path: root/include/linux
2006-12-01Merge git://git.kernel.org/pub/scm/linux/kernel/git/bunk/trivialLinus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/bunk/trivial: Fix typos in drivers/isdn/hisax/isdnl2.c Fix typos in doc and comments BUG_ON conversion for fs/aio.c BUG_ON conversion for drivers/mmc/omap.c BUG_ON conversion for drivers/media/video/pwc/pwc-if.c Fix misc .c/.h comment typos Fix misc Kconfig typos Fix typos in /Documentation : Misc Fix typos in /Documentation : 'U-Z' Fix typos in /Documentation : 'T'' Fix jiffies.h comment tabify MAINTAINERS fix spelling error in include/linux/kernel.h mqueue.h: don't include linux/types.h
2006-12-01[BLOCK] Cleanup unused variable passingJens Axboe
- ->init_queue() does not need the elevator passed in - ->put_request() is a hot path and need not have the queue passed in - cfq_update_io_seektime() does not need cfqd passed in Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2006-12-01[PATCH] block: support larger block pc requestsMike Christie
This patch modifies blk_rq_map/unmap_user() and the cdrom and scsi_ioctl.c users so that it supports requests larger than bio by chaining them together. Signed-off-by: Mike Christie <michaelc@cs.wisc.edu> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2006-12-01[PATCH] blktrace: add timestamp messageOlaf Kirch
This adds a new timestamp message to blktrace, giving the timeofday when we starting tracing. This helps user space correlate block trace events with eg an application strace. This requires a (compatible) update to blkparse. The changed blkparse is still able to process traces generated by older kernels, and older versions of blkparse should silently ignore the new records (because they have a pid of 0). Signed-off-by: Olaf Kirch <okir@suse.de> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2006-11-30Fix typos in doc and commentsJan Engelhardt
Changes persistant -> persistent. www.dictionary.com does not know persistant (with an A), but should it be one of those things you can spell in more than one correct way, let me know. Signed-off-by: Jan Engelhardt <jengelh@gmx.de> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2006-11-30Fix misc .c/.h comment typosMatt LaPlante
Fix various .c/.h typos in comments (no code changes). Signed-off-by: Matt LaPlante <kernel1@cyberdogtech.com> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2006-11-30Fix jiffies.h commentChase Venters
jiffies.h includes a comment informing that jiffies_64 must be read with the assistance of the xtime_lock seqlock. The comment text, however, calls jiffies_64 "not volatile", which should probably read "not atomic". Signed-off-by: Chase Venters <chase.venters@clientec.com> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2006-11-30fix spelling error in include/linux/kernel.hJim Cromie
2006-11-30mqueue.h: don't include linux/types.hAlexey Dobriyan
This #include is not required. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2006-11-28[NET]: Fix MAX_HEADER setting.David S. Miller
MAX_HEADER is either set to LL_MAX_HEADER or LL_MAX_HEADER + 48, and this is controlled by a set of CONFIG_* ifdef tests. It is trying to use LL_MAX_HEADER + 48 when any of the tunnels are enabled which set hard_header_len like this: dev->hard_header_len = LL_MAX_HEADER + sizeof(struct xxx); The correct set of tunnel drivers which do this are: ipip ip_gre ip6_tunnel sit so make the ifdef test match. Noticed by Patrick McHardy and with help from Herbert Xu. Signed-off-by: David S. Miller <davem@davemloft.net>
2006-11-26Fix 'ALIGN()' macro, take 2Linus Torvalds
You wouldn't think that doing an ALIGN() macro that aligns something up to a power-of-two boundary would be likely to have bugs, would you? But hey, in the wonderful world of mixing integer types, you have to be careful. This just makes sure that the alignment is interpreted in the same type as the thing to be aligned. Thanks to Roland Dreier, who noticed that the amso1100 driver got broken by the previous fix (that just extended the mask to "unsigned long", but was still broken in "unsigned long long" - it just happened to be the same on 64-bit architectures). See commit 4c8bd7eeee4c8f157fb61fb64b57500990b42e0e for the history of bugs here... Acked-by: Roland Dreier <rdreier@cisco.com> Cc: Andrew Morton <akpm@osdl.org> Cc: David Miller <davem@davemloft.net> Cc: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-11-26Revert "[PATCH] Enforce "unsigned long flags;" when spinlocking"Linus Torvalds
