path: root/include/linux/usb.h
2009-01-27USB: add kernel-doc for wusb_dev in struct usb_deviceInaky Perez-Gonzalez
Reported by Randy Dunlap from a warning on the v2.6.29 merge window. Signed-off-by: Inaky Perez-Gonzalez <inaky@linux.intel.com> Cc: David Vrabel <david.vrabel@csr.com> Cc: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-01-07USB: remove info() macro from usb.hGreg Kroah-Hartman
USB should not be having it's own printk macros, so remove info() and use the system-wide standard of dev_info() wherever possible. No one in the tree is using the macro, so it can now be removed. Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-01-07USB: remove warn() macro from usb.hGreg Kroah-Hartman
USB should not be having it's own printk macros, so remove warn() and use the system-wide standard of dev_warn() wherever possible. In the few places that will not work out, use a basic printk(). Now that all in-tree users are gone, remove the macro. Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-01-07USB: extension of anchor API to unpoison an anchorOliver Neukum
This extension allows unpoisoning an anchor allowing drivers that resubmit URBs to reuse an anchor for methods like resume() Signed-off-by: Oliver Neukum <oneukum@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-01-07USB: mark "reject" field of struct urb as atomic_tMing Lei
It is enough to protect accesses to reject field of urb by marking it as atomic_t,also it is the only reason of existence of usb_reject_lock,so remove the lock to make code more clean. Signed-off-by: Ming Lei <tom.leiming@gmail.com> Acked-off-by: Alan Stern <stern@rowland.harvard.edu> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-01-07USB: utilize the bus notifiersAlan Stern
This patch (as1185) makes usbcore take advantage of the bus notifications sent out by the driver core. Now we can create all our device and interface attribute files before the device or interface uevent is broadcast. A side effect is that we no longer create the endpoint "pseudo" devices at the same time as a device or interface is registered -- it seems like a bad idea to try registering an endpoint before the registration of its parent is complete. So the routines for creating and removing endpoint devices have been split out and renamed, and they are called explicitly when needed. A new bitflag is used for keeping track of whether or not the interface's endpoint devices have been created, since (just as with the interface attributes) they vary with the altsetting and hence can be changed at random times. Signed-off-by: Alan Stern <stern@rowland.harvard.edu> Cc: Kay Sievers <kay.sievers@vrfy.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-01-07USB: Enhance usage of pm_message_tAlan Stern
This patch (as1177) modifies the USB core suspend and resume routines. The resume functions now will take a pm_message_t argument, so they will know what sort of resume is occurring. The new argument is also passed to the port suspend/resume and bus suspend/resume routines (although they don't use it for anything but debugging). In addition, special pm_message_t values are used for user-initiated, device-initiated (i.e., remote wakeup), and automatic suspend/resume. By testing these values, drivers can tell whether or not a particular suspend was an autosuspend. Unfortunately, they can't do the same for resumes -- not until the pm_message_t argument is also passed to the drivers' resume methods. That will require a bigger change. IMO, the whole Power Management framework should have been set up this way in the first place. Signed-off-by: Alan Stern <stern@rowland.harvard.edu> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-01-07USB: Allow usbmon as a module even if usbcore is builtinPete Zaitcev
usbmon can only be built as a module if usbcore is a module too. Trivial changes to the relevant Kconfig and Makefile (and a few trivial changes elsewhere) allow usbmon to be built as a module even if usbcore is builtin. This is verified to work in all 9 permutations (3 correctly prohibited by Kconfig, 6 build a suitable result). Signed-off-by: Paul Bolle <pebolle@tiscali.nl> Signed-off-by: Pete Zaitcev <zaitcev@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-01-07USB: Introduce usb_queue_reset() to do resets from atomic contextsInaky Perez-Gonzalez
