path: root/include/linux/usb/hcd.h
2011-02-16merge: USB: remove duplicated usb_hcd_map_urb_for_dmaDan Willemsen
The original commit went upstream, this is to fix a merge issue from a slightly different version coming back. Change-Id: I69a58a483e58a0ee1a13521a466709f5cad6505f Reviewed-on: http://git-master/r/19663 Reviewed-by: Daniel Willemsen <dwillemsen@nvidia.com> Tested-by: Daniel Willemsen <dwillemsen@nvidia.com> Reviewed-by: Robert Morell <rmorell@nvidia.com> Reviewed-by: Bharat Nihalani <bnihalani@nvidia.com> Reviewed-by: Nitin Kumbhar <nkumbhar@nvidia.com>
2011-02-14merging android-tegra-2.6.36 into git-master/linux-2.6/android-tegra-2.6.36Nitin Kumbhar
Conflicts: drivers/usb/host/ehci-tegra.c include/linux/usb.h include/linux/usb/hcd.h Change-Id: I2499459b717e36a2a994af9d7a5ae1ecb5e7ca9c
2011-02-08USB: HCD: Add driver hooks for (un)?map_urb_for_dmaRobert Morell
Provide optional hooks for the host controller driver to override the default DMA mapping and unmapping routines. In general, these shouldn't be necessary unless the host controller has special DMA requirements, such as alignment contraints. If these are not specified, the general usb_hcd_(un)?map_urb_for_dma functions will be used instead. Also, pass the status to unmap_urb_for_dma so it can know whether the DMA buffer has been overwritten. Finally, add a flag to be used by these implementations if they allocated a temporary buffer so it can be freed properly when unmapping. Signed-off-by: Robert Morell <rmorell@nvidia.com> Acked-by: Alan Stern <stern@rowland.harvard.edu> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-02-08USB: HCD: Add usb_hcd prefix to exported functionsRobert Morell
The convention is to prefix symbols exported from the USB HCD core with "usb_hcd". This change makes unmap_urb_setup_for_dma() and unmap_urb_for_dma() consistent with that. Signed-off-by: Robert Morell <rmorell@nvidia.com> Acked-by: Alan Stern <stern@rowland.harvard.edu> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-12-16USB: Add driver hooks for (un)?map_urb_for_dmaRobert Morell
These are useful in case your device has quirks involving what memory is and is not DMAable. Signed-off-by: Robert Morell <rmorell@nvidia.com> Change-Id: I60b48ef8efd9f7f78eaba70d708d25b231f23d82 Reviewed-on: http://git-master/r/13381 Reviewed-by: Scott Williams <scwilliams@nvidia.com> Reviewed-by: Janne Hellsten <jhellsten@nvidia.com>
2010-08-10USB: fix race between root-hub wakeup & controller suspendAlan Stern
This patch (as1395) adds code to hcd_pci_suspend() for handling wakeup races. This is another general race pattern, similar to the "open vs. unregister" race we're all familiar with. Here, the race is between suspending a device and receiving a wakeup request from one of the device's suspended children. In particular, if a root-hub wakeup is requested at about the same time as the corresponding USB controller is suspended, and if the controller is enabled for wakeup, then the controller should either fail to suspend or else wake right back up again. During system sleep this won't happen very much, especially since host controllers generally aren't enabled for wakeup during sleep. However it is definitely an issue for runtime PM. Something like this will be needed to prevent the controller from autosuspending while waiting for a root-hub resume to take place. (That is, in fact, the common case, for which there is an extra test.) Signed-off-by: Alan Stern <stern@rowland.harvard.edu> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-08-10USB: add do_wakeup parameter for PCI HCD suspendAlan Stern
This patch (as1385) adds a "do_wakeup" parameter to the pci_suspend method used by PCI-based host controller drivers. ehci-hcd in particular needs to know whether or not to enable wakeup when suspending a controller. Although that information is currently available through device_may_wakeup(), when support is added for runtime suspend this will no longer be true. Signed-off-by: Alan Stern <stern@rowland.harvard.edu> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-08-10USB: convert usb_hcd bitfields into atomic flagsAlan Stern
This patch (as1393) converts several of the single-bit fields in struct usb_hcd to atomic flags. This is for safety's sake; not all CPUs can update bitfield values atomically, and these flags are used in multiple contexts. The flag fields that are set only during registration or removal can remain as they are, since non-atomic accesses at those times will not cause any problems. (Strictly speaking, the authorized_default flag should become atomic as well. I didn't bother with it because it gets changed only via sysfs. It can be done later, if anyone wants.) Signed-off-by: Alan Stern <stern@rowland.harvard.edu> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-08-10USB: EHCI: EHCI 1.1 addendum: Basic LPM feature supportAlek Du
