path: root/include/linux/workqueue.h
2014-04-01Merge branch 'timers-core-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull timer changes from Thomas Gleixner: "This assorted collection provides: - A new timer based timer broadcast feature for systems which do not provide a global accessible timer device. That allows those systems to put CPUs into deep idle states where the per cpu timer device stops. - A few NOHZ_FULL related improvements to the timer wheel - The usual updates to timer devices found in ARM SoCs - Small improvements and updates all over the place" * 'timers-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (44 commits) tick: Remove code duplication in tick_handle_periodic() tick: Fix spelling mistake in tick_handle_periodic() x86: hpet: Use proper destructor for delayed work workqueue: Provide destroy_delayed_work_on_stack() clocksource: CMT, MTU2, TMU and STI should depend on GENERIC_CLOCKEVENTS timer: Remove code redundancy while calling get_nohz_timer_target() hrtimer: Rearrange comments in the order struct members are declared timer: Use variable head instead of &work_list in __run_timers() clocksource: exynos_mct: silence a static checker warning arm: zynq: Add support for cpufreq arm: zynq: Don't use arm_global_timer with cpufreq clocksource/cadence_ttc: Overhaul clocksource frequency adjustment clocksource/cadence_ttc: Call clockevents_update_freq() with IRQs enabled clocksource: Add Kconfig entries for CMT, MTU2, TMU and STI sh: Remove Kconfig entries for TMU, CMT and MTU2 ARM: shmobile: Remove CMT, TMU and STI Kconfig entries clocksource: armada-370-xp: Use atomic access for shared registers clocksource: orion: Use atomic access for shared registers clocksource: timer-keystone: Delete unnecessary variable clocksource: timer-keystone: introduce clocksource driver for Keystone ...
2014-03-29workqueue: remove deprecated WQ_NON_REENTRANTZhangZhen
Tejun Heo has made WQ_NON_REENTRANT useless in the dbf2576e37 ("workqueue: make all workqueues non-reentrant"). So remove its usages and definition. This patch doesn't introduce any behavior changes. tj: minor description updates. Signed-off-by: ZhangZhen <zhenzhang.zhang@huawei.com> Sigend-off-by: Tejun Heo <tj@kernel.org> Acked-by: James Chapman <jchapman@katalix.com> Acked-by: Ulf Hansson <ulf.hansson@linaro.org>
2014-03-25workqueue: Provide destroy_delayed_work_on_stack()Thomas Gleixner
If a delayed or deferrable work is on stack we need to tell debug objects that we are destroying the timer and the work. Otherwise we leak the tracking object. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: Vince Weaver <vincent.weaver@maine.edu> Acked-by: Tejun Heo <tj@kernel.org> Link: http://lkml.kernel.org/r/20140323141939.911487677@linutronix.de Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2014-03-24workqueue: Spelling s/instensive/intensive/Geert Uytterhoeven
Signed-off-by: Geert Uytterhoeven <geert+renesas@glider.be> Signed-off-by: Tejun Heo <tj@kernel.org>
2014-03-07workqueue: remove PREPARE_[DELAYED_]WORK()Tejun Heo
Peter Hurley noticed that since a2c1c57be8d9 ("workqueue: consider work function when searching for busy work items"), a work item which gets assigned a different work function would break out of the non-reentrancy guarantee as workqueue would consider it a different work item. This is fragile and extremely subtle. PREPARE_[DELAYED_]WORK() have never been used widely and its semantics has always been somewhat iffy. If the work item is known not to be on queue when PREPARE_WORK() is called, there's no difference from using INIT_WORK(). If the work item may be queued at the time of PREPARE_WORK(), we can't really tell whether the old or new function will be executed the next time. We really don't want this level of subtlety in workqueue interface for such marginal use cases. The previous patches converted all existing users away from PREPARE_[DELAYED_]WORK(). Let's remove them. Signed-off-by: Tejun Heo <tj@kernel.org> Cc: Peter Hurley <peter@hurleysoftware.com> Link: http://lkml.kernel.org/g/1392493119-9277-1-git-send-email-peter@hurleysoftware.com
2014-03-07Merge branch 'wq/for-3.14-fixes' into wq/for-3.15Tejun Heo
To receive 70044d71d31d ("firewire: don't use PREPARE_DELAYED_WORK"). There will be further related updates in for-3.15 branch. Signed-off-by: Tejun Heo <tj@kernel.org>
2014-02-18workqueue: Remove deprecated __cancel_delayed_work()Tan Xiaojun
__cancel_delayed_work() was deprecated by 136b5721d75a ("workqueue: deprecate __cancel_delayed_work()") as cancel_delayed_work() was updated so that it could be used from all contexts. Enough time has passed since the deprecation. Let's remove it. tj: description update Signed-off-by: Tan Xiaojun <tanxiaojun@huawei.com> Signed-off-by: Tejun Heo <tj@kernel.org>
2014-02-14workqueue: add args to workqueue lockdep nameLi Zhong
