path: root/include/linux
2014-11-15Merge tag 'drm/fixes/for-3.19-rc1' of ↵Dave Airlie
git://people.freedesktop.org/~tagr/linux into drm-next drm: Miscellaneous fixes for v3.19-rc1 This is a small collection of fixes that I've been carrying around for a while now. Many of these have been posted and reviewed or acked. The few that haven't I deemed too trivial to bother. * tag 'drm/fixes/for-3.19-rc1' of git://people.freedesktop.org/~tagr/linux: video/hdmi: Relicense header under MIT license drm/gma500: mdfld: Reuse video/mipi_display.h drm: Make drm_mode_create_tv_properties() signature consistent drm: Implement drm_get_pci_dev() dummy for !PCI drm/prime: Use unsigned type for number of pages drm/gem: Fix typo in kerneldoc drm: Use const data when creating blob properties drm: Use size_t for blob property sizes
2014-11-13video/hdmi: Relicense header under MIT licenseThierry Reding
OpenBSD wants to reuse this file but needs the license to be more permissive. Acked-by: Alban Bedel <alban.bedel@avionic-design.de> Acked-by: Daniel Vetter <daniel.vetter@intel.com> Acked-by: Alex Deucher <alexander.deucher@amd.com> Acked-by: Christian König <christian.koenig@amd.com> Signed-off-by: Thierry Reding <treding@nvidia.com>
2014-11-09Merge branch 'devicetree/merge' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/glikely/linux Pull devicetree bugfix from Grant Likely: "One buffer overflow bug that shouldn't be left around" * 'devicetree/merge' of git://git.kernel.org/pub/scm/linux/kernel/git/glikely/linux: of: Fix overflow bug in string property parsing functions
2014-11-06Merge tag 'pci-v3.18-fixes-2' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/helgaas/pci Pull PCI fix from Bjorn Helgaas: "This fixes an oops when enabling SR-IOV VF devices. The oops is a regression I added by configuring all devices during enumeration. - Don't oops on virtual buses in acpi_pci_get_bridge_handle() (Yinghai Lu)" * tag 'pci-v3.18-fixes-2' of git://git.kernel.org/pub/scm/linux/kernel/git/helgaas/pci: PCI: Don't oops on virtual buses in acpi_pci_get_bridge_handle()
2014-11-05PCI: Don't oops on virtual buses in acpi_pci_get_bridge_handle()Yinghai Lu
acpi_pci_get_bridge_handle() returns the ACPI handle for the bridge device (either a host bridge or a PCI-to-PCI bridge) leading to a PCI bus. But SR-IOV virtual functions can be on a virtual bus with no bridge leading to it. Return a NULL acpi_handle in this case instead of trying to dereference the NULL pointer to the bridge. This fixes a NULL pointer dereference oops in pci_get_hp_params() when adding SR-IOV VF devices on virtual buses. [bhelgaas: changelog, add comment in code] Fixes: 6cd33649fa83 ("PCI: Add pci_configure_device() during enumeration") Link: https://bugzilla.kernel.org/show_bug.cgi?id=87591 Reported-by: Chao Zhou <chao.zhou@intel.com> Reported-by: Joerg Roedel <joro@8bytes.org> Signed-off-by: Yinghai Lu <yinghai@kernel.org> Signed-off-by: Bjorn Helgaas <bhelgaas@google.com>
2014-11-04of: Fix overflow bug in string property parsing functionsGrant Likely
The string property read helpers will run off the end of the buffer if it is handed a malformed string property. Rework the parsers to make sure that doesn't happen. At the same time add new test cases to make sure the functions behave themselves. The original implementations of of_property_read_string_index() and of_property_count_strings() both open-coded the same block of parsing code, each with it's own subtly different bugs. The fix here merges functions into a single helper and makes the original functions static inline wrappers around the helper. One non-bugfix aspect of this patch is the addition of a new wrapper, of_property_read_string_array(). The new wrapper is needed by the device_properties feature that Rafael is working on and planning to merge for v3.19. The implementation is identical both with and without the new static inline wrapper, so it just got left in to reduce the churn on the header file. Signed-off-by: Grant Likely <grant.likely@linaro.org> Cc: Rafael J. Wysocki <rafael.j.wysocki@intel.com> Cc: Mika Westerberg <mika.westerberg@linux.intel.com> Cc: Rob Herring <robh+dt@kernel.org> Cc: Arnd Bergmann <arnd@arndb.de> Cc: Darren Hart <darren.hart@intel.com> Cc: <stable@vger.kernel.org> # v3.3+: Drop selftest hunks that don't apply
2014-11-03Merge branch 'fixes-for-v3.18' of ↵Linus Torvalds
git://git.linaro.org/people/mszyprowski/linux-dma-mapping Pull CMA and DMA-mapping fixes from Marek Szyprowski: "This contains important fixes for recently introduced highmem support for default contiguous memory region used for dma-mapping subsystem" * 'fixes-for-v3.18' of git://git.linaro.org/people/mszyprowski/linux-dma-mapping: mm, cma: make parameters order consistent in func declaration and definition mm: cma: Use %pa to print physical addresses mm: cma: Ensure that reservations never cross the low/high mem boundary mm: cma: Always consider a 0 base address reservation as dynamic mm: cma: Don't crash on allocation if CMA area can't be activated
2014-11-02Merge tag 'for-linus-20141102' of git://git.infradead.org/linux-mtdLinus Torvalds
Pull MTD fixes from Brian Norris: "Three main MTD fixes for 3.18: - A regression from 3.16 which was noticed in 3.17. With the restructuring of the m25p80.c driver and the SPI NOR library framework, we omitted proper listing of the SPI device IDs. This means m25p80.c wouldn't auto-load (modprobe) properly when built as a module. For now, we duplicate the device IDs into both modules. - The OMAP / ELM modules were depending on an implicit link ordering. Use deferred probing so that the new link order (in 3.18-rc) can still allow for successful probing. - Fix suspend/resume support for LH28F640BF NOR flash" * tag 'for-linus-20141102' of git://git.infradead.org/linux-mtd: mtd: cfi_cmdset_0001.c: fix resume for LH28F640BF chips mtd: omap: fix mtd devices not showing up mtd: m25p80,spi-nor: Fix module aliases for m25p80 mtd: spi-nor: make spi_nor_scan() take a chip type name, not spi_device_id mtd: m25p80: get rid of spi_get_device_id
