path: root/include/linux/tty.h
2008-04-30tty: add throttle/unthrottle helpersAlan Cox
Something Arjan suggested which allows us to clean up the code nicely Signed-off-by: Alan Cox <alan@redhat.com> Cc: Arjan van de Ven <arjan@infradead.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-30tty: The big operations reworkAlan Cox
- Operations are now a shared const function block as with most other Linux objects - Introduce wrappers for some optional functions to get consistent behaviour - Wrap put_char which used to be patched by the tty layer - Document which functions are needed/optional - Make put_char report success/fail - Cache the driver->ops pointer in the tty as tty->ops - Remove various surplus lock calls we no longer need - Remove proc_write method as noted by Alexey Dobriyan - Introduce some missing sanity checks where certain driver/ldisc combinations would oops as they didn't check needed methods were present [akpm@linux-foundation.org: fix fs/compat_ioctl.c build] [akpm@linux-foundation.org: fix isicom] [akpm@linux-foundation.org: fix arch/ia64/hp/sim/simserial.c build] [akpm@linux-foundation.org: fix kgdb] Signed-off-by: Alan Cox <alan@redhat.com> Acked-by: Greg Kroah-Hartman <gregkh@suse.de> Cc: Jason Wessel <jason.wessel@windriver.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-30tty_io: fix remaining pid struct lockingAlan Cox
This fixes the last couple of pid struct locking failures I know about. [oleg@tv-sign.ru: clean up do_task_stat()] Signed-off-by: Alan Cox <alan@redhat.com> Signed-off-by: Oleg Nesterov <oleg@tv-sign.ru> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-30redo locking of tty->pgrpAlan Cox
Historically tty->pgrp and friends were pid_t and the code "knew" they were safe. The change to pid structs opened up a few races and the removal of the BKL in places made them quite hittable. We put tty->pgrp under the ctrl_lock for the tty. Signed-off-by: Alan Cox <alan@redhat.com> Cc: Oleg Nesterov <oleg@tv-sign.ru> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-30tty: BKL pushdownAlan Cox
- Push the BKL down into the line disciplines - Switch the tty layer to unlocked_ioctl - Introduce a new ctrl_lock spin lock for the control bits - Eliminate much of the lock_kernel use in n_tty - Prepare to (but don't yet) call the drivers with the lock dropped on the paths that historically held the lock BKL now primarily protects open/close/ldisc change in the tty layer [jirislaby@gmail.com: a couple of fixes] Signed-off-by: Alan Cox <alan@redhat.com> Signed-off-by: Jiri Slaby <jirislaby@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-28[patch 1/2] audit: let userspace fully control TTY input auditingMiloslav Trmac
Remove the code that automatically disables TTY input auditing in processes that open TTYs when they have no other TTY open; this heuristic was intended to automatically handle daemons, but it has false positives (e.g. with sshd) that make it impossible to control TTY input auditing from a PAM module. With this patch, TTY input auditing is controlled from user-space only. On the other hand, not even for daemons does it make sense to audit "input" from PTY masters; this data was produced by a program writing to the PTY slave, and does not represent data entered by the user. Signed-off-by: Miloslav Trmac <mitr@redhat.com> Cc: Al Viro <viro@zeniv.linux.org.uk> Cc: David Woodhouse <dwmw2@infradead.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2008-04-28Audit: collect sessionid in netlink messagesEric Paris
Previously I added sessionid output to all audit messages where it was available but we still didn't know the sessionid of the sender of netlink messages. This patch adds that information to netlink messages so we can audit who sent netlink messages. Signed-off-by: Eric Paris <eparis@redhat.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2008-02-07tty: Kill TTY_FLIPBUF_SIZEAlan Cox
This legacy define from the old buffer code is now only used in a single power pc driver than doesn't compile anyway. Signed-off-by: Alan Cox <alan@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-06drivers/char/tty_io.c: remove pty_semDaniel Walker
I couldn't find any users, so removing it.. Signed-off-by: Daniel Walker <dwalker@mvista.com> Acked-by: Alan Cox <alan@redhat.com> Cc: "H. Peter Anvin" <hpa@zytor.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-01-28[CAN]: Allocate protocol numbers for PF_CANOliver Hartkopp
This patch adds a protocol/address family number, ARP hardware type, ethernet packet type, and a line discipline number for the SocketCAN implementation. Signed-off-by: Oliver Hartkopp <oliver.hartkopp@volkswagen.de> Signed-off-by: Urs Thuermann <urs.thuermann@volkswagen.de> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-08pl2303: Fix mode switching regressionAlan Cox
