Both avg_overlap and avg_wakeup had an inherent problem in that their accuracy
was detrimentally affected by cross-cpu wakeups, this because we are missing
the necessary call to update_curr(). This can't be fixed without increasing
overhead in our already too fat fastpath.
Additionally, with recent load balancing changes making us prefer to place tasks
in an idle cache domain (which is good for compute bound loads), communicating
tasks suffer when a sync wakeup, which would enable affine placement, is turned
into a non-sync wakeup by SYNC_LESS. With one task on the runqueue, wake_affine()
rejects the affine wakeup request, leaving the unfortunate where placed, taking
frequent cache misses.
Remove it, and recover some fastpath cycles.
Signed-off-by: Mike Galbraith <efault@gmx.de>
LKML-Reference: <1268301121.6785.30.camel@marge.simson.net>
Testing the load which led to this heuristic (nfs4 kbuild) shows that it has
outlived it's usefullness. With intervening load balancing changes, I cannot
see any difference with/without, so recover there fastpath cycles.
LKML-Reference: <1268301062.6785.29.camel@marge.simson.net>
Entering nohz code on every micro-idle is costing ~10% throughput for netperf
TCP_RR when scheduling cross-cpu. Rate limiting entry fixes this, but raises
ticks a bit. On my Q6600, an idle box goes from ~85 interrupts/sec to 128.
The higher the context switch rate, the more nohz entry costs. With this patch
and some cycle recovery patches in my tree, max cross cpu context switch rate is
improved by ~16%, a large portion of which of which is this ratelimiting.
LKML-Reference: <1268301003.6785.28.camel@marge.simson.net>
Put all statistic fields of sched_entity in one struct, sched_statistics,
and embed it into sched_entity.
This change allows to memset the sched_statistics to 0 when needed (for
instance when forking), avoiding bugs of non initialized fields.
Signed-off-by: Lucas De Marchi <lucas.de.marchi@gmail.com>
LKML-Reference: <1268275065-18542-1-git-send-email-lucas.de.marchi@gmail.com>
git://git.kernel.org/pub/scm/linux/kernel/git/khilman/linux-davinci
* 'davinci-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/khilman/linux-davinci: (40 commits)
DaVinci DM365: Adding support for SPI EEPROM
DaVinci DM365: Adding DM365 SPI support
DaVinci DM355: Modifications to DM355 SPI support
DaVinci: SPI: Adding header file for SPI support.
davinci: dm646x: CDCE clocks: davinci_clk converted to clk_lookup
davinci: clkdev cleanup: remove clk_lookup wrapper, use clkdev_add_table()
DaVinci: DM365: Voice codec support for the DM365 SoC
davinci: clock: let clk->set_rate function sleep
Add SDA and SCL pin numbers to i2c platform data
davinci: da8xx/omap-l1xx: Add EDMA platform data for da850/omap-l138
davinci: build list of unused EDMA events dynamically
davinci: Fix edma_alloc_channel api for EDMA_CHANNEL_ANY case
davinci: Keep count of channel controllers on a platform
davinci: Correct return value of edma_alloc_channel api
davinci: add CDCE949 support on DM6467 EVM
davinci: add support for CDCE949 clock synthesizer
davinci: da850/omap-l138 EVM: register for suspend support
davinci: da850/omap-l138: add support for SoC suspend
davinci: add power management support
DaVinci: DM365: Changing default queue for DM365.
git://git.kernel.org/pub/scm/linux/kernel/git/jgarzik/libata-dev
* 'upstream-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jgarzik/libata-dev: (38 commits)
sata_via: Delay on vt6420 when starting ATAPI DMA write
ata: Detect Delkin Devices compact flash
pata_efar: Enable parallel scanning
pata_atiixp: enable parallel scan
[libata] pata_atiixp: add locking for parallel scanning
[libata] pata_efar: add locking for parallel scanning
libata: Pass host flags into the pci helper
[libata] pata_marvell: CONFIG_AHCI is really CONFIG_SATA_AHCI
libata: Allow pata_legacy to be built on non-ISA but PCI systems
pata_pdc202xx_old: fix UDMA mode for PDC2026x chipsets
pata_pdc202xx_old: fix UDMA mode for Promise UDMA33 cards
[libata] pata_at91: fix backslash-continued string
pata_via: store UDMA masks in via_isa_bridges table
pata_via: fix address setup timings underlocking
pata_serverworks: fix error message
pata_serverworks: fix PIO setup for the second channel
pata_efar: fix secondary port support
pata_cypress: fix PIO timings underclocking
pata_cs5535: use correct values for PIO1 and PIO2 data timings
pata_cmd64x: remove unused definitions
I have a Delkin Devices compact flash card that isn't being recognized using the
SATA/PATA drivers.
