git://git.kernel.org/pub/scm/linux/kernel/git/peter.chen/usb into usb-next
Hi Greg, below are changes for chipidea and OTG FSM, no major changes.
Some for documentation, some for tiny changes, thanks.
The XHCI controller presents two USB buses to the system - one for USB2
and one for USB3. The hub init code (hub_port_init) is reentrant but
only locks one bus per thread, leading to a race condition failure when
two threads attempt to simultaneously initialise a USB2 and USB3 device:
[ 8.034843] xhci_hcd 0000:00:14.0: Timeout while waiting for setup device command
[ 13.183701] usb 3-3: device descriptor read/all, error -110
On a test system this failure occurred on 6% of all boots.
The call traces at the point of failure are:
Call Trace:
[<ffffffff81b9bab7>] schedule+0x37/0x90
[<ffffffff817da7cd>] usb_kill_urb+0x8d/0xd0
[<ffffffff8111e5e0>] ? wake_up_atomic_t+0x30/0x30
[<ffffffff817dafbe>] usb_start_wait_urb+0xbe/0x150
[<ffffffff817db10c>] usb_control_msg+0xbc/0xf0
[<ffffffff817d07de>] hub_port_init+0x51e/0xb70
[<ffffffff817d4697>] hub_event+0x817/0x1570
[<ffffffff810f3e6f>] process_one_work+0x1ff/0x620
[<ffffffff810f3dcf>] ? process_one_work+0x15f/0x620
[<ffffffff810f4684>] worker_thread+0x64/0x4b0
[<ffffffff810f4620>] ? rescuer_thread+0x390/0x390
[<ffffffff810fa7f5>] kthread+0x105/0x120
[<ffffffff810fa6f0>] ? kthread_create_on_node+0x200/0x200
[<ffffffff81ba183f>] ret_from_fork+0x3f/0x70
Call Trace:
[<ffffffff817fd36d>] xhci_setup_device+0x53d/0xa40
[<ffffffff817fd87e>] xhci_address_device+0xe/0x10
[<ffffffff817d047f>] hub_port_init+0x1bf/0xb70
[<ffffffff811247ed>] ? trace_hardirqs_on+0xd/0x10
Which results from the two call chains:
hub_port_init
usb_get_device_descriptor
usb_get_descriptor
usb_control_msg
usb_internal_control_msg
usb_start_wait_urb
usb_submit_urb / wait_for_completion_timeout / usb_kill_urb
hub_port_init
hub_set_address
xhci_address_device
xhci_setup_device
Mathias Nyman explains the current behaviour violates the XHCI spec:
hub_port_reset() will end up moving the corresponding xhci device slot
to default state.
As hub_port_reset() is called several times in hub_port_init() it
sounds reasonable that we could end up with two threads having their
xhci device slots in default state at the same time, which according to
xhci 4.5.3 specs still is a big no no:
"Note: Software shall not transition more than one Device Slot to the
Default State at a time"
So both threads fail at their next task after this.
One fails to read the descriptor, and the other fails addressing the
device.
Fix this in hub_port_init by locking the USB controller (instead of an
individual bus) to prevent simultaneous initialisation of both buses.
Fixes: 638139eb95d2 ("usb: hub: allow to process more usb hub events in parallel")
Link: https://lkml.org/lkml/2016/2/8/312
Link: https://lkml.org/lkml/2016/2/4/748
Signed-off-by: Chris Bainbridge <chris.bainbridge@gmail.com>
Cc: stable <stable@vger.kernel.org>
Acked-by: Mathias Nyman <mathias.nyman@linux.intel.com>
If the following environment, the first argument of DMA API should
be set to a DMAC's device structure, not a udc controller's one.
- A udc controller needs an external DMAC device (like a DMA Engine).
- The external DMAC enables IOMMU.
So, this patch add usb_gadget_{un}map_request_by_dev() API to set
a DMAC's device structure by a udc controller driver.
Signed-off-by: Yoshihiro Shimoda <yoshihiro.shimoda.uh@renesas.com>
Signed-off-by: Felipe Balbi <felipe.balbi@linux.intel.com>
Move the state_changed variable into struct otg_fsm
so that we can support multiple instances.