Cleaning out all the incorrect 'no change made' checks for termios settings showed up a problem with the PL2303. The hardware here seems to lose sync and bits if you tell it to make no changes. This shows up with a real world application. To fix this the driver check for meaningful hardware changes is restored but doing the tests correctly and as a tty layer function so it doesn't get duplicated wrongly everywhere if other drivers turn out to need it. Signed-off-by: Alan Cox <alan@redhat.com> Tested-by: Mirko Parthey <mirko.parthey@informatik.tu-chemnitz.de> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-11-07[TTY]: Fix network driver interactions with TCGET/SET calls.Alan Cox
Dave Miller noted various cases where line disciplines for things like ppp go poking around in termios themselves in ways that broke with the new termios code. Rather than have them all learning about termios internals provide proper methods for this - tty_mode_ioctl() This handles all the terminal mode handling for speed/carrier etc and none of the methods are ldisc dependant so they can be called by any user - tty_perform_flush() This extracts the flush functionality and enables pppd the ppp layer to share it cleanly. The existing n_tty_ioctl code is refactored in this patch to provide the new functions and to call them itself appropriately. This patch has no (intended) behaviour changes and simply prepares for the other fixes. Signed-off-by: Alan Cox <alan@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-17tty: expose new methods needed for drivers to get termios rightAlan Cox
This adds three new functions (or in one case to be more exact makes it always available) tty_termios_copy_hw Copies all the hardware settings from one termios structure to the other. This is intended for drivers that support little or no hardware setting tty_termios_encode_baud_rate Allows you to set the input and output baud rate in a termios structure. A driver is supposed to set the resulting baud rate from a request so most will want to use this function to set the resulting input and output rates to match the hardware values. Internally it knows about keeping Bxxx encoding when possible to maximise compatibility. tty_encode_baud_rate As above but for the tty's own current termios structure I suspect this will initially need some tweaking as it gets enabled by driver patches over the next few mm cycles so consider this lot -mm only for the moment so it can stabilize and end up neat before it goes to base. I've tried not to break any obscure architectures - if you get a speed you can't represent the code will print warnings on non updated termios systems but not break. Once this is merged and seems sane I've got a growing pile of driver updates to use it - notably for USB serial drivers. [akpm@linux-foundation.org: cleanups] Signed-off-by: Alan Cox <alan@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-17tty.h: remove dead defineAlan Cox
No longer used. TTY_FLIPBUF_SIZE will also go soon but needs a couple of other cleanups first Signed-off-by: Alan Cox <alan@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-12PTY: add kernel parameter to overwrite legacy pty countKay Sievers
Signed-off-by: Kay Sievers <kay.sievers@vrfy.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-08-11fix serial buffer memory leakAlan Cox
Patch c5c34d4862e18ef07c1276d233507f540fb5a532 (tty: flush flip buffer on ldisc input queue flush) introduces a race condition which can lead to memory leaks. The problem can be triggered when tcflush() is called when data are being pushed to the line discipline driver by flush_to_ldisc(). flush_to_ldisc() releases tty->buf.lock when calling the line discipline receive_buf function. At that poing tty_buffer_flush() kicks in and sets both tty->buf.head and tty->buf.tail to NULL. When flush_to_ldisc() finishes, it restores tty->buf.head but doesn't touch tty->buf.tail. This corrups the buffer queue, and the next call to tty_buffer_request_room() will allocate a new buffer and overwrite tty->buf.head. The previous buffer is then lost forever without being released. (Thanks to Laurent for the above text, for finding, disgnosing and reporting the bug) - Use tty->flags bits for the flush status. - Wait for the flag to clear again before returning - Fix the doc error noted - Fix flush of empty queue leaving stale flushpending [akpm@linux-foundation.org: cleanup] Signed-off-by: Alan Cox <alan@redhat.com> Acked-by: Paul Fulghum <paulkf@microgate.com> Cc: Laurent Pinchart <laurentp@cse-semaphore.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-16Audit: add TTY input auditingMiloslav Trmac
