path: root/include/linux/usb.h
2005-11-23[PATCH] USB: kernel-doc for linux/usb.hRandy Dunlap
Fix kernel-doc warning in linux/usb.h. Signed-off-by: Randy Dunlap <rdunlap@xenotime.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-13[PATCH] DocBook: allow to mark structure members privateMartin Waitz
Many structures contain both an internal part and one which is part of the API to other modules. With this patch it is possible to only include these public members in the kernel documentation. Signed-off-by: Martin Waitz <tali@admingilde.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-10-28[PATCH] usbcore: Fix handling of sysfs strings and other attributesAlan Stern
This patch (as592) makes a few small improvements to the way device strings are handled, and it fixes some bugs in a couple of other sysfs attribute routines. (Look at show_configuration_string() to see what I mean.) Signed-off-by: Alan Stern <stern@rowland.harvard.edu> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2005-10-28[PATCH] usbcore: Wrap lines before column 80Alan Stern
I can't stand text lines that wrap-around in my 80-column windows. This patch (as589) makes cosmetic changes to a couple of source files. Signed-off-by: Alan Stern <stern@rowland.harvard.edu> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2005-10-28[PATCH] usbcore: Improve endpoint sysfs file handlingAlan Stern
This revised patch (as587b) improves the implementation of USB endpoint sysfs files. Instead of storing a whole bunch of attributes for every single endpoint, each endpoint now gets its own kobject and they can share a static list of attributes. The number of extra fields added to struct usb_host_endpoint has been reduced from 4 to 1. The bEndpointAddress field is retained even though it is redundant (it repeats the same information as the attributes' directory name). The code avoids calling kobject_register, to prevent generating unwanted hotplug events. Signed-off-by: Alan Stern <stern@rowland.harvard.edu> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2005-10-28[PATCH] USB: add notifier functions to the USB core for devices and bussesGreg Kroah-Hartman
This should let us get rid of all of the different hooks in the USB core for when something has changed. Also, some other parts of the kernel have wanted to know this kind of information at times. Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2005-10-28[PATCH] stop exporting two functionsDavid Brownell
The way we're looking at USB suspend lately doesn't expect drivers to call usb_suspend_device() or usb_resume_device() directly; that'll be implicit when no interfaces are in use. This patch removes those APIs from visibility outside usbcore. Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> drivers/usb/core/hub.c | 12 ++++-------- drivers/usb/core/usb.h | 4 ++++ include/linux/usb.h | 5 ----- 3 files changed, 8 insertions(+), 13 deletions(-)
2005-10-28[PATCH] remove usb_suspend_device() parameterDavid Brownell
This patch removes the extra usb_suspend_device() parameter. The original reason to pass that parameter was so that this routine could suspend any active children. A previous patch removed that functionality ... leaving no reason to pass the parameter. A close analogy is pci_set_power_state, which doesn't need a pm_message_t either. On the internal code path that comes through the driver model, the parameter is now used to distinguish cases where USB devices need to "freeze" but not suspend. It also checks for an error case that's accessible through sysfs: attempting to suspend a device before its interfaces (or for hubs, ports). Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de> drivers/usb/core/hub.c | 34 +++++++++++++++++++++------------- drivers/usb/core/usb.c | 23 +++++++++++++++++++++-- drivers/usb/host/ehci-hcd.c | 2 +- drivers/usb/host/isp116x-hcd.c | 2 +- drivers/usb/host/ohci-pci.c | 2 +- include/linux/usb.h | 2 +- 6 files changed, 46 insertions(+), 19 deletions(-)
2005-10-28[PATCH] devfs: Remove the mode field from usb_class_driver as it's no longer ↵Greg Kroah-Hartman
needed Also fixes all drivers that set this field, and removes some other devfs specfic USB logic. Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de> drivers/usb/class/usblp.c | 3 +-- drivers/usb/core/file.c | 19 ++++--------------- drivers/usb/image/mdc800.c | 3 +-- drivers/usb/input/aiptek.c | 2 +- drivers/usb/input/hiddev.c | 3 +-- drivers/usb/media/dabusb.c | 3 +-- drivers/usb/misc/auerswald.c | 3 +-- drivers/usb/misc/idmouse.c | 5 ++--- drivers/usb/misc/legousbtower.c | 5 ++--- drivers/usb/misc/rio500.c | 3 +-- drivers/usb/misc/sisusbvga/sisusb.c | 5 ----- drivers/usb/misc/usblcd.c | 9 ++++----- drivers/usb/usb-skeleton.c | 3 +-- include/linux/usb.h | 7 ++----- 14 files changed, 22 insertions(+), 51 deletions(-)
2005-10-28[PATCH] USB: add endpoint information to sysfsGreg Kroah-Hartman
This patch adds endpoint information for both devices and interfaces to sysfs. Previously it was only possible to get the endpoint information from usbfs, and never possible to get any information on endpoint 0. Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de> drivers/usb/core/sysfs.c | 195 ++++++++++++++++++++++++++++++++++++++++++++++- include/linux/usb.h | 4 2 files changed, 197 insertions(+), 2 deletions(-)
2005-10-28[PATCH] gfp_t: drivers/usbAl Viro
2005-09-08[PATCH] USB: URB_ASYNC_UNLINK flag removed from the kernelAlan Stern