Signed-off-by: Roger Quadros <rogerq@ti.com>
Acked-by: Peter Chen <peter.chen@freescale.com>
Signed-off-by: Peter Chen <peter.chen@nxp.com>
struct otg_fsm is the interface to the OTG state machine.
Document the input, output and internal state variables.
Definations are taken from Table 7-2 and Table 7-4 of
the USB OTG & EH Specification Rev.2.0
Re-arrange some of the members as per use case for more
clarity.
Although most of USB devices are hot-plug's, there are still some devices
are hard wired on the board, eg, for HSIC and SSIC interface USB devices.
If these kinds of USB devices are multiple functions, and they can supply
other interfaces like i2c, gpios for other devices, we may need to
describe these at device tree.
In this commit, it uses "reg" in dts as physical port number to match
the phyiscal port number decided by USB core, if they are the same,
then the device node is for the device we are creating for USB core.
Signed-off-by: Peter Chen <peter.chen@freescale.com>
Acked-by: Philipp Zabel <p.zabel@pengutronix.de>
Acked-by: Alan Stern <stern@rowland.harvard.edu>
Acked-by: Rob Herring <robh@kernel.org>
musb_hdrc_platform_data::config
The musb_hdrc_platform_data::config was defined as a non-const pointer.
However some drivers (e.g. the ux500) set up this pointer to point to a
static structure, which is potentially dangerous. Since the musb core
uses the pointer in a read-only manner the const qualifier was added to
protect the content of the config.
Signed-off-by: Petr Kulhavy <petr@barix.com>
Acked-by: Sergei Shtylyov <sergei.shtylyov@cogentembedded.com>
Signed-off-by: Bin Liu <b-liu@ti.com>
Signed-off-by: Felipe Balbi <balbi@kernel.org>
Add A-idle to B-disconnect timer, B-device detects that bus is idle
for more than TB_AIDL_BDIS min and begins HNP by turning off pullup
on D+. This allows the bus to discharge to the SE0 state.
Acked-by: Peter Chen <peter.chen@nxp.com>
Signed-off-by: Li Jun <jun.li@nxp.com>
Adds HNP polling timer when transits to host state, the OTG status
request will be sent to peripheral after timeout, if host request flag
is set, it will switch to peripheral state, otherwise it will repeat HNP
polling every 1.5s and maintain the current session.
Add 2 flags for USB OTG HNP polling, hnp_polling_support is to indicate
if the gadget can support HNP polling, host_request_flag is used for
gadget to store host request information from application, which can be
used to respond to HNP polling from host.
Since commit 855ed04a3758b205e84b269f92d26ab36ed8e2f7 ("usb: gadget:
udc-core: independent registration of gadgets and gadget drivers") gadget
drivers can not assume that UDC drivers are already available on their
initialization. This broke the HACK, which was used in gadgetfs driver,
to get UDC controller name. This patch removes this hack and replaces it
by additional function in the UDC core (which is usefully only for legacy
drivers, please don't use it in the new code).
Reported-by: Vegard Nossum <vegard.nossum@oracle.com>
Tested-by: Vegard Nossum <vegard.nossum@oracle.com>
Since the usb2 phy driver for gen3 (phy-rcar-gen3-usb2) cannot access
LPSTS and UGCTRL2 registers in the HSUSB module, this driver have to
initialize the registers. So, this patch adds such handling code into
rcar3.c.
When a function is added to a configuration with usb_add_function(), the
configuration speed flags are updated. These flags indicate for which
speeds the configuration is valid for.
This patch adds a flag in the configuration for SuperSpeedPlus and
also updates this based on the existence of ssp_descriptors.
Signed-off-by: John Youn <johnyoun@synopsys.com>
Add a ssp_descriptors member to struct usb_function and handle the
initialization and cleanup of it. This holds the SuperSpeedPlus
descriptors for a function that supports SuperSpeedPlus. This is added
by usb_assign_descriptors().