Add TTY input auditing, used to audit system administrator's actions. This is required by various security standards such as DCID 6/3 and PCI to provide non-repudiation of administrator's actions and to allow a review of past actions if the administrator seems to overstep their duties or if the system becomes misconfigured for unknown reasons. These requirements do not make it necessary to audit TTY output as well. Compared to an user-space keylogger, this approach records TTY input using the audit subsystem, correlated with other audit events, and it is completely transparent to the user-space application (e.g. the console ioctls still work). TTY input auditing works on a higher level than auditing all system calls within the session, which would produce an overwhelming amount of mostly useless audit events. Add an "audit_tty" attribute, inherited across fork (). Data read from TTYs by process with the attribute is sent to the audit subsystem by the kernel. The audit netlink interface is extended to allow modifying the audit_tty attribute, and to allow sending explanatory audit events from user-space (for example, a shell might send an event containing the final command, after the interactive command-line editing and history expansion is performed, which might be difficult to decipher from the TTY input alone). Because the "audit_tty" attribute is inherited across fork (), it would be set e.g. for sshd restarted within an audited session. To prevent this, the audit_tty attribute is cleared when a process with no open TTY file descriptors (e.g. after daemon startup) opens a TTY. See https://www.redhat.com/archives/linux-audit/2007-June/msg00000.html for a more detailed rationale document for an older version of this patch. [akpm@linux-foundation.org: build fix] Signed-off-by: Miloslav Trmac <mitr@redhat.com> Cc: Al Viro <viro@zeniv.linux.org.uk> Cc: Alan Cox <alan@lxorguk.ukuu.org.uk> Cc: Paul Fulghum <paulkf@microgate.com> Cc: Casey Schaufler <casey@schaufler-ca.com> Cc: Steve Grubb <sgrubb@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-16Prevent an O_NDELAY writer from blocking when a tty write is blocked by the ↵Alan Cox
tty atomic writer mutex Without this a tty write could block if a previous blocking tty write was in progress on the same tty and blocked by a line discipline or hardware event. Originally found and reported by Dave Johnson. Signed-off-by: Alan Cox <alan@redhat.com> Acked-by: Dave Johnson <djohnson+linux-kernel@sw.starentnetworks.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-08tty: introduce no_tty and use it in selinuxEric W. Biederman
While researching the tty layer pid leaks I found a weird case in selinux when we drop a controlling tty because of inadequate permissions we don't do the normal hangup processing. Which is a problem if it happens the session leader has exec'd something that can no longer access the tty. We already have code in the kernel to handle this case in the form of the TIOCNOTTY ioctl. So this patch factors out a helper function that is the essence of that ioctl and calls it from the selinux code. This removes the inconsistency in handling dropping of a controlling tty and who knows it might even make some part of user space happy because it received a SIGHUP it was expecting. In addition since this removes the last user of proc_set_tty outside of tty_io.c proc_set_tty is made static and removed from tty.h Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Acked-by: Alan Cox <alan@lxorguk.ukuu.org.uk> Cc: James Morris <jmorris@namei.org> Cc: Stephen Smalley <sds@tycho.nsa.gov> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-12[PATCH] tty: update the tty layer to work with struct pidEric W. Biederman
Of kernel subsystems that work with pids the tty layer is probably the largest consumer. But it has the nice virtue that the assiation with a session only lasts until the session leader exits. Which means that no reference counting is required. So using struct pid winds up being a simple optimization to avoid hash table lookups. In the long term the use of pid_nr also ensures that when we have multiple pid spaces mixed everything will work correctly. Signed-off-by: Eric W. Biederman <eric@maxwell.lnxi.com> Cc: Alan Cox <alan@lxorguk.ukuu.org.uk> Cc: Oleg Nesterov <oleg@tv-sign.ru> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-12[PATCH] pid: replace is_orphaned_pgrp with is_current_pgrp_orphanedEric W. Biederman
Every call to is_orphaned_pgrp passed in process_group(current) which is racy with respect to another thread changing our process group. It didn't bite us because we were dealing with integers and the worse we would get would be a stale answer. In switching the checks to use struct pid to be a little more efficient and prepare the way for pid namespaces this race became apparent. So I simplified the calls to the more specialized is_current_pgrp_orphaned so I didn't have to worry about making logic changes to avoid the race. Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Cc: Alan Cox <alan@lxorguk.ukuu.org.uk> Cc: Oleg Nesterov <oleg@tv-sign.ru> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-12[PATCH] tty: make __proc_set_tty staticEric W. Biederman
