path: root/include/linux/xfrm.h
2008-10-05xfrm: MIGRATE enhancements (draft-ebalard-mext-pfkey-enhanced-migrate)Arnaud Ebalard
Provides implementation of the enhancements of XFRM/PF_KEY MIGRATE mechanism specified in draft-ebalard-mext-pfkey-enhanced-migrate-00. Defines associated PF_KEY SADB_X_EXT_KMADDRESS extension and XFRM/netlink XFRMA_KMADDRESS attribute. Signed-off-by: Arnaud Ebalard <arno@natisbad.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-07-10xfrm: Add a XFRM_STATE_AF_UNSPEC flag to xfrm_usersa_infoSteffen Klassert
Add a XFRM_STATE_AF_UNSPEC flag to handle the AF_UNSPEC behavior for the selector family. Userspace applications can set this flag to leave the selector family of the xfrm_state unspecified. This can be used to to handle inter family tunnels if the selector is not set from userspace. Signed-off-by: Steffen Klassert <steffen.klassert@secunet.com> Acked-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-04-25xfrm: alg_key_len & alg_icv_len should be unsignedEric Dumazet
In commit ba749ae98d5aa9d2ce9a7facde0deed454f92230 ([XFRM]: alg_key_len should be unsigned to avoid integer divides <http://git2.kernel.org/?p=linux/kernel/git/davem/net-2.6.git;a=commitdiff;h=ba749ae98d5aa9d2ce9a7facde0deed454f92230>) alg_key_len field of struct xfrm_algo was converted to unsigned int to avoid integer divides. Then Herbert in commit 1a6509d991225ad210de54c63314fd9542922095 ([IPSEC]: Add support for combined mode algorithms) added a new structure xfrm_algo_aead, that resurrected a signed int for alg_key_len and re-introduce integer divides. This patch avoids these divides and saves 64 bytes of text on i386. Signed-off-by: Eric Dumazet <dada1@cosmosbay.com> Acked-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-02-28[XFRM]: Speed up xfrm_policy and xfrm_state walkingTimo Teras
Change xfrm_policy and xfrm_state walking algorithm from O(n^2) to O(n). This is achieved adding the entries to one more list which is used solely for walking the entries. This also fixes some races where the dump can have duplicate or missing entries when the SPD/SADB is modified during an ongoing dump. Dumping SADB with 20000 entries using "time ip xfrm state" the sys time dropped from 1.012s to 0.080s. Signed-off-by: Timo Teras <timo.teras@iki.fi> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-31[IPSEC]: Add support for combined mode algorithmsHerbert Xu
This patch adds support for combined mode algorithms with GCM being the first algorithm supported. Combined mode algorithms can be added through the xfrm_user interface using the new algorithm payload type XFRMA_ALG_AEAD. Each algorithms is identified by its name and the ICV length. For the purposes of matching algorithms in xfrm_tmpl structures, combined mode algorithms occupy the same name space as encryption algorithms. This is in line with how they are negotiated using IKE. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-28[XFRM]: Fix struct xfrm_algo code formatting.David S. Miller
Realign struct members. Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-28[XFRM]: alg_key_len should be unsigned to avoid integer dividesEric Dumazet
alg_key_len is currently defined as 'signed int'. This unfortunatly leads to integer divides in several paths. Converting it to unsigned is safe and saves 208 bytes of text on i386. Signed-off-by: Eric Dumazet <dada1@cosmosbay.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-28[IPSEC]: Add ICMP host relookup supportHerbert Xu
RFC 4301 requires us to relookup ICMP traffic that does not match any policies using the reverse of its payload. This patch implements this for ICMP traffic that originates from or terminates on localhost. This is activated on outbound with the new policy flag XFRM_POLICY_ICMP, and on inbound by the new state flag XFRM_STATE_ICMP. On inbound the policy check is now performed by the ICMP protocol so that it can repeat the policy check where necessary. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-28[IPSEC]: Added xfrm_decode_session_reverse and xfrmX_policy_check_reverseHerbert Xu
RFC 4301 requires us to relookup ICMP traffic that does not match any policies using the reverse of its payload. This patch adds the functions xfrm_decode_session_reverse and xfrmX_policy_check_reverse so we can get the reverse flow to perform such a lookup. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-05-04[XFRM] SPD info TLV aggregationJamal Hadi Salim
Aggregate the SPD info TLVs. Signed-off-by: Jamal Hadi Salim <hadi@cyberus.ca> Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-05-04[XFRM] SAD info TLV aggregationxJamal Hadi Salim
