path: root/include/linux
2007-12-06Add wait_event_killableMatthew Wilcox
Signed-off-by: Matthew Wilcox <willy@linux.intel.com>
2007-12-06Add schedule_timeout_killableMatthew Wilcox
2007-12-06Add mutex_lock_killableLiam R. Howlett
Similar to mutex_lock_interruptible, it can be interrupted by a fatal signal only. Signed-off-by: Liam R. Howlett <howlett@gmail.com> Acked-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Matthew Wilcox <willy@linux.intel.com>
2007-12-06Add lock_page_killableMatthew Wilcox
This routine is like lock_page, but can be interrupted by a fatal signal Signed-off-by: Matthew Wilcox <willy@linux.intel.com>
2007-12-06Add fatal_signal_pendingMatthew Wilcox
Like signal_pending, but it's only true for signals which are fatal to this process Signed-off-by: Matthew Wilcox <willy@linux.intel.com>
2007-12-06Add TASK_WAKEKILLMatthew Wilcox
Set TASK_WAKEKILL for TASK_STOPPED and TASK_TRACED, add TASK_KILLABLE and use TASK_WAKEKILL in signal_wake_up() Signed-off-by: Matthew Wilcox <willy@linux.intel.com>
2007-12-06wait: Use TASK_NORMALMatthew Wilcox
Also move wake_up_locked() to be with the related functions Signed-off-by: Matthew Wilcox <willy@linux.intel.com>
2007-12-06Add macros to replace direct uses of TASK_ flagsMatthew Wilcox
With the changes to support TASK_KILLABLE, ->state becomes a bitmask, and moving these tests to convenience macros will fix all the users. Signed-off-by: Matthew Wilcox <willy@linux.intel.com>
2007-12-05Merge git://git.kernel.org/pub/scm/linux/kernel/git/mingo/linux-2.6-schedLinus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/mingo/linux-2.6-sched: futex: correctly return -EFAULT not -EINVAL lockdep: in_range() fix lockdep: fix debug_show_all_locks() sched: style cleanups futex: fix for futex_wait signal stack corruption
2007-12-05Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jmorris/selinux-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jmorris/selinux-2.6: VM/Security: add security hook to do_brk Security: round mmap hint address above mmap_min_addr security: protect from stack expantion into low vm addresses Security: allow capable check to permit mmap or low vm space SELinux: detect dead booleans SELinux: do not clear f_op when removing entries
2007-12-05Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6: [LRO]: fix lro_gen_skb() alignment [TCP]: NAGLE_PUSH seems to be a wrong way around [TCP]: Move prior_in_flight collect to more robust place [TCP] FRTO: Use of existing funcs make code more obvious & robust [IRDA]: Move ircomm_tty_line_info() under #ifdef CONFIG_PROC_FS [ROSE]: Trivial compilation CONFIG_INET=n case [IPVS]: Fix sched registration race when checking for name collision. [IPVS]: Don't leak sysctl tables if the scheduler registration fails.
2007-12-05proc: fix proc_dir_entry refcountingAlexey Dobriyan
Creating PDEs with refcount 0 and "deleted" flag has problems (see below). Switch to usual scheme: * PDE is created with refcount 1 * every de_get does +1 * every de_put() and remove_proc_entry() do -1 * once refcount reaches 0, PDE is freed. This elegantly fixes at least two following races (both observed) without introducing new locks, without abusing old locks, without spreading lock_kernel(): 1) PDE leak remove_proc_entry de_put ----------------- ------ [refcnt = 1] if (atomic_read(&de->count) == 0) if (atomic_dec_and_test(&de->count)) if (de->deleted) /* also not taken! */ free_proc_entry(de); else de->deleted = 1; [refcount=0, deleted=1] 2) use after free remove_proc_entry de_put ----------------- ------ [refcnt = 1] if (atomic_dec_and_test(&de->count)) if (atomic_read(&de->count) == 0) free_proc_entry(de); /* boom! */ if (de->deleted) free_proc_entry(de); BUG: unable to handle kernel paging request at virtual address 6b6b6b6b printing eip: c10acdda *pdpt = 00000000338f8001 *pde = 0000000000000000 Oops: 0000 [#1] PREEMPT SMP Modules linked in: af_packet ipv6 cpufreq_ondemand loop serio_raw psmouse k8temp hwmon sr_mod cdrom Pid: 23161, comm: cat Not tainted (2.6.24-rc2-8c0863403f109a43d7000b4646da4818220d501f #4) EIP: 0060:[<c10acdda>] EFLAGS: 00210097 CPU: 1 EIP is at strnlen+0x6/0x18 EAX: 6b6b6b6b EBX: 6b6b6b6b ECX: 6b6b6b6b EDX: fffffffe ESI: c128fa3b EDI: f380bf34 EBP: ffffffff ESP: f380be44 DS: 007b ES: 007b FS: 00d8 GS: 0033 SS: 0068 Process cat (pid: 23161, ti=f380b000 task=f38f2570 task.ti=f380b000) Stack: c10ac4f0 00000278 c12ce000 f43cd2a8 00000163 00000000 7da86067 00000400 c128fa20 00896b18 f38325a8 c128fe20 ffffffff 00000000 c11f291e 00000400 f75be300 c128fa20 f769c9a0 c10ac779 f380bf34 f7bfee70 c1018e6b f380bf34 Call Trace: [<c10ac4f0>] vsnprintf+0x2ad/0x49b [<c10ac779>] vscnprintf+0x14/0x1f [<c1018e6b>] vprintk+0xc5/0x2f9 [<c10379f1>] handle_fasteoi_irq+0x0/0xab [<c1004f44>] do_IRQ+0x9f/0xb7 [<c117db3b>] preempt_schedule_irq+0x3f/0x5b [<c100264e>] need_resched+0x1f/0x21 [<c10190ba>] printk+0x1b/0x1f [<c107c8ad>] de_put+0x3d/0x50 [<c107c8f8>] proc_delete_inode+0x38/0x41 [<c107c8c0>] proc_delete_inode+0x0/0x41 [<c1066298>] generic_delete_inode+0x5e/0xc6 [<c1065aa9>] iput+0x60/0x62 [<c1063c8e>] d_kill+0x2d/0x46 [<c1063fa9>] dput+0xdc/0xe4 [<c10571a1>] __fput+0xb0/0xcd [<c1054e49>] filp_close+0x48/0x4f [<c1055ee9>] sys_close+0x67/0xa5 [<c10026b6>] sysenter_past_esp+0x5f/0x85 ======================= Code: c9 74 0c f2 ae 74 05 bf 01 00 00 00 4f 89 fa 5f 89 d0 c3 85 c9 57 89 c7 89 d0 74 05 f2 ae 75 01 4f 89 f8 5f c3 89 c1 89 c8 eb 06 <80> 38 00 74 07 40 4a 83 fa ff 75 f4 29 c8 c3 90 90 90 57 83 c9 EIP: [<c10acdda>] strnlen+0x6/0x18 SS:ESP 0068:f380be44 Also, remove broken usage of ->deleted from reiserfs: if sget() succeeds, module is already pinned and remove_proc_entry() can't happen => nobody can mark PDE deleted. Dummy proc root in netns code is not marked with refcount 1. AFAICS, we never get it, it's just for proper /proc/net removal. I double checked CLONE_NETNS continues to work. Patch survives many hours of modprobe/rmmod/cat loops without new bugs which can be attributed to refcounting. Signed-off-by: Alexey Dobriyan <adobriyan@sw.ru> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-12-05jbd: Fix assertion failure in fs/jbd/checkpoint.cJan Kara
Before we start committing a transaction, we call __journal_clean_checkpoint_list() to cleanup transaction's written-back buffers. If this call happens to remove all of them (and there were already some buffers), __journal_remove_checkpoint() will decide to free the transaction because it isn't (yet) a committing transaction and soon we fail some assertion - the transaction really isn't ready to be freed :). We change the check in __journal_remove_checkpoint() to free only a transaction in T_FINISHED state. The locking there is subtle though (as everywhere in JBD ;(). We use j_list_lock to protect the check and a subsequent call to __journal_drop_transaction() and do the same in the end of journal_commit_transaction() which is the only place where a transaction can get to T_FINISHED state. Probably I'm too paranoid here and such locking is not really necessary - checkpoint lists are processed only from log_do_checkpoint() where a transaction must be already committed to be processed or from __journal_clean_checkpoint_list() where kjournald itself calls it and thus transaction cannot change state either. Better be safe if something changes in future... Signed-off-by: Jan Kara <jack@suse.cz> Cc: <linux-ext4@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-12-05futex: fix for futex_wait signal stack corruptionSteven Rostedt
