path: root/include/linux
2009-03-10tracing: document TRACE_EVENT macro in tracepoint.hSteven Rostedt
Impact: clean up / comments Kosaki Motohiro asked about an explanation to the TRACE_EVENT macro. Ingo Molnar replied with a nice description. This patch takes the description that Ingo wrote (with some slight modifications) and adds it to the tracepoint.h file. Reported-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Signed-off-by: Steven Rostedt <srostedt@redhat.com>
2009-03-10tracing: flip the TP_printk and TP_fast_assign in the TRACE_EVENT macroSteven Rostedt
Impact: clean up In trying to stay consistant with the C style format in the TRACE_EVENT macro, it makes more sense to do the printk after the assigning of the variables. Reported-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Steven Rostedt <srostedt@redhat.com>
2009-03-10tracing: remove obsolete TRACE_EVENT_FORMAT macroSteven Rostedt
Impact: clean up The TRACE_EVENT_FORMAT macro is no longer used by trace points and only the DECLARE_TRACE, TRACE_FORMAT or TRACE_EVENT macros should be used by them. Although the TRACE_EVENT_FORMAT macro is still used by the internal tracing utility, it should not be used in core kernel code. Signed-off-by: Steven Rostedt <srostedt@redhat.com>
2009-03-10tracing: new format for specialized trace pointsSteven Rostedt
Impact: clean up and enhancement The TRACE_EVENT_FORMAT macro looks quite ugly and is limited in its ability to save data as well as to print the record out. Working with Ingo Molnar, we came up with a new format that is much more pleasing to the eye of C developers. This new macro is more C style than the old macro, and is more obvious to what it does. Here's the example. The only updated macro in this patch is the sched_switch trace point. The old method looked like this: TRACE_EVENT_FORMAT(sched_switch, TP_PROTO(struct rq *rq, struct task_struct *prev, struct task_struct *next), TP_ARGS(rq, prev, next), TP_FMT("task %s:%d ==> %s:%d", prev->comm, prev->pid, next->comm, next->pid), TRACE_STRUCT( TRACE_FIELD(pid_t, prev_pid, prev->pid) TRACE_FIELD(int, prev_prio, prev->prio) TRACE_FIELD_SPECIAL(char next_comm[TASK_COMM_LEN], next_comm, TP_CMD(memcpy(TRACE_ENTRY->next_comm, next->comm, TASK_COMM_LEN))) TRACE_FIELD(pid_t, next_pid, next->pid) TRACE_FIELD(int, next_prio, next->prio) ), TP_RAW_FMT("prev %d:%d ==> next %s:%d:%d") ); The above method is hard to read and requires two format fields. The new method: /* * Tracepoint for task switches, performed by the scheduler: * * (NOTE: the 'rq' argument is not used by generic trace events, * but used by the latency tracer plugin. ) */ TRACE_EVENT(sched_switch, TP_PROTO(struct rq *rq, struct task_struct *prev, struct task_struct *next), TP_ARGS(rq, prev, next), TP_STRUCT__entry( __array( char, prev_comm, TASK_COMM_LEN ) __field( pid_t, prev_pid ) __field( int, prev_prio ) __array( char, next_comm, TASK_COMM_LEN ) __field( pid_t, next_pid ) __field( int, next_prio ) ), TP_printk("task %s:%d [%d] ==> %s:%d [%d]", __entry->prev_comm, __entry->prev_pid, __entry->prev_prio, __entry->next_comm, __entry->next_pid, __entry->next_prio), TP_fast_assign( memcpy(__entry->next_comm, next->comm, TASK_COMM_LEN); __entry->prev_pid = prev->pid; __entry->prev_prio = prev->prio; memcpy(__entry->prev_comm, prev->comm, TASK_COMM_LEN); __entry->next_pid = next->pid; __entry->next_prio = next->prio; ) ); This macro is called TRACE_EVENT, it is broken up into 5 parts: TP_PROTO: the proto type of the trace point TP_ARGS: the arguments of the trace point TP_STRUCT_entry: the structure layout of the entry in the ring buffer TP_printk: the printk format TP_fast_assign: the method used to write the entry into the ring buffer The structure is the definition of how the event will be saved in the ring buffer. The printk is used by the internal tracing in case of an oops, and the kernel needs to print out the format of the record to the console. This the TP_printk gives a means to show the records in a human readable format. It is also used to print out the data from the trace file. The TP_fast_assign is executed directly. It is basically like a C function, where the __entry is the handle to the record. Signed-off-by: Steven Rostedt <srostedt@redhat.com>
2009-03-10tracing: replace TP<var> with TP_<var>Steven Rostedt