Tommi noticed a 'funny' lock class name: "%s#5" from a lock acquired in process_one_work(). Maybe #fmt plus #args could be used as the lock_name to give some more information for some fmt string like the above. __builtin_constant_p() check is removed (as there seems no good way to check all the variables in args list). However, by removing the check, it only adds two additional "s for those constants. Some lockdep name examples printed out after the change: lockdep name wq->name "events_long" events_long "%s"("khelper") khelper "xfs-data/%s"mp->m_fsname xfs-data/dm-3 Signed-off-by: Li Zhong <zhong@linux.vnet.ibm.com> Signed-off-by: Tejun Heo <tj@kernel.org>
2013-07-30workqueue: mark WQ_NON_REENTRANT deprecatedTejun Heo
dbf2576e37 ("workqueue: make all workqueues non-reentrant") made WQ_NON_REENTRANT no-op but the following patches didn't remove the flag or update the documentation. Let's mark the flag deprecated and update the documentation accordingly. Signed-off-by: Tejun Heo <tj@kernel.org>
2013-07-03drivers: avoid format strings in names passed to alloc_workqueue()Kees Cook
For the workqueue creation interfaces that do not expect format strings, make sure they cannot accidently be parsed that way. Additionally, clean up calls made with a single parameter that would be handled as a format string. Many callers are passing potentially dynamic string content, so use "%s" in those cases to avoid any potential accidents. Signed-off-by: Kees Cook <keescook@chromium.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-05-14workqueue: Add system wide power_efficient workqueuesViresh Kumar
This patch adds system wide workqueues aligned towards power saving. This is done by allocating them with WQ_UNBOUND flag if 'wq_power_efficient' is set to 'true'. tj: updated comments a bit. Signed-off-by: Viresh Kumar <viresh.kumar@linaro.org> Signed-off-by: Tejun Heo <tj@kernel.org>
2013-05-14workqueues: Introduce new flag WQ_POWER_EFFICIENT for power oriented workqueuesViresh Kumar
Workqueues can be performance or power-oriented. Currently, most workqueues are bound to the CPU they were created on. This gives good performance (due to cache effects) at the cost of potentially waking up otherwise idle cores (Idle from scheduler's perspective. Which may or may not be physically idle) just to process some work. To save power, we can allow the work to be rescheduled on a core that is already awake. Workqueues created with the WQ_UNBOUND flag will allow some power savings. However, we don't change the default behaviour of the system. To enable power-saving behaviour, a new config option CONFIG_WQ_POWER_EFFICIENT needs to be turned on. This option can also be overridden by the workqueue.power_efficient boot parameter. tj: Updated config description and comments. Renamed CONFIG_WQ_POWER_EFFICIENT to CONFIG_WQ_POWER_EFFICIENT_DEFAULT. Signed-off-by: Viresh Kumar <viresh.kumar@linaro.org> Reviewed-by: Amit Kucheria <amit.kucheria@linaro.org> Signed-off-by: Tejun Heo <tj@kernel.org>
2013-04-30workqueue: include workqueue info when printing debug dump of a worker taskTejun Heo
One of the problems that arise when converting dedicated custom threadpool to workqueue is that the shared worker pool used by workqueue anonimizes each worker making it more difficult to identify what the worker was doing on which target from the output of sysrq-t or debug dump from oops, BUG() and friends. This patch implements set_worker_desc() which can be called from any workqueue work function to set its description. When the worker task is dumped for whatever reason - sysrq-t, WARN, BUG, oops, lockdep assertion and so on - the description will be printed out together with the workqueue name and the worker function pointer. The printing side is implemented by print_worker_info() which is called from functions in task dump paths - sched_show_task() and dump_stack_print_info(). print_worker_info() can be safely called on any task in any state as long as the task struct itself is accessible. It uses probe_*() functions to access worker fields. It may print garbage if something went very wrong, but it wouldn't cause (another) oops. The description is currently limited to 24bytes including the terminating \0. worker->desc_valid and workder->desc[] are added and the 64 bytes marker which was already incorrect before adding the new fields is moved to the correct position. Here's an example dump with writeback updated to set the bdi name as worker desc. Hardware name: Bochs Modules linked in: Pid: 7, comm: kworker/u9:0 Not tainted 3.9.0-rc1-work+ #1 Workqueue: writeback bdi_writeback_workfn (flush-8:0) ffffffff820a3ab0 ffff88000f6e9cb8 ffffffff81c61845 ffff88000f6e9cf8 ffffffff8108f50f 0000000000000000 0000000000000000 ffff88000cde16b0 ffff88000cde1aa8 ffff88001ee19240 ffff88000f6e9fd8 ffff88000f6e9d08 Call Trace: [<ffffffff81c61845>] dump_stack+0x19/0x1b [<ffffffff8108f50f>] warn_slowpath_common+0x7f/0xc0 [<ffffffff8108f56a>] warn_slowpath_null+0x1a/0x20 [<ffffffff81200150>] bdi_writeback_workfn+0x2a0/0x3b0 ... Signed-off-by: Tejun Heo <tj@kernel.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Ingo Molnar <mingo@redhat.com> Acked-by: Jan Kara <jack@suse.cz> Cc: Oleg Nesterov <oleg@redhat.com> Cc: Jens Axboe <axboe@kernel.dk> Cc: Dave Chinner <david@fromorbit.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-04-01workqueue: update sysfs interface to reflect NUMA awareness and a kernel ↵Tejun Heo