This patch introduces a new call to be able to do a USB reset from an atomic contect. This is quite helpful in USB callbacks to handle errors (when the only thing that can be done is to do a device reset). It is done queuing a work struct that will do the actual reset. The struct is "attached" to an interface so pending requests from an interface are removed when said interface is unbound from the driver. The call flow then becomes: usb_queue_reset_device() __usb_queue_reset_device() [workqueue] usb_reset_device() usb_probe_interface() usb_cancel_queue_reset() [error path] usb_unbind_interface() usb_cancel_queue_reset() usb_driver_release_interface() usb_cancel_queue_reset() Note usb_cancel_queue_reset() needs smarts to try not to unqueue when it is actually being executed. This happens when we run the reset from the workqueue: usb_reset_device() is called and on interface unbind time, usb_cancel_queue_reset() would be called. That would deadlock on cancel_work_sync(). To avoid that, we set (before running usb_reset_device()) usb_intf->reset_running and clear it inmediately after returning. Patch is against 2.6.28-rc2 and depends on http://marc.info/?l=linux-usb&m=122581634925308&w=2 (as submitted by Alan Stern). Signed-off-by: Inaky Perez-Gonzalez <inaky@linux.intel.com> Cc: Alan Stern <stern@rowland.harvard.edu> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-01-07USB: add asynchronous autosuspend/autoresume supportAlan Stern
This patch (as1160b) adds support routines for asynchronous autosuspend and autoresume, with accompanying documentation updates. There already are several potential users of this interface, and others are likely to arise as autosuspend support becomes more widespread. Signed-off-by: Alan Stern <stern@rowland.harvard.edu> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-11-13USB: don't register endpoints for interfaces that are going awayAlan Stern
This patch (as1155) fixes a bug in usbcore. When interfaces are deleted, either because the device was disconnected or because of a configuration change, the extra attribute files and child endpoint devices may get left behind. This is because the core removes them before calling device_del(). But during device_del(), after the driver is unbound the core will reinstall altsetting 0 and recreate those extra attributes and children. The patch prevents this by adding a flag to record when the interface is in the midst of being unregistered. When the flag is set, the attribute files and child devices will not be created. Signed-off-by: Alan Stern <stern@rowland.harvard.edu> Cc: stable <stable@kernel.org> [2.6.27, 2.6.26, 2.6.25] Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-10-17USB: anchor API changes needed for btusbOliver Neukum
This extends the anchor API as btusb needs for autosuspend. Signed-off-by: Oliver Neukum <oneukum@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-10-17USB: extend poisoning to anchorsOliver Neukum
this extends the poisoning concept to anchors. This way poisoning will work with fire and forget drivers. Signed-off-by: Oliver Neukum <oneukum@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-10-17USB: kill URBs permanentlyOliver Neukum
looking at usb_kill_urb() it seems to me that it is unnecessarily lenient. In the use case of disconnect() you never want to use the URB again (for the same device) But leaving urb->reject elevated will make it easier to avoid races between read/write and disconnect. Signed-off-by: Oliver Neukum <oneukum@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-08-21USB: Defer Set-Interface for suspended devicesAlan Stern
This patch (as1128) fixes one of the problems related to the new PM infrastructure. We are not allowed to register new child devices during the middle of a system sleep transition, but unbinding a USB driver causes the core to automatically install altsetting 0 and thereby create new endpoint pseudo-devices. The patch fixes this problem (and the related problem that installing altsetting 0 will fail if the device is suspended) by deferring the Set-Interface call until some later time when it is legal and can succeed. Possible later times are: when a new driver is being probed for the interface, and when the interface is being resumed. Signed-off-by: Alan Stern <stern@rowland.harvard.edu> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-08-13USB: add missing kerneldoc line for "needs_binding"Alan Stern
This patch (as1117) adds a kerneldoc line for the "needs_binding" field in struct usb_interface. It was accidentally omitted when the field was added. Signed-off-by: Alan Stern <stern@rowland.harvard.edu> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-07-21USB: Force unbinding of drivers lacking reset_resume or other methodsAlan Stern
