path: root/include/linux/usb
2010-05-20USB: Add definition for the Pipe Usage descriptorMatthew Wilcox
The Pipe Usage descriptor is needed for USB Attached SCSI Signed-off-by: Matthew Wilcox <willy@linux.intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-05-20USB: export the new ch11.h file to userspceAlan Stern
This patch (as1374) cleans up a few loose ends in the include/linux/usb/ch11.h header file and exports it to userspace. Signed-off-by: Alan Stern <stern@rowland.harvard.edu> Cc: Eric Lescouet <Eric.Lescouet@virtuallogix.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-05-20USB: Composite framework: Add suspended sysfs entryFabien Chouteau
This patch adds a sysfs entry (/sys/devices/platform/_UDC_/gadget/suspended) to show the suspend state of an USB composite gadget. Signed-off-by: Fabien Chouteau <fabien.chouteau@barco.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-05-20USB: ncm: added ncm.h with auxiliary definitionsYauheni Kaliuta
Signed-off-by: Yauheni Kaliuta <yauheni.kaliuta@nokia.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-05-20usb: cdc: ncm constants and structures addedYauheni Kaliuta
2010-05-20USB: Support for allocating USB 3.0 streams.Sarah Sharp
Bulk endpoint streams were added in the USB 3.0 specification. Streams allow a device driver to overload a bulk endpoint so that multiple transfers can be queued at once. The device then decides which transfer it wants to work on first, and can queue part of a transfer before it switches to a new stream. All this switching is invisible to the device driver, which just gets a completion for the URB. Drivers that use streams must be able to handle URBs completing in a different order than they were submitted to the endpoint. This requires adding new API to set up xHCI data structures to support multiple queues ("stream rings") per endpoint. Drivers will allocate a number of stream IDs before enqueueing URBs to the bulk endpoints of the device, and free the stream IDs in their disconnect function. See Documentation/usb/bulk-streams.txt for details. The new mass storage device class, USB Attached SCSI Protocol (UASP), uses these streams API. Signed-off-by: Sarah Sharp <sarah.a.sharp@linux.intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-05-20USB: Add parsing of SuperSpeed endpoint companion descriptor.Sarah Sharp
Allow the xHCI drivers (and any new USB 3.0 drivers) to parse the SuperSpeed endpoint companion descriptor to find the maximum number of bulk endpoint streams the endpoint supports. This is used to calculate the maximum total number of streams the driver can allocate. Signed-off-by: Sarah Sharp <sarah.a.sharp@linux.intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-05-20usb: otg: add global ULPI register definitionsHeikki Krogerus
Definitions for registers defined by ULPI specification v1.1. Signed-off-by: Heikki Krogerus <ext-heikki.krogerus@nokia.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-05-20USB: gadget: add HID gadget driverFabien Chouteau
g_hid is a USB gadget driver implementing the Human Interface Device class specification. The driver handles basic HID protocol handling in the kernel, and allows userspace to read/write HID reports trough /dev/hidgX character devices. Signed-off-by: Fabien Chouteau <fabien.chouteau@barco.com> Signed-off-by: Peter Korsgaard <peter.korsgaard@barco.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-05-20USB: serial: generalise write buffer preparationJohan Hovold
Generalise write buffer preparation. This allows for drivers to manipulate (e.g. add headers) to bulk out data before it is sent. This adds a new function pointer to usb_serial_driver: int (*prepare_write_buffer)(struct usb_serial_port *port, void **dest, size_t size, const void *src, size_t count); The function is generic and can be used with either kfifo-based or multi-urb writes: If *dest is NULL the implementation should allocate dest. If src is NULL the implementation should use the port write fifo. If not set, a generic implementation is used which simply uses memcpy or kfifo_out. Signed-off-by: Johan Hovold <jhovold@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-05-20USB: serial: re-implement multi-urb writes in generic driverJohan Hovold