The aim of this patch set is to start wrapping up the struct pid conversions. As such this patchset culminates with the removal of kill_pg, kill_pg_info, __kill_pg_info, do_each_task_pid, and while_each_task_pid. kill_proc, daemonize, and kernel_thread are still in my sights but there is still work to get to them. The first three are basic cleanups around disassociate_ctty, while working on converting it I found several issues. tty_old_pgrp can be a tricky concept to wrap your head around. 1 tty: Make __proc_set_tty static. 2 tty: Clarify disassociate_ctty 3 tty: Fix the locking for signal->session in disassociate_ctty These just stop using the old helper functions. 4 signal: Use kill_pgrp not kill_pg in the sunos compatibility code. 5 signal: Rewrite kill_something_info so it uses newer helpers. Then the grind to convert the tty layer and all of it's helper functions to struct pid. 6 pid: Make session_of_pgrp use struct pid instead of pid_t. 7 pid: Use struct pid for talking about process groups in exit.c 8 pid: Replace is_orphaned_pgrp with is_current_pgrp_orphaned 9 tty: Update the tty layer to work with struct pid. A final helper function update. 10 pid: Replace do/while_each_task_pid with do/while_each_pid_task And the removal of the functions that are now unused. 11 pid: Remove now unused do_each_task_pid and while_each_task_pid 12 pid: Remove the now unused kill_pg kill_pg_info and __kill_pg_info All of these should be fairly simple and to the point. This patch: Currently all users of __proc_set_tty are in tty_io.c so make the function static. Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Cc: Alan Cox <alan@lxorguk.ukuu.org.uk> Cc: Oleg Nesterov <oleg@tv-sign.ru> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-11[PATCH] consolidate line discipline number definitionsTilman Schmidt
The line discipline numbers N_* are currently defined for each architecture individually, but (except for a seeming mistake) identically, in asm/termios.h. There is no obvious reason why these numbers should be architecture specific, nor any apparent relationship with the termios structure. The total number of these, NR_LDISCS, is defined in linux/tty.h anyway. So I propose the following patch which moves the definitions of the individual line disciplines to linux/tty.h too. Three of these numbers (N_MASC, N_PROFIBUS_FDL, and N_SMSBLOCK) are unused in the current kernel, but the patch still keeps the complete set in case there are plans to use them yet. Signed-off-by: Tilman Schmidt <tilman@imap.cc> Cc: <linux-arch@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-11[PATCH] vt: refactor console SAK processingEric W. Biederman
This does several things. - It moves looking up of the current foreground console into process context where we can safely take the semaphore that protects this operation. - It uses the new flavor of work queue processing. - This generates a factor of do_SAK, __do_SAK that runs immediately. - This calls __do_SAK with the console semaphore held ensuring nothing else happens to the console while we process the SAK operation. - With the console SAK processing moved into process context this patch removes the xchg operations that I used to attempt to attomically update struct pid, because of the strange locking used in the SAK processing. With SAK using the normal console semaphore nothing special is needed. Cc: Oleg Nesterov <oleg@tv-sign.ru> Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2006-12-08[PATCH] tty: switch to ktermios and new frameworkAlan Cox
This is the core of the switch to the new framework. I've split it from the driver patches which are mostly search/replace and would encourage people to give this one a good hard stare. The references to BOTHER and ISHIFT are the termios values that must be defined by a platform once it wants to turn on "new style" ioctl support. The code patches here ensure that providing 1. The termios overlays the ktermios in memory 2. The only new kernel only fields are c_ispeed/c_ospeed (or none) the existing behaviour is retained. This is true for the patches at this point in time. Future patches will define BOTHER, ISHIFT and enable newer termios structures for each architecture, and once they are all done some of the ifdefs also vanish. [akpm@osdl.org: warning fix] [akpm@osdl.org: IRDA fix] Signed-off-by: Alan Cox <alan@redhat.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-08[PATCH] tty: ->signal->tty lockingPeter Zijlstra