Aggregate the SAD info TLVs. Signed-off-by: Jamal Hadi Salim <hadi@cyberus.ca> Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-28[XFRM]: Export SPD infoJamal Hadi Salim
With this patch you can use iproute2 in user space to efficiently see how many policies exist in different directions. Signed-off-by: Jamal Hadi Salim <hadi@cyberus.ca> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-26[XFRM]: Export SAD info.Jamal Hadi Salim
On a system with a lot of SAs, counting SAD entries chews useful CPU time since you need to dump the whole SAD to user space; i.e something like ip xfrm state ls | grep -i src | wc -l I have seen taking literally minutes on a 40K SAs when the system is swapping. With this patch, some of the SAD info (that was already being tracked) is exposed to user space. i.e you do: ip xfrm state count And you get the count; you can also pass -s to the command line and get the hash info. Signed-off-by: Jamal Hadi Salim <hadi@cyberus.ca> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-02-08[XFRM]: Extension for dynamic update of endpoint address(es)Shinta Sugimoto
Extend the XFRM framework so that endpoint address(es) in the XFRM databases could be dynamically updated according to a request (MIGRATE message) from user application. Target XFRM policy is first identified by the selector in the MIGRATE message. Next, the endpoint addresses of the matching templates and XFRM states are updated according to the MIGRATE message. Signed-off-by: Shinta Sugimoto <shinta.sugimoto@ericsson.com> Signed-off-by: Masahide NAKAMURA <nakam@linux-ipv6.org> Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-12-08[XFRM]: Fix XFRMGRP_REPORT to use correct multicast group.J Hadi Salim
XFRMGRP_REPORT uses 0x10 which is a group that belongs to events. The correct value is 0x20. We should really be using xfrm_nlgroups going forward; it was tempting to delete the definition of XFRMGRP_REPORT but it would break at least iproute2. Signed-off-by: J Hadi Salim <hadi@cyberus.ca> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-12-02[XFRM]: Fix aevent structuring to be more complete.Jamal Hadi Salim
aevents can not uniquely identify an SA. We break the ABI with this patch, but consensus is that since it is not yet utilized by any (known) application then it is fine (better do it now than later). Signed-off-by: Jamal Hadi Salim <hadi@cyberus.ca> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-12-02[IPV4]: encapsulation annotationsAl Viro
Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-10-04[XFRM]: BEET modeDiego Beltrami
This patch introduces the BEET mode (Bound End-to-End Tunnel) with as specified by the ietf draft at the following link: http://www.ietf.org/internet-drafts/draft-nikander-esp-beet-mode-06.txt The patch provides only single family support (i.e. inner family = outer family). Signed-off-by: Diego Beltrami <diego.beltrami@gmail.com> Signed-off-by: Miika Komu <miika@iki.fi> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: Abhinav Pathak <abhinav.pathak@hiit.fi> Signed-off-by: Jeff Ahrenholz <ahrenholz@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-09-28[XFRM]: struct xfrm_usersa_id annotationsAl Viro
2006-09-28[XFRM]: struct xfrm_id annotationsAl Viro
2006-09-28[XFRM]: xfrm_address_t annotationsAl Viro
2006-09-28[XFRM]: ports in struct xfrm_selector annotatedAl Viro
2006-09-22[XFRM] POLICY: Support netlink socket interface for sub policy.Masahide NAKAMURA
Sub policy can be used through netlink socket. PF_KEY uses main only and it is TODO to support sub. Signed-off-by: Masahide NAKAMURA <nakam@linux-ipv6.org> Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-09-22[XFRM] POLICY: sub policy support.Masahide NAKAMURA
Sub policy is introduced. Main and sub policy are applied the same flow. (Policy that current kernel uses is named as main.) It is required another transformation policy management to keep IPsec and Mobile IPv6 lives separate. Policy which lives shorter time in kernel should be a sub i.e. normally main is for IPsec and sub is for Mobile IPv6. (Such usage as two IPsec policies on different database can be used, too.) Limitation or TODOs: - Sub policy is not supported for per socket one (it is always inserted as main). - Current kernel makes cached outbound with flowi to skip searching database. However this patch makes it disabled only when "two policies are used and the first matched one is bypass case" because neither flowi nor bundle information knows about transformation template size. Signed-off-by: Masahide NAKAMURA <nakam@linux-ipv6.org> Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org>
2006-09-22[XFRM]: Introduce XFRM_MSG_REPORT.Masahide NAKAMURA
