path: root/include/linux/writeback.h
2010-06-08writeback: pay attention to wbc->nr_to_write in write_cache_pagesDave Chinner
If a filesystem writes more than one page in ->writepage, write_cache_pages fails to notice this and continues to attempt writeback when wbc->nr_to_write has gone negative - this trace was captured from XFS: wbc_writeback_start: towrt=1024 wbc_writepage: towrt=1024 wbc_writepage: towrt=0 wbc_writepage: towrt=-1 wbc_writepage: towrt=-5 wbc_writepage: towrt=-21 wbc_writepage: towrt=-85 This has adverse effects on filesystem writeback behaviour. write_cache_pages() needs to terminate after a certain number of pages are written, not after a certain number of calls to ->writepage are made. This is a regression introduced by 17bc6c30cf6bfffd816bdc53682dd46fc34a2cf4 ("vfs: Add no_nrwrite_index_update writeback control flag"), but cannot be reverted directly due to subsequent bug fixes that have gone in on top of it. Signed-off-by: Dave Chinner <dchinner@redhat.com> Reviewed-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-06-01Revert "writeback: fix WB_SYNC_NONE writeback from umount"Jens Axboe
This reverts commit e913fc825dc685a444cb4c1d0f9d32f372f59861. We are investigating a hang associated with the WB_SYNC_NONE changes, so revert them for now. Conflicts: fs/fs-writeback.c mm/page-writeback.c Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2010-05-21writeback: fix problem with !CONFIG_BLOCK compilationJens Axboe
When CONFIG_BLOCK isn't enabled: mm/page-writeback.c: In function 'laptop_mode_timer_fn': mm/page-writeback.c:708: error: dereferencing pointer to incomplete type mm/page-writeback.c:709: error: dereferencing pointer to incomplete type Fix this by essentially eliminating the laptop sync handlers when CONFIG_BLOCK isn't set, as most are only used from the block layer code. The exception is laptop_sync_completion() which is used from sys_sync(), make that an empty declaration in that case. Reported-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2010-05-17writeback: fix WB_SYNC_NONE writeback from umountJens Axboe
When umount calls sync_filesystem(), we first do a WB_SYNC_NONE writeback to kick off writeback of pending dirty inodes, then follow that up with a WB_SYNC_ALL to wait for it. Since umount already holds the sb s_umount mutex, WB_SYNC_NONE ends up doing nothing and all writeback happens as WB_SYNC_ALL. This can greatly slow down umount, since WB_SYNC_ALL writeback is a data integrity operation and thus a bigger hammer than simple WB_SYNC_NONE. For barrier aware file systems it's a lot slower. Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2010-04-06laptop-mode: Make flushes per-deviceMatthew Garrett
One of the features of laptop-mode is that it forces a writeout of dirty pages if something else triggers a physical read or write from a device. The current implementation flushes pages on all devices, rather than only the one that triggered the flush. This patch alters the behaviour so that only the recently accessed block device is flushed, preventing other disks being spun up for no terribly good reason. Signed-off-by: Matthew Garrett <mjg@redhat.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2010-03-12vfs: improve writeback_inodes_wb()Edward Shishkin
Do not pin/unpin superblock for every inode in writeback_inodes_wb(), pin it for the whole group of inodes which belong to the same superblock and call writeback_sb_inodes() handler for them. Signed-off-by: Edward Shishkin <edward.shishkin@gmail.com> Cc: Jens Axboe <jens.axboe@oracle.com> Cc: Wu Fengguang <fengguang.wu@intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2009-12-23fs-writeback: Add helper function to start writeback if idleEric Sandeen
ext4, at least, would like to start pushing on writeback if it starts to get close to ENOSPC when reserving worst-case blocks for delalloc writes. Writing out delalloc data will convert those worst-case predictions into usually smaller actual usage, freeing up space before we hit ENOSPC based on this speculation. Thanks to Jens for the suggestion for the helper function, & the naming help. I've made the helper return status on whether writeback was started even though I don't plan to use it in the ext4 patch; it seems like it would be potentially useful to test this in some cases. Signed-off-by: Eric Sandeen <sandeen@redhat.com> Acked-by: Jan Kara <jack@suse.cz>
2009-12-17kill I_LOCKChristoph Hellwig
After I_SYNC was split from I_LOCK the leftover is always used together with I_NEW and thus superflous. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2009-12-03writeback: introduce wbc.for_backgroundWu Fengguang
It will lower the flush priority for NFS, and maybe more in future. Signed-off-by: Wu Fengguang <fengguang.wu@intel.com> Cc: Trond Myklebust <Trond.Myklebust@netapp.com> Cc: Jens Axboe <jens.axboe@oracle.com> Cc: Christoph Hellwig <hch@infradead.org> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2009-09-24sysctl: remove "struct file *" argument of ->proc_handlerAlexey Dobriyan
