path: root/include/linux/tty.h
2013-01-18tty: Added a CONFIG_TTY option to allow removal of TTYJoe Millenbach
The option allows you to remove TTY and compile without errors. This saves space on systems that won't support TTY interfaces anyway. bloat-o-meter output is below. The bulk of this patch consists of Kconfig changes adding "depends on TTY" to various serial devices and similar drivers that require the TTY layer. Ideally, these dependencies would occur on a common intermediate symbol such as SERIO, but most drivers "select SERIO" rather than "depends on SERIO", and "select" does not respect dependencies. bloat-o-meter output comparing our previous minimal to new minimal by removing TTY. The list is filtered to not show removed entries with awk '$3 != "-"' as the list was very long. add/remove: 0/226 grow/shrink: 2/14 up/down: 6/-35356 (-35350) function old new delta chr_dev_init 166 170 +4 allow_signal 80 82 +2 static.__warned 143 142 -1 disallow_signal 63 62 -1 __set_special_pids 95 94 -1 unregister_console 126 121 -5 start_kernel 546 541 -5 register_console 593 588 -5 copy_from_user 45 40 -5 sys_setsid 128 120 -8 sys_vhangup 32 19 -13 do_exit 1543 1526 -17 bitmap_zero 60 40 -20 arch_local_irq_save 137 117 -20 release_task 674 652 -22 static.spin_unlock_irqrestore 308 260 -48 Signed-off-by: Joe Millenbach <jmillenbach@gmail.com> Reviewed-by: Jamey Sharp <jamey@minilop.net> Reviewed-by: Josh Triplett <josh@joshtriplett.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-01-15TTY: switch tty_flip_buffer_pushJiri Slaby
Now, we start converting tty buffer functions to actually use tty_port. This will allow us to get rid of the need of tty in many call sites. Only tty_port will needed and hence no more tty_port_tty_get in those paths. Now, the one where most of tty_port_tty_get gets removed: tty_flip_buffer_push. IOW we also closed all the races in drivers not using tty_port_tty_get at all yet. Also we move tty_flip_buffer_push declaration from include/linux/tty.h to include/linux/tty_flip.h to all others while we are changing it anyway. Signed-off-by: Jiri Slaby <jslaby@suse.cz> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-01-15TTY: move low_latency to tty_portJiri Slaby
One point is to have less places where we actually need tty pointer. The other is that low_latency is bound to buffer processing and buffers are now in tty_port. So it makes sense to move low_latency to tty_port too. Signed-off-by: Jiri Slaby <jslaby@suse.cz> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-11-15TTY: introduce tty_port_destroyJiri Slaby
After commit "TTY: move tty buffers to tty_port", the tty buffers are not freed in some drivers. This is because tty_port_destructor is not called whenever a tty_port is freed. This was an assumption I counted with but was unfortunately untrue. Those using refcounting are safe now, but for those which do not we introduce a function to be called right before the tty_port is freed by the drivers. Signed-off-by: Jiri Slaby <jslaby@suse.cz> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-10-22TTY: move tty buffers to tty_portJiri Slaby
So this is it. The big step why we did all the work over the past kernel releases. Now everything is prepared, so nothing protects us from doing that big step. | | \ \ nnnn/^l | | | | \ / / | | | '-,.__ => \/ ,-` => | '-,.__ | O __.´´) ( .` | O __.´´) ~~~ ~~ `` ~~~ ~~ The buffers are now in the tty_port structure and we can start teaching the buffer helpers (insert char/string, flip etc.) to use tty_port instead of tty_struct all around. Signed-off-by: Jiri Slaby <jslaby@suse.cz> Acked-by: Alan Cox <alan@linux.intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-10-22TTY: add port -> tty linkJiri Slaby
For that purpose we have to temporarily introduce a second tty back pointer into tty_port. It is because serial layer, and maybe others, still do not use tty_port_tty_set/get. So that we cannot set the tty_port->tty to NULL at will now. Yes, the fix would be to convert whole serial layer and all its users to tty_port_tty_set/get. However we are in the process of removing the need of tty in most of the call sites, so this would lead to a duplicated work. Instead we have now tty_port->itty (internal tty) which will be used only in flush_to_ldisc. For that one it is ensured that itty is valid wherever the work is run. IOW, the work is synchronously cancelled before we set itty to NULL and also before hangup is processed. After we need only tty_port and not tty_struct in most code, this shall be changed to tty_port_tty_set/get and itty removed completely. Signed-off-by: Jiri Slaby <jslaby@suse.cz> Acked-by: Alan Cox <alan@linux.intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-10-22TTY: move TTY_FLUSH* flags to tty_portJiri Slaby