Use dynamic transfer buffer sizes since it is more efficient to let the host controller do the partitioning to fit endpoint size. This way we also do not use more than one urb per write request. Replace max_in_flight_urbs with multi_urb_write flag in struct usb_serial_driver to enable multi-urb writes. Use MAX_TX_URBS=40 and a max buffer size of PAGE_SIZE to prevent DoS attacks. Signed-off-by: Johan Hovold <jhovold@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-05-20USB: serial: generalise generic read implementationJohan Hovold
Add process_read_urb to usb_serial_driver so that a driver can rely on the generic read (and throttle) mechanism but still do device specific processing of incoming data (such as adding tty_flags before pushing to line discipline). The default generic implementation handles sysrq for consoles but otherwise simply pushes to tty. Signed-off-by: Johan Hovold <jhovold@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-05-20USB: serial: refactor read urb submission in generic driverJohan Hovold
Use the already exported function for submitting the read urb associated with a usb_serial_port. Make sure it returns the result of usb_submit_urb and rename to the more descriptive usb_serial_generic_submit_read_urb. Signed-off-by: Johan Hovold <jhovold@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-05-20USB: serial: allow drivers to define bulk buffer sizesJohan Hovold
Allow drivers to define custom bulk in/out buffer sizes in struct usb_serial_driver. If not set, fall back to the default buffer size which matches the endpoint size. Three drivers are currently freeing the pre-allocated buffers and allocating larger ones to achieve this at port probe (ftdi_sio) or even at port open (ipaq and iuu_phoenix), which needless to say is suboptimal. Signed-off-by: Johan Hovold <jhovold@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-05-20USB: Add a new quirk: USB_QUIRK_HONOR_BNUMINTERFACESHans de Goede
Add a new quirk USB_QUIRK_HONOR_BNUMINTERFACES, when this quirk is set and a device has more interface descriptors in a configuration then it claims to have in config->bNumInterfaces, ignore all additional interfaces. This is needed for devices which try to hide unused interfaces by only lowering config->bNumInterfaces, and which can't handle if you try to talk to the "hidden" interfaces. Signed-off-by: Hans de Goede <hdegoede@redhat.com> Acked-by: Alan Stern <stern@rowland.harvard.edu> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-05-20USB: musb: allow the Blackfin vrsel gpio to be active lowCliff Cai
Rather than hardcoding the gpio levels for vrsel, allow the platform resources to handle this so boards can be active high or low. Signed-off-by: Cliff Cai <cliff.cai@analog.com> Signed-off-by: Mike Frysinger <vapier@gentoo.org> Signed-off-by: Felipe Balbi <felipe.balbi@nokia.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-05-20usb: musb: allow board to pass down fifo modeFelipe Balbi
boards might want to optimize their fifo configuration to the particular needs of that specific board. Allow that by moving all related data structures to <linux/usb/musb.h> Signed-off-by: Felipe Balbi <felipe.balbi@nokia.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-05-20usb-serial: Use tty_port version console instead of usb_serial_portJason Wessel
Replace all instances of using the console variable in struct usb_serial_port with the struct tty_port version. CC: Alan Cox <alan@linux.intel.com> CC: Alan Stern <stern@rowland.harvard.edu> CC: Oliver Neukum <oliver@neukum.org> CC: Andrew Morton <akpm@linux-foundation.org> CC: linux-usb@vger.kernel.org CC: linux-kernel@vger.kernel.org Signed-off-by: Jason Wessel <jason.wessel@windriver.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-05-20USB: remove bogus USB_PORT_FEAT_*_SPEED symbolsAlan Stern
This patch (as1348) removes the bogus USB_PORT_FEAT_{HIGHSPEED,SUPERSPEED} symbols from ch11.h. No such features are defined by the USB spec. (There is a PORT_LOWSPEED feature, but the spec doesn't mention it except to say that host software should never use it.) The speed indicators are port statuses, not port features. As a temporary workaround for the xhci-hcd driver, a fictional USB_PORT_STAT_SUPER_SPEED symbol is added. Signed-off-by: Alan Stern <stern@rowland.harvard.edu> CC: Sarah Sharp <sarah.a.sharp@linux.intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-05-20USB: split hub.h into ch11.h and merge-in hcd.hEric Lescouet
