to connect KVM with VFIO. This
helps with devices that use NoSnoop PCI transactions, letting the
driver in the guest execute WBINVD instructions. This includes some
nVidia cards on Windows, that fail to start without these patches and
the corresponding userspace changes"
* tag 'for-linus' of git://git.kernel.org/pub/scm/virt/kvm/kvm: (146 commits)
kvm, vmx: Fix lazy FPU on nested guest
arm/arm64: KVM: PSCI: propagate caller endianness to the incoming vcpu
arm/arm64: KVM: MMIO support for BE guest
kvm, cpuid: Fix sparse warning
kvm: Delete prototype for non-existent function kvm_check_iopl
kvm: Delete prototype for non-existent function complete_pio
hung_task: add method to reset detector
pvclock: detect watchdog reset at pvclock read
kvm: optimize out smp_mb after srcu_read_unlock
srcu: API for barrier after srcu read unlock
KVM: remove vm mmap method
KVM: IOMMU: hva align mapping page size
KVM: x86: trace cpuid emulation when called from emulator
KVM: emulator: cleanup decode_register_operand() a bit
KVM: emulator: check rex prefix inside decode_register()
KVM: x86: fix emulation of "movzbl %bpl, %eax"
kvm_host: typo fix
KVM: x86: emulate SAHF instruction
MAINTAINERS: add tree for kvm.git
Documentation/kvm: add a 00-INDEX file
git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux
Pull virtio updates from Rusty Russell:
"Nothing really exciting: some groundwork for changing virtio endian,
and some robustness fixes for broken virtio devices, plus minor
tweaks"
* tag 'virtio-next-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux:
virtio_scsi: verify if queue is broken after virtqueue_get_buf()
x86, asmlinkage, lguest: Pass in globals into assembler statement
virtio: mmio: fix signature checking for BE guests
virtio_ring: adapt to notify() returning bool
virtio_net: verify if queue is broken after virtqueue_get_buf()
virtio_console: verify if queue is broken after virtqueue_get_buf()
virtio_blk: verify if queue is broken after virtqueue_get_buf()
virtio_ring: add new function virtqueue_is_broken()
virtio_test: verify if virtqueue_kick() succeeded
virtio_net: verify if virtqueue_kick() succeeded
virtio_ring: let virtqueue_{kick()/notify()} return a bool
virtio_ring: change host notification API
virtio_config: remove virtio_config_val
virtio: use size-based config accessors.
virtio_config: introduce size-based accessors.
virtio_ring: plug kmemleak false positive.
virtio: pm: use CONFIG_PM_SLEEP instead of CONFIG_PM
Pull module updates from Rusty Russell:
"Mainly boring here, too. rmmod --wait finally removed, though"
* tag 'modules-next-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux:
modpost: fix bogus 'exported twice' warnings.
init: fix in-place parameter modification regression
asmlinkage, module: Make ksymtab and kcrctab symbols and __this_module __visible
kernel: add support for init_array constructors
modpost: Optionally ignore secondary errors seen if a single module build fails
module: remove rmmod --wait option.
Fix following errors:
include/linux/cmdline-parser.h:17:12: error: 'BDEVNAME_SIZE' undeclared here
block/cmdline-parser.c:17:2: error: implicit declaration of function 'kzalloc'
Signed-off-by: Alexander Beregalov <alexander.beregalov@intel.com>
Cc: CaiZhiyong <caizhiyong@huawei.com>
This patch enhances the type safety for the kfifo API. It is now safe
to put const data into a non const FIFO and the API will now generate a
compiler warning when reading from the fifo where the destination
address is pointing to a const variable.
As a side effect the kfifo_put() does now expect the value of an element
instead a pointer to the element. This was suggested Russell King. It
make the handling of the kfifo_put easier since there is no need to
create a helper variable for getting the address of a pointer or to pass
integers of different sizes.
IMHO the API break is okay, since there are currently only six users of
kfifo_put().
The code is also cleaner by kicking out the "if (0)" expressions.
Signed-off-by: Stefani Seibold <stefani@seibold.net>
Cc: Hauke Mehrtens <hauke@hauke-m.de>
Make this useful helper available for other users.
Cc: Neil Brown <neilb@suse.de>
x86_64 allnoconfig:
kernel/up.c:25: error: redefinition of '__smp_call_function_single'
include/linux/smp.h:154: note: previous definition of '__smp_call_function_single' was here
Cc: Jan Kara <jack@suse.cz>
We've switched over every architecture that supports SMP to it, so
remove the new useless config variable.
This commit was incomplete in that code to remove items from the per-cpu
lists was missing and never acquired a user in the 5 years it has been in
the tree. We're going to implement what it seems to try to archive in a
simpler way, and this code is in the way of doing so.
All users are converted over to reinit_completion(). Remove the old
macro now.
Signed-off-by: Wolfram Sang <wsa@the-dreams.de>
Cc: Linus Walleij <linus.walleij@linaro.org>
For the casual device driver writer, it is hard to remember when to use
init_completion (to init a completion structure) or INIT_COMPLETION (to
*reinit* a completion structure). Furthermore, while all other
completion functions exepct a pointer as a parameter, INIT_COMPLETION
does not. To make it easier to remember which function to use and to
make code more readable, introduce a new inline function with the proper
name and consistent argument type. Update the kernel-doc for
init_completion while we are here.
