path: root/include/linux
2019-04-05i2c: Allow recovery of the initial IRQ by an I2C client device.Jim Broadus
[ Upstream commit 93b6604c5a669d84e45fe5129294875bf82eb1ff ] A previous change allowed I2C client devices to discover new IRQs upon reprobe by clearing the IRQ in i2c_device_remove. However, if an IRQ was assigned in i2c_new_device, that information is lost. For example, the touchscreen and trackpad devices on a Dell Inspiron laptop are I2C devices whose IRQs are defined by ACPI extended IRQ types. The client device structures are initialized during an ACPI walk. After removing the i2c_hid device, modprobe fails. This change caches the initial IRQ value in i2c_new_device and then resets the client device IRQ to the initial value in i2c_device_remove. Fixes: 6f108dd70d30 ("i2c: Clear client->irq in i2c_device_remove") Signed-off-by: Jim Broadus <jbroadus@gmail.com> Reviewed-by: Benjamin Tissoires <benjamin.tissoires@redhat.com> Reviewed-by: Charles Keepax <ckeepax@opensource.cirrus.com> [wsa: this is an easy to backport fix for the regression. We will refactor the code to handle irq assignments better in general.] Signed-off-by: Wolfram Sang <wsa@the-dreams.de> Signed-off-by: Sasha Levin <sashal@kernel.org>
2019-04-05f2fs: fix to check inline_xattr_size boundary correctlyChao Yu
[ Upstream commit 500e0b28ecd3c5aade98f3c3a339d18dcb166bb6 ] We use below condition to check inline_xattr_size boundary: if (!F2FS_OPTION(sbi).inline_xattr_size || F2FS_OPTION(sbi).inline_xattr_size >= DEF_ADDRS_PER_INODE - F2FS_TOTAL_EXTRA_ATTR_SIZE - DEF_INLINE_RESERVED_SIZE - DEF_MIN_INLINE_SIZE) There is there problems in that check: - we should allow inline_xattr_size equaling to min size of inline {data,dentry} area. - F2FS_TOTAL_EXTRA_ATTR_SIZE and inline_xattr_size are based on different size unit, previous one is 4 bytes, latter one is 1 bytes. - DEF_MIN_INLINE_SIZE only indicate min size of inline data area, however, we need to consider min size of inline dentry area as well, minimal inline dentry should at least contain two entries: '.' and '..', so that min inline_dentry size is 40 bytes. .bitmap 1 * 1 = 1 .reserved 1 * 1 = 1 .dentry 11 * 2 = 22 .filename 8 * 2 = 16 total 40 Signed-off-by: Chao Yu <yuchao0@huawei.com> Signed-off-by: Jaegeuk Kim <jaegeuk@kernel.org> Signed-off-by: Sasha Levin <sashal@kernel.org>
2019-04-05kasan: fix kasan_check_read/write definitionsArnd Bergmann
[ Upstream commit bcf6f55a0d05eedd8ebb6ecc60ae3f93205ad833 ] Building little-endian allmodconfig kernels on arm64 started failing with the generated atomic.h implementation, since we now try to call kasan helpers from the EFI stub: aarch64-linux-gnu-ld: drivers/firmware/efi/libstub/arm-stub.stub.o: in function `atomic_set': include/generated/atomic-instrumented.h:44: undefined reference to `__efistub_kasan_check_write' I suspect that we get similar problems in other files that explicitly disable KASAN for some reason but call atomic_t based helper functions. We can fix this by checking the predefined __SANITIZE_ADDRESS__ macro that the compiler sets instead of checking CONFIG_KASAN, but this in turn requires a small hack in mm/kasan/common.c so we do see the extern declaration there instead of the inline function. Link: http://lkml.kernel.org/r/20181211133453.2835077-1-arnd@arndb.de Fixes: b1864b828644 ("locking/atomics: build atomic headers as required") Signed-off-by: Arnd Bergmann <arnd@arndb.de> Reported-by: Anders Roxell <anders.roxell@linaro.org> Acked-by: Andrey Ryabinin <aryabinin@virtuozzo.com> Cc: Ard Biesheuvel <ard.biesheuvel@linaro.org> Cc: Will Deacon <will.deacon@arm.com> Cc: Mark Rutland <mark.rutland@arm.com> Cc: Alexander Potapenko <glider@google.com> Cc: Dmitry Vyukov <dvyukov@google.com> Cc: Andrey Konovalov <andreyknvl@google.com> Cc: Stephen Rothwell <sfr@canb.auug.org.au>, Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Sasha Levin <sashal@kernel.org>
2019-04-05include/linux/relay.h: fix percpu annotation in struct rchanLuc Van Oostenryck
[ Upstream commit 62461ac2e5b6520b6d65fc6d7d7b4b8df4b848d8 ] The percpu member of this structure is declared as: struct ... ** __percpu member; So its type is: __percpu pointer to pointer to struct ... But looking at how it's used, its type should be: pointer to __percpu pointer to struct ... and it should thus be declared as: struct ... * __percpu *member; So fix the placement of '__percpu' in the definition of this structures. This silents a few Sparse's warnings like: warning: incorrect type in initializer (different address spaces) expected void const [noderef] <asn:3> *__vpp_verify got struct sched_domain ** Link: http://lkml.kernel.org/r/20190118144902.79065-1-luc.vanoostenryck@gmail.com Fixes: 017c59c042d01 ("relay: Use per CPU constructs for the relay channel buffer pointers") Signed-off-by: Luc Van Oostenryck <luc.vanoostenryck@gmail.com> Cc: Jens Axboe <axboe@suse.de> Cc: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Sasha Levin <sashal@kernel.org>
2019-04-05tracing: kdb: Fix ftdump to not sleepDouglas Anderson
[ Upstream commit 31b265b3baaf55f209229888b7ffea523ddab366 ] As reported back in 2016-11 [1], the "ftdump" kdb command triggers a BUG for "sleeping function called from invalid context". kdb's "ftdump" command wants to call ring_buffer_read_prepare() in atomic context. A very simple solution for this is to add allocation flags to ring_buffer_read_prepare() so kdb can call it without triggering the allocation error. This patch does that. Note that in the original email thread about this, it was suggested that perhaps the solution for kdb was to either preallocate the buffer ahead of time or create our own iterator. I'm hoping that this alternative of adding allocation flags to ring_buffer_read_prepare() can be considered since it means I don't need to duplicate more of the core trace code into "trace_kdb.c" (for either creating my own iterator or re-preparing a ring allocator whose memory was already allocated). NOTE: another option for kdb is to actually figure out how to make it reuse the existing ftrace_dump() function and totally eliminate the duplication. This sounds very appealing and actually works (the "sr z" command can be seen to properly dump the ftrace buffer). The downside here is that ftrace_dump() fully consumes the trace buffer. Unless that is changed I'd rather not use it because it means "ftdump | grep xyz" won't be very useful to search the ftrace buffer since it will throw away the whole trace on the first grep. A future patch to dump only the last few lines of the buffer will also be hard to implement. [1] https://lkml.kernel.org/r/20161117191605.GA21459@google.com Link: http://lkml.kernel.org/r/20190308193205.213659-1-dianders@chromium.org Reported-by: Brian Norris <briannorris@chromium.org> Signed-off-by: Douglas Anderson <dianders@chromium.org> Signed-off-by: Steven Rostedt (VMware) <rostedt@goodmis.org> Signed-off-by: Sasha Levin <sashal@kernel.org>
2019-04-03mm: add support for kmem caches in DMA32 zoneNicolas Boichat