The card is recognized and works with the deprecated ATA drivers.
The error I am seeing is:
ata1.00: failed to IDENTIFY (device reports invalid type, err_mask=0x0)
I tracked it down to ata_id_is_cfa() in include/linux/ata.h.
The Delkin card has id[0] set to 0x844a and id[83] set to 0.
This isn't what the kernel expects and is probably incorrect.
The simplest work-around is to add a check for 0x844a to ata_id_is_cfa().
Signed-off-by: Ben Gardner <gardner.ben@gmail.com>
This allows parallel scan and the like to be set without having to stop
using the existing full helper functions. This patch merely adds the argument
and fixes up the callers. It doesn't undo the special cases already in the
tree or add any new parallel callers.
Signed-off-by: Alan Cox <alan@linux.intel.com>
Traditional IDE interface sucks in that it doesn't have a reliable IRQ
pending bit, so if the controller raises IRQ while the driver is
expecting it not to, the IRQ won't be cleared and eventually the IRQ
line will be killed by interrupt subsystem. Some controllers have
non-standard mechanism to indicate IRQ pending so that this condition
can be detected and worked around.
This patch adds an optional operation ->sff_irq_check() which will be
called for each port from the ata_sff_interrupt() if an unexpected
interrupt is received. If the operation returns %true,
->sff_check_status() and ->sff_irq_clear() will be cleared for the
port. Note that this doesn't mark the interrupt as handled so it
won't prevent IRQ subsystem from killing the IRQ if this mechanism
fails to clear the spurious IRQ.
This patch also implements ->sff_irq_check() for ata_piix. Note that
this adds slight overhead to shared IRQ operation as IRQs which are
destined for other controllers will trigger extra register accesses to
check whether IDE interrupt is pending but this solves rare screaming
IRQ cases and for some curious reason also helps weird BIOS related
glitch on Samsung n130 as reported in bko#14314.
http://bugzilla.kernel.org/show_bug.cgi?id=14314
* piix_base_ops dropped as suggested by Sergei.
* Spurious IRQ detection doesn't kick in anymore if polling qc is in
progress. This provides less protection but some controllers have
possible data corruption issues if the wrong register is accessed
while a command is in progress.
Reported-by: Johannes Stezenbach <js@sig21.net>
Reported-by: Hans Werner <hwerner4@gmx.de>
Cc: Alan Cox <alan@lxorguk.ukuu.org.uk>
Cc: Sergei Shtylyov <sshtylyov@ru.mvista.com>
git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input: (62 commits)
Input: atkbd - release previously reserved keycodes 248 - 254
Input: add KEY_WPS_BUTTON definition
Input: ads7846 - add regulator support
Input: winbond-cir - fix suspend/resume
Input: gamecon - use pr_err() and friends
Input: gamecon - constify some of the setup structures
Input: gamecon - simplify pad type handling
Input: gamecon - simplify coordinate calculation for PSX
Input: gamecon - fix some formatting issues
Input: gamecon - add rumble support for N64 pads
Input: wacom - add device type to device name string
Input: s3c24xx_ts - report touch only when stylus is down
Input: s3c24xx_ts - re-enable IRQ on resume
Input: wacom - constify product features data
Input: wacom - use per-device instance of wacom_features
Input: sh_keysc - enable building on SH-Mobile ARM
Input: wacom - get features from driver info
Input: rotary-encoder - set gpio direction for each requested gpio
Input: sh_keysc - update the driver with mode 6
Input: sh_keysc - switch to using bitmaps
* 'for-linus' of master.kernel.org:/home/rmk/linux-2.6-arm: (100 commits)
ARM: Eliminate decompressor -Dstatic= PIC hack
ARM: 5958/1: ARM: U300: fix inverted clk round rate
ARM: 5956/1: misplaced parentheses
ARM: 5955/1: ep93xx: move timer defines into core.c and document
ARM: 5954/1: ep93xx: move gpio interrupt support to gpio.c
ARM: 5953/1: ep93xx: fix broken build of clock.c
ARM: 5952/1: ARM: MM: Add ARM_L1_CACHE_SHIFT_6 for handle inside each ARCH Kconfig
ARM: 5949/1: NUC900 add gpio virtual memory map
ARM: 5948/1: Enable timer0 to time4 clock support for nuc910
ARM: 5940/2: ARM: MMCI: remove custom DBG macro and printk
ARM: make_coherent(): fix problems with highpte, part 2
MM: Pass a PTE pointer to update_mmu_cache() rather than the PTE itself
ARM: 5945/1: ep93xx: include correct irq.h in core.c
ARM: 5933/1: amba-pl011: support hardware flow control
ARM: 5930/1: Add PKMAP area description to memory.txt.