They are only TTY buffers specific. And the buffers will go to tty_port in the next patches. So to remove the need to have both tty_port and tty_struct at some places, let us move the flags to tty_port. Signed-off-by: Jiri Slaby <jslaby@suse.cz> Acked-by: Alan Cox <alan@linux.intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-10-22TTY: move ldisc data from tty_struct: locksJiri Slaby
atomic_write_lock is not n_tty specific, so move it up in the tty_struct. And since these are the last ones to move, remove also the comment saying there are some ldisc' members. There are none now. Signed-off-by: Jiri Slaby <jslaby@suse.cz> Acked-by: Alan Cox <alan@linux.intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-10-22TTY: move ldisc data from tty_struct: read_* and echo_* and canon_* stuffJiri Slaby
All the ring-buffers... Signed-off-by: Jiri Slaby <jslaby@suse.cz> Acked-by: Alan Cox <alan@linux.intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-10-22TTY: move ldisc data from tty_struct: bitmapsJiri Slaby
Here we move bitmaps and use DECLARE_BITMAP to declare them in the new structure. And instead of memset, we use bitmap_zero as it is more appropriate. Signed-off-by: Jiri Slaby <jslaby@suse.cz> Acked-by: Alan Cox <alan@linux.intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-10-22TTY: move ldisc data from tty_struct: simple membersJiri Slaby
Here we start moving all the n_tty related bits from tty_struct to the newly defined n_tty_data struct in n_tty proper. In this patch primitive members and bits are moved. The rest will be done per-partes in the next patches. Signed-off-by: Jiri Slaby <jslaby@suse.cz> Acked-by: Alan Cox <alan@linux.intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-10-22TTY: audit, stop accessing tty->icountJiri Slaby
This is a private member of n_tty. Stop accessing it. Instead, take is as an argument. This is needed to allow clean switch of the private members to a separate private structure of n_tty. Signed-off-by: Jiri Slaby <jslaby@suse.cz> Acked-by: Alan Cox <alan@linux.intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-10-13UAPI: (Scripted) Disintegrate include/linuxDavid Howells
Signed-off-by: David Howells <dhowells@redhat.com> Acked-by: Arnd Bergmann <arnd@arndb.de> Acked-by: Thomas Gleixner <tglx@linutronix.de> Acked-by: Michael Kerrisk <mtk.manpages@gmail.com> Acked-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Acked-by: Dave Jones <davej@redhat.com>
2012-10-02Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/ebiederm/user-namespace Pull user namespace changes from Eric Biederman: "This is a mostly modest set of changes to enable basic user namespace support. This allows the code to code to compile with user namespaces enabled and removes the assumption there is only the initial user namespace. Everything is converted except for the most complex of the filesystems: autofs4, 9p, afs, ceph, cifs, coda, fuse, gfs2, ncpfs, nfs, ocfs2 and xfs as those patches need a bit more review. The strategy is to push kuid_t and kgid_t values are far down into subsystems and filesystems as reasonable. Leaving the make_kuid and from_kuid operations to happen at the edge of userspace, as the values come off the disk, and as the values come in from the network. Letting compile type incompatible compile errors (present when user namespaces are enabled) guide me to find the issues. The most tricky areas have been the places where we had an implicit union of uid and gid values and were storing them in an unsigned int. Those places were converted into explicit unions. I made certain to handle those places with simple trivial patches. Out of that work I discovered we have generic interfaces for storing quota by projid. I had never heard of the project identifiers before. Adding full user namespace support for project identifiers accounts for most of the code size growth in my git tree. Ultimately there will be work to relax privlige checks from "capable(FOO)" to "ns_capable(user_ns, FOO)" where it is safe allowing root in a user names to do those things that today we only forbid to non-root users because it will confuse suid root applications. While I was pushing kuid_t and kgid_t changes deep into the audit code I made a few other cleanups. I capitalized on the fact we process netlink messages in the context of the message sender. I removed usage of NETLINK_CRED, and started directly using current->tty. Some of these