It's unused. It isn't needed -- read or write flag is already passed and sysctl shouldn't care about the rest. It _was_ used in two places at arch/frv for some reason. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Cc: David Howells <dhowells@redhat.com> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Cc: Al Viro <viro@zeniv.linux.org.uk> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: "David S. Miller" <davem@davemloft.net> Cc: James Morris <jmorris@namei.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-09-16writeback: separate starting of sync vs opportunistic writebackJens Axboe
bdi_start_writeback() is currently split into two paths, one for WB_SYNC_NONE and one for WB_SYNC_ALL. Add bdi_sync_writeback() for WB_SYNC_ALL writeback and let bdi_start_writeback() handle only WB_SYNC_NONE. Push down the writeback_control allocation and only accept the parameters that make sense for each function. This cleans up the API considerably. Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2009-09-16writeback: get rid of wbc->for_writepagesJens Axboe
It's only set, it's never checked. Kill it. Acked-by: Jan Kara <jack@suse.cz> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2009-09-14vfs: Remove generic_osync_inode() and sync_page_range{_nolock}()Jan Kara
Remove these three functions since nobody uses them anymore. Signed-off-by: Jan Kara <jack@suse.cz>
2009-09-11writeback: get rid of pdflush completelyJens Axboe
It is now unused, so kill it off. Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2009-09-11writeback: switch to per-bdi threads for flushing dataJens Axboe
This gets rid of pdflush for bdi writeout and kupdated style cleaning. pdflush writeout suffers from lack of locality and also requires more threads to handle the same workload, since it has to work in a non-blocking fashion against each queue. This also introduces lumpy behaviour and potential request starvation, since pdflush can be starved for queue access if others are accessing it. A sample ffsb workload that does random writes to files is about 8% faster here on a simple SATA drive during the benchmark phase. File layout also seems a LOT more smooth in vmstat: r b swpd free buff cache si so bi bo in cs us sy id wa 0 1 0 608848 2652 375372 0 0 0 71024 604 24 1 10 48 42 0 1 0 549644 2712 433736 0 0 0 60692 505 27 1 8 48 44 1 0 0 476928 2784 505192 0 0 4 29540 553 24 0 9 53 37 0 1 0 457972 2808 524008 0 0 0 54876 331 16 0 4 38 58 0 1 0 366128 2928 614284 0 0 4 92168 710 58 0 13 53 34 0 1 0 295092 3000 684140 0 0 0 62924 572 23 0 9 53 37 0 1 0 236592 3064 741704 0 0 4 58256 523 17 0 8 48 44 0 1 0 165608 3132 811464 0 0 0 57460 560 21 0 8 54 38 0 1 0 102952 3200 873164 0 0 4 74748 540 29 1 10 48 41 0 1 0 48604 3252 926472 0 0 0 53248 469 29 0 7 47 45 where vanilla tends to fluctuate a lot in the creation phase: r b swpd free buff cache si so bi bo in cs us sy id wa 1 1 0 678716 5792 303380 0 0 0 74064 565 50 1 11 52 36 1 0 0 662488 5864 319396 0 0 4 352 302 329 0 2 47 51 0 1 0 599312 5924 381468 0 0 0 78164 516 55 0 9 51 40 0 1 0 519952 6008 459516 0 0 4 78156 622 56 1 11 52 37 1 1 0 436640 6092 541632 0 0 0 82244 622 54 0 11 48 41 0 1 0 436640 6092 541660 0 0 0 8 152 39 0 0 51 49 0 1 0 332224 6200 644252 0 0 4 102800 728 46 1 13 49 36 1 0 0 274492 6260 701056 0 0 4 12328 459 49 0 7 50 43 0 1 0 211220 6324 763356 0 0 0 106940 515 37 1 10 51 39 1 0 0 160412 6376 813468 0 0 0 8224 415 43 0 6 49 45 1 1 0 85980 6452 886556 0 0 4 113516 575 39 1 11 54 34 0 2 0 85968 6452 886620 0 0 0 1640 158 211 0 0 46 54 A 10 disk test with btrfs performs 26% faster with per-bdi flushing. A SSD based writeback test on XFS performs over 20% better as well, with the throughput being very stable around 1GB/sec, where pdflush only manages 750MB/sec and fluctuates wildly while doing so. Random buffered writes to many files behave a lot better as well, as does random mmap'ed writes. A separate thread is added to sync the super blocks. In the long term, adding sync_supers_bdi() functionality could get rid of this thread again. Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2009-09-11writeback: get rid of generic_sync_sb_inodes() exportJens Axboe
This adds two new exported functions: - writeback_inodes_sb(), which only attempts to writeback dirty inodes on this super_block, for WB_SYNC_NONE writeout. - sync_inodes_sb(), which writes out all dirty inodes on this super_block and also waits for the IO to complete. Acked-by: Jan Kara <jack@suse.cz> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2009-06-11vfs: Make sys_sync() use fsync_super() (version 4)Jan Kara
