path: root/include/linux/tcp.h
2008-01-28[TCP]: Rewrite SACK block processing & sack_recv_cache useIlpo Järvinen
Key points of this patch are: - In case new SACK information is advance only type, no skb processing below previously discovered highest point is done - Optimize cases below highest point too since there's no need to always go up to highest point (which is very likely still present in that SACK), this is not entirely true though because I'm dropping the fastpath_skb_hint which could previously optimize those cases even better. Whether that's significant, I'm not too sure. Currently it will provide skipping by walking. Combined with RB-tree, all skipping would become fast too regardless of window size (can be done incrementally later). Previously a number of cases in TCP SACK processing fails to take advantage of costly stored information in sack_recv_cache, most importantly, expected events such as cumulative ACK and new hole ACKs. Processing on such ACKs result in rather long walks building up latencies (which easily gets nasty when window is huge). Those latencies are often completely unnecessary compared with the amount of _new_ information received, usually for cumulative ACK there's no new information at all, yet TCP walks whole queue unnecessary potentially taking a number of costly cache misses on the way, etc.! Since the inclusion of highest_sack, there's a lot information that is very likely redundant (SACK fastpath hint stuff, fackets_out, highest_sack), though there's no ultimate guarantee that they'll remain the same whole the time (in all unearthly scenarios). Take advantage of this knowledge here and drop fastpath hint and use direct access to highest SACKed skb as a replacement. Effectively "special cased" fastpath is dropped. This change adds some complexity to introduce better coveraged "fastpath", though the added complexity should make TCP behave more cache friendly. The current ACK's SACK blocks are compared against each cached block individially and only ranges that are new are then scanned by the high constant walk. For other parts of write queue, even when in previously known part of the SACK blocks, a faster skip function is used (if necessary at all). In addition, whenever possible, TCP fast-forwards to highest_sack skb that was made available by an earlier patch. In typical case, no other things but this fast-forward and mandatory markings after that occur making the access pattern quite similar to the former fastpath "special case". DSACKs are special case that must always be walked. The local to recv_sack_cache copying could be more intelligent w.r.t DSACKs which are likely to be there only once but that is left to a separate patch. Signed-off-by: Ilpo Järvinen <ilpo.jarvinen@helsinki.fi> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-28[TCP]: Earlier SACK block verification & simplify access to themIlpo Järvinen
2008-01-28[TCP]: Convert highest_sack to sk_buff to allow direct accessIlpo Järvinen
It is going to replace the sack fastpath hint quite soon... :-) Signed-off-by: Ilpo Järvinen <ilpo.jarvinen@helsinki.fi> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-15[TCP]: Make snd_cwnd_cnt 32-bitIlpo Järvinen
Very little point of having 32-bit snd_cnwd if this is not 32-bit as well, as a number of snd_cwnd incrementation formulas assume that snd_cwnd_cnt can be at least as large as snd_cwnd. Whether 32-bit is useful was discussed when e0ef57cc56c3c96 was made: http://marc.info/?l=linux-netdev&m=117218144409825&w=2 Signed-off-by: Ilpo Järvinen <ilpo.jarvinen@helsinki.fi> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-11[TCP]: Limit processing lost_retrans loop to work-to-do casesIlpo Järvinen
This addition of lost_retrans_low to tcp_sock might be unnecessary, it's not clear how often lost_retrans worker is executed when there wasn't work to do. Signed-off-by: Ilpo Järvinen <ilpo.jarvinen@helsinki.fi> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-10[TCP]: Comment fastpath_cnt_hint off-by-one trapIlpo Järvinen
2007-10-10[TCP]: Update comment about highest_sack validityIlpo Järvinen
