path: root/include/linux/unwind.h
2006-06-26[PATCH] x86_64: allow unwinder to build without module supportJan Beulich
Add proper conditionals to be able to build with CONFIG_MODULES=n. Signed-off-by: Jan Beulich <jbeulich@novell.com> Signed-off-by: Andi Kleen <ak@suse.de> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-26[PATCH] i386/x86-64: fall back to old-style call trace if no unwindingJan Beulich
If no unwinding is possible at all for a certain exception instance, fall back to the old style call trace instead of not showing any trace at all. Also, allow setting the stack trace mode at the command line. Signed-off-by: Jan Beulich <jbeulich@novell.com> Signed-off-by: Andi Kleen <ak@suse.de> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-26[PATCH] x86_64: reliable stack trace supportJan Beulich
These are the generic bits needed to enable reliable stack traces based on Dwarf2-like (.eh_frame) unwind information. Subsequent patches will enable x86-64 and i386 to make use of this. Thanks to Andi Kleen and Ingo Molnar, who pointed out several possibilities for improvement. Signed-off-by: Jan Beulich <jbeulich@novell.com> Signed-off-by: Andi Kleen <ak@suse.de> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