This patch (as1024) takes care of a FIXME issue: Drivers that don't have the necessary suspend, resume, reset_resume, pre_reset, or post_reset methods will be unbound and their interface reprobed when one of the unsupported events occurs. This is made slightly more difficult by the fact that bind operations won't work during a system sleep transition. So instead the code has to defer the operation until the transition ends. Signed-off-by: Alan Stern <stern@rowland.harvard.edu> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-07-21USB: fix usb_reset_device and usb_reset_composite_device(take 3)Ming Lei
This patch renames the existing usb_reset_device in hub.c to usb_reset_and_verify_device and renames the existing usb_reset_composite_device to usb_reset_device. Also the new usb_reset_and_verify_device does't need to be EXPORTED . The idea of the patch is that external interface driver should warn the other interfaces' driver of the same device before and after reseting the usb device. One interface driver shoud call _old_ usb_reset_composite_device instead of _old_ usb_reset_device since it can't assume the device contains only one interface. The _old_ usb_reset_composite_device is safe for single interface device also. we rename the two functions to make the change easily. This patch is under guideline from Alan Stern. Signed-off-by: Ming Lei <tom.leiming@gmail.com>
2008-07-21USB: remove interface parameter of usb_reset_composite_deviceMing Lei
From the current implementation of usb_reset_composite_device function, the iface parameter is no longer useful. This function doesn't do something special for the iface usb_interface,compared with other interfaces in the usb_device. So remove the parameter and fix the related caller. Signed-off-by: Ming Lei <tom.leiming@gmail.com> Acked-by: Alan Stern <stern@rowland.harvard.edu> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-07-21USB: implement "soft" unbindingAlan Stern
This patch (as1091) changes the way usbcore handles interface unbinding. If the interface's driver supports "soft" unbinding (a new flag in the driver structure) then in-flight URBs are not cancelled and endpoints are not disabled. Instead the driver is allowed to continue communicating with the device (although of course it should stop before its disconnect routine returns). The purpose of this change is to allow drivers to do a clean shutdown when they get unbound from a device that is still plugged in. Killing all the URBs and disabling the endpoints before calling the driver's disconnect method doesn't give the driver any control over what happens, and it can leave devices in indeterminate states. For example, when usb-storage unbinds it doesn't want to stop while in the middle of transmitting a SCSI command. The soft_unbind flag is added because in the past, a number of drivers have experienced problems related to ongoing I/O after their disconnect routine returned. Hence "soft" unbinding is made available only to drivers that claim to support it. The patch also replaces "interface_to_usbdev(intf)" with "udev" in a couple of places, a minor simplification. Signed-off-by: Alan Stern <stern@rowland.harvard.edu> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-07-21USB: handle pci_name() being constGreg Kroah-Hartman
This changes usb_create_hcd() to be able to handle the fact that pci_name() has changed to a constant string. Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-04-24wusb: add link wusb-usb deviceInaky Perez-Gonzalez
We need to tie the WUSB and USB devices; the USB stack doesn't need to know the details about the WUSB device, but needs to have a link to it. This is needed so that the notify call back for Remove Device can tie both and undo the device setup (sysfs files). We connect the devices together at the Add Device notifier callback (the wusb_dev references the usb_dev and stores it, the usb_dev references the wusb_dev and stores it); then we do create the WUSB sysfs files at the usb_dev sysfs directory. At Remove Device, we undo that (thus we need the usb_dev reference). Cross reference to functions in the WUSB substack: wusb_dev_{add,rm}_ncb(). Signed-off-by: Inaky Perez-Gonzalez <inaky@linux.intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-04-24wusb: add authenticathed bit to usb_devInaky Perez-Gonzalez
This bit indicates the system that the WUSB device has been crypto authenticated and thus can operate as normal. Signed-off-by: Inaky Perez-Gonzalez <inaky@linux.intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-04-24USB: update comments about usb driver's headerOliver Neukum