ARM: 5929/1: Add checks to detect overlap of memory regions.
ARM: 5928/1: Change type of VMALLOC_END to unsigned long.
ARM: 5927/1: Make delimiters of DMA area globally visibly.
ARM: 5926/1: Add "Virtual kernel memory..." printout.
ARM: 5920/1: OMAP4: Enable L2 Cache
Fix up trivial conflict in arch/arm/mach-mx25/clock.c
* 'for-2.6.34' of git://git.kernel.dk/linux-2.6-block: (38 commits)
block: don't access jiffies when initialising io_context
cfq: remove 8 bytes of padding from cfq_rb_root on 64 bit builds
block: fix for "Consolidate phys_segment and hw_segment limits"
cfq-iosched: quantum check tweak
blktrace: perform cleanup after setup error
blkdev: fix merge_bvec_fn return value checks
cfq-iosched: requests "in flight" vs "in driver" clarification
cciss: Fix problem with scatter gather elements in the scsi half of the driver
cciss: eliminate unnecessary pointer use in cciss scsi code
cciss: do not use void pointer for scsi hba data
cciss: factor out scatter gather chain block mapping code
cciss: fix scatter gather chain block dma direction kludge
cciss: simplify scatter gather code
cciss: factor out scatter gather chain block allocation and freeing
cciss: detect bad alignment of scsi commands at build time
cciss: clarify command list padding calculation
cfq-iosched: rethink seeky detection for SSDs
cfq-iosched: rework seeky detection
block: remove padding from io_context on 64bit builds
block: Consolidate phys_segment and hw_segment limits
git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound-2.6
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound-2.6: (252 commits)
ASoC: Check progress when reporting periods from i.MX FIQ handler
ASoC: Remove a unused variables from i.MX FIQ runtime data
ALSA: hda - Add/fix ALC269 FSC and Quanta models
ALSA: hda - Add ALC670 codec support
OMAP4: PMIC: Add support for twl6030 codec
ALSA: hda - remove unnecessary msleep on power state transitions
usb/gadget/{f_audio,gmidi}.c: follow recent changes in audio.h
ASoC: fsi: Modify over/under run error settlement
ASoC: OMAP4: Add McPDM platform driver
ASoC: OMAP4: Add support for McPDM
ASoC: OMAP: data_type and sync_mode configurable in audio dma
ALSA: hda - Add missing description in HD-Audio-Models.txt
ALSA: add support for Macbook Air 2,1 internal speaker
ALSA: usbaudio: consolidate header files
ALSA: usbmixer: bail out early when parsing audio class v2 descriptors
ALSA: usbaudio: implement basic set of class v2.0 parser
ALSA: usbaudio: introduce new types for audio class v2
ALSA: usbaudio: parse USB descriptors with structs
ALSA: hda - enable snoop for Intel Cougar Point
ALSA: hda - Remove identical definitions for macmini3 model
'bkl-drivers-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip
* 'futexes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip:
futex: Protect pid lookup in compat code with RCU
* 'irq-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip:
genirq: Fix documentation of default chip disable()
* 'bkl-drivers-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip:
nvram: Drop the BKL from nvram_open()
* 'timers-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip:
posix-timers.c: Don't export local functions
clocksource: start CMT at clocksource resume
clocksource: add suspend callback
clocksource: add argument to resume callback
ntp: Cleanup xtime references in ntp.c
ntp: Make time_esterror and time_maxerror static
* 'x86-ptrace-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip:
x86, ptrace: Remove set_stopped_child_used_math() in [x]fpregs_set
x86, ptrace: Simplify xstateregs_get()
ptrace: Fix ptrace_regset() comments and diagnose errors specifically
parisc: Disable CONFIG_HAVE_ARCH_TRACEHOOK
ptrace: Add support for generic PTRACE_GETREGSET/PTRACE_SETREGSET
x86, ptrace: regset extensions to support xstate
* 'x86-pci-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip:
x86: Enable NMI on all cpus on UV
vgaarb: Add user selectability of the number of GPUS in a system
vgaarb: Fix VGA arbiter to accept PCI domains other than 0
x86, uv: Update UV arch to target Legacy VGA I/O correctly.