2014-11-02Merge tag 'scsi-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi Pull SCSI fixes from James Bottomley: "This is a set of six patches consisting of: - two MAINTAINER updates - two scsi-mq fixs for the old parallel interface (not every request is tagged and we need to set the right flags to populate the SPI tag message) - a fix for a memory leak in scatterlist traversal caused by a preallocation update in 3.17 - an ipv6 fix for cxgbi" [ The scatterlist fix also came in separately through the block layer tree ] * tag 'scsi-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi: MAINTAINERS: ufs - remove self MAINTAINERS: change hpsa and cciss maintainer libcxgbi : support ipv6 address host_param scsi: set REQ_QUEUE for the blk-mq case Revert "block: all blk-mq requests are tagged" lib/scatterlist: fix memory leak with scsi-mq
2014-11-02Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs Pull VFS fixes from Al Viro: "A bunch of assorted fixes, most of them followups to overlayfs merge" * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: ovl: initialize ->is_cursor Return short read or 0 at end of a raw device, not EIO isofs: don't bother with ->d_op for normal case isofs_cmp(): we'll never see a dentry for . or .. overlayfs: fix lockdep misannotation ovl: fix check for cursor overlayfs: barriers for opening upper-layer directory rcu: Provide counterpart to rcu_dereference() for non-RCU situations staging: android: logger: Fix log corruption regression
2014-10-31Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/netLinus Torvalds
Pull networking fixes from David Miller: "A bit has accumulated, but it's been a week or so since my last batch of post-merge-window fixes, so... 1) Missing module license in netfilter reject module, from Pablo. Lots of people ran into this. 2) Off by one in mac80211 baserate calculation, from Karl Beldan. 3) Fix incorrect return value from ax88179_178a driver's set_mac_addr op, which broke use of it with bonding. From Ian Morgan. 4) Checking of skb_gso_segment()'s return value was not all encompassing, it can return an SKB pointer, a pointer error, or NULL. Fix from Florian Westphal. This is crummy, and longer term will be fixed to just return error pointers or a real SKB. 6) Encapsulation offloads not being handled by skb_gso_transport_seglen(). From Florian Westphal. 7) Fix deadlock in TIPC stack, from Ying Xue. 8) Fix performance regression from using rhashtable for netlink sockets. The problem was the synchronize_net() invoked for every socket destroy. From Thomas Graf. 9) Fix bug in eBPF verifier, and remove the strong dependency of BPF on NET. From Alexei Starovoitov. 10) In qdisc_create(), use the correct interface to allocate ->cpu_bstats, otherwise the u64_stats_sync member isn't initialized properly. From Sabrina Dubroca. 11) Off by one in ip_set_nfnl_get_byindex(), from Dan Carpenter. 12) nf_tables_newchain() was erroneously expecting error pointers from netdev_alloc_pcpu_stats(). It only returna a valid pointer or NULL. From Sabrina Dubroca. 13) Fix use-after-free in _decode_session6(), from Li RongQing. 14) When we set the TX flow hash on a socket, we mistakenly do so before we've nailed down the final source port. Move the setting deeper to fix this. From Sathya Perla. 15) NAPI budget accounting in amd-xgbe driver was counting descriptors instead of full packets, fix from Thomas Lendacky. 16) Fix total_data_buflen calculation in hyperv driver, from Haiyang Zhang. 17) Fix bcma driver build with OF_ADDRESS disabled, from Hauke Mehrtens. 18) Fix mis-use of per-cpu memory in TCP md5 code. The problem is that something that ends up being vmalloc memory can't be passed to the crypto hash routines via scatter-gather lists. From Eric Dumazet. 19) Fix regression in promiscuous mode enabling in cdc-ether, from Olivier Blin. 20) Bucket eviction and frag entry killing can race with eachother, causing an unlink of the object from the wrong list. Fix from Nikolay Aleksandrov. 21) Missing initialization of spinlock in cxgb4 driver, from Anish Bhatt. 22) Do not cache ipv4 routing failures, otherwise if the sysctl for forwarding is subsequently enabled this won't be seen. From Nicolas Cavallari" * git://git.kernel.org/pub/scm/linux/kernel/git/davem/net: (131 commits) drivers: net: cpsw: Support ALLMULTI and fix IFF_PROMISC in switch mode drivers: net: cpsw: Fix broken loop condition in switch mode net: ethtool: Return -EOPNOTSUPP if user space tries to read EEPROM with lengh 0 stmmac: pci: set default of the filter bins net: smc91x: Fix gpios for device tree based booting mpls: Allow mpls_gso to be built as module mpls: Fix mpls_gso handler. r8152: stop submitting intr for -EPROTO netfilter: nft_reject_bridge: restrict reject to prerouting and input netfilter: nft_reject_bridge: don't use IP stack to reject traffic netfilter: nf_reject_ipv6: split nf_send_reset6() in smaller functions netfilter: nf_reject_ipv4: split nf_send_reset() in smaller functions netfilter: nf_tables_bridge: update hook_mask to allow {pre,post}routing drivers/net: macvtap and tun depend on INET drivers/net, ipv6: Select IPv6 fragment idents for virtio UFO packets drivers/net: Disable UFO through virtio net: skb_fclone_busy() needs to detect orphaned skb gre: Use inner mac length when computing tunnel length mlx4: Avoid leaking steering rules on flow creation error flow net/mlx4_en: Don't attempt to TX offload the outer UDP checksum for VXLAN ...