commit 6d6ea1e967a246f12cfe2f5fb743b70b2e608d4a upstream. Patch series "iommu/io-pgtable-arm-v7s: Use DMA32 zone for page tables", v6. This is a followup to the discussion in [1], [2]. IOMMUs using ARMv7 short-descriptor format require page tables (level 1 and 2) to be allocated within the first 4GB of RAM, even on 64-bit systems. For L1 tables that are bigger than a page, we can just use __get_free_pages with GFP_DMA32 (on arm64 systems only, arm would still use GFP_DMA). For L2 tables that only take 1KB, it would be a waste to allocate a full page, so we considered 3 approaches: 1. This series, adding support for GFP_DMA32 slab caches. 2. genalloc, which requires pre-allocating the maximum number of L2 page tables (4096, so 4MB of memory). 3. page_frag, which is not very memory-efficient as it is unable to reuse freed fragments until the whole page is freed. [3] This series is the most memory-efficient approach. stable@ note: We confirmed that this is a regression, and IOMMU errors happen on 4.19 and linux-next/master on MT8173 (elm, Acer Chromebook R13). The issue most likely starts from commit ad67f5a6545f ("arm64: replace ZONE_DMA with ZONE_DMA32"), i.e. 4.15, and presumably breaks a number of Mediatek platforms (and maybe others?). [1] https://lists.linuxfoundation.org/pipermail/iommu/2018-November/030876.html [2] https://lists.linuxfoundation.org/pipermail/iommu/2018-December/031696.html [3] https://patchwork.codeaurora.org/patch/671639/ This patch (of 3): IOMMUs using ARMv7 short-descriptor format require page tables to be allocated within the first 4GB of RAM, even on 64-bit systems. On arm64, this is done by passing GFP_DMA32 flag to memory allocation functions. For IOMMU L2 tables that only take 1KB, it would be a waste to allocate a full page using get_free_pages, so we considered 3 approaches: 1. This patch, adding support for GFP_DMA32 slab caches. 2. genalloc, which requires pre-allocating the maximum number of L2 page tables (4096, so 4MB of memory). 3. page_frag, which is not very memory-efficient as it is unable to reuse freed fragments until the whole page is freed. This change makes it possible to create a custom cache in DMA32 zone using kmem_cache_create, then allocate memory using kmem_cache_alloc. We do not create a DMA32 kmalloc cache array, as there are currently no users of kmalloc(..., GFP_DMA32). These calls will continue to trigger a warning, as we keep GFP_DMA32 in GFP_SLAB_BUG_MASK. This implies that calls to kmem_cache_*alloc on a SLAB_CACHE_DMA32 kmem_cache must _not_ use GFP_DMA32 (it is anyway redundant and unnecessary). Link: http://lkml.kernel.org/r/20181210011504.122604-2-drinkcat@chromium.org Signed-off-by: Nicolas Boichat <drinkcat@chromium.org> Acked-by: Vlastimil Babka <vbabka@suse.cz> Acked-by: Will Deacon <will.deacon@arm.com> Cc: Robin Murphy <robin.murphy@arm.com> Cc: Joerg Roedel <joro@8bytes.org> Cc: Christoph Lameter <cl@linux.com> Cc: Pekka Enberg <penberg@kernel.org> Cc: David Rientjes <rientjes@google.com> Cc: Joonsoo Kim <iamjoonsoo.kim@lge.com> Cc: Michal Hocko <mhocko@suse.com> Cc: Mel Gorman <mgorman@techsingularity.net> Cc: Sasha Levin <Alexander.Levin@microsoft.com> Cc: Huaisheng Ye <yehs1@lenovo.com> Cc: Mike Rapoport <rppt@linux.vnet.ibm.com> Cc: Yong Wu <yong.wu@mediatek.com> Cc: Matthias Brugger <matthias.bgg@gmail.com> Cc: Tomasz Figa <tfiga@google.com> Cc: Yingjoe Chen <yingjoe.chen@mediatek.com> Cc: Christoph Hellwig <hch@infradead.org> Cc: Matthew Wilcox <willy@infradead.org> Cc: Hsin-Yi Wang <hsinyi@chromium.org> Cc: <stable@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2019-04-03mm/hotplug: fix offline undo_isolate_page_range()Qian Cai
commit 9b7ea46a82b31c74a37e6ff1c2a1df7d53e392ab upstream. Commit f1dd2cd13c4b ("mm, memory_hotplug: do not associate hotadded memory to zones until online") introduced move_pfn_range_to_zone() which calls memmap_init_zone() during onlining a memory block. memmap_init_zone() will reset pagetype flags and makes migrate type to be MOVABLE. However, in __offline_pages(), it also call undo_isolate_page_range() after offline_isolated_pages() to do the same thing. Due to commit 2ce13640b3f4 ("mm: __first_valid_page skip over offline pages") changed __first_valid_page() to skip offline pages, undo_isolate_page_range() here just waste CPU cycles looping around the offlining PFN range while doing nothing, because __first_valid_page() will return NULL as offline_isolated_pages() has already marked all memory sections within the pfn range as offline via offline_mem_sections(). Also, after calling the "useless" undo_isolate_page_range() here, it reaches the point of no returning by notifying MEM_OFFLINE. Those pages will be marked as MIGRATE_MOVABLE again once onlining. The only thing left to do is to decrease the number of isolated pageblocks zone counter which would make some paths of the page allocation slower that the above commit introduced. Even if alloc_contig_range() can be used to isolate 16GB-hugetlb pages on ppc64, an "int" should still be enough to represent the number of pageblocks there. Fix an incorrect comment along the way. [cai@lca.pw: v4] Link: http://lkml.kernel.org/r/20190314150641.59358-1-cai@lca.pw Link: http://lkml.kernel.org/r/20190313143133.46200-1-cai@lca.pw Fixes: 2ce13640b3f4 ("mm: __first_valid_page skip over offline pages") Signed-off-by: Qian Cai <cai@lca.pw> Acked-by: Michal Hocko <mhocko@suse.com> Reviewed-by: Oscar Salvador <osalvador@suse.de> Cc: Vlastimil Babka <vbabka@suse.cz> Cc: <stable@vger.kernel.org> [4.13+] Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2019-04-03net: mii: Fix PAUSE cap advertisement from linkmode_adv_to_lcl_adv_t() helperClaudiu Manoil
[ Upstream commit 7f07e5f1f778605e98cf2156d4db1ff3a3a1a74a ] With a recent link mode advertisement code update this helper providing local pause capability translation used for flow control link mode negotiation got broken. For eth drivers using this helper, the issue is apparent only if either PAUSE or ASYM_PAUSE is being advertised. Fixes: 3c1bcc8614db ("net: ethernet: Convert phydev advertize and supported from u32 to link mode") Signed-off-by: Claudiu Manoil <claudiu.manoil@nxp.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2019-03-27aio: simplify - and fix - fget/fput for io_submit()Linus Torvalds
commit 84c4e1f89fefe70554da0ab33be72c9be7994379 upstream. Al Viro root-caused a race where the IOCB_CMD_POLL handling of fget/fput() could cause us to access the file pointer after it had already been freed: "In more details - normally IOCB_CMD_POLL handling looks so: 1) io_submit(2) allocates aio_kiocb instance and passes it to aio_poll() 2) aio_poll() resolves the descriptor to struct file by req->file = fget(iocb->aio_fildes) 3) aio_poll() sets ->woken to false and raises ->ki_refcnt of that aio_kiocb to 2 (bumps by 1, that is). 4) aio_poll() calls vfs_poll(). After sanity checks (basically, "poll_wait() had been called and only once") it locks the queue. That's what the extra reference to iocb had been for - we know we can safely access it. 5) With queue locked, we check if ->woken has already been set to true (by aio_poll_wake()) and, if it had been, we unlock the queue, drop a reference to aio_kiocb and bugger off - at that point it's a responsibility to aio_poll_wake() and the stuff called/scheduled by it. That code will drop the reference to file in req->file, along with the other reference to our aio_kiocb. 6) otherwise, we see whether we need to wait. If we do, we unlock the queue, drop one reference to aio_kiocb and go away - eventual wakeup (or cancel) will deal with the reference to file and with the other reference to aio_kiocb 7) otherwise we remove ourselves from waitqueue (still under the queue lock), so that wakeup won't get us. No async activity will be happening, so we can safely drop req->file and iocb ourselves. If wakeup happens while we are in vfs_poll(), we are fine - aio_kiocb won't get freed under us, so we can do all the checks and locking safely. And we don't touch ->file if we detect that case. However, vfs_poll() most certainly *does* touch the file it had been given. So wakeup coming while we are still in ->poll() might end up doing fput() on that file. That case is not too rare, and usually we are saved by the still present reference from descriptor table - that fput() is not the final one. But if another thread closes that descriptor right after our fget() and wakeup does happen before ->poll() returns, we are in trouble - final fput() done while we are in the middle of a method: Al also wrote a patch to take an extra reference to the file descriptor to fix this, but I instead suggested we just streamline the whole file pointer handling by submit_io() so that the generic aio submission code simply keeps the file pointer around until the aio has completed. Fixes: bfe4037e722e ("aio: implement IOCB_CMD_POLL") Acked-by: Al Viro <viro@zeniv.linux.org.uk> Reported-by: syzbot+503d4cc169fcec1cb18c@syzkaller.appspotmail.com Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2019-03-27libceph: wait for latest osdmap in ceph_monc_blacklist_add()Ilya Dryomov