This stale info came from the original idea, which proved to be unnecessarily complex, sacked_out > 0 is easy to do and that when it's going to be needed anyway (it _can_ be valid also when sacked_out == 0 but there's not going to be a guarantee about it for now). Signed-off-by: Ilpo Järvinen <ilpo.jarvinen@helsinki.fi> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-10[TCP]: Tighten tcp_sock's belt, drop left_outIlpo Järvinen
It is easily calculable when needed and user are not that many after all. Signed-off-by: Ilpo Järvinen <ilpo.jarvinen@helsinki.fi> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-10[TCP]: Access to highest_sack obsoletes forward_cnt_hintIlpo Järvinen
In addition, added a reference about the purpose of the loop. Signed-off-by: Ilpo Järvinen <ilpo.jarvinen@helsinki.fi> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-10[TCP]: Add highest_sack seqno, points to globally highest SACKIlpo Järvinen
It is guaranteed to be valid only when !tp->sacked_out. In most cases this seqno is available in the last ACK but there is no guarantee for that. The new fast recovery loss marking algorithm needs this as entry point. Signed-off-by: Ilpo Järvinen <ilpo.jarvinen@helsinki.fi> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-25[SK_BUFF]: Introduce skb_transport_header(skb)Arnaldo Carvalho de Melo
For the places where we need a pointer to the transport header, it is still legal to touch skb->h.raw directly if just adding to, subtracting from or setting it to another layer header. Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-25[SK_BUFF]: Introduce tcp_hdr(), remove skb->h.thArnaldo Carvalho de Melo
2007-04-25[TCP]: Introduce tcp_hdrlen() and tcp_optlen()Arnaldo Carvalho de Melo
The ip_hdrlen() buddy, created to reduce the number of skb->h.th-> uses and to avoid the longer, open coded equivalent. Ditched a no-op in bnx2 in the process. I wonder if we should have a BUG_ON(skb->h.th->doff < 5) in tcp_optlen()... Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-25[TCP]: Make snd_cwnd_clamp a u32.David S. Miller
2007-04-25[TCP]: Keep copied_seq, rcv_wup and rcv_next together.Eric Dumazet
I noticed in oprofile study a cache miss in tcp_rcv_established() to read copied_seq. ffffffff80400a80 <tcp_rcv_established>: /* tcp_rcv_established total: 4034293   2.0400 */  55493  0.0281 :ffffffff80400bc9:   mov    0x4c8(%r12),%eax copied_seq 543103  0.2746 :ffffffff80400bd1:   cmp    0x3e0(%r12),%eax   rcv_nxt     if (tp->copied_seq == tp->rcv_nxt &&         len - tcp_header_len <= tp->ucopy.len) { In this function, the cache line 0x4c0 -> 0x500 is used only for this reading 'copied_seq' field. rcv_wup and copied_seq should be next to rcv_nxt field, to lower number of active cache lines in hot paths. (tcp_rcv_established(), tcp_poll(), ...) As you suggested, I changed tcp_create_openreq_child() so that these fields are changed together, to avoid adding a new store buffer stall. Patch is 64bit friendly (no new hole because of alignment constraints) Signed-off-by: Eric Dumazet <dada1@cosmosbay.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-02-08[TCP]: Seperate DSACK from SACK fast pathBaruch Even
Move DSACK code outside the SACK fast-path checking code. If the DSACK determined that the information was too old we stayed with a partial cache copied. Most likely this matters very little since the next packet will not be DSACK and we will find it in the cache. but it's still not good form and there is little reason to couple the two checks. Since the SACK receive cache doesn't need the data to be in host order we also remove the ntohl in the checking loop. Signed-off-by: Baruch Even <baruch@ev-en.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-12-02[TCP]: Renove the __ prefix on the struct tcp_sock membersArnaldo Carvalho de Melo
As this struct is not userland visible at all. Signed-off-by: Arnaldo Carvalho de Melo <acme@mandriva.com>
2006-12-02[TCP]: Change tcp_header_len member in tcp_sock to u16Arnaldo Carvalho de Melo