XFRM_MSG_REPORT is a message as notification of state protocol and selector from kernel to user-space. Mobile IPv6 will use it when inbound reject is occurred at route optimization to make user-space know a binding error requirement. Based on MIPL2 kernel patch. Signed-off-by: Masahide NAKAMURA <nakam@linux-ipv6.org> Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-09-22[XFRM] IPV6: Update outbound state timestamp for each sending.Masahide NAKAMURA
With this patch transformation state is updated last used time for each sending. Xtime is used for it like other state lifetime expiration. Mobile IPv6 enabled nodes will want to know traffic status of each binding (e.g. judgement to request binding refresh by correspondent node, or to keep home/care-of nonce alive by mobile node). The last used timestamp is an important hint about it. Based on MIPL2 kernel patch. This patch was also written by: Henrik Petander <petander@tcs.hut.fi> Signed-off-by: Masahide NAKAMURA <nakam@linux-ipv6.org> Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-09-22[XFRM] STATE: Introduce care-of address.Noriaki TAKAMIYA
Care-of address is carried by state as a transformation option like IPsec encryption/authentication algorithm. Based on MIPL2 kernel patch. Signed-off-by: Noriaki TAKAMIYA <takamiya@po.ntts.co.jp> Signed-off-by: Masahide NAKAMURA <nakam@linux-ipv6.org> Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org>
2006-09-22[XFRM] STATE: Common receive function for route optimization extension headers.Masahide NAKAMURA
XFRM_STATE_WILDRECV flag is introduced; the last resort state is set it and receives packet which is not route optimized but uses such extension headers i.e. Mobile IPv6 signaling (binding update and acknowledgement). A node enabled Mobile IPv6 adds the state. Based on MIPL2 kernel patch. Signed-off-by: Masahide NAKAMURA <nakam@linux-ipv6.org> Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-09-22[XFRM] STATE: Search by address using source address list.Masahide NAKAMURA
This is a support to search transformation states by its addresses by using source address list for Mobile IPv6 usage. To use it from user-space, it is also added a message type for source address as a xfrm state option. Based on MIPL2 kernel patch. Signed-off-by: Masahide NAKAMURA <nakam@linux-ipv6.org> Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-09-22[XFRM]: Add XFRM_MODE_xxx for future use.Masahide NAKAMURA
Transformation mode is used as either IPsec transport or tunnel. It is required to add two more items, route optimization and inbound trigger for Mobile IPv6. Based on MIPL2 kernel patch. This patch was also written by: Ville Nuorvala <vnuorval@tcs.hut.fi> Signed-off-by: Masahide NAKAMURA <nakam@linux-ipv6.org> Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-06-17[IPSEC] xfrm: Abstract out encapsulation modesHerbert Xu
This patch adds the structure xfrm_mode. It is meant to represent the operations carried out by transport/tunnel modes. By doing this we allow additional encapsulation modes to be added without clogging up the xfrm_input/xfrm_output paths. Candidate modes include 4-to-6 tunnel mode, 6-to-4 tunnel mode, and BEET modes. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-03-20[XFRM]: Rearrange struct xfrm_aevent_id for better compatibility.Jamal Hadi Salim
struct xfrm_aevent_id needs to be 32-bit + 64-bit align friendly. Based upon suggestions from Yoshifuji. Signed-off-by: Jamal Hadi Salim <hadi@cyberus.ca> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-03-20[IPSEC]: Sync series - core changesJamal Hadi Salim
This patch provides the core functionality needed for sync events for ipsec. Derived work of Krisztian KOVACS <hidden@balabit.hu> Signed-off-by: Jamal Hadi Salim <hadi@cyberus.ca> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-01-03[LSM-IPSec]: Security association restriction.Trent Jaeger
This patch series implements per packet access control via the extension of the Linux Security Modules (LSM) interface by hooks in the XFRM and pfkey subsystems that leverage IPSec security associations to label packets. Extensions to the SELinux LSM are included that leverage the patch for this purpose. This patch implements the changes necessary to the XFRM subsystem, pfkey interface, ipv4/ipv6, and xfrm_user interface to restrict a socket to use only authorized security associations (or no security association) to send/receive network packets. Patch purpose: The patch is designed to enable access control per packets based on the strongly authenticated IPSec security association. Such access controls augment the existing ones based on network interface and IP address. The former are very coarse-grained, and the latter can be spoofed. By using IPSec, the system can control access