Acked-by: Linus Walleij <linus.walleij@linaro.org> (personally at LCE13)
There are several users who want to know bytes written by seq_*() for
alignment purpose. Currently they are using %n format for knowing it
because seq_*() returns 0 on success.
This patch introduces seq_setwidth() and seq_pad() for allowing them to
align without using %n format.
Cc: Joe Perches <joe@perches.com>
Avoid the fragile Kconfig construct guestimating spinlock_t sizes; use a
friendly compile-time test to determine this.
[kirill.shutemov@linux.intel.com: drop CONFIG_CMPXCHG_LOCKREF]
Signed-off-by: Peter Zijlstra <peterz@infradead.org>
If DEBUG_SPINLOCK and DEBUG_LOCK_ALLOC are enabled spinlock_t on x86_64
is 72 bytes. For page->ptl they will be allocated from kmalloc-96 slab,
so we loose 24 on each. An average system can easily allocate few tens
thousands of page->ptl and overhead is significant.
Let's create a separate slab for page->ptl allocation to solve this.
Use kernel/bounds.c to convert build-time spinlock_t size check into a
preprocessor symbol and apply that to properly separate the page::ptl
situation.
If split page table lock is in use, we embed the lock into struct page
of table's page. We have to disable split lock, if spinlock_t is too
big be to be embedded, like when DEBUG_SPINLOCK or DEBUG_LOCK_ALLOC
enabled.
This patch add support for dynamic allocation of split page table lock
if we can't embed it to struct page.
page->ptl is unsigned long now and we use it as spinlock_t if
sizeof(spinlock_t) <= sizeof(long), otherwise it's pointer to spinlock_t.
The spinlock_t allocated in pgtable_page_ctor() for PTE table and in
pgtable_pmd_page_ctor() for PMD table. All other helpers converted to
support dynamically allocated page->ptl.
Reviewed-by: Peter Zijlstra <peterz@infradead.org>
Change pgtable_page_ctor() return type from void to bool. Returns true,
if initialization is successful and false otherwise.
Current implementation never fails, but it will change later.
The basic idea is the same as with PTE level: the lock is embedded into
struct page of table's page.
We can't use mm->pmd_huge_pte to store pgtables for THP, since we don't
take mm->page_table_lock anymore. Let's reuse page->lru of table's page
for that.
pgtable_pmd_page_ctor() returns true, if initialization is successful
and false otherwise. Current implementation never fails, but assumption
that constructor can fail will help to port it to -rt where spinlock_t
is rather huge and cannot be embedded into struct page -- dynamic
allocation is required.
Signed-off-by: Naoya Horiguchi <n-horiguchi@ah.jp.nec.com>
Tested-by: Alex Thorlton <athorlton@sgi.com>
Cc: "Eric W . Biederman" <ebiederm@xmission.com>
Cc: "Paul E . McKenney" <paulmck@linux.vnet.ibm.com>
Cc: Dave Jones <davej@redhat.com>
Cc: Michael Kerrisk <mtk.manpages@gmail.com>
Cc: Robin Holt <robinmholt@gmail.com>
Cc: Sedat Dilek <sedat.dilek@gmail.com>
Cc: Srikar Dronamraju <srikar@linux.vnet.ibm.com>
Reviewed-by: Steven Rostedt <rostedt@goodmis.org>
Hugetlb supports multiple page sizes. We use split lock only for PMD
level, but not for PUD.
Currently mm->pmd_huge_pte protected by page table lock. It will not
work with split lock. We have to have per-pmd pmd_huge_pte for proper
access serialization.
For now, let's just introduce wrapper to access mm->pmd_huge_pte.
Cc: Alex Thorlton <athorlton@sgi.com>
Cc: Naoya Horiguchi <n-horiguchi@ah.jp.nec.com>
With split page table lock we can't know which lock we need to take
before we find the relevant pmd.
Let's move lock taking inside the function.
With split ptlock it's important to know which lock
pmd_trans_huge_lock() took. This patch adds one more parameter to the
function to return the lock.
In most places migration to new api is trivial. Exception is
move_huge_pmd(): we need to take two locks if pmd tables are different.
Basic api, backed by mm->page_table_lock for now. Actual implementation
will be added later.
With split page table lock for PMD level we can't hold mm->page_table_lock
while updating nr_ptes.
Let's convert it to atomic_long_t to avoid races.
We're going to introduce split page table lock for PMD level. Let's
rename existing split ptlock for PTE level to avoid confusion.
Pull core locking changes from Ingo Molnar:
"The biggest changes:
- add lockdep support for seqcount/seqlocks structures, this
unearthed both bugs and required extra annotation.