2014-10-31Merge branch 'core-urgent-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull core fixes from Ingo Molnar: "The tree contains two RCU fixes and a compiler quirk comment fix" * 'core-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: rcu: Make rcu_barrier() understand about missing rcuo kthreads compiler/gcc4+: Remove inaccurate comment about 'asm goto' miscompiles rcu: More on deadlock between CPU hotplug and expedited grace periods
2014-10-31Return short read or 0 at end of a raw device, not EIODavid Jeffery
Author: David Jeffery <djeffery@redhat.com> Changes to the basic direct I/O code have broken the raw driver when reading to the end of a raw device. Instead of returning a short read for a read that extends partially beyond the device's end or 0 when at the end of the device, these reads now return EIO. The raw driver needs the same end of device handling as was added for normal block devices. Using blkdev_read_iter, which has the needed size checks, prevents the EIO conditions at the end of the device. Signed-off-by: David Jeffery <djeffery@redhat.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2014-10-30net: skb_fclone_busy() needs to detect orphaned skbEric Dumazet
Some drivers are unable to perform TX completions in a bound time. They instead call skb_orphan() Problem is skb_fclone_busy() has to detect this case, otherwise we block TCP retransmits and can freeze unlucky tcp sessions on mostly idle hosts. Signed-off-by: Eric Dumazet <edumazet@google.com> Fixes: 1f3279ae0c13 ("tcp: avoid retransmits of TCP packets hanging in host queues") Signed-off-by: David S. Miller <davem@davemloft.net>
2014-10-29Merge branch 'akpm' (incoming from Andrew Morton)Linus Torvalds
Merge misc fixes from Andrew Morton: "21 fixes" * emailed patches from Andrew Morton <akpm@linux-foundation.org>: (21 commits) mm/balloon_compaction: fix deflation when compaction is disabled sh: fix sh770x SCIF memory regions zram: avoid NULL pointer access in concurrent situation mm/slab_common: don't check for duplicate cache names ocfs2: fix d_splice_alias() return code checking mm: rmap: split out page_remove_file_rmap() mm: memcontrol: fix missed end-writeback page accounting mm: page-writeback: inline account_page_dirtied() into single caller lib/bitmap.c: fix undefined shift in __bitmap_shift_{left|right}() drivers/rtc/rtc-bq32k.c: fix register value memory-hotplug: clear pgdat which is allocated by bootmem in try_offline_node() drivers/rtc/rtc-s3c.c: fix initialization failure without rtc source clock kernel/kmod: fix use-after-free of the sub_info structure drivers/rtc/rtc-pm8xxx.c: rework to support pm8941 rtc mm, thp: fix collapsing of hugepages on madvise drivers: of: add return value to of_reserved_mem_device_init() mm: free compound page with correct order gcov: add ARM64 to GCOV_PROFILE_ALL fsnotify: next_i is freed during fsnotify_unmount_inodes. mm/compaction.c: avoid premature range skip in isolate_migratepages_range ...
2014-10-29mm: memcontrol: fix missed end-writeback page accountingJohannes Weiner
Commit 0a31bc97c80c ("mm: memcontrol: rewrite uncharge API") changed page migration to uncharge the old page right away. The page is locked, unmapped, truncated, and off the LRU, but it could race with writeback ending, which then doesn't unaccount the page properly: test_clear_page_writeback() migration wait_on_page_writeback() TestClearPageWriteback() mem_cgroup_migrate() clear PCG_USED mem_cgroup_update_page_stat() if (PageCgroupUsed(pc)) decrease memcg pages under writeback release pc->mem_cgroup->move_lock The per-page statistics interface is heavily optimized to avoid a function call and a lookup_page_cgroup() in the file unmap fast path, which means it doesn't verify whether a page is still charged before clearing PageWriteback() and it has to do it in the stat update later. Rework it so that it looks up the page's memcg once at the beginning of the transaction and then uses it throughout. The charge will be verified before clearing PageWriteback() and migration can't uncharge the page as long as that is still set. The RCU lock will protect the memcg past uncharge. As far as losing the optimization goes, the following test results are from a microbenchmark that maps, faults, and unmaps a 4GB sparse file three times in a nested fashion, so that there are two negative passes that don't account but still go through the new transaction overhead. There is no actual difference: old: 33.195102545 seconds time elapsed ( +- 0.01% ) new: 33.199231369 seconds time elapsed ( +- 0.03% ) The time spent in page_remove_rmap()'s callees still adds up to the same, but the time spent in the function itself seems reduced: # Children Self Command Shared Object Symbol old: 0.12% 0.11% filemapstress [kernel.kallsyms] [k] page_remove_rmap new: 0.12% 0.08% filemapstress [kernel.kallsyms] [k] page_remove_rmap Signed-off-by: Johannes Weiner <hannes@cmpxchg.org> Acked-by: Michal Hocko <mhocko@suse.cz> Cc: Vladimir Davydov <vdavydov@parallels.com> Cc: <stable@vger.kernel.org> [3.17.x] Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-10-29mm: page-writeback: inline account_page_dirtied() into single callerJohannes Weiner
A follow-up patch would have changed the call signature. To save the trouble, just fold it instead. Signed-off-by: Johannes Weiner <hannes@cmpxchg.org> Acked-by: Michal Hocko <mhocko@suse.cz> Cc: Vladimir Davydov <vdavydov@parallels.com> Cc: <stable@vger.kernel.org> [3.17.x] Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-10-29mm, thp: fix collapsing of hugepages on madviseDavid Rientjes