David Holmes found a bug in the -rt tree with respect to pthread_cond_timedwait. After trying his test program on the latest git from mainline, I found the bug was there too. The bug he was seeing that his test program showed, was that if one were to do a "Ctrl-Z" on a process that was in the pthread_cond_timedwait, and then did a "bg" on that process, it would return with a "-ETIMEDOUT" but early. That is, the timer would go off early. Looking into this, I found the source of the problem. And it is a rather nasty bug at that. Here's the relevant code from kernel/futex.c: (not in order in the file) [...] smlinkage long sys_futex(u32 __user *uaddr, int op, u32 val, struct timespec __user *utime, u32 __user *uaddr2, u32 val3) { struct timespec ts; ktime_t t, *tp = NULL; u32 val2 = 0; int cmd = op & FUTEX_CMD_MASK; if (utime && (cmd == FUTEX_WAIT || cmd == FUTEX_LOCK_PI)) { if (copy_from_user(&ts, utime, sizeof(ts)) != 0) return -EFAULT; if (!timespec_valid(&ts)) return -EINVAL; t = timespec_to_ktime(ts); if (cmd == FUTEX_WAIT) t = ktime_add(ktime_get(), t); tp = &t; } [...] return do_futex(uaddr, op, val, tp, uaddr2, val2, val3); } [...] long do_futex(u32 __user *uaddr, int op, u32 val, ktime_t *timeout, u32 __user *uaddr2, u32 val2, u32 val3) { int ret; int cmd = op & FUTEX_CMD_MASK; struct rw_semaphore *fshared = NULL; if (!(op & FUTEX_PRIVATE_FLAG)) fshared = &current->mm->mmap_sem; switch (cmd) { case FUTEX_WAIT: ret = futex_wait(uaddr, fshared, val, timeout); [...] static int futex_wait(u32 __user *uaddr, struct rw_semaphore *fshared, u32 val, ktime_t *abs_time) { [...] struct restart_block *restart; restart = &current_thread_info()->restart_block; restart->fn = futex_wait_restart; restart->arg0 = (unsigned long)uaddr; restart->arg1 = (unsigned long)val; restart->arg2 = (unsigned long)abs_time; restart->arg3 = 0; if (fshared) restart->arg3 |= ARG3_SHARED; return -ERESTART_RESTARTBLOCK; [...] static long futex_wait_restart(struct restart_block *restart) { u32 __user *uaddr = (u32 __user *)restart->arg0; u32 val = (u32)restart->arg1; ktime_t *abs_time = (ktime_t *)restart->arg2; struct rw_semaphore *fshared = NULL; restart->fn = do_no_restart_syscall; if (restart->arg3 & ARG3_SHARED) fshared = &current->mm->mmap_sem; return (long)futex_wait(uaddr, fshared, val, abs_time); } So when the futex_wait is interrupt by a signal we break out of the hrtimer code and set up or return from signal. This code does not return back to userspace, so we set up a RESTARTBLOCK. The bug here is that we save the "abs_time" which is a pointer to the stack variable "ktime_t t" from sys_futex. This returns and unwinds the stack before we get to call our signal. On return from the signal we go to futex_wait_restart, where we update all the parameters for futex_wait and call it. But here we have a problem where abs_time is no longer valid. I verified this with print statements, and sure enough, what abs_time was set to ends up being garbage when we get to futex_wait_restart. The solution I did to solve this (with input from Linus Torvalds) was to add unions to the restart_block to allow system calls to use the restart with specific parameters. This way the futex code now saves the time in a 64bit value in the restart block instead of storing it on the stack. Note: I'm a bit nervious to add "linux/types.h" and use u32 and u64 in thread_info.h, when there's a #ifdef __KERNEL__ just below that. Not sure what that is there for. If this turns out to be a problem, I've tested this with using "unsigned int" for u32 and "unsigned long long" for u64 and it worked just the same. I'm using u32 and u64 just to be consistent with what the futex code uses. Signed-off-by: Steven Rostedt <srostedt@redhat.com> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Acked-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-12-05[LRO]: fix lro_gen_skb() alignmentAndrew Gallatin
