path: root/include/linux/sunrpc/svc.h
2008-06-23sunrpc: remove sv_kill_signal field from svc_serv structJeff Layton
Since we no longer make any distinction between shutdown signals with nfsd, then it becomes easier to just standardize on a particular signal to use to bring it down (SIGINT, in this case). Signed-off-by: Jeff Layton <jlayton@redhat.com> Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu>
2008-06-23knfsd: convert knfsd to kthread APIJeff Layton
This patch is rather large, but I couldn't figure out a way to break it up that would remain bisectable. It does several things: - change svc_thread_fn typedef to better match what kthread_create expects - change svc_pool_map_set_cpumask to be more kthread friendly. Make it take a task arg and and get rid of the "oldmask" - have svc_set_num_threads call kthread_create directly - eliminate __svc_create_thread Signed-off-by: Jeff Layton <jlayton@redhat.com> Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu>
2008-04-23SUNRPC: remove svc_create_thread()Jeff Layton
Now that the nfs4 callback thread uses the kthread API, there are no more users of svc_create_thread(). Remove it. Signed-off-by: Jeff Layton <jlayton@redhat.com> Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu>
2008-02-10nfsd: clean up svc_reserve_auth()J. Bruce Fields
This is a void function attempting to return the return value from another void function, which seems harmless but extremely weird, and apparently makes some compilers complain. While we're there, clean up a little (e.g. the switch statement had a minor style problem and seemed overkill as long as there's only one case). Thanks to Trond for noticing this. Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu> Cc: Trond Myklebust <Trond.Myklebust@netapp.com>
2008-02-01SUNRPC: spin svc_rqst initialization to its own functionJeff Layton
Move the initialzation in __svc_create_thread that happens prior to thread creation to a new function. Export the function to allow services to have better control over the svc_rqst structs. Also rearrange the rqstp initialization to prevent NULL pointer dereferences in svc_exit_thread in case allocations fail. Signed-off-by: Jeff Layton <jlayton@redhat.com> Reviewed-by: NeilBrown <neilb@suse.de> Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu>
2008-02-01svc: Add transport hdr size for defer/revisitTom Tucker
Some transports have a header in front of the RPC header. The current defer/revisit processing considers only the iov_len and arg_len to determine how much to back up when saving the original request to revisit. Add a field to the rqstp structure to save the size of the transport header so svc_defer can correctly compute the start of a request. Signed-off-by: Tom Tucker <tom@opengridcomputing.com> Acked-by: Neil Brown <neilb@suse.de> Reviewed-by: Chuck Lever <chuck.lever@oracle.com> Reviewed-by: Greg Banks <gnb@sgi.com> Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu>
2008-02-01svc: Removing remaining references to rq_sock in rqstpTom Tucker
This functionally empty patch removes rq_sock and unamed union from rqstp structure. Signed-off-by: Tom Tucker <tom@opengridcomputing.com> Acked-by: Neil Brown <neilb@suse.de> Reviewed-by: Chuck Lever <chuck.lever@oracle.com> Reviewed-by: Greg Banks <gnb@sgi.com> Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu>
2008-02-01svc: Make deferral processing xprt independentTom Tucker
This patch moves the transport independent sk_deferred list to the svc_xprt structure and updates the svc_deferred_req structure to keep pointers to svc_xprt's directly. The deferral processing code is also moved out of the transport dependent recvfrom functions and into the generic svc_recv path. Signed-off-by: Tom Tucker <tom@opengridcomputing.com> Acked-by: Neil Brown <neilb@suse.de> Reviewed-by: Chuck Lever <chuck.lever@oracle.com> Reviewed-by: Greg Banks <gnb@sgi.com> Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu>
2008-02-01svc: Add transport specific xpo_release functionTom Tucker
The svc_sock_release function releases pages allocated to a thread. For UDP this frees the receive skb. For RDMA it will post a receive WR and bump the client credit count. Signed-off-by: Tom Tucker <tom@opengridcomputing.com> Acked-by: Neil Brown <neilb@suse.de> Reviewed-by: Chuck Lever <chuck.lever@oracle.com> Reviewed-by: Greg Banks <gnb@sgi.com> Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu>
2008-02-01svc: Change the svc_sock in the rqstp structure to a transportTom Tucker
The rqstp structure contains a pointer to the transport for the RPC request. This functionaly trivial patch adds an unamed union with pointers to both svc_sock and svc_xprt. Ultimately the union will be removed and only the rq_xprt field will remain. This allows incrementally extracting transport independent interfaces without one gigundo patch. Signed-off-by: Tom Tucker <tom@opengridcomputing.com> Acked-by: Neil Brown <neilb@suse.de> Reviewed-by: Chuck Lever <chuck.lever@oracle.com> Reviewed-by: Greg Banks <gnb@sgi.com> Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu>