If an anonymous mapping is not allowed to fault thp memory and then madvise(MADV_HUGEPAGE) is used after fault, khugepaged will never collapse this memory into thp memory. This occurs because the madvise(2) handler for thp, hugepage_madvise(), clears VM_NOHUGEPAGE on the stack and it isn't stored in vma->vm_flags until the final action of madvise_behavior(). This causes the khugepaged_enter_vma_merge() to be a no-op in hugepage_madvise() when the vma had previously had VM_NOHUGEPAGE set. Fix this by passing the correct vma flags to the khugepaged mm slot handler. There's no chance khugepaged can run on this vma until after madvise_behavior() returns since we hold mm->mmap_sem. It would be possible to clear VM_NOHUGEPAGE directly from vma->vm_flags in hugepage_advise(), but I didn't want to introduce special case behavior into madvise_behavior(). I think it's best to just let it always set vma->vm_flags itself. Signed-off-by: David Rientjes <rientjes@google.com> Reported-by: Suleiman Souhlal <suleiman@google.com> Cc: "Kirill A. Shutemov" <kirill.shutemov@linux.intel.com> Cc: Andrea Arcangeli <aarcange@redhat.com> Cc: <stable@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-10-29drivers: of: add return value to of_reserved_mem_device_init()Marek Szyprowski
Driver calling of_reserved_mem_device_init() might be interested if the initialization has been successful or not, so add support for returning error code. This fixes a build warining caused by commit 7bfa5ab6fa1b ("drivers: dma-coherent: add initialization from device tree"), which has been merged without this change and without fixing function return value. Fixes: 7bfa5ab6fa1b1 ("drivers: dma-coherent: add initialization from device tree") Signed-off-by: Marek Szyprowski <m.szyprowski@samsung.com> Acked-by: Arnd Bergmann <arnd@arndb.de> Cc: Michal Nazarewicz <mina86@mina86.com> Cc: Grant Likely <grant.likely@linaro.org> Cc: Laura Abbott <lauraa@codeaurora.org> Cc: Josh Cartwright <joshc@codeaurora.org> Cc: Joonsoo Kim <iamjoonsoo.kim@lge.com> Cc: Kyungmin Park <kyungmin.park@samsung.com> Cc: Russell King <rmk+kernel@arm.linux.org.uk> Cc: Stephen Rothwell <sfr@canb.auug.org.au> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-10-29Merge branch 'for-linus' of git://git.kernel.dk/linux-blockLinus Torvalds
Pull block layer fixes from Jens Axboe: "A small collection of fixes for the current kernel. This contains: - Two error handling fixes from Jan Kara. One for null_blk on failure to add a device, and the other for the block/scsi_ioctl SCSI_IOCTL_SEND_COMMAND fixing up the error jump point. - A commit added in the merge window for the bio integrity bits unfortunately disabled merging for all requests if CONFIG_BLK_DEV_INTEGRITY wasn't set. Reverse the logic, so that integrity checking wont disallow merges when not enabled. - A fix from Ming Lei for merging and generating too many segments. This caused a BUG in virtio_blk. - Two error handling printk() fixups from Robert Elliott, improving the information given when we rate limit. - Error handling fixup on elevator_init() failure from Sudip Mukherjee. - A fix from Tony Battersby, fixing up a memory leak in the scatterlist handling with scsi-mq" * 'for-linus' of git://git.kernel.dk/linux-block: block: Fix merge logic when CONFIG_BLK_DEV_INTEGRITY is not defined lib/scatterlist: fix memory leak with scsi-mq block: fix wrong error return in elevator_init() scsi: Fix error handling in SCSI_IOCTL_SEND_COMMAND null_blk: Cleanup error recovery in null_add_dev() blk-merge: recaculate segment if it isn't less than max segments fs: clarify rate limit suppressed buffer I/O errors fs: merge I/O error prints into one line
2014-10-28block: Fix merge logic when CONFIG_BLK_DEV_INTEGRITY is not definedMartin K. Petersen
Commit 4eaf99beadce switched to returning bool and as a result reversed the logic of the integrity merge checks. However, the empty stubs used when the block integrity code is compiled out were still returning 0. Make these stubs return "true". Signed-off-by: Martin K. Petersen <martin.petersen@oracle.com> Reported-by: Michael L. Semon <mlsemon35@gmail.com> Tested-by: Michael L. Semon <mlsemon35@gmail.com> Signed-off-by: Jens Axboe <axboe@fb.com>
2014-10-28overlayfs: fix lockdep misannotationMiklos Szeredi
In an overlay directory that shadows an empty lower directory, say /mnt/a/empty102, do: touch /mnt/a/empty102/x unlink /mnt/a/empty102/x rmdir /mnt/a/empty102 It's actually harmless, but needs another level of nesting between I_MUTEX_CHILD and I_MUTEX_NORMAL. Signed-off-by: Miklos Szeredi <mszeredi@suse.cz> Tested-by: David Howells <dhowells@redhat.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2014-10-28rcu: Provide counterpart to rcu_dereference() for non-RCU situationsPaul E. McKenney
Although rcu_dereference() and friends can be used in situations where object lifetimes are being managed by something other than RCU, the resulting sparse and lockdep-RCU noise can be annoying. This commit therefore supplies a lockless_dereference(), which provides the protection for dereferences without the RCU-related debugging noise. Reported-by: Al Viro <viro@ZenIV.linux.org.uk> Signed-off-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2014-10-28usbnet: add a callback for set_rx_modeOlivier Blin
To delegate promiscuous mode and multicast filtering to the subdriver. Signed-off-by: Olivier Blin <olivier.blin@softathome.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-10-28skbuff.h: fix kernel-doc warning for headers_endRandy Dunlap