This reverts commit ee3ce191e8eaa4cc15c51a28b34143b36404c4f5, since it broke on at least ARM, MIPS and PA-RISC due to complicated header file dependencies. Conflicts in include/linux/spinlock.h (due to the "nested" variety fixes) fixed up by hand. Cc: Alexey Dobriyan <adobriyan@gmail.com> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: Kyle McMartin <kyle@parisc-linux.org> Cc: Russell King <rmk+lkml@arm.linux.org.uk> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-11-25[PATCH] lockdep: spin_lock_irqsave_nested()Arjan van de Ven
Introduce spin_lock_irqsave_nested(); implementation from: http://lkml.org/lkml/2006/6/1/122 Patch from: http://lkml.org/lkml/2006/9/13/258 [akpm@osdl.org: two compile fixes] Signed-off-by: Arjan van de Ven <arjan@linux.intel.com> Signed-off-by: Jiri Kosina <jikos@jikos.cz> Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Acked-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-11-25[PATCH] Enforce "unsigned long flags;" when spinlockingAlexey Dobriyan
Make it break or warn if you pass to spin_lock_irqsave() and friends something different from "unsigned long flags;". Suprisingly large amount of these was caught by recent commit c53421b18f205c5f97c604ae55c6a921f034b0f6 and others. Idea is largely from FRV typechecking. Suggestions from Andrew Morton. All stupid typos in first version fixed. Passes allmodconfig on i386, x86_64, alpha, arm as well as my usual config. Note #1: checking with sparse is still needed, because a driver can save and pass around flags or something. So far patch is very intrusive. Note #2: techically, we should break only if sizeof(flags) < sizeof(unsigned long), however, the more pain for getting suspicious code into kernel, the better. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Cc: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-11-25[PATCH] mounstats NULL pointer dereferenceVasily Tarasov
OpenVZ developers team has encountered the following problem in 2.6.19-rc6 kernel. After some seconds of running script while [[ 1 ]] do find /proc -name mountstats | xargs cat done this Oops appears: BUG: unable to handle kernel NULL pointer dereference at virtual address 00000010 printing eip: c01a6b70 *pde = 00000000 Oops: 0000 [#1] SMP Modules linked in: xt_length ipt_ttl xt_tcpmss ipt_TCPMSS iptable_mangle iptable_filter xt_multiport xt_limit ipt_tos ipt_REJECT ip_tables x_tables parport_pc lp parport sunrpc af_packet thermal processor fan button battery asus_acpi ac ohci_hcd ehci_hcd usbcore i2c_nforce2 i2c_core tg3 floppy pata_amd ide_cd cdrom sata_nv libata CPU: 1 EIP: 0060:[<c01a6b70>] Not tainted VLI EFLAGS: 00010246 (2.6.19-rc6 #2) EIP is at mountstats_open+0x70/0xf0 eax: 00000000 ebx: e6247030 ecx: e62470f8 edx: 00000000 esi: 00000000 edi: c01a6b00 ebp: c33b83c0 esp: f4105eb4 ds: 007b es: 007b ss: 0068 Process cat (pid: 6044, ti=f4105000 task=f4104a70 task.ti=f4105000) Stack: c33b83c0 c04ee940 f46a4a80 c33b83c0 e4df31b4 c01a6b00 f4105000 c0169231 e4df31b4 c33b83c0 c33b83c0 f4105f20 00000003 f4105000 c0169445 f2503cf0 f7f8c4c0 00008000 c33b83c0 00000000 00008000 c0169350 f4105f20 00008000 Call Trace: [<c01a6b00>] mountstats_open+0x0/0xf0 [<c0169231>] __dentry_open+0x181/0x250 [<c0169445>] nameidata_to_filp+0x35/0x50 [<c0169350>] do_filp_open+0x50/0x60 [<c01873d6>] seq_read+0xc6/0x300 [<c0169511>] get_unused_fd+0x31/0xc0 [<c01696d3>] do_sys_open+0x63/0x110 [<c01697a7>] sys_open+0x27/0x30 [<c01030bd>] sysenter_past_esp+0x56/0x79 ======================= Code: 45 74 8b 54 24 20 89 44 24 08 8b 42 f0 31 d2 e8 47 cb f8 ff 85 c0 89 c3 74 51 8d 80 a0 04 00 00 e8 46 06 2c 00 8b 83 48 04 00 00 <8b> 78 10 85 ff 74 03 f0 ff 07 b0 01 86 83 a0 04 00 00 f0 ff 4b EIP: [<c01a6b70>] mountstats_open+0x70/0xf0 SS:ESP 0068:f4105eb4 The problem is that task->nsproxy can be equal NULL for some time during task exit. This patch fixes the BUG. Signed-off-by: Vasily Tarasov <vtaras@openvz.org> Cc: Herbert Poetzl <herbert@13thfloor.at> Cc: "Serge E. Hallyn" <serue@us.ibm.com> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-11-21[IGMP]: Fix IGMPV3_EXP() normalization bit shift value.David L Stevens