2007-07-17knfsd: nfsd: set rq_client to ip-address-determined-domainJ. Bruce Fields
We want it to be possible for users to restrict exports both by IP address and by pseudoflavor. The pseudoflavor information has previously been passed using special auth_domains stored in the rq_client field. After the preceding patch that stored the pseudoflavor in rq_pflavor, that's now superfluous; so now we use rq_client for the ip information, as auth_null and auth_unix do. However, we keep around the special auth_domain in the rq_gssclient field for backwards compatibility purposes, so we can still do upcalls using the old "gss/pseudoflavor" auth_domain if upcalls using the unix domain to give us an appropriate export. This allows us to continue supporting old mountd. In fact, for this first patch, we always use the "gss/pseudoflavor" auth_domain (and only it) if it is available; thus rq_client is ignored in the auth_gss case, and this patch on its own makes no change in behavior; that will be left to later patches. Note on idmap: I'm almost tempted to just replace the auth_domain in the idmap upcall by a dummy value--no version of idmapd has ever used it, and it's unlikely anyone really wants to perform idmapping differently depending on the where the client is (they may want to perform *credential* mapping differently, but that's a different matter--the idmapper just handles id's used in getattr and setattr). But I'm updating the idmapd code anyway, just out of general backwards-compatibility paranoia. Signed-off-by: "J. Bruce Fields" <bfields@citi.umich.edu> Signed-off-by: Neil Brown <neilb@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-17knfsd: nfsd4: store pseudoflavor in requestAndy Adamson
Add a new field to the svc_rqst structure to record the pseudoflavor that the request was made with. For now we record the pseudoflavor but don't use it for anything. Signed-off-by: Andy Adamson <andros@citi.umich.edu> Signed-off-by: "J. Bruce Fields" <bfields@citi.umich.edu> Signed-off-by: Neil Brown <neilb@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-10sendfile: convert nfsd to splice_direct_to_actor()Jens Axboe
2007-05-09RPC: add wrapper for svc_reserve to account for checksumJeff Layton
When the kernel calls svc_reserve to downsize the expected size of an RPC reply, it fails to account for the possibility of a checksum at the end of the packet. If a client mounts a NFSv2/3 with sec=krb5i/p, and does I/O then you'll generally see messages similar to this in the server's ring buffer: RPC request reserved 164 but used 208 While I was never able to verify it, I suspect that this problem is also the root cause of some oopses I've seen under these conditions: https://bugzilla.redhat.com/bugzilla/show_bug.cgi?id=227726 This is probably also a problem for other sec= types and for NFSv4. The large reserved size for NFSv4 compound packets seems to generally paper over the problem, however. This patch adds a wrapper for svc_reserve that accounts for the possibility of a checksum. It also fixes up the appropriate callers of svc_reserve to call the wrapper. For now, it just uses a hardcoded value that I determined via testing. That value may need to be revised upward as things change, or we may want to eventually add a new auth_op that attempts to calculate this somehow. Unfortunately, there doesn't seem to be a good way to reliably determine the expected checksum length prior to actually calculating it, particularly with schemes like spkm3. Signed-off-by: Jeff Layton <jlayton@redhat.com> Acked-by: Neil Brown <neilb@suse.de> Cc: Trond Myklebust <trond.myklebust@fys.uio.no> Acked-by: J. Bruce Fields <bfields@citi.umich.edu> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-03-06[PATCH] knfsd: remove CONFIG_IPV6 ifdefs from sunrpc server codeNeilBrown
They don't really save that much, and aren't worth the hassle. Signed-off-by: Neil Brown <neilb@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-12[PATCH] knfsd: SUNRPC: support IPv6 addresses in RPC server's UDP receive pathChuck Lever
Add support for IPv6 addresses in the RPC server's UDP receive path. [akpm@linux-foundation.org: cleanups] Signed-off-by: Chuck Lever <chuck.lever@oracle.com> Cc: Aurelien Charbon <aurelien.charbon@ext.bull.net> Signed-off-by: Neil Brown <neilb@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-12[PATCH] knfsd: SUNRPC: Make rq_daddr field address-version independentChuck Lever
The rq_daddr field must support larger addresses. Signed-off-by: Chuck Lever <chuck.lever@oracle.com> Cc: Aurelien Charbon <aurelien.charbon@ext.bull.net> Signed-off-by: Neil Brown <neilb@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-12[PATCH] knfsd: SUNRPC: Provide room in svc_rqst for larger addressesChuck Lever