Impact: clean up The macros TPPROTO, TPARGS, TPFMT, TPRAWFMT, and TPCMD all look a bit ugly. This patch adds an underscore to their names. Signed-off-by: Steven Rostedt <srostedt@redhat.com>
2009-03-09tracing: optimize trace_printk()Ingo Molnar
Impact: micro-optimization trace_printk() does this unconditionally: trace_printk_fmt = fmt; Where trace_printk_fmt is an entry into a global array. This is very SMP-unfriendly. So only write it once per bootup. Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Steven Rostedt <rostedt@goodmis.org> Cc: Peter Zijlstra <peterz@infradead.org> LKML-Reference: <1236356510-8381-5-git-send-email-fweisbec@gmail.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-03-06tracing/core: drop the old trace_printk() implementation in favour of ↵Frederic Weisbecker
trace_bprintk() Impact: faster and lighter tracing Now that we have trace_bprintk() which is faster and consume lesser memory than trace_printk() and has the same purpose, we can now drop the old implementation in favour of the binary one from trace_bprintk(), which means we move all the implementation of trace_bprintk() to trace_printk(), so the Api doesn't change except that we must now use trace_seq_bprintk() to print the TRACE_PRINT entries. Some changes result of this: - Previously, trace_bprintk depended of a single tracer and couldn't work without. This tracer has been dropped and the whole implementation of trace_printk() (like the module formats management) is now integrated in the tracing core (comes with CONFIG_TRACING), though we keep the file trace_printk (previously trace_bprintk.c) where we can find the module management. Thus we don't overflow trace.c - changes some parts to use trace_seq_bprintk() to print TRACE_PRINT entries. - change a bit trace_printk/trace_vprintk macros to support non-builtin formats constants, and fix 'const' qualifiers warnings. But this is all transparent for developers. - etc... V2: - Rebase against last changes - Fix mispell on the changelog V3: - Rebase against last changes (moving trace_printk() to kernel.h) Signed-off-by: Frederic Weisbecker <fweisbec@gmail.com> Acked-by: Steven Rostedt <rostedt@goodmis.org> LKML-Reference: <1236356510-8381-5-git-send-email-fweisbec@gmail.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-03-06tracing: add trace_bprintk()Lai Jiangshan
Impact: add a generic printk() for tracing, like trace_printk() trace_bprintk() uses the infrastructure to record events on ring_buffer. [ fweisbec@gmail.com: ported to latest -tip, made it work if !CONFIG_MODULES, never free the format strings from modules because we can't keep track of them and conditionnaly create the ftrace format strings section (reported by Steven Rostedt) ] Signed-off-by: Lai Jiangshan <laijs@cn.fujitsu.com> Signed-off-by: Frederic Weisbecker <fweisbec@gmail.com> Acked-by: Steven Rostedt <rostedt@goodmis.org> LKML-Reference: <1236356510-8381-4-git-send-email-fweisbec@gmail.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-03-06tracing: infrastructure for supporting binary recordLai Jiangshan
Impact: save on memory for tracing Current tracers are typically using a struct(like struct ftrace_entry, struct ctx_switch_entry, struct special_entr etc...)to record a binary event. These structs can only record a their own kind of events. A new kind of tracer need a new struct and a lot of code too handle it. So we need a generic binary record for events. This infrastructure is for this purpose. [fweisbec@gmail.com: rebase against latest -tip, make it safe while sched tracing as reported by Steven Rostedt] Signed-off-by: Lai Jiangshan <laijs@cn.fujitsu.com> Signed-off-by: Frederic Weisbecker <fweisbec@gmail.com> Acked-by: Steven Rostedt <rostedt@goodmis.org> LKML-Reference: <1236356510-8381-3-git-send-email-fweisbec@gmail.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-03-06Merge branch 'core/printk' into tracing/ftraceIngo Molnar
2009-03-06vsprintf: add binary printfLai Jiangshan
Impact: add new APIs for binary trace printk infrastructure vbin_printf(): write args to binary buffer, string is copied when "%s" is occurred. bstr_printf(): read from binary buffer for args and format a string [fweisbec@gmail.com: rebase] Signed-off-by: Lai Jiangshan <laijs@cn.fujitsu.com> Signed-off-by: Frederic Weisbecker <fweisbec@gmail.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> LKML-Reference: <1236356510-8381-2-git-send-email-fweisbec@gmail.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-03-06Merge branch 'tip/tracing/ftrace' of ↵Ingo Molnar