param to disable NUMA affinity Unbound workqueues are now NUMA aware. Let's add some control knobs and update sysfs interface accordingly. * Add kernel param workqueue.numa_disable which disables NUMA affinity globally. * Replace sysfs file "pool_id" with "pool_ids" which contain node:pool_id pairs. This change is userland-visible but "pool_id" hasn't seen a release yet, so this is okay. * Add a new sysf files "numa" which can toggle NUMA affinity on individual workqueues. This is implemented as attrs->no_numa whichn is special in that it isn't part of a pool's attributes. It only affects how apply_workqueue_attrs() picks which pools to use. After "pool_ids" change, first_pwq() doesn't have any user left. Removed. Signed-off-by: Tejun Heo <tj@kernel.org> Reviewed-by: Lai Jiangshan <laijs@cn.fujitsu.com>
2013-03-13workqueue: inline trivial wrappersTejun Heo
There's no reason to make these trivial wrappers full (exported) functions. Inline the followings. queue_work() queue_delayed_work() mod_delayed_work() schedule_work_on() schedule_work() schedule_delayed_work_on() schedule_delayed_work() keventd_up() Signed-off-by: Tejun Heo <tj@kernel.org>
2013-03-12workqueue: implement current_is_workqueue_rescuer()Tejun Heo
Implement a function which queries whether it currently is running off a workqueue rescuer. This will be used to convert writeback to workqueue. Signed-off-by: Tejun Heo <tj@kernel.org>
2013-03-12workqueue: implement sysfs interface for workqueuesTejun Heo
There are cases where workqueue users want to expose control knobs to userland. e.g. Unbound workqueues with custom attributes are scheduled to be used for writeback workers and depending on configuration it can be useful to allow admins to tinker with the priority or allowed CPUs. This patch implements workqueue_sysfs_register(), which makes the workqueue visible under /sys/bus/workqueue/devices/WQ_NAME. There currently are two attributes common to both per-cpu and unbound pools and extra attributes for unbound pools including nice level and cpumask. If alloc_workqueue*() is called with WQ_SYSFS, workqueue_sysfs_register() is called automatically as part of workqueue creation. This is the preferred method unless the workqueue user wants to apply workqueue_attrs before making the workqueue visible to userland. v2: Disallow exposing ordered workqueues as ordered workqueues can't be tuned in any way. Signed-off-by: Tejun Heo <tj@kernel.org>
2013-03-12workqueue: reject adjusting max_active or applying attrs to ordered workqueuesTejun Heo
Adjusting max_active of or applying new workqueue_attrs to an ordered workqueue breaks its ordering guarantee. The former is obvious. The latter is because applying attrs creates a new pwq (pool_workqueue) and there is no ordering constraint between the old and new pwqs. Make apply_workqueue_attrs() and workqueue_set_max_active() trigger WARN_ON() if those operations are requested on an ordered workqueue and fail / ignore respectively. Signed-off-by: Tejun Heo <tj@kernel.org> Reviewed-by: Lai Jiangshan <laijs@cn.fujitsu.com>
2013-03-12workqueue: make it clear that WQ_DRAINING is an internal flagTejun Heo
We're gonna add another internal WQ flag. Let's make the distinction clear. Prefix WQ_DRAINING with __ and move it to bit 16. Signed-off-by: Tejun Heo <tj@kernel.org> Reviewed-by: Lai Jiangshan <laijs@cn.fujitsu.com>
2013-03-12workqueue: implement apply_workqueue_attrs()Tejun Heo
Implement apply_workqueue_attrs() which applies workqueue_attrs to the specified unbound workqueue by creating a new pwq (pool_workqueue) linked to worker_pool with the specified attributes. A new pwq is linked at the head of wq->pwqs instead of tail and __queue_work() verifies that the first unbound pwq has positive refcnt before choosing it for the actual queueing. This is to cover the case where creation of a new pwq races with queueing. As base ref on a pwq won't be dropped without making another pwq the first one, __queue_work() is guaranteed to make progress and not add work item to a dead pwq. init_and_link_pwq() is updated to return the last first pwq the new pwq replaced, which is put by apply_workqueue_attrs(). Note that apply_workqueue_attrs() is almost identical to unbound pwq part of alloc_and_link_pwqs(). The only difference is that there is no previous first pwq. apply_workqueue_attrs() is implemented to handle such cases and replaces unbound pwq handling in alloc_and_link_pwqs(). Signed-off-by: Tejun Heo <tj@kernel.org> Reviewed-by: Lai Jiangshan <laijs@cn.fujitsu.com>