commit bb229bbb3bf63d23128e851a1f3b85c083178fa1 upstream. Because map updates are distributed lazily, an OSD may not know about the new blacklist for quite some time after "osd blacklist add" command is completed. This makes it possible for a blacklisted but still alive client to overwrite a post-blacklist update, resulting in data corruption. Waiting for latest osdmap in ceph_monc_blacklist_add() and thus using the post-blacklist epoch for all post-blacklist requests ensures that all such requests "wait" for the blacklist to come into force on their respective OSDs. Cc: stable@vger.kernel.org Fixes: 6305a3b41515 ("libceph: support for blacklisting clients") Signed-off-by: Ilya Dryomov <idryomov@gmail.com> Reviewed-by: Jason Dillaman <dillaman@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2019-03-23KVM: Call kvm_arch_memslots_updated() before updating memslotsSean Christopherson
commit 152482580a1b0accb60676063a1ac57b2d12daf6 upstream. kvm_arch_memslots_updated() is at this point in time an x86-specific hook for handling MMIO generation wraparound. x86 stashes 19 bits of the memslots generation number in its MMIO sptes in order to avoid full page fault walks for repeat faults on emulated MMIO addresses. Because only 19 bits are used, wrapping the MMIO generation number is possible, if unlikely. kvm_arch_memslots_updated() alerts x86 that the generation has changed so that it can invalidate all MMIO sptes in case the effective MMIO generation has wrapped so as to avoid using a stale spte, e.g. a (very) old spte that was created with generation==0. Given that the purpose of kvm_arch_memslots_updated() is to prevent consuming stale entries, it needs to be called before the new generation is propagated to memslots. Invalidating the MMIO sptes after updating memslots means that there is a window where a vCPU could dereference the new memslots generation, e.g. 0, and incorrectly reuse an old MMIO spte that was created with (pre-wrap) generation==0. Fixes: e59dbe09f8e6 ("KVM: Introduce kvm_arch_memslots_updated()") Cc: <stable@vger.kernel.org> Signed-off-by: Sean Christopherson <sean.j.christopherson@intel.com> Signed-off-by: Paolo Bonzini <pbonzini@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2019-03-23dm: fix to_sector() for 32bitNeilBrown
commit 0bdb50c531f7377a9da80d3ce2d61f389c84cb30 upstream. A dm-raid array with devices larger than 4GB won't assemble on a 32 bit host since _check_data_dev_sectors() was added in 4.16. This is because to_sector() treats its argument as an "unsigned long" which is 32bits (4GB) on a 32bit host. Using "unsigned long long" is more correct. Kernels as early as 4.2 can have other problems due to to_sector() being used on the size of a device. Fixes: 0cf4503174c1 ("dm raid: add support for the MD RAID0 personality") cc: stable@vger.kernel.org (v4.2+) Reported-and-tested-by: Guillaume Perréal <gperreal@free.fr> Signed-off-by: NeilBrown <neil@brown.name> Signed-off-by: Mike Snitzer <snitzer@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2019-03-23arm64: Fix HCR.TGE status for NMI contextsJulien Thierry
commit 5870970b9a828d8693aa6d15742573289d7dbcd0 upstream. When using VHE, the host needs to clear HCR_EL2.TGE bit in order to interact with guest TLBs, switching from EL2&0 translation regime to EL1&0. However, some non-maskable asynchronous event could happen while TGE is cleared like SDEI. Because of this address translation operations relying on EL2&0 translation regime could fail (tlb invalidation, userspace access, ...). Fix this by properly setting HCR_EL2.TGE when entering NMI context and clear it if necessary when returning to the interrupted context. Signed-off-by: Julien Thierry <julien.thierry@arm.com> Suggested-by: Marc Zyngier <marc.zyngier@arm.com> Reviewed-by: Marc Zyngier <marc.zyngier@arm.com> Reviewed-by: James Morse <james.morse@arm.com> Cc: Arnd Bergmann <arnd@arndb.de> Cc: Will Deacon <will.deacon@arm.com> Cc: Marc Zyngier <marc.zyngier@arm.com> Cc: James Morse <james.morse@arm.com> Cc: linux-arch@vger.kernel.org Cc: stable@vger.kernel.org Signed-off-by: Catalin Marinas <catalin.marinas@arm.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2019-03-23swiotlb: Add is_swiotlb_active() functionJoerg Roedel
commit 492366f7b4237257ef50ca9c431a6a0d50225aca upstream. This function will be used from dma_direct code to determine the maximum segment size of a dma mapping. Cc: stable@vger.kernel.org Reviewed-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com> Reviewed-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Joerg Roedel <jroedel@suse.de> Signed-off-by: Michael S. Tsirkin <mst@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2019-03-23swiotlb: Introduce swiotlb_max_mapping_size()Joerg Roedel
commit abe420bfae528c92bd8cc5ecb62dc95672b1fd6f upstream. The function returns the maximum size that can be remapped by the SWIOTLB implementation. This function will be later exposed to users through the DMA-API. Cc: stable@vger.kernel.org Reviewed-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com> Reviewed-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Joerg Roedel <jroedel@suse.de> Signed-off-by: Michael S. Tsirkin <mst@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2019-03-23dma: Introduce dma_max_mapping_size()Joerg Roedel
commit 133d624b1cee16906134e92d5befb843b58bcf31 upstream. The function returns the maximum size that can be mapped using DMA-API functions. The patch also adds the implementation for direct DMA and a new dma_map_ops pointer so that other implementations can expose their limit. Cc: stable@vger.kernel.org Reviewed-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com> Reviewed-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Joerg Roedel <jroedel@suse.de> Signed-off-by: Michael S. Tsirkin <mst@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2019-03-23device property: Fix the length used in PROPERTY_ENTRY_STRING()Heikki Krogerus
commit 2b6e492467c78183bb629bb0a100ea3509b615a5 upstream. With string type property entries we need to use sizeof(const char *) instead of the number of characters as the length of the entry. If the string was shorter then sizeof(const char *), attempts to read it would have failed with -EOVERFLOW. The problem has been hidden because all build-in string properties have had a string longer then 8 characters until now. Fixes: a85f42047533 ("device property: helper macros for property entry creation") Cc: 4.5+ <stable@vger.kernel.org> # 4.5+ Signed-off-by: Heikki Krogerus <heikki.krogerus@linux.intel.com> Reviewed-by: Andy Shevchenko <andriy.shevchenko@linux.intel.com> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2019-03-23splice: don't merge into linked buffersJann Horn
commit a0ce2f0aa6ad97c3d4927bf2ca54bcebdf062d55 upstream. Before this patch, it was possible for two pipes to affect each other after data had been transferred between them with tee(): ============ $ cat tee_test.c int main(void) { int pipe_a[2]; if (pipe(pipe_a)) err(1, "pipe"); int pipe_b[2]; if (pipe(pipe_b)) err(1, "pipe"); if (write(pipe_a[1], "abcd", 4) != 4) err(1, "write"); if (tee(pipe_a[0], pipe_b[1], 2, 0) != 2) err(1, "tee"); if (write(pipe_b[1], "xx", 2) != 2) err(1, "write"); char buf[5]; if (read(pipe_a[0], buf, 4) != 4) err(1, "read"); buf[4] = 0; printf("got back: '%s'\n", buf); } $ gcc -o tee_test tee_test.c $ ./tee_test got back: 'abxx' $ ============ As suggested by Al Viro, fix it by creating a separate type for non-mergeable pipe buffers, then changing the types of buffers in splice_pipe_to_pipe() and link_pipe(). Cc: <stable@vger.kernel.org> Fixes: 7c77f0b3f920 ("splice: implement pipe to pipe splicing") Fixes: 70524490ee2e ("[PATCH] splice: add support for sys_tee()") Suggested-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Jann Horn <jannh@google.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2019-03-10cpufreq: Use struct kobj_attribute instead of struct global_attrViresh Kumar