git://git.kernel.org/pub/scm/linux/kernel/git/rostedt/linux-2.6-trace into tracing/ftrace
2009-03-06Merge branches 'tracing/ftrace' and 'tracing/function-graph-tracer' into ↵Ingo Molnar
tracing/core
2009-03-05tracing: add tracing_on/tracing_off to kernel.hSteven Rostedt
Impact: cleanup The functions tracing_start/tracing_stop have been moved to kernel.h. These are not the functions a developer most likely wants to use when they want to insert a place to stop tracing and restart it from user space. tracing_start/tracing_stop was created to work with things like suspend to ram, where even calling smp_processor_id() can crash the system. The tracing_start/tracing_stop was used to stop the tracer from doing anything. These are still light weight functions, but add a bit more overhead to be able to stop the tracers. They also have no interface back to userland. That is, if the kernel calls tracing_stop, userland can not start tracing. What a developer most likely wants to use is tracing_on/tracing_off. These are very light weight functions (simply sets or clears a bit). These functions just stop recording into the ring buffer. The tracers don't even know that this happens except that they would receive NULL from the ring_buffer_lock_reserve function. Also, there's a way for the user land to enable or disable this bit. In debugfs/tracing/tracing_on, a user may echo "0" (same as tracing_off()) or echo "1" (same as tracing_on()) into this file. This becomes handy when a kernel developer is debugging and wants tracing to turn off when it hits an anomaly. Then the developer can examine the trace, and restart tracing if they want to try again (echo 1 > tracing_on). This patch moves the prototypes for tracing_on/tracing_off to kernel.h and comments their use, so that a kernel developer will know how to use them. Signed-off-by: Steven Rostedt <srostedt@redhat.com>
2009-03-05tracing/function-graph-tracer: use the more lightweight local clockFrederic Weisbecker
Impact: decrease hangs risks with the graph tracer on slow systems Since the function graph tracer can spend too much time on timer interrupts, it's better now to use the more lightweight local clock. Anyway, the function graph traces are more reliable on a per cpu trace. Signed-off-by: Frederic Weisbecker <fweisbec@gmail.com> Cc: Steven Rostedt <rostedt@goodmis.org> Cc: Peter Zijlstra <peterz@infradead.org> LKML-Reference: <49af243d.06e9300a.53ad.ffff840c@mx.google.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-03-05tracing: move utility functions from ftrace.h to kernel.hIngo Molnar
Make common utility functions such as trace_printk() and tracing_start()/tracing_stop() generally available to kernel code. Cc: Steven Rostedt <srostedt@redhat.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-03-05tracing: rename ftrace_printk() => trace_printk()Ingo Molnar
Impact: cleanup Use a more generic name - this also allows the prototype to move to kernel.h and be generally available to kernel developers who want to do some quick tracing. Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-03-04Merge branch 'core/locking' into tracing/ftraceIngo Molnar
2009-03-04Merge branch 'rfc/splice/tip/tracing/ftrace' of ↵Ingo Molnar
2009-03-04Merge branch 'tracing/ftrace'; commit 'v2.6.29-rc7' into tracing/coreIngo Molnar
2009-03-03ring-buffer: fix ring_buffer_read_pageSteven Rostedt
The ring_buffer_read_page was broken if it were to only copy part of the page. This patch fixes that up as well as adds a parameter to allow a length field, in order to only copy part of the buffer page. Signed-off-by: Steven Rostedt <srostedt@redhat.com>
2009-03-03Merge branch 'sched-fixes-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'sched-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: sched: don't allow setuid to succeed if the user does not have rt bandwidth sched_rt: don't start timer when rt bandwidth disabled
2009-03-03Merge branch 'core-fixes-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'core-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: rcu: Teach RCU that idle task is not quiscent state at boot