Comments here are so outdated that they are plain wrong. We cannot expect people to write correct drivers if the headers have incorrect comments. Signed-off-by: Oliver Neukum <oneukum@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-04-24USB: add extension of anchor API, usb_unlink_anchored_urbsOliver Neukum
This adds the ability to trigger asynchronous unlinks of anchored URBs. This is needed for error handling in the comntext of completion handlers, which cannot sleep. Signed-off-by: Oliver Neukum <oneukum@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-04-24USB: usb.h: reduce syslog clutter [v3]Tilman Schmidt
The the err() / info() / warn() macros in usb.h inserted __FILE__ at the beginning of the message, which expands to the complete pathname of the source file within the kernel tree, frequently taking up half of an 80 character screen line before the actual message even begins. Use the module name instead. Signed-off-by: Tilman Schmidt <tilman@imap.cc> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-04-24USB: convert usb.h struct usb_device to kernel-docRandy Dunlap
Convert struct usb_device to use kernel-doc notation. Please especially check the @filelist and @usb_classdev descriptions. Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Cc: Alan Stern <stern@rowland.harvard.edu> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-04-24USB: remove CONFIG_USB_PERSIST settingAlan Stern
This patch (as1047) removes the USB_PERSIST Kconfig option, enabling it permanently. It also prevents the power/persist attribute from being created for hub devices; there's no point in having it since USB-PERSIST is always turned on for hubs. Signed-off-by: Alan Stern <stern@rowland.harvard.edu> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-03-04USB: fix comment of struct usb_interfaceLei Ming
update the comment for the removed "driver" field and being out-of-order of @cur_altsetting and @num_altsetting. Signed-off-by: Lei Ming <tom.leiming@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-03-03docbook: fix usb source filesRandy Dunlap
Fix docbook problems in USB source files. These cause the generated docbook to be incorrect. Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-01USB: fix codingstyle issues in include/linux/usb.hGreg Kroah-Hartman
No logical code changes were made, but checkpatch.pl is much happier now. Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-02-01USB: Export suspend statisticsSarah Sharp
This patch exports two statistics to userspace: /sys/bus/usb/device/.../power/connected_duration /sys/bus/usb/device/.../power/active_duration connected_duration is the total time (in msec) that the device has been connected. active_duration is the total time the device has not been suspended. With these two statistics, tools like PowerTOP can calculate the percentage time that a device is active, i.e. not suspended or auto-suspended. Users can also use the active_duration to check if a device is actually autosuspended. Currently, they can set power/level to auto and power/autosuspend to a positive timeout, but there's no way to know from userspace if a device was actually autosuspended without looking at the dmesg output. These statistics will be useful in creating an automated userspace script to test autosuspend for USB devices. Signed-off-by: Sarah Sharp <sarah.a.sharp@intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-02-01USB: Convert from class_device to device for USB coreTony Jones
Convert from class_device to device for drivers/usb/core. Signed-off-by: Tony Jones <tonyj@suse.de> Cc: Kay Sievers <kay.sievers@vrfy.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-12-17usb.h: fix kernel-doc warningRandy Dunlap
Fix kernel-doc warning in usb.h: Warning(linux-2.6.24-rc3-git7//include/linux/usb.h:166): No description found for parameter 'sysfs_files_created' Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-11-28USB: keep track of whether interface sysfs files existAlan Stern
This patch (as1009) solves the problem of multiple registrations for USB sysfs files in a more satisfying way than the existing code. It simply adds a flag to keep track of whether or not the files have been created; that way the files can be created or removed as needed. Signed-off-by: Alan Stern <stern@rowland.harvard.edu>
2007-10-12USB: skip autosuspended devices during system resumeAlan Stern