The IGMPV3_EXP() macro doesn't correctly shift the normalization bit, so time-out values are longer than they should be. Thanks to Dirk Ooms for finding the problem in IGMPv3 - MLDv2 had a similar problem that was already fixed a year ago. :-( Signed-off-by: David L Stevens <dlstevens@us.ibm.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-11-20Add "pure_initcall" for static variable initializationLinus Torvalds
This is a quick hack to overcome the fact that SRCU currently does not allow static initializers, and we need to sometimes initialize those things before any other initializers (even "core" ones) can do so. Currently we don't allow this at all for modules, and the only user that needs is right now is cpufreq. As reported by Thomas Gleixner: "Commit b4dfdbb3c707474a2254c5b4d7e62be31a4b7da9 ("[PATCH] cpufreq: make the transition_notifier chain use SRCU breaks cpu frequency notification users, which register the callback > on core_init level." Cc: Thomas Gleixner <tglx@timesys.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Arjan van de Ven <arjan@infradead.org> Cc: Andrew Morton <akpm@osdl.org>, Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-11-20[CRYPTO] api: Remove one too many semicolonYoichi Yuasa
This patch has removed one too many semicolon in crypto.h. Signed-off-by: Yoichi Yuasa <yoichi_yuasa@tripeaks.co.jp> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2006-11-16Merge master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6Linus Torvalds
* master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6: [TG3]: Disable TSO on 5906 if CLKREQ is enabled. [TCP]: Fix up sysctl_tcp_mem initialization. [NETFILTER]: ip6_tables: use correct nexthdr value in ipv6_find_hdr() [NETFILTER]: ip6_tables: fixed conflicted optname for getsockopt [NETFILTER]: Use pskb_trim in {ip,ip6,nfnetlink}_queue [NETFILTER]: nfnetlink_log: fix byteorder of NFULA_SEQ_GLOBAL [TG3]: Increase 5906 firmware poll time.
2006-11-16[PATCH] fat: add fat_getattr()OGAWA Hirofumi
This adds fat_getattr() for setting stat->blksize. (FAT uses the size of cluster for proper I/O) Signed-off-by: OGAWA Hirofumi <hirofumi@mail.parknet.co.jp> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-11-15[TG3]: Disable TSO on 5906 if CLKREQ is enabled.Michael Chan
Due to hardware errata, TSO must be disabled if the PCI Express clock request is enabled on 5906. The chip may hang when transmitting TSO frames if CLKREQ is enabled. Update version to 3.69. Signed-off-by: Michael Chan <mchan@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-11-15[NETFILTER]: ip6_tables: fixed conflicted optname for getsockoptYasuyuki Kozakai
66 and 67 for getsockopt on IPv6 socket is doubly used for IPv6 Advanced API and ip6tables. This moves numbers for ip6tables to 68 and 69. This also kills XT_SO_* because {ip,ip6,arp}_tables doesn't have so much common numbers now. The old userland tools keep to behave as ever, because old kernel always calls functions of IPv6 Advanced API for their numbers. Signed-off-by: Yasuyuki Kozakai <yasuyuki.kozakai@toshiba.co.jp> Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-11-14[PATCH] hugetlb: prepare_hugepage_range check offset tooHugh Dickins
(David:) If hugetlbfs_file_mmap() returns a failure to do_mmap_pgoff() - for example, because the given file offset is not hugepage aligned - then do_mmap_pgoff will go to the unmap_and_free_vma backout path. But at this stage the vma hasn't been marked as hugepage, and the backout path will call unmap_region() on it. That will eventually call down to the non-hugepage version of unmap_page_range(). On ppc64, at least, that will cause serious problems if there are any existing hugepage pagetable entries in the vicinity - for example if there are any other hugepage mappings under the same PUD. unmap_page_range() will trigger a bad_pud() on the hugepage pud entries. I suspect this will also cause bad problems on