With this we eliminate the last hole in struct tcp_sock. End result: [acme@newtoy net-2.6.20]$ codiff -sV /tmp/tcp.o.before net/ipv4/tcp.o /pub/scm/linux/kernel/git/acme/net-2.6.20/net/ipv4/tcp.c: struct tcp_sock | -4 tcp_header_len; from: int /* 1000(0) 4(0) */ to: u16 /* 1000(0) 2(0) */ 1 struct changed [acme@newtoy net-2.6.20]$ Now sizeof(tcp_sock) is just... [acme@newtoy net-2.6.20]$ pahole --sizes ../OUTPUT/qemu/net-2.6.20/net/ipv4/tcp.o | grep -w tcp_sock struct tcp_sock: 1500 0 1500 bytes ;-) Signed-off-by: Arnaldo Carvalho de Melo <acme@mandriva.com>
2006-12-02[NET]: Annotate checksums in on-the-wire packets.Al Viro
Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-12-02[TCP]: MD5 Signature Option (RFC2385) support.YOSHIFUJI Hideaki
Based on implementation by Rick Payne. Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-10-18[TCP]: Bound TSO defer timeJohn Heffner
This patch limits the amount of time you will defer sending a TSO segment to less than two clock ticks, or the time between two acks, whichever is longer. On slow links, deferring causes significant bursts. See attached plots, which show RTT through a 1 Mbps link with a 100 ms RTT and ~100 ms queue for (a) non-TSO, (b) currnet TSO, and (c) patched TSO. This burstiness causes significant jitter, tends to overflow queues early (bad for short queues), and makes delay-based congestion control more difficult. Deferring by a couple clock ticks I believe will have a relatively small impact on performance. Signed-off-by: John Heffner <jheffner@psc.edu> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-09-28[TCP]: struct tcp_sock .pred_flags is net-endianAl Viro
2006-09-28[TCP]: struct tcp_sack_block annotationsAl Viro
Some of the instances of tcp_sack_block are host-endian, some - net-endian. Define struct tcp_sack_block_wire identical to struct tcp_sack_block with u32 replaced with __be32; annotate uses of tcp_sack_block replacing net-endian ones with tcp_sack_block_wire. Change is obviously safe since for cc(1) __be32 is typedefed to u32. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-09-28[IPV4]: TCP headers annotatedAl Viro
2006-06-23[TCP]: Move inclusion of <linux/dmaengine.h> to correct place in <linux/tcp.h>David Woodhouse
The new <linux/dmaengine.h> header shouldn't be included from the !__KERNEL__ portion of tcp.h Signed-off-by: David Woodhouse <dwmw2@infradead.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-06-20Merge git://git.infradead.org/hdrcleanup-2.6Linus Torvalds
* git://git.infradead.org/hdrcleanup-2.6: (63 commits) [S390] __FD_foo definitions. Switch to __s32 types in joystick.h instead of C99 types for consistency. Add <sys/types.h> to headers included for userspace in <linux/input.h> Move inclusion of <linux/compat.h> out of user scope in asm-x86_64/mtrr.h Remove struct fddi_statistics from user view in <linux/if_fddi.h> Move user-visible parts of drivers/s390/crypto/z90crypt.h to include/asm-s390 Revert include/media changes: Mauro says those ioctls are only used in-kernel(!) Include <linux/types.h> and use __uXX types in <linux/cramfs_fs.h> Use __uXX types in <linux/i2o_dev.h>, include <linux/ioctl.h> too Remove private struct dx_hash_info from public view in <linux/ext3_fs.h> Include <linux/types.h> and use __uXX types in <linux/affs_hardblocks.h> Use __uXX types in <linux/divert.h> for struct divert_blk et al. Use __u32 for elf_addr_t in <asm-powerpc/elf.h>, not u32. It's user-visible. Remove PPP_FCS from user view in <linux/ppp_defs.h>, remove __P mess entirely Use __uXX types in user-visible structures in <linux/nbd.h> Don't use 'u32' in user-visible struct ip_conntrack_old_tuple. Use __uXX types for S390 DASD volume label definitions which are user-visible S390 BIODASDREADCMB ioctl should use __u64 not u64 type. Remove unneeded inclusion of <linux/time.h> from <linux/ufs_fs.h> Fix private integer types used in V4L2 ioctls. ... Manually resolve conflict in include/linux/mtd/physmap.h
2006-06-17[I/OAT]: Structure changes for TCP recv offload to I/OATChris Leech