Add the 'ssp_descriptors' parameter to the usb_assign_descriptors()
function. This allows a function driver to add descriptors for
SuperSpeedPlus speeds if it supports it.
Also update all uses of this function in the gadget subsystem so that
they pass NULL for the ssp_descriptors parameters.
Add a function to check for SuperSpeedPlus capable gadgets.
Now that usb_bus_list has been removed and switched to idr
rename the related mutex accordingly.
Signed-off-by: Heiner Kallweit <hkallweit1@gmail.com>
The fixes are:
- fix indentation of a comment
- fix a typo in the comment about bulk_cb_wrap.Length
- make comment about US_BULK_CB_SIGN look like the one about
US_BULK_CS_SIGN below
- make the comment about bulk_cs_wrap.Signature look more like the one
about bulk_cb_wrap.Signature
Signed-off-by: Antonio Ospite <ao2@ao2.it>
USB bus numbering is based on directly dealing with bitmaps and
defines a separate list of busses.
This can be simplified and unified by using existing idr functionality.
Disable the silicon quirk which is normally enabled for HSIC
host mode. This would otherwise prevent low speed devices
from enumerating properly.
Signed-off-by: Jack Pham <jackp@codeaurora.org>
Signed-off-by: Timur Tabi <timur@codeaurora.org>
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb
Pull USB updates from Greg KH:
"Here is the big USB drivers update for 4.5-rc1.
Lots of gadget driver updates and fixes, like usual, and a mix of
other USB driver updates as well. Full details in the shortlog. All
of these have been in linux-next for a while"
* tag 'usb-4.5-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb: (191 commits)
MAINTAINERS: change my email address
USB: usbmon: remove assignment from IS_ERR argument
USB: mxu11x0: drop redundant function name from error messages
USB: mxu11x0: fix debug-message typos
USB: mxu11x0: rename usb-serial driver
USB: mxu11x0: fix modem-control handling on B0-transitions
USB: mxu11x0: fix memory leak on firmware download
USB: mxu11x0: fix memory leak in port-probe error path
USB: serial: add Moxa UPORT 11x0 driver
USB: cp210x: add ID for ELV Marble Sound Board 1
usb: chipidea: otg: use usb autosuspend to suspend bus for HNP
usb: chipidea: host: set host to be null after hcd is freed
usb: chipidea: removing of_find_property
usb: chipidea: implement platform shutdown callback
usb: chipidea: clean up CONFIG_USB_CHIPIDEA_DEBUG reference
usb: chipidea: delete static debug support
usb: chipidea: support debugfs without CONFIG_USB_CHIPIDEA_DEBUG
usb: chipidea: udc: improve error handling on _hardware_enqueue
usb: chipidea: udc: _ep_queue and _hw_queue cleanup
usb: dwc3: of-simple: fix build warning on !PM
git://git.kernel.org/pub/scm/linux/kernel/git/balbi/usb into usb-next
Felipe writes:
usb: patches for v4.5
A ton of improvements to dwc2 have been made. The
driver should be a lot more stable on v4.5 then ever
before.
Our good old dwc3 got a few cleanups and misc fixes
and also added support to Xilinx's integration of
this IP.
Yoshihiro Shimoda gives us support for a new USB3
peripheral controller from Renesas.
Other than these, the usual misc fixes all over the
place.
NCM buffer sizes are negotiated with the device independently of
the network device MTU. The RX buffers are allocated by the
usbnet framework based on the rx_urb_size value set by cdc_ncm. A
single RX buffer can hold a number of MTU sized packets.
The default usbnet change_mtu ndo only modifies rx_urb_size if it
is equal to hard_mtu. And the cdc_ncm driver will set rx_urb_size
and hard_mtu independently of each other, based on dwNtbInMaxSize
and dwNtbOutMaxSize respectively. It was therefore assumed that
usbnet_change_mtu() would never touch rx_urb_size. This failed to
consider the case where dwNtbInMaxSize and dwNtbOutMaxSize happens
to be equal.
Fix by implementing an NCM specific change_mtu ndo, modifying the
netdev MTU without touching the buffer size settings.