ia64, though I don't have a machine to test it on. (Hugh:) prepare_hugepage_range() should check file offset alignment when it checks virtual address and length, to stop MAP_FIXED with a bad huge offset from unmapping before it fails further down. PowerPC should apply the same prepare_hugepage_range alignment checks as ia64 and all the others do. Then none of the alignment checks in hugetlbfs_file_mmap are required (nor is the check for too small a mapping); but even so, move up setting of VM_HUGETLB and add a comment to warn of what David Gibson discovered - if hugetlbfs_file_mmap fails before setting it, do_mmap_pgoff's unmap_region when unwinding from error will go the non-huge way, which may cause bad behaviour on architectures (powerpc and ia64) which segregate their huge mappings into a separate region of the address space. Signed-off-by: Hugh Dickins <hugh@veritas.com> Cc: "Luck, Tony" <tony.luck@intel.com> Cc: "David S. Miller" <davem@davemloft.net> Acked-by: Adam Litke <agl@us.ibm.com> Acked-by: David Gibson <david@gibson.dropbear.id.au> Cc: Paul Mackerras <paulus@samba.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-11-13[PATCH] Fix missing parens in set_personality()Russell King
If you call set_personality() with an expression such as: set_personality(foo ? PERS_FOO1 : PERS_FOO2); then this evaluates to: ((current->personality == foo ? PERS_FOO1 : PERS_FOO2) ? ... which is obviously not the intended result. Add the missing parents to ensure this gets evaluated as expected: ((current->personality == (foo ? PERS_FOO1 : PERS_FOO2)) ? ... Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-11-13[PATCH] vmalloc: optimization, cleanup, bugfixesEric Dumazet
- reorder 'struct vm_struct' to speedup lookups on CPUS with small cache lines. The fields 'next,addr,size' should be now in the same cache line, to speedup lookups. - One minor cleanup in __get_vm_area_node() - Bugfixes in vmalloc_user() and vmalloc_32_user() NULL returns from __vmalloc() and __find_vm_area() were not tested. [akpm@osdl.org: remove redundant BUG_ONs] Signed-off-by: Eric Dumazet <dada1@cosmosbay.com> Cc: Nick Piggin <nickpiggin@yahoo.com.au> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-11-08[PATCH] htirq: allow buggy drivers of buggy hardware to write the registersEric W. Biederman
This patch adds a variant of ht_create_irq __ht_create_irq that takes an aditional parameter update that is a function that is called whenever we want to write to a drivers htirq configuration registers. This is needed to support the ipath_iba6110 because it's registers in the proper location are not actually conected to the hardware that controlls interrupt delivery. [bos@serpentine.com: fixes] Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Cc: Andi Kleen <ak@suse.de> Cc: <olson@pathscale.com> Cc: Roland Dreier <rolandd@cisco.com> Signed-off-by: Bryan O'Sullivan <bryan.osullivan@qlogic.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-11-08[PATCH] htirq: refactor so we only have one function that writes to the chipEric W. Biederman
This refactoring actually optimizes the code a little by caching the value that we think the device is programmed with instead of reading it back from the hardware. Which simplifies the code a little and should speed things up a bit. This patch introduces the concept of a ht_irq_msg and modifies the architecture read/write routines to update this code. There is a minor consistency fix here as well as x86_64 forgot to initialize the htirq as masked. Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Cc: Andi Kleen <ak@suse.de> Acked-by: Bryan O'Sullivan <bos@pathscale.com> Cc: <olson@pathscale.com> Cc: Roland Dreier <rolandd@cisco.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-11-08[PATCH] IPMI: retry messages on certain error returnsCorey Minyard
Some more errors from the IPMI send message command are retryable, but are not being retried by the IPMI code. Make sure they get retried. Signed-off-by: Corey Minyard <minyard@acm.org> Cc: Frederic Lelievre <Frederic.Lelievre@ca.kontron.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-11-08[PATCH] nfsd4: fix open-create permissionsJ. Bruce Fields