commit 625c85a62cb7d3c79f6e16de3cfa972033658250 upstream. The cpufreq_global_kobject is created using kobject_create_and_add() helper, which assigns the kobj_type as dynamic_kobj_ktype and show/store routines are set to kobj_attr_show() and kobj_attr_store(). These routines pass struct kobj_attribute as an argument to the show/store callbacks. But all the cpufreq files created using the cpufreq_global_kobject expect the argument to be of type struct attribute. Things work fine currently as no one accesses the "attr" argument. We may not see issues even if the argument is used, as struct kobj_attribute has struct attribute as its first element and so they will both get same address. But this is logically incorrect and we should rather use struct kobj_attribute instead of struct global_attr in the cpufreq core and drivers and the show/store callbacks should take struct kobj_attribute as argument instead. This bug is caught using CFI CLANG builds in android kernel which catches mismatch in function prototypes for such callbacks. Reported-by: Donghee Han <dh.han@samsung.com> Reported-by: Sangkyu Kim <skwith.kim@samsung.com> Signed-off-by: Viresh Kumar <viresh.kumar@linaro.org> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2019-03-02Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/netLinus Torvalds
Pull networking fixes from David Miller: 1) Fix refcount leak in act_ipt during replace, from Davide Caratti. 2) Set task state properly in tun during blocking reads, from Timur Celik. 3) Leaked reference in DSA, from Wen Yang. 4) NULL deref in act_tunnel_key, from Vlad Buslov. 5) cipso_v4_erro can reference the skb IPCB in inappropriate contexts thus referencing garbage, from Nazarov Sergey. 6) Don't accept RTA_VIA and RTA_GATEWAY in contexts where those attributes make no sense. 7) Fix hung sendto in tipc, from Tung Nguyen. 8) Out-of-bounds access in netlabel, from Paul Moore. 9) Grant reference leak in xen-netback, from Igor Druzhinin. 10) Fix tx stalls with lan743x, from Bryan Whitehead. 11) Fix interrupt storm with mv88e6xxx, from Hein Kallweit. 12) Memory leak in sit on device registry failure, from Mao Wenan. * git://git.kernel.org/pub/scm/linux/kernel/git/davem/net: (44 commits) net: sit: fix memory leak in sit_init_net() net: dsa: mv88e6xxx: Fix statistics on mv88e6161 geneve: correctly handle ipv6.disable module parameter net: dsa: mv88e6xxx: prevent interrupt storm caused by mv88e6390x_port_set_cmode bpf: fix sanitation rewrite in case of non-pointers ipv4: Add ICMPv6 support when parse route ipproto MIPS: eBPF: Fix icache flush end address lan743x: Fix TX Stall Issue net: phy: phylink: fix uninitialized variable in phylink_get_mac_state net: aquantia: regression on cpus with high cores: set mode with 8 queues selftests: fixes for UDP GRO bpf: drop refcount if bpf_map_new_fd() fails in map_create() net: dsa: mv88e6xxx: power serdes on/off for 10G interfaces on 6390X net: dsa: mv88e6xxx: Fix u64 statistics xen-netback: don't populate the hash cache on XenBus disconnect xen-netback: fix occasional leak of grant ref mappings under memory pressure sctp: chunk.c: correct format string for size_t in printk net: netem: fix skb length BUG_ON in __skb_to_sgvec netlabel: fix out-of-bounds memory accesses ipv4: Pass original device to ip_rcv_finish_core ...
2019-02-27net: dev: Use unsigned integer as an argument to left-shiftAndy Shevchenko
1 << 31 is Undefined Behaviour according to the C standard. Use U type modifier to avoid theoretical overflow. Signed-off-by: Andy Shevchenko <andriy.shevchenko@linux.intel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2019-02-25Revert "x86/fault: BUG() when uaccess helpers fault on kernel addresses"Linus Torvalds
This reverts commit 9da3f2b74054406f87dff7101a569217ffceb29b. It was well-intentioned, but wrong. Overriding the exception tables for instructions for random reasons is just wrong, and that is what the new code did. It caused problems for tracing, and it caused problems for strncpy_from_user(), because the new checks made perfectly valid use cases break, rather than catch things that did bad things. Unchecked user space accesses are a problem, but that's not a reason to add invalid checks that then people have to work around with silly flags (in this case, that 'kernel_uaccess_faults_ok' flag, which is just an odd way to say "this commit was wrong" and was sprinked into random places to hide the wrongness). The real fix to unchecked user space accesses is to get rid of the special "let's not check __get_user() and __put_user() at all" logic. Make __{get|put}_user() be just aliases to the regular {get|put}_user() functions, and make it impossible to access user space without having the proper checks in places. The raison d'être of the special double-underscore versions used to be that the range check was expensive, and if you did multiple user accesses, you'd do the range check up front (like the signal frame handling code, for example). But SMAP (on x86) and PAN (on ARM) have made that optimization pointless, because the _real_ expense is the "set CPU flag to allow user space access". Do let's not break the valid cases to catch invalid cases that shouldn't even exist. Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Kees Cook <keescook@chromium.org> Cc: Tobin C. Harding <tobin@kernel.org> Cc: Borislav Petkov <bp@alien8.de> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Andy Lutomirski <luto@kernel.org> Cc: Jann Horn <jannh@google.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2019-02-24Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/netLinus Torvalds
Pull networking fixes from David Miller: "Hopefully the last pull request for this release. Fingers crossed: 1) Only refcount ESP stats on full sockets, from Martin Willi. 2) Missing barriers in AF_UNIX, from Al Viro. 3) RCU protection fixes in ipv6 route code, from Paolo Abeni. 4) Avoid false positives in untrusted GSO validation, from Willem de Bruijn. 5) Forwarded mesh packets in mac80211 need more tailroom allocated, from Felix Fietkau. 6) Use operstate consistently for linkup in team driver, from George Wilkie. 7) ThunderX bug fixes from Vadim Lomovtsev. Mostly races between VF and PF code paths. 8) Purge ipv6 exceptions during netdevice removal, from Paolo Abeni. 9) nfp eBPF code gen fixes from Jiong Wang. 10) bnxt_en firmware timeout fix from Michael Chan. 11) Use after free in udp/udpv6 error handlers, from Paolo Abeni. 12) Fix a race in x25_bind triggerable by syzbot, from Eric Dumazet" * git://git.kernel.org/pub/scm/linux/kernel/git/davem/net: (65 commits) net: phy: realtek: Dummy IRQ calls for RTL8366RB tcp: repaired skbs must init their tso_segs net/x25: fix a race in x25_bind() net: dsa: Remove documentation for port_fdb_prepare Revert "bridge: do not add port to router list when receives query with source 0.0.0.0" selftests: fib_tests: sleep after changing carrier. again. net: set static variable an initial value in atl2_probe() net: phy: marvell10g: Fix Multi-G advertisement to only advertise 10G bpf, doc: add bpf list as secondary entry to maintainers file udp: fix possible user after free in error handler udpv6: fix possible user after free in error handler fou6: fix proto error handler argument type udpv6: add the required annotation to mib type mdio_bus: Fix use-after-free on device_register fails net: Set rtm_table to RT_TABLE_COMPAT for ipv6 for tables > 255 bnxt_en: Wait longer for the firmware message response to complete. bnxt_en: Fix typo in firmware message timeout logic. nfp: bpf: fix ALU32 high bits clearance bug nfp: bpf: fix code-gen bug on BPF_ALU | BPF_XOR | BPF_K Documentation: networking: switchdev: Update port parent ID section ...
