path: root/include/linux
2007-05-09[POWERPC] swsusp: Introduce register_nosave_region_lateJohannes Berg
This patch introduces a new register_nosave_region_late function that can be called from initcalls when register_nosave_region can no longer be used because it uses bootmem. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Acked-by: Rafael J. Wysocki <rjw@sisk.pl> Signed-off-by: Paul Mackerras <paulus@samba.org>
2007-05-08disable socket power in adapter driver instead of media oneAlex Dubov
Socket power must be fully controlled by adapter driver. This also prevents unnecessary power-off of the socket when media driver is unloaded, yet media remains in the socket. Signed-off-by: Alex Dubov <oakad@yahoo.com> Signed-off-by: Pierre Ossman <drzeus@drzeus.cx>
2007-05-08Merge branch 'reset-seq' of ↵Linus Torvalds
master.kernel.org:/pub/scm/linux/kernel/git/jgarzik/libata-dev * 'reset-seq' of master.kernel.org:/pub/scm/linux/kernel/git/jgarzik/libata-dev: [libata reset-seq] build and merge fixes libata: reimplement reset sequencing libata: improve ata_std_prereset() libata: improve 0xff status handling libata: add deadline support to prereset and reset methods
2007-05-08Merge master.kernel.org:/pub/scm/linux/kernel/git/dtor/inputLinus Torvalds
* master.kernel.org:/pub/scm/linux/kernel/git/dtor/input: Input: move USB miscellaneous devices under drivers/input/misc Input: move USB mice under drivers/input/mouse Input: move USB gamepads under drivers/input/joystick Input: move USB touchscreens under drivers/input/touchscreen Input: move USB tablets under drivers/input/tablet Input: i8042 - fix AUX port detection with some chips Input: aaed2000_kbd - convert to use polldev library Input: drivers/usb/input - usb_buffer_free() cleanup Input: synaptics - don't complain about failed resets Input: pull input.h into uinpit.h Input: drivers/usb/input - fix sparse warnings (signedness) Input: evdev - fix some sparse warnings (signedness, shadowing) Input: drivers/joystick - fix various sparse warnings Input: force feedback - make sure effect is present before playing
2007-05-08Merge branch 'master' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/paulus/powerpc * 'master' of git://git.kernel.org/pub/scm/linux/kernel/git/paulus/powerpc: (77 commits) [POWERPC] Abolish powerpc_flash_init() [POWERPC] Early serial debug support for PPC44x [POWERPC] Support for the Ebony 440GP reference board in arch/powerpc [POWERPC] Add device tree for Ebony [POWERPC] Add powerpc/platforms/44x, disable platforms/4xx for now [POWERPC] MPIC U3/U4 MSI backend [POWERPC] MPIC MSI allocator [POWERPC] Enable MSI mappings for MPIC [POWERPC] Tell Phyp we support MSI [POWERPC] RTAS MSI implementation [POWERPC] PowerPC MSI infrastructure [POWERPC] Rip out the existing powerpc msi stubs [POWERPC] Remove use of 4level-fixup.h for ppc32 [POWERPC] Add powerpc PCI-E reset API implementation [POWERPC] Holly bootwrapper [POWERPC] Holly DTS [POWERPC] Holly defconfig [POWERPC] Add support for 750CL Holly board [POWERPC] Generalize tsi108 PCI setup [POWERPC] Generalize tsi108 PHY types ... Fixed conflict in include/asm-powerpc/kdebug.h manually Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-08s3fb: updatesOndrej Zajicek
Move s3fb_get_tilemax to svgalib.c as svga_get_tilemax, because it reports limitation of other code from svgalib (svga_settile, svga_tilecopy, ...) Limit font width to 8 pixels in 4 bpp mode. Signed-off-by: Ondrej Zajicek <santiago@crfreenet.org> Signed-off-by: Antonino Daplas <adaplas@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-08use mutex instead of semaphore in virtual console driverMatthias Kaehlcke
The virtual console driver uses a semaphore as mutex. Use the mutex API instead of the (binary) semaphore. Signed-off-by: Matthias Kaehlcke <matthias.kaehlcke@gmail.com> Cc: "Antonino A. Daplas" <adaplas@pol.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-08fbdev: fbcon: check if mode can handle new screenAntonino A. Daplas
Check if the mode can properly display the screen. This will be needed by drivers where the capability is not constant with each mode. The function fb_set_var() will query fbcon the requirement, then it will query the driver (via a new hook fb_get_caps()) its capability. If the driver's capability cannot handle fbcon's requirement, then fb_set_var() will fail. For example, if a particular driver supports 2 modes where: mode1 = can only display 8x16 bitmaps mode2 = can display any bitmap then if current mode = mode2 and current font = 12x22 fbset <mode1> /* mode1 cannot handle 12x22 */ fbset will fail Signed-off-by: Antonino Daplas <adaplas@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-08fbdev: add tile operation to get the maximum length of the mapAntonino A. Daplas
Add a tile method, fb_get_tilemax(), that returns the maximum length of the tile map (or font map). This is needed by s3fb which can only handle 256 characters. Signed-off-by: Antonino Daplas <adaplas@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-08fbcon: font setting should check limitation of driverAntonino A. Daplas