It is unnecessarily fragile to have two places (fsync_super() and do_sync()) doing data integrity sync of the filesystem. Alter __fsync_super() to accommodate needs of both callers and use it. So after this patch __fsync_super() is the only place where we gather all the calls needed to properly send all data on a filesystem to disk. Nice bonus is that we get a complete livelock avoidance and write_supers() is now only used for periodic writeback of superblocks. sync_blockdevs() introduced a couple of patches ago is gone now. [build fixes folded] Signed-off-by: Jan Kara <jack@suse.cz> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2009-05-15Revert "mm: add /proc controls for pdflush threads"Jens Axboe
This reverts commit fafd688e4c0c34da0f3de909881117d374e4c7af. Work is progressing to switch away from pdflush as the process backing for flushing out dirty data. So it seems pointless to add more knobs to control pdflush threads. The original author of the patch did not have any specific use cases for adding the knobs, so we can easily revert this before 2.6.30 to avoid having to maintain this API forever. Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2009-04-07mm: add /proc controls for pdflush threadsPeter W Morreale
Add /proc entries to give the admin the ability to control the minimum and maximum number of pdflush threads. This allows finer control of pdflush on both large and small machines. The rationale is simply one size does not fit all. Admins on large and/or small systems may want to tune the min/max pdflush thread count to best suit their needs. Right now the min/max is hardcoded to 2/8. While probably a fair estimate for smaller machines, large machines with large numbers of CPUs and large numbers of filesystems/block devices may benefit from larger numbers of threads working on different block devices. Even if the background flushing algorithm is radically changed, it is still likely that multiple threads will be involved and admins would still desire finer control on the min/max other than to have to recompile the kernel. The patch adds '/proc/sys/vm/nr_pdflush_threads_min' and '/proc/sys/vm/nr_pdflush_threads_max' with r/w permissions. The minimum value for nr_pdflush_threads_min is 1 and the maximum value is the current value of nr_pdflush_threads_max. This minimum is required since additional thread creation is performed in a pdflush thread itself. The minimum value for nr_pdflush_threads_max is the current value of nr_pdflush_threads_min and the maximum value can be 1000. Documentation/sysctl/vm.txt is also updated. [akpm@linux-foundation.org: fix comment, fix whitespace, use __read_mostly] Signed-off-by: Peter W Morreale <pmorreale@novell.com> Reviewed-by: Rik van Riel <riel@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-01mm: fix proc_dointvec_userhz_jiffies "breakage"Alexey Dobriyan
Addresses http://bugzilla.kernel.org/show_bug.cgi?id=9838 On i386, HZ=1000, jiffies_to_clock_t() converts time in a somewhat strange way from the user's point of view: # echo 500 >/proc/sys/vm/dirty_writeback_centisecs # cat /proc/sys/vm/dirty_writeback_centisecs 499 So, we have 5000 jiffies converted to only 499 clock ticks and reported back. TICK_NSEC = 999848 ACTHZ = 256039 Keeping in-kernel variable in units passed from userspace will fix issue of course, but this probably won't be right for every sysctl. [akpm@linux-foundation.org: coding-style fixes] Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Nick Piggin <nickpiggin@yahoo.com.au> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-06fs: remove WB_SYNC_HOLDNick Piggin
Remove WB_SYNC_HOLD. The primary motiviation is the design of my anti-starvation code for fsync. It requires taking an inode lock over the sync operation, so we could run into lock ordering problems with multiple inodes. It is possible to take a single global lock to solve the ordering problem, but then that would prevent a future nice implementation of "sync multiple inodes" based on lock order via inode address. Seems like a backward step to remove this, but actually it is busted anyway: we can't use the inode lists for data integrity wait: an inode can be taken off the dirty lists but still be under writeback. In order to satisfy data integrity semantics, we should wait for it to finish writeback, but if we only search the dirty lists, we'll miss it. It would be possible to have a "writeback" list, for sys_sync, I suppose. But why complicate things by prematurely optimise? For unmounting, we could avoid the "livelock avoidance" code, which would be easier, but again premature IMO. Fixing the existing data integrity problem will come next. Signed-off-by: Nick Piggin <npiggin@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-06mm: add dirty_background_bytes and dirty_bytes sysctlsDavid Rientjes
