path: root/include/linux/vermagic.h
Many source files in the tree are missing licensing information, which makes it harder for compliance tools to determine the correct license. By default all files without license information are under the default license of the kernel, which is GPL version 2. Update the files which contain no license information with the 'GPL-2.0' SPDX license identifier. The SPDX identifier is a legally binding shorthand, which can be used instead of the full boiler plate text. This patch is based on work done by Thomas Gleixner and Kate Stewart and Philippe Ombredanne. How this work was done: Patches were generated and checked against linux-4.14-rc6 for a subset of the use cases: - file had no licensing information it it. - file was a */uapi/* one with no licensing information in it, - file was a */uapi/* one with existing licensing information, Further patches will be generated in subsequent months to fix up cases where non-standard license headers were used, and references to license had to be inferred by heuristics based on keywords. The analysis to determine which SPDX License Identifier to be applied to a file was done in a spreadsheet of side by side results from of the output of two independent scanners (ScanCode & Windriver) producing SPDX tag:value files created by Philippe Ombredanne. Philippe prepared the base worksheet, and did an initial spot review of a few 1000 files. The 4.13 kernel was the starting point of the analysis with 60,537 files assessed. Kate Stewart did a file by file comparison of the scanner results in the spreadsheet to determine which SPDX license identifier(s) to be applied to the file. She confirmed any determination that was not immediately clear with lawyers working with the Linux Foundation. Criteria used to select files for SPDX license identifier tagging was: - Files considered eligible had to be source code files. - Make and config files were included as candidates if they contained >5 lines of source - File already had some variant of a license header in it (even if <5 lines). All documentation files were explicitly excluded. The following heuristics were used to determine which SPDX license identifiers to apply. - when both scanners couldn't find any license traces, file was considered to have no license information in it, and the top level COPYING file license applied. For non */uapi/* files that summary was: SPDX license identifier # files ---------------------------------------------------|------- GPL-2.0 11139 and resulted in the first patch in this series. If that file was a */uapi/* path one, it was "GPL-2.0 WITH Linux-syscall-note" otherwise it was "GPL-2.0". Results of that was: SPDX license identifier # files ---------------------------------------------------|------- GPL-2.0 WITH Linux-syscall-note 930 and resulted in the second patch in this series. - if a file had some form of licensing information in it, and was one of the */uapi/* ones, it was denoted with the Linux-syscall-note if any GPL family license was found in the file or had no licensing in it (per prior point). Results summary: SPDX license identifier # files ---------------------------------------------------|------ GPL-2.0 WITH Linux-syscall-note 270 GPL-2.0+ WITH Linux-syscall-note 169 ((GPL-2.0 WITH Linux-syscall-note) OR BSD-2-Clause) 21 ((GPL-2.0 WITH Linux-syscall-note) OR BSD-3-Clause) 17 LGPL-2.1+ WITH Linux-syscall-note 15 GPL-1.0+ WITH Linux-syscall-note 14 ((GPL-2.0+ WITH Linux-syscall-note) OR BSD-3-Clause) 5 LGPL-2.0+ WITH Linux-syscall-note 4 LGPL-2.1 WITH Linux-syscall-note 3 ((GPL-2.0 WITH Linux-syscall-note) OR MIT) 3 ((GPL-2.0 WITH Linux-syscall-note) AND MIT) 1 and that resulted in the third patch in this series. - when the two scanners agreed on the detected license(s), that became the concluded license(s). - when there was disagreement between the two scanners (one detected a license but the other didn't, or they both detected different licenses) a manual inspection of the file occurred. - In most cases a manual inspection of the information in the file resulted in a clear resolution of the license that should apply (and which scanner probably needed to revisit its heuristics). - When it was not immediately clear, the license identifier was confirmed with lawyers working with the Linux Foundation. - If there was any question as to the appropriate license identifier, the file was flagged for further research and to be revisited later in time. In total, over 70 hours of logged manual review was done on the spreadsheet to determine the SPDX license identifiers to apply to the source files by Kate, Philippe, Thomas and, in some cases, confirmation by lawyers working with the Linux Foundation. Kate also obtained a third independent scan of the 4.13 code base from FOSSology, and compared selected files where the other two scanners disagreed against that SPDX file, to see if there was new insights. The Windriver scanner is based on an older version of FOSSology in part, so they are related. Thomas did random spot checks in about 500 files from the spreadsheets for the uapi headers and agreed with SPDX license identifier in the files he inspected. For the non-uapi files Thomas did random spot checks in about 15000 files. In initial set of patches against 4.14-rc6, 3 files were found to have copy/paste license identifier errors, and have been fixed to reflect the correct identifier. Additionally Philippe spent 10 hours this week doing a detailed manual inspection and review of the 12,461 patched files from the initial patch version early this week with: - a full scancode scan run, collecting the matched texts, detected license ids and scores - reviewing anything where there was a license detected (about 500+ files) to ensure that the applied SPDX license was correct - reviewing anything where there was no detection