Add a field to the lro_mgr struct so that drivers can specify how much padding is required to align layer 3 headers when a packet is copied into a freshly allocated skb by inet_lro.c:lro_gen_skb(). Without padding, skbs generated by LRO will cause alignment warnings on architectures which require strict alignment (seen on sparc64). Myri10GE is updated to use this field. Signed-off-by: Andrew Gallatin <gallatin@myri.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-12-06Security: round mmap hint address above mmap_min_addrEric Paris
If mmap_min_addr is set and a process attempts to mmap (not fixed) with a non-null hint address less than mmap_min_addr the mapping will fail the security checks. Since this is just a hint address this patch will round such a hint address above mmap_min_addr. gcj was found to try to be very frugal with vm usage and give hint addresses in the 8k-32k range. Without this patch all such programs failed and with the patch they happily get a higher address. This patch is wrappad in CONFIG_SECURITY since mmap_min_addr doesn't exist without it and there would be no security check possible no matter what. So we should not bother compiling in this rounding if it is just a waste of time. Signed-off-by: Eric Paris <eparis@redhat.com> Signed-off-by: James Morris <jmorris@namei.org>
2007-12-04PHY: Add the phy_device_release device method.Anton Vorontsov
Lately I've got this nice badness on mdio bus removal: Device 'e0103120:06' does not have a release() function, it is broken and must be fixed. ------------[ cut here ]------------ Badness at drivers/base/core.c:107 NIP: c015c1a8 LR: c015c1a8 CTR: c0157488 REGS: c34bdcf0 TRAP: 0700 Not tainted (2.6.23-rc5-g9ebadfbb-dirty) MSR: 00029032 <EE,ME,IR,DR> CR: 24088422 XER: 00000000 ... [c34bdda0] [c015c1a8] device_release+0x78/0x80 (unreliable) [c34bddb0] [c01354cc] kobject_cleanup+0x80/0xbc [c34bddd0] [c01365f0] kref_put+0x54/0x6c [c34bdde0] [c013543c] kobject_put+0x24/0x34 [c34bddf0] [c015c384] put_device+0x1c/0x2c [c34bde00] [c0180e84] mdiobus_unregister+0x2c/0x58 ... Though actually there is nothing broken, it just device subsystem core expects another "pattern" of resource managment. This patch implement phy device's release function, thus we're getting rid of this badness. Also small hidden bug fixed, hope none other introduced. ;-) Signed-off-by: Anton Vorontsov <avorontsov@ru.mvista.com> Acked-by: Andy Fleming <afleming@freescale.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-12-03Merge git://git.kernel.org/pub/scm/linux/kernel/git/mingo/linux-2.6-schedLinus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/mingo/linux-2.6-sched: sched: cpu accounting controller (V2)
2007-12-03Merge git://git.kernel.org/pub/scm/linux/kernel/git/herbert/net-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/herbert/net-2.6: (27 commits) [INET]: Fix inet_diag dead-lock regression [NETNS]: Fix /proc/net breakage [TEXTSEARCH]: Do not allow zero length patterns in the textsearch infrastructure [NETFILTER]: fix forgotten module release in xt_CONNMARK and xt_CONNSECMARK [NETFILTER]: xt_TCPMSS: remove network triggerable WARN_ON [DECNET]: dn_nl_deladdr() almost always returns no error [IPV6]: Restore IPv6 when MTU is big enough [RXRPC]: Add missing select on CRYPTO mac80211: rate limit wep decrypt failed messages rfkill: fix double-mutex-locking mac80211: drop unencrypted frames if encryption is expected mac80211: Fix behavior of ieee80211_open and ieee80211_close ieee80211: fix unaligned access in ieee80211_copy_snap mac80211: free ifsta->extra_ie and clear IEEE80211_STA_PRIVACY_INVOKED SCTP: Fix build issues with SCTP AUTH. SCTP: Fix chunk acceptance when no authenticated chunks were listed. SCTP: Fix the supported extensions paramter SCTP: Fix SCTP-AUTH to correctly add HMACS paramter. SCTP: Fix the number of HB transmissions. [TCP] illinois: Incorrect beta usage ...
