path: root/include/linux/sunrpc/clnt.h
2009-06-17nfs41: sunrpc: Export the call prepare state for session resetAndy Adamson
Signed-off-by: Andy Adamson<andros@netapp.com> Signed-off-by: Benny Halevy <bhalevy@panasas.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2008-12-23rpc: pass target name down to rpc level on callbacksOlga Kornievskaia
The rpc client needs to know the principal that the setclientid was done as, so it can tell gssd who to authenticate to. Signed-off-by: Olga Kornievskaia <aglo@citi.umich.edu> Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2008-09-29nfsd: use nfs client rpc callback programBenny Halevy
since commit ff7d9756b501744540be65e172d27ee321d86103 "nfsd: use static memory for callback program and stats" do_probe_callback uses a static callback program (NFS4_CALLBACK) rather than the one set in clp->cl_callback.cb_prog as passed in by the client in setclientid (4.0) or create_session (4.1). This patches introduces rpc_create_args.prognumber that allows overriding program->number when creating rpc_clnt. Signed-off-by: Benny Halevy <bhalevy@panasas.com> Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu>
2008-09-29SUNRPC: Simplify rpcb_register() APIChuck Lever
Bruce suggested there's no need to expose the difference between an error sending the PMAP_SET request and an error reply from the portmapper to rpcb_register's callers. The user space equivalent of rpcb_register() is pmap_set(3), which returns a bool_t : either the PMAP set worked, or it didn't. Simple. So let's remove the "*okay" argument from rpcb_register() and rpcb_v4_register(), and simply return an error if any part of the call didn't work. Signed-off-by: Chuck Lever <chuck.lever@oracle.com> Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu>
2008-07-15SUNRPC: Support registering IPv6 interfaces with local rpcbind daemonChuck Lever
Introduce a new API to register RPC services on IPv6 interfaces to allow the NFS server and lockd to advertise on IPv6 networks. Unlike rpcb_register(), the new rpcb_v4_register() function uses rpcbind protocol version 4 to contact the local rpcbind daemon. The version 4 SET/UNSET procedures allow services to register address families besides AF_INET, register at specific network interfaces, and register transport protocols besides UDP and TCP. All of this functionality is exposed via the new rpcb_v4_register() kernel API. A user-space rpcbind daemon implementation that supports version 4 of the rpcbind protocol is required in order to make use of this new API. Note that rpcbind version 3 is sufficient to support the new rpcbind facilities listed above, but most extant implementations use version 4. Signed-off-by: Chuck Lever <chuck.lever@oracle.com> Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2008-07-09rpc: bring back cl_chattyOlga Kornievskaia
The cl_chatty flag alows us to control whether a given rpc client leaves "server X not responding, timed out" messages in the syslog. Such messages make sense for ordinary nfs clients (where an unresponsive server means applications on the mountpoint are probably hanging), but not for the callback client (which can fail more commonly, with the only result just of disabling some optimizations). Previously cl_chatty was removed, do to lack of users; reinstate it, and use it for the nfsd's callback client. Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2008-02-14SUNRPC: Declare as const the rpc_message arguments to rpc_call_sync/asyncTrond Myklebust
2008-02-01Merge branch 'task_killable' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/willy/misc * 'task_killable' of git://git.kernel.org/pub/scm/linux/kernel/git/willy/misc: (22 commits) Remove commented-out code copied from NFS NFS: Switch from intr mount option to TASK_KILLABLE Add wait_for_completion_killable Add wait_event_killable Add schedule_timeout_killable Use mutex_lock_killable in vfs_readdir Add mutex_lock_killable Use lock_page_killable Add lock_page_killable Add fatal_signal_pending Add TASK_WAKEKILL exit: Use task_is_* signal: Use task_is_* sched: Use task_contributes_to_load, TASK_ALL and TASK_NORMAL ptrace: Use task_is_* power: Use task_is_* wait: Use TASK_NORMAL proc/base.c: Use task_is_* proc/array.c: Use TASK_REPORT perfmon: Use task_is_* ... Fixed up conflicts in NFS/sunrpc manually..