- move the various kernel locking primitives to the new
kernel/locking/ directory"
* 'core-locking-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (21 commits)
block: Use u64_stats_init() to initialize seqcounts
locking/lockdep: Mark __lockdep_count_forward_deps() as static
lockdep/proc: Fix lock-time avg computation
locking/doc: Update references to kernel/mutex.c
ipv6: Fix possible ipv6 seqlock deadlock
cpuset: Fix potential deadlock w/ set_mems_allowed
seqcount: Add lockdep functionality to seqcount/seqlock structures
net: Explicitly initialize u64_stats_sync structures for lockdep
locking: Move the percpu-rwsem code to kernel/locking/
locking: Move the lglocks code to kernel/locking/
locking: Move the rwsem code to kernel/locking/
locking: Move the rtmutex code to kernel/locking/
locking: Move the semaphore core to kernel/locking/
locking: Move the spinlock code to kernel/locking/
locking: Move the lockdep code to kernel/locking/
locking: Move the mutex code to kernel/locking/
hung_task debugging: Add tracepoint to report the hang
x86/locking/kconfig: Update paravirt spinlock Kconfig description
lockstat: Report avg wait and hold times
lockdep, x86/alternatives: Drop ancient lockdep fixup message
git://git.kernel.org/pub/scm/linux/kernel/git/tomba/linux
Pull fbdev changes from Tomi Valkeinen:
"Nothing particularly stands out in this pull request. The biggest
part of the changes are cleanups.
Maybe one fix to mention is the "fb: reorder the lock sequence to fix
potential dead lock" which hopefully fixes the fb locking issues
reported by multiple persons.
There are also a few commits that have changes to arch/arm/mach-at91
and arch/avr32, which have been acked by the maintainers"
* tag 'fbdev-3.13' of git://git.kernel.org/pub/scm/linux/kernel/git/tomba/linux: (143 commits)
fb: reorder the lock sequence to fix potential dead lock
fbdev: shmobile-lcdcfb: Convert to clk_prepare/unprepare
fbdev: shmobile-hdmi: Convert to clk_prepare/unprepare
omapdss: Add new panel driver for Topolly td028ttec1 LCD.
video: exynos_mipi_dsi: Unlock the mutex before returning
video: da8xx-fb: remove unwanted define
video: Remove unnecessary semicolons
simplefb: use write-combined remapping
simplefb: fix unmapping fb during destruction
OMAPDSS: connector-dvi: fix releasing i2c_adapter
OMAPDSS: DSI: fix perf measuring ifdefs
framebuffer: Use fb_<level>
framebuffer: Add fb_<level> convenience logging macros
efifb: prevent null-deref when iterating dmi_list
fbdev: fix error return code in metronomefb_probe()
video: xilinxfb: Fix for "Use standard variable name convention"
OMAPDSS: Fix de_level in videomode_to_omap_video_timings()
video: xilinxfb: Simplify error path
video: xilinxfb: Use devm_kzalloc instead of kzalloc
video: xilinxfb: Use standard variable name convention
git://git.kernel.org/pub/scm/linux/kernel/git/helgaas/pci
Pull PCI changes from Bjorn Helgaas:
"Resource management
- Fix host bridge window coalescing (Alexey Neyman)
- Pass type, width, and prefetchability for window alignment (Wei Yang)
PCI device hotplug
- Convert acpiphp, acpiphp_ibm to dynamic debug (Lan Tianyu)
Power management
- Remove pci_pm_complete() (Liu Chuansheng)
MSI
- Fail initialization if device is not in PCI_D0 (Yijing Wang)
MPS (Max Payload Size)
- Use pcie_get_mps() and pcie_set_mps() to simplify code (Yijing Wang)
- Use pcie_set_readrq() to simplify code (Yijing Wang)
- Use cached pci_dev->pcie_mpss to simplify code (Yijing Wang)
SR-IOV
- Enable upstream bridges even for VFs on virtual buses (Bjorn Helgaas)
- Use pci_is_root_bus() to avoid catching virtual buses (Wei Yang)
Virtualization
- Add x86 MSI masking ops (Konrad Rzeszutek Wilk)
Freescale i.MX6
- Support i.MX6 PCIe controller (Sean Cross)
- Increase link startup timeout (Marek Vasut)
- Probe PCIe in fs_initcall() (Marek Vasut)
- Fix imprecise abort handler (Tim Harvey)
- Remove redundant of_match_ptr (Sachin Kamat)
Renesas R-Car
- Support Gen2 internal PCIe controller (Valentine Barshak)
Samsung Exynos
- Add MSI support (Jingoo Han)
- Turn off power when link fails (Jingoo Han)
- Add Jingoo Han as maintainer (Jingoo Han)
- Add clk_disable_unprepare() on error path (Wei Yongjun)
Synopsys DesignWare
- Add irq_create_mapping() (Pratyush Anand)
- Add header guards (Seungwon Jeon)
Miscellaneous
- Enable native PCIe services by default on non-ACPI (Andrew Murray)
- Cleanup _OSC usage and messages (Bjorn Helgaas)
- Remove pcibios_last_bus boot option on non-x86 (Bjorn Helgaas)
- Convert bus code to use bus_, drv_, and dev_groups (Greg Kroah-Hartman)