2019-02-23net: phy: realtek: Dummy IRQ calls for RTL8366RBLinus Walleij
This fixes a regression introduced by commit 0d2e778e38e0ddffab4bb2b0e9ed2ad5165c4bf7 "net: phy: replace PHY_HAS_INTERRUPT with a check for config_intr and ack_interrupt". This assumes that a PHY cannot trigger interrupt unless it has .config_intr() or .ack_interrupt() implemented. A later patch makes the code assume both need to be implemented for interrupts to be present. But this PHY (which is inside a DSA) will happily fire interrupts without either callback. Implement dummy callbacks for .config_intr() and .ack_interrupt() in the phy header to fix this. Tested on the RTL8366RB on D-Link DIR-685. Fixes: 0d2e778e38e0 ("net: phy: replace PHY_HAS_INTERRUPT with a check for config_intr and ack_interrupt") Cc: Heiner Kallweit <hkallweit1@gmail.com> Signed-off-by: Linus Walleij <linus.walleij@linaro.org> Reviewed-by: Andrew Lunn <andrew@lunn.ch> Signed-off-by: David S. Miller <davem@davemloft.net>
2019-02-21net: avoid false positives in untrusted gso validationWillem de Bruijn
GSO packets with vnet_hdr must conform to a small set of gso_types. The below commit uses flow dissection to drop packets that do not. But it has false positives when the skb is not fully initialized. Dissection needs skb->protocol and skb->network_header. Infer skb->protocol from gso_type as the two must agree. SKB_GSO_UDP can use both ipv4 and ipv6, so try both. Exclude callers for which network header offset is not known. Fixes: d5be7f632bad ("net: validate untrusted gso packets without csum offload") Signed-off-by: Willem de Bruijn <willemb@google.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2019-02-20Merge branch 'fixes-v5.1-rc6' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jmorris/linux-security Pull keys fixes from James Morris: - Handle quotas better, allowing full quota to be reached. - Fix the creation of shortcuts in the assoc_array internal representation when the index key needs to be an exact multiple of the machine word size. - Fix a dependency loop between the request_key contruction record and the request_key authentication key. The construction record isn't really necessary and can be dispensed with. - Set the timestamp on a new key rather than leaving it as 0. This would ordinarily be fine - provided the system clock is never set to a time before 1970 * 'fixes-v5.1-rc6' of git://git.kernel.org/pub/scm/linux/kernel/git/jmorris/linux-security: keys: Timestamp new keys keys: Fix dependency loop between construction record and auth key assoc_array: Fix shortcut creation KEYS: allow reaching the keys quotas exactly
2019-02-19Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/netLinus Torvalds
Pull networking fixes from David Miller: 1) Fix suspend and resume in mt76x0u USB driver, from Stanislaw Gruszka. 2) Missing memory barriers in xsk, from Magnus Karlsson. 3) rhashtable fixes in mac80211 from Herbert Xu. 4) 32-bit MIPS eBPF JIT fixes from Paul Burton. 5) Fix for_each_netdev_feature() on big endian, from Hauke Mehrtens. 6) GSO validation fixes from Willem de Bruijn. 7) Endianness fix for dwmac4 timestamp handling, from Alexandre Torgue. 8) More strict checks in tcp_v4_err(), from Eric Dumazet. 9) af_alg_release should NULL out the sk after the sock_put(), from Mao Wenan. 10) Missing unlock in mac80211 mesh error path, from Wei Yongjun. 11) Missing device put in hns driver, from Salil Mehta. * git://git.kernel.org/pub/scm/linux/kernel/git/davem/net: (44 commits) sky2: Increase D3 delay again vhost: correctly check the return value of translate_desc() in log_used() net: netcp: Fix ethss driver probe issue net: hns: Fixes the missing put_device in positive leg for roce reset net: stmmac: Fix a race in EEE enable callback qed: Fix iWARP syn packet mac address validation. qed: Fix iWARP buffer size provided for syn packet processing. r8152: Add support for MAC address pass through on RTL8153-BD mac80211: mesh: fix missing unlock on error in table_path_del() net/mlx4_en: fix spelling mistake: "quiting" -> "quitting" net: crypto set sk to NULL when af_alg_release. net: Do not allocate page fragments that are not skb aligned mm: Use fixed constant in page_frag_alloc instead of size + 1 tcp: tcp_v4_err() should be more careful tcp: clear icsk_backoff in tcp_write_queue_purge() net: mv643xx_eth: disable clk on error path in mv643xx_eth_shared_probe() qmi_wwan: apply SET_DTR quirk to Sierra WP7607 net: stmmac: handle endianness in dwmac4_get_timestamp doc: Mention MSG_ZEROCOPY implementation for UDP mlxsw: __mlxsw_sp_port_headroom_set(): Fix a use of local variable ...
2019-02-17Merge branch 'efi-urgent-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull EFI fixes from Ingo Molnar: "This tree reverts a GICv3 commit (which was broken) and fixes it in another way, by adding a memblock build-time entries quirk for ARM64" * 'efi-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: efi/arm: Revert "Defer persistent reservations until after paging_init()" arm64, mm, efi: Account for GICv3 LPI tables in static memblock reserve table
2019-02-17Merge branch 'perf-urgent-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull perf fixes from Ingo Molnar: "Two fixes on the kernel side: fix an over-eager condition that failed larger perf ring-buffer sizes, plus fix crashes in the Intel BTS code for a corner case, found by fuzzing" * 'perf-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: perf/core: Fix impossible ring-buffer sizes warning perf/x86: Add check_period PMU callback
2019-02-16Merge git://git.kernel.org/pub/scm/linux/kernel/git/bpf/bpfDavid S. Miller
Alexei Starovoitov says: ==================== pull-request: bpf 2019-02-16 The following pull-request contains BPF updates for your *net* tree. The main changes are: 1) fix lockdep false positive in bpf_get_stackid(), from Alexei. 2) several AF_XDP fixes, from Bjorn, Magnus, Davidlohr. 3) fix narrow load from struct bpf_sock, from Martin. 4) mips JIT fixes, from Paul. 5) gso handling fix in bpf helpers, from Willem. ==================== Signed-off-by: David S. Miller <davem@davemloft.net>
2019-02-16net: Add header for usage of fls64()David S. Miller
Fixes: 3b89ea9c5902 ("net: Fix for_each_netdev_feature on Big endian") Suggested-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2019-02-16Merge tag 'compiler-attributes-for-linus-v5.0-rc7' of ↵Linus Torvalds
git://github.com/ojeda/linux Pull compiler attributes fixes from Miguel Ojeda: "Clean the new GCC 9 -Wmissing-attributes warnings The upcoming GCC 9 release extends the -Wmissing-attributes warnings (enabled by -Wall) to C and aliases: it warns when particular function attributes are missing in the aliases but not in their target, e.g.: void __cold f(void) {} void __alias("f") g(void); diagnoses: warning: 'g' specifies less restrictive attribute than its target 'f': 'cold' [-Wmissing-attributes] These patch series clean these new warnings. Most of them are caused by the module_init/exit macros" Link: https://lore.kernel.org/lkml/20190125104353.2791-1-labbott@redhat.com/ * tag 'compiler-attributes-for-linus-v5.0-rc7' of git://github.com/ojeda/linux: include/linux/module.h: copy __init/__exit attrs to init/cleanup_module Compiler Attributes: add support for __copy (gcc >= 9) lib/crc32.c: mark crc32_le_base/__crc32c_le_base aliases as __pure
2019-02-16efi/arm: Revert "Defer persistent reservations until after paging_init()"Ard Biesheuvel
This reverts commit eff896288872d687d9662000ec9ae11b6d61766f, which deferred the processing of persistent memory reservations to a point where the memory may have already been allocated and overwritten, defeating the purpose. Signed-off-by: Ard Biesheuvel <ard.biesheuvel@linaro.org> Acked-by: Will Deacon <will.deacon@arm.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Marc Zyngier <marc.zyngier@arm.com> Cc: Mike Rapoport <rppt@linux.ibm.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: linux-arm-kernel@lists.infradead.org Cc: linux-efi@vger.kernel.org Link: http://lkml.kernel.org/r/20190215123333.21209-3-ard.biesheuvel@linaro.org Signed-off-by: Ingo Molnar <mingo@kernel.org>
2019-02-16arm64, mm, efi: Account for GICv3 LPI tables in static memblock reserve tableArd Biesheuvel