System suspends and hibernation are supposed to be as transparent as possible. By this reasoning, if a USB device is already autosuspended before the system sleep begins then it should remain autosuspended after the system wakes up. This patch (as1001) adds a skip_sys_resume flag to the usb_device structure and uses it to avoid waking up devices which were suspended when a system sleep began. Signed-off-by: Alan Stern <stern@rowland.harvard.edu> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-10-12USB: Export URB statistics for powertopSarah Sharp
powertop currently tracks interrupts generated by uhci, ehci, and ohci, but it has no way of telling which USB device to blame USB bus activity on. This patch exports the number of URBs that are submitted for a given device. Cat the file 'urbnum' in /sys/bus/usb/devices/.../ Signed-off-by: Sarah Sharp <sarah.a.sharp@intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-10-12USB: flush outstanding URBs when suspendingAlan Stern
This patch (as989) makes usbcore flush all outstanding URBs for each device as the device is suspended. This will be true even when CONFIG_USB_SUSPEND is not enabled. In addition, an extra can_submit flag is added to the usb_device structure. That flag will be turned off whenever a suspend request has been received for the device, even if the device isn't actually suspended because CONFIG_USB_SUSPEND isn't set. It's no longer necessary to check for the device state being equal to USB_STATE_SUSPENDED during URB submission; that check can be replaced by a check of the can_submit flag. This also permits us to remove some questionable references to the deprecated power.power_state field. Signed-off-by: Alan Stern <stern@rowland.harvard.edu> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-10-12USB: get rid of urb->lockAlan Stern
Now that urb->status isn't used, urb->lock doesn't protect anything. This patch (as980) removes it and replaces it with a private mutex in the one remaining place it was still used: usb_kill_urb. Signed-off-by: Alan Stern <stern@rowland.harvard.edu> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-10-12USB: add urb->unlinked fieldAlan Stern
This patch (as970) adds a new urb->unlinked field, which is used to store the status of unlinked URBs since we can't use urb->status for that purpose any more. To help simplify the HCDs, usbcore will check urb->unlinked before calling the completion handler; if the value is set it will automatically override the status reported by the HCD. Signed-off-by: Alan Stern <stern@rowland.harvard.edu> CC: David Brownell <david-b@pacbell.net> CC: Olav Kongas <ok@artecdesign.ee> CC: Yoshihiro Shimoda <shimoda.yoshihiro@renesas.com> CC: Tony Olech <tony.olech@elandigitalsystems.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-10-12usb: introduce usb_device authorization bitsInaky Perez-Gonzalez
This just modifies 'struct usb_device' to contain the 'authorized' bit. It also adds a 'wusb' bit. This is needed because nonauthorized (and thus non-authenticated) wusb devices will fail certain kind of simple requests (such as string descriptors). By knowing the device is WUSB, we just avoid them. Signed-off-by: Inaky Perez-Gonzalez <inaky@linux.intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-10-12USB: cleanup for previous patchesAlan Stern
This patch (as951) cleans up a few loose ends from earlier patches. Redundant checks for non-NULL urb->dev are removed, as are checks of urb->dev->bus (which can never be NULL). Conversely, a check for non-NULL urb->ep is added to the unlink paths. A homegrown round-down-to-power-of-2 loop is simplified by using the ilog2 routine. The comparison in usb_urb_dir_in() is made more transparent. Signed-off-by: Alan Stern <stern@rowland.harvard.edu> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-10-12USB: avoid using urb->pipe in usbcoreAlan Stern
This patch (as946) eliminates many of the uses of urb->pipe in usbcore. Unfortunately there will have to be a significant API change, affecting all USB drivers, before we can remove it entirely. This patch contents itself with changing only the interface to usb_buffer_map_sg() and friends: The pipe argument is replaced with a direction flag. That can be done easily because those routines get used in only one place. Signed-off-by: Alan Stern <stern@rowland.harvard.edu> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-10-12USB: add direction bit to urb->transfer_flagsAlan Stern