2013-03-12workqueue: drop WQ_RESCUER and test workqueue->rescuer for NULL insteadTejun Heo
WQ_RESCUER is superflous. WQ_MEM_RECLAIM indicates that the user wants a rescuer and testing wq->rescuer for NULL can answer whether a given workqueue has a rescuer or not. Drop WQ_RESCUER and test wq->rescuer directly. This will help simplifying __alloc_workqueue_key() failure path by allowing it to use destroy_workqueue() on a partially constructed workqueue, which in turn will help implementing dynamic management of pool_workqueues. While at it, clear wq->rescuer after freeing it in destroy_workqueue(). This is a precaution as scheduled changes will make destruction more complex. This patch doesn't introduce any functional changes. Signed-off-by: Tejun Heo <tj@kernel.org> Reviewed-by: Lai Jiangshan <laijs@cn.fujitsu.com>
2013-03-12workqueue: introduce workqueue_attrsTejun Heo
Introduce struct workqueue_attrs which carries worker attributes - currently the nice level and allowed cpumask along with helper routines alloc_workqueue_attrs() and free_workqueue_attrs(). Each worker_pool now carries ->attrs describing the attributes of its workers. All functions dealing with cpumask and nice level of workers are updated to follow worker_pool->attrs instead of determining them from other characteristics of the worker_pool, and init_workqueues() is updated to set worker_pool->attrs appropriately for all standard pools. Note that create_worker() is updated to always perform set_user_nice() and use set_cpus_allowed_ptr() combined with manual assertion of PF_THREAD_BOUND instead of kthread_bind(). This simplifies handling random attributes without affecting the outcome. This patch doesn't introduce any behavior changes. v2: Missing cpumask_var_t definition caused build failure on some archs. linux/cpumask.h included. Signed-off-by: Tejun Heo <tj@kernel.org> Reported-by: kbuild test robot <fengguang.wu@intel.com> Reviewed-by: Lai Jiangshan <laijs@cn.fujitsu.com>
2013-03-12workqueue: consistently use int for @cpu variablesTejun Heo
Workqueue is mixing unsigned int and int for @cpu variables. There's no point in using unsigned int for cpus - many of cpu related APIs take int anyway. Consistently use int for @cpu variables so that we can use negative values to mark special ones. This patch doesn't introduce any visible behavior changes. Signed-off-by: Tejun Heo <tj@kernel.org> Reviewed-by: Lai Jiangshan <laijs@cn.fujitsu.com>
2013-03-04workqueue: allow more off-queue flag spaceLai Jiangshan
When a work item is off-queue, its work->data contains WORK_STRUCT_* and WORK_OFFQ_* flags. As WORK_OFFQ_* flags are used only while a work item is off-queue, it can occupy bits of work->data which aren't used while off-queue. WORK_OFFQ_* currently only use bits used by on-queue CWQ pointer. As color bits aren't used while off-queue, there's no reason to not use them. Lower WORK_OFFQ_FLAG_BASE from WORK_STRUCT_FLAG_BITS to WORK_STRUCT_COLOR_SHIFT thus giving 4 more bits to off-queue flag space which is also used to record worker_pool ID while off-queue. This doesn't introduce any visible behavior difference. tj: Rewrote the description. Signed-off-by: Lai Jiangshan <laijs@cn.fujitsu.com> Signed-off-by: Tejun Heo <tj@kernel.org>
2013-02-13workqueue: rename cpu_workqueue to pool_workqueueTejun Heo
workqueue has moved away from global_cwqs to worker_pools and with the scheduled custom worker pools, wforkqueues will be associated with pools which don't have anything to do with CPUs. The workqueue code went through significant amount of changes recently and mass renaming isn't likely to hurt much additionally. Let's replace 'cpu' with 'pool' so that it reflects the current design. * s/struct cpu_workqueue_struct/struct pool_workqueue/ * s/cpu_wq/pool_wq/ * s/cwq/pwq/ This patch is purely cosmetic. Signed-off-by: Tejun Heo <tj@kernel.org>
2013-02-06workqueue: add delayed_work->wq to simplify reentrancy handlingLai Jiangshan