Fix kernel-doc warning in <linux/skbuff.h> by making both headers_start and headers_end private fields. Warning(..//include/linux/skbuff.h:654): No description found for parameter 'headers_end[0]' Signed-off-by: Randy Dunlap <rdunlap@infradead.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-10-28compiler/gcc4+: Remove inaccurate comment about 'asm goto' miscompilesSteven Noonan
The bug referenced by the comment in this commit was not completely fixed in GCC 4.8.2, as I mentioned in a thread back in February: https://lkml.org/lkml/2014/2/12/797 The conclusion at that time was to make the quirk unconditional until the bug could be found and fixed in GCC. Unfortunately, when I submitted the patch (commit a9f18034) I left a comment in that claimed the bug was fixed in GCC 4.8.2+. This comment is inaccurate, and should be removed. Signed-off-by: Steven Noonan <steven@uplinklabs.net> Signed-off-by: Ingo Molnar <mingo@kernel.org> Cc: Jakub Jelinek <jakub@redhat.com> Cc: Richard Henderson <rth@twiddle.net> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Steven Rostedt <rostedt@goodmis.org> Link: http://lkml.kernel.org/r/1414274982-14040-1-git-send-email-steven@uplinklabs.net Cc: Ingo Molnar <mingo@kernel.org>
2014-10-28Revert "block: all blk-mq requests are tagged"Christoph Hellwig
This reverts commit fb3ccb5da71273e7f0d50b50bc879e50cedd60e7. SCSI-2/SPI actually needs the tagged/untagged flag in the request to work properly. Revert this patch and add a follow on to set it in the right place. Signed-off-by: Christoph Hellwig <hch@lst.de> Reviewed-by: Martin K. Petersen <martin.petersen@oracle.com> Acked-by: Jens Axboe <axboe@kernel.dk> Reported-by: Meelis Roos <mroos@linux.ee> Tested-by: Meelis Roos <mroos@linux.ee> Cc: stable@vger.kernel.org
2014-10-27mm, cma: make parameters order consistent in func declaration and definitionWeijie Yang
In the current code, the base and size parameters order is not consistent in functions declaration and definition. If someone calls these functions according to the declaration parameters order in cma.h, he will run into some bug and it's hard to find the reason. This patch makes the parameters order consistent in functions declaration and definition. Signed-off-by: Weijie Yang <weijie.yang@samsung.com> Acked-by: Michal Nazarewicz <mina86@mina86.com> Signed-off-by: Marek Szyprowski <m.szyprowski@samsung.com>
2014-10-27Merge remote-tracking branch 'regulator/fix/core' into regulator-linusMark Brown
2014-10-26Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs Pull vfs updates from Al Viro: "overlayfs merge + leak fix for d_splice_alias() failure exits" * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: overlayfs: embed middle into overlay_readdir_data overlayfs: embed root into overlay_readdir_data overlayfs: make ovl_cache_entry->name an array instead of pointer overlayfs: don't hold ->i_mutex over opening the real directory fix inode leaks on d_splice_alias() failure exits fs: limit filesystem stacking depth overlay: overlay filesystem documentation overlayfs: implement show_options overlayfs: add statfs support overlay filesystem shmem: support RENAME_WHITEOUT ext4: support RENAME_WHITEOUT vfs: add RENAME_WHITEOUT vfs: add whiteout support vfs: export check_sticky() vfs: introduce clone_private_mount() vfs: export __inode_permission() to modules vfs: export do_splice_direct() to modules vfs: add i_op->dentry_open()
2014-10-24Merge tag 'for-linus' of git://git.kernel.org/pub/scm/virt/kvm/kvmLinus Torvalds
Pull kvm fixes from Paolo Bonzini: "This is a pretty large update. I think it is roughly as big as what I usually had for the _whole_ rc period. There are a few bad bugs where the guest can OOPS or crash the host. We have also started looking at attack models for nested virtualization; bugs that usually result in the guest ring 0 crashing itself become more worrisome if you have nested virtualization, because the nested guest might bring down the non-nested guest as well. For current uses of nested virtualization these do not really have a security impact, but you never know and bugs are bugs nevertheless. A lot of these bugs are in 3.17 too, resulting in a large number of stable@ Ccs. I checked that all the patches apply there with no conflicts" * tag 'for-linus' of git://git.kernel.org/pub/scm/virt/kvm/kvm: kvm: vfio: fix unregister kvm_device_ops of vfio KVM: x86: Wrong assertion on paging_tmpl.h kvm: fix excessive pages un-pinning in kvm_iommu_map error path. KVM: x86: PREFETCH and HINT_NOP should have SrcMem flag KVM: x86: Emulator does not decode clflush well KVM: emulate: avoid accessing NULL ctxt->memopp KVM: x86: Decoding guest instructions which cross page boundary may fail kvm: x86: don't kill guest on unknown exit reason kvm: vmx: handle invvpid vm exit gracefully KVM: x86: Handle errors when RIP is set during far jumps KVM: x86: Emulator fixes for eip canonical checks on near branches KVM: x86: Fix wrong masking on relative jump/call KVM: x86: Improve thread safety in pit KVM: x86: Prevent host from panicking on shared MSR writes. KVM: x86: Check non-canonical addresses upon WRMSR
2014-10-24Merge tag 'random_for_linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tytso/random Pull /dev/random updates from Ted Ts'o: "This adds a memzero_explicit() call which is guaranteed not to be optimized away by GCC. This is important when we are wiping cryptographically sensitive material" * tag 'random_for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tytso/random: crypto: memzero_explicit - make sure to clear out sensitive data random: add and use memzero_explicit() for clearing data