In the case where an open creates the file, we shouldn't be rechecking permissions to open the file; the open succeeds regardless of what the new file's mode bits say. This patch fixes the problem, but only by introducing yet another parameter to nfsd_create_v3. This is ugly. This will be fixed by later patches. Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu> Acked-by: Neil Brown <neilb@suse.de> Cc: Jeff Garzik <jeff@garzik.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-11-06[PATCH] sysctl: implement CTL_UNNUMBEREDEric W. Biederman
This patch takes the CTL_UNNUMBERD concept from NFS and makes it available to all new sysctl users. At the same time the sysctl binary interface maintenance documentation is updated to mention and to describe what is needed to successfully maintain the sysctl binary interface. Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Acked-by: Alan Cox <alan@redhat.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-11-06[PATCH] sysctl: allow a zero ctl_name in the middle of a sysctl tableEric W. Biederman
Since it is becoming clear that there are just enough users of the binary sysctl interface that completely removing the binary interface from the kernel will not be an option for foreseeable future, we need to find a way to address the sysctl maintenance issues. The basic problem is that sysctl requires one central authority to allocate sysctl numbers, or else conflicts and ABI breakage occur. The proc interface to sysctl does not have that problem, as names are not densely allocated. By not terminating a sysctl table until I have neither a ctl_name nor a procname, it becomes simple to add sysctl entries that don't show up in the binary sysctl interface. Which allows people to avoid allocating a binary sysctl value when not needed. I have audited the kernel code and in my reading I have not found a single sysctl table that wasn't terminated by a completely zero filled entry. So this change in behavior should not affect anything. I think this mechanism eases the pain enough that combined with a little disciple we can solve the reoccurring sysctl ABI breakage. Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Acked-by: Alan Cox <alan@redhat.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-11-05[IPX]: Trivial parts of endianness annotationsAl Viro
Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-11-03[PATCH] Create compat_sys_migrate_pagesStephen Rothwell
This is needed on bigendian 64bit architectures. Signed-off-by: Stephen Rothwell <sfr@canb.auug.org.au> Acked-by: Christoph Lameter <clameter@sgi.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-11-03[PATCH] swsusp: debuggingRafael J. Wysocki
Add a swsusp debugging mode. This does everything that's needed for a suspend except for actually suspending. So we can look in the log messages and work out a) what code is being slow and b) which drivers are misbehaving. (1) # echo testproc > /sys/power/disk # echo disk > /sys/power/state This should turn off the non-boot CPU, freeze all processes, wait for 5 seconds and then thaw the processes and the CPU. (2) # echo test > /sys/power/disk # echo disk > /sys/power/state This should turn off the non-boot CPU, freeze all processes, shrink memory, suspend all devices, wait for 5 seconds, resume the devices etc. Cc: Pavel Machek <pavel@ucw.cz> Cc: Stefan Seyfried <seife@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-11-03[PATCH] Add printk_timed_ratelimit()Andrew Morton
printk_ratelimit() has global state which makes it not useful for callers which wish to perform ratelimiting at a particular frequency. Add a printk_timed_ratelimit() which utilises caller-provided state storage to permit more flexibility. This function can in fact be used for things other than printk ratelimiting and is perhaps poorly named. Cc: Ulrich Drepper <drepper@redhat.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Rusty Russell <rusty@rustcorp.com.au> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-11-03[PATCH] fix UFS superblock alignment issuesEric Sandeen