fbcon_set_font() will now check if the new font dimensions can be drawn by the driver (by checking pixmap.blit_x and blit_y). Similarly, add 2 new parameters to get_default_font(), font_w and font_h, to further aid in the font selection process. Signed-off-by: Antonino Daplas <adaplas@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-08fbdev: advertise limitation of drawing engineAntonino A. Daplas
A few drivers are not capable of blitting rectangles of any dimension. vga16fb can only blit 8-pixel wide rectangles, while s3fb (in tileblitting mode) can only blit 8x16 rectangles. For example, loading a 12x22 font in vga16fb will result in a corrupt display. Advertise this limitation/capability in info->pixmap.blit_x and blit_y. These fields are 32-bit arrays (font max is 32x32 only), ie, if bit 7 is set, then width/height of 7+1 is supported. Signed-off-by: Antonino Daplas <adaplas@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-08fbdev: add fb_read/fb_write functions for framebuffers in system RAMAntonino A. Daplas
The functions fb_read() and fb_write in fbmem.c assume that the framebuffer is in IO memory. However, we have 3 drivers (hecubafb, arcfb, and vfb) where the framebuffer is allocated from system RAM (via vmalloc). Using __raw_read/__raw_write (fb_readl/fb_writel) for these drivers is illegal, especially in other platforms. Create file read and write methods for these types of drivers. These are named fb_sys_read() and fb_sys_write(). Signed-off-by: Antonino Daplas <adaplas@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-08fbdev: pass struct fb_info to fb_read and fb_writeAntonino A. Daplas
It is unnecessary to pass struct file to fb_read() and fb_write() in struct fb_ops. For consistency with the other methods, pass struct fb_info instead. Signed-off-by: Antonino Daplas <adaplas@gmail.com> Acked-by: Paul Mundt <lethal@linux-sh.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-08fbdev: add drawing functions for framebuffers in system RAMAntonino A. Daplas
The generic drawing functions (cfbimgblt, cfbcopyarea, cfbfillrect) assume that the framebuffer is in IO memory. However, we have 3 drivers (hecubafb, arcfb, and vfb) where the framebuffer is allocated from system RAM (via vmalloc). Using _raw_read/write and family for these drivers (as used in the cfb* functions) is illegal, especially in other platforms. Create 3 new drawing functions, based almost entirely from the original except that the framebuffer memory is assumed to be in system RAM. These are named as sysimgblt, syscopyarea, and sysfillrect. Signed-off-by: Antonino Daplas <adaplas@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-08vt: add color support to the "underline" and "italic" attributesJan Engelhardt
Add color support to the "underline" and "italic" attributes as in OpenBSD/NetBSD-style (vt220) and xterm. Signed-off-by: Jan Engelhardt <jengelh@gmx.de> Acked-by: "Antonino A. Daplas" <adaplas@pol.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-08fb: fsync() method for deferred I/O flush.Paul Mundt
There are cases when we do not want to wait on the delay for automatically updating the "real" framebuffer, this implements a simple ->fsync() hook for explicitly flushing the deferred I/O work. The ->page_mkwrite() handler will rearm the work queue normally. (akpm: nuke unneeded ifdefs, forward-delcare struct dentry) Signed-off-by: Paul Mundt <lethal@linux-sh.org> Cc: Jaya Kumar <jayakumar.lkml@gmail.com> Acked-by: Antonino Daplas <adaplas@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-08fbdev: mm: Deferred IO supportJaya Kumar
This implements deferred IO support in fbdev. Deferred IO is a way to delay and repurpose IO. This implementation is done using mm's page_mkwrite and page_mkclean hooks in order to detect, delay and then rewrite IO. This functionality is used by hecubafb. [adaplas] This is useful for graphics hardware with no directly addressable/mappable framebuffer. Implementing this will allow the "framebuffer" to be accesible from user space via mmap(). Signed-off-by: Jaya Kumar <jayakumar.lkml@gmail.com> Signed-off-by: Antonino Daplas <adaplas@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-08fbdev: display classJames Simmons
Add the new display class. This is meant to unite the various solutions to display units ie acpi output device, auxdisplay and the defunct lcd class in the backlight directory. Signed-off-by: James Simmons <jsimmons@infradead.org> Cc: "Antonino A. Daplas" <adaplas@pol.net> Cc: Greg KH <greg@kroah.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-08Char: cyclades, dynamic portsJiri Slaby
and save thus approx. 160k of .bss Signed-off-by: Jiri Slaby <jirislaby@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-08Char: cyclades, remove unused timestampsJiri Slaby
2007-05-08Char: cyclades, remove sleep_onJiri Slaby
convert to wait_* and completion Signed-off-by: Jiri Slaby <jirislaby@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-08Char: cyclades, make info->card a pointerJiri Slaby