- Remove unused pci_mem_start (Myron Stowe)
- Make sysfs functions static (Sachin Kamat)
- Warn on invalid return from driver probe (Stephen M. Cameron)
- Remove Intel Haswell D3 delays (Todd E Brandt)
- Call pci_set_master() in core if driver doesn't do it (Yinghai Lu)
- Use pci_is_pcie() to simplify code (Yijing Wang)
- Use PCIe capability accessors to simplify code (Yijing Wang)
- Use cached pci_dev->pcie_cap to simplify code (Yijing Wang)
- Removed unused "is_pcie" from struct pci_dev (Yijing Wang)
- Simplify sysfs CPU affinity implementation (Yijing Wang)"
* tag 'pci-v3.13-changes' of git://git.kernel.org/pub/scm/linux/kernel/git/helgaas/pci: (79 commits)
PCI: Enable upstream bridges even for VFs on virtual buses
PCI: Add pci_upstream_bridge()
PCI: Add x86_msi.msi_mask_irq() and msix_mask_irq()
PCI: Warn on driver probe return value greater than zero
PCI: Drop warning about drivers that don't use pci_set_master()
PCI: Workaround missing pci_set_master in pci drivers
powerpc/pci: Use pci_is_pcie() to simplify code [fix]
PCI: Update pcie_ports 'auto' behavior for non-ACPI platforms
PCI: imx6: Probe the PCIe in fs_initcall()
PCI: Add R-Car Gen2 internal PCI support
PCI: imx6: Remove redundant of_match_ptr
PCI: Report pci_pme_active() kmalloc failure
mn10300/PCI: Remove useless pcibios_last_bus
frv/PCI: Remove pcibios_last_bus
PCI: imx6: Increase link startup timeout
PCI: exynos: Remove redundant of_match_ptr
PCI: imx6: Fix imprecise abort handler
PCI: Fail MSI/MSI-X initialization if device is not in PCI_D0
PCI: imx6: Remove redundant dev_err() in imx6_pcie_probe()
x86/PCI: Coalesce multiple overlapping host bridge windows
Pull ACPI and power management updates from Rafael J Wysocki:
- New power capping framework and the the Intel Running Average Power
Limit (RAPL) driver using it from Srinivas Pandruvada and Jacob Pan.
- Addition of the in-kernel switching feature to the arm_big_little
cpufreq driver from Viresh Kumar and Nicolas Pitre.
- cpufreq support for iMac G5 from Aaro Koskinen.
- Baytrail processors support for intel_pstate from Dirk Brandewie.
- cpufreq support for Midway/ECX-2000 from Mark Langsdorf.
- ARM vexpress/TC2 cpufreq support from Sudeep KarkadaNagesha.
- ACPI power management support for the I2C and SPI bus types from Mika
Westerberg and Lv Zheng.
- cpufreq core fixes and cleanups from Viresh Kumar, Srivatsa S Bhat,
Stratos Karafotis, Xiaoguang Chen, Lan Tianyu.
- cpufreq drivers updates (mostly fixes and cleanups) from Viresh
Kumar, Aaro Koskinen, Jungseok Lee, Sudeep KarkadaNagesha, Lukasz
Majewski, Manish Badarkhe, Hans-Christian Egtvedt, Evgeny Kapaev.
- intel_pstate updates from Dirk Brandewie and Adrian Huang.
- ACPICA update to version 20130927 includig fixes and cleanups and
some reduction of divergences between the ACPICA code in the kernel
and ACPICA upstream in order to improve the automatic ACPICA patch
generation process. From Bob Moore, Lv Zheng, Tomasz Nowicki, Naresh
Bhat, Bjorn Helgaas, David E Box.
- ACPI IPMI driver fixes and cleanups from Lv Zheng.
- ACPI hotplug fixes and cleanups from Bjorn Helgaas, Toshi Kani, Zhang
Yanfei, Rafael J Wysocki.
- Conversion of the ACPI AC driver to the platform bus type and
multiple driver fixes and cleanups related to ACPI from Zhang Rui.
- ACPI processor driver fixes and cleanups from Hanjun Guo, Jiang Liu,
Bartlomiej Zolnierkiewicz, Mathieu Rhéaume, Rafael J Wysocki.
- Fixes and cleanups and new blacklist entries related to the ACPI
video support from Aaron Lu, Felipe Contreras, Lennart Poettering,
Kirill Tkhai.
- cpuidle core cleanups from Viresh Kumar and Lorenzo Pieralisi.
- cpuidle drivers fixes and cleanups from Daniel Lezcano, Jingoo Han,
Bartlomiej Zolnierkiewicz, Prarit Bhargava.
- devfreq updates from Sachin Kamat, Dan Carpenter, Manish Badarkhe.
- Operation Performance Points (OPP) core updates from Nishanth Menon.
- Runtime power management core fix from Rafael J Wysocki and update
from Ulf Hansson.
- Hibernation fixes from Aaron Lu and Rafael J Wysocki.
- Device suspend/resume lockup detection mechanism from Benoit Goby.
- Removal of unused proc directories created for various ACPI drivers
from Lan Tianyu.
- ACPI LPSS driver fix and new device IDs for the ACPI platform scan
handler from Heikki Krogerus and Jarkko Nikula.
- New ACPI _OSI blacklist entry for Toshiba NB100 from Levente Kurusa.
- Assorted fixes and cleanups related to ACPI from Andy Shevchenko, Al
Stone, Bartlomiej Zolnierkiewicz, Colin Ian King, Dan Carpenter,
Felipe Contreras, Jianguo Wu, Lan Tianyu, Yinghai Lu, Mathias Krause,
Liu Chuansheng.