patches have also made it into maintainer trees, with no problems from identical code from different trees showing up in linux-next. After reading through all of this code I feel like I might be able to win a game of kernel trivial pursuit." Fix up some fairly trivial conflicts in netfilter uid/git logging code. * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/ebiederm/user-namespace: (107 commits) userns: Convert the ufs filesystem to use kuid/kgid where appropriate userns: Convert the udf filesystem to use kuid/kgid where appropriate userns: Convert ubifs to use kuid/kgid userns: Convert squashfs to use kuid/kgid where appropriate userns: Convert reiserfs to use kuid and kgid where appropriate userns: Convert jfs to use kuid/kgid where appropriate userns: Convert jffs2 to use kuid and kgid where appropriate userns: Convert hpfs to use kuid and kgid where appropriate userns: Convert btrfs to use kuid/kgid where appropriate userns: Convert bfs to use kuid/kgid where appropriate userns: Convert affs to use kuid/kgid wherwe appropriate userns: On alpha modify linux_to_osf_stat to use convert from kuids and kgids userns: On ia64 deal with current_uid and current_gid being kuid and kgid userns: On ppc convert current_uid from a kuid before printing. userns: Convert s390 getting uid and gid system calls to use kuid and kgid userns: Convert s390 hypfs to use kuid and kgid where appropriate userns: Convert binder ipc to use kuids userns: Teach security_path_chown to take kuids and kgids userns: Add user namespace support to IMA userns: Convert EVM to deal with kuids and kgids in it's hmac computation ...
2012-09-17userns: Convert the audit loginuid to be a kuidEric W. Biederman
Always store audit loginuids in type kuid_t. Print loginuids by converting them into uids in the appropriate user namespace, and then printing the resulting uid. Modify audit_get_loginuid to return a kuid_t. Modify audit_set_loginuid to take a kuid_t. Modify /proc/<pid>/loginuid on read to convert the loginuid into the user namespace of the opener of the file. Modify /proc/<pid>/loginud on write to convert the loginuid rom the user namespace of the opener of the file. Cc: Al Viro <viro@zeniv.linux.org.uk> Cc: Eric Paris <eparis@redhat.com> Cc: Paul Moore <paul@paul-moore.com> ? Cc: David Miller <davem@davemloft.net> Signed-off-by: Eric W. Biederman <ebiederm@xmission.com>
2012-09-06tty_register_device_attr updated for tty-nextTomas Hlavacek
Added tty_device_create_release() and bound to dev->release in tty_register_device_attr(). Added tty_port_register_device_attr() and used in uart_add_one_port() instead of tty_register_device_attr(). Signed-off-by: Tomas Hlavacek <tmshlvck@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-09-06tty: uartclk value from serial_core exposed to sysfsTomas Hlavacek
Added file /sys/devices/.../tty/ttySX/uartclk to allow reading uartclk value in struct uart_port in serial_core via sysfs. tty_register_device() has been generalized and refactored in order to add support for setting drvdata and attribute_group to the device. Signed-off-by: Tomas Hlavacek <tmshlvck@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-09-05serial: add a new helper functionHuang Shijie
In most of the time, the driver needs to check if the cts flow control is enabled. But now, the driver checks the ASYNC_CTS_FLOW flag manually, which is not a grace way. So add a new wraper function to make the code tidy and clean. Signed-off-by: Huang Shijie <shijie8@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-09-05tty: move the async flags from the serial code into the tty includesAlan Cox
These are used with the tty_port flags which are tty generic so move the flags into a more sensible place. This then makes it possible to add helpers such as those suggested by Huang Shijie. Signed-off-by: Alan Cox <alan@linux.intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-08-13TTY: add tty_port_link_deviceJiri Slaby
This is for those drivers which do not have dynamic device creation (do not call tty_port_register_device) and do not want to implement tty->ops->install (will not call tty_port_install). They still have to provide the link somehow though. And this newly added function is exactly to serve that purpose. Signed-off-by: Jiri Slaby <jslaby@suse.cz> Acked-by: Alan Cox <alan@linux.intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-08-10tty: localise the lockAlan Cox