but the patch license was not GPL-2.0 WITH Linux-syscall-note to ensure that the applied SPDX license was correct This produced a worksheet with 20 files needing minor correction. This worksheet was then exported into 3 different .csv files for the different types of files to be modified. These .csv files were then reviewed by Greg. Thomas wrote a script to parse the csv files and add the proper SPDX tag to the file, in the format that the file expected. This script was further refined by Greg based on the output to detect more types of files automatically and to distinguish between header and source .c files (which need different comment types.) Finally Greg ran the script using the .csv files to generate the patches. Reviewed-by: Kate Stewart <kstewart@linuxfoundation.org> Reviewed-by: Philippe Ombredanne <pombredanne@nexb.com> Reviewed-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-06-22gcc-plugins: Add the randstruct pluginKees Cook
This randstruct plugin is modified from Brad Spengler/PaX Team's code in the last public patch of grsecurity/PaX based on my understanding of the code. Changes or omissions from the original code are mine and don't reflect the original grsecurity/PaX code. The randstruct GCC plugin randomizes the layout of selected structures at compile time, as a probabilistic defense against attacks that need to know the layout of structures within the kernel. This is most useful for "in-house" kernel builds where neither the randomization seed nor other build artifacts are made available to an attacker. While less useful for distribution kernels (where the randomization seed must be exposed for third party kernel module builds), it still has some value there since now all kernel builds would need to be tracked by an attacker. In more performance sensitive scenarios, GCC_PLUGIN_RANDSTRUCT_PERFORMANCE can be selected to make a best effort to restrict randomization to cacheline-sized groups of elements, and will not randomize bitfields. This comes at the cost of reduced randomization. Two annotations are defined,__randomize_layout and __no_randomize_layout, which respectively tell the plugin to either randomize or not to randomize instances of the struct in question. Follow-on patches enable the auto-detection logic for selecting structures for randomization that contain only function pointers. It is disabled here to assist with bisection. Since any randomized structs must be initialized using designated initializers, __randomize_layout includes the __designated_init annotation even when the plugin is disabled so that all builds will require the needed initialization. (With the plugin enabled, annotations for automatically chosen structures are marked as well.) The main differences between this implemenation and grsecurity are: - disable automatic struct selection (to be enabled in follow-up patch) - add designated_init attribute at runtime and for manual marking - clarify debugging output to differentiate bad cast warnings - add whitelisting infrastructure - support gcc 7's DECL_ALIGN and DECL_MODE changes (Laura Abbott) - raise minimum required GCC version to 4.7 Earlier versions of this patch series were ported by Michael Leibowitz. Signed-off-by: Kees Cook <keescook@chromium.org>
2011-10-31vermagic: delete unused include of <linux/module.h>Paul Gortmaker
This file consists of nothing other than things like: #ifdef CONFIG_FOO #define .... There is no reason for it to require module.h Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2009-12-12kbuild: move utsrelease.h to include/generatedSam Ravnborg
Fix up all users of utsrelease.h Signed-off-by: Sam Ravnborg <sam@ravnborg.org> Signed-off-by: Michal Marek <mmarek@suse.cz>
2008-05-09module: put modversions in vermagicRusty Russell
Don't allow a module built without versions altogether to be inserted into a kernel which expects modversions. modprobe --force will strip vermagic as well as modversions, so it won't be effected, but this will make sure that a non-CONFIG_MODVERSIONS module won't be accidentally inserted into a CONFIG_MODVERSIONS kernel. Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2006-09-26[PATCH] Move compiler check for modules to ia64 onlyAndi Kleen
Apparently IA64 needs it, but i386/x86-64 don't anymore since gcc 2.95 support was dropped. Nobody else on linux-arch requested keeping it generically Cc: tony.luck@intel.com Cc: kaos@sgi.com Signed-off-by: Andi Kleen <ak@suse.de>
2006-07-03kbuild: introduce utsrelease.hSam Ravnborg
include/linux/version.h contained both actual KERNEL version and UTS_RELEASE that contains a subset from git SHA1 for when kernel was compiled as part of a git repository. This had the unfortunate side-effect that all files including version.h would be recompiled when some git changes was made due to changes SHA1. Split it out so we keep independent parts in separate files. Also update checkversion.pl script to no longer check for UTS_RELEASE. Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2006-04-11[PATCH] module support: record in vermagic ability to unload a modulePaolo 'Blaisorblade' Giarrusso
An UML user reported (against 2.6.13.3/UML) he got kernel Oopses when trying to rmmod (on a kernel with module unloading enabled) a module compiled with module unloading disabled. As crashing is a very correct thing to do in that case, a solution is altering the vermagic string to include this too. Possibly, however, the code should not crash in this case, even if the module didn't support unloading - it should simply abort the module removal. In this case, fixing that bug would be a better solution. I've not investigated though. (akpm: a bit marginal - root screwed up and shot himself in the foot). Cc: Hayim Shaul <hayim@post.tau.ac.il> Cc: Rusty Russell <rusty@rustcorp.com.au> Signed-off-by: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