pci: Update pci_set_vga_state() to call arch functions
* 'x86-mm-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip:
x86, mm: Unify kernel_physical_mapping_init() API
x86, mm: Allow highmem user page tables to be disabled at boot time
x86: Do not reserve brk for DMI if it's not going to be used
x86: Convert tlbstate_lock to raw_spinlock
x86: Use the generic page_is_ram()
x86: Remove BIOS data range from e820
Move page_is_ram() declaration to mm.h
Generic page_is_ram: use __weak
resources: introduce generic page_is_ram()
* 'sched-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: (25 commits)
sched: Fix SCHED_MC regression caused by change in sched cpu_power
sched: Don't use possibly stale sched_class
kthread, sched: Remove reference to kthread_create_on_cpu
sched: cpuacct: Use bigger percpu counter batch values for stats counters
percpu_counter: Make __percpu_counter_add an inline function on UP
sched: Remove member rt_se from struct rt_rq
sched: Change usage of rt_rq->rt_se to rt_rq->tg->rt_se[cpu]
sched: Remove unused update_shares_locked()
sched: Use for_each_bit
sched: Queue a deboosted task to the head of the RT prio queue
sched: Implement head queueing for sched_rt
sched: Extend enqueue_task to allow head queueing
sched: Remove USER_SCHED
sched: Fix the place where group powers are updated
sched: Assume *balance is valid
sched: Remove load_balance_newidle()
sched: Unify load_balance{,_newidle}()
sched: Add a lock break for PREEMPT=y
sched: Remove from fwd decls
sched: Remove rq_iterator from move_one_task
Fix up trivial conflicts in kernel/sched.c
* 'sched-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip:
sched: Fix race between ttwu() and task_rq_lock()
sched: Fix SMT scheduler regression in find_busiest_queue()
sched: Fix sched_mv_power_savings for !SMT
kernel/sched.c: Suppress unused var warning
* 'perf-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: (172 commits)
perf_event, amd: Fix spinlock initialization
perf_event: Fix preempt warning in perf_clock()
perf tools: Flush maps on COMM events
perf_events, x86: Split PMU definitions into separate files
perf annotate: Handle samples not at objdump output addr boundaries
perf_events, x86: Remove superflous MSR writes
perf_events: Simplify code by removing cpu argument to hw_perf_group_sched_in()
perf_events, x86: AMD event scheduling
perf_events: Add new start/stop PMU callbacks
perf_events: Report the MMAP pgoff value in bytes
perf annotate: Defer allocating sym_priv->hist array
perf symbols: Improve debugging information about symtab origins
perf top: Use a macro instead of a constant variable
perf symbols: Check the right return variable
perf/scripts: Tag syscall_name helper as not yet available
perf/scripts: Add perf-trace-python Documentation
perf/scripts: Remove unnecessary PyTuple resizes
perf/scripts: Add syscall tracing scripts
perf/scripts: Add Python scripting engine
perf/scripts: Remove check-perf-trace from listed scripts
Fix trivial conflict in tools/perf/util/probe-event.c
* 'tracing-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: (28 commits)
ftrace: Add function names to dangling } in function graph tracer
tracing: Simplify memory recycle of trace_define_field
tracing: Remove unnecessary variable in print_graph_return
tracing: Fix typo of info text in trace_kprobe.c
tracing: Fix typo in prof_sysexit_enable()
tracing: Remove CONFIG_TRACE_POWER from kernel config
tracing: Fix ftrace_event_call alignment for use with gcc 4.5
ftrace: Remove memory barriers from NMI code when not needed
tracing/kprobes: Add short documentation for HAVE_REGS_AND_STACK_ACCESS_API
s390: Add pt_regs register and stack access API
tracing/kprobes: Make Kconfig dependencies generic
tracing: Unify arch_syscall_addr() implementations
tracing: Add notrace to TRACE_EVENT implementation functions
ftrace: Allow to remove a single function from function graph filter
tracing: Add correct/incorrect to sort keys for branch annotation output
tracing: Simplify test for function_graph tracing start point
tracing: Drop the tr check from the graph tracing path
tracing: Add stack dump to trace_printk if stacktrace option is set
tracing: Use appropriate perl constructs in recordmcount.pl
tracing: optimize recordmcount.pl for offsets-handling
* 'core-rcu-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: (44 commits)