ufs2 fails to mount on x86_64, claiming bad magic. This is because ufs_super_block_third's fs_un1 member is padded out by 4 bytes for 8-byte alignment, pushing down the rest of the struct. Forcing this to be packed solves it. I took a quick look over other on-disk structures and didn't immediately find other problems. I was able to mount & ls a populated ufs2 filesystem w/ this change. Signed-off-by: Eric Sandeen <sandeen@redhat.com> Cc: Evgeniy Dushistov <dushistov@mail.ru> Cc: <stable@kernel.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-11-02pci_ids.h: Add NVIDIA PCI IDPeer Chen
Signed-off-by: Jeff Garzik <jeff@garzik.org>
2006-10-31[PATCH] libata: unexport ata_dev_revalidate()Tejun Heo
ata_dev_revalidate() isn't used outside of libata core. Unexport it. Signed-off-by: Tejun Heo <htejun@gmail.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2006-10-30[PATCH] MTD: fix last kernel-doc warningRandy Dunlap
Fix the last current kernel-doc warning: Warning(/var/linsrc/linux-2619-rc3g5//include/linux/mtd/nand.h:416): No description found for parameter 'write_page' Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Cc: David Woodhouse <dwmw2@infradead.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-30[PATCH] lockdep: annotate DECLARE_WAIT_QUEUE_HEADPeter Zijlstra
kernel: INFO: trying to register non-static key. kernel: the code is fine but needs lockdep annotation. kernel: turning off the locking correctness validator. kernel: [<c04051ed>] show_trace_log_lvl+0x58/0x16a kernel: [<c04057fa>] show_trace+0xd/0x10 kernel: [<c0405913>] dump_stack+0x19/0x1b kernel: [<c043b1e2>] __lock_acquire+0xf0/0x90d kernel: [<c043bf70>] lock_acquire+0x4b/0x6b kernel: [<c061472f>] _spin_lock_irqsave+0x22/0x32 kernel: [<c04363d3>] prepare_to_wait+0x17/0x4b kernel: [<f89a24b6>] lpfc_do_work+0xdd/0xcc2 [lpfc] kernel: [<c04361b9>] kthread+0xc3/0xf2 kernel: [<c0402005>] kernel_thread_helper+0x5/0xb Another case of non-static lockdep keys; duplicate the paradigm set by DECLARE_COMPLETION_ONSTACK and introduce DECLARE_WAIT_QUEUE_HEAD_ONSTACK. Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Greg KH <gregkh@suse.de> Cc: Markus Lidel <markus.lidel@shadowconnect.com> Acked-by: Ingo Molnar <mingo@elte.hu> Cc: Arjan van de Ven <arjan@infradead.org> Cc: James Bottomley <James.Bottomley@steeleye.com> Cc: Marcel Holtmann <marcel@holtmann.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-28[PATCH] taskstats: kill ->taskstats_lock in favor of ->siglockOleg Nesterov
signal_struct is (mostly) protected by ->sighand->siglock, I think we don't need ->taskstats_lock to protect ->stats. This also allows us to simplify the locking in fill_tgid(). Signed-off-by: Oleg Nesterov <oleg@tv-sign.ru> Cc: Shailabh Nagar <nagar@watson.ibm.com> Cc: Balbir Singh <balbir@in.ibm.com> Cc: Jay Lan <jlan@sgi.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-28[PATCH] taskstats_tgid_alloc: optimizationOleg Nesterov
Every subthread (except first) does unneeded kmem_cache_alloc/kmem_cache_free. Signed-off-by: Oleg Nesterov <oleg@tv-sign.ru> Cc: Shailabh Nagar <nagar@watson.ibm.com> Cc: Balbir Singh <balbir@in.ibm.com> Cc: Jay Lan <jlan@sgi.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-28[PATCH] taskstats_tgid_free: fix usageOleg Nesterov
taskstats_tgid_free() is called on copy_process's error path. This is wrong. IF (clone_flags & CLONE_THREAD) We should not clear ->signal->taskstats, current uses it, it probably has a valid accumulated info. ELSE taskstats_tgid_init() set ->signal->taskstats = NULL, there is nothing to free. Move the callsite to __exit_signal(). We don't need any locking, entire thread group is exiting, nobody should have a reference to soon to be released ->signal. Signed-off-by: Oleg Nesterov <oleg@tv-sign.ru> Cc: Shailabh Nagar <nagar@watson.ibm.com> Cc: Balbir Singh <balbir@in.ibm.com> Cc: Jay Lan <jlan@sgi.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-28[PATCH] Constify compat_get_bitmap argumentStephen Rothwell
This means we can call it when the bitmap we want to fetch is declared const. Signed-off-by: Stephen Rothwell <sfr@canb.auug.org.au> Cc: Christoph Lameter <clameter@engr.sgi.com> Cc: Paul Jackson <pj@sgi.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-28[PATCH] __vmalloc with GFP_ATOMIC causes 'sleeping from invalid context'Giridhar Pemmasani