To avoid executing the same work item from multiple CPUs concurrently, a work_struct records the last pool it was on in its ->data so that, on the next queueing, the pool can be queried to determine whether the work item is still executing or not. A delayed_work goes through timer before actually being queued on the target workqueue and the timer needs to know the target workqueue and CPU. This is currently achieved by modifying delayed_work->work.data such that it points to the cwq which points to the target workqueue and the last CPU the work item was on. __queue_delayed_work() extracts the last CPU from delayed_work->work.data and then combines it with the target workqueue to create new work.data. The only thing this rather ugly hack achieves is encoding the target workqueue into delayed_work->work.data without using a separate field, which could be a trade off one can make; unfortunately, this entangles work->data management between regular workqueue and delayed_work code by setting cwq pointer before the work item is actually queued and becomes a hindrance for further improvements of work->data handling. This can be easily made sane by adding a target workqueue field to delayed_work. While delayed_work is used widely in the kernel and this does make it a bit larger (<5%), I think this is the right trade-off especially given the prospect of much saner handling of work->data which currently involves quite tricky memory barrier dancing, and don't expect to see any measureable effect. Add delayed_work->wq and drop the delayed_work->work.data overloading. tj: Rewrote the description. Signed-off-by: Lai Jiangshan <laijs@cn.fujitsu.com> Signed-off-by: Tejun Heo <tj@kernel.org>
2013-02-06workqueue: replace WORK_CPU_NONE/LAST with WORK_CPU_ENDLai Jiangshan
Now that workqueue has moved away from gcwqs, workqueue no longer has the need to have a CPU identifier indicating "no cpu associated" - we now use WORK_OFFQ_POOL_NONE instead - and most uses of WORK_CPU_NONE are gone. The only left usage is as the end marker for for_each_*wq*() iterators, where the name WORK_CPU_NONE is confusing w/o actual WORK_CPU_NONE usages. Similarly, WORK_CPU_LAST which equals WORK_CPU_NONE no longer makes sense. Replace both WORK_CPU_NONE and LAST with WORK_CPU_END. This patch doesn't introduce any functional difference. tj: s/WORK_CPU_LAST/WORK_CPU_END/ and rewrote the description. Signed-off-by: Lai Jiangshan <laijs@cn.fujitsu.com> Signed-off-by: Tejun Heo <tj@kernel.org>
2013-01-24workqueue: record pool ID instead of CPU in work->data when off-queueTejun Heo
Currently, when a work item is off-queue, work->data records the CPU it was last on, which is used to locate the last executing instance for non-reentrance, flushing, etc. We're in the process of removing global_cwq and making worker_pool the top level abstraction. This patch makes work->data point to the pool it was last associated with instead of CPU. After the previous WORK_OFFQ_POOL_CPU and worker_poo->id additions, the conversion is fairly straight-forward. WORK_OFFQ constants and functions are modified to record and read back pool ID instead. worker_pool_by_id() is added to allow looking up pool from ID. get_work_pool() replaces get_work_gcwq(), which is reimplemented using get_work_pool(). get_work_pool_id() replaces work_cpu(). This patch shouldn't introduce any observable behavior changes. Signed-off-by: Tejun Heo <tj@kernel.org> Reviewed-by: Lai Jiangshan <laijs@cn.fujitsu.com>
2013-01-24workqueue: introduce WORK_OFFQ_CPU_NONETejun Heo
Currently, when a work item is off queue, high bits of its data encodes the last CPU it was on. This is scheduled to be changed to pool ID, which will make it impossible to use WORK_CPU_NONE to indicate no association. This patch limits the number of bits which are used for off-queue cpu number to 31 (so that the max fits in an int) and uses the highest possible value - WORK_OFFQ_CPU_NONE - to indicate no association. Signed-off-by: Tejun Heo <tj@kernel.org> Reviewed-by: Lai Jiangshan <laijs@cn.fujitsu.com>
2013-01-24workqueue: unexport work_cpu()Tejun Heo
This function no longer has any external users. Unexport it. It will be removed later on. Signed-off-by: Tejun Heo <tj@kernel.org> Reviewed-by: Lai Jiangshan <laijs@cn.fujitsu.com>
2012-08-21workqueue: deprecate __cancel_delayed_work()Tejun Heo
Now that cancel_delayed_work() can be safely called from IRQ handlers, there's no reason to use __cancel_delayed_work(). Use cancel_delayed_work() instead of __cancel_delayed_work() and mark the latter deprecated. Signed-off-by: Tejun Heo <tj@kernel.org> Acked-by: Jens Axboe <axboe@kernel.dk> Cc: Jiri Kosina <jkosina@suse.cz> Cc: Roland Dreier <roland@kernel.org> Cc: Tomi Valkeinen <tomi.valkeinen@ti.com>
2012-08-21workqueue: reimplement cancel_delayed_work() using try_to_grab_pending()Tejun Heo
cancel_delayed_work() can't be called from IRQ handlers due to its use of del_timer_sync() and can't cancel work items which are already transferred from timer to worklist. Also, unlike other flush and cancel functions, a canceled delayed_work would still point to the last associated cpu_workqueue. If the workqueue is destroyed afterwards and the work item is re-used on a different workqueue, the queueing code can oops trying to dereference already freed cpu_workqueue. This patch reimplements cancel_delayed_work() using try_to_grab_pending() and set_work_cpu_and_clear_pending(). This allows the function to be called from IRQ handlers and makes its behavior consistent with other flush / cancel functions. Signed-off-by: Tejun Heo <tj@kernel.org> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Andrew Morton <akpm@linux-foundation.org>