In the irqchip and EFI code, we have what basically amounts to a quirk to work around a peculiarity in the GICv3 architecture, which permits the system memory address of LPI tables to be programmable only once after a CPU reset. This means kexec kernels must use the same memory as the first kernel, and thus ensure that this memory has not been given out for other purposes by the time the ITS init code runs, which is not very early for secondary CPUs. On systems with many CPUs, these reservations could overflow the memblock reservation table, and this was addressed in commit: eff896288872 ("efi/arm: Defer persistent reservations until after paging_init()") However, this turns out to have made things worse, since the allocation of page tables and heap space for the resized memblock reservation table itself may overwrite the regions we are attempting to reserve, which may cause all kinds of corruption, also considering that the ITS will still be poking bits into that memory in response to incoming MSIs. So instead, let's grow the static memblock reservation table on such systems so it can accommodate these reservations at an earlier time. This will permit us to revert the above commit in a subsequent patch. [ mingo: Minor cleanups. ] Signed-off-by: Ard Biesheuvel <ard.biesheuvel@linaro.org> Acked-by: Mike Rapoport <rppt@linux.ibm.com> Acked-by: Will Deacon <will.deacon@arm.com> Acked-by: Marc Zyngier <marc.zyngier@arm.com> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: linux-arm-kernel@lists.infradead.org Cc: linux-efi@vger.kernel.org Link: http://lkml.kernel.org/r/20190215123333.21209-2-ard.biesheuvel@linaro.org Signed-off-by: Ingo Molnar <mingo@kernel.org>
2019-02-15net: validate untrusted gso packets without csum offloadWillem de Bruijn
Syzkaller again found a path to a kernel crash through bad gso input. By building an excessively large packet to cause an skb field to wrap. If VIRTIO_NET_HDR_F_NEEDS_CSUM was set this would have been dropped in skb_partial_csum_set. GSO packets that do not set checksum offload are suspicious and rare. Most callers of virtio_net_hdr_to_skb already pass them to skb_probe_transport_header. Move that test forward, change it to detect parse failure and drop packets on failure as those cleary are not one of the legitimate VIRTIO_NET_HDR_GSO types. Fixes: bfd5f4a3d605 ("packet: Add GSO/csum offload support.") Fixes: f43798c27684 ("tun: Allow GSO using virtio_net_hdr") Reported-by: syzbot <syzkaller@googlegroups.com> Signed-off-by: Willem de Bruijn <willemb@google.com> Reviewed-by: Eric Dumazet <edumazet@google.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2019-02-15net: Fix for_each_netdev_feature on Big endianHauke Mehrtens
The features attribute is of type u64 and stored in the native endianes on the system. The for_each_set_bit() macro takes a pointer to a 32 bit array and goes over the bits in this area. On little Endian systems this also works with an u64 as the most significant bit is on the highest address, but on big endian the words are swapped. When we expect bit 15 here we get bit 47 (15 + 32). This patch converts it more or less to its own for_each_set_bit() implementation which works on 64 bit integers directly. This is then completely in host endianness and should work like expected. Fixes: fd867d51f ("net/core: generic support for disabling netdev features down stack") Signed-off-by: Hauke Mehrtens <hauke.mehrtens@intel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2019-02-15keys: Fix dependency loop between construction record and auth keyDavid Howells
In the request_key() upcall mechanism there's a dependency loop by which if a key type driver overrides the ->request_key hook and the userspace side manages to lose the authorisation key, the auth key and the internal construction record (struct key_construction) can keep each other pinned. Fix this by the following changes: (1) Killing off the construction record and using the auth key instead. (2) Including the operation name in the auth key payload and making the payload available outside of security/keys/. (3) The ->request_key hook is given the authkey instead of the cons record and operation name. Changes (2) and (3) allow the auth key to naturally be cleaned up if the keyring it is in is destroyed or cleared or the auth key is unlinked. Fixes: 7ee02a316600 ("keys: Fix dependency loop between construction record and auth key") Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: James Morris <james.morris@microsoft.com>
2019-02-15include/linux/module.h: copy __init/__exit attrs to init/cleanup_moduleMiguel Ojeda
The upcoming GCC 9 release extends the -Wmissing-attributes warnings (enabled by -Wall) to C and aliases: it warns when particular function attributes are missing in the aliases but not in their target. In particular, it triggers for all the init/cleanup_module aliases in the kernel (defined by the module_init/exit macros), ending up being very noisy. These aliases point to the __init/__exit functions of a module, which are defined as __cold (among other attributes). However, the aliases themselves do not have the __cold attribute. Since the compiler behaves differently when compiling a __cold function as well as when compiling paths leading to calls to __cold functions, the warning is trying to point out the possibly-forgotten attribute in the alias. In order to keep the warning enabled, we decided to silence this case. Ideally, we would mark the aliases directly as __init/__exit. However, there are currently around 132 modules in the kernel which are missing __init/__exit in their init/cleanup functions (either because they are missing, or for other reasons, e.g. the functions being called from somewhere else); and a section mismatch is a hard error. A conservative alternative was to mark the aliases as __cold only. However, since we would like to eventually enforce __init/__exit to be always marked, we chose to use the new __copy function attribute (introduced by GCC 9 as well to deal with this). With it, we copy the attributes used by the target functions into the aliases. This way, functions that were not marked as __init/__exit won't have their aliases marked either, and therefore there won't be a section mismatch. Note that the warning would go away marking either the extern declaration, the definition, or both. However, we only mark the definition of the alias, since we do not want callers (which only see the declaration) to be compiled as if the function was __cold (and therefore the paths leading to those calls would be assumed to be unlikely). Link: https://lore.kernel.org/lkml/20190123173707.GA16603@gmail.com/ Link: https://lore.kernel.org/lkml/20190206175627.GA20399@gmail.com/ Suggested-by: Martin Sebor <msebor@gcc.gnu.org> Acked-by: Jessica Yu <jeyu@kernel.org> Signed-off-by: Miguel Ojeda <miguel.ojeda.sandonis@gmail.com>
2019-02-15Compiler Attributes: add support for __copy (gcc >= 9)Miguel Ojeda
From the GCC manual: copy copy(function) The copy attribute applies the set of attributes with which function has been declared to the declaration of the function to which the attribute is applied. The attribute is designed for libraries that define aliases or function resolvers that are expected to specify the same set of attributes as their targets. The copy attribute can be used with functions, variables, or types. However, the kind of symbol to which the attribute is applied (either function or variable) must match the kind of symbol to which the argument refers. The copy attribute copies only syntactic and semantic attributes but not attributes that affect a symbol’s linkage or visibility such as alias, visibility, or weak. The deprecated attribute is also not copied. https://gcc.gnu.org/onlinedocs/gcc/Common-Function-Attributes.html The upcoming GCC 9 release extends the -Wmissing-attributes warnings (enabled by -Wall) to C and aliases: it warns when particular function attributes are missing in the aliases but not in their target, e.g.: void __cold f(void) {} void __alias("f") g(void); diagnoses: warning: 'g' specifies less restrictive attribute than its target 'f': 'cold' [-Wmissing-attributes] Using __copy(f) we can copy the __cold attribute from f to g: void __cold f(void) {} void __copy(f) __alias("f") g(void); This attribute is most useful to deal with situations where an alias is declared but we don't know the exact attributes the target has. For instance, in the kernel, the widely used module_init/exit macros define the init/cleanup_module aliases, but those cannot be marked always as __init/__exit since some modules do not have their functions marked as such. Suggested-by: Martin Sebor <msebor@gcc.gnu.org> Reviewed-by: Nick Desaulniers <ndesaulniers@google.com> Signed-off-by: Miguel Ojeda <miguel.ojeda.sandonis@gmail.com>