rcu: Fix accelerated GPs for last non-dynticked CPU
rcu: Make non-RCU_PROVE_LOCKING rcu_read_lock_sched_held() understand boot
rcu: Fix accelerated grace periods for last non-dynticked CPU
rcu: Export rcu_scheduler_active
rcu: Make rcu_read_lock_sched_held() take boot time into account
rcu: Make lockdep_rcu_dereference() message less alarmist
sched, cgroups: Fix module export
rcu: Add RCU_CPU_STALL_VERBOSE to dump detailed per-task information
rcu: Fix rcutorture mod_timer argument to delay one jiffy
rcu: Fix deadlock in TREE_PREEMPT_RCU CPU stall detection
rcu: Convert to raw_spinlocks
rcu: Stop overflowing signed integers
rcu: Use canonical URL for Mathieu's dissertation
rcu: Accelerate grace period if last non-dynticked CPU
rcu: Fix citation of Mathieu's dissertation
rcu: Documentation update for CONFIG_PROVE_RCU
security: Apply lockdep-based checking to rcu_dereference() uses
idr: Apply lockdep-based diagnostics to rcu_dereference() uses
radix-tree: Disable RCU lockdep checking in radix tree
vfs: Abstract rcu_dereference_check for files-fdtable use
'tracing-fixes-for-linus', 'x86-debug-for-linus', 'x86-doc-for-linus', 'x86-gpu-for-linus' and 'x86-rlimit-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip
* 'core-ipi-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip:
generic-ipi: Optimize accesses by using DEFINE_PER_CPU_SHARED_ALIGNED for IPI data
* 'core-locking-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip:
plist: Fix grammar mistake, and c-style mistake
* 'tracing-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip:
kprobes: Add mcount to the kprobes blacklist
* 'x86-debug-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip:
x86_64: Print modules like i386 does
* 'x86-doc-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip:
x86: Put 'nopat' in kernel-parameters
* 'x86-gpu-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip:
x86-64: Allow fbdev primary video code
* 'x86-rlimit-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip:
x86: Use helpers for rlimits
* 'for-linus' of git://git390.marist.edu/pub/scm/linux-2.6: (35 commits)
[S390] time: remove unused code
[S390] zcore: Add prefix registers to dump header
[S390] correct vdso version string
[S390] add support for compressed kernels
[S390] Define new s390 ELF note sections in elf.h
[S390] codepage conversion of kernel parameter line
[S390] seq_file: convert drivers/s390/
[S390] add z9-ec/z10 instruction to kernel disassembler
[S390] dasd: correct offline processing
[S390] dasd: fix refcounting.
[S390] dasd: fix online/offline race
[S390] use kprobes_built_in() in mm/fault code
[S390] bug: use relative pointers in bug table entries
[S390] Cleanup struct _lowcore usage and defines.
[S390] free_initmem: reduce code duplication
[S390] Replace ENOTSUPP usage with EOPNOTSUPP
[S390] spinlock: check virtual cpu running status
[S390] sysinfo: fix SYSIB 3,2,2 structure
[S390] add MACHINE_IS_LPAR flag
[S390] qdio: optimize cache line usage of struct qdio_irq
git://git.kernel.org/pub/scm/linux/kernel/git/benh/powerpc
* 'next' of git://git.kernel.org/pub/scm/linux/kernel/git/benh/powerpc: (88 commits)
powerpc: Fix lwsync feature fixup vs. modules on 64-bit
powerpc: Convert pmc_owner_lock to raw_spinlock
powerpc: Convert die.lock to raw_spinlock
powerpc: Convert tlbivax_lock to raw_spinlock
powerpc: Convert mpic locks to raw_spinlock
powerpc: Convert pmac_pic_lock to raw_spinlock
powerpc: Convert big_irq_lock to raw_spinlock
powerpc: Convert feature_lock to raw_spinlock
powerpc: Convert i8259_lock to raw_spinlock
powerpc: Convert beat_htab_lock to raw_spinlock
powerpc: Convert confirm_error_lock to raw_spinlock
powerpc: Convert ipic_lock to raw_spinlock
powerpc: Convert native_tlbie_lock to raw_spinlock
powerpc: Convert beatic_irq_mask_lock to raw_spinlock
powerpc: Convert nv_lock to raw_spinlock
powerpc: Convert context_lock to raw_spinlock
powerpc/85xx: Add NOR, LEDs and PIB support for MPC8568E-MDS boards
powerpc/86xx: Enable VME driver on the GE SBC610
powerpc/86xx: Enable VME driver on the GE PPC9A
powerpc/86xx: Add MSI section to GE PPC9A DTS
git://git.kernel.org/pub/scm/linux/kernel/git/frederic/random-tracing into tracing/core
Before the scheduler starts, all tasks are non-preemptible by
definition. So, during that time, rcu_read_lock_sched_held()
needs to always return "true". This patch makes that be so
for RCU_PROVE_LOCKING=n.