2007-12-02sched: cpu accounting controller (V2)Srivatsa Vaddagiri
Commit cfb5285660aad4931b2ebbfa902ea48a37dfffa1 removed a useful feature for us, which provided a cpu accounting resource controller. This feature would be useful if someone wants to group tasks only for accounting purpose and doesnt really want to exercise any control over their cpu consumption. The patch below reintroduces the feature. It is based on Paul Menage's original patch (Commit 62d0df64065e7c135d0002f069444fbdfc64768f), with these differences: - Removed load average information. I felt it needs more thought (esp to deal with SMP and virtualized platforms) and can be added for 2.6.25 after more discussions. - Convert group cpu usage to be nanosecond accurate (as rest of the cfs stats are) and invoke cpuacct_charge() from the respective scheduler classes - Make accounting scalable on SMP systems by splitting the usage counter to be per-cpu - Move the code from kernel/cpu_acct.c to kernel/sched.c (since the code is not big enough to warrant a new file and also this rightly needs to live inside the scheduler. Also things like accessing rq->lock while reading cpu usage becomes easier if the code lived in kernel/sched.c) The patch also modifies the cpu controller not to provide the same accounting information. Tested-by: Balbir Singh <balbir@linux.vnet.ibm.com> Tested the patches on top of 2.6.24-rc3. The patches work fine. Ran some simple tests like cpuspin (spin on the cpu), ran several tasks in the same group and timed them. Compared their time stamps with cpuacct.usage. Signed-off-by: Srivatsa Vaddagiri <vatsa@linux.vnet.ibm.com> Signed-off-by: Balbir Singh <balbir@linux.vnet.ibm.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2007-12-01phylib: add PHY interface modes for internal delay for tx and rx onlyKim Phillips
Allow phylib specification of cases where hardware needs to configure PHYs for Internal Delay only on either RX or TX (not both). Signed-off-by: Kim Phillips <kim.phillips@freescale.com> Tested-by: Anton Vorontsov <avorontsov@ru.mvista.com> Acked-by: Li Yang <leoli@freescale.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-12-01Merge branch 'master' into upstream-fixesJeff Garzik
2007-12-02[NETNS]: Fix /proc/net breakageEric W. Biederman
Well I clearly goofed when I added the initial network namespace support for /proc/net. Currently things work but there are odd details visible to user space, even when we have a single network namespace. Since we do not cache proc_dir_entry dentries at the moment we can just modify ->lookup to return a different directory inode depending on the network namespace of the process looking at /proc/net, replacing the current technique of using a magic and fragile follow_link method. To accomplish that this patch: - introduces a shadow_proc method to allow different dentries to be returned from proc_lookup. - Removes the old /proc/net follow_link magic - Fixes a weakness in our not caching of proc generic dentries. As shadow_proc uses a task struct to decided which dentry to return we can go back later and fix the proc generic caching without modifying any code that uses the shadow_proc method. Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Cc: "Rafael J. Wysocki" <rjw@sisk.pl> Cc: Pavel Machek <pavel@ucw.cz> Cc: Pavel Emelyanov <xemul@openvz.org> Cc: "David S. Miller" <davem@davemloft.net> Cc: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2007-11-29RTC: convert mutex to bitfieldJiri Kosina
RTC code is using mutex to assure exclusive access to /dev/rtc. This is however wrong usage, as it leaves the mutex locked when returning into userspace, which is unacceptable. Convert rtc->char_lock into bit operation. Signed-off-by: Jiri Kosina <jkosina@suse.cz> Acked-by: Alessandro Zummo <a.zummo@towertech.it> Cc: David Brownell <david-b@pacbell.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-11-29fuse: pass open flags to read and writeMiklos Szeredi
Some open flags (O_APPEND, O_DIRECT) can be changed with fcntl(F_SETFL, ...) after open, but fuse currently only sends the flags to userspace in open. To make it possible to correcly handle changing flags, send the current value to userspace in each read and write. Signed-off-by: Miklos Szeredi <mszeredi@suse.cz> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-11-29x86_64 EFI boot support: EFI frame buffer driverHuang, Ying
This patch adds Graphics Output Protocol support to the kernel. UEFI2.0 spec deprecates Universal Graphics Adapter (UGA) protocol and only Graphics Output Protocol (GOP) is produced. Therefore, the boot loader needs to query the UEFI firmware with appropriate Output Protocol and pass the video information to the kernel. As a result of GOP protocol, an EFI framebuffer driver is needed for displaying console messages. The patch adds a EFI framebuffer driver. The EFI frame buffer driver in this patch is based on the Intel Mac framebuffer driver. The ELILO bootloader takes care of passing the video information as appropriate for EFI firmware. The framebuffer driver has been tested in i386 kernel and x86_64 kernel on EFI platform. Signed-off-by: Chandramouli Narayanan <mouli@linux.intel.com> Signed-off-by: Huang Ying <ying.huang@intel.com> Cc: "H. Peter Anvin" <hpa@zytor.com> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Ingo Molnar <mingo@elte.hu> Cc: Andi Kleen <ak@suse.de> Cc: "Antonino A. Daplas" <adaplas@pol.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-11-29fix up ext2_fs.h for userspace after reservations backportTobias Poschwatta