Base on inputs from Alan Stern, split the hub.h header into: - new ch11.h header (most of it) containing constants and structures from chapter 11 of the USB 2.0 spec. - a small remaining part being merged into hcd.h. Signed-of-by: Eric Lescouet <eric@lescouet.org> Cc: Alan Stern <stern@rowland.harvard.edu> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-05-20USB: make hub.h public (drivers dependency)Eric Lescouet
The usbcore headers: hcd.h and hub.h are shared between usbcore, HCDs and a couple of other drivers (e.g. USBIP modules). So, it makes sense to move them into a more public location and to cleanup dependency of those modules on kernel internal headers. This patch moves hub.h from drivers/usb/core into include/linux/usb/ Signed-of-by: Eric Lescouet <eric@lescouet.org> Cc: Alan Stern <stern@rowland.harvard.edu> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-05-20USB: make hcd.h public (drivers dependency)Eric Lescouet
The usbcore headers: hcd.h and hub.h are shared between usbcore, HCDs and a couple of other drivers (e.g. USBIP modules). So, it makes sense to move them into a more public location and to cleanup dependency of those modules on kernel internal headers. This patch moves hcd.h from drivers/usb/core into include/linux/usb/ Signed-of-by: Eric Lescouet <eric@lescouet.org> Cc: Alan Stern <stern@rowland.harvard.edu> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2010-03-08Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound-2.6: (26 commits) ALSA: hdmi - show debug message on changing audio infoframe ALSA: hdmi - merge common code for intelhdmi and nvhdmi ALSA: hda - Add ASRock mobo to MSI blacklist ALSA: hda: uninitialized variable fix ALSA: hda: Use LPIB for a Biostar Microtech board ALSA: usb/audio.h: Fix field order ALSA: fix jazz16 compile (udelay) ALSA: hda: Use LPIB for Dell Latitude 131L ALSA: hda - Build hda_eld into snd-hda-codec module ALSA: hda - Support NVIDIA MCP89 and GT21x hdmi audio ALSA: hda - Support max codecs to 8 for nvidia hda controller ALSA: riptide: clean up while loop ALSA: usbaudio - remove debug "SAMPLE BYTES" printk line ALSA: timer - pass real event in snd_timer_notify1() to instance callback ALSA: oxygen: change || to && ALSA: opti92x: use PnP data to select Master Control port ASoC: fix ak4104 register array access ASoC: soc_pcm_open: Add missing bailout tag ALSA: usbaudio: Fix wrong bitrate for Creative Creative VF0470 Live Cam ALSA: ua101: removing debugging code ...
2010-03-05ALSA: usb/audio.h: Fix field orderDaniel Mack
Signed-off-by: Daniel Mack <daniel@caiaq.de> Cc: Clemens Ladisch <clemens@ladisch.de> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2010-03-03Merge git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb-2.6: (220 commits) USB: backlight, appledisplay: fix incomplete registration failure handling USB: pl2303: remove unnecessary reset of usb_device in urbs USB: ftdi_sio: remove obsolete check in unthrottle USB: ftdi_sio: remove unused tx_bytes counter USB: qcaux: driver for auxiliary serial ports on Qualcomm devices USB: pl2303: initial TIOCGSERIAL support USB: option: add Longcheer/Longsung vendor ID USB: fix I2C API usage in ohci-pnx4008. USB: usbmon: mask seconds properly in text API USB: sisusbvga: no unnecessary GFP_ATOMIC USB: storage: onetouch: unnecessary GFP_ATOMIC USB: serial: ftdi: add CONTEC vendor and product id USB: remove references to port->port.count from the serial drivers USB: tty: Prune uses of tty_request_room in the USB layer USB: tty: Add a function to insert a string of characters with the same flag USB: don't read past config->interface[] if usb_control_msg() fails in usb_reset_configuration() USB: tty: kill request_room for USB ACM class USB: tty: sort out the request_room handling for whiteheat USB: storage: fix misplaced parenthesis USB: vstusb.c: removal of driver for Vernier Software & Technology, Inc., devices and spectrometers ...