Signed-off-by: Bjørn Mork <bjorn@mork.no>
Queue a request to disabled ep doesn't make sense, and induce caller
make mistakes.
Here is a example for the android mtp gadget function driver. A mem
corruption can happen on below senario.
1) On disconnect, mtp driver disable its EPs,
2) During send_file_work and receive_file_work, mtp queues a request
to ep. (The mtp driver need improve its synchronization logic!)
3) mtp_function_unbind is invoked and all mtp requests are freed.
4) when udc process the request queued on step 2, will cause kernel
NULL pointer dereference exception.
Signed-off-by: Du, Changbin <changbin.du@intel.com>
Signed-off-by: Felipe Balbi <balbi@ti.com>
If OF is disabled, we will try to define a stub for
of_usb_get_dr_mode_by_phy(), however that missed a
static inline annotation which made us redefine the
stub over and over again. Fix that.
Fixes: 98bfb3946695 ("usb: of: add an api to get
dr_mode by the phy node")
We currently can't unload omap2430 MUSB platform glue driver module and
this cause issues for fixing the MUSB code further. The reason we can't
remove omap2430 is because it uses the PHY functions and also exports the
omap_musb_mailbox function that some PHY drivers are using.
Let's fix the issue by exporting a more generic musb_mailbox function
from the MUSB core and allow platform glue layers to register phy_callback
function as needed.
And now we can now also get rid of the include/linux/musb-omap.h.
Cc: Bin Liu <b-liu@ti.com>
Cc: Felipe Balbi <balbi@ti.com>
Cc: Kishon Vijay Abraham I <kishon@ti.com>
Cc: NeilBrown <neil@brown.name>
Reviewed-by: Kishon Vijay Abraham I <kishon@ti.com>
Change behavior during registration of gadgets and
gadget drivers in udc-core. Instead of previous
approach when for successful probe of usb gadget driver
at least one usb gadget should be already registered
use another one where gadget drivers and gadgets
can be registered in udc-core independently.
Independent registration of gadgets and gadget drivers
is useful for built-in into kernel gadget and gadget
driver case - because it's possible that gadget is
really probed only on late_init stage (due to deferred
probe) whereas gadget driver's probe is silently failed
on module_init stage due to no any UDC added.
Also it is useful for modules case - now there is no
difference what module to insert first: gadget module
or gadget driver one.
Tested-by: Maxime Ripard <maxime.ripard@free-electrons.com>
Signed-off-by: Ruslan Bilovol <ruslan.bilovol@gmail.com>
[simplified code as requested by Alan Stern and Felipe Balbi,
fixed checkpatch issues]
Tested-by: Peter Chen <peter.chen@freescale.com>
Now when last user of usb_udc_attach_driver() is switched
to passing UDC name via usb_gadget_driver struct, it's safe
to remove this function
Introduce new 'udc_name' member to usb_gadget_driver structure.
The 'udc_name' is a name of UDC that usb_gadget_driver should
be bound to. If udc_name is NULL, it will be bound to any
available UDC.
Some USB phy drivers have different handling for the controller in each
dr_mode. But the phy driver does not have visibility to the dr_mode of
the controller.
This adds an api to return the dr_mode of the controller which
associates the given phy node.
The current code has info->bufnmb_last to calculate the BUFNMB bits of
PIPEBUF register. However, since the bufnmb_last is initialized in
the usbhs_pipe_init() only, this driver is possible to set unexpected
value to the register if usb_ep_{enable,disable}() are called many times.
So, this patch modifies the pipe configuration via struct
renesas_usbhs_driver_param to simplify the code. Also this patch changes:
- a double buffer configuration
- isochronous buffer size from 512 to 1024
Some USB device / host controller combinations seem to have problems
with Link Power Management. For example, Steinar found that his xHCI
controller wouldn't handle bandwidth calculations correctly for two
video cards simultaneously when LPM was enabled, even though the bus
had plenty of bandwidth available.
This patch introduces a new quirk flag for devices that should remain
disabled for LPM, and creates quirk entries for Steinar's devices.
