path: root/include/linux/vmalloc.h
2006-09-26[PATCH] mm/: make functions staticAdrian Bunk
This patch makes the following needlessly global functions static: - slab.c: kmem_find_general_cachep() - swap.c: __page_cache_release() - vmalloc.c: __vmalloc_node() Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-07-14[PATCH] mm: fix oom roll-back of __vmalloc_area_nodeJan Kiszka
__vunmap must not rely on area->nr_pages when picking the release methode for area->pages. It may be too small when __vmalloc_area_node failed early due to lacking memory. Instead, use a flag in vmstruct to differentiate. Signed-off-by: Jan Kiszka <jan.kiszka@web.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-23[PATCH] mm: introduce remap_vmalloc_range()Nick Piggin
Add remap_vmalloc_range, vmalloc_user, and vmalloc_32_user so that drivers can have a nice interface for remapping vmalloc memory. Signed-off-by: Nick Piggin <npiggin@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-10-29[PATCH] vmalloc_nodeChristoph Lameter
This patch adds vmalloc_node(size, node) -> Allocate necessary memory on the specified node and get_vm_area_node(size, flags, node) and the other functions that it depends on. Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-10-08[PATCH] gfp flags annotations - part 1Al Viro
- added typedef unsigned int __nocast gfp_t; - replaced __nocast uses for gfp flags with gfp_t - it gives exactly the same warnings as far as sparse is concerned, doesn't change generated code (from gcc point of view we replaced unsigned int with typedef) and documents what's going on far better. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-05[PATCH] arm: allow for arch-specific IOREMAP_MAX_ORDERDeepak Saxena
Version 6 of the ARM architecture introduces the concept of 16MB pages (supersections) and 36-bit (40-bit actually, but nobody uses this) physical addresses. 36-bit addressed memory and I/O and ARMv6 can only be mapped using supersections and the requirement on these is that both virtual and physical addresses be 16MB aligned. In trying to add support for ioremap() of 36-bit I/O, we run into the issue that get_vm_area() allows for a maximum of 512K alignment via the IOREMAP_MAX_ORDER constant. To work around this, we can: - Allocate a larger VM area than needed (size + (1ul << IOREMAP_MAX_ORDER)) and then align the pointer ourselves, but this ends up with 512K of wasted VM per ioremap(). - Provide a new __get_vm_area_aligned() API and make __get_vm_area() sit on top of this. I did this and it works but I don't like the idea adding another VM API just for this one case. - My preferred solution which is to allow the architecture to override the IOREMAP_MAX_ORDER constant with it's own version. Signed-off-by: Deepak Saxena <dsaxena@plexity.net> Cc: Russell King <rmk@arm.linux.org.uk> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-05-20[PATCH] x86_64: Fixed guard page handling again in iounmapAndi Kleen
Caused oopses again. Also fix potential mismatch in checking if change_page_attr was needed. To do it without races I needed to change mm/vmalloc.c to export a __remove_vm_area that does not take vmlist lock. Noticed by Terence Ripperda and based on a patch of his. Signed-off-by: Andi Kleen <ak@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