The termios and other changes mean the other protections needed on the driver tty arrays should be adequate. Turn it all back on. This contains pieces folded in from the fixes made to the original patches | From: Geert Uytterhoeven <geert@linux-m68k.org> (fix m68k) | From: Paul Gortmaker <paul.gortmaker@windriver.com> (fix cris) | From: Jiri Kosina <jkosina@suze.cz> (lockdep) | From: Eric Dumazet <eric.dumazet@gmail.com> (lockdep) Signed-off-by: Alan Cox <alan@linux.intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-07-17tty: Move the handling of the tty release logicAlan Cox
Now that we don't have tty->termios tied to drivers->tty we can untangle the logic here. In addition we can push the removal logic out of the destructor path. At that point we can think about sorting out tty_port and console and all the other ugly hangovers. Signed-off-by: Alan Cox <alan@linux.intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-07-16tty: move the termios object into the ttyAlan Cox
This will let us sort out a whole pile of tty related races. The alternative would be to keep points and refcount the termios objects. However 1. They are tiny anyway 2. Many devices don't use the stored copies 3. We can remove a pty special case Signed-off-by: Alan Cox <alan@linux.intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-07-16tty: revert incorrectly applied lock patchAlan Cox
I sent GregKH this after the pre-requisites. He dropped the pre-requesites for good reason and unfortunately then applied this patch. Without this reverted you get random kernel memory corruption which will make bisecting anything between it and the properly applied patches a complete sod. Signed-off-by: Alan Cox <alan@linux.intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-07-06tty: localise the lockAlan Cox
2012-06-13TTY: add tty_port_register_device helperJiri Slaby
This will automatically assign tty_port to tty_driver's port array for later recall in tty_init_dev. This is intended to be called instead of tty_register_device. Signed-off-by: Jiri Slaby <jslaby@suse.cz> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-06-13TTY: provide drivers with tty_port_installJiri Slaby
This will be used in tty_ops->install to set tty->port (and to call tty_standard_install). Signed-off-by: Jiri Slaby <jslaby@suse.cz> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-06-02tty: Revert the tty locking series, it needs more workLinus Torvalds
This reverts the tty layer change to use per-tty locking, because it's not correct yet, and fixing it will require some more deep surgery. The main revert is d29f3ef39be4 ("tty_lock: Localise the lock"), but there are several smaller commits that built upon it, they also get reverted here. The list of reverted commits is: fde86d310886 - tty: add lockdep annotations 8f6576ad476b - tty: fix ldisc lock inversion trace d3ca8b64b97e - pty: Fix lock inversion b1d679afd766 - tty: drop the pty lock during hangup abcefe5fc357 - tty/amiserial: Add missing argument for tty_unlock() fd11b42e3598 - cris: fix missing tty arg in wait_event_interruptible_tty call d29f3ef39be4 - tty_lock: Localise the lock The revert had a trivial conflict in the 68360serial.c staging driver that got removed in the meantime. Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-05-04tty_lock: Localise the lockAlan Cox
In each remaining case the tty_lock is associated with a specific tty. This means we can now lock on a per tty basis. We do need tty_lock_pair() for the pty case. Uglier but still a step in the right direction. [fixed up calls in 3 missing drivers - gregkh] Signed-off-by: Alan Cox <alan@linux.intel.com> Acked-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-03-28Remove all #inclusions of asm/system.hDavid Howells
Remove all #inclusions of asm/system.h preparatory to splitting and killing it. Performed with the following command: perl -p -i -e 's!^#\s*include\s*<asm/system[.]h>.*\n!!' `grep -Irl '^#\s*include\s*<asm/system[.]h>' *` Signed-off-by: David Howells <dhowells@redhat.com>
2012-02-02TTY: provide tty_standard_install helperJiri Slaby
There are currently many cut&paste copies of what tty_driver_install_tty does when custom ->install method is not provided. Let's get rid of the copies and create a helper with this setup code. Signed-off-by: Jiri Slaby <jslaby@suse.cz> Cc: Havard Skinnemoen <hskinnemoen@google.com> Acked-by: Alan Cox <alan@linux.intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-01-24tty: rework pty count limitingKonstantin Khlebnikov