2012-08-21workqueue: use irqsafe timer for delayed_workTejun Heo
Up to now, for delayed_works, try_to_grab_pending() couldn't be used from IRQ handlers because IRQs may happen while delayed_work_timer_fn() is in progress leading to indefinite -EAGAIN. This patch makes delayed_work use the new TIMER_IRQSAFE flag for delayed_work->timer. This makes try_to_grab_pending() and thus mod_delayed_work_on() safe to call from IRQ handlers. Signed-off-by: Tejun Heo <tj@kernel.org>
2012-08-21workqueue: clean up delayed_work initializers and add missing oneTejun Heo
Reimplement delayed_work initializers using new timer initializers which take timer flags. This reduces code duplications and will ease further initializer changes. This patch also adds a missing initializer - INIT_DEFERRABLE_WORK_ONSTACK(). Signed-off-by: Tejun Heo <tj@kernel.org>
2012-08-21workqueue: make deferrable delayed_work initializer names consistentTejun Heo
Initalizers for deferrable delayed_work are confused. * __DEFERRED_WORK_INITIALIZER() * DECLARE_DEFERRED_WORK() * INIT_DELAYED_WORK_DEFERRABLE() Rename them to * __DEFERRABLE_WORK_INITIALIZER() * DECLARE_DEFERRABLE_WORK() * INIT_DEFERRABLE_WORK() This patch doesn't cause any functional changes. Signed-off-by: Tejun Heo <tj@kernel.org>
2012-08-21workqueue: cosmetic whitespace updates for macro definitionsTejun Heo
Consistently use the last tab position for '\' line continuation in complex macro definitions. This is to help the following patches. This patch is cosmetic. Signed-off-by: Tejun Heo <tj@kernel.org>
2012-08-20workqueue: deprecate system_nrt[_freezable]_wqTejun Heo
system_nrt[_freezable]_wq are now spurious. Mark them deprecated and convert all users to system[_freezable]_wq. If you're cc'd and wondering what's going on: Now all workqueues are non-reentrant, so there's no reason to use system_nrt[_freezable]_wq. Please use system[_freezable]_wq instead. This patch doesn't make any functional difference. Signed-off-by: Tejun Heo <tj@kernel.org> Acked-By: Lai Jiangshan <laijs@cn.fujitsu.com> Cc: Jens Axboe <axboe@kernel.dk> Cc: David Airlie <airlied@linux.ie> Cc: Jiri Kosina <jkosina@suse.cz> Cc: "David S. Miller" <davem@davemloft.net> Cc: Rusty Russell <rusty@rustcorp.com.au> Cc: "Paul E. McKenney" <paulmck@linux.vnet.ibm.com> Cc: David Howells <dhowells@redhat.com>
2012-08-20workqueue: deprecate flush[_delayed]_work_sync()Tejun Heo
flush[_delayed]_work_sync() are now spurious. Mark them deprecated and convert all users to flush[_delayed]_work(). If you're cc'd and wondering what's going on: Now all workqueues are non-reentrant and the regular flushes guarantee that the work item is not pending or running on any CPU on return, so there's no reason to use the sync flushes at all and they're going away. This patch doesn't make any functional difference. Signed-off-by: Tejun Heo <tj@kernel.org> Cc: Russell King <linux@arm.linux.org.uk> Cc: Paul Mundt <lethal@linux-sh.org> Cc: Ian Campbell <ian.campbell@citrix.com> Cc: Jens Axboe <axboe@kernel.dk> Cc: Mattia Dongili <malattia@linux.it> Cc: Kent Yoder <key@linux.vnet.ibm.com> Cc: David Airlie <airlied@linux.ie> Cc: Jiri Kosina <jkosina@suse.cz> Cc: Karsten Keil <isdn@linux-pingi.de> Cc: Bryan Wu <bryan.wu@canonical.com> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Alasdair Kergon <agk@redhat.com> Cc: Mauro Carvalho Chehab <mchehab@infradead.org> Cc: Florian Tobias Schandinat <FlorianSchandinat@gmx.de> Cc: David Woodhouse <dwmw2@infradead.org> Cc: "David S. Miller" <davem@davemloft.net> Cc: linux-wireless@vger.kernel.org Cc: Anton Vorontsov <cbou@mail.ru> Cc: Sangbeom Kim <sbkim73@samsung.com> Cc: "James E.J. Bottomley" <James.Bottomley@HansenPartnership.com> Cc: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Cc: Eric Van Hensbergen <ericvh@gmail.com> Cc: Takashi Iwai <tiwai@suse.de> Cc: Steven Whitehouse <swhiteho@redhat.com> Cc: Petr Vandrovec <petr@vandrovec.name> Cc: Mark Fasheh <mfasheh@suse.com> Cc: Christoph Hellwig <hch@infradead.org> Cc: Avi Kivity <avi@redhat.com>
2012-08-20workqueue: gut system_nrt[_freezable]_wq()Tejun Heo
Now that all workqueues are non-reentrant, system[_freezable]_wq() are equivalent to system_nrt[_freezable]_wq(). Replace the latter with wrappers around system[_freezable]_wq(). The wrapping goes through inline functions so that __deprecated can be added easily. Signed-off-by: Tejun Heo <tj@kernel.org>
2012-08-20workqueue: gut flush[_delayed]_work_sync()Tejun Heo
Now that all workqueues are non-reentrant, flush[_delayed]_work_sync() are equivalent to flush[_delayed]_work(). Drop the separate implementation and make them thin wrappers around flush[_delayed]_work(). * start_flush_work() no longer takes @wait_executing as the only left user - flush_work() - always sets it to %true. * __cancel_work_timer() uses flush_work() instead of wait_on_work(). Signed-off-by: Tejun Heo <tj@kernel.org>