This change introduces two new sysctls to /proc/sys/vm: dirty_background_bytes and dirty_bytes. dirty_background_bytes is the counterpart to dirty_background_ratio and dirty_bytes is the counterpart to dirty_ratio. With growing memory capacities of individual machines, it's no longer sufficient to specify dirty thresholds as a percentage of the amount of dirtyable memory over the entire system. dirty_background_bytes and dirty_bytes specify quantities of memory, in bytes, that represent the dirty limits for the entire system. If either of these values is set, its value represents the amount of dirty memory that is needed to commence either background or direct writeback. When a `bytes' or `ratio' file is written, its counterpart becomes a function of the written value. For example, if dirty_bytes is written to be 8096, 8K of memory is required to commence direct writeback. dirty_ratio is then functionally equivalent to 8K / the amount of dirtyable memory: dirtyable_memory = free pages + mapped pages + file cache dirty_background_bytes = dirty_background_ratio * dirtyable_memory -or- dirty_background_ratio = dirty_background_bytes / dirtyable_memory AND dirty_bytes = dirty_ratio * dirtyable_memory -or- dirty_ratio = dirty_bytes / dirtyable_memory Only one of dirty_background_bytes and dirty_background_ratio may be specified at a time, and only one of dirty_bytes and dirty_ratio may be specified. When one sysctl is written, the other appears as 0 when read. The `bytes' files operate on a page size granularity since dirty limits are compared with ZVC values, which are in page units. Prior to this change, the minimum dirty_ratio was 5 as implemented by get_dirty_limits() although /proc/sys/vm/dirty_ratio would show any user written value between 0 and 100. This restriction is maintained, but dirty_bytes has a lower limit of only one page. Also prior to this change, the dirty_background_ratio could not equal or exceed dirty_ratio. This restriction is maintained in addition to restricting dirty_background_bytes. If either background threshold equals or exceeds that of the dirty threshold, it is implicitly set to half the dirty threshold. Acked-by: Peter Zijlstra <peterz@infradead.org> Cc: Dave Chinner <david@fromorbit.com> Cc: Christoph Lameter <cl@linux-foundation.org> Signed-off-by: David Rientjes <rientjes@google.com> Cc: Andrea Righi <righi.andrea@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-06mm: change dirty limit type specifiers to unsigned longDavid Rientjes
The background dirty and dirty limits are better defined with type specifiers of unsigned long since negative writeback thresholds are not possible. These values, as returned by get_dirty_limits(), are normally compared with ZVC values to determine whether writeback shall commence or be throttled. Such page counts cannot be negative, so declaring the page limits as signed is unnecessary. Acked-by: Peter Zijlstra <peterz@infradead.org> Cc: Dave Chinner <david@fromorbit.com> Cc: Christoph Lameter <cl@linux-foundation.org> Signed-off-by: David Rientjes <rientjes@google.com> Cc: Andrea Righi <righi.andrea@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-16vfs: Add no_nrwrite_index_update writeback control flagAneesh Kumar K.V
If no_nrwrite_index_update is set we don't update nr_to_write and address space writeback_index in write_cache_pages. This change enables a file system to skip these updates in write_cache_pages and do them in the writepages() callback. This patch will be followed by an ext4 patch that make use of these new flags. Signed-off-by: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com> Signed-off-by: "Theodore Ts'o" <tytso@mit.edu> CC: linux-fsdevel@vger.kernel.org
2008-10-14vfs: Remove the range_cont writeback mode.Aneesh Kumar K.V
Ext4 was the only user of range_cont writeback mode and ext4 switched to a different method. So remove the range_cont mode which is not used in the kernel. Signed-off-by: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com> Signed-off-by: "Theodore Ts'o" <tytso@mit.edu> CC: linux-fsdevel@vger.kernel.org
2008-07-15Merge branch 'for_linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tytso/ext4 * 'for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tytso/ext4: (61 commits) ext4: Documention update for new ordered mode and delayed allocation ext4: do not set extents feature from the kernel ext4: Don't allow nonextenst mount option for large filesystem ext4: Enable delalloc by default. ext4: delayed allocation i_blocks fix for stat ext4: fix delalloc i_disksize early update issue ext4: Handle page without buffers in ext4_*_writepage() ext4: Add ordered mode support for delalloc ext4: Invert lock ordering of page_lock and transaction start in delalloc mm: Add range_cont mode for writeback ext4: delayed allocation ENOSPC handling percpu_counter: new function percpu_counter_sum_and_set ext4: Add delayed allocation support in data=writeback mode vfs: add hooks for ext4's delayed allocation support jbd2: Remove data=ordered mode support using jbd buffer heads ext4: Use new framework for data=ordered mode in JBD2 jbd2: Implement data=ordered mode handling via inodes vfs: export filemap_fdatawrite_range() ext4: Fix lock inversion in ext4_ext_truncate() ext4: Invert the locking order of page_lock and transaction start ...