- Assorted PM fixes and cleanups from Andy Shevchenko, Thierry Reding,
Jean-Christophe Plagniol-Villard.
* tag 'pm+acpi-3.13-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/rafael/linux-pm: (386 commits)
cpufreq: conservative: fix requested_freq reduction issue
ACPI / hotplug: Consolidate deferred execution of ACPI hotplug routines
PM / runtime: Use pm_runtime_put_sync() in __device_release_driver()
ACPI / event: remove unneeded NULL pointer check
Revert "ACPI / video: Ignore BIOS initial backlight value for HP 250 G1"
ACPI / video: Quirk initial backlight level 0
ACPI / video: Fix initial level validity test
intel_pstate: skip the driver if ACPI has power mgmt option
PM / hibernate: Avoid overflow in hibernate_preallocate_memory()
ACPI / hotplug: Do not execute "insert in progress" _OST
ACPI / hotplug: Carry out PCI root eject directly
ACPI / hotplug: Merge device hot-removal routines
ACPI / hotplug: Make acpi_bus_hot_remove_device() internal
ACPI / hotplug: Simplify device ejection routines
ACPI / hotplug: Fix handle_root_bridge_removal()
ACPI / hotplug: Refuse to hot-remove all objects with disabled hotplug
ACPI / scan: Start matching drivers after trying scan handlers
ACPI: Remove acpi_pci_slot_init() headers from internal.h
ACPI / blacklist: fix name of ThinkPad Edge E530
PowerCap: Fix build error with option -Werror=format-security
arch/arm/mach-omap2/opp.c
drivers/Kconfig
drivers/spi/spi.c
Pull MTD changes from Brian Norris:
- Unify some compile-time differences so that we have fewer uses of
#ifdef CONFIG_OF in atmel_nand
- Other general cleanups (removing unused functions, options,
variables, fields; use correct interfaces)
- Fix BUG() for new odd-sized NAND, which report non-power-of-2
dimensions via ONFI
- Miscellaneous driver fixes (SPI NOR flash; BCM47xx NAND flash; etc.)
- Improve differentiation between SLC and MLC NAND -- this clarifies an
ABI issue regarding the MTD "type" (in sysfs and in the MEMGETINFO
ioctl), where the MTD_MLCNANDFLASH type was present but
inconsistently used
- Extend GPMI NAND to support multi-chip-select NAND for some platforms
- Many improvements to the OMAP2/3 NAND driver, including an expanded
DT binding to bring us closer to mainline support for some OMAP
systems
- Fix a deadlock in the error path of the Atmel NAND driver probe
- Correct the error codes from MTD mmap() to conform to POSIX and the
Linux Programmer's Manual. This is an acknowledged change in the MTD
ABI, but I can't imagine somebody relying on the non-standard -ENOSYS
error code specifically. Am I just being unimaginative? :)
- Fix a few important GPMI NAND bugs (one regression from 3.12 and one
long-standing race condition)
- More? Read the log!
* tag 'for-linus-20131112' of git://git.infradead.org/linux-mtd: (98 commits)
mtd: gpmi: fix the NULL pointer
mtd: gpmi: fix kernel BUG due to racing DMA operations
mtd: mtdchar: return expected errors on mmap() call
mtd: gpmi: only scan two chips for imx6
mtd: gpmi: Use devm_kzalloc()
mtd: atmel_nand: fix bug driver will in a dead lock if no nand detected
mtd: nand: use a local variable to simplify the nand_scan_tail
mtd: nand: remove deprecated IRQF_DISABLED
mtd: dataflash: Say if we find a device we don't support
mtd: nand: omap: fix error return code in omap_nand_probe()
mtd: nand_bbt: kill NAND_BBT_SCANALLPAGES
mtd: m25p80: fixup device removal failure path
mtd: mxc_nand: Include linux/of.h header
mtd: remove duplicated include from mtdcore.c
mtd: m25p80: add support for Macronix mx25l3255e
mtd: nand: omap: remove selection of BCH ecc-scheme via KConfig
mtd: nand: omap: updated devm_xx for all resource allocation and free calls
mtd: nand: omap: use drivers/mtd/nand/nand_bch.c wrapper for BCH ECC instead of lib/bch.c
mtd: nand: omap: clean-up ecc layout for BCH ecc schemes
mtd: nand: omap2: clean-up BCHx_HW and BCHx_SW ECC configurations in device_probe
Pull block IO core updates from Jens Axboe:
"This is the pull request for the core changes in the block layer for
3.13. It contains:
- The new blk-mq request interface.
This is a new and more scalable queueing model that marries the
best part of the request based interface we currently have (which
is fully featured, but scales poorly) and the bio based "interface"
which the new drivers for high IOPS devices end up using because
it's much faster than the request based one.