2010-03-02USB: vstusb.c: removal of driver for Vernier Software & Technology, Inc., ↵Dennis O'Brien
devices and spectrometers This patch removes the vstusb driver and support from the Linux tree. This driver provided support for Vernier Software & Technology devices and spectrometers (Ocean Optics). This driver is being replaced by a user space - libusb - implementation. Signed-off-by: Jim Collar <jim.collar@eqware.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-03-02USB: Extend and neaten dbg macrosJoe Perches
Add format/argument validation for #ifndef DEBUG dbg macro Neaten dbg macro definitions Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-03-02USB: atmel uaba: Adding invert vbus_pinEirik Aanonsen
Adding vbus_pin_inverted so that the usb detect pin can be active high or low depending on HW implementation also replaced the gpio_get_value(udc->vbus_pin); with a call to vbus_is_present(udc); This allows the driver to be loaded and save about 0,15W on the consumption. Signed-off-by: Eirik Aanonsen <eaa@wprmedical.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-03-02USB: musb: deprecate what we don't useFelipe Balbi
after 2.6.34, those fields will be removed from struct musb_hdrc_platform_data, it's expected that other architectures are fixed by then. Signed-off-by: Felipe Balbi <felipe.balbi@nokia.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-03-02usb: musb: Add 'extvbus' in musb_hdrc_platform_dataAjay Kumar Gupta
Some of the board might use external Vbus power supply on musb interface which would require to program ULPI_BUSCONTROL register. Adding 'extvbus' flag which can be set from such boards which will be checked at musb driver files before programming ULPI_BUSCONTROL. Signed-off-by: Ajay Kumar Gupta <ajay.gupta@ti.com> Signed-off-by: Felipe Balbi <felipe.balbi@nokia.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-03-02USB: rename USB_SPEED_VARIABLE to USB_SPEED_WIRELESSGreg Kroah-Hartman
It's really the wireless speed, so rename the thing to make more sense. Based on a recommendation from David Vrabel Cc: David Vrabel <david.vrabel@csr.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-03-02USB: storage: Never reset devices that will morph to an old modeOliver Neukum
Some devices must be switched to a new mode to fully use them. A reset would make them revert to the old mode. Therefore a reset must not be used for error handling with such devices. Signed-off-by: Oliver Neukum <oliver@neukum.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-03-02USB: otg: add notifier supportFelipe Balbi
The notifier will be used to communicate usb events to other drivers like the charger chip. This can be used as source of information to kick usb charger detection as described by the USB Battery Charging Specification 1.1 and/or to pass bMaxPower field of selected usb_configuration to charger chip in order to use that information as input current on the charging profile setup. Signed-off-by: Felipe Balbi <felipe.balbi@nokia.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-03-02Merge branch 'omap-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tmlind/linux-omap-2.6 * 'omap-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tmlind/linux-omap-2.6: (214 commits) omap2: Initialize Menelaus and MMC for N8X0 AM3517 EVM: correct typo - tca6416 mispelt as tca6516 AM3517 EVM: Enable I2C support AM35x: Enable OMAP_MUX in defconfig AM35x: Add missing GPIO mux config for EHCI port Zoom3: Defconfig update omap: i2c: Fix muxing for command line enabled bus OMAP4: clock: Remove clock hacks from timer-gp.c OMAP4: clock: Add dummy clock nodes for interface clocks OMAP4: clock: Rename leaf clock nodes to end with a _ick or _fck OMAP2+ clock: revise omap2_clk_{disable,enable}() OMAP2/3 clock: combine OMAP2 & 3 boot-time MPU rate change code OMAP clockdomain: if no autodeps exist, don't try to add or remove them OMAP hwmod: add hwmod class support OMAP hwmod: convert header files with static allocations into C files OMAP hwmod: convert hwmod to use hardware clock names rather than clkdev dev+con OMAP clock: add omap_clk_get_by_name() for use by OMAP hwmod core code OMAP3: clock: add capability to change rate of dpll4_m5_ck_3630 OMAP4 clock: drop the ALWAYS_ENABLED clock flag OMAP clock: drop RATE_FIXED clock flag ...