2014-10-24Merge tag 'pm+acpi-3.18-rc2' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/rafael/linux-pm Pull ACPI and power management updates from Rafael Wysocki: "This is material that didn't make it to my 3.18-rc1 pull request for various reasons, mostly related to timing and travel (LinuxCon EU / LPC) plus a couple of fixes for recent bugs. The only really new thing here is the PM QoS class for memory bandwidth, but it is simple enough and users of it will be added in the next cycle. One major change in behavior is that platform devices enumerated by ACPI will use 32-bit DMA mask by default. Also included is an ACPICA update to a new upstream release, but that's mostly cleanups, changes in tools and similar. The rest is fixes and cleanups mostly. Specifics: - Fix for a recent PCI power management change that overlooked the fact that some IRQ chips might not be able to configure PCIe PME for system wakeup from Lucas Stach. - Fix for a bug introduced in 3.17 where acpi_device_wakeup() is called with a wrong ordering of arguments from Zhang Rui. - A bunch of intel_pstate driver fixes (all -stable candidates) from Dirk Brandewie, Gabriele Mazzotta and Pali Rohár. - Fixes for a rather long-standing problem with the OOM killer and the freezer that frozen processes killed by the OOM do not actually release any memory until they are thawed, so OOM-killing them is rather pointless, with a couple of cleanups on top (Michal Hocko, Cong Wang, Rafael J Wysocki). - ACPICA update to upstream release 20140926, inlcuding mostly cleanups reducing differences between the upstream ACPICA and the kernel code, tools changes (acpidump, acpiexec) and support for the _DDN object (Bob Moore, Lv Zheng). - New PM QoS class for memory bandwidth from Tomeu Vizoso. - Default 32-bit DMA mask for platform devices enumerated by ACPI (this change is mostly needed for some drivers development in progress targeted at 3.19) from Heikki Krogerus. - ACPI EC driver cleanups, mostly related to debugging, from Lv Zheng. - cpufreq-dt driver updates from Thomas Petazzoni. - powernv cpuidle driver update from Preeti U Murthy" * tag 'pm+acpi-3.18-rc2' of git://git.kernel.org/pub/scm/linux/kernel/git/rafael/linux-pm: (34 commits) intel_pstate: Correct BYT VID values. intel_pstate: Fix BYT frequency reporting intel_pstate: Don't lose sysfs settings during cpu offline cpufreq: intel_pstate: Reflect current no_turbo state correctly cpufreq: expose scaling_cur_freq sysfs file for set_policy() drivers cpufreq: intel_pstate: Fix setting max_perf_pct in performance policy PCI / PM: handle failure to enable wakeup on PCIe PME ACPI: invoke acpi_device_wakeup() with correct parameters PM / freezer: Clean up code after recent fixes PM: convert do_each_thread to for_each_process_thread OOM, PM: OOM killed task shouldn't escape PM suspend freezer: remove obsolete comments in __thaw_task() freezer: Do not freeze tasks killed by OOM killer ACPI / platform: provide default DMA mask cpuidle: powernv: Populate cpuidle state details by querying the device-tree cpufreq: cpufreq-dt: adjust message related to regulators cpufreq: cpufreq-dt: extend with platform_data cpufreq: allow driver-specific data ACPI / EC: Cleanup coding style. ACPI / EC: Refine event/query debugging messages. ...
2014-10-24Merge branch 'next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/rzhang/linux Pull thermal management updates from Zhang Rui: "Sorry that I missed the merge window as there is a bug found in the last minute, and I have to fix it and wait for the code to be tested in linux-next tree for a few days. Now the buggy patch has been dropped entirely from my next branch. Thus I hope those changes can still be merged in 3.18-rc2 as most of them are platform thermal driver changes. Specifics: - introduce ACPI INT340X thermal drivers. Newer laptops and tablets may have thermal sensors and other devices with thermal control capabilities that are exposed for the OS to use via the ACPI INT340x device objects. Several drivers are introduced to expose the temperature information and cooling ability from these objects to user-space via the normal thermal framework. From: Lu Aaron, Lan Tianyu, Jacob Pan and Zhang Rui. - introduce a new thermal governor, which just uses a hysteresis to switch abruptly on/off a cooling device. This governor can be used to control certain fan devices that can not be throttled but just switched on or off. From: Peter Feuerer. - introduce support for some new thermal interrupt functions on i.MX6SX, in IMX thermal driver. From: Anson, Huang. - introduce tracing support on thermal framework. From: Punit Agrawal. - small fixes in OF thermal and thermal step_wise governor" * 'next' of git://git.kernel.org/pub/scm/linux/kernel/git/rzhang/linux: (25 commits) Thermal: int340x thermal: select ACPI fan driver Thermal: int3400_thermal: use acpi_thermal_rel parsing APIs Thermal: int340x_thermal: expose acpi thermal relationship tables Thermal: introduce int3403 thermal driver Thermal: introduce INT3402 thermal driver Thermal: move the KELVIN_TO_MILLICELSIUS macro to thermal.h ACPI / Fan: support INT3404 thermal device ACPI / Fan: add ACPI 4.0 style fan support ACPI / fan: convert to platform driver ACPI / fan: use acpi_device_xxx_power instead of acpi_bus equivelant ACPI / fan: remove no need check for device pointer ACPI / fan: remove unused macro Thermal: int3400 thermal: register to thermal framework Thermal: int3400 thermal: add capability to detect supporting UUIDs Thermal: introduce int3400 thermal driver ACPI: add ACPI_TYPE_LOCAL_REFERENCE support to acpi_extract_package() ACPI: make acpi_create_platform_device() an external API thermal: step_wise: fix: Prevent from binary overflow when trend is dropping ACPI: introduce ACPI int340x thermal scan handler thermal: Added Bang-bang thermal governor ...