The bio interface has no block layer support, since it taps into
the stack much earlier. This means that drivers end up having to
implement a lot of functionality on their own, like tagging,
timeout handling, requeue, etc. The blk-mq interface provides all
these. Some drivers even provide a switch to select bio or rq and
has code to handle both, since things like merging only works in
the rq model and hence is faster for some workloads. This is a
huge mess. Conversion of these drivers nets us a substantial code
reduction. Initial results on converting SCSI to this model even
shows an 8x improvement on single queue devices. So while the
model was intended to work on the newer multiqueue devices, it has
substantial improvements for "classic" hardware as well. This code
has gone through extensive testing and development, it's now ready
to go. A pull request is coming to convert virtio-blk to this
model will be will be coming as well, with more drivers scheduled
for 3.14 conversion.
- Two blktrace fixes from Jan and Chen Gang.
- A plug merge fix from Alireza Haghdoost.
- Conversion of __get_cpu_var() from Christoph Lameter.
- Fix for sector_div() with 64-bit divider from Geert Uytterhoeven.
- A fix for a race between request completion and the timeout
handling from Jeff Moyer. This is what caused the merge conflict
with blk-mq/core, in case you are looking at that.
- A dm stacking fix from Mike Snitzer.
- A code consolidation fix and duplicated code removal from Kent
Overstreet.
- A handful of block bug fixes from Mikulas Patocka, fixing a loop
crash and memory corruption on blk cg.
- Elevator switch bug fix from Tomoki Sekiyama.
A heads-up that I had to rebase this branch. Initially the immutable
bio_vecs had been queued up for inclusion, but a week later, it became
clear that it wasn't fully cooked yet. So the decision was made to
pull this out and postpone it until 3.14. It was a straight forward
rebase, just pruning out the immutable series and the later fixes of
problems with it. The rest of the patches applied directly and no
further changes were made"
* 'for-3.13/core' of git://git.kernel.dk/linux-block: (31 commits)
block: replace IS_ERR and PTR_ERR with PTR_ERR_OR_ZERO
block: Do not call sector_div() with a 64-bit divisor
kernel: trace: blktrace: remove redundent memcpy() in compat_blk_trace_setup()
block: Consolidate duplicated bio_trim() implementations
block: Use rw_copy_check_uvector()
block: Enable sysfs nomerge control for I/O requests in the plug list
block: properly stack underlying max_segment_size to DM device
elevator: acquire q->sysfs_lock in elevator_change()
elevator: Fix a race in elevator switching and md device initialization
block: Replace __get_cpu_var uses
bdi: test bdi_init failure
block: fix a probe argument to blk_register_region
loop: fix crash if blk_alloc_queue fails
blk-core: Fix memory corruption if blkcg_init_queue fails
block: fix race between request completion and timeout handling
blktrace: Send BLK_TN_PROCESS events to all running traces
blk-mq: don't disallow request merges for req->special being set
blk-mq: mq plug list breakage
blk-mq: fix for flush deadlock
Pull ARM updates from Russell King:
"Included in this series are:
1. BE8 (modern big endian) changes for ARM from Ben Dooks
2. big.Little support from Nicolas Pitre and Dave Martin
3. support for LPAE systems with all system memory above 4GB
4. Perf updates from Will Deacon
5. Additional prefetching and other performance improvements from Will.
6. Neon-optimised AES implementation fro Ard.
7. A number of smaller fixes scattered around the place.
There is a rather horrid merge conflict in tools/perf - I was never
notified of the conflict because it originally occurred between Will's
tree and other stuff. Consequently I have a resolution which Will
forwarded me, which I'll forward on immediately after sending this
mail.
The other notable thing is I'm expecting some build breakage in the
crypto stuff on ARM only with Ard's AES patches. These were merged
into a stable git branch which others had already pulled, so there's
little I can do about this. The problem is caused because these
patches have a dependency on some code in the crypto git tree - I
tried requesting a branch I can pull to resolve these, and all I got
each time from the crypto people was "we'll revert our patches then"
which would only make things worse since I still don't have the
dependent patches. I've no idea what's going on there or how to
resolve that, and since I can't split these patches from the rest of
this pull request, I'm rather stuck with pushing this as-is or
reverting Ard's patches.
Since it should "come out in the wash" I've left them in - the only
build problems they seem to cause at the moment are with randconfigs,
and since it's a new feature anyway. However, if by -rc1 the
dependencies aren't in, I think it'd be best to revert Ard's patches"
I resolved the perf conflict roughly as per the patch sent by Russell,
but there may be some differences. Any errors are likely mine. Let's
see how the crypto issues work out..
* 'for-linus' of git://git.linaro.org/people/rmk/linux-arm: (110 commits)
ARM: 7868/1: arm/arm64: remove atomic_clear_mask() in "include/asm/atomic.h"
ARM: 7867/1: include: asm: use 'int' instead of 'unsigned long' for 'oldval' in atomic_cmpxchg().