2007-05-08Char: cyclades, remove useless fileds from cyclades_cardJiri Slaby
pde, ctl_phys and base_phys are useless -- they are never used. Signed-off-by: Jiri Slaby <jirislaby@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-08Char: cyclades, unexport struct cyclades_cardJiri Slaby
Do not export internal card data to userspace. cytune doesn't use this anyway. Signed-off-by: Jiri Slaby <jirislaby@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-08PNP: notice whether we have PNP devices (PNPBIOS or PNPACPI)Bjorn Helgaas
This series converts i386 and x86_64 legacy serial ports to be platform devices and prevents probing for them if we have PNP. This prevents double discovery, where a device was found both by the legacy probe and by 8250_pnp. This also prevents the serial driver from claiming IRDA devices (unless they have a UART PNP ID). The serial legacy probe sometimes assumed the wrong IRQ, so the user had to use "setserial" to fix it. Removing the need for setserial to make IRDA devices work seems good, but it does break some things. In particular, you may need to keep setserial from poking legacy UART stuff back in by doing something like "dpkg-reconfigure setserial" with the "kernel" option. Otherwise, the setserial-discovered "UART" will claim resources and prevent the IRDA driver from loading. This patch: If we can discover devices using PNP, we can skip some legacy probes. This flag ("pnp_platform_devices") indicates that PNPBIOS or PNPACPI is enabled and should tell us about builtin devices. Signed-off-by: Bjorn Helgaas <bjorn.helgaas@hp.com> Cc: Keith Owens <kaos@ocs.com.au> Cc: Len Brown <lenb@kernel.org> Cc: Adam Belay <ambx1@neo.rr.com> Cc: Matthieu CASTET <castet.matthieu@free.fr> Cc: Jean Tourrilhes <jt@hpl.hp.com> Cc: Matthew Garrett <mjg59@srcf.ucam.org> Cc: Ville Syrjala <syrjala@sci.fi> Cc: Russell King <rmk+serial@arm.linux.org.uk> Cc: Samuel Ortiz <samuel@sortiz.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-08Char: cyclades, cy_readX/writeX cleanupJiri Slaby
cyclades, cy_readX/writeX cleanup - cy_readX are placeholders for readX, remove it - move cy_writeX macros into do {} while(0) to be safe Signed-off-by: Jiri Slaby <jirislaby@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-08Add IRQF_IRQPOLL flag (common code)Bernhard Walle
irqpoll is broken on some architectures that don't use the IRQ 0 for the timer interrupt like IA64. This patch adds a IRQF_IRQPOLL flag. Each architecture is handled in a separate pach. As I left the irq == 0 as condition, this should not break existing architectures that use timer_irq == 0 and that I did't address with that patch (because I don't know). This patch: This patch adds a IRQF_IRQPOLL flag that the interrupt registration code could use for the interrupt it wants to use for IRQ polling. Because this must not be the timer interrupt, an additional flag was added instead of re-using the IRQF_TIMER constant. Until all architectures will have an IRQF_IRQPOLL interrupt, irq == 0 will stay as alternative as it should not break anything. Also, note_interrupt() is called on CPU-specific interrupts to be used as interrupt source for IRQ polling. Signed-off-by: Bernhard Walle <bwalle@suse.de> Cc: Russell King <rmk@arm.linux.org.uk> Cc: Kyle McMartin <kyle@mcmartin.ca> Cc: Matthew Wilcox <willy@debian.org> Cc: Grant Grundler <grundler@google.com> Cc: Paul Mundt <lethal@linux-sh.org> Cc: "Luck, Tony" <tony.luck@intel.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Alan Cox <alan@lxorguk.ukuu.org.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-08nfs: fix congestion control: use atomic_longsPeter Zijlstra
Change the atomic_t in struct nfs_server to atomic_long_t in anticipation of machines that can handle 8+TB of (4K) pages under writeback. However I suspect other things in NFS will start going *bang* by then. Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Trond Myklebust <trond.myklebust@fys.uio.no> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-08Kprobes: The ON/OFF knob thru debugfsAnanth N Mavinakayanahalli
This patch provides a debugfs knob to turn kprobes on/off o A new file /debug/kprobes/enabled indicates if kprobes is enabled or not (default enabled) o Echoing 0 to this file will disarm all installed probes o Any new probe registration when disabled will register the probe but not arm it. A message will be printed out in such a case. o When a value 1 is echoed to the file, all probes (including ones registered in the intervening period) will be enabled o Unregistration will happen irrespective of whether probes are globally enabled or not. o Update Documentation/kprobes.txt to reflect these changes. While there also update the doc to make it current. We are also looking at providing sysrq key support to tie to the disabling feature provided by this patch. [akpm@linux-foundation.org: Use bool like a bool!] [akpm@linux-foundation.org: add printk facility levels] [cornelia.huck@de.ibm.com: Add the missing arch_trampoline_kprobe() for s390] Signed-off-by: Ananth N Mavinakayanahalli <ananth@in.ibm.com> Signed-off-by: Srinivasa DS <srinivasa@in.ibm.com> Signed-off-by: Cornelia Huck <cornelia.huck@de.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-08kprobes: kretprobes simplificationsChristoph Hellwig