Expand the rq_addr field to allow it to contain larger addresses. Specifically, we replace a 'sockaddr_in' with a 'sockaddr_storage', then everywhere the 'sockaddr_in' was referenced, we use instead an accessor function (svc_addr_in) which safely casts the _storage to _in. Signed-off-by: Chuck Lever <chuck.lever@oracle.com> Cc: Aurelien Charbon <aurelien.charbon@ext.bull.net> Signed-off-by: Neil Brown <neilb@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-12[PATCH] knfsd: SUNRPC: Use sockaddr_storage to store address in svc_deferred_reqChuck Lever
Sockaddr_storage will allow us to store arbitrary socket addresses in the svc_deferred_req struct. Signed-off-by: Chuck Lever <chuck.lever@oracle.com> Cc: Aurelien Charbon <aurelien.charbon@ext.bull.net> Signed-off-by: Neil Brown <neilb@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-12[PATCH] knfsd: SUNRPC: Add a function to format the address in an svc_rqst ↵Chuck Lever
for printing There are loads of places where the RPC server assumes that the rq_addr fields contains an IPv4 address. Top among these are error and debugging messages that display the server's IP address. Let's refactor the address printing into a separate function that's smart enough to figure out the difference between IPv4 and IPv6 addresses. Signed-off-by: Chuck Lever <chuck.lever@oracle.com> Cc: Aurelien Charbon <aurelien.charbon@ext.bull.net> Signed-off-by: Neil Brown <neilb@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-01-26[PATCH] knfsd: fix an NFSD bug with full sized, non-page-aligned readsNeilBrown
NFSd assumes that largest number of pages that will be needed for a request+response is 2+N where N pages is the size of the largest permitted read/write request. The '2' are 1 for the non-data part of the request, and 1 for the non-data part of the reply. However, when a read request is not page-aligned, and we choose to use ->sendfile to send it directly from the page cache, we may need N+1 pages to hold the whole reply. This can overflow and array and cause an Oops. This patch increases size of the array for holding pages by one and makes sure that entry is NULL when it is not in use. Signed-off-by: Neil Brown <neilb@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2006-10-20[PATCH] fix svc_procfunc declarationAl Viro
svc_procfunc instances return __be32, not int Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Acked-by: Trond Myklebust <trond.myklebust@fys.uio.no> Acked-by: Neil Brown <neilb@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-06[PATCH] knfsd: tidy up up meaning of 'buffer size' in nfsd/sunrpcNeilBrown
There is some confusion about the meaning of 'bufsz' for a sunrpc server. In some cases it is the largest message that can be sent or received. In other cases it is the largest 'payload' that can be included in a NFS message. In either case, it is not possible for both the request and the reply to be this large. One of the request or reply may only be one page long, which fits nicely with NFS. So we remove 'bufsz' and replace it with two numbers: 'max_payload' and 'max_mesg'. Max_payload is the size that the server requests. It is used by the server to check the max size allowed on a particular connection: depending on the protocol a lower limit might be used. max_mesg is the largest single message that can be sent or received. It is calculated as the max_payload, rounded up to a multiple of PAGE_SIZE, and with PAGE_SIZE added to overhead. Only one of the request and reply may be this size. The other must be at most one page. Cc: Greg Banks <gnb@sgi.com> Cc: "J. Bruce Fields" <bfields@fieldses.org> Signed-off-by: Neil Brown <neilb@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-04[PATCH] knfsd: register all RPC programs with portmapper by defaultOlaf Kirch
The NFSACL patches introduced support for multiple RPC services listening on the same transport. However, only the first of these services was registered with portmapper. This was perfectly fine for nfsacl, as you traditionally do not want these to show up in a portmapper listing. The patch below changes the default behavior to always register all services listening on a given transport, but retains the old behavior for nfsacl services. Signed-off-by: Olaf Kirch <okir@suse.de> Signed-off-by: Neil Brown <neilb@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-04[PATCH] knfsd: Prepare knfsd for support of rsize/wsize of up to 1MB, over TCPGreg Banks
The limit over UDP remains at 32K. Also, make some of the apparently arbitrary sizing constants clearer. The biggest change here involves replacing NFSSVC_MAXBLKSIZE by a function of the rqstp. This allows it to be different for different protocols (udp/tcp) and also allows it to depend on the servers declared sv_bufsiz. Note that we don't actually increase sv_bufsz for nfs yet. That comes next. Signed-off-by: Greg Banks <gnb@melbourne.sgi.com> Signed-off-by: Neil Brown <neilb@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-04[PATCH] knfsd: Avoid excess stack usage in svc_tcp_recvfromNeilBrown