to remote hosts based on cryptographic keys generated using the IPSec mechanism. This enables access control on a per-machine basis or per-application if the remote machine is running the same mechanism and trusted to enforce the access control policy. Patch design approach: The overall approach is that policy (xfrm_policy) entries set by user-level programs (e.g., setkey for ipsec-tools) are extended with a security context that is used at policy selection time in the XFRM subsystem to restrict the sockets that can send/receive packets via security associations (xfrm_states) that are built from those policies. A presentation available at www.selinux-symposium.org/2005/presentations/session2/2-3-jaeger.pdf from the SELinux symposium describes the overall approach. Patch implementation details: On output, the policy retrieved (via xfrm_policy_lookup or xfrm_sk_policy_lookup) must be authorized for the security context of the socket and the same security context is required for resultant security association (retrieved or negotiated via racoon in ipsec-tools). This is enforced in xfrm_state_find. On input, the policy retrieved must also be authorized for the socket (at __xfrm_policy_check), and the security context of the policy must also match the security association being used. The patch has virtually no impact on packets that do not use IPSec. The existing Netfilter (outgoing) and LSM rcv_skb hooks are used as before. Also, if IPSec is used without security contexts, the impact is minimal. The LSM must allow such policies to be selected for the combination of socket and remote machine, but subsequent IPSec processing proceeds as in the original case. Testing: The pfkey interface is tested using the ipsec-tools. ipsec-tools have been modified (a separate ipsec-tools patch is available for version 0.5) that supports assignment of xfrm_policy entries and security associations with security contexts via setkey and the negotiation using the security contexts via racoon. The xfrm_user interface is tested via ad hoc programs that set security contexts. These programs are also available from me, and contain programs for setting, getting, and deleting policy for testing this interface. Testing of sa functions was done by tracing kernel behavior. Signed-off-by: Trent Jaeger <tjaeger@cse.psu.edu> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-08-29[NETLINK]: Convert netlink users to use group numbers instead of bitmasksPatrick McHardy
2005-06-20[IPSEC]: Add XFRM_STATE_NOPMTUDISC flagHerbert Xu
This patch adds the flag XFRM_STATE_NOPMTUDISC for xfrm states. It is similar to the nopmtudisc on IPIP/GRE tunnels. It only has an effect on IPv4 tunnel mode states. For these states, it will ensure that the DF flag is always cleared. This is primarily useful to work around ICMP blackholes. In future this flag could also allow a larger MTU to be set within the tunnel just like IPIP/GRE tunnels. This could be useful for short haul tunnels where temporary fragmentation outside the tunnel is desired over smaller fragments inside the tunnel. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Acked-by: James Morris <jmorris@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-06-18[IPSEC]: Add XFRMA_SA/XFRMA_POLICY for delete notificationHerbert Xu
This patch changes the format of the XFRM_MSG_DELSA and XFRM_MSG_DELPOLICY notification so that the main message sent is of the same format as that received by the kernel if the original message was via netlink. This also means that we won't lose the byid information carried in km_event. Since this user interface is introduced by Jamal's patch we can still afford to change it. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-06-18[IPSEC] Add complete xfrm event notificationJamal Hadi Salim
Heres the final patch. What this patch provides - netlink xfrm events - ability to have events generated by netlink propagated to pfkey and vice versa. - fixes the acquire lets-be-happy-with-one-success issue Signed-off-by: Jamal Hadi Salim <hadi@cyberus.ca> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2005-05-03[XFRM]: Cleanup xfrm_msg_min and xfrm_dispatchThomas Graf
Converts xfrm_msg_min and xfrm_dispatch to use c99 designated initializers to make greping a little bit easier. Also replaces two hardcoded message type with meaningful names. Signed-off-by: Thomas Graf <tgraf@suug.ch> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-05-03[XFRM]: Prevent off-by-one access to xfrm_dispatchThomas Graf
Makes the type > XFRM_MSG_MAX check behave correctly to protect access to xfrm_dispatch. Signed-off-by: Thomas Graf <tgraf@suug.ch> Signed-off-by: David S. Miller <davem@davemloft.net>