Signed-off-by: Alan Stern <stern@rowland.harvard.edu>
Reported-by: Steinar H. Gunderson <sgunderson@bigfoot.com>
The usb_mon_operations structure is never modified, so declare it as const.
Done with the help of Coccinelle.
Signed-off-by: Julia Lawall <Julia.Lawall@lip6.fr>
git://git.kernel.org/pub/scm/linux/kernel/git/nab/target-pending
Pull SCSI target updates from Nicholas Bellinger:
"This series contains HCH's changes to absorb configfs attribute
->show() + ->store() function pointer usage from it's original
tree-wide consumers, into common configfs code.
It includes usb-gadget, target w/ drivers, netconsole and ocfs2
changes to realize the improved simplicity, that now renders the
original include/target/configfs_macros.h CPP magic for fabric drivers
and others, unnecessary and obsolete.
And with common code in place, new configfs attributes can be added
easier than ever before.
Note, there are further improvements in-flight from other folks for
v4.5 code in configfs land, plus number of target fixes for post -rc1
code"
In the meantime, a new user of the now-removed old configfs API came in
through the char/misc tree in commit 7bd1d4093c2f ("stm class: Introduce
an abstraction for System Trace Module devices").
This merge resolution comes from Alexander Shishkin, who updated his stm
class tracing abstraction to account for the removal of the old
show_attribute and store_attribute methods in commit 517982229f78
("configfs: remove old API") from this pull. As Alexander says about
that patch:
"There's no need to keep an extra wrapper structure per item and the
awkward show_attribute/store_attribute item ops are no longer needed.
This patch converts policy code to the new api, all the while making
the code quite a bit smaller and easier on the eyes.
Signed-off-by: Alexander Shishkin <alexander.shishkin@linux.intel.com>"
That patch was folded into the merge so that the tree should be fully
bisectable.
* 'for-next' of git://git.kernel.org/pub/scm/linux/kernel/git/nab/target-pending: (23 commits)
ocfs2/cluster: use per-attribute show and store methods
ocfs2/cluster: move locking into attribute store methods
netconsole: use per-attribute show and store methods
target: use per-attribute show and store methods
spear13xx_pcie_gadget: use per-attribute show and store methods
dlm: use per-attribute show and store methods
usb-gadget/f_serial: use per-attribute show and store methods
usb-gadget/f_phonet: use per-attribute show and store methods
usb-gadget/f_obex: use per-attribute show and store methods
usb-gadget/f_uac2: use per-attribute show and store methods
usb-gadget/f_uac1: use per-attribute show and store methods
usb-gadget/f_mass_storage: use per-attribute show and store methods
usb-gadget/f_sourcesink: use per-attribute show and store methods
usb-gadget/f_printer: use per-attribute show and store methods
usb-gadget/f_midi: use per-attribute show and store methods
usb-gadget/f_loopback: use per-attribute show and store methods
usb-gadget/ether: use per-attribute show and store methods
usb-gadget/f_acm: use per-attribute show and store methods
usb-gadget/f_hid: use per-attribute show and store methods
"Here is the big USB patchset for 4.4-rc1.
As usual, most of the changes are in the gadget subsystem, and we
removed a host controller for a device that is no longer in existance,
and probably never was even made public. There is also other minor
driver updates and new device ids, full details in the changelog.