Adds an async_wait_queue and some additional fields to tcp_sock, and a dma_cookie_t to sk_buff. Signed-off-by: Chris Leech <christopher.leech@intel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-04-26Don't include linux/config.h from anywhere else in include/David Woodhouse
2006-03-20[TCP] mtu probing: move tcp-specific data out of inet_connection_sockJohn Heffner
This moves some TCP-specific MTU probing state out of inet_connection_sock back to tcp_sock. Signed-off-by: John Heffner <jheffner@psc.edu> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-01-03[IP_SOCKGLUE]: Remove most of the tcp specific callsArnaldo Carvalho de Melo
As DCCP needs to be called in the same spots. Now we have a member in inet_sock (is_icsk), set at sock creation time from struct inet_protosw->flags (if INET_PROTOSW_ICSK is set, like for TCP and DCCP) to see if a struct sock instance is a inet_connection_sock for places like the ones in ip_sockglue.c (v4 and v6) where we previously were looking if sk_type was SOCK_STREAM, that is insufficient because we now use the same code for DCCP, that has sk_type SOCK_DCCP. Signed-off-by: Arnaldo Carvalho de Melo <acme@mandriva.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-01-03[TCP]: Move the TCPF_ enum to tcp_states.hArnaldo Carvalho de Melo
Upcoming patches will make, for instance, ip_sockglue.c need just this enum and not all of tcp.h. Signed-off-by: Arnaldo Carvalho de Melo <acme@mandriva.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-01-03[ICSK]: Rename struct tcp_func to struct inet_connection_sock_af_opsArnaldo Carvalho de Melo
And move it to struct inet_connection_sock. DCCP will use it in the upcoming changesets. Signed-off-by: Arnaldo Carvalho de Melo <acme@mandriva.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-11-10[TCP]: speed up SACK processingStephen Hemminger
Use "hints" to speed up the SACK processing. Various forms of this have been used by TCP developers (Web100, STCP, BIC) to avoid the 2x linear search of outstanding segments. Signed-off-by: Stephen Hemminger <shemminger@osdl.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-11-10[TCP]: Appropriate Byte Count supportStephen Hemminger
This is an updated version of the RFC3465 ABC patch originally for Linux 2.6.11-rc4 by Yee-Ting Li. ABC is a way of counting bytes ack'd rather than packets when updating congestion control. The orignal ABC described in the RFC applied to a Reno style algorithm. For advanced congestion control there is little change after leaving slow start. Signed-off-by: Stephen Hemminger <shemminger@osdl.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-08-29[ICSK]: Move TCP congestion avoidance members to icskArnaldo Carvalho de Melo
This changeset basically moves tcp_sk()->{ca_ops,ca_state,etc} to inet_csk(), minimal renaming/moving done in this changeset to ease review. Most of it is just changes of struct tcp_sock * to struct sock * parameters. With this we move to a state closer to two interesting goals: 1. Generalisation of net/ipv4/tcp_diag.c, becoming inet_diag.c, being used for any INET transport protocol that has struct inet_hashinfo and are derived from struct inet_connection_sock. Keeps the userspace API, that will just not display DCCP sockets, while newer versions of tools can support DCCP. 2. INET generic transport pluggable Congestion Avoidance infrastructure, using the current TCP CA infrastructure with DCCP. Signed-off-by: Arnaldo Carvalho de Melo <acme@mandriva.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-08-29[ICSK]: Introduce reqsk_queue_prune from code in tcp_synack_timerArnaldo Carvalho de Melo
With this we're very close to getting all of the current TCP refactorings in my dccp-2.6 tree merged, next changeset will export some functions needed by the current DCCP code and then dccp-2.6.git will be born! Signed-off-by: Arnaldo Carvalho de Melo <acme@ghostprotocols.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-08-29[NET]: Introduce inet_connection_sockArnaldo Carvalho de Melo