In commit a686cd898bd999fd026a51e90fb0a3410d258ddb: "Val's cross-port of the ext3 reservations code into ext2." include/linux/ext2_fs.h got a new function whose return value is only defined if __KERNEL__ is defined. Putting #ifdef __KERNEL__ around the function seems to help, patch below. Signed-off-by: Eric Sandeen <sandeen@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-11-29IP22ZILOG: fix lockup and sysrqThomas Bogendoerfer
- fix lockup when switching from early console to real console - make sysrq reliable - fix panic, if sysrq is issued before console is opened Signed-off-by: Thomas Bogendoerfer <tsbogend@alpha.franken.de> Acked-by: Ralf Baechle <ralf@linux-mips.org> Cc: Alan Cox <alan@lxorguk.ukuu.org.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-11-29Fix <linux/kd.h> usage in userspaceDavid Woodhouse
For reasons unclear to me, glibc's <sys/kd.h> deliberately defeats the attempt we make in <linux/kd.h> to include <linux/types.h> For now, change the one instance of __u32 to 'unsigned int' instead because it's breaking userspace. We should probably also remove our inclusion of <linux/types.h>, since we don't use it -- but that's not a change to make in -rc. [akpm@linux-foundation.org: coding-style fixes] Signed-off-by: David Woodhouse <dwmw2@infradead.org> Cc: Samuel Thibault <samuel.thibault@ens-lyon.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-11-29PNP: increase the maximum number of resourcesZhao Yakui
On some systems the number of resources(IO,MEM) returnedy by PNP device is greater than the PNP constant, for example motherboard devices. It brings that some resources can't be reserved and resource confilicts. This will cause PCI resources are assigned wrongly in some systems, and cause hang. This is a regression since we deleted ACPI motherboard driver and use PNP system driver. [akpm@linux-foundation.org: fix text and coding-style a bit] Signed-off-by: Li Shaohua <shaohua.li@intel.com> Signed-off-by: Zhao Yakui <yakui.zhao@intel.com> Cc: Bjorn Helgaas <bjorn.helgaas@hp.com> Cc: Thomas Renninger <trenn@suse.de> Cc: <stable@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-11-28Merge git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb-2.6: (25 commits) USB: s3c2410 gadget: ensure vbus pin in input mode during read USB: s3c2410 gadget: allow sharing of vbus irq USB: s3c2410 gadget: Header move fixups USB: usb-storage: unusual_devs entry for JetFlash TS1GJF2A USB: fix up EHCI startup synchronization USB: make the microtek driver and HAL cooperate USB: uevent environment key fix USB: keep track of whether interface sysfs files exist USB: sierra: new product id USB HCD: avoid duplicate local_irq_disable() USB: mailing lists have changed USB: remove USB HUB entry from MAINTAINERS USB: fix directory references in usb/README USB: add support for an older firmware revision for the Nikon D200 USB: FIx locks and urb->status in adutux (updated) USB: power-management documenation update USB: Fix signr comment in usbdevice_fs.h usbserial: fix inconsistent lock state USB: fix usbled disconnect read race #2 USB: free memory when writing fails in usb/serial/mos7840.c ...
2007-11-28USB: keep track of whether interface sysfs files existAlan Stern
This patch (as1009) solves the problem of multiple registrations for USB sysfs files in a more satisfying way than the existing code. It simply adds a flag to keep track of whether or not the files have been created; that way the files can be created or removed as needed. Signed-off-by: Alan Stern <stern@rowland.harvard.edu>
2007-11-28USB: Fix signr comment in usbdevice_fs.hPhil Endecott
This trivial documentation patch corrects a comment in usbdevice_fs.h; it previously suggested that the signal would only be sent on error, but I am told that it is sent on both successful and unsuccessful completion, and that zero indicates that no signal should be sent. Signed-off-by: Phil Endecott <spam_from_usb_devel@chezphil.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-11-28sched: clean up, move __sched_text_start/end to sched.hIngo Molnar
move __sched_text_start/end to sched.h. No code changed: text data bss dec hex filename 26582 2310 28 28920 70f8 sched.o.before 26582 2310 28 28920 70f8 sched.o.after Signed-off-by: Ingo Molnar <mingo@elte.hu>
2007-11-27Merge branch 'for-linus' of git://git.kernel.dk/linux-2.6-blockLinus Torvalds
* 'for-linus' of git://git.kernel.dk/linux-2.6-block: scatterlist: add more safeguards Revert "ll_rw_blk: temporarily enable max_segments tweaking" mmc: Add missing sg_init_table() call block: Fix memory leak in alloc_disk_node() alpha: fix sg_page breakage blktrace: Make sure BLKTRACETEARDOWN does the full cleanup.