With this patch, the LPM capable EHCI host controller can put device into L1 sleep state which is a mode that can enter/exit quickly, and reduce power consumption. Signed-off-by: Jacob Pan <jacob.jun.pan@intel.com> Signed-off-by: Alek Du <alek.du@intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-08-10USB: don't stop root-hub status polls too soonAlan Stern
This patch (as1390) fixes a problem that crops up when a UHCI host controller is unbound from uhci-hcd while there are still some active URBs. The URBs have to be unlinked when the root hub is unregistered, and uhci-hcd relies upon root-hub status polls as part of its unlinking procedure. But usb_hcd_poll_rh_status() won't make those status calls if hcd->rh_registered is clear, and the flag is cleared _before_ the unregistration takes place. Since hcd->rh_registered is used for other things and needs to be cleared early, the solution is to add a new flag (rh_pollable) and use it instead. It gets cleared _after_ the root hub is unregistered. Now that the status polls don't end too soon, we have to make sure they also don't occur too late -- after the root hub's usb_device structure or the HCD's private structures are deallocated. Therefore the patch adds usb_get_device() and usb_put_device() calls to protect the root hub structure, and it adds an extra del_timer_sync() to prevent the root-hub timer from causing an unexpected status poll. This additional complexity would not be needed if the HCD framework had provided separate stop() and release() callbacks instead of just stop(). This lack could be fixed at some future time (although it would require changes to every host controller driver); when that happens this patch won't be needed any more. Signed-off-by: Alan Stern <stern@rowland.harvard.edu> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-05-20USB: include/usb/*.h checkpatch cleanupGreg Kroah-Hartman
Lots of minor formatting cleanups in includes/usb/ to make checkpatch happier. Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-05-20USB: Support for allocating USB 3.0 streams.Sarah Sharp
Bulk endpoint streams were added in the USB 3.0 specification. Streams allow a device driver to overload a bulk endpoint so that multiple transfers can be queued at once. The device then decides which transfer it wants to work on first, and can queue part of a transfer before it switches to a new stream. All this switching is invisible to the device driver, which just gets a completion for the URB. Drivers that use streams must be able to handle URBs completing in a different order than they were submitted to the endpoint. This requires adding new API to set up xHCI data structures to support multiple queues ("stream rings") per endpoint. Drivers will allocate a number of stream IDs before enqueueing URBs to the bulk endpoints of the device, and free the stream IDs in their disconnect function. See Documentation/usb/bulk-streams.txt for details. The new mass storage device class, USB Attached SCSI Protocol (UASP), uses these streams API. Signed-off-by: Sarah Sharp <sarah.a.sharp@linux.intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-05-20USB: split hub.h into ch11.h and merge-in hcd.hEric Lescouet
Base on inputs from Alan Stern, split the hub.h header into: - new ch11.h header (most of it) containing constants and structures from chapter 11 of the USB 2.0 spec. - a small remaining part being merged into hcd.h. Signed-of-by: Eric Lescouet <eric@lescouet.org> Cc: Alan Stern <stern@rowland.harvard.edu> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-05-20USB: make hub.h public (drivers dependency)Eric Lescouet
The usbcore headers: hcd.h and hub.h are shared between usbcore, HCDs and a couple of other drivers (e.g. USBIP modules). So, it makes sense to move them into a more public location and to cleanup dependency of those modules on kernel internal headers. This patch moves hub.h from drivers/usb/core into include/linux/usb/ Signed-of-by: Eric Lescouet <eric@lescouet.org> Cc: Alan Stern <stern@rowland.harvard.edu> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-05-20USB: make hcd.h public (drivers dependency)Eric Lescouet
The usbcore headers: hcd.h and hub.h are shared between usbcore, HCDs and a couple of other drivers (e.g. USBIP modules). So, it makes sense to move them into a more public location and to cleanup dependency of those modules on kernel internal headers. This patch moves hcd.h from drivers/usb/core into include/linux/usb/ Signed-of-by: Eric Lescouet <eric@lescouet.org> Cc: Alan Stern <stern@rowland.harvard.edu> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