2009-03-02Merge branch 'x86-fixes-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'x86-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: fix warning in io_mapping_map_wc() x86: i915 needs pgprot_writecombine() and is_io_mapping_possible()
2009-03-02Merge branch 'tip/tracing/ftrace' of ↵Ingo Molnar
2009-03-02tracing: make CALLER_ADDRx overwriteableUwe Kleine-Koenig
The current definition of CALLER_ADDRx isn't suitable for all platforms. E.g. for ARM __builtin_return_address(N) doesn't work for N > 0 and AFAIK for powerpc there are no frame pointers needed to have a working __builtin_return_address. This patch allows defining the CALLER_ADDRx macros in <asm/ftrace.h> and let these take precedence. Because now <asm/ftrace.h> is included unconditionally in <linux/ftrace.h> all archs that don't already had this include get an empty one for free. Signed-off-by: Uwe Kleine-Koenig <u.kleine-koenig@pengutronix.de> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Ingo Molnar <mingo@elte.hu> Reviewed-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Signed-off-by: Steven Rostedt <srostedt@redhat.com>
2009-03-02Merge branches 'tracing/ftrace', 'tracing/mmiotrace' and 'linus' into ↵Ingo Molnar
tracing/core
2009-03-02fix warning in io_mapping_map_wc()Pallipadi, Venkatesh
Signed-off-by: Venkatesh Pallipadi <venkatesh.pallipadi@intel.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-03-01net headers: export dcbnl.hChris Leech
The DCB netlink interface is required for building the userspace tools available at e1000.sourceforge.net Signed-off-by: Chris Leech <christopher.leech@intel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-03-01net headers: cleanup dcbnl.hChris Leech
1) add an include for <linux/types.h> 2) change dcbmsg.dcb_family from unsigned char to __u8 to be more consistent with use of kernel types Signed-off-by: Chris Leech <christopher.leech@intel.com> Acked-by: Sam Ravnborg <sam@ravnborg.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-02-28Merge branch 'master' of /home/davem/src/GIT/linux-2.6/David S. Miller
2009-02-28Merge branch 'tip/tracing/ftrace' of ↵Ingo Molnar
2009-02-28tracing: create the C style tracing for the sched subsystemSteven Rostedt
This patch utilizes the TRACE_EVENT_FORMAT macro to enable the C style faster tracing for the sched subsystem trace points. Signed-off-by: Steven Rostedt <srostedt@redhat.com>
2009-02-27Merge branch 'x86-fixes-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'x86-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: x86: enable DMAR by default xen: disable interrupts early, as start_kernel expects gpu/drm, x86, PAT: io_mapping_create_wc and resource_size_t gpu/drm, x86, PAT: Handle io_mapping_create_wc() errors in a clean way x86, Voyager: fix compile by lifting the degeneracy of phys_cpu_present_map x86, doc: fix references to Documentation/x86/i386/boot.txt
2009-02-27Fix recursive lock in free_uid()/free_user_ns()David Howells
free_uid() and free_user_ns() are corecursive when CONFIG_USER_SCHED=n, but free_user_ns() is called from free_uid() by way of uid_hash_remove(), which requires uidhash_lock to be held. free_user_ns() then calls free_uid() to complete the destruction. Fix this by deferring the destruction of the user_namespace. Signed-off-by: David Howells <dhowells@redhat.com> Acked-by: Serge Hallyn <serue@us.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-02-27sched: don't allow setuid to succeed if the user does not have rt bandwidthDhaval Giani
Impact: fix hung task with certain (non-default) rt-limit settings Corey Hickey reported that on using setuid to change the uid of a rt process, the process would be unkillable and not be running. This is because there was no rt runtime for that user group. Add in a check to see if a user can attach an rt task to its task group. On failure, return EINVAL, which is also returned in CONFIG_CGROUP_SCHED. Reported-by: Corey Hickey <bugfood-ml@fatooh.org> Signed-off-by: Dhaval Giani <dhaval@linux.vnet.ibm.com> Acked-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-02-27Merge branches 'tracing/ftrace' and 'linus' into tracing/coreIngo Molnar
2009-02-27Merge branch 'sched/clock' into tracing/ftraceIngo Molnar
Conflicts: kernel/sched_clock.c
2009-02-26Merge branch 'sched/clock' into tracing/ftraceIngo Molnar