2008-07-11mm: Add range_cont mode for writebackAneesh Kumar K.V
Filesystems like ext4 needs to start a new transaction in the writepages for block allocation. This happens with delayed allocation and there is limit to how many credits we can request from the journal layer. So we call write_cache_pages multiple times with wbc->nr_to_write set to the maximum possible value limitted by the max journal credits available. Add a new mode to writeback that enables us to handle this behaviour. In the new mode we update the wbc->range_start to point to the new offset to be written. Next call to call to write_cache_pages will start writeout from specified range_start offset. In the new mode we also limit writing to the specified wbc->range_end. Signed-off-by: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com> Signed-off-by: Mingming Cao <cmm@us.ibm.com> Acked-by: Jan Kara <jack@suse.cz> Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
2008-05-23ftrace: limit trace entriesSteven Rostedt
Currently there is no protection from the root user to use up all of memory for trace buffers. If the root user allocates too many entries, the OOM killer might start kill off all tasks. This patch adds an algorith to check the following condition: pages_requested > (freeable_memory + current_trace_buffer_pages) / 4 If the above is met then the allocation fails. The above prevents more than 1/4th of freeable memory from being used by trace buffers. To determine the freeable_memory, I made determine_dirtyable_memory in mm/page-writeback.c global. Special thanks goes to Peter Zijlstra for suggesting the above calculation. Signed-off-by: Steven Rostedt <srostedt@redhat.com> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2008-04-30mm: bdi: export BDI attributes in sysfsPeter Zijlstra
Provide a place in sysfs (/sys/class/bdi) for the backing_dev_info object. This allows us to see and set the various BDI specific variables. In particular this properly exposes the read-ahead window for all relevant users and /sys/block/<block>/queue/read_ahead_kb should be deprecated. With patient help from Kay Sievers and Greg KH [mszeredi@suse.cz] - split off NFS and FUSE changes into separate patches - document new sysfs attributes under Documentation/ABI - do bdi_class_init as a core_initcall, otherwise the "default" BDI won't be initialized - remove bdi_init_fmt macro, it's not used very much [akpm@linux-foundation.org: fix ia64 warning] Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Kay Sievers <kay.sievers@vrfy.org> Acked-by: Greg KH <greg@kroah.com> Cc: Trond Myklebust <trond.myklebust@fys.uio.no> Signed-off-by: Miklos Szeredi <mszeredi@suse.cz> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-05writeback: speed up writeback of big dirty filesFengguang Wu
After making dirty a 100M file, the normal behavior is to start the writeback for all data after 30s delays. But sometimes the following happens instead: - after 30s: ~4M - after 5s: ~4M - after 5s: all remaining 92M Some analyze shows that the internal io dispatch queues goes like this: s_io s_more_io ------------------------- 1) 100M,1K 0 2) 1K 96M 3) 0 96M 1) initial state with a 100M file and a 1K file 2) 4M written, nr_to_write <= 0, so write more 3) 1K written, nr_to_write > 0, no more writes(BUG) nr_to_write > 0 in (3) fools the upper layer to think that data have all been written out. The big dirty file is actually still sitting in s_more_io. We cannot simply splice s_more_io back to s_io as soon as s_io becomes empty, and let the loop in generic_sync_sb_inodes() continue: this may starve newly expired inodes in s_dirty. It is also not an option to draw inodes from both s_more_io and s_dirty, an let the loop go on: this might lead to live locks, and might also starve other superblocks in sync time(well kupdate may still starve some superblocks, that's another bug). We have to return when a full scan of s_io completes. So nr_to_write > 0 does not necessarily mean that "all data are written". This patch introduces a flag writeback_control.more_io to indicate that more io should be done. With it the big dirty file no longer has to wait for the next kupdate invokation 5s later. In sync_sb_inodes() we only set more_io on super_blocks we actually visited. This avoids the interaction between two pdflush deamons. Also in __sync_single_inode() we don't blindly keep requeuing the io if the filesystem cannot progress. Failing to do so may lead to 100% iowait. Tested-by: Mike Snitzer <snitzer@gmail.com> Signed-off-by: Fengguang Wu <wfg@mail.ustc.edu.cn> Cc: Michael Rubin <mrubin@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-05mm/page-writeback: highmem_is_dirtyable optionBron Gondwana
