path: root/include/linux/sysdev.h
2011-10-31sysdev.h: dont include <linux/module.h> for no reasonPaul Gortmaker
The <linux/module.h> pretty much brings in the kitchen sink along with it, so it should be avoided wherever reasonably possible in terms of being included from other commonly used <linux/something.h> files, as it results in a measureable increase on compile times. There doesn't appear to be any module specifics in this file. The obvious people who were relying on the presence of the vast amount of stuff module.h sucked in have been fixed. If other files are implicitly relying on it, then lets see who they are and fix them too. Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2011-05-11PM: Remove sysdev suspend, resume and shutdown operationsRafael J. Wysocki
Since suspend, resume and shutdown operations in struct sysdev_class and struct sysdev_driver are not used any more, remove them. Also drop sysdev_suspend(), sysdev_resume() and sysdev_shutdown() used for executing those operations and modify all of their users accordingly. This reduces kernel code size quite a bit and reduces its complexity. Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Acked-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-03-23Introduce ARCH_NO_SYSDEV_OPS config option (v2)Rafael J. Wysocki
Introduce Kconfig option allowing architectures where sysdev operations used during system suspend, resume and shutdown have been completely replaced with struct sycore_ops operations to avoid building sysdev code that will never be used. Make callbacks in struct sys_device and struct sysdev_driver depend on ARCH_NO_SYSDEV_OPS to allows us to verify if all of the references have been actually removed from the code the given architecture depends on. Make x86 select ARCH_NO_SYSDEV_OPS. Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl>
2010-03-07sysdev: Add sysdev_create/remove_filesAndi Kleen
Allow to create/remove arrays of sysdev attributes Just wrappers around sysfs_create/move_files Will be used later to clean up some drivers. Signed-off-by: Andi Kleen <ak@linux.intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-03-07sysfs: Add attribute array to sysdev classesAndi Kleen
Add a attribute array that is automatically registered and unregistered to struct sysdev_class. This is similar to what struct class has. A lot of drivers add list of attributes, so it's better to do this easily in the common sysdev layer. This adds a new field to struct sysdev_class. I audited the whole tree and there are no dynamically allocated sysdev classes, so this is fully compatible. Signed-off-by: Andi Kleen <ak@linux.intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-03-07sysdev: Pass attribute in sysdev_class attributes show/storeAndi Kleen
Passing the attribute to the low level IO functions allows all kinds of cleanups, by sharing low level IO code without requiring an own function for every piece of data. Also drivers can extend the attributes with own data fields and use that in the low level function. Similar to sysdev_attributes and normal attributes. This is a tree-wide sweep, converting everything in one go. No functional changes in this patch other than passing the new argument everywhere. Tested on x86, the non x86 parts are uncompiled. Signed-off-by: Andi Kleen <ak@linux.intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-07-21sysdev: Add utility functions for simple int/ulong variable sysdev attributesAndi Kleen
This adds a new sysdev_ext_attribute that stores a pointer to the variable it manages and some utility functions/macro to easily use them. Previously all users wrote custom macros to generate show/store functions for each variable, with this it is possible to avoid that in many cases. Signed-off-by: Andi Kleen <ak@linux.intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-07-21sysdev: Pass the attribute to the low level sysdev show/store functionAndi Kleen
This allow to dynamically generate attributes and share show/store functions between attributes. Right now most attributes are generated by special macros and lots of duplicated code. With the attribute passed it's instead possible to attach some data to the attribute and then use that in shared low level functions to do different things. I need this for the dynamically generated bank attributes in the x86 machine check code, but it'll allow some further cleanups. I converted all users in tree to the new show/store prototype. It's a single huge patch to avoid unbisectable sections. Runtime tested: x86-32, x86-64 Compiled only: ia64, powerpc Not compile tested/only grep converted: sh, arm, avr32 Signed-off-by: Andi Kleen <ak@linux.intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-04-19cpumask: add show cpu map functionsMike Travis
* Add cpu_sysdev_class functions to display the following maps with cpulist_scnprintf(). cpu_online_map cpu_present_map cpu_possible_map * Small change to include/linux/sysdev.h to allow the attribute name and label to be different (to avoid collision with the "attr_online" entry for bringing cpus on- and off-line.) Cc: H. Peter Anvin <hpa@zytor.com> Signed-off-by: Mike Travis <travis@sgi.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-01-24Driver core: change sysdev classes to use dynamic kobject namesKay Sievers
All kobjects require a dynamically allocated name now. We no longer need to keep track if the name is statically assigned, we can just unconditionally free() all kobject names on cleanup. Signed-off-by: Kay Sievers <kay.sievers@vrfy.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-07-11sysfs: kill unnecessary attribute->ownerTejun Heo
sysfs is now completely out of driver/module lifetime game. After deletion, a sysfs node doesn't access anything outside sysfs proper, so there's no reason to hold onto the attribute owners. Note that often the wrong modules were accounted for as owners leading to accessing removed modules. This patch kills now unnecessary attribute->owner. Note that with this change, userland holding a sysfs node does not prevent the backing module from being unloaded. For more info regarding lifetime rule cleanup, please read the following message. http://article.gmane.org/gmane.linux.kernel/510293 (tweaked by Greg to not delete the field just yet, to make it easier to merge things properly.) Signed-off-by: Tejun Heo <htejun@gmail.com> Cc: Cornelia Huck <cornelia.huck@de.ibm.com> Cc: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-05-08<linux/sysdev.h> needs to include <linux/module.h>Ralf Baechle
sysdev.h uses THIS_MODULE so should include <linux/module.h>. [akpm@linux-foundation.org: couple of fixes] Signed-off-by: Ralf Baechle <ralf@linux-mips.org> Cc: Andi Kleen <ak@suse.de> Cc: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-07[POWERPC] Introduce _SYSDEV_ATTROlof Johansson
Introduce _SYSDEV_ATTR(), to be used to just define the struct, and not a named variable with the attribute. Useful for arrays of sysdev_attributes. Signed-off-by: Olof Johansson <olof@lixom.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de> Signed-off-by: Paul Mackerras <paulus@samba.org>
2006-06-21[PATCH] Driver Core: Allow sysdev_class have attributesShaohua Li
allow sysdev_class adding attribute. Next patch will use the new API to add an attribute under /sys/device/system/cpu/. Signed-off-by: Shaohua Li <shaohua.li@intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2005-04-16[PATCH] pm_message_t: more fixes in common and i386Pavel Machek
I thought I'm done with fixing u32 vs. pm_message_t ... unfortunately that turned out not to be the case as Russel King pointed out. Here are fixes for Documentation and common code (mainly system devices). Signed-off-by: Pavel Machek <pavel@suse.cz> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