If __vmalloc is called to allocate memory with GFP_ATOMIC in atomic context, the chain of calls results in __get_vm_area_node allocating memory for vm_struct with GFP_KERNEL, causing the 'sleeping from invalid context' warning. This patch fixes it by passing the gfp flags along so __get_vm_area_node allocates memory for vm_struct with the same flags. Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-28[PATCH] vmscan: Fix temp_priority raceMartin Bligh
The temp_priority field in zone is racy, as we can walk through a reclaim path, and just before we copy it into prev_priority, it can be overwritten (say with DEF_PRIORITY) by another reclaimer. The same bug is contained in both try_to_free_pages and balance_pgdat, but it is fixed slightly differently. In balance_pgdat, we keep a separate priority record per zone in a local array. In try_to_free_pages there is no need to do this, as the priority level is the same for all zones that we reclaim from. Impact of this bug is that temp_priority is copied into prev_priority, and setting this artificially high causes reclaimers to set distress artificially low. They then fail to reclaim mapped pages, when they are, in fact, under severe memory pressure (their priority may be as low as 0). This causes the OOM killer to fire incorrectly. From: Andrew Morton <akpm@osdl.org> __zone_reclaim() isn't modifying zone->prev_priority. But zone->prev_priority is used in the decision whether or not to bring mapped pages onto the inactive list. Hence there's a risk here that __zone_reclaim() will fail because zone->prev_priority ir large (ie: low urgency) and lots of mapped pages end up stuck on the active list. Fix that up by decreasing (ie making more urgent) zone->prev_priority as __zone_reclaim() scans the zone's pages. This bug perhaps explains why ZONE_RECLAIM_PRIORITY was created. It should be possible to remove that now, and to just start out at DEF_PRIORITY? Cc: Nick Piggin <nickpiggin@yahoo.com.au> Cc: Christoph Lameter <clameter@engr.sgi.com> Cc: <stable@kernel.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-28[PATCH] mm: clean up pagecache allocationNick Piggin
- Consolidate page_cache_alloc - Fix splice: only the pagecache pages and filesystem data need to use mapping_gfp_mask. - Fix grab_cache_page_nowait: same as splice, also honour NUMA placement. Signed-off-by: Nick Piggin <npiggin@suse.de> Cc: Jens Axboe <jens.axboe@oracle.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-27[PATCH] drivers: wait for threaded probes between initcall levelsAndrew Morton
The multithreaded-probing code has a problem: after one initcall level (eg, core_initcall) has been processed, we will then start processing the next level (postcore_initcall) while the kernel threads which are handling core_initcall are still executing. This breaks the guarantees which the layered initcalls previously gave us. IOW, we want to be multithreaded _within_ an initcall level, but not between different levels. Fix that up by causing the probing code to wait for all outstanding probes at one level to complete before we start processing the next level. Cc: Greg KH <greg@kroah.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-23[PATCH] Remove __must_check for device_for_each_child()Russell King
Eliminate more __must_check madness. The return code from device_for_each_child() depends on the values which the helper function returns. If the helper function always returns zero, it's utterly pointless to check the return code from device_for_each_child(). The only code which knows if the return value should be checked is the caller itself, so forcing the return code to always be checked is silly. Hence, remove the __must_check annotation. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-21Merge branch 'upstream-linus' of ↵Linus Torvalds
master.kernel.org:/pub/scm/linux/kernel/git/jgarzik/libata-dev * 'upstream-linus' of master.kernel.org:/pub/scm/linux/kernel/git/jgarzik/libata-dev: [PATCH] libata-sff: Allow for wacky systems [PATCH] ahci: readability tweak [PATCH] libata: typo fix [PATCH] ATA must depend on BLOCK [PATCH] libata: use correct map_db values for ICH8