This creates struct inet_connection_sock, moving members out of struct tcp_sock that are shareable with other INET connection oriented protocols, such as DCCP, that in my private tree already uses most of these members. The functions that operate on these members were renamed, using a inet_csk_ prefix while not being moved yet to a new file, so as to ease the review of these changes. Signed-off-by: Arnaldo Carvalho de Melo <acme@ghostprotocols.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-08-29[INET]: Generalise tcp_tw_bucket, aka TIME_WAIT socketsArnaldo Carvalho de Melo
This paves the way to generalise the rest of the sock ID lookup routines and saves some bytes in TCPv4 TIME_WAIT sockets on distro kernels (where IPv6 is always built as a module): [root@qemu ~]# grep tw_sock /proc/slabinfo tw_sock_TCPv6 0 0 128 31 1 tw_sock_TCP 0 0 96 41 1 [root@qemu ~]# Now if a protocol wants to use the TIME_WAIT generic infrastructure it only has to set the sk_prot->twsk_obj_size field with the size of its inet_timewait_sock derived sock and proto_register will create sk_prot->twsk_slab, for now its only for INET sockets, but we can introduce timewait_sock later if some non INET transport protocolo wants to use this stuff. Next changesets will take advantage of this new infrastructure to generalise even more TCP code. [acme@toy net-2.6.14]$ grep built-in /tmp/before.size /tmp/after.size /tmp/before.size: 188646 11764 5068 205478 322a6 net/ipv4/built-in.o /tmp/after.size: 188144 11764 5068 204976 320b0 net/ipv4/built-in.o [acme@toy net-2.6.14]$ Tested with both IPv4 & IPv6 (::1 (localhost) & ::ffff:172.20.0.1 (qemu host)). Signed-off-by: Arnaldo Carvalho de Melo <acme@ghostprotocols.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-08-29[TCP]: Move the tcp sock states to net/tcp_states.hArnaldo Carvalho de Melo
Lots of places just needs the states, not even linux/tcp.h, where this enum was, needs it. This speeds up development of the refactorings as less sources are rebuilt when things get moved from net/tcp.h. Signed-off-by: Arnaldo Carvalho de Melo <acme@ghostprotocols.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-08-29[INET]: Move bind_hash from tcp_sk to inet_skArnaldo Carvalho de Melo
This should really be in a inet_connection_sock, but I'm leaving it for a later optimization, when some more fields common to INET transport protocols now in tcp_sk or inet_sk will be chunked out into inet_connection_sock, for now its better to concentrate on getting the changes in the core merged to leave the DCCP tree with only DCCP specific code. Next changesets will take advantage of this move to generalise things like tcp_bind_hash, tcp_put_port, tcp_inherit_port, making the later receive a inet_hashinfo parameter, and even __tcp_tw_hashdance, etc in the future, when tcp_tw_bucket gets transformed into the struct timewait_sock hierarchy. tcp_destroy_sock also is eligible as soon as tcp_orphan_count gets moved to sk_prot. A cascade of incremental changes will ultimately make the tcp_lookup functions be fully generic. Signed-off-by: Arnaldo Carvalho de Melo <acme@ghostprotocols.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-08-29[INET]: Just rename the TCP hashtable functions/structs to inet_Arnaldo Carvalho de Melo
This is to break down the complexity of the series of patches, making it very clear that this one just does: 1. renames tcp_ prefixed hashtable functions and data structures that were already mostly generic to inet_ to share it with DCCP and other INET transport protocols. 2. Removes not used functions (__tb_head & tb_head) 3. Removes some leftover prototypes in the headers (tcp_bucket_unlock & tcp_v4_build_header) Next changesets will move tcp_sk(sk)->bind_hash to inet_sock so that we can make functions such as tcp_inherit_port, __tcp_inherit_port, tcp_v4_get_port, __tcp_put_port, generic and get others like tcp_destroy_sock closer to generic (tcp_orphan_count will go to sk->sk_prot to allow this). Eventually most of these functions will be used passing the transport protocol inet_hashinfo structure. Signed-off-by: Arnaldo Carvalho de Melo <acme@ghostprotocols.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-07-05[TCP]: Move to new TSO segmenting scheme.David S. Miller