ARM: 7866/1: include: asm: use 'long long' instead of 'u64' within atomic.h
ARM: 7871/1: amba: Extend number of IRQS
ARM: 7887/1: Don't smp_cross_call() on UP devices in arch_irq_work_raise()
ARM: 7872/1: Support arch_irq_work_raise() via self IPIs
ARM: 7880/1: Clear the IT state independent of the Thumb-2 mode
ARM: 7878/1: nommu: Implement dummy early_paging_init()
ARM: 7876/1: clear Thumb-2 IT state on exception handling
ARM: 7874/2: bL_switcher: Remove cpu_hotplug_driver_{lock,unlock}()
ARM: footbridge: fix build warnings for netwinder
ARM: 7873/1: vfp: clear vfp_current_hw_state for dying cpu
ARM: fix misplaced arch_virt_to_idmap()
ARM: 7848/1: mcpm: Implement cpu_kill() to synchronise on powerdown
ARM: 7847/1: mcpm: Factor out logical-to-physical CPU translation
ARM: 7869/1: remove unused XSCALE_PMU Kconfig param
ARM: 7864/1: Handle 64-bit memory in case of 32-bit phys_addr_t
ARM: 7863/1: Let arm_add_memory() always use 64-bit arguments
ARM: 7862/1: pcpu: replace __get_cpu_var_uses
ARM: 7861/1: cacheflush: consolidate single-CPU ARMv7 cache disabling code
Pull DMA mask updates from Russell King:
"This series cleans up the handling of DMA masks in a lot of drivers,
fixing some bugs as we go.
Some of the more serious errors include:
- drivers which only set their coherent DMA mask if the attempt to
set the streaming mask fails.
- drivers which test for a NULL dma mask pointer, and then set the
dma mask pointer to a location in their module .data section -
which will cause problems if the module is reloaded.
To counter these, I have introduced two helper functions:
- dma_set_mask_and_coherent() takes care of setting both the
streaming and coherent masks at the same time, with the correct
error handling as specified by the API.
- dma_coerce_mask_and_coherent() which resolves the problem of
drivers forcefully setting DMA masks. This is more a marker for
future work to further clean these locations up - the code which
creates the devices really should be initialising these, but to fix
that in one go along with this change could potentially be very
disruptive.
The last thing this series does is prise away some of Linux's addition
to "DMA addresses are physical addresses and RAM always starts at
zero". We have ARM LPAE systems where all system memory is above 4GB
physical, hence having DMA masks interpreted by (eg) the block layers
as describing physical addresses in the range 0..DMAMASK fails on
these platforms. Santosh Shilimkar addresses this in this series; the
patches were copied to the appropriate people multiple times but were
ignored.
Fixing this also gets rid of some ARM weirdness in the setup of the
max*pfn variables, and brings ARM into line with every other Linux
architecture as far as those go"
* 'for-linus-dma-masks' of git://git.linaro.org/people/rmk/linux-arm: (52 commits)
ARM: 7805/1: mm: change max*pfn to include the physical offset of memory
ARM: 7797/1: mmc: Use dma_max_pfn(dev) helper for bounce_limit calculations
ARM: 7796/1: scsi: Use dma_max_pfn(dev) helper for bounce_limit calculations
ARM: 7795/1: mm: dma-mapping: Add dma_max_pfn(dev) helper function
ARM: 7794/1: block: Rename parameter dma_mask to max_addr for blk_queue_bounce_limit()
ARM: DMA-API: better handing of DMA masks for coherent allocations
ARM: 7857/1: dma: imx-sdma: setup dma mask
DMA-API: firmware/google/gsmi.c: avoid direct access to DMA masks
DMA-API: dcdbas: update DMA mask handing
DMA-API: dma: edma.c: no need to explicitly initialize DMA masks
DMA-API: usb: musb: use platform_device_register_full() to avoid directly messing with dma masks
DMA-API: crypto: remove last references to 'static struct device *dev'
DMA-API: crypto: fix ixp4xx crypto platform device support
DMA-API: others: use dma_set_coherent_mask()
DMA-API: staging: use dma_set_coherent_mask()
DMA-API: usb: use new dma_coerce_mask_and_coherent()
DMA-API: usb: use dma_set_coherent_mask()
DMA-API: parport: parport_pc.c: use dma_coerce_mask_and_coherent()
DMA-API: net: octeon: use dma_coerce_mask_and_coherent()
DMA-API: net: nxp/lpc_eth: use dma_coerce_mask_and_coherent()
No point in having this bit defined by architecture.
Acked-by: Peter Zijlstra <peterz@infradead.org>
Link: http://lkml.kernel.org/r/20130917183629.090698799@linutronix.de
There is no reason for per arch hardirq bits. Make them all generic
Link: http://lkml.kernel.org/r/20130917183628.534494408@linutronix.de
On a 68k platform a couple of interrupts are demultiplexed and
"polled" from a top level interrupt. Unfortunately there is no way to
determine which of the sub interrupts raised the top level interrupt,
so all of the demultiplexed interrupt handlers need to be
invoked. Given a high enough frequency this can trigger the spurious
interrupt detection mechanism, if one of the demultiplex interrupts
returns IRQ_NONE continuously. But this is a false positive as the
polling causes this behaviour and not buggy hardware/software.
Introduce IRQ_POLLED which can be set at interrupt chip setup time via
irq_set_status_flags(). The flag excludes the interrupt from the
spurious detector and from all core polling activities.
Reported-and-tested-by: Michael Schmitz <schmitzmic@gmail.com>
Cc: linux-m68k@vger.kernel.org
Link: http://lkml.kernel.org/r/alpine.DEB.2.02.1311061149250.23353@ionos.tec.linutronix.de
Pull networking updates from David Miller:
1) The addition of nftables. No longer will we need protocol aware
firewall filtering modules, it can all live in userspace.