Add vm.highmem_is_dirtyable toggle A 32 bit machine with HIGHMEM64 enabled running DCC has an MMAPed file of approximately 2Gb size which contains a hash format that is written randomly by the dbclean process. On 2.6.16 this process took a few minutes. With lowmem only accounting of dirty ratios, this takes about 12 hours of 100% disk IO, all random writes. Include a toggle in /proc/sys/vm/highmem_is_dirtyable which can be set to 1 to add the highmem back to the total available memory count. [akpm@linux-foundation.org: Fix the CONFIG_DETECT_SOFTLOCKUP=y build] Signed-off-by: Bron Gondwana <brong@fastmail.fm> Cc: Ethan Solomita <solo@google.com> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: WU Fengguang <wfg@mail.ustc.edu.cn> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-01-14Revert "writeback: introduce writeback_control.more_io to indicate more io"Linus Torvalds
This reverts commit 2e6883bdf49abd0e7f0d9b6297fc3be7ebb2250b, as requested by Fengguang Wu. It's not quite fully baked yet, and while there are patches around to fix the problems it caused, they should get more testing. Says Fengguang: "I'll resend them both for -mm later on, in a more complete patchset". See http://bugzilla.kernel.org/show_bug.cgi?id=9738 for some of this discussion. Requested-by: Fengguang Wu <wfg@mail.ustc.edu.cn> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Peter Zijlstra <peterz@infradead.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-17introduce I_SYNCJoern Engel
I_LOCK was used for several unrelated purposes, which caused deadlock situations in certain filesystems as a side effect. One of the purposes now uses the new I_SYNC bit. Also document the various bits and change their order from historical to logical. [bunk@stusta.de: make fs/inode.c:wake_up_inode() static] Signed-off-by: Joern Engel <joern@wohnheim.fh-wedel.de> Cc: Dave Kleikamp <shaggy@linux.vnet.ibm.com> Cc: David Chinner <dgc@sgi.com> Cc: Anton Altaparmakov <aia21@cam.ac.uk> Cc: Al Viro <viro@ftp.linux.org.uk> Cc: Christoph Hellwig <hch@infradead.org> Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-17writeback: introduce writeback_control.more_io to indicate more ioFengguang Wu
After making dirty a 100M file, the normal behavior is to start the writeback for all data after 30s delays. But sometimes the following happens instead: - after 30s: ~4M - after 5s: ~4M - after 5s: all remaining 92M Some analyze shows that the internal io dispatch queues goes like this: s_io s_more_io ------------------------- 1) 100M,1K 0 2) 1K 96M 3) 0 96M 1) initial state with a 100M file and a 1K file 2) 4M written, nr_to_write <= 0, so write more 3) 1K written, nr_to_write > 0, no more writes(BUG) nr_to_write > 0 in (3) fools the upper layer to think that data have all been written out. The big dirty file is actually still sitting in s_more_io. We cannot simply splice s_more_io back to s_io as soon as s_io becomes empty, and let the loop in generic_sync_sb_inodes() continue: this may starve newly expired inodes in s_dirty. It is also not an option to draw inodes from both s_more_io and s_dirty, an let the loop go on: this might lead to live locks, and might also starve other superblocks in sync time(well kupdate may still starve some superblocks, that's another bug). We have to return when a full scan of s_io completes. So nr_to_write > 0 does not necessarily mean that "all data are written". This patch introduces a flag writeback_control.more_io to indicate this situation. With it the big dirty file no longer has to wait for the next kupdate invocation 5s later. Cc: David Chinner <dgc@sgi.com> Cc: Ken Chen <kenchen@google.com> Signed-off-by: Fengguang Wu <wfg@mail.ustc.edu.cn> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-17mm: per device dirty thresholdPeter Zijlstra
Scale writeback cache per backing device, proportional to its writeout speed. By decoupling the BDI dirty thresholds a number of problems we currently have will go away, namely: - mutual interference starvation (for any number of BDIs); - deadlocks with stacked BDIs (loop, FUSE and local NFS mounts). It might be that all dirty pages are for a single BDI while other BDIs are idling. By giving each BDI a 'fair' share of the dirty limit, each one can have dirty pages outstanding and make progress. A global threshold also creates a deadlock for stacked BDIs; when A writes to B, and A generates enough dirty pages to get throttled, B will never start writeback until the dirty pages go away. Again, by giving each BDI its own 'independent' dirty limit, this problem is avoided. So the problem is to determine how to distribute the total dirty limit across the BDIs fairly and efficiently. A DBI that has a large dirty limit but does not have any dirty pages outstanding is a waste. What is done is to keep a floating proportion between the DBIs based on writeback completions. This way faster/more active devices get a larger share than slower/idle devices. [akpm@linux-foundation.org: fix warnings] [hugh@veritas.com: Fix occasional hang when a task couldn't get out of balance_dirty_pages] Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Signed-off-by: Hugh Dickins <hugh@veritas.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-15Merge git://git.linux-nfs.org/pub/linux/nfs-2.6Linus Torvalds