Make TSO segment transmit size decisions at send time not earlier. The basic scheme is that we try to build as large a TSO frame as possible when pulling in the user data, but the size of the TSO frame output to the card is determined at transmit time. This is guided by tp->xmit_size_goal. It is always set to a multiple of MSS and tells sendmsg/sendpage how large an SKB to try and build. Later, tcp_write_xmit() and tcp_push_one() chop up the packet if necessary and conditions warrant. These routines can also decide to "defer" in order to wait for more ACKs to arrive and thus allow larger TSO frames to be emitted. A general observation is that TSO elongates the pipe, thus requiring a larger congestion window and larger buffering especially at the sender side. Therefore, it is important that applications 1) get a large enough socket send buffer (this is accomplished by our dynamic send buffer expansion code) 2) do large enough writes. Signed-off-by: David S. Miller <davem@davemloft.net>
2005-06-23[TCP]: Allow choosing TCP congestion control via sockopt.Stephen Hemminger
Allow using setsockopt to set TCP congestion control to use on a per socket basis. Signed-off-by: Stephen Hemminger <shemminger@osdl.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-06-23[TCP]: Add pluggable congestion control algorithm infrastructure.Stephen Hemminger
Allow TCP to have multiple pluggable congestion control algorithms. Algorithms are defined by a set of operations and can be built in or modules. The legacy "new RENO" algorithm is used as a starting point and fallback. Signed-off-by: Stephen Hemminger <shemminger@osdl.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-06-18[NET] Generalise tcp_listen_optArnaldo Carvalho de Melo
This chunks out the accept_queue and tcp_listen_opt code and moves them to net/core/request_sock.c and include/net/request_sock.h, to make it useful for other transport protocols, DCCP being the first one to use it. Next patches will rename tcp_listen_opt to accept_sock and remove the inline tcp functions that just call a reqsk_queue_ function. Signed-off-by: Arnaldo Carvalho de Melo <acme@ghostprotocols.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-06-18[NET] Rename open_request to request_sockArnaldo Carvalho de Melo
Ok, this one just renames some stuff to have a better namespace and to dissassociate it from TCP: struct open_request -> struct request_sock tcp_openreq_alloc -> reqsk_alloc tcp_openreq_free -> reqsk_free tcp_openreq_fastfree -> __reqsk_free With this most of the infrastructure closely resembles a struct sock methods subset. Signed-off-by: Arnaldo Carvalho de Melo <acme@ghostprotocols.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-06-18[NET] Generalise TCP's struct open_request minisock infrastructureArnaldo Carvalho de Melo
Kept this first changeset minimal, without changing existing names to ease peer review. Basicaly tcp_openreq_alloc now receives the or_calltable, that in turn has two new members: ->slab, that replaces tcp_openreq_cachep ->obj_size, to inform the size of the openreq descendant for a specific protocol The protocol specific fields in struct open_request were moved to a class hierarchy, with the things that are common to all connection oriented PF_INET protocols in struct inet_request_sock, the TCP ones in tcp_request_sock, that is an inet_request_sock, that is an open_request. I.e. this uses the same approach used for the struct sock class hierarchy, with sk_prot indicating if the protocol wants to use the open_request infrastructure by filling in sk_prot->rsk_prot with an or_calltable. Results? Performance is improved and TCP v4 now uses only 64 bytes per open request minisock, down from 96 without this patch :-) Next changeset will rename some of the structs, fields and functions mentioned above, struct or_calltable is way unclear, better name it struct request_sock_ops, s/struct open_request/struct request_sock/g, etc. Signed-off-by: Arnaldo Carvalho de Melo <acme@ghostprotocols.net> Signed-off-by: David S. Miller <davem@davemloft.net>