2014-10-24kvm: vfio: fix unregister kvm_device_ops of vfioWanpeng Li
After commit 80ce163 (KVM: VFIO: register kvm_device_ops dynamically), kvm_device_ops of vfio can be registered dynamically. Commit 3c3c29fd (kvm-vfio: do not use module_init) move the dynamic register invoked by kvm_init in order to fix broke unloading of the kvm module. However, kvm_device_ops of vfio is unregistered after rmmod kvm-intel module which lead to device type collision detection warning after kvm-intel module reinsmod. WARNING: CPU: 1 PID: 10358 at /root/cathy/kvm/arch/x86/kvm/../../../virt/kvm/kvm_main.c:3289 kvm_init+0x234/0x282 [kvm]() Modules linked in: kvm_intel(O+) kvm(O) nfsv3 nfs_acl auth_rpcgss oid_registry nfsv4 dns_resolver nfs fscache lockd sunrpc pci_stub bridge stp llc autofs4 8021q cpufreq_ondemand ipv6 joydev microcode pcspkr igb i2c_algo_bit ehci_pci ehci_hcd e1000e i2c_i801 ixgbe ptp pps_core hwmon mdio tpm_tis tpm ipmi_si ipmi_msghandler acpi_cpufreq isci libsas scsi_transport_sas button dm_mirror dm_region_hash dm_log dm_mod [last unloaded: kvm_intel] CPU: 1 PID: 10358 Comm: insmod Tainted: G W O 3.17.0-rc1 #2 Hardware name: Intel Corporation S2600CP/S2600CP, BIOS RMLSDP.86I.00.29.D696.1311111329 11/11/2013 0000000000000cd9 ffff880ff08cfd18 ffffffff814a61d9 0000000000000cd9 0000000000000000 ffff880ff08cfd58 ffffffff810417b7 ffff880ff08cfd48 ffffffffa045bcac ffffffffa049c420 0000000000000040 00000000000000ff Call Trace: [<ffffffff814a61d9>] dump_stack+0x49/0x60 [<ffffffff810417b7>] warn_slowpath_common+0x7c/0x96 [<ffffffffa045bcac>] ? kvm_init+0x234/0x282 [kvm] [<ffffffff810417e6>] warn_slowpath_null+0x15/0x17 [<ffffffffa045bcac>] kvm_init+0x234/0x282 [kvm] [<ffffffffa016e995>] vmx_init+0x1bf/0x42a [kvm_intel] [<ffffffffa016e7d6>] ? vmx_check_processor_compat+0x64/0x64 [kvm_intel] [<ffffffff810002ab>] do_one_initcall+0xe3/0x170 [<ffffffff811168a9>] ? __vunmap+0xad/0xb8 [<ffffffff8109c58f>] do_init_module+0x2b/0x174 [<ffffffff8109d414>] load_module+0x43e/0x569 [<ffffffff8109c6d8>] ? do_init_module+0x174/0x174 [<ffffffff8109c75a>] ? copy_module_from_user+0x39/0x82 [<ffffffff8109b7dd>] ? module_sect_show+0x20/0x20 [<ffffffff8109d65f>] SyS_init_module+0x54/0x81 [<ffffffff814a9a12>] system_call_fastpath+0x16/0x1b ---[ end trace 0626f4a3ddea56f3 ]--- The bug can be reproduced by: rmmod kvm_intel.ko insmod kvm_intel.ko without rmmod/insmod kvm.ko This patch fixes the bug by unregistering kvm_device_ops of vfio when the kvm-intel module is removed. Reported-by: Liu Rongrong <rongrongx.liu@intel.com> Fixes: 3c3c29fd0d7cddc32862c350d0700ce69953e3bd Signed-off-by: Wanpeng Li <wanpeng.li@linux.intel.com> Signed-off-by: Paolo Bonzini <pbonzini@redhat.com>
2014-10-24fs: limit filesystem stacking depthMiklos Szeredi
Add a simple read-only counter to super_block that indicates how deep this is in the stack of filesystems. Previously ecryptfs was the only stackable filesystem and it explicitly disallowed multiple layers of itself. Overlayfs, however, can be stacked recursively and also may be stacked on top of ecryptfs or vice versa. To limit the kernel stack usage we must limit the depth of the filesystem stack. Initially the limit is set to 2. Signed-off-by: Miklos Szeredi <mszeredi@suse.cz>
2014-10-24vfs: add whiteout supportMiklos Szeredi
Whiteout isn't actually a new file type, but is represented as a char device (Linus's idea) with 0/0 device number. This has several advantages compared to introducing a new whiteout file type: - no userspace API changes (e.g. trivial to make backups of upper layer filesystem, without losing whiteouts) - no fs image format changes (you can boot an old kernel/fsck without whiteout support and things won't break) - implementation is trivial Signed-off-by: Miklos Szeredi <mszeredi@suse.cz>
2014-10-24vfs: export check_sticky()Miklos Szeredi
It's already duplicated in btrfs and about to be used in overlayfs too. Move the sticky bit check to an inline helper and call the out-of-line helper only in the unlikly case of the sticky bit being set. Signed-off-by: Miklos Szeredi <mszeredi@suse.cz>
2014-10-24vfs: introduce clone_private_mount()Miklos Szeredi
Overlayfs needs a private clone of the mount, so create a function for this and export to modules. Signed-off-by: Miklos Szeredi <mszeredi@suse.cz>
2014-10-24vfs: export __inode_permission() to modulesMiklos Szeredi
We need to be able to check inode permissions (but not filesystem implied permissions) for stackable filesystems. Expose this interface for overlayfs. Signed-off-by: Miklos Szeredi <mszeredi@suse.cz>
2014-10-24vfs: export do_splice_direct() to modulesMiklos Szeredi
Export do_splice_direct() to modules. Needed by overlay filesystem. Signed-off-by: Miklos Szeredi <mszeredi@suse.cz>
2014-10-24vfs: add i_op->dentry_open()Miklos Szeredi
Add a new inode operation i_op->dentry_open(). This is for stacked filesystems that want to return a struct file from a different filesystem. Signed-off-by: Miklos Szeredi <mszeredi@suse.cz>
2014-10-23Merge tag 'remove-weak-declarations' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/helgaas/pci Pull weak function declaration removal from Bjorn Helgaas: "The "weak" attribute is commonly used for the default version of a function, where an architecture can override it by providing a strong version. Some header file declarations included the "weak" attribute. That's error-prone because it causes every implementation to be weak, with no strong version at all, and the linker chooses one based on link order. What we want is the "weak" attribute only on the *definition* of the default implementation. These changes remove "weak" from the declarations, leaving it on the default definitions" * tag 'remove-weak-declarations' of git://git.kernel.org/pub/scm/linux/kernel/git/helgaas/pci: uprobes: Remove "weak" from function declarations memory-hotplug: Remove "weak" from memory_block_size_bytes() declaration kgdb: Remove "weak" from kgdb_arch_pc() declaration ARC: kgdb: generic kgdb_arch_pc() suffices vmcore: Remove "weak" from function declarations clocksource: Remove "weak" from clocksource_default_clock() declaration x86, intel-mid: Remove "weak" from function declarations audit: Remove "weak" from audit_classify_compat_syscall() declaration
2014-10-23Merge branch 'x86-efi-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull x86 EFI updates from Peter Anvin: "This patchset falls under the "maintainers that grovel" clause in the v3.18-rc1 announcement. We had intended to push it late in the merge window since we got it into the -tip tree relatively late. Many of these are relatively simple things, but there are a couple of key bits, especially Ard's and Matt's patches" * 'x86-efi-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (24 commits) rtc: Disable EFI rtc for x86 efi: rtc-efi: Export platform:rtc-efi as module alias efi: Delete the in_nmi() conditional runtime locking efi: Provide a non-blocking SetVariable() operation x86/efi: Adding efi_printks on memory allocationa and pci.reads x86/efi: Mark initialization code as such x86/efi: Update comment regarding required phys mapped EFI services x86/efi: Unexport add_efi_memmap variable x86/efi: Remove unused efi_call* macros efi: Resolve some shadow warnings arm64: efi: Format EFI memory type & attrs with efi_md_typeattr_format() ia64: efi: Format EFI memory type & attrs with efi_md_typeattr_format() x86: efi: Format EFI memory type & attrs with efi_md_typeattr_format() efi: Introduce efi_md_typeattr_format() efi: Add macro for EFI_MEMORY_UCE memory attribute x86/efi: Clear EFI_RUNTIME_SERVICES if failing to enter virtual mode arm64/efi: Do not enter virtual mode if booting with efi=noruntime or noefi arm64/efi: uefi_init error handling fix efi: Add kernel param efi=noruntime lib: Add a generic cmdline parse function parse_option_str ...