After adding devpts multiple-insrances sysctl kernel.pty.max limit pty count for each devpts instance independently, while kernel.pty.nr shows total pty count. This patch restores sysctl kernel.pty.max as global limit (4096 by default), adds pty reseve for main devpts (mounted without "newinstance" argument), and new sysctl to tune it: kernel.pty.reserve (1024 by default) Also it adds devpts mount option "max=%d" to limit pty count for each devpts instance independently. (by default NR_UNIX98_PTY_MAX == 2^20) Thus devpts instances in containers cannot eat up all available pty even if we didn't set any limits, while with "max" argument we can adjust limits more precisely. Plus, now open("/dev/ptmx") return -ENOSPC in case lack of pty indexes, this is more informative than -EIO. Signed-off-by: Konstantin Khlebnikov <khlebnikov@openvz.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2012-01-24tty: cleanup prohibition of direct opening for unix98 pty masterKonstantin Khlebnikov
cleanup hack added in v2.6.27-3203-g15582d3 comment from that patch: : pty: If the administrator creates a device for a ptmx slave we should not error : : The open path for ptmx slaves is via the ptmx device. Opening them any : other way is not allowed. Vegard Nossum found that previously this was not : the case and mknod foo c 128 42; cat foo would produce nasty diagnostics : : Signed-off-by: Alan Cox <alan@redhat.com> : Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> devpts_get_tty() returns non-null only for inodes on devpts, but there is no inodes for master-devices, /dev/ptmx (/dev/pts/ptmx) is the only way to open them. Thus we can completely forbid lookup for master-devices and eliminate that hack in tty_init_dev() because tty_open() will get EIO from tty_driver_lookup_tty(). Signed-off-by: Konstantin Khlebnikov <khlebnikov@openvz.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-10-26Merge branch 'tty-next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/tty * 'tty-next' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/tty: (79 commits) TTY: serial_core: Fix crash if DCD drop during suspend tty/serial: atmel_serial: bootconsole removed from auto-enumerates Revert "TTY: call tty_driver_lookup_tty unconditionally" tty/serial: atmel_serial: add device tree support tty/serial: atmel_serial: auto-enumerate ports tty/serial: atmel_serial: whitespace and braces modifications tty/serial: atmel_serial: change platform_data variable name tty/serial: RS485 bindings for device tree TTY: call tty_driver_lookup_tty unconditionally TTY: pty, release tty in all ptmx_open fail paths TTY: make tty_add_file non-failing TTY: drop driver reference in tty_open fail path 8250_pci: Fix kernel panic when pch_uart is disabled h8300: drivers/serial/Kconfig was moved parport_pc: release IO region properly if unsupported ITE887x card is found tty: Support compat_ioctl get/set termios_locked hvc_console: display printk messages on console. TTY: snyclinkmp: forever loop in tx_load_dma_buffer() tty/n_gsm: avoid fifo overflow in gsm_dlci_data_output tty/n_gsm: fix a bug in gsm_dlci_data_output (adaption = 2 case) ... Fix up Conflicts in: - drivers/tty/serial/8250_pci.c Trivial conflict with removed duplicate device ID - drivers/tty/serial/atmel_serial.c Annoying silly conflict between "specify the port num via platform_data" and other changes to atmel_console_init
2011-10-18TTY: make tty_add_file non-failingJiri Slaby
If tty_add_file fails at the point it is now, we have to revert all the changes we did to the tty. It means either decrease all refcounts if this was a tty reopen or delete the tty if it was newly allocated. There was a try to fix this in v3.0-rc2 using tty_release in 0259894c7 (TTY: fix fail path in tty_open). But instead it introduced a NULL dereference. It's because tty_release dereferences filp->private_data, but that one is set even in our tty_add_file. And when tty_add_file fails, it's still NULL/garbage. Hence tty_release cannot be called there. To circumvent the original leak (and the current NULL deref) we split tty_add_file into two functions, making the latter non-failing. In that case we may do the former early in open, where handling failures is easy. The latter stays as it is now. So there is no change in functionality. The original bug (leak) was introduced by f573bd176 (tty: Remove __GFP_NOFAIL from tty_add_file()). Thanks Dan for reporting this. Later, we may split tty_release into more functions and call only some of them in this fail path instead. (If at all possible.) Introduced-in: v2.6.37-rc2 Signed-off-by: Jiri Slaby <jslaby@suse.cz> Reported-by: Dan Carpenter <dan.carpenter@oracle.com> Cc: stable <stable@vger.kernel.org> Cc: Alan Cox <alan@lxorguk.ukuu.org.uk> Cc: Pekka Enberg <penberg@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-10-18tty: Support compat_ioctl get/set termios_lockedThomas Meyer