2012-08-13workqueue: fix CPU binding of flush_delayed_work[_sync]()Tejun Heo
delayed_work encodes the workqueue to use and the last CPU in delayed_work->work.data while it's on timer. The target CPU is implicitly recorded as the CPU the timer is queued on and delayed_work_timer_fn() queues delayed_work->work to the CPU it is running on. Unfortunately, this leaves flush_delayed_work[_sync]() no way to find out which CPU the delayed_work was queued for when they try to re-queue after killing the timer. Currently, it chooses the local CPU flush is running on. This can unexpectedly move a delayed_work queued on a specific CPU to another CPU and lead to subtle errors. There isn't much point in trying to save several bytes in struct delayed_work, which is already close to a hundred bytes on 64bit with all debug options turned off. This patch adds delayed_work->cpu to remember the CPU it's queued for. Note that if the timer is migrated during CPU down, the work item could be queued to the downed global_cwq after this change. As a detached global_cwq behaves like an unbound one, this doesn't change much for the delayed_work. Signed-off-by: Tejun Heo <tj@kernel.org> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Andrew Morton <akpm@linux-foundation.org>
2012-08-03workqueue: implement mod_delayed_work[_on]()Tejun Heo
Workqueue was lacking a mechanism to modify the timeout of an already pending delayed_work. delayed_work users have been working around this using several methods - using an explicit timer + work item, messing directly with delayed_work->timer, and canceling before re-queueing, all of which are error-prone and/or ugly. This patch implements mod_delayed_work[_on]() which behaves similarly to mod_timer() - if the delayed_work is idle, it's queued with the given delay; otherwise, its timeout is modified to the new value. Zero @delay guarantees immediate execution. v2: Updated to reflect try_to_grab_pending() changes. Now safe to be called from bh context. Signed-off-by: Tejun Heo <tj@kernel.org> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com>
2012-08-03workqueue: mark a work item being canceled as suchTejun Heo
There can be two reasons try_to_grab_pending() can fail with -EAGAIN. One is when someone else is queueing or deqeueing the work item. With the previous patches, it is guaranteed that PENDING and queued state will soon agree making it safe to busy-retry in this case. The other is if multiple __cancel_work_timer() invocations are racing one another. __cancel_work_timer() grabs PENDING and then waits for running instances of the target work item on all CPUs while holding PENDING and !queued. try_to_grab_pending() invoked from another task will keep returning -EAGAIN while the current owner is waiting. Not distinguishing the two cases is okay because __cancel_work_timer() is the only user of try_to_grab_pending() and it invokes wait_on_work() whenever grabbing fails. For the first case, busy looping should be fine but wait_on_work() doesn't cause any critical problem. For the latter case, the new contender usually waits for the same condition as the current owner, so no unnecessarily extended busy-looping happens. Combined, these make __cancel_work_timer() technically correct even without irq protection while grabbing PENDING or distinguishing the two different cases. While the current code is technically correct, not distinguishing the two cases makes it difficult to use try_to_grab_pending() for other purposes than canceling because it's impossible to tell whether it's safe to busy-retry grabbing. This patch adds a mechanism to mark a work item being canceled. try_to_grab_pending() now disables irq on success and returns -EAGAIN to indicate that grabbing failed but PENDING and queued states are gonna agree soon and it's safe to busy-loop. It returns -ENOENT if the work item is being canceled and it may stay PENDING && !queued for arbitrary amount of time. __cancel_work_timer() is modified to mark the work canceling with WORK_OFFQ_CANCELING after grabbing PENDING, thus making try_to_grab_pending() fail with -ENOENT instead of -EAGAIN. Also, it invokes wait_on_work() iff grabbing failed with -ENOENT. This isn't necessary for correctness but makes it consistent with other future users of try_to_grab_pending(). v2: try_to_grab_pending() was testing preempt_count() to ensure that the caller has disabled preemption. This triggers spuriously if !CONFIG_PREEMPT_COUNT. Use preemptible() instead. Reported by Fengguang Wu. v3: Updated so that try_to_grab_pending() disables irq on success rather than requiring preemption disabled by the caller. This makes busy-looping easier and will allow try_to_grap_pending() to be used from bh/irq contexts. Signed-off-by: Tejun Heo <tj@kernel.org> Cc: Fengguang Wu <fengguang.wu@intel.com>