.. by allocating the array of 'kvec' in 'struct svc_rqst'. As we plan to increase RPCSVC_MAXPAGES from 8 upto 256, we can no longer allocate an array of this size on the stack. So we allocate it in 'struct svc_rqst'. However svc_rqst contains (indirectly) an array of the same type and size (actually several, but they are in a union). So rather than waste space, we move those arrays out of the separately allocated union and into svc_rqst to share with the kvec moved out of svc_tcp_recvfrom (various arrays are used at different times, so there is no conflict). Signed-off-by: Neil Brown <neilb@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-04[PATCH] knfsd: Replace two page lists in struct svc_rqst with oneNeilBrown
We are planning to increase RPCSVC_MAXPAGES from about 8 to about 256. This means we need to be a bit careful about arrays of size RPCSVC_MAXPAGES. struct svc_rqst contains two such arrays. However the there are never more that RPCSVC_MAXPAGES pages in the two arrays together, so only one array is needed. The two arrays are for the pages holding the request, and the pages holding the reply. Instead of two arrays, we can simply keep an index into where the first reply page is. This patch also removes a number of small inline functions that probably server to obscure what is going on rather than clarify it, and opencode the needed functionality. Also remove the 'rq_restailpage' variable as it is *always* 0. i.e. if the response 'xdr' structure has a non-empty tail it is always in the same pages as the head. check counters are initilised and incr properly check for consistant usage of ++ etc maybe extra some inlines for common approach general review Signed-off-by: Neil Brown <neilb@suse.de> Cc: Magnus Maatta <novell@kiruna.se> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-02[PATCH] knfsd: make rpc threads pools numa awareGreg Banks
Actually implement multiple pools. On NUMA machines, allocate a svc_pool per NUMA node; on SMP a svc_pool per CPU; otherwise a single global pool. Enqueue sockets on the svc_pool corresponding to the CPU on which the socket bh is run (i.e. the NIC interrupt CPU). Threads have their cpu mask set to limit them to the CPUs in the svc_pool that owns them. This is the patch that allows an Altix to scale NFS traffic linearly beyond 4 CPUs and 4 NICs. Incorporates changes and feedback from Neil Brown, Trond Myklebust, and Christoph Hellwig. Signed-off-by: Greg Banks <gnb@melbourne.sgi.com> Signed-off-by: Neil Brown <neilb@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-02[PATCH] knfsd: add svc_set_num_threadsGreg Banks
Currently knfsd keeps its own list of all nfsd threads in nfssvc.c; add a new way of managing the list of all threads in a svc_serv. Add svc_create_pooled() to allow creation of a svc_serv whose threads are managed by the sunrpc code. Add svc_set_num_threads() to manage the number of threads in a service, either per-pool or globally across the service. Signed-off-by: Greg Banks <gnb@melbourne.sgi.com> Signed-off-by: Neil Brown <neilb@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-02[PATCH] knfsd: add svc_getGreg Banks
add svc_get() for those occasions when we need to temporarily bump up svc_serv->sv_nrthreads as a pseudo refcount. Signed-off-by: Greg Banks <gnb@melbourne.sgi.com> Signed-off-by: Neil Brown <neilb@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-02[PATCH] knfsd: split svc_serv into poolsGreg Banks
Split out the list of idle threads and pending sockets from svc_serv into a new svc_pool structure, and allocate a fixed number (in this patch, 1) of pools per svc_serv. The new structure contains a lock which takes over several of the duties of svc_serv->sv_lock, which is now relegated to protecting only sv_tempsocks, sv_permsocks, and sv_tmpcnt in svc_serv. The point is to move the hottest fields out of svc_serv and into svc_pool, allowing a following patch to arrange for a svc_pool per NUMA node or per CPU. This is a major step towards making the NFS server NUMA-friendly. Signed-off-by: Greg Banks <gnb@melbourne.sgi.com> Signed-off-by: Neil Brown <neilb@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-02[PATCH] knfsd: move tempsock aging to a timerGreg Banks
Following are 11 patches from Greg Banks which combine to make knfsd more Numa-aware. They reduce hitting on 'global' data structures, and create some data-structures that can be node-local. knfsd threads are bound to a particular node, and the thread to handle a new request is chosen from the threads that are attach to the node that received the interrupt. The distribution of threads across nodes can be controlled by a new file in the 'nfsd' filesystem, though the default approach of an even spread is probably fine for most sites. Some (old) numbers that show the efficacy of these patches: N == number of NICs == number of CPUs == nmber of clients. Number of NUMA nodes == N/2 N Throughput, MiB/s CPU usage, % (max=N*100) Before After Before After --- ------ ---- ----- ----- 4 312 435 350 228 6 500 656 501 418 8 562 804 690 589 This patch: Move the aging of RPC/TCP connection sockets from the main svc_recv() loop to a timer which uses a mark-and-sweep algorithm every 6 minutes. This reduces the amount of work that needs to be done in the main RPC loop and the length of time we need to hold the (effectively global) svc_serv->sv_lock. [akpm@osdl.org: cleanup] Signed-off-by: Greg Banks <gnb@melbourne.sgi.com> Signed-off-by: Neil Brown <neilb@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-02[PATCH] knfsd: Drop 'serv' option to svc_recv and svc_processNeilBrown