At the core of nftables is a, for lack of a better term, virtual
machine that executes byte codes to inspect packet or metadata
(arriving interface index, etc.) and make verdict decisions.
Besides support for loading packet contents and comparing them, the
interpreter supports lookups in various datastructures as
fundamental operations. For example sets are supports, and
therefore one could create a set of whitelist IP address entries
which have ACCEPT verdicts attached to them, and use the appropriate
byte codes to do such lookups.
Since the interpreted code is composed in userspace, userspace can
do things like optimize things before giving it to the kernel.
Another major improvement is the capability of atomically updating
portions of the ruleset. In the existing netfilter implementation,
one has to update the entire rule set in order to make a change and
this is very expensive.
Userspace tools exist to create nftables rules using existing
netfilter rule sets, but both kernel implementations will need to
co-exist for quite some time as we transition from the old to the
new stuff.
Kudos to Patrick McHardy, Pablo Neira Ayuso, and others who have
worked so hard on this.
2) Daniel Borkmann and Hannes Frederic Sowa made several improvements
to our pseudo-random number generator, mostly used for things like
UDP port randomization and netfitler, amongst other things.
In particular the taus88 generater is updated to taus113, and test
cases are added.
3) Support 64-bit rates in HTB and TBF schedulers, from Eric Dumazet
and Yang Yingliang.
4) Add support for new 577xx tigon3 chips to tg3 driver, from Nithin
Sujir.
5) Fix two fatal flaws in TCP dynamic right sizing, from Eric Dumazet,
Neal Cardwell, and Yuchung Cheng.
6) Allow IP_TOS and IP_TTL to be specified in sendmsg() ancillary
control message data, much like other socket option attributes.
From Francesco Fusco.
7) Allow applications to specify a cap on the rate computed
automatically by the kernel for pacing flows, via a new
SO_MAX_PACING_RATE socket option. From Eric Dumazet.
8) Make the initial autotuned send buffer sizing in TCP more closely
reflect actual needs, from Eric Dumazet.
9) Currently early socket demux only happens for TCP sockets, but we
can do it for connected UDP sockets too. Implementation from Shawn
Bohrer.
10) Refactor inet socket demux with the goal of improving hash demux
performance for listening sockets. With the main goals being able
to use RCU lookups on even request sockets, and eliminating the
listening lock contention. From Eric Dumazet.
11) The bonding layer has many demuxes in it's fast path, and an RCU
conversion was started back in 3.11, several changes here extend the
RCU usage to even more locations. From Ding Tianhong and Wang
Yufen, based upon suggestions by Nikolay Aleksandrov and Veaceslav
Falico.
12) Allow stackability of segmentation offloads to, in particular, allow
segmentation offloading over tunnels. From Eric Dumazet.
13) Significantly improve the handling of secret keys we input into the
various hash functions in the inet hashtables, TCP fast open, as
well as syncookies. From Hannes Frederic Sowa. The key fundamental
operation is "net_get_random_once()" which uses static keys.
Hannes even extended this to ipv4/ipv6 fragmentation handling and
our generic flow dissector.
14) The generic driver layer takes care now to set the driver data to
NULL on device removal, so it's no longer necessary for drivers to
explicitly set it to NULL any more. Many drivers have been cleaned
up in this way, from Jingoo Han.
15) Add a BPF based packet scheduler classifier, from Daniel Borkmann.
16) Improve CRC32 interfaces and generic SKB checksum iterators so that
SCTP's checksumming can more cleanly be handled. Also from Daniel
Borkmann.
17) Add a new PMTU discovery mode, IP_PMTUDISC_INTERFACE, which forces
using the interface MTU value. This helps avoid PMTU attacks,
particularly on DNS servers. From Hannes Frederic Sowa.
18) Use generic XPS for transmit queue steering rather than internal
(re-)implementation in virtio-net. From Jason Wang.
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next: (1622 commits)
random32: add test cases for taus113 implementation
random32: upgrade taus88 generator to taus113 from errata paper
random32: move rnd_state to linux/random.h
random32: add prandom_reseed_late() and call when nonblocking pool becomes initialized
random32: add periodic reseeding
random32: fix off-by-one in seeding requirement
PHY: Add RTL8201CP phy_driver to realtek
xtsonic: add missing platform_set_drvdata() in xtsonic_probe()
macmace: add missing platform_set_drvdata() in mace_probe()
ethernet/arc/arc_emac: add missing platform_set_drvdata() in arc_emac_probe()
ipv6: protect for_each_sk_fl_rcu in mem_check with rcu_read_lock_bh
vlan: Implement vlan_dev_get_egress_qos_mask as an inline.
ixgbe: add warning when max_vfs is out of range.
igb: Update link modes display in ethtool
netfilter: push reasm skb through instead of original frag skbs
ip6_output: fragment outgoing reassembled skb properly
MAINTAINERS: mv643xx_eth: take over maintainership from Lennart
net_sched: tbf: support of 64bit rates
ixgbe: deleting dfwd stations out of order can cause null ptr deref
ixgbe: fix build err, num_rx_queues is only available with CONFIG_RPS