2007-11-27Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input: Input: adds the context menu key (HUT GenDesc 0x84) Input: add definitions for frame forward and frame back keys Input: bf54x-keys - keypad does not exist on BF544 parts Input: gpio-keys - request and configure GPIOs Input: i8042 - add i8042.noloop quirk for MS Virtual Machine Sonypi: use synchronize_irq instead of sycnronize_sched sonypi: fit input devices into sysfs tree sony-laptop: fit input devices into sysfs tree
2007-11-27scatterlist: add more safeguardsTejun Heo
Add more safeguards to protect against misinterpreting a chain entry as a normal scatterlist and vice-versa. * Make sure the entry isn't a chain when assigning and reading a normal sg. * Clear offset and length when chaining. Signed-off-by: Tejun Heo <htejun@gmail.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2007-11-27Input: adds the context menu key (HUT GenDesc 0x84)Aristeu Rozanski
Signed-off-by: Aristeu Rozanski <aris@ruivo.org> Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2007-11-27Input: add definitions for frame forward and frame back keysAristeu Rozanski
2007-11-26Merge git://git.kernel.org/pub/scm/linux/kernel/git/herbert/net-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/herbert/net-2.6: (41 commits) [XFRM]: Fix leak of expired xfrm_states [ATM]: [he] initialize lock and tasklet earlier [IPV4]: Remove bogus ifdef mess in arp_process [SKBUFF]: Free old skb properly in skb_morph [IPV4]: Fix memory leak in inet_hashtables.h when NUMA is on [IPSEC]: Temporarily remove locks around copying of non-atomic fields [TCP] MTUprobe: Cleanup send queue check (no need to loop) [TCP]: MTUprobe: receiver window & data available checks fixed [MAINTAINERS]: tlan list is subscribers-only [SUNRPC]: Remove SPIN_LOCK_UNLOCKED [SUNRPC]: Make xprtsock.c:xs_setup_{udp,tcp}() static [PFKEY]: Sending an SADB_GET responds with an SADB_GET [IRDA]: Compilation for CONFIG_INET=n case [IPVS]: Fix compiler warning about unused register_ip_vs_protocol [ARP]: Fix arp reply when sender ip 0 [IPV6] TCPMD5: Fix deleting key operation. [IPV6] TCPMD5: Check return value of tcp_alloc_md5sig_pool(). [IPV4] TCPMD5: Use memmove() instead of memcpy() because we have overlaps. [IPV4] TCPMD5: Omit redundant NULL check for kfree() argument. ieee80211: Stop net_ratelimit/IEEE80211_DEBUG_DROP log pollution ...
2007-11-26Merge git://git.linux-nfs.org/pub/linux/nfs-2.6Linus Torvalds
* git://git.linux-nfs.org/pub/linux/nfs-2.6: NFS: Clean up new multi-segment direct I/O changes NFS: Ensure we return zero if applications attempt to write zero bytes NFS: Support multiple segment iovecs in the NFS direct I/O path NFS: Introduce iovec I/O helpers to fs/nfs/direct.c SUNRPC: Add missing "space" to net/sunrpc/auth_gss.c SUNRPC: make sunrpc/xprtsock.c:xs_setup_{udp,tcp}() static NFS: fs/nfs/dir.c should #include "internal.h" NFS: make nfs_wb_page_priority() static NFS: mount failure causes bad page state SUNRPC: remove NFS/RDMA client's binary sysctls kernel BUG at fs/nfs/namespace.c:108! - can be triggered by bad server sunrpc: rpc_pipe_poll may miss available data in some cases sunrpc: return error if unsupported enctype or cksumtype is encountered sunrpc: gss_pipe_downcall(), don't assume all errors are transient NFS: Fix the ustat() regression
2007-11-26Merge git://git.kernel.org/pub/scm/linux/kernel/git/x86/linux-2.6-x86Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/x86/linux-2.6-x86: x86: fix APIC related bootup crash on Athlon XP CPUs time: add ADJ_OFFSET_SS_READ x86: export the symbol empty_zero_page on the 32-bit x86 architecture x86: fix kprobes_64.c inlining borkage pci: use pci=bfsort for HP DL385 G2, DL585 G2 x86: correctly set UTS_MACHINE for "make ARCH=x86" lockdep: annotate do_debug() trap handler x86: turn off iommu merge by default x86: fix ACPI compile for LOCAL_APIC=n x86: printk kernel version in WARN_ON and other dump_stack users ACPI: Set max_cstate to 1 for early Opterons. x86: fix NMI watchdog & 'stopped time' problem
2007-11-26Merge branch 'upstream-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jgarzik/libata-dev * 'upstream-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jgarzik/libata-dev: (21 commits) libata: bump transfer chunk size if it's odd libata: Return proper ATA INT status in pata_bf54x driver pata_ali: trim trailing whitespace (fix checkpatch complaints) pata_isapnp: Polled devices pata_hpt37x: Fix cable detect bug spotted by Sergei pata_ali: Lots of problems still showing up with small ATAPI DMA pata_ali: Add Mitac 8317 and derivatives libata-core: List more documentation sources for reference ata_piix: Invalid use of writel/readl with iomap sata_sil24: fix sg table sizing pata_jmicron: fix disabled port handling in jmicron_pre_reset() pata_sil680: kill bogus reset code (take 2) ata_piix: port enable for the first SATA controller of ICH8 is 0xf not 0x3 ata_piix: only enable the first port on apple macbook pro ata_piix: reorganize controller IDs pata_sis.c: Add Packard Bell EasyNote K5305 to laptops libata-scsi: be tolerant of 12-byte ATAPI commands in 16-byte CDBs libata: use ATA_HORKAGE_STUCK_ERR for ATAPI tape drives libata: workaround DRQ=1 ERR=1 for ATAPI tape drives libata: remove unused functions ...