2019-02-15Merge tag 'mmc-v5.0-rc5' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/ulfh/mmc Pull MMC fixes from Ulf Hansson: "A couple of MMC fixes intended for v5.0-rc7. MMC core: - Fix deadlock bug for block I/O requests MMC host: - sunxi: Disable broken HS-DDR mode for H5 by default - sunxi: Avoid unsupported speed modes declared via DT - meson-gx: Restore interrupt name" * tag 'mmc-v5.0-rc5' of git://git.kernel.org/pub/scm/linux/kernel/git/ulfh/mmc: mmc: meson-gx: fix interrupt name mmc: block: handle complete_work on separate workqueue mmc: sunxi: Filter out unsupported modes declared in the device tree mmc: sunxi: Disable HS-DDR mode for H5 eMMC controller by default
2019-02-15Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/netLinus Torvalds
Pull networking fixes from David Miller: 1) Fix MAC address setting in mac80211 pmsr code, from Johannes Berg. 2) Probe SFP modules after being attached, from Russell King. 3) Byte ordering bug in SMC rx_curs_confirmed code, from Ursula Braun. 4) Revert some r8169 changes that are causing regressions, from Heiner Kallweit. 5) Fix spurious connection timeouts in netfilter nat code, from Florian Westphal. 6) SKB leak in tipc, from Hoang Le. 7) Short packet checkum issue in mlx4, similar to a previous mlx5 change, from Saeed Mahameed. The issue is that whilst padding bytes are usually zero, it is not guarateed and the hardware doesn't take the padding bytes into consideration when generating the checksum. 8) Fix various races in cls_tcindex, from Cong Wang. 9) Need to set stream ext to NULL before freeing in SCTP code, from Xin Long. 10) Fix locking in phy_is_started, from Heiner Kallweit. * git://git.kernel.org/pub/scm/linux/kernel/git/davem/net: (54 commits) net: ethernet: freescale: set FEC ethtool regs version net: hns: Fix object reference leaks in hns_dsaf_roce_reset() mm: page_alloc: fix ref bias in page_frag_alloc() for 1-byte allocs net: phy: fix potential race in the phylib state machine net: phy: don't use locking in phy_is_started selftests: fix timestamping Makefile net: dsa: bcm_sf2: potential array overflow in bcm_sf2_sw_suspend() net: fix possible overflow in __sk_mem_raise_allocated() dsa: mv88e6xxx: Ensure all pending interrupts are handled prior to exit net: phy: fix interrupt handling in non-started states sctp: set stream ext to NULL after freeing it in sctp_stream_outq_migrate sctp: call gso_reset_checksum when computing checksum in sctp_gso_segment net/mlx5e: XDP, fix redirect resources availability check net/mlx5: Fix a compilation warning in events.c net/mlx5: No command allowed when command interface is not ready net/mlx5e: Fix NULL pointer derefernce in set channels error flow netfilter: nft_compat: use-after-free when deleting targets team: avoid complex list operations in team_nl_cmd_options_set() net_sched: fix two more memory leaks in cls_tcindex net_sched: fix a memory leak in cls_tcindex ...
2019-02-14net: phy: don't use locking in phy_is_startedHeiner Kallweit
Russell suggested to remove the locking from phy_is_started() because the read is atomic anyway and actually the locking may be more misleading. Fixes: 2b3e88ea6528 ("net: phy: improve phy state checking") Suggested-by: Russell King - ARM Linux admin <linux@armlinux.org.uk> Signed-off-by: Heiner Kallweit <hkallweit1@gmail.com> Reviewed-by: Florian Fainelli <f.fainelli@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2019-02-11perf/x86: Add check_period PMU callbackJiri Olsa
Vince (and later on Ravi) reported crashes in the BTS code during fuzzing with the following backtrace: general protection fault: 0000 [#1] SMP PTI ... RIP: 0010:perf_prepare_sample+0x8f/0x510 ... Call Trace: <IRQ> ? intel_pmu_drain_bts_buffer+0x194/0x230 intel_pmu_drain_bts_buffer+0x160/0x230 ? tick_nohz_irq_exit+0x31/0x40 ? smp_call_function_single_interrupt+0x48/0xe0 ? call_function_single_interrupt+0xf/0x20 ? call_function_single_interrupt+0xa/0x20 ? x86_schedule_events+0x1a0/0x2f0 ? x86_pmu_commit_txn+0xb4/0x100 ? find_busiest_group+0x47/0x5d0 ? perf_event_set_state.part.42+0x12/0x50 ? perf_mux_hrtimer_restart+0x40/0xb0 intel_pmu_disable_event+0xae/0x100 ? intel_pmu_disable_event+0xae/0x100 x86_pmu_stop+0x7a/0xb0 x86_pmu_del+0x57/0x120 event_sched_out.isra.101+0x83/0x180 group_sched_out.part.103+0x57/0xe0 ctx_sched_out+0x188/0x240 ctx_resched+0xa8/0xd0 __perf_event_enable+0x193/0x1e0 event_function+0x8e/0xc0 remote_function+0x41/0x50 flush_smp_call_function_queue+0x68/0x100 generic_smp_call_function_single_interrupt+0x13/0x30 smp_call_function_single_interrupt+0x3e/0xe0 call_function_single_interrupt+0xf/0x20 </IRQ> The reason is that while event init code does several checks for BTS events and prevents several unwanted config bits for BTS event (like precise_ip), the PERF_EVENT_IOC_PERIOD allows to create BTS event without those checks being done. Following sequence will cause the crash: If we create an 'almost' BTS event with precise_ip and callchains, and it into a BTS event it will crash the perf_prepare_sample() function because precise_ip events are expected to come in with callchain data initialized, but that's not the case for intel_pmu_drain_bts_buffer() caller. Adding a check_period callback to be called before the period is changed via PERF_EVENT_IOC_PERIOD. It will deny the change if the event would become BTS. Plus adding also the limit_period check as well. Reported-by: Vince Weaver <vincent.weaver@maine.edu> Signed-off-by: Jiri Olsa <jolsa@kernel.org> Acked-by: Peter Zijlstra <peterz@infradead.org> Cc: <stable@vger.kernel.org> Cc: Alexander Shishkin <alexander.shishkin@linux.intel.com> Cc: Arnaldo Carvalho de Melo <acme@kernel.org> Cc: Arnaldo Carvalho de Melo <acme@redhat.com> Cc: Jiri Olsa <jolsa@redhat.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Naveen N. Rao <naveen.n.rao@linux.vnet.ibm.com> Cc: Ravi Bangoria <ravi.bangoria@linux.ibm.com> Cc: Stephane Eranian <eranian@google.com> Cc: Thomas Gleixner <tglx@linutronix.de> Link: http://lkml.kernel.org/r/20190204123532.GA4794@krava Signed-off-by: Ingo Molnar <mingo@kernel.org>
2019-02-10bpf: only adjust gso_size on bytestream protocolsWillem de Bruijn
bpf_skb_change_proto and bpf_skb_adjust_room change skb header length. For GSO packets they adjust gso_size to maintain the same MTU. The gso size can only be safely adjusted on bytestream protocols. Commit d02f51cbcf12 ("bpf: fix bpf_skb_adjust_net/bpf_skb_proto_xlat to deal with gso sctp skbs") excluded SKB_GSO_SCTP. Since then type SKB_GSO_UDP_L4 has been added, whose contents are one gso_size unit per datagram. Also exclude these. Move from a blacklist to a whitelist check to future proof against additional such new GSO types, e.g., for fraglist based GRO. Fixes: bec1f6f69736 ("udp: generate gso with UDP_SEGMENT") Signed-off-by: Willem de Bruijn <willemb@google.com> Signed-off-by: Alexei Starovoitov <ast@kernel.org>
2019-02-10Merge branch 'irq-urgent-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull irq fixes from Ingo Molnar: "irqchip driver fixes: most of them are race fixes for ARM GIC (General Interrupt Controller) variants, but also a fix for the ARM MMP (Marvell PXA168 et al) irqchip affecting OLPC keyboards" * 'irq-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: irqchip/gic-v3-its: Fix ITT_entry_size accessor irqchip/mmp: Only touch the PJ4 IRQ & FIQ bits on enable/disable irqchip/gic-v3-its: Gracefully fail on LPI exhaustion irqchip/gic-v3-its: Plug allocation race for devices sharing a DevID irqchip/gic-v4: Fix occasional VLPI drop
2019-02-09Merge tag 'for-linus-20190209' of git://git.kernel.dk/linux-blockLinus Torvalds
Pull block fixes from Jens Axboe: - NVMe pull request from Christoph, fixing namespace locking when dealing with the effects log, and a rapid add/remove issue (Keith) - blktrace tweak, ensuring requests with -1 sectors are shown (Jan) - link power management quirk for a Smasung SSD (Hans) - m68k nfblock dynamic major number fix (Chengguang) - series fixing blk-iolatency inflight counter issue (Liu) - ensure that we clear ->private when setting up the aio kiocb (Mike) - __find_get_block_slow() rate limit print (Tetsuo) * tag 'for-linus-20190209' of git://git.kernel.dk/linux-block: blk-mq: remove duplicated definition of blk_mq_freeze_queue Blk-iolatency: warn on negative inflight IO counter blk-iolatency: fix IO hang due to negative inflight counter blktrace: Show requests without sector fs: ratelimit __find_get_block_slow() failure message. m68k: set proper major_num when specifying module param major_num libata: Add NOLPM quirk for SAMSUNG MZ7TE512HMHP-000L1 SSD nvme-pci: fix rapid add remove sequence nvme: lock NS list changes while handling command effects aio: initialize kiocb private in case any filesystems expect it.