Fix the locking of signal->tty. Use ->sighand->siglock to protect ->signal->tty; this lock is already used by most other members of ->signal/->sighand. And unless we are 'current' or the tasklist_lock is held we need ->siglock to access ->signal anyway. (NOTE: sys_unshare() is broken wrt ->sighand locking rules) Note that tty_mutex is held over tty destruction, so while holding tty_mutex any tty pointer remains valid. Otherwise the lifetime of ttys are governed by their open file handles. This leaves some holes for tty access from signal->tty (or any other non file related tty access). It solves the tty SLAB scribbles we were seeing. (NOTE: the change from group_send_sig_info to __group_send_sig_info needs to be examined by someone familiar with the security framework, I think it is safe given the SEND_SIG_PRIV from other __group_send_sig_info invocations) [schwidefsky@de.ibm.com: 3270 fix] [akpm@osdl.org: various post-viro fixes] Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Acked-by: Alan Cox <alan@redhat.com> Cc: Oleg Nesterov <oleg@tv-sign.ru> Cc: Prarit Bhargava <prarit@redhat.com> Cc: Chris Wright <chrisw@sous-sol.org> Cc: Roland McGrath <roland@redhat.com> Cc: Stephen Smalley <sds@tycho.nsa.gov> Cc: James Morris <jmorris@namei.org> Cc: "David S. Miller" <davem@davemloft.net> Cc: Jeff Dike <jdike@addtoit.com> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Jan Kara <jack@ucw.cz> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-05Merge branch 'master' of ↵David Howells
git://git.kernel.org/pub/scm/linux/kernel/git/torvalds/linux-2.6 Conflicts: drivers/infiniband/core/iwcm.c drivers/net/chelsio/cxgb2.c drivers/net/wireless/bcm43xx/bcm43xx_main.c drivers/net/wireless/prism54/islpci_eth.c drivers/usb/core/hub.h drivers/usb/input/hid-core.c net/core/netpoll.c Fix up merge failures with Linus's head and fix new compilation failures. Signed-Off-By: David Howells <dhowells@redhat.com>
2006-12-01Driver core: convert tty core to use struct deviceGreg Kroah-Hartman
Converts from using struct "class_device" to "struct device" making everything show up properly in /sys/devices/ with symlinks from the /sys/class directory. Also fixes up the isdn drivers that were putting something in the class device's directory. Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-11-22WorkStruct: Separate delayable and non-delayable events.David Howells
Separate delayable work items from non-delayable work items be splitting them into a separate structure (delayed_work), which incorporates a work_struct and the timer_list removed from work_struct. The work_struct struct is huge, and this limits it's usefulness. On a 64-bit architecture it's nearly 100 bytes in size. This reduces that by half for the non-delayable type of event. Signed-Off-By: David Howells <dhowells@redhat.com>
2006-09-30[PATCH] BLOCK: Move extern declarations out of fs/*.c into header files [try #6]David Howells
Create a new header file, fs/internal.h, for common definitions local to the sources in the fs/ directory. Move extern definitions that should be in header files from fs/*.c to fs/internal.h or other main header files where they span directories. Signed-Off-By: David Howells <dhowells@redhat.com> Signed-off-by: Jens Axboe <axboe@kernel.dk>
2006-09-29[PATCH] tty: make termios_sem a mutexArjan van de Ven
[akpm@osdl.org: fix] Cc: Alan Cox <alan@lxorguk.ukuu.org.uk> Cc: Arjan van de Ven <arjan@infradead.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-09-29[PATCH] Remove unused tty_struct fieldMatthias Urlichs
Unused: tty_struct.max_flip_cnt $ git grep max_flip_cnt include/linux/tty.h: int max_flip_cnt; $ Cc: Paul Fulghum <paulkf@microgate.com> Acked-by: Alan Cox <alan@lxorguk.ukuu.org.uk> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-08-27[PATCH] Fix tty layer DoS and comment relevant codeAlan Cox
Unlike the other tty comment patch this one has code changes. Specifically it limits the queue size for a tty to 64K characters (128Kbytes) worst case even if the tty is ignoring tty->throttle. This is because certain drivers don't honour the throttle value correctly, although it is a useful safeguard anyway. Signed-off-by: Alan Cox <alan@redhat.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-07-10[PATCH] tty: Remove include of screen_info.h from tty.hJon Smirl
screen_info.h doesn't have anything to do with the tty layer and shouldn't be included by tty.h. This patches removes the include and modifies all users to directly include screen_info.h. struct screen_info is mainly used to communicate with the console drivers in drivers/video/console. Note that this patch touches every arch and I have no way of testing it. If there is a mistake the worst thing that will happen is a compile error. [akpm@osdl.org: fix arm build] [akpm@osdl.org: fix alpha build] Signed-off-by: Jon Smirl <jonsmir@gmail.com> Signed-off-by: Antonino Daplas <adaplas@pol.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-07-10[PATCH] vt: Remove VT-specific declarations and definitions from tty.hJon Smirl