When running a Fedora 15 (x86) on an x86_64 kernel, in the boot process plymouthd complains about those two missing ioctls: [ 2.581783] ioctl32(plymouthd:186): Unknown cmd fd(10) cmd(00005457){t:'T';sz:0} arg(ffb6a5d0) on /dev/tty1 [ 2.581803] ioctl32(plymouthd:186): Unknown cmd fd(10) cmd(00005456){t:'T';sz:0} arg(ffb6a680) on /dev/tty1 both ioctl functions work on the 'struct termios' resp. 'struct termios2', which has the same size (36 bytes resp. 44 bytes) on x86 and x86_64, so it's just a matter of converting the pointer from userland. Signed-off-by: Thomas Meyer <thomas@m3y3r.de> Cc: Arnd Bergmann <arnd@arndb.de> Cc: Alan Cox <alan@lxorguk.ukuu.org.uk> Signed-off-by: Andrew Morton <akpm@google.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-08-25TTY: define tty_wait_until_sent_from_closeJiri Slaby
We need this helper to fix system stalls. The issue is that the rest of the system TTYs wait for us to finish waiting. This wasn't an issue with BKL. BKL used to unlock implicitly. This is based on the Arnd suggestion. Signed-off-by: Jiri Slaby <jslaby@suse.cz> Acked-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-08-23TTY: remove tty_lockedJiri Slaby
We used it really only serial and ami_serial. The rest of the callsites were BUG/WARN_ONs to check if BTM is held. Now that we pruned tty_locked from both of the real users, we can get rid of tty_lock along with __big_tty_mutex_owner. Signed-off-by: Jiri Slaby <jslaby@suse.cz> Acked-by: Arnd Bergmann <arnd@arndb.de> Cc: Alan Cox <alan@linux.intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-08-23TTY: pty, fix pty countingJiri Slaby
tty_operations->remove is normally called like: queue_release_one_tty ->tty_shutdown ->tty_driver_remove_tty ->tty_operations->remove However tty_shutdown() is called from queue_release_one_tty() only if tty_operations->shutdown is NULL. But for pty, it is not. pty_unix98_shutdown() is used there as ->shutdown. So tty_operations->remove of pty (i.e. pty_unix98_remove()) is never called. This results in invalid pty_count. I.e. what can be seen in /proc/sys/kernel/pty/nr. I see this was already reported at: https://lkml.org/lkml/2009/11/5/370 But it was not fixed since then. This patch is kind of a hackish way. The problem lies in ->install. We allocate there another tty (so-called tty->link). So ->install is called once, but ->remove twice, for both tty and tty->link. The fix here is to count both tty and tty->link and divide the count by 2 for user. And to have ->remove called, let's make tty_driver_remove_tty() global and call that from pty_unix98_shutdown() (tty_operations->shutdown). While at it, let's document that when ->shutdown is defined, tty_shutdown() is not called. Signed-off-by: Jiri Slaby <jslaby@suse.cz> Cc: Alan Cox <alan@linux.intel.com> Cc: "H. Peter Anvin" <hpa@zytor.com> Cc: stable <stable@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-06-07TTY: export NR_LDISC and N_* line discipline numbers to user-spaceFlorian Fainelli
Since commit (4564f9e5: consolidate line discipline number definitions) the patch moved all line discipline number from a per-architecture termios.h to a shared one: tty.h. However, prior to this consolidation work, the line discipline numbers were outside of an ifdef __KERNEL__/endif block so these numbers used to be exported to user-space. Since such numbers are kernel ABI anyway, and tty.h is already included for user- space header processing, just move these relevant defines outside of the ifdef __KERNEL__/endif block in include/linux/tty.h. CC: Maxime Bizon <mbizon@freebox.fr> Signed-off-by: Florian Fainelli <ffainelli@freebox.fr> Acked-by: Tilman Schmidt <tilman@imap.cc> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-05-13n_tracerouter and n_tracesink ldisc additions.J Freyensee
The n_tracerouter and n_tracesink line discpline drivers use the Linux tty line discpline framework to route trace data coming from a tty port (say UART for example) to the trace sink line discipline driver and to another tty port(say USB). Those these two line discipline drivers can be used together, independently from pti.c, they are part of the original implementation solution of the MIPI P1149.7, compact JTAG, PTI solution for Intel mobile platforms starting with the Medfield platform. Signed-off-by: J Freyensee <james_p_freyensee@linux.intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-04-19TTY: introduce deinit helpers for proper ldisc shutdownJiri Slaby