- consolidate duplicate code in all arch_prepare_kretprobe instances into common code - replace various odd helpers that use hlist_for_each_entry to get the first elemenet of a list with either a hlist_for_each_entry_save or an opencoded access to the first element in the caller - inline add_rp_inst into it's only remaining caller - use kretprobe_inst_table_head instead of opencoding it Signed-off-by: Christoph Hellwig <hch@lst.de> Cc: Prasanna S Panchamukhi <prasanna@in.ibm.com> Acked-by: Ananth N Mavinakayanahalli <ananth@in.ibm.com> Cc: Anil S Keshavamurthy <anil.s.keshavamurthy@intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-08revert "rtc: Add rtc_merge_alarm()"Andrew Morton
David says "884b4aaaa242a2db8c8252796f0118164a680ab5 should be reverted. It added an rtc_merge_alarm() call to the 2.6.20 kernel, which hasn't yet been used by any in-tree driver; this patch obviates the need for that call, and uses a more robust approach." Cc: Scott Wood <scottwood@freescale.com> Cc: Alessandro Zummo <a.zummo@towertech.it> Cc: David Brownell <david-b@pacbell.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-08rtc-cmos wakeup interfaceDavid Brownell
I finally got around to testing the updated wakeup event hooks for rtc-cmos, and they follow in two patches: - Interface update ... when a simple enable_irq_wake() doesn't suffice, the platform data can hold suspend/resume callback hooks. - ACPI implementation ... provides callback hooks to do ACPI magic, and eliminate the legacy /proc/acpi/alarm file. The interface update could go into 2.6.21, but that's not essential; they will be NOPs on most PCs, without the ACPI stuff. I suspect the ACPI folk may have opinions about how to merge that second patch, and how to obsolete that legacy procfs file. I'd like to see that merge into 2.6.22 if possible... As for how to kick it in ... two ways: - The appended "rtcwake" program; updated since the last time it was posted, it deals much better with timezones and DST. - Write the /sys/class/rtc/.../wakealarm file, then go to sleep. For some reason RTC wake from "swsusp" stopped working on a system where it previously worked; the alarm setting appears to get clobbered. But on the bright side, RTC wake from "standby" worked on a system that had never been able to resume from that state before ... IDEACPI is my guess as to why it finally started to work. It's the old "two steps forward, one step back" dance, I guess. - Dave /* gcc -Wall -Os -o rtcwake rtcwake.c */ #include <stdio.h> #include <getopt.h> #include <fcntl.h> #include <stdlib.h> #include <string.h> #include <unistd.h> #include <errno.h> #include <time.h> #include <sys/ioctl.h> #include <sys/time.h> #include <sys/types.h> #include <linux/rtc.h> /* constants from legacy PC/AT hardware */ #define RTC_PF 0x40 #define RTC_AF 0x20 #define RTC_UF 0x10 /* * rtcwake -- enter a system sleep state until specified wakeup time. * * This uses cross-platform Linux interfaces to enter a system sleep state, * and leave it no later than a specified time. It uses any RTC framework * driver that supports standard driver model wakeup flags. * * This is normally used like the old "apmsleep" utility, to wake from a * suspend state like ACPI S1 (standby) or S3 (suspend-to-RAM). Most * platforms can implement those without analogues of BIOS, APM, or ACPI. * * On some systems, this can also be used like "nvram-wakeup", waking * from states like ACPI S4 (suspend to disk). Not all systems have * persistent media that are appropriate for such suspend modes. * * The best way to set the system's RTC is so that it holds the current * time in UTC. Use the "-l" flag to tell this program that the system * RTC uses a local timezone instead (maybe you dual-boot MS-Windows). */ static char *progname; #ifdef DEBUG #define VERSION "1.0 dev (" __DATE__ " " __TIME__ ")" #else #define VERSION "0.9" #endif static unsigned verbose; static int rtc_is_utc = -1; static int may_wakeup(const char *devname) { char buf[128], *s; FILE *f; snprintf(buf, sizeof buf, "/sys/class/rtc/%s/device/power/wakeup", devname); f = fopen(buf, "r"); if (!f) { perror(buf); return 0; } fgets(buf, sizeof buf, f); fclose(f); s = strchr(buf, '\n'); if (!s) return 0; *s = 0; /* wakeup events could be disabled or not supported */ return strcmp(buf, "enabled") == 0; } /* all times should be in UTC */ static time_t sys_time; static time_t rtc_time; static int get_basetimes(int fd) { struct tm tm; struct rtc_time rtc; /* this process works in RTC time, except when working * with the system clock (which always uses UTC). */ if (rtc_is_utc) setenv("TZ", "UTC", 1); tzset(); /* read rtc and system clocks "at the same time", or as * precisely (+/- a second) as we can read them. */ if (ioctl(fd, RTC_RD_TIME, &rtc) < 0) { perror("read rtc time"); return 0; } sys_time = time(0); if (sys_time == (time_t)-1) { perror("read system time"); return 0; } /* convert rtc_time to normal arithmetic-friendly form, * updating tm.tm_wday as used by asctime(). */ memset(&tm, 0, sizeof tm); tm.tm_sec = rtc.tm_sec; tm.tm_min = rtc.tm_min; tm.tm_hour = rtc.tm_hour; tm.tm_mday = rtc.tm_mday; tm.tm_mon = rtc.tm_mon; tm.tm_year = rtc.tm_year; tm.tm_isdst = rtc.tm_isdst; /* stays unspecified? */ rtc_time = mktime(&tm); if (rtc_time == (time_t)-1) { perror("convert rtc time"); return 0; } if (verbose) { if (!rtc_is_utc) { printf("\ttzone = %ld\n", timezone); printf("\ttzname = %s\n", tzname[daylight]); gmtime_r(&rtc_time, &tm); } printf("\tsystime = %ld, (UTC) %s", (long) sys_time, asctime(gmtime(&sys_time))); printf("\trtctime = %ld, (UTC) %s", (long) rtc_time, asctime(&tm)); } return 1; } static int setup_alarm(int fd, time_t *wakeup) { struct tm *tm; struct rtc_wkalrm wake; tm = gmtime(wakeup); wake.time.tm_sec = tm->tm_sec; wake.time.tm_min = tm->tm_min; wake.time.tm_hour = tm->tm_hour; wake.time.tm_mday = tm->tm_mday; wake.time.tm_mon = tm->tm_mon; wake.time.tm_year = tm->tm_year; wake.time.tm_wday = tm->tm_wday; wake.time.tm_yday = tm->tm_yday; wake.time.tm_isdst = tm->tm_isdst; /* many rtc alarms only support up to 24 hours from 'now' ... */ if ((rtc_time + (24 * 60 * 60)) > *wakeup) { if (ioctl(fd, RTC_ALM_SET, &wake.time) < 0) { perror("set rtc alarm"); return 0; } if (ioctl(fd, RTC_AIE_ON, 0) < 0) { perror("enable rtc alarm"); return 0; } /* ... so use the "more than 24 hours" request only if we must */ } else { /* avoid an extra AIE_ON call */ wake.enabled = 1; if (ioctl(fd, RTC_WKALM_SET, &wake) < 0) { perror("set rtc wake alarm"); return 0; } } return 1; } static void suspend_system(const char *suspend) { FILE *f = fopen("/sys/power/state", "w"); if (!f) { perror("/sys/power/state"); return; } fprintf(f, "%s\n", suspend); fflush(f); /* this executes after wake from suspend */ fclose(f); } int main(int argc, char **argv) { static char *devname = "rtc0"; static unsigned seconds = 0; static char *suspend = "standby"; int t; int fd; time_t alarm = 0; progname = strrchr(argv[0], '/'); if (progname) progname++; else progname = argv[0]; if (chdir("/dev/") < 0) { perror("chdir /dev"); return 1; } while ((t = getopt(argc, argv, "d:lm:s:t:uVv")) != EOF) { switch (t) { case 'd': devname = optarg; break; case 'l': rtc_is_utc = 0; break; /* what system power mode to use? for now handle only * standardized mode names; eventually when systems define * their own state names, parse /sys/power/state. * * "on" is used just to test the RTC alarm mechanism, * bypassing all the wakeup-from-sleep infrastructure. */ case 'm': if (strcmp(optarg, "standby") == 0 || strcmp(optarg, "mem") == 0 || strcmp(optarg, "disk") == 0 || strcmp(optarg, "on") == 0 ) { suspend = optarg; break; } printf("%s: unrecognized suspend state '%s'\n", progname, optarg); goto usage; /* alarm time, seconds-to-sleep (relative) */ case 's': t = atoi(optarg); if (t < 0) { printf("%s: illegal interval %s seconds\n", progname, optarg); goto usage; } seconds = t; break; /* alarm time, time_t (absolute, seconds since 1/1 1970 UTC) */ case 't': t = atoi(optarg); if (t < 0) { printf("%s: illegal time_t value %s\n", progname, optarg); goto usage; } alarm = t; break; case 'u': rtc_is_utc = 1; break; case 'v': verbose++; break; case 'V': printf("%s: version %s\n", progname, VERSION); break; default: usage: printf("usage: %s [options]" "\n\t" "-d rtc0|rtc1|...\t(select rtc)" "\n\t" "-l\t\t\t(RTC uses local timezone)" "\n\t" "-m standby|mem|...\t(sleep mode)" "\n\t" "-s seconds\t\t(seconds to sleep)" "\n\t" "-t time_t\t\t(time to wake)" "\n\t" "-u\t\t\t(RTC uses UTC)" "\n\t" "-v\t\t\t(verbose messages)" "\n\t" "-V\t\t\t(show version)" "\n", progname); return 1; } } if (!alarm && !seconds) { printf("%s: must provide wake time\n", progname); goto usage; } /* REVISIT: if /etc/adjtime exists, read it to see what * the util-linux version of hwclock assumes. */ if (rtc_is_utc == -1) { printf("%s: assuming RTC uses UTC ...\n", progname); rtc_is_utc = 1; } /* this RTC must exist and (if we'll sleep) be wakeup-enabled */ fd = open(devname, O_RDONLY); if (fd < 0) { perror(devname); return 1; } if (strcmp(suspend, "on") != 0 && !may_wakeup(devname)) { printf("%s: %s not enabled for wakeup events\n", progname, devname); return 1; } /* relative or absolute alarm time, normalized to time_t */ if (!get_basetimes(fd)) return 1; if (verbose) printf("alarm %ld, sys_time %ld, rtc_time %ld, seconds %u\n", alarm, sys_time, rtc_time, seconds); if (alarm) { if (alarm < sys_time) { printf("%s: time doesn't go backward to %s", progname, ctime(&alarm)); return 1; } alarm += sys_time - rtc_time; } else alarm = rtc_time + seconds + 1; if (setup_alarm(fd, &alarm) < 0) return 1; sync(); printf("%s: wakeup from \"%s\" using %s at %s", progname, suspend, devname, ctime(&alarm)); fflush(stdout); usleep(10 * 1000); if (strcmp(suspend, "on") != 0) suspend_system(suspend); else { unsigned long data; do { t = read(fd, &data, sizeof data); if (t < 0) { perror("rtc read"); break; } if (verbose) printf("... %s: %03lx\n", devname, data); } while (!