path: root/include/linux/sunrpc/debug.h
2008-02-01svc: Make svc_sock the tcp/udp transportTom Tucker
Make TCP and UDP svc_sock transports, and register them with the svc transport core. A transport type (svc_sock) has an svc_xprt as its first member, and calls svc_xprt_init to initialize this field. Signed-off-by: Tom Tucker <tom@opengridcomputing.com> Acked-by: Neil Brown <neilb@suse.de> Reviewed-by: Chuck Lever <chuck.lever@oracle.com> Reviewed-by: Greg Banks <gnb@sgi.com> Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu>
2008-02-01svc: Add an svc transport classTom Tucker
The transport class (svc_xprt_class) represents a type of transport, e.g. udp, tcp, rdma. A transport class has a unique name and a set of transport operations kept in the svc_xprt_ops structure. A transport class can be dynamically registered and unregisterd. The svc_xprt_class represents the module that implements the transport type and keeps reference counts on the module to avoid unloading while there are active users. The endpoint (svc_xprt) is a generic, transport independent endpoint that can be used to send and receive data for an RPC service. It inherits it's operations from the transport class. A transport driver module registers and unregisters itself with svc sunrpc by calling svc_reg_xprt_class, and svc_unreg_xprt_class respectively. Signed-off-by: Tom Tucker <tom@opengridcomputing.com> Acked-by: Neil Brown <neilb@suse.de> Reviewed-by: Chuck Lever <chuck.lever@oracle.com> Reviewed-by: Greg Banks <gnb@sgi.com> Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu>
2007-11-26SUNRPC: remove NFS/RDMA client's binary sysctlsJames Lentini
Support for binary sysctls is being deprecated in 2.6.24. Since there are no applications using the NFS/RDMA client's binary sysctls, it makes sense to remove them. The patch below does this while leaving the /proc/sys interface unchanged. Please consider this for 2.6.24. Signed-off-by: James Lentini <jlentini@netapp.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2007-10-09RPCRDMA: rpc rdma transport switch\"Talpey, Thomas\
This implements the configuration and building of the core transport switch implementation of the rpcrdma transport. Stubs are provided for the rpcrdma protocol handling, and the infiniband/iwarp verbs interface. These are provided in following patches. Signed-off-by: Tom Talpey <talpey@netapp.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2007-04-30SUNRPC: remove old portmapperChuck Lever
net/sunrpc/pmap_clnt.c has been replaced by net/sunrpc/rpcb_clnt.c. Signed-off-by: Chuck Lever <chuck.lever@oracle.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2007-04-30SUNRPC: introduce rpcbind: replacement for in-kernel portmapperChuck Lever
Introduce a replacement for the in-kernel portmapper client that supports all 3 versions of the rpcbind protocol. This code is not used yet. Original code by Groupe Bull updated for the latest kernel, with multiple bug fixes. Note that rpcb_clnt.c does not yet support registering via versions 3 and 4 of the rpcbind protocol. That is planned for a later patch. Signed-off-by: Chuck Lever <chuck.lever@oracle.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2007-02-14[PATCH] sysctl: move CTL_SUNRPC to sysctl.h where it belongsEric W. Biederman
Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Cc: Trond Myklebust <trond.myklebust@fys.uio.no> Cc: Neil Brown <neilb@cse.unsw.edu.au> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2006-12-06SUNRPC: Remove pprintk() from net/sunrpc/xprt.cChuck Lever
These appear to be deprecated. Removing them also gets rid of some sparse noise. Signed-off-by: Chuck Lever <chuck.lever@oracle.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2006-04-26Don't include linux/config.h from anywhere else in include/David Woodhouse
2006-04-25Sanitise linux/sunrpc/debug.h for userspace consumptionDavid Woodhouse
Move some inclusion of private header files and the definition of RPC_DEBUG inside the existing #ifdef __KERNEL__ Signed-off-by: David Woodhouse <dwmw2@infradead.org>
2005-09-23[PATCH] RPC: allow RPC client's port range to be adjustableChuck Lever
Select an RPC client source port between 650 and 1023 instead of between 1 and 800. The old range conflicts with a number of network services. Provide sysctls to allow admins to select a different port range. Note that this doesn't affect user-level RPC library behavior, which still uses 1 to 800. Based on a suggestion by Olaf Kirch <okir@suse.de>. Test-plan: Repeated mount and unmount. Destructive testing. Idle timeouts. Signed-off-by: Chuck Lever <cel@netapp.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2005-09-23[PATCH] RPC: transport switch function namingChuck Lever
Introduce block header comments and a function naming convention to the socket transport implementation. Provide a debug setting for transports that is separate from RPCDBG_XPRT. Eliminate xprt_default_timeout(). Provide block comments for exposed interfaces in xprt.c, and eliminate the useless obvious comments. Convert printk's to dprintk's. Test-plan: Compile kernel with CONFIG_NFS enabled. Version: Thu, 11 Aug 2005 16:04:04 -0400 Signed-off-by: Chuck Lever <cel@netapp.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