2009-02-26sched: allow architectures to specify sched_clock_stableIngo Molnar
Allow CONFIG_HAVE_UNSTABLE_SCHED_CLOCK architectures to still specify that their sched_clock() implementation is reliable. This will be used by x86 to switch on a faster sched_clock_cpu() implementation on certain CPU types. Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-02-26tracing: implement trace_clock_*() APIsIngo Molnar
Impact: implement new tracing timestamp APIs Add three trace clock variants, with differing scalability/precision tradeoffs: - local: CPU-local trace clock - medium: scalable global clock with some jitter - global: globally monotonic, serialized clock Make the ring-buffer use the local trace clock internally. Acked-by: Peter Zijlstra <peterz@infradead.org> Acked-by: Steven Rostedt <rostedt@goodmis.org> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-02-26block: reduce stack footprint of blk_recount_segments()Jens Axboe
blk_recalc_rq_segments() requires a request structure passed in, which we don't have from blk_recount_segments(). So the latter allocates one on the stack, using > 400 bytes of stack for that. This can cause us to spill over one page of stack from ext4 at least: 0) 4560 400 blk_recount_segments+0x43/0x62 1) 4160 32 bio_phys_segments+0x1c/0x24 2) 4128 32 blk_rq_bio_prep+0x2a/0xf9 3) 4096 32 init_request_from_bio+0xf9/0xfe 4) 4064 112 __make_request+0x33c/0x3f6 5) 3952 144 generic_make_request+0x2d1/0x321 6) 3808 64 submit_bio+0xb9/0xc3 7) 3744 48 submit_bh+0xea/0x10e 8) 3696 368 ext4_mb_init_cache+0x257/0xa6a [ext4] 9) 3328 288 ext4_mb_regular_allocator+0x421/0xcd9 [ext4] 10) 3040 160 ext4_mb_new_blocks+0x211/0x4b4 [ext4] 11) 2880 336 ext4_ext_get_blocks+0xb61/0xd45 [ext4] 12) 2544 96 ext4_get_blocks_wrap+0xf2/0x200 [ext4] 13) 2448 80 ext4_da_get_block_write+0x6e/0x16b [ext4] 14) 2368 352 mpage_da_map_blocks+0x7e/0x4b3 [ext4] 15) 2016 352 ext4_da_writepages+0x2ce/0x43c [ext4] 16) 1664 32 do_writepages+0x2d/0x3c 17) 1632 144 __writeback_single_inode+0x162/0x2cd 18) 1488 96 generic_sync_sb_inodes+0x1e3/0x32b 19) 1392 16 sync_sb_inodes+0xe/0x10 20) 1376 48 writeback_inodes+0x69/0xb3 21) 1328 208 balance_dirty_pages_ratelimited_nr+0x187/0x2f9 22) 1120 224 generic_file_buffered_write+0x1d4/0x2c4 23) 896 176 __generic_file_aio_write_nolock+0x35f/0x393 24) 720 80 generic_file_aio_write+0x6c/0xc8 25) 640 80 ext4_file_write+0xa9/0x137 [ext4] 26) 560 320 do_sync_write+0xf0/0x137 27) 240 48 vfs_write+0xb3/0x13c 28) 192 64 sys_write+0x4c/0x74 29) 128 128 system_call_fastpath+0x16/0x1b Split the segment counting out into a __blk_recalc_rq_segments() helper to avoid allocating an onstack request just for checking the physical segment count. Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2009-02-26rcu: Teach RCU that idle task is not quiscent state at bootPaul E. McKenney
This patch fixes a bug located by Vegard Nossum with the aid of kmemcheck, updated based on review comments from Nick Piggin, Ingo Molnar, and Andrew Morton. And cleans up the variable-name and function-name language. ;-) The boot CPU runs in the context of its idle thread during boot-up. During this time, idle_cpu(0) will always return nonzero, which will fool Classic and Hierarchical RCU into deciding that a large chunk of the boot-up sequence is a big long quiescent state. This in turn causes RCU to prematurely end grace periods during this time. This patch changes the rcutree.c and rcuclassic.c rcu_check_callbacks() function to ignore the idle task as a quiescent state until the system has started up the scheduler in rest_init(), introducing a new non-API function rcu_idle_now_means_idle() to inform RCU of this transition. RCU maintains an internal rcu_idle_cpu_truthful variable to track this state, which is then used by rcu_check_callback() to determine if it should believe idle_cpu(). Because this patch has the effect of disallowing RCU grace periods during long stretches of the boot-up sequence, this patch also introduces Josh Triplett's UP-only optimization that makes synchronize_rcu() be a no-op if num_online_cpus() returns 1. This allows boot-time code that calls synchronize_rcu() to proceed normally. Note, however, that RCU callbacks registered by call_rcu() will likely queue up until later in the boot sequence. Although rcuclassic and rcutree can also use this same optimization