All of these have been in linux-next for a while"
* tag 'usb-4.4-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb: (233 commits)
USB: core: Codestyle fix in urb.c
usb: misc: usb3503: Use i2c_add_driver helper macro
usb: host: lpc32xx: don't unregister phy device
usb: host: lpc32xx: balance clk enable/disable on removal
usb: host: lpc32xx: fix warnings caused by enabling unprepared clock
uwb: drp: Use setup_timer
uwb: neh: Use setup_timer
uwb: rsv: Use setup_timer
USB: qcserial: add Sierra Wireless MC74xx/EM74xx
usb: chipidea: otg: don't wait vbus drops below BSV when starts host
chipidea: ci_hdrc_pci: use PCI_VDEVICE() instead of PCI_DEVICE()
doc: dt-binding: ci-hdrc-usb2: split vendor specific properties
usb: chipidea: imx: add imx6ul usb support
doc: dt-binding: ci-hdrc-usb2: improve property description
usb: chipidea: imx: add usb support for imx7d
Doc: usb: ci-hdrc-usb2: Add phy-clkgate-delay-us entry
usb: chipidea: Add support for 'phy-clkgate-delay-us' property
usb: chipidea: Use extcon framework for VBUS and ID detect
usb: gadget: net2280: restore ep_cfg after defect7374 workaround
usb: dwc2: host: Fix use after free w/ simultaneous irqs
Peter writes:
USB Chipidea updates for v4.4-rc1
- Use extcon framework for VBUS and ID detect
- Add imx6sx and imx7d support
- Other small changes
Felipe writes:
usb: patches for v4.4 merge window
This pull request is large with a total of 136 non-merge
commits. Because of its size, we will only describe the big things in
broad terms.
Many will be happy to know that dwc3 is now almost twice as fast after
some profiling and speed improvements. Also in dwc3, John Youn from
Synopsys added support for their new DWC USB3.1 IP Core and the HAPS
platform which can be used to validate it.
A series of patches from Robert Baldyga cleaned up uses of
ep->driver_data as a flag for "claimed endpoint" in favor of the new
ep->claimed flag.
Sudip Mukherjee fixed a ton of really old problems on the amd5536udc
driver. That should make a few people happy.
Heikki Krogerus worked on converting dwc3 to the unified device property
interface.
Together with these, there's a ton of non-critical fixes, typos and
stuff like that.
Add support for the optional 'phy-clkgate-delay-us' property that is
used to describe the delay time between putting PHY into low power mode
and turning off the PHY clock.
Signed-off-by: Li Jun <jun.li@freescale.com>
On recent Qualcomm platforms VBUS and ID lines are not routed to
USB PHY LINK controller. Use extcon framework to receive connect
and disconnect ID and VBUS notification.
Signed-off-by: Ivan T. Ivanov <ivan.ivanov@linaro.org>
drivers/net/usb/asix_common.c
net/ipv4/inet_connection_sock.c
net/switchdev/switchdev.c
In the inet_connection_sock.c case the request socket hashing scheme
is completely different in net-next.
The other two conflicts were overlapping changes.
To simplify the configfs interface and remove boilerplate code that also
causes binary bloat.
Reviewed-by: Andrzej Pietrasiewicz <andrzej.p@samsung.com>
Acked-by: Felipe Balbi <balbi@ti.com>
This patch fixes the following warning if 64-bit architecture environment:
./drivers/usb/renesas_usbhs/common.c:496:25: warning: cast from pointer to integer of different size [-Wpointer-to-int-cast]
dparam->type = of_id ? (u32)of_id->data : 0;
Hosts that support USB 3.1 Enhaned SuperSpeed can set their speed to
HCD_USB31 to let usb core and host drivers know that the controller
supports new USB 3.1 features.
make sure usb core handle HCD_USB31 hosts correctly, for now similar
to HCD_USB3.
Signed-off-by: Mathias Nyman <mathias.nyman@linux.intel.com>
Acked-by: Geert Uytterhoeven <geert+renesas@glider.be>
By using the unified device property interface, the function
can be made available for all platforms and not just the
ones using DT.
Signed-off-by: Heikki Krogerus <heikki.krogerus@linux.intel.com>
ones using DT.
- Replace all "transceiver" with "phy"
- Replace one "OTG controller" with "phy"
This patch introduces 'enabled' flag in struct usb_ep, and modifies
usb_ep_enable() and usb_ep_disable() functions to encapsulate endpoint
enabled/disabled state. It helps to avoid enabling endpoints which are
already enabled, and disabling endpoints which are already disables.
From now USB functions don't have to remember current endpoint
enable/disable state, as this state is now handled automatically which
makes this API less bug-prone.
Signed-off-by: Robert Baldyga <r.baldyga@samsung.com>
This patch introduces usb_ep_autoconfig_release() function which allows
to release endpoint previously obtained from usb_ep_autoconfig() during
USB function bind.