2019-02-08Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/ebiederm/user-namespace Pull signal fixes from Eric Biederman: "This contains four small fixes for signal handling. A missing range check, a regression fix, prioritizing signals we have already started a signal group exit for, and better detection of synchronous signals. The confused decision of which signals to handle failed spectacularly when a timer was pointed at SIGBUS and the stack overflowed. Resulting in an unkillable process in an infinite loop instead of a SIGSEGV and core dump" * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/ebiederm/user-namespace: signal: Better detection of synchronous signals signal: Always notice exiting tasks signal: Always attempt to allocate siginfo for SIGSTOP signal: Make siginmask safe when passed a signal of 0
2019-02-08Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/netLinus Torvalds
Pull networking fixes from David Miller: "This pull request is dedicated to the upcoming snowpocalypse parts 2 and 3 in the Pacific Northwest: 1) Drop profiles are broken because some drivers use dev_kfree_skb* instead of dev_consume_skb*, from Yang Wei. 2) Fix IWLWIFI kconfig deps, from Luca Coelho. 3) Fix percpu maps updating in bpftool, from Paolo Abeni. 4) Missing station release in batman-adv, from Felix Fietkau. 5) Fix some networking compat ioctl bugs, from Johannes Berg. 6) ucc_geth must reset the BQL queue state when stopping the device, from Mathias Thore. 7) Several XDP bug fixes in virtio_net from Toshiaki Makita. 8) TSO packets must be sent always on queue 0 in stmmac, from Jose Abreu. 9) Fix socket refcounting bug in RDS, from Eric Dumazet. 10) Handle sparse cpu allocations in bpf selftests, from Martynas Pumputis. 11) Make sure mgmt frames have enough tailroom in mac80211, from Felix Feitkau. 12) Use safe list walking in sctp_sendmsg() asoc list traversal, from Greg Kroah-Hartman. 13) Make DCCP's ccid_hc_[rt]x_parse_options always check for NULL ccid, from Eric Dumazet. 14) Need to reload WoL password into bcmsysport device after deep sleeps, from Florian Fainelli. 15) Remove filter from mask before freeing in cls_flower, from Petr Machata. 16) Missing release and use after free in error paths of s390 qeth code, from Julian Wiedmann. 17) Fix lockdep false positive in dsa code, from Marc Zyngier. 18) Fix counting of ATU violations in mv88e6xxx, from Andrew Lunn. 19) Fix EQ firmware assert in qed driver, from Manish Chopra. 20) Don't default Caivum PTP to Y in kconfig, from Bjorn Helgaas" * git://git.kernel.org/pub/scm/linux/kernel/git/davem/net: (116 commits) net: dsa: b53: Fix for failure when irq is not defined in dt sit: check if IPv6 enabled before calling ip6_err_gen_icmpv6_unreach() geneve: should not call rt6_lookup() when ipv6 was disabled net: Don't default Cavium PTP driver to 'y' net: broadcom: replace dev_kfree_skb_irq by dev_consume_skb_irq for drop profiles net: via-velocity: replace dev_kfree_skb_irq by dev_consume_skb_irq for drop profiles net: tehuti: replace dev_kfree_skb_irq by dev_consume_skb_irq for drop profiles net: sun: replace dev_kfree_skb_irq by dev_consume_skb_irq for drop profiles net: fsl_ucc_hdlc: replace dev_kfree_skb_irq by dev_consume_skb_irq for drop profiles net: fec_mpc52xx: replace dev_kfree_skb_irq by dev_consume_skb_irq for drop profiles net: smsc: epic100: replace dev_kfree_skb_irq by dev_consume_skb_irq for drop profiles net: dscc4: replace dev_kfree_skb_irq by dev_consume_skb_irq for drop profiles net: tulip: de2104x: replace dev_kfree_skb_irq by dev_consume_skb_irq for drop profiles net: defxx: replace dev_kfree_skb_irq by dev_consume_skb_irq for drop profiles net/mlx5e: Don't overwrite pedit action when multiple pedit used net/mlx5e: Update hw flows when encap source mac changed qed*: Advance drivers version to 8.37.0.20 qed: Change verbosity for coalescing message. qede: Fix system crash on configuring channels. qed: Consider TX tcs while deriving the max num_queues for PF. ...
2019-02-08mmc: block: handle complete_work on separate workqueueZachary Hays
The kblockd workqueue is created with the WQ_MEM_RECLAIM flag set. This generates a rescuer thread for that queue that will trigger when the CPU is under heavy load and collect the uncompleted work. In the case of mmc, this creates the possibility of a deadlock when there are multiple partitions on the device as other blk-mq work is also run on the same queue. For example: - worker 0 claims the mmc host to work on partition 1 - worker 1 attempts to claim the host for partition 2 but has to wait for worker 0 to finish - worker 0 schedules complete_work to release the host - rescuer thread is triggered after time-out and collects the dangling work - rescuer thread attempts to complete the work in order starting with claim host - the task to release host is now blocked by a task to claim it and will never be called The above results in multiple hung tasks that lead to failures to mount partitions. Handling complete_work on a separate workqueue avoids this by keeping the work completion tasks separate from the other blk-mq work. This allows the host to be released without getting blocked by other tasks attempting to claim the host. Signed-off-by: Zachary Hays <zhays@lexmark.com> Fixes: 81196976ed94 ("mmc: block: Add blk-mq support") Cc: <stable@vger.kernel.org> Signed-off-by: Ulf Hansson <ulf.hansson@linaro.org>
2019-02-07Merge tag 'irqchip-5.0-3' of ↵Thomas Gleixner
git://git.kernel.org/pub/scm/linux/kernel/git/maz/arm-platforms into irq/urgent Pull irqchip updates from Marc Zyngier: - Another GICv3 ITS fix for devices sharing the same DevID - Don't return invalid data on exhaustion of the GICv3 LPI pool - Fix a GICv3 field decoding bug leading to memory over-allocation - Init GICv4 at boot time instead of lazy init - Fix interrupt masking on PJ4