MAX_NR_CONSOLES, fg_console, want_console and last_console are more of a function of the VT layer than the TTY one. Moving these to vt.h and vt_kern.h allows all of the framebuffer and VT console drivers to remove their dependency on tty.h. [akpm@osdl.org: fix alpha build] Signed-off-by: Jon Smirl <jonsmir@gmail.com> Signed-off-by: Antonino Daplas <adaplas@pol.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-28[PATCH] remove active field from tty buffer structurePaul Fulghum
Remove 'active' field from tty buffer structure. This was added in 2.6.16 as part of a patch to make the new tty buffering SMP safe. This field is unnecessary with the more intelligently written flush_to_ldisc that adds receive_room handling. Removing this field reverts to simpler logic where the tail buffer is always the 'active' buffer, which should not be freed by flush_to_ldisc. (active == buffer being filled with new data) The result is simpler, smaller, and faster tty buffer code. Signed-off-by: Paul Fulghum <paulkf@microgate.com> Cc: Alan Cox <alan@lxorguk.ukuu.org.uk> Cc: Theodore Ts'o <tytso@mit.edu> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-28[PATCH] remove TTY_DONT_FLIPPaul Fulghum
Remove TTY_DONT_FLIP tty flag. This flag was introduced in 2.1.X kernels to prevent the N_TTY line discipline functions read_chan() and n_tty_receive_buf() from running at the same time. 2.2.15 introduced tty->read_lock to protect access to the N_TTY read buffer, which is the only state requiring protection between these two functions. The current TTY_DONT_FLIP implementation is broken for SMP, and is not universally honored by drivers that send data directly to the line discipline receive_buf function. Because TTY_DONT_FLIP is not necessary, is broken in implementation, and is not universally honored, it is removed. Signed-off-by: Paul Fulghum <paulkf@microgate.com> Cc: Alan Cox <alan@lxorguk.ukuu.org.uk> Cc: Theodore Ts'o <tytso@mit.edu> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-21[PATCH] TTY: return class device pointer from tty_register_device()Hansjoerg Lipp
Let tty_register_device() return a pointer to the class device it creates. This allows registrants to add their own sysfs files under the class device node. Signed-off-by: Hansjoerg Lipp <hjlipp@web.de> Signed-off-by: Tilman Schmidt <tilman@imap.cc> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-04-26Don't include linux/config.h from anywhere else in include/David Woodhouse
2006-03-23[PATCH] sem2mutex: ttyIngo Molnar
Semaphore to mutex conversion. The conversion was generated via scripts, and the result was validated automatically via a script as well. Signed-off-by: Ingo Molnar <mingo@elte.hu> Cc: Alan Cox <alan@lxorguk.ukuu.org.uk> Cc: Russell King <rmk@arm.linux.org.uk> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-02-10[PATCH] tty buffering stall fixPaul Fulghum
Prevent stalled processing of received data when a driver allocates tty buffer space but does not immediately follow the allocation with more data and a call to schedule receive tty processing. (example: hvc_console) This bug was introduced by the first locking patch for the new tty buffering. Signed-off-by: Paul Fulghum <paulkf@microgate.com> Cc: Alan Cox <alan@lxorguk.ukuu.org.uk> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-02-03[PATCH] new tty buffering locking fixPaul Fulghum
Change locking in the new tty buffering facility from using tty->read_lock, which is currently ignored by drivers and thus ineffective. New locking uses a new tty buffering specific lock enforced centrally in the tty buffering code. Two drivers (esp and cyclades) are updated to use the tty buffering functions instead of accessing tty buffering internals directly. This is required for the new locking to work. Minor checks for NULL buffers added to tty_prepare_flip_string/tty_prepare_flip_string_flags Signed-off-by: Paul Fulghum <paulkf@microgate.com> Cc: Alan Cox <alan@lxorguk.ukuu.org.uk> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-10[PATCH] TTY layer buffering revampAlan Cox
The API and code have been through various bits of initial review by serial driver people but they definitely need to live somewhere for a while so the unconverted drivers can get knocked into shape, existing drivers that have been updated can be better tuned and bugs whacked out. This replaces the tty flip buffers with kmalloc objects in rings. In the normal situation for an IRQ driven serial port at typical speeds the behaviour is pretty much the same, two buffers end up allocated and the kernel cycles between them as before. When there are delays or at high speed we now behave far better as the buffer pool can grow a bit rather than lose characters. This also means that we can operate at higher speeds reliably. For drivers that receive characters in blocks (DMA based, USB and especially virtualisation) the layer allows a lot