2012-08-03workqueue: introduce WORK_OFFQ_FLAG_*Tejun Heo
Low WORK_STRUCT_FLAG_BITS bits of work_struct->data contain WORK_STRUCT_FLAG_* and flush color. If the work item is queued, the rest point to the cpu_workqueue with WORK_STRUCT_CWQ set; otherwise, WORK_STRUCT_CWQ is clear and the bits contain the last CPU number - either a real CPU number or one of WORK_CPU_*. Scheduled addition of mod_delayed_work[_on]() requires an additional flag, which is used only while a work item is off queue. There are more than enough bits to represent off-queue CPU number on both 32 and 64bits. This patch introduces WORK_OFFQ_FLAG_* which occupy the lower part of the @work->data high bits while off queue. This patch doesn't define any actual OFFQ flag yet. Off-queue CPU number is now shifted by WORK_OFFQ_CPU_SHIFT, which adds the number of bits used by OFFQ flags to WORK_STRUCT_FLAG_SHIFT, to make room for OFFQ flags. To avoid shift width warning with large WORK_OFFQ_FLAG_BITS, ulong cast is added to WORK_STRUCT_NO_CPU and, just in case, BUILD_BUG_ON() to check that there are enough bits to accomodate off-queue CPU number is added. This patch doesn't make any functional difference. Signed-off-by: Tejun Heo <tj@kernel.org>
2012-08-03workqueue: set delayed_work->timer function on initializationTejun Heo
delayed_work->timer.function is currently initialized during queue_delayed_work_on(). Export delayed_work_timer_fn() and set delayed_work timer function during delayed_work initialization together with other fields. This ensures the timer function is always valid on an initialized delayed_work. This is to help mod_delayed_work() implementation. To detect delayed_work users which diddle with the internal timer, trigger WARN if timer function doesn't match on queue. Signed-off-by: Tejun Heo <tj@kernel.org>
2012-08-03workqueue: make queueing functions return boolTejun Heo
All queueing functions return 1 on success, 0 if the work item was already pending. Update them to return bool instead. This signifies better that they don't return 0 / -errno. This is cleanup and doesn't cause any functional difference. While at it, fix comment opening for schedule_work_on(). Signed-off-by: Tejun Heo <tj@kernel.org>
2012-08-03workqueue: reorder queueing functions so that _on() variants are on topTejun Heo
Currently, queue/schedule[_delayed]_work_on() are located below the counterpart without the _on postifx even though the latter is usually implemented using the former. Swap them. This is cleanup and doesn't cause any functional difference. Signed-off-by: Tejun Heo <tj@kernel.org>
2012-03-02Block: use a freezable workqueue for disk-event pollingAlan Stern
This patch (as1519) fixes a bug in the block layer's disk-events polling. The polling is done by a work routine queued on the system_nrt_wq workqueue. Since that workqueue isn't freezable, the polling continues even in the middle of a system sleep transition. Obviously, polling a suspended drive for media changes and such isn't a good thing to do; in the case of USB mass-storage devices it can lead to real problems requiring device resets and even re-enumeration. The patch fixes things by creating a new system-wide, non-reentrant, freezable workqueue and using it for disk-events polling. Signed-off-by: Alan Stern <stern@rowland.harvard.edu> CC: <stable@kernel.org> Acked-by: Tejun Heo <tj@kernel.org> Acked-by: Rafael J. Wysocki <rjw@sisk.pl> Signed-off-by: Jens Axboe <axboe@kernel.dk>
2012-01-10workqueue: make alloc_workqueue() take printf fmt and args for nameTejun Heo
alloc_workqueue() currently expects the passed in @name pointer to remain accessible. This is inconvenient and a bit silly given that the whole wq is being dynamically allocated. This patch updates alloc_workqueue() and friends to take printf format string instead of opaque string and matching varargs at the end. The name is allocated together with the wq and formatted. alloc_ordered_workqueue() is converted to a macro to unify varargs handling with alloc_workqueue(), and, while at it, add comment to alloc_workqueue(). None of the current in-kernel users pass in string with '%' as constant name and this change shouldn't cause any problem. [akpm@linux-foundation.org: use __printf] Signed-off-by: Tejun Heo <tj@kernel.org> Suggested-by: Christoph Hellwig <hch@infradead.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-07-26atomic: use <linux/atomic.h>Arun Sharma
This allows us to move duplicated code in <asm/atomic.h> (atomic_inc_not_zero() for now) to <linux/atomic.h> Signed-off-by: Arun Sharma <asharma@fb.com> Reviewed-by: Eric Dumazet <eric.dumazet@gmail.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: David Miller <davem@davemloft.net> Cc: Eric Dumazet <eric.dumazet@gmail.com> Acked-by: Mike Frysinger <vapier@gentoo.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