2010-03-02Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next-2.6: (1341 commits) virtio_net: remove forgotten assignment be2net: fix tx completion polling sis190: fix cable detect via link status poll net: fix protocol sk_buff field bridge: Fix build error when IGMP_SNOOPING is not enabled bnx2x: Tx barriers and locks scm: Only support SCM_RIGHTS on unix domain sockets. vhost-net: restart tx poll on sk_sndbuf full vhost: fix get_user_pages_fast error handling vhost: initialize log eventfd context pointer vhost: logging thinko fix wireless: convert to use netdev_for_each_mc_addr ethtool: do not set some flags, if others failed ipoib: returned back addrlen check for mc addresses netlink: Adding inode field to /proc/net/netlink axnet_cs: add new id bridge: Make IGMP snooping depend upon BRIDGE. bridge: Add multicast count/interval sysfs entries bridge: Add hash elasticity/max sysfs entries bridge: Add multicast_snooping sysfs toggle ... Trivial conflicts in Documentation/feature-removal-schedule.txt
2010-03-01Merge with mainline to remove plat-omap/Kconfig conflictTony Lindgren
Conflicts: arch/arm/plat-omap/Kconfig
2010-02-23ALSA: usbaudio: consolidate header filesDaniel Mack
Use the definitions from linux/usb/audio.h all over the ALSA USB audio driver and add some missing definitions there as well. Use the endpoint attribute macros from linux/usb/ch9 and remove the own things from sound/usb/usbaudio.h. Now things are also nicely prefixed which makes understanding the code easier. Signed-off-by: Daniel Mack <daniel@caiaq.de> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2010-02-23ALSA: usbaudio: introduce new types for audio class v2Daniel Mack
This patch adds some definitions for audio class v2. Unfortunately, the UNIT types PROCESSING_UNIT and EXTENSION_UNIT have different numerical representations in both standards, so there is need for a _V1 add-on now. usbmixer.c is changed accordingly. Signed-off-by: Daniel Mack <daniel@caiaq.de> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2010-02-23ALSA: usbaudio: parse USB descriptors with structsDaniel Mack
In preparation of support for v2.0 audio class, use the structs from linux/usb/audio.h and add some new ones to describe the fields that are actually parsed by the descriptor decoders. Also, factor out code from usb_create_streams(). This makes it easier to adopt the new iteration logic needed for v2.0. Signed-off-by: Daniel Mack <daniel@caiaq.de> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2010-02-19omap: musb: Pass board specific data from board fileMaulik Mankad
Pass board specific data for MUSB (like interface_type, mode etc) from board file by defining board specific structure. Each board file can define this structure based on its requirement and pass this information to the driver. Signed-off-by: Maulik Mankad <x0082077@ti.com> Cc: Tony Lindgren <tony@atomide.com> Cc: Felipe Balbi <felipe.balbi@nokia.com> Cc: David Brownell <david-b@pacbell.net> Cc: Greg Kroah-Hartman <gregkh@suse.de> Cc: Gupta Ajay Kumar <ajay.gupta@ti.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
2010-02-19USB: Add empty functions in otg.hMaulik Mankad
Add empty functions for usb_nop_xceiv_register() and usb_nop_xceiv_unregister() in otg.h so that these functions can be called even when CONFIG_NOP_USB_XCEIV is not enabled. It allows to remove ifdef's from board file. Signed-off-by: Maulik Mankad <x0082077@ti.com> Cc: Sergei Shtylyov <sshtylyov@ru.mvista.com> Cc: Ajay Kumar Gupta <ajay.gupta@ti.com> Acked-by: Olof Johansson <olof@lixom.net> Acked-by: Felipe Balbi <felipe.balbi@nokia.com> Acked-by: Greg Kroah-Hartman <gregkh@suse.de> Signed-off-by: Tony Lindgren <tony@atomide.com>
2010-02-17usbnet: Convert dev(dbg|err|warn|info) macros to netdev_<level>Joe Perches
These macros are too similar to the dev_<level> equivalents but take a usbnet * argument. Convert them to the recently introduced netdev_<level> macros and remove the old macros. The old macros had "\n" appended to the format string. Add the "\n" to the converted uses. Some existing uses of the dev<foo> macros in cdc_eem.c probably mistakenly had trailing "\n". No "\n" added there. Fix net1080 this/other log message inversion. Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-12-23Fix usb_serial_probe() problem introduced by the recent kfifo changesStefani Seibold
The USB serial code was a new user of the kfifo API, and it was missed when porting things to the new kfifo API. Please make the write_fifo in place. Here is my patch to fix the regression and full ported version. Signed-off-by: Stefani Seibold <stefani@seibold.net> Reported-and-tested-by: Rafael J. Wysocki <rjw@sisk.pl> Cc: Greg KH <greg@kroah.com> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Alan Stern <stern@rowland.harvard.edu> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-12-11Merge git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/tty-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/tty-2.6: (58 commits) tty: split the lock up a bit further tty: Move the leader test in disassociate tty: Push the bkl down a bit in the hangup code tty: Push the lock down further into the ldisc code tty: push the BKL down into the handlers a bit tty: moxa: split open lock tty: moxa: Kill the use of lock_kernel tty: moxa: Fix modem op locking tty: moxa: Kill off the throttle method tty: moxa: Locking clean up tty: moxa: rework the locking a bit tty: moxa: Use more tty_port ops tty: isicom: fix deadlock on shutdown tty: mxser: Use the new locking rules to fix setserial properly tty: mxser: use the tty_port_open method tty: isicom: sort out the board init logic tty: isicom: switch to the new tty_port_open helper tty: tty_port: Add a kref object to the tty port tty: istallion: tty port open/close methods tty: stallion: Convert to the tty_port_open/close methods ...