of driver specific code that works around the tty layer with private secondary queues to be removed. The IBM folks need this sort of layer, the smart serial port people do, the virtualisers do (because a virtualised tty typically operates at infinite speed rather than emulating 9600 baud). Finally many drivers had invalid and unsafe attempts to avoid buffer overflows by directly invoking tty methods extracted out of the innards of work queue structs. These are no longer needed and all go away. That fixes various random hangs with serial ports on overflow. The other change in here is to optimise the receive_room path that is used by some callers. It turns out that only one ldisc uses receive room except asa constant and it updates it far far less than the value is read. We thus make it a variable not a function call. I expect the code to contain bugs due to the size alone but I'll be watching and squashing them and feeding out new patches as it goes. Because the buffers now dynamically expand you should only run out of buffering when the kernel runs out of memory for real. That means a lot of the horrible hacks high performance drivers used to do just aren't needed any more. Description: tty_insert_flip_char is an old API and continues to work as before, as does tty_flip_buffer_push() [this is why many drivers dont need modification]. It does now also return the number of chars inserted There are also tty_buffer_request_room(tty, len) which asks for a buffer block of the length requested and returns the space found. This improves efficiency with hardware that knows how much to transfer. and tty_insert_flip_string_flags(tty, str, flags, len) to insert a string of characters and flags For a smart interface the usual code is len = tty_request_buffer_room(tty, amount_hardware_says); tty_insert_flip_string(tty, buffer_from_card, len); More description! At the moment tty buffers are attached directly to the tty. This is causing a lot of the problems related to tty layer locking, also problems at high speed and also with bursty data (such as occurs in virtualised environments) I'm working on ripping out the flip buffers and replacing them with a pool of dynamically allocated buffers. This allows both for old style "byte I/O" devices and also helps virtualisation and smart devices where large blocks of data suddenely materialise and need storing. So far so good. Lots of drivers reference tty->flip.*. Several of them also call directly and unsafely into function pointers it provides. This will all break. Most drivers can use tty_insert_flip_char which can be kept as an API but others need more. At the moment I've added the following interfaces, if people think more will be needed now is a good time to say int tty_buffer_request_room(tty, size) Try and ensure at least size bytes are available, returns actual room (may be zero). At the moment it just uses the flipbuf space but that will change. Repeated calls without characters being added are not cumulative. (ie if you call it with 1, 1, 1, and then 4 you'll have four characters of space. The other functions will also try and grow buffers in future but this will be a more efficient way when you know block sizes. int tty_insert_flip_char(tty, ch, flag) As before insert a character if there is room. Now returns 1 for success, 0 for failure. int tty_insert_flip_string(tty, str, len) Insert a block of non error characters. Returns the number inserted. int tty_prepare_flip_string(tty, strptr, len) Adjust the buffer to allow len characters to be added. Returns a buffer pointer in strptr and the length available. This allows for hardware that needs to use functions like insl or mencpy_fromio. Signed-off-by: Alan Cox <alan@redhat.com> Cc: Paul Fulghum <paulkf@microgate.com> Signed-off-by: Hirokazu Takata <takata@linux-m32r.org> Signed-off-by: Serge Hallyn <serue@us.ibm.com> Signed-off-by: Jeff Dike <jdike@addtoit.com> Signed-off-by: John Hawkes <hawkes@sgi.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com> Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-08[PATCH] Split out screen_info from tty.hBrian Gerst
This makes it possible for boot code to use screen_info without dragging in all of tty.h. Signed-off-by: Brian Gerst <bgerst@didntduck.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-09[PATCH] vesafb: Add blanking supportAntonino A. Daplas
Add rudimentary support by manipulating the VGA registers. However, not all vesa modes are VGA compatible, so VGA compatiblity is checked first. Only 2 levels are supported, powerup and powerdown. Signed-off-by: Antonino Daplas <adaplas@pol.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-23[PATCH] Introduce tty_unregister_ldisc()Alexey Dobriyan
It's a bit strange to see tty_register_ldisc call in modules' exit functions. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