* git://git.linux-nfs.org/pub/linux/nfs-2.6: (131 commits) NFSv4: Fix a typo in nfs_inode_reclaim_delegation NFS: Add a boot parameter to disable 64 bit inode numbers NFS: nfs_refresh_inode should clear cache_validity flags on success NFS: Fix a connectathon regression in NFSv3 and NFSv4 NFS: Use nfs_refresh_inode() in ops that aren't expected to change the inode SUNRPC: Don't call xprt_release in call refresh SUNRPC: Don't call xprt_release() if call_allocate fails SUNRPC: Fix buggy UDP transmission [23/37] Clean up duplicate includes in [2.6 patch] net/sunrpc/rpcb_clnt.c: make struct rpcb_program static SUNRPC: Use correct type in buffer length calculations SUNRPC: Fix default hostname created in rpc_create() nfs: add server port to rpc_pipe info file NFS: Get rid of some obsolete macros NFS: Simplify filehandle revalidation NFS: Ensure that nfs_link() returns a hashed dentry NFS: Be strict about dentry revalidation when doing exclusive create NFS: Don't zap the readdir caches upon error NFS: Remove the redundant nfs_reval_fsid() NFSv3: Always use directory post-op attributes in nfs3_proc_lookup ... Fix up trivial conflict due to sock_owned_by_user() cleanup manually in net/sunrpc/xprtsock.c
2007-10-10Fix warnings with !CONFIG_BLOCKJens Axboe
Hide everything in blkdev.h with CONFIG_BLOCK isn't set, and fixup the (few) files that fail to build because they were relying on blkdev.h pulling in extra includes for them. Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2007-10-09VFS: Remove writeback_control->fs_privateTrond Myklebust
The only user of this field was NFS. Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2007-10-08mm: set_page_dirty_balance() vs ->page_mkwrite()Peter Zijlstra
All the current page_mkwrite() implementations also set the page dirty. Which results in the set_page_dirty_balance() call to _not_ call balance, because the page is already found dirty. This allows us to dirty a _lot_ of pages without ever hitting balance_dirty_pages(). Not good (tm). Force a balance call if ->page_mkwrite() was successful. Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-21Detach sched.h from mm.hAlexey Dobriyan
First thing mm.h does is including sched.h solely for can_do_mlock() inline function which has "current" dereference inside. By dealing with can_do_mlock() mm.h can be detached from sched.h which is good. See below, why. This patch a) removes unconditional inclusion of sched.h from mm.h b) makes can_do_mlock() normal function in mm/mlock.c c) exports can_do_mlock() to not break compilation d) adds sched.h inclusions back to files that were getting it indirectly. e) adds less bloated headers to some files (asm/signal.h, jiffies.h) that were getting them indirectly Net result is: a) mm.h users would get less code to open, read, preprocess, parse, ... if they don't need sched.h b) sched.h stops being dependency for significant number of files: on x86_64 allmodconfig touching sched.h results in recompile of 4083 files, after patch it's only 3744 (-8.3%). Cross-compile tested on all arm defconfigs, all mips defconfigs, all powerpc defconfigs, alpha alpha-up arm i386 i386-up i386-defconfig i386-allnoconfig ia64 ia64-up m68k mips parisc parisc-up powerpc powerpc-up s390 s390-up sparc sparc-up sparc64 sparc64-up um-x86_64 x86_64 x86_64-up x86_64-defconfig x86_64-allnoconfig as well as my two usual configs. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-11consolidate generic_writepages and mpage_writepagesMiklos Szeredi
Clean up massive code duplication between mpage_writepages() and generic_writepages(). The new generic function, write_cache_pages() takes a function pointer argument, which will be called for each page to be written. Maybe cifs_writepages() too can use this infrastructure, but I'm not touching that with a ten-foot pole. The upcoming page writeback support in fuse will also want this. Signed-off-by: Miklos Szeredi <mszeredi@suse.cz> Acked-by: Christoph Hellwig <hch@infradead.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-04-30NFS: Fix a race when doing NFS write coalescingTrond Myklebust
Currently we do write coalescing in a very inefficient manner: one pass in generic_writepages() in order to lock the pages for writing, then one pass in nfs_flush_mapping() and/or nfs_sync_mapping_wait() in order to gather the locked pages for coalescing into RPC requests of size "wsize". In fact, it turns out there is actually a deadlock possible here since we only start I/O on the second pass. If the user signals the process while we're in nfs_sync_mapping_wait(), for instance, then we may exit before starting I/O on all the requests that have been queued up. Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2007-03-01[PATCH] throttle_vm_writeout(): don't loop on GFP_NOFS and GFP_NOIO allocationsAndrew Morton