(data & RTC_AF)); } if (ioctl(fd, RTC_AIE_OFF, 0) < 0) perror("disable rtc alarm interrupt"); close(fd); return 0; } This patch: Make rtc-cmos do the relevant magic so this RTC can wake the system from a sleep state. That magic comes in two basic flavors: - Straightforward: enable_irq_wake(), the way it'd work on most SOC chips; or generally with system sleep states which don't disable core IRQ logic. - Roundabout, using non-IRQ platform hooks. This is needed with ACPI and one almost-clone chip which uses a special wakeup-only alarm. (That's the RTC used on Footbridge boards, FWIW, which don't do PM in Linux.) A separate patch implements those hooks for ACPI platforms, so that rtc_cmos can issue system wakeup events (and its sysfs "wakealarm" attribute works on at least some systems). Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Cc: Alessandro Zummo <a.zummo@towertech.it> Cc: Len Brown <lenb@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-08rtc: remove rest of class_deviceDavid Brownell
Finish converting the RTC framework so it no longer uses class_device. Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Acked-by: Greg Kroah-Hartman <gregkh@suse.de> Acked-By: Alessandro Zummo <a.zummo@towertech.it> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-08rtc: rtc interfaces don't use class_deviceDavid Brownell
This patch removes class_device from the programming interface that the RTC framework exposes to the rest of the kernel. Now an rtc_device is passed, which is more type-safe and streamlines all the relevant code. Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Acked-by: Greg Kroah-Hartman <gregkh@suse.de> Acked-By: Alessandro Zummo <a.zummo@towertech.it> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-08rtc: remove /sys/class/rtc-dev/*David Brownell
This simplifies the /dev support by removing a superfluous class_device (the /sys/class/rtc-dev stuff) and the class_interface that hooks it into the rtc core. Accordingly, if it's configured then /dev support is now part of the RTC core, and is never a separate module. It's another step towards being able to remove "struct class_device". [bunk@stusta.de: drivers/rtc/rtc-dev.c should #include "rtc-core.h"] Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Acked-by: Greg Kroah-Hartman <gregkh@suse.de> Acked-By: Alessandro Zummo <a.zummo@towertech.it> Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-08utimensat implementationUlrich Drepper
Implement utimensat(2) which is an extension to futimesat(2) in that it a) supports nano-second resolution for the timestamps b) allows to selectively ignore the atime/mtime value c) allows to selectively use the current time for either atime or mtime d) supports changing the atime/mtime of a symlink itself along the lines of the BSD lutimes(3) functions For this change the internally used do_utimes() functions was changed to accept a timespec time value and an additional flags parameter. Additionally the sys_utime function was changed to match compat_sys_utime which already use do_utimes instead of duplicating the work. Also, the completely missing futimensat() functionality is added. We have such a function in glibc but we have to resort to using /proc/self/fd/* which not everybody likes (chroot etc). Test application (the syscall number will need per-arch editing): #include <errno.h> #include <fcntl.h> #include <time.h> #include <sys/time.h> #include <stddef.h> #include <syscall.h> #define __NR_utimensat 280 #define UTIME_NOW ((1l << 30) - 1l) #define UTIME_OMIT ((1l << 30) - 2l) int main(void) { int status = 0; int fd = open("ttt", O_RDWR|O_CREAT|O_EXCL, 0666); if (fd == -1) error (1, errno, "failed to create test file \"ttt\""); struct stat64 st1; if (fstat64 (fd, &st1) != 0) error (1, errno, "fstat failed"); struct timespec t[2]; t[0].tv_sec = 0; t[0].tv_nsec = 0; t[1].tv_sec = 0; t[1].tv_nsec = 0; if (syscall(__NR_utimensat, AT_FDCWD, "ttt", t, 0) != 0) error (1, errno, "utimensat failed"); struct stat64 st2; if (fstat64 (fd, &st2) != 0) error (1, errno, "fstat failed"); if (st2.st_atim.tv_sec != 0 || st2.st_atim.tv_nsec != 0) { puts ("atim not reset to zero"); status = 1; } if (st2.st_mtim.tv_sec != 0 || st2.st_mtim.tv_nsec != 0) { puts ("mtim not reset to zero"); status = 1; } if (status != 0) goto out; t[0] = st1.st_atim; t[1].tv_sec = 0; t[1].tv_nsec = UTIME_OMIT; if (syscall(__NR_utimensat, AT_FDCWD, "ttt", t, 0) != 0) error (1, errno, "utimensat failed"); if (fstat64 (fd, &st2) != 0) error (1, errno, "fstat failed"); if (st2.st_atim.tv_sec != st1.st_atim.tv_sec || st2.st_atim.tv_nsec != st1.st_atim.tv_nsec) { puts ("atim not set"); status = 1; } if (st2.st_mtim.tv_sec != 0 || st2.st_mtim.tv_nsec != 0) { puts ("mtim changed from zero"); status = 1; } if (status != 0) goto out; t[0].tv_sec = 0; t[0].tv_nsec = UTIME_OMIT; t[1] = st1.st_mtim; if (syscall(__NR_utimensat, AT_FDCWD, "ttt", t, 0) != 0) error (1, errno, "utimensat failed"); if (fstat64 (fd, &st2) != 0) error (1, errno, "fstat failed"); if (st2.st_atim.tv_sec != st1.st_atim.tv_sec || st2.st_atim.tv_nsec != st1.st_atim.tv_nsec) { puts ("mtim changed from original time"); status = 1; } if (st2.st_mtim.tv_sec != st1.st_mtim.tv_sec || st2.st_mtim.tv_nsec != st1.st_mtim.tv_nsec) { puts ("mtim not set"); status = 1; } if (status != 0) goto out; sleep (2); t[0].tv_sec = 0; t[0].tv_nsec = UTIME_NOW; t[1].tv_sec = 0; t[1].tv_nsec = UTIME_NOW; if (syscall(__NR_utimensat, AT_FDCWD, "ttt", t, 0) != 0) error (1, errno, "utimensat failed"); if (fstat64 (fd, &st2) != 0) error (1, errno, "fstat failed"); struct timeval tv; gettimeofday(&tv,NULL); if (st2.st_atim.tv_sec <= st1.st_atim.tv_sec || st2.st_atim.tv_sec > tv.tv_sec) { puts ("atim not set to NOW"); status = 1; } if (st2.st_mtim.tv_sec <= st1.st_mtim.tv_sec || st2.st_mtim.tv_sec > tv.tv_sec) { puts ("mtim not set to NOW"); status = 1; } if (symlink ("ttt", "tttsym") != 0) error (1, errno, "cannot create symlink"); t[0].tv_sec = 0; t[0].tv_nsec = 0; t[1].tv_sec = 0; t[1].tv_nsec = 0; if (syscall(__NR_utimensat, AT_FDCWD, "tttsym", t, AT_SYMLINK_NOFOLLOW) != 0) error (1, errno, "utimensat failed"); if (lstat64 ("tttsym", &st2) != 0) error (1, errno, "lstat failed"); if (st2.st_atim.tv_sec != 0 || st2.st_atim.tv_nsec != 0) { puts ("symlink atim not reset to zero"); status = 1; } if (st2.st_mtim.tv_sec != 0 || st2.st_mtim.tv_nsec != 0) { puts ("symlink mtim not reset to zero"); status = 1; } if (status != 0) goto out; t[0].tv_sec = 1; t[0].tv_nsec = 0; t[1].tv_sec = 1; t[1].tv_nsec = 0; if (syscall(__NR_utimensat, fd, NULL, t, 0) != 0) error (1, errno, "utimensat failed"); if (fstat64 (fd, &st2) != 0) error (1, errno, "fstat failed"); if (st2.st_atim.tv_sec != 1 || st2.st_atim.tv_nsec != 0) { puts ("atim not reset to one"); status = 1; } if (st2.st_mtim.tv_sec != 1 || st2.st_mtim.tv_nsec != 0) { puts ("mtim not reset to one"); status = 1; } if (status == 0) puts ("all OK"); out: close (fd); unlink ("ttt"); unlink ("tttsym"); return status; } [akpm@linux-foundation.org: add missing i386 syscall table entry] Signed-off-by: Ulrich Drepper <drepper@redhat.com> Cc: Alexey Dobriyan <adobriyan@openvz.org> Cc: Michael Kerrisk <mtk-manpages@gmx.net> Cc: <linux-arch@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-08Speed up divides by cpu_power in schedulerEric Dumazet
I noticed expensive divides done in try_to_wakeup() and find_busiest_group() on a bi dual core Opteron machine (total of 4 cores), moderatly loaded (15.000 context switch per second) oprofile numbers : CPU: AMD64 processors, speed 2600.05 MHz (estimated) Counted CPU_CLK_UNHALTED events (Cycles outside of halt state) with a unit mask of 0x00 (No unit mask) count 50000 samples % symbol name ... 613914 1.0498 try_to_wake_up 834 0.0013 :ffffffff80227ae1: div %rcx 77513 0.1191 :ffffffff80227ae4: mov %rax,%r11 608893 1.0413 find_busiest_group 1841 0.0031 :ffffffff802260bf: div %rdi 140109 0.2394 :ffffffff802260c2: test %sil,%sil Some of these divides can use the reciprocal divides we introduced some time ago (currently used in slab AFAIK) We can assume a load will fit in a 32bits number, because with a SCHED_LOAD_SCALE=128 value, its still a theorical limit of 33554432 When/if we reach this limit one day, probably cpus will have a fast hardware divide and we can zap the reciprocal divide trick. Ingo suggested to rename cpu_power to __cpu_power to make clear it should not be modified without changing its reciprocal value too. I did not convert the divide in cpu_avg_load_per_task(), because tracking nr_running changes may be not worth it ? We could use a static table of 32 reciprocal values but it would add a conditional branch and table lookup. [akpm@linux-foundation.org: !SMP build fix] Signed-off-by: Eric Dumazet <dada1@cosmosbay.com> Acked-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-08sched: dynticks idle load balancingSiddha, Suresh B
Fix the process idle load balancing in the presence of dynticks. cpus for which ticks are stopped will sleep till the next event wakes it up. Potentially these sleeps can be for large durations and during which today, there is no periodic idle load balancing being done. This patch nominates an owner among the idle cpus, which does the idle load balancing on behalf of the other idle cpus. And once all the cpus are completely idle, then we can stop this idle load balancing too. Checks added in fast path are minimized. Whenever there are busy cpus in the system, there will be an owner(idle cpu) doing the system wide idle load balancing. Open items: 1. Intelligent owner selection (like an idle core in a busy package). 2. Merge with rcu's nohz_cpu_mask? Signed-off-by: Suresh Siddha <suresh.b.siddha@intel.com> Acked-by: Ingo Molnar <mingo@elte.hu> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Nick Piggin <nickpiggin@yahoo.com.au> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-08sanitize linux/isdn_divertif.h for userspaceMike Frysinger