Introduce deinitialize_tty_struct which should be called after initialize_tty_struct and before successfull tty_ldisc_setup. It calls tty_ldisc_deinit which is opposite of tty_ldisc_init. It only puts a reference to ldisc and assigns NULL to tty->ldisc. It will be used to shut down ldisc when tty_release cannot be called yet. Signed-off-by: Jiri Slaby <jslaby@suse.cz> Cc: Alan Cox <alan@lxorguk.ukuu.org.uk> Cc: Julian Anastasov <ja@ssi.bg> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-03-22tty: stop using "delayed_work" in the tty layerLinus Torvalds
Using delayed-work for tty flip buffers ends up causing us to wait for the next tick to complete some actions. That's usually not all that noticeable, but for certain latency-critical workloads it ends up being totally unacceptable. As an extreme case of this, passing a token back-and-forth over a pty will take two ticks per iteration, so even just a thousand iterations will take 8 seconds assuming a common 250Hz configuration. Avoiding the whole delayed work issue brings that ping-pong test-case down to 0.009s on my machine. In more practical terms, this latency has been a performance problem for things like dive computer simulators (simulating the serial interface using the ptys) and for other environments (Alan mentions a CP/M emulator). Reported-by: Jef Driesen <jefdriesen@telenet.be> Acked-by: Greg KH <gregkh@suse.de> Acked-by: Alan Cox <alan@lxorguk.ukuu.org.uk> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-02-17tty: add a helper for setting termios data from kernel sideAlan Cox
This basically encapsulates the small bit of locking knowledge needed. While we are at it make sure we blow up on any more abusers and unsafe misuses of ioctl for this kind of stuff. We change the function to return an argument as at some point it needs to honour the POSIX 'I asked for changes but got none of them' error reporting corner case. Signed-off-by: Alan Cox <alan@linux.intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-02-17tty: fix build error in vt_ioctl.c if CONFIG_COMPAT is enabledGreg Kroah-Hartman
This was caused by the previous patch to remove the file pointer from the tty ioctl handler. Cc: Alan Cox <alan@linux.intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-02-17tty: now phase out the ioctl file pointer for goodAlan Cox
Only oddities here are a couple of drivers that bogusly called the ldisc helpers instead of returning -ENOIOCTLCMD. Fix the bug and the rest goes away. Signed-off-by: Alan Cox <alan@linux.intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-12-02Merge branch 'tty-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/tty-2.6 * 'tty-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/tty-2.6: serial: mfd: adjust the baud rate setting TTY: open/hangup race fixup TTY: don't allow reopen when ldisc is changing NET: wan/x25, fix ldisc->open retval TTY: ldisc, fix open flag handling serial8250: Mark console as CON_ANYTIME
2010-11-29TTY: open/hangup race fixupJiri Slaby
Like in the "TTY: don't allow reopen when ldisc is changing" patch, this one fixes a TTY WARNING as described in the option 1) there: 1) __tty_hangup from tty_ldisc_hangup to tty_ldisc_enable. During this section tty_lock is held. However tty_lock is temporarily dropped in the middle of the function by tty_ldisc_hangup. The fix is to introduce a new flag which we set during the unlocked window and check it in tty_reopen too. The flag is TTY_HUPPING and is cleared after TTY_HUPPED is set. While at it, remove duplicate TTY_HUPPED set_bit. The one after calling ops->hangup seems to be more correct. But anyway, we hold tty_lock, so there should be no difference. Also document the function it does that kind of crap. Nicely reproducible with two forked children: static void do_work(const char *tty) { if (signal(SIGHUP, SIG_IGN) == SIG_ERR) exit(1); setsid(); while (1) { int fd = open(tty, O_RDWR|O_NOCTTY); if (fd < 0) continue; if (ioctl(fd, TIOCSCTTY)) continue; if (vhangup()) continue; close(fd); } exit(0); } Signed-off-by: Jiri Slaby <jslaby@suse.cz> Reported-by: <Valdis.Kletnieks@vt.edu> Reported-by: Kyle McMartin <kyle@mcmartin.ca> Cc: Alan Cox <alan@lxorguk.ukuu.org.uk> Cc: stable <stable@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-11-17BKL: remove extraneous #include <smp_lock.h>Arnd Bergmann
The big kernel lock has been removed from all these files at some point, leaving only the #include. Remove this too as a cleanup. Signed-off-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-11-09tty: Fix formatting in tty.hAlan Cox
Someone added a new ldisc number and messed up the tabbing. Fix it before anyone else copies it. Signed-off-by: Alan Cox <alan@linux.intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