This patch (as945) adds a bit to urb->transfer_flags for recording the direction of the URB. The bit is set/cleared automatically in usb_submit_urb() so drivers don't have to worry about it (although as a result, it isn't valid until the URB has been submitted). Inline routines are added for easily checking an URB's direction. They replace calls to usb_pipein in the DMA-mapping parts of hcd.c. For non-control endpoints, the direction is determined directly from the endpoint descriptor. However control endpoints are bi-directional; for them the direction is determined from the bRequestType byte and the wLength value in the setup packet. Signed-off-by: Alan Stern <stern@rowland.harvard.edu> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-10-12USB: add ep->enableAlan Stern
This patch (as944) adds an explicit "enabled" field to the usb_host_endpoint structure and uses it in place of the current mechanism. This is merely a time-space tradeoff; it makes checking whether URBs may be submitted to an endpoint simpler. The existing mechanism is efficient when converting urb->pipe to an endpoint pointer, but it's not so efficient when urb->ep is used instead. As a side effect, the procedure for enabling an endpoint is now a little more complicated. The ad-hoc inline code in usb.c and hub.c for enabling ep0 is now replaced with calls to usb_enable_endpoint, which is no longer static. Signed-off-by: Alan Stern <stern@rowland.harvard.edu> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-10-12USB: add urb->epAlan Stern
This patch (as943) prepares the way for eliminating urb->pipe by introducing an endpoint pointer into struct urb. For now urb->ep is set by usb_submit_urb() from the pipe value; eventually drivers will set it themselves and we will remove urb->pipe completely. The patch also adds new inline routines to retrieve an endpoint descriptor's number and transfer type, essentially as replacements for usb_pipeendpoint and usb_pipetype. usb_submit_urb(), usb_hcd_submit_urb(), and usb_hcd_unlink_urb() are converted to use the new field and new routines. Other parts of usbcore will be converted in later patches. Signed-off-by: Alan Stern <stern@rowland.harvard.edu> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-07-30USB: usb.h kernel-doc additionsRandy Dunlap
Add kernel-doc entries in <linux/usb.h> for: Warning(linux-2.6.22-git12//include/linux/usb.h:162): No description found for parameter 'intf_assoc' Warning(linux-2.6.22-git12//include/linux/usb.h:268): No description found for parameter 'intf_assoc[USB_MAXIADS]' Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-07-12USB: add IAD support to usbfs and sysfsCraig W. Nadler
USB_IAD: Adds support for USB Interface Association Descriptors. This patch adds support to the USB host stack for parsing, storing, and displaying Interface Association Descriptors. In /proc/bus/usb/devices lines starting with A: show the fields in an IAD. In sysfs if an interface on a USB device is referenced by an IAD the following files will be added to the sysfs directory for that interface: iad_bFirstInterface, iad_bInterfaceCount, iad_bFunctionClass, and iad_bFunctionSubClass, iad_bFunctionProtocol Signed-off-by: Craig W. Nadler <craig@nadler.us> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-07-12USB: Add URB_FREE_BUFFER flag and the logic behind itMarcel Holtmann
USB: Add URB_FREE_BUFFER flag for freeing the transfer buffer In some cases it is not needed that the driver keeps track of the transfer buffer of an URB. It can be simply freed along with the URB itself when the reference count goes down to zero. The new flag URB_FREE_BUFFER enables this behavior. Signed-off-by: Marcel Holtmann <marcel@holtmann.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-07-12USB: add power/persist device attributeAlan Stern
This patch (as920) adds an extra level of protection to the USB-Persist facility. Now it will apply by default only to hubs; for all other devices the user must enable it explicitly by setting the power/persist device attribute. The disconnect_all_children() routine in hub.c has been removed and its code placed inline. This is the way it was originally as part of hub_pre_reset(); the revised usage in hub_reset_resume() is sufficiently different that the code can no longer be shared. Likewise, mark_children_for_reset() is now inline as part of hub_reset_resume(). The end result looks much cleaner than before. The sysfs interface is updated to add the new attribute file, and there are corresponding documentation updates. Signed-off-by: Alan Stern <stern@rowland.harvard.edu> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