throttle_vm_writeout() is designed to wait for the dirty levels to subside. But if the caller holds IO or FS locks, we might be holding up that writeout. So change it to take a single nap to give other devices a chance to clean some memory, then return. Cc: Nick Piggin <nickpiggin@yahoo.com.au> Cc: OGAWA Hirofumi <hirofumi@mail.parknet.co.jp> Cc: Kumar Gala <galak@kernel.crashing.org> Cc: Pete Zaitcev <zaitcev@redhat.com> Cc: <stable@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2006-10-20[PATCH] separate bdi congestion functions from queue congestion functionsAndrew Morton
Separate out the concept of "queue congestion" from "backing-dev congestion". Congestion is a backing-dev concept, not a queue concept. The blk_* congestion functions are retained, as wrappers around the core backing-dev congestion functions. This proper layering is needed so that NFS can cleanly use the congestion functions, and so that CONFIG_BLOCK=n actually links. Cc: "Thomas Maier" <balagi@justmail.de> Cc: "Jens Axboe" <jens.axboe@oracle.com> Cc: Trond Myklebust <trond.myklebust@fys.uio.no> Cc: David Howells <dhowells@redhat.com> Cc: Peter Osterlund <petero2@telia.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-03fix file specification in commentsUwe Zeisberger
Many files include the filename at the beginning, serveral used a wrong one. Signed-off-by: Uwe Zeisberger <Uwe_Zeisberger@digi.com> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2006-09-30[PATCH] BLOCK: Dissociate generic_writepages() from mpage stuff [try #6]David Howells
Dissociate the generic_writepages() function from the mpage stuff, moving its declaration to linux/mm.h and actually emitting a full implementation into mm/page-writeback.c. The implementation is a partial duplicate of mpage_writepages() with all BIO references removed. It is used by NFS to do writeback. Signed-Off-By: David Howells <dhowells@redhat.com> Signed-off-by: Jens Axboe <axboe@kernel.dk>
2006-09-29[PATCH] call mm/page-writeback.c:set_ratelimit() when new pages are hot-addedChandra Seetharaman
ratelimit_pages in page-writeback.c is recalculated (in set_ratelimit()) every time a CPU is hot-added/removed. But this value is not recalculated when new pages are hot-added. This patch fixes that problem by calling set_ratelimit() when new pages are hot-added. [akpm@osdl.org: cleanups] Signed-off-by: Chandra Seetharaman <sekharan@us.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-09-26[PATCH] mm: balance dirty pagesPeter Zijlstra
Now that we can detect writers of shared mappings, throttle them. Avoids OOM by surprise. Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Hugh Dickins <hugh@veritas.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-09-22Add a real API for dealing with blk_congestion_wait()Trond Myklebust
2006-06-23[PATCH] writeback: fix range handlingOGAWA Hirofumi
When a writeback_control's `start' and `end' fields are used to indicate a one-byte-range starting at file offset zero, the required values of .start=0,.end=0 mean that the ->writepages() implementation has no way of telling that it is being asked to perform a range request. Because we're currently overloading (start == 0 && end == 0) to mean "this is not a write-a-range request". To make all this sane, the patch changes range of writeback_control. So caller does: If it is calling ->writepages() to write pages, it sets range (range_start/end or range_cyclic) always. And if range_cyclic is true, ->writepages() thinks the range is cyclic, otherwise it just uses range_start and range_end. This patch does, - Add LLONG_MAX, LLONG_MIN, ULLONG_MAX to include/linux/kernel.h -1 is usually ok for range_end (type is long long). But, if someone did, range_end += val; range_end is "val - 1" u64val = range_end >> bits; u64val is "~(0ULL)" or something, they are wrong. So, this adds LLONG_MAX to avoid nasty things, and uses LLONG_MAX for range_end. - All callers of ->writepages() sets range_start/end or range_cyclic. - Fix updates of ->writeback_index. It seems already bit strange. If it starts at 0 and ended by check of nr_to_write, this last index may reduce chance to scan end of file. So, this updates ->writeback_index only if range_cyclic is true or whole-file is scanned. Signed-off-by: OGAWA Hirofumi <hirofumi@mail.parknet.co.jp> Cc: Nathan Scott <nathans@sgi.com> Cc: Anton Altaparmakov <aia21@cantab.net> Cc: Steven French <sfrench@us.ibm.com> Cc: "Vladimir V. Saveliev" <vs@namesys.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