2007-11-26Merge branch 'release' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux-acpi-2.6 * 'release' of git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux-acpi-2.6: (39 commits) ACPI: EC: Workaround for optimized controllers (version 3) ACPI: EC: use printk_ratelimit(), add some DEBUG mode messages Revert "ACPI: EC: Workaround for optimized controllers" ACPI: fix two IRQ8 issues in IOAPIC mode ACPI: Add missing spaces to printk format cpuidle: fix HP nx6125 regression cpuidle: add sched_clock_idle_[sleep|wakeup]_event() hooks cpuidle: fix C3 for no bus-master control case ACPI: thinkpad-acpi: fix oops when a module parameter has no value Revert "Fix very high interrupt rate for IRQ8 (rtc) unless pnpacpi=off" ACPI: EC: Don't init EC early if it has no _INI Revert "acpi: make ACPI_PROCFS default to y" Revert "ACPI: add documentation for deprecated /proc/acpi/battery in ACPI_PROCFS" ACPI: Split out control for /proc/acpi entries from battery, ac, and sbs. ACPI: Video: Increase buffer size for writes to brightness proc file. ACPI: EC: Workaround for optimized controllers ACPI: SBS: Fix retval warning ACPI: Enable MSR (FixedHW) support for T-States ACPI: Get throttling info from BIOS only after evaluating _PDC ACPI: Use _TSS for throttling control, when present. Add error checks. ...
2007-11-26SUNRPC: make sunrpc/xprtsock.c:xs_setup_{udp,tcp}() staticAdrian Bunk
xs_setup_{udp,tcp}() can now become static. Signed-off-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2007-11-26NFS: make nfs_wb_page_priority() staticAdrian Bunk
nfs_wb_page_priority() can now become static. Signed-off-by: Adrian Bunk <bunk@kernel.org> Cc: Trond Myklebust <trond.myklebust@fys.uio.no> Cc: "J. Bruce Fields" <bfields@fieldses.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2007-11-26SUNRPC: remove NFS/RDMA client's binary sysctlsJames Lentini
Support for binary sysctls is being deprecated in 2.6.24. Since there are no applications using the NFS/RDMA client's binary sysctls, it makes sense to remove them. The patch below does this while leaving the /proc/sys interface unchanged. Please consider this for 2.6.24. Signed-off-by: James Lentini <jlentini@netapp.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2007-11-26time: add ADJ_OFFSET_SS_READJohn Stultz
Michael Kerrisk reported that a long standing bug in the adjtimex() system call causes glibc's adjtime(3) function to deliver the wrong results if 'delta' is NULL. add the ADJ_OFFSET_SS_READ API detail, which will be used by glibc to fix this API compatibility bug. Also see: http://bugzilla.kernel.org/show_bug.cgi?id=6761 [ mingo@elte.hu: added patch description and made it backwards compatible ] NOTE: the new flag is defined 0xa001 so that it returns -EINVAL on older kernels - this way glibc can use it safely. Suggested by Ulrich Drepper. Acked-by: Ulrich Drepper <drepper@redhat.com> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2007-11-26[SKBUFF]: Free old skb properly in skb_morphHerbert Xu
The skb_morph function only freed the data part of the dst skb, but leaked the auxiliary data such as the netfilter fields. This patch fixes this by moving the relevant parts from __kfree_skb to skb_release_all and calling it in skb_morph. It also makes kfree_skbmem static since it's no longer called anywhere else and it now no longer does skb_release_data. Thanks to Yasuyuki KOZAKAI for finding this problem and posting a patch for it. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2007-11-23forcedeth: new mcp79 pci idsAyaz Abdulla
This patch adds new device ids and features for mcp79 devices into the forcedeth driver. Signed-off-by: Ayaz Abdulla <aabdulla@nvidia.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