29 July 2005, Cambridge, MA: This afternoon Alan Stern submitted a patch to remove the URB_ASYNC_UNLINK flag from the Linux kernel. Mr. Stern explained, "This flag is a relic from an earlier, less-well-designed system. For over a year it hasn't been used for anything other than printing warning messages." An anonymous spokesman for the Linux kernel development community commented, "This is exactly the sort of thing we see happening all the time. As the kernel evolves, support for old techniques and old code can be jettisoned and replaced by newer, better approaches. Proprietary operating systems do not have the freedom or flexibility to change so quickly." Mr. Stern, a staff member at Harvard University's Rowland Institute who works on Linux only as a hobby, noted that the patch (labelled as548) did not update two files, keyspan.c and option.c, in the USB drivers' "serial" subdirectory. "Those files need more extensive changes," he remarked. "They examine the status field of several URBs at times when they're not supposed to. That will need to be fixed before the URB_ASYNC_UNLINK flag is removed." Greg Kroah-Hartman, the kernel maintainer responsible for overseeing all of Linux's USB drivers, did not respond to our inquiries or return our calls. His only comment was "Applied, thanks." Signed-off-by: Alan Stern <stern@rowland.harvard.edu> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2005-09-08[PATCH] USB: real nodes instead of usbfsKay Sievers
This patch introduces a /sys/class/usb_device/ class where every connected usb-device will show up: tree /sys/class/usb_device/ /sys/class/usb_device/ |-- usb1.1 | |-- dev | `-- device -> ../../../devices/pci0000:00/0000:00:1d.0/usb1 |-- usb2.1 | |-- dev | `-- device -> ../../../devices/pci0000:00/0000:00:1d.1/usb2 ... The presence of the "dev" file lets udev create real device nodes. kay@pim:~/src/linux-2.6> tree /dev/bus/usb/ /dev/bus/usb/ |-- 1 | `-- 1 |-- 2 | `-- 1 ... udev rule: SUBSYSTEM="usb_device", PROGRAM="/sbin/usb_device %k", NAME="%c" (echo $1 | /bin/sed 's/usb\([0-9]*\)\.\([0-9]*\)/bus\/usb\/\1\/\2/') This makes libusb pick up the real nodes instead of the mounted usbfs: export USB_DEVFS_PATH=/dev/bus/usb Background: All this makes it possible to manage usb devices with udev instead of the devfs solution. We are currently working on a pam_console/resmgr replacement driven by udev and a pam-helper. It applies ACL's to device nodes, which is required for modern desktop functionalty like "Fast User Switching" or multiple local login support. New patch with its own major. I've succesfully disabled usbfs and use real nodes only on my box. With: "export USB_DEVFS_PATH=/dev/bus/usb" libusb picks up the udev managed nodes instead of reading usbfs files. This makes udev to provide symlinks for libusb to pick up: SUBSYSTEM="usb_device", PROGRAM="/sbin/usbdevice %k", SYMLINK="%c" /sbin/usbdevice: #!/bin/sh echo $1 | /bin/sed 's/usbdev\([0-9]*\)\.\([0-9]*\)/bus\/usb\/\1\/\2/' Signed-off-by: Kay Sievers <kay.sievers@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2005-07-12[PATCH] USB: Fix kmalloc's flags type in USBOlav Kongas
Greg, This patch fixes the kmalloc() flags argument type in USB subsystem; hopefully all of its occurences. The patch was made against patch-2.6.12-git2 from Jun 20. Cleanup of flags for kmalloc() in USB subsystem. Signed-off-by: Olav Kongas <ok@artecdesign.ee> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2005-06-23[PATCH] better USB_MON dependenciesAdrian Bunk
This makes the USB_MON less confusing. Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-20[PATCH] USB: move the usb hcd code to use the new class code.gregkh@suse.de
This moves a kref into the main hcd structure, which detaches it from the class device structure. Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2005-06-03[PATCH] USB: update urb documentationRoman Kagan
On Wed, May 04, 2005 at 01:37:30PM -0700, David Brownell wrote: > On Wednesday 04 May 2005 12:19 pm, Roman Kagan wrote: > > struct urb { > > /* private, usb core and host controller only fields in the urb */ > > ... > > struct list_head urb_list; /* list pointer to all active urbs */ > > ... > > }; > > > > Is it safe to use it for driver's purposes when the driver owns the urb, > > that is, starting from the completion routine until the urb is submitted > > with usb_submit_urb()? > > Right now, it should be. Great! FWIW I've briefly tested a modified version of usbatm using the list head in struct urb instead of creating a wrapper struct, and I haven't seen any failures yet. So I tend to believe that your "should be" actually means "is" :) > > If it is, can it be guaranteed in future, e.g. > > by moving the list head into the public section of struct urb? > > In fact I'm not sure why it ever got called "private" to usbcore/hcds. > I thought the idea was that it should be like urb->status, reserved for > whoever controls the URB. OK then how about the following (essentially documentation) patch? Signed-off-by: Roman Kagan <rkagan@mail.ru> Acked-by: David Brownell <david-b@pacbell.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2005-04-18[PATCH] usb suspend updates (interface suspend)David Brownell
This is the first of a few installments of PM API updates to match the recent switch to "pm_message_t". This installment primarily affects USB device drivers (for USB interfaces), and it changes the handful of drivers which currently implement suspend methods: - <linux/usb.h> and usbcore, signature change - Some drivers only changed the signature, net effect this just shuts up "sparse -Wbitwise": * hid-core * stir4200 - Two network drivers did that, and also grew slightly more featureful suspend code ... they now properly shut down their activities. (As should stir4200...) * pegasus * usbnet Note that the Wake-On-Lan (WOL) support in pegasus doesn't yet work; looks to me like it's missing a request to turn it on, vs just configuring it. The ASIX code in usbnet also has WOL hooks that are ready to use; untested. Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de> Index: gregkh-2.6/drivers/net/irda/stir4200.c ===================================================================