It isn't needed as it is available in rqstp->rq_server, and dropping it allows some local vars to be dropped. [akpm@osdl.org: build fix] Cc: "J. Bruce Fields" <bfields@fieldses.org> Signed-off-by: Neil Brown <neilb@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-02[PATCH] knfsd: add a callback for when last rpc thread finishesNeilBrown
nfsd has some cleanup that it wants to do when the last thread exits, and there will shortly be some more. So collect this all into one place and define a callback for an rpc service to call when the service is about to be destroyed. [akpm@osdl.org: cleanups, build fix] Signed-off-by: Neil Brown <neilb@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-09-28[SUNRPC]: trivial endianness annotationsAlexey Dobriyan
pure s/u32/__be32/ [AV: large part based on Alexey's patches] Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-09-28[SUNRPC]: svc_{get,put}nl()Alexey Dobriyan
* add svc_getnl(): Take network-endian value from buffer, convert to host-endian and return it. * add svc_putnl(): Take host-endian value, convert to network-endian and put it into a buffer. * annotate svc_getu32()/svc_putu32() as dealing with network-endian. * convert to svc_getnl(), svc_putnl(). [AV: in large part it's a carved-up Alexey's patch] Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-06-30[PATCH] knfsd: nfsd: mark rqstp to prevent use of sendfile in privacy caseJ. Bruce Fields
Add a rq_sendfile_ok flag to svc_rqst which will be cleared in the privacy case so that the wrapping code will get copies of the read data instead of real page cache pages. This makes life simpler when we encrypt the response. Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu> Signed-off-by: Neil Brown <neilb@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-04-11[PATCH] knfsd: svcrpc: WARN() instead of returning an error from svc_take_pageJ. Bruce Fields
Every caller of svc_take_page ignores its return value and assumes it succeeded. So just WARN() instead of returning an ignored error. This would have saved some time debugging a recent nfsd4 problem. If there are still failure cases here, then the result is probably that we overwrite an earlier part of the reply while xdr-encoding. While the corrupted reply is a nasty bug, it would be worse to panic here and create the possibility of a remote DOS; hence WARN() instead of BUG(). Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu> Signed-off-by: Neil Brown <neilb@suse.de> Cc: Ingo Oeser <ioe-lkml@rameria.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-18[PATCH] svcrpc: save and restore the daddr field when request deferredJ. Bruce Fields
The server code currently keeps track of the destination address on every request so that it can reply using the same address. However we forget to do that in the case of a deferred request. Remedy this oversight. >From folks at PolyServe. Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu> Signed-off-by: Neil Brown <neilb@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-07[PATCH] knfsd: Fix some minor sign problems in nfsd/xdrNeilBrown
There are a couple of tests which could possibly be confused by extremely large numbers appearing in 'xdr' packets. I think the closest to an exploit you could get would be writing random data from a free page into a file - i.e. leak data out of kernel space. I'm fairly sure they cannot be used for remote compromise. Signed-off-by: Neil Brown <neilb@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-22[PATCH] NFSD: Add server support for NFSv3 ACLs.Andreas Gruenbacher
This adds functions for encoding and decoding POSIX ACLs for the NFSACL protocol extension, and the GETACL and SETACL RPCs. The implementation is compatible with NFSACL in Solaris. Signed-off-by: Andreas Gruenbacher <agruen@suse.de> Acked-by: Olaf Kirch <okir@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2005-06-22[PATCH] RPC: Allow the sunrpc server to multiplex serveral programs on a ↵Andreas Gruenbacher
single port The NFS and NFSACL programs run on the same RPC transport. This patch adds support for this by converting svc_program into a chained list of programs (server-side). Signed-off-by: Andreas Gruenbacher <agruen@suse.de> Signed-off-by: Olaf Kirch <okir@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