Cc: laijs@cn.fujitsu.com
Cc: dipankar@in.ibm.com
Cc: mathieu.desnoyers@polymtl.ca
Cc: josh@joshtriplett.org
Cc: dvhltc@us.ibm.com
Cc: niv@us.ibm.com
Cc: peterz@infradead.org
Cc: rostedt@goodmis.org
Cc: Valdis.Kletnieks@vt.edu
Cc: dhowells@redhat.com
LKML-Reference: <1267231138-27856-2-git-send-email-paulmck@linux.vnet.ibm.com>
git://git.kernel.org/pub/scm/linux/kernel/git/rafael/suspend-2.6
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/rafael/suspend-2.6:
PM / Hibernate: Fix preallocating of memory
PM / Hibernate: Remove swsusp.c finally
PM / Hibernate: Remove trailing space in message
PM: Allow SCSI devices to suspend/resume asynchronously
PM: Allow USB devices to suspend/resume asynchronously
USB: implement non-tree resume ordering constraints for PCI host controllers
PM: Allow PCI devices to suspend/resume asynchronously
PM / Hibernate: Swap, remove useless check from swsusp_read()
PM / Hibernate: Really deprecate deprecated user ioctls
PM: Allow device drivers to use dpm_wait()
PM: Start asynchronous resume threads upfront
PM: Add facility for advanced testing of async suspend/resume
PM: Add a switch for disabling/enabling asynchronous suspend/resume
PM: Asynchronous suspend and resume of devices
PM: Add parent information to timing messages
PM: Document device power attributes in sysfs
PM / Runtime: Add sysfs switch for disabling device run-time PM
git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-2.6
* 'v4l_for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-2.6: (362 commits)
V4L-DVB: cx88-dvb: remove extra attribution for core
V4L/DVB: v4l: soc_camera: fix bound checking of mbus_fmt[] index
V4L/DVB: Add support for SMT7020 to cx88
V4L/DVB: radio-si470x: Use UTF-8 encoding on a comment
V4L/DVB: MAINTAINERS: Telegent tlg2300 section fix
V4L/DVB: gspca_stv06xx: Add support for camera button
V4L/DVB: gspca_ov519: add support for the button on ov511 based cams
V4L/DVB: gspca_ov519: Add support for the button on ov518 based cams
V4L/DVB: gspca_ov519: add support for the button on ov519 based cams
V4L/DVB: gspca_main: Fix a compile error when CONFIG_INPUT is not set
V4L/DVB: gspca_main: some input error handling fixes
V4L/DVB: gspca_main: Allow use of input device creation code for non int. inputs
V4L/DVB: gspca_pac7302: much improved exposure control
V4L/DVB: gspca_sonixb: Make sonixb driver handle pas106 and pas202 cameras
V4L/DVB: gspca_sonixb: pas106: fixup bright ctrl and add gain and exposure ctrls
V4L/DVB: Documentation: gspca.txt: update known mr97310a cams
V4L/DVB: gspca_mr97310a: add support for the Sakar 1638x CyberPix
V4L/DVB: gscpa_sonixb: limit ov7630 max framerate at 640x480
V4L/DVB: gspca_sonixb: pas202: fixup brightness ctrl and add gain and exposure ctrls
V4L/DVB: gscpa_sonixb: Differentiate between sensors with a coarse and fine expo ctrl
* git://git.kernel.org/pub/scm/linux/kernel/git/jejb/xfs-vipt:
xfs: fix xfs to work with Virtually Indexed architectures
sh: add mm API for DMA to vmalloc/vmap areas
arm: add mm API for DMA to vmalloc/vmap areas
parisc: add mm API for DMA to vmalloc/vmap areas
mm: add coherence API for DMA to vmalloc/vmap areas
* git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi-misc-2.6: (158 commits)
[SCSI] Fix printing of failed 32-byte commands
[SCSI] Fix printing of variable length commands
[SCSI] libsrp: fix bug in ADDITIONAL CDB LENGTH interpretation
[SCSI] scsi_dh_alua: Add IBM Power Virtual SCSI ALUA device to dev list
[SCSI] scsi_dh_alua: add netapp to dev list
[SCSI] qla2xxx: Update version number to 8.03.02-k1.
[SCSI] qla2xxx: EEH: Restore PCI saved state during pci slot reset.
[SCSI] qla2xxx: Add firmware ETS burst support.
[SCSI] qla2xxx: Correct loop-resync issues during SNS scans.
[SCSI] qla2xxx: Correct use-after-free issue in terminate_rport_io callback.
[SCSI] qla2xxx: Correct EH bus-reset handling.
[SCSI] qla2xxx: Proper clean-up of BSG requests when request times out.
[SCSI] qla2xxx: Initialize payload receive length in failure path of vendor commands
[SCSI] fix duplicate removal on error path in scsi_sysfs_add_sdev
[SCSI] fix refcounting bug in scsi_get_host_dev
[SCSI] fix memory leak in scsi_report_lun_scan
[SCSI] lpfc: correct PPC build failure
[SCSI] raid_class: add raid1e
[SCSI] mpt2sas: Do not call sas_is_tlr_enabled for RAID volumes.