after boot completes, rcupreempt must restrict its use of this optimization to the portion of the boot sequence before the scheduler starts up, given that an rcupreempt RCU read-side critical section may be preeempted. In addition, this patch takes Nick Piggin's suggestion to make the system_state global variable be __read_mostly. Changes since v4: o Changes the name of the introduced function and variable to be less emotional. ;-) Changes since v3: o WARN_ON(nr_context_switches() > 0) to verify that RCU switches out of boot-time mode before the first context switch, as suggested by Nick Piggin. Changes since v2: o Created rcu_blocking_is_gp() internal-to-RCU API that determines whether a call to synchronize_rcu() is itself a grace period. o The definition of rcu_blocking_is_gp() for rcuclassic and rcutree checks to see if but a single CPU is online. o The definition of rcu_blocking_is_gp() for rcupreempt checks to see both if but a single CPU is online and if the system is still in early boot. This allows rcupreempt to again work correctly if running on a single CPU after booting is complete. o Added check to rcupreempt's synchronize_sched() for there being but one online CPU. Tested all three variants both SMP and !SMP, booted fine, passed a short rcutorture test on both x86 and Power. Located-by: Vegard Nossum <vegard.nossum@gmail.com> Tested-by: Vegard Nossum <vegard.nossum@gmail.com> Tested-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Signed-off-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-02-26Merge branch 'tip/tracing/ftrace' of ↵Ingo Molnar
ssh://master.kernel.org/pub/scm/linux/kernel/git/rostedt/linux-2.6-trace into tracing/ftrace
2009-02-26Merge branches 'tracing/ftrace', 'tracing/hw-branch-tracing' and 'linus' ↵Ingo Molnar
into tracing/core
2009-02-25tracing: wrap arguments with PARAMSSteven Rostedt
Peter Zijlstra warned that TPPROTO and TPARGS might become something other than a simple copy of itself. To prevent this from having side effects in the TRACE_FORMAT macro in tracepoint.h, we add a PARAMS() macro to be defined as just a wrapper. Reported-by: Peter Zijlstra <peterz@infradead.org> Signed-off-by: Steven Rostedt <srostedt@redhat.com>
2009-02-25tracing: rename DEFINE_TRACE_FMT to just TRACE_FORMATSteven Rostedt
There's been a bit confusion to whether DEFINE/DECLARE_TRACE_FMT should be a DEFINE or a DECLARE. Ingo Molnar suggested simply calling it TRACE_FORMAT. Reported-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Steven Rostedt <srostedt@redhat.com>
2009-02-25ide: fix refcounting in device driversBartlomiej Zolnierkiewicz
During host driver module removal del_gendisk() results in a final put on drive->gendev and freeing the drive by drive_release_dev(). Convert device drivers from using struct kref to use struct device so device driver's object holds reference on ->gendev and prevents drive from prematurely going away. Also fix ->remove methods to not erroneously drop reference on a host driver by using only put_device() instead of ide*_put(). Reported-by: Stanislaw Gruszka <stf_xl@wp.pl> Tested-by: Stanislaw Gruszka <stf_xl@wp.pl> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2009-02-25Merge git://git.infradead.org/iommu-2.6Linus Torvalds
* git://git.infradead.org/iommu-2.6: intel-iommu: fix endless "Unknown DMAR structure type" loop VT-d: handle Invalidation Queue Error to avoid system hang intel-iommu: fix build error with INTR_REMAP=y and DMAR=n
2009-02-25gpu/drm, x86, PAT: io_mapping_create_wc and resource_size_tVenkatesh Pallipadi
io_mapping_create_wc should take a resource_size_t parameter in place of unsigned long. With unsigned long, there will be no way to map greater than 4GB address in i386/32 bit. On x86, greater than 4GB addresses cannot be mapped on i386 without PAE. Return error for such a case. Patch also adds a structure for io_mapping, that saves the base, size and type on HAVE_ATOMIC_IOMAP archs, that can be used to verify the offset on io_mapping_map calls. Signed-off-by: Venkatesh Pallipadi <venkatesh.pallipadi@intel.com> Signed-off-by: Suresh Siddha <suresh.b.siddha@intel.com> Cc: Dave Airlie <airlied@redhat.com> Cc: Jesse Barnes <jbarnes@virtuousgeek.org> Cc: Eric Anholt <eric@anholt.net> Cc: Keith Packard <keithp@keithp.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