the isdn_divertif contains kernel-only references so I've wrapped them in __KERNEL__ and add proper #include statements. Signed-off-by: Mike Frysinger <vapier@gentoo.org> Cc: Karsten Keil <kkeil@suse.de> Cc: David Woodhouse <dwmw2@infradead.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-08make drivers/isdn/capi/capiutil.c:cdebbuf_alloc() staticAdrian Bunk
Signed-off-by: Adrian Bunk <bunk@stusta.de> Acked-by: Karsten Keil <kkeil@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-08SPI kerneldocDavid Brownell
Various documentation updates for the SPI infrastructure, to clarify things that may not have been clear, to cope with lack of editing, and fix omissions. Also, plug SPI into the kernel-api DocBook template, and fix all the resulting glitches in document generation. Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Cc: "Randy.Dunlap" <rdunlap@xenotime.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-08/dev/spidevB.C interfaceAndrea Paterniani
Add a filesystem API for <linux/spi/spi.h> stack. The initial version of this interface is purely synchronous. dbrownell@users.sourceforge.net: Cleaned up, bugfixed; much simplified; added preliminary documentation. Works with mdev given CONFIG_SYSFS_DEPRECATED; and presumably udev. Updated SPI_IOC_MESSAGE ioctl to full spi_message semantics, supporting groups of one or more transfers (each of which may be full duplex if desired). This is marked as EXPERIMENTAL with an explicit disclaimer that the API (notably the ioctls) is subject to change. Signed-off-by: Andrea Paterniani <a.paterniani@swapp-eng.it> Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Cc: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-08clockchips.h: kernel-doc fixSergei Shtylyov
Fix misnamed fields of 'struct clock_event_device' in the kernel-doc comment. Convert the acronyms to uppercase, while at it... Signed-off-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Acked-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-08hide spinlock in linux/quota.h behind __KERNEL__Mike Frysinger
Signed-off-by: Mike Frysinger <vapier@gentoo.org> Acked-by: Jan Kara <jack@ucw.cz> Cc: David Woodhouse <dwmw2@infradead.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-08Add taskstats.h to kbuildDavid Woodhouse
Add taskstats.h to include/linux/Kbuild, make headers_install would then pickup taskstats.h. This needs to be done as taskstats.h is a user interface header. Signed-off-by: Balbir Singh <balbir@linux.vnet.ibm.com> Signed-off-by: David Woodhouse <dwmw2@infradead.org> Cc: Don Zickus <dzickus@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-08Misc: add sensable phantom driverJiri Slaby
Add sensable phantom driver Signed-off-by: Jiri Slaby <jirislaby@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-08Driver for the Maxim DS1WM, a 1-wire bus master ASIC coreakpm@linux-foundation.org
Cc: Matt Reimer <mreimer@vpop.net> [akpm@linux-foundation.org: kconfig update] Signed-off-by: Matt Reimer <mreimer@vpop.net> Signed-off-by: Evgeniy Polyakov <johnpol@2ka.mipt.ru> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-08consolidate asm/const.h to linux/const.hRandy Dunlap
Make a global linux/const.h header file instead of having multiple, per-arch files, and convert current users of asm/const.h to use linux/const.h. Built on x86_64 and sparc64. [akpm@linux-foundation.org: fix include/asm-x86_64/Kbuild] Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: David S. Miller <davem@davemloft.net> Cc: Andi Kleen <ak@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-08fat: don't use free_clusters for fat32OGAWA Hirofumi
It seems that the recent Windows changed specification, and it's undocumented. Windows doesn't update ->free_clusters correctly. This patch doesn't use ->free_clusters by default. (instead, add "usefree" for forcing to use it) Signed-off-by: OGAWA Hirofumi <hirofumi@mail.parknet.co.jp> Cc: Juergen Beisert <juergen127@kreuzholzen.de> Cc: Andreas Schwab <schwab@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-08ext3: copy i_flags to inode flags on writeJan Kara
A patch that stores inode flags such as S_IMMUTABLE, S_APPEND, etc. from i_flags to EXT3_I(inode)->i_flags when inode is written to disk. The same thing is done on GETFLAGS ioctl. Quota code changes these flags on quota files (to make it harder for sysadmin to screw himself) and these changes were not correctly propagated into the filesystem (especially, lsattr did not show them and users were wondering...). Propagate flags such as S_APPEND, S_IMMUTABLE, etc. from i_flags into ext3-specific i_flags. Hence, when someone sets these flags via a different interface than ioctl, they are stored correctly. Signed-off-by: Jan Kara <jack@suse.cz> Cc: <linux-ext4@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