[SCSI] zfcp: Introduce header file for qdio structs and inline functions
* git://git.kernel.org/pub/scm/linux/kernel/git/lethal/sh-2.6: (187 commits)
sh: remove dead LED code for migo-r and ms7724se
sh: ecovec build fix for CONFIG_I2C=n
sh: ecovec r-standby support
sh: ms7724se r-standby support
sh: SH-Mobile R-standby register save/restore
clocksource: Fix up a registration/IRQ race in the sh drivers.
sh: ms7724: modify scan_timing for KEYSC
sh: ms7724: Add sh_sir support
sh: mach-ecovec24: Add sh_sir support
sh: wire up SET/GET_UNALIGN_CTL.
sh: allow alignment fault mode to be configured at kernel boot.
sh: sh7724: Update FSI/SPU2 clock
sh: always enable sh7724 vpu_clk and set to 166MHz on Ecovec
sh: add sh7724 kick callback to clk_div4_table
sh: introduce struct clk_div4_table
sh: clock-cpg div4 set_rate() shift fix
sh: Turn on speculative return for SH7785 and SH7786
sh: Merge legacy and dynamic PMB modes.
sh: Use uncached I/O helpers in PMB setup.
sh: Provide uncached I/O helpers.
* git://git.kernel.org/pub/scm/linux/kernel/git/herbert/crypto-2.6: (31 commits)
crypto: aes_generic - Fix checkpatch errors
crypto: fcrypt - Fix checkpatch errors
crypto: ecb - Fix checkpatch errors
crypto: des_generic - Fix checkpatch errors
crypto: deflate - Fix checkpatch errors
crypto: crypto_null - Fix checkpatch errors
crypto: cipher - Fix checkpatch errors
crypto: crc32 - Fix checkpatch errors
crypto: compress - Fix checkpatch errors
crypto: cast6 - Fix checkpatch errors
crypto: cast5 - Fix checkpatch errors
crypto: camellia - Fix checkpatch errors
crypto: authenc - Fix checkpatch errors
crypto: api - Fix checkpatch errors
crypto: anubis - Fix checkpatch errors
crypto: algapi - Fix checkpatch errors
crypto: blowfish - Fix checkpatch errors
crypto: aead - Fix checkpatch errors
crypto: ablkcipher - Fix checkpatch errors
crypto: pcrypt - call the complete function on error
S390 ELF core dump currently only contains the PSW, the general purpose
registers, the floating point registers and the access registers stored
in PRSTATUS/PRFPREG note sections.
For analyzing s390 kernel problems additional registers are important.
In order to be able to include these registers to a kernel ELF core dump,
this patch adds the following five new note sections to elf.h:
* NT_S390_TIMER: S390 timer register
* NT_S390_TODCMP: S390 TOD comparator register
* NT_S390_TODPREG: S390 TOD programmable register
* NT_S390_CTRS: S390 control registers
* NT_S390_PREFIX: S390 prefix register
The new note sections have been already defined and accepted in the upstream
binutils package.
Signed-off-by: Michael Holzheu <holzheu@linux.vnet.ibm.com>
This patch (as1331) adds non-tree ordering constraints needed for
proper resume of PCI USB host controllers from hibernation. The main
issue is that non-high-speed devices must not be resumed before the
high-speed root hub, because it is the ehci_bus_resume() routine which
takes care of handing the device connection over to the companion
controller. If the device resume is attempted before the handover
then the device won't be found and it will be treated as though it had
disconnected.
The patch adds a new field to the usb_bus structure; for each
full/low-speed bus this field will contain a pointer to the companion
high-speed bus (if one exists). It is used during normal device
resume; if the hs_companion pointer isn't NULL then we wait for the
root-hub device on the hs_companion bus.
A secondary issue is that an EHCI controlller shouldn't be resumed
before any of its companions. On some machines I have observed
handovers failing if the companion controller is reinitialized after
the handover. Thus, the EHCI resume routine must wait for the
companion controllers to be resumed.
The patch also fixes a small bug in usb_hcd_pci_probe(); an error path
jumps to the wrong label, causing a memory leak.
[rjw: Fixed compilation for CONFIG_PM_SLEEP unset.]
Signed-off-by: Alan Stern <stern@rowland.harvard.edu>
There are some dependencies between devices (in particular, between
EHCI USB controllers and their OHCI/UHCI siblings) which are not
reflected by the structure of the device tree. With synchronous
suspend and resume these dependencies are taken into accout
automatically, because the devices in question are always registered
in the right order, but to meet these constraints with asynchronous
suspend and resume the drivers of these devices will need to use
dpm_wait() in their suspend/resume routines, so introduce a helper
function allowing them to do that.
Add configuration switch CONFIG_PM_ADVANCED_DEBUG for compiling in
extra PM debugging/testing code allowing one to access some
PM-related attributes of devices from the user space via sysfs.