2009-12-11usb_serial: Kill port mutexAlan Cox
The tty port has a port mutex used for all the port related locking so we don't need the one in the USB serial layer any more. Signed-off-by: Alan Cox <alan@linux.intel.com> Cc: Alan Stern <stern@rowland.harvard.edu> Cc: Oliver Neukum <oliver@neukum.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-12-11USB OTG: Add generic driver for ULPI OTG transceiverDaniel Mack
This adds a minimal generic driver for ULPI connected transceivers, using the OTG framework functions recently introduced. The driver got a table to match the ULPI chips, which currently only has one entry for NXP's ISP 1504 transceiver. Signed-off-by: Daniel Mack <daniel@caiaq.de> Cc: Heikki Krogerus <ext-heikki.krogerus@nokia.com> Cc: David Brownell <dbrownell@users.sourceforge.net> Cc: Sascha Hauer <s.hauer@pengutronix.de> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-12-11USB OTG: add support for ulpi connected external transceiversDaniel Mack
This adds support for OTG transceivers directly connected to the ULPI interface. In particular, the following details are added - a struct for low level io functions (read/write) - a priv field to be used as 'viewport' by low level access functions - an (*init) and (*shutdown) callbacks, along with static inline helpers - a (*set_vbus) callback to switch the port power on and off - a flags field for per-transceiver settings - some defines for the flags bitmask to configure platform specific details Signed-off-by: Daniel Mack <daniel@caiaq.de> Cc: Heikki Krogerus <ext-heikki.krogerus@nokia.com> Cc: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-12-11USB gadget: Handle endpoint requests at the function levelLaurent Pinchart
Control requests targeted at an endpoint (that is sent to EP0 but specifying the target endpoint address in wIndex) are dispatched to the current configuration's setup callback, requiring all gadget drivers to dispatch the requests to the correct function driver. To avoid this, record which endpoints are used by each function in the composite driver SET CONFIGURATION handler and dispatch requests targeted at endpoints to the correct function. Signed-off-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com> Cc: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-12-09Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (42 commits) tree-wide: fix misspelling of "definition" in comments reiserfs: fix misspelling of "journaled" doc: Fix a typo in slub.txt. inotify: remove superfluous return code check hdlc: spelling fix in find_pvc() comment doc: fix regulator docs cut-and-pasteism mtd: Fix comment in Kconfig doc: Fix IRQ chip docs tree-wide: fix assorted typos all over the place drivers/ata/libata-sff.c: comment spelling fixes fix typos/grammos in Documentation/edac.txt sysctl: add missing comments fs/debugfs/inode.c: fix comment typos sgivwfb: Make use of ARRAY_SIZE. sky2: fix sky2_link_down copy/paste comment error tree-wide: fix typos "couter" -> "counter" tree-wide: fix typos "offest" -> "offset" fix kerneldoc for set_irq_msi() spidev: fix double "of of" in comment comment typo fix: sybsystem -> subsystem ...