2014-10-23Merge branches 'pm-cpuidle' and 'pm-cpufreq'Rafael J. Wysocki
* pm-cpuidle: cpuidle: powernv: Populate cpuidle state details by querying the device-tree * pm-cpufreq: intel_pstate: Correct BYT VID values. intel_pstate: Fix BYT frequency reporting intel_pstate: Don't lose sysfs settings during cpu offline cpufreq: intel_pstate: Reflect current no_turbo state correctly cpufreq: expose scaling_cur_freq sysfs file for set_policy() drivers cpufreq: intel_pstate: Fix setting max_perf_pct in performance policy cpufreq: cpufreq-dt: adjust message related to regulators cpufreq: cpufreq-dt: extend with platform_data cpufreq: allow driver-specific data
2014-10-23Merge branch 'freezer'Rafael J. Wysocki
* freezer: PM / freezer: Clean up code after recent fixes PM: convert do_each_thread to for_each_process_thread OOM, PM: OOM killed task shouldn't escape PM suspend freezer: remove obsolete comments in __thaw_task() freezer: Do not freeze tasks killed by OOM killer
2014-10-23Merge branch 'pm-qos'Rafael J. Wysocki
* pm-qos: PM / QoS: Add PM_QOS_MEMORY_BANDWIDTH class
2014-10-22uprobes: Remove "weak" from function declarationsBjorn Helgaas
For the following interfaces: set_swbp() set_orig_insn() is_swbp_insn() is_trap_insn() uprobe_get_swbp_addr() arch_uprobe_ignore() arch_uprobe_copy_ixol() kernel/events/uprobes.c provides default definitions explicitly marked "weak". Some architectures provide their own definitions intended to override the defaults, but the "weak" attribute on the declarations applied to the arch definitions as well, so the linker chose one based on link order (see 10629d711ed7 ("PCI: Remove __weak annotation from pcibios_get_phb_of_node decl")). Remove the "weak" attribute from the declarations so we always prefer a non-weak definition over the weak one, independent of link order. Signed-off-by: Bjorn Helgaas <bhelgaas@google.com> Acked-by: Ingo Molnar <mingo@kernel.org> Acked-by: Srikar Dronamraju <srikar@linux.vnet.ibm.com> CC: Victor Kamensky <victor.kamensky@linaro.org> CC: Oleg Nesterov <oleg@redhat.com> CC: David A. Long <dave.long@linaro.org> CC: Ananth N Mavinakayanahalli <ananth@in.ibm.com>
2014-10-22memory-hotplug: Remove "weak" from memory_block_size_bytes() declarationBjorn Helgaas
drivers/base/memory.c provides a default memory_block_size_bytes() definition explicitly marked "weak". Several architectures provide their own definitions intended to override the default, but the "weak" attribute on the declaration applied to the arch definitions as well, so the linker chose one based on link order (see 10629d711ed7 ("PCI: Remove __weak annotation from pcibios_get_phb_of_node decl")). Remove the "weak" attribute from the declaration so we always prefer a non-weak definition over the weak one, independent of link order. Fixes: 41f107266b19 ("drivers: base: Add prototype declaration to the header file") Signed-off-by: Bjorn Helgaas <bhelgaas@google.com> Acked-by: Andrew Morton <akpm@linux-foundation.org> CC: Rashika Kheria <rashika.kheria@gmail.com> CC: Nathan Fontenot <nfont@austin.ibm.com> CC: Anton Blanchard <anton@au1.ibm.com> CC: Heiko Carstens <heiko.carstens@de.ibm.com> CC: Yinghai Lu <yinghai@kernel.org>
2014-10-22kgdb: Remove "weak" from kgdb_arch_pc() declarationBjorn Helgaas
kernel/debug/debug_core.c provides a default kgdb_arch_pc() definition explicitly marked "weak". Several architectures provide their own definitions intended to override the default, but the "weak" attribute on the declaration applied to the arch definitions as well, so the linker chose one based on link order (see 10629d711ed7 ("PCI: Remove __weak annotation from pcibios_get_phb_of_node decl")). Remove the "weak" attribute from the declaration so we always prefer a non-weak definition over the weak one, independent of link order. Fixes: 688b744d8bc8 ("kgdb: fix signedness mixmatches, add statics, add declaration to header") Tested-by: Vineet Gupta <vgupta@synopsys.com> # for ARC build Signed-off-by: Bjorn Helgaas <bhelgaas@google.com> Reviewed-by: Harvey Harrison <harvey.harrison@gmail.com>