If CONFIG_PM_ADVANCED_DEBUG is set, add sysfs attribute power/async
for every device allowing the user space to access the device's
power.async_suspend flag and modify it, if desired.
Theoretically, the total time of system sleep transitions (suspend
to RAM, hibernation) can be reduced by running suspend and resume
callbacks of device drivers in parallel with each other. However,
there are dependencies between devices such that we're not allowed
to suspend the parent of a device before suspending the device
itself. Analogously, we're not allowed to resume a device before
resuming its parent.
The most straightforward way to take these dependencies into accout
is to start the async threads used for suspending and resuming
devices at the core level, so that async_schedule() is called for
each suspend and resume callback supposed to be executed
asynchronously.
For this purpose, introduce a new device flag, power.async_suspend,
used to mark the devices whose suspend and resume callbacks are to be
executed asynchronously (ie. in parallel with the main suspend/resume
thread and possibly in parallel with each other) and helper function
device_enable_async_suspend() allowing one to set power.async_suspend
for given device (power.async_suspend is unset by default for all
devices). For each device with the power.async_suspend flag set the
PM core will use async_schedule() to execute its suspend and resume
callbacks.
The async threads started for different devices as a result of
calling async_schedule() are synchronized with each other and with
the main suspend/resume thread with the help of completions, in the
following way:
(1) There is a completion, power.completion, for each device object.
(2) Each device's completion is reset before calling async_schedule()
for the device or, in the case of devices with the
power.async_suspend flags unset, before executing the device's
suspend and resume callbacks.
(3) During suspend, right before running the bus type, device type
and device class suspend callbacks for the device, the PM core
waits for the completions of all the device's children to be
completed.
(4) During resume, right before running the bus type, device type and
device class resume callbacks for the device, the PM core waits
for the completion of the device's parent to be completed.
(5) The PM core completes power.completion for each device right
after the bus type, device type and device class suspend (or
resume) callbacks executed for the device have returned.
Add new device sysfs attribute, power/control, allowing the user
space to block the run-time power management of the devices. If this
attribute is set to "on", the driver of the device won't be able to power
manage it at run time (without breaking the rules) and the device will
always be in the full power state (except when the entire system goes
into a sleep state).
Acked-by: Alan Stern <stern@rowland.harvard.edu>
git://git.kernel.org/pub/scm/linux/kernel/git/jbarnes/pci-2.6
* 'linux-next' of git://git.kernel.org/pub/scm/linux/kernel/git/jbarnes/pci-2.6: (48 commits)
x86/PCI: Prevent mmconfig memory corruption
ACPI: Use GPE reference counting to support shared GPEs
x86/PCI: use host bridge _CRS info by default on 2008 and newer machines
PCI: augment bus resource table with a list
PCI: add pci_bus_for_each_resource(), remove direct bus->resource[] refs
PCI: read bridge windows before filling in subtractive decode resources
PCI: split up pci_read_bridge_bases()
PCIe PME: use pci_pcie_cap()
PCI PM: Run-time callbacks for PCI bus type
PCIe PME: use pci_is_pcie()
PCI / ACPI / PM: Platform support for PCI PME wake-up
ACPI / ACPICA: Multiple system notify handlers per device
ACPI / PM: Add more run-time wake-up fields
PCI PM: Make it possible to force using INTx for PCIe PME signaling
PCI PM: PCIe PME root port service driver
PCI PM: Add function for checking PME status of devices
PCI: mark is_pcie obsolete
PCI: set PCI_PREF_RANGE_TYPE_64 in pci_bridge_check_ranges
PCI: pciehp: second try to get big range for pcie devices
This new driver supports USB PIA CPiA version 1 cams, replacing the
old v4l1 driver.
New gspca subdriver adding support for SN9C2028 dual-mode cameras.
Signed-off-by: Theodore Kilgore <kilgota@banach.math.auburn.edu>
On 64 bit builds when CONFIG_BLK_CGROUP=n (the default) this removes 8
bytes of padding from structure io_context and drops its size from 72 to
64 bytes, so needing one fewer cachelines and allowing more objects per
slab in it's kmem_cache.
Signed-off-by: Richard Kennedy <richard@rsk.demon.co.uk>
patch against 2.6.33
compiled & test on x86_64 AMDX2
regards
Richard
Except for SCSI no device drivers distinguish between physical and
hardware segment limits. Consolidate the two into a single segment
limit.
The block layer calling convention is blk_queue_<limit name>.
blk_queue_max_sectors predates this practice, leading to some confusion.
Rename the function to appropriately reflect that its intended use is to
set max_hw_sectors.
Also introduce a temporary wrapper for backwards compability. This can
be removed after the merge window is closed.