2008-01-30SUNRPC: Use appropriate argument types in rpcb clientChuck Lever
Clean up: Follow recommendations of Chapter 5 of Documentation/CodingStyle and use "u32" instead of "__u32" for types in definitions that are not shared with user space. Signed-off-by: Chuck Lever <chuck.lever@oracle.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2008-01-30SUNRPC: fewer conditionals in the format_ip_address routinesChuck Lever
Clean up: have the set up routines explicitly pass the strings to be used for the transport name and NETID. This removes a number of conditionals and dependencies on rpc_xprt.prot, which is overloaded. Tighten up type checking on the address_strings array while we're at it. Signed-off-by: Chuck Lever <chuck.lever@oracle.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2008-01-30SUNRPC: Add support for per-client timeout valuesTrond Myklebust
In order to be able to support setting the timeo and retrans parameters on a per-mountpoint basis, we move the rpc_timeout structure into the rpc_clnt. Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2008-01-30SUNRPC: Remove the now unused function rpc_call_setup()Trond Myklebust
2008-01-30SUNRPC: Add a helper rpc_call_start() that initialises task->tk_actionTrond Myklebust
2008-01-30SUNRPC: Cleanup of rpc_task initialisationTrond Myklebust
2007-12-06NFS: Switch from intr mount option to TASK_KILLABLEMatthew Wilcox
By using the TASK_KILLABLE infrastructure, we can get rid of the 'intr' mount option. We have to use _killable everywhere instead of _interruptible as we get rid of rpc_clnt_sigmask/sigunmask. Signed-off-by: Liam R. Howlett <howlett@gmail.com> Signed-off-by: Matthew Wilcox <willy@linux.intel.com>
2007-10-09SUNRPC: fix a signed v. unsigned comparison nit in rpc_bind_new_programChuck Lever
/home/cel/linux/net/sunrpc/clnt.c: In function ‘rpc_bind_new_program’: /home/cel/linux/net/sunrpc/clnt.c:445: warning: comparison between signed and unsigned RPC version numbers are u32, not int. Signed-off-by: Chuck Lever <chuck.lever@oracle.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2007-07-10SUNRPC client: add interface for binding to a local addressFrank van Maarseveen
In addition to binding to a local privileged port the NFS client should allow binding to a specific local address. This is used by the server for callbacks. The patch adds the necessary interface. Signed-off-by: Frank van Maarseveen <frankvm@frankvm.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2007-07-10SUNRPC: Rename rpcb_getport to be consistent with new rpcb_getport_sync nameChuck Lever
Clean up, for consistency. Rename rpcb_getport as rpcb_getport_async, to match the naming scheme of rpcb_getport_sync. Signed-off-by: Chuck Lever <chuck.lever@oracle.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2007-07-10SUNRPC: Rename rpcb_getport_external routineChuck Lever
In preparation for handling NFS mount option parsing in the kernel, rename rpcb_getport_external as rpcb_get_port_sync, and make it available always (instead of only when CONFIG_ROOT_NFS is enabled). Signed-off-by: Chuck Lever <chuck.lever@oracle.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2007-07-10SUNRPC: Add the helper function 'rpc_call_null()'Trond Myklebust
Does a NULL RPC call and returns a pointer to the resulting rpc_task. The call may be either synchronous or asynchronous. Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2007-07-10SUNRPC: Make rpc_ping() staticTrond Myklebust
2007-07-10SUNRPC: Move rpc_register_client and friends into net/sunrpc/clnt.cTrond Myklebust
2007-07-10SUNRPC: Remove rpc_clnt->cl_countTrond Myklebust
The kref now does most of what cl_count + cl_user used to do. The only remaining role for cl_count is to tell us if we are in a 'shutdown' phase. We can provide that information using a single bit field instead of a full atomic counter. Also rename rpc_destroy_client() to rpc_close_client(), which reflects better what its role is these days. Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2007-07-10SUNRPC: Kill rpc_clnt->cl_oneshotTrond Myklebust
Replace it with explicit calls to rpc_shutdown_client() or rpc_destroy_client() (for the case of asynchronous calls). Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2007-07-10SUNRPC: Kill rpc_clnt->cl_deadTrond Myklebust
Its use is at best racy, and there is only one user (lockd), which has additional locking that makes the whole thing redundant. Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2007-07-10SUNRPC: Convert rpc_clnt->cl_users to a krefTrond Myklebust
2007-07-10SUNRPC: Add a per-rpc_clnt spinlockTrond Myklebust
Use that to protect the rpc_clnt->cl_tasks list instead of using a global lock. Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2007-07-10SUNRPC: Move rpc_task->tk_task list into struct rpc_clntTrond Myklebust
2007-04-30SUNRPC: remove old portmapperChuck Lever
net/sunrpc/pmap_clnt.c has been replaced by net/sunrpc/rpcb_clnt.c. Signed-off-by: Chuck Lever <chuck.lever@oracle.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2007-04-30SUNRPC: introduce rpcbind: replacement for in-kernel portmapperChuck Lever
Introduce a replacement for the in-kernel portmapper client that supports all 3 versions of the rpcbind protocol. This code is not used yet. Original code by Groupe Bull updated for the latest kernel, with multiple bug fixes. Note that rpcb_clnt.c does not yet support registering via versions 3 and 4 of the rpcbind protocol. That is planned for a later patch. Signed-off-by: Chuck Lever <chuck.lever@oracle.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2007-04-30SUNRPC: RPC buffer size estimates are too largeChuck Lever
The RPC buffer size estimation logic in net/sunrpc/clnt.c always significantly overestimates the requirements for the buffer size. A little instrumentation demonstrated that in fact rpc_malloc was never allocating the buffer from the mempool, but almost always called kmalloc. To compute the size of the RPC buffer more precisely, split p_bufsiz into two fields; one for the argument size, and one for the result size. Then, compute the sum of the exact call and reply header sizes, and split the RPC buffer precisely between the two. That should keep almost all RPC buffers within the 2KiB buffer mempool limit. And, we can finally be rid of RPC_SLACK_SPACE! Signed-off-by: Chuck Lever <chuck.lever@oracle.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2007-02-12NFS: disconnect before retrying NFSv4 requests over TCPChuck Lever
RFC3530 section 3.1.1 states an NFSv4 client MUST NOT send a request twice on the same connection unless it is the NULL procedure. Section 3.1.1 suggests that the client should disconnect and reconnect if it wants to retry a request. Implement this by adding an rpc_clnt flag that an ULP can use to specify that the underlying transport should be disconnected on a major timeout. The NFSv4 client asserts this new flag, and requests no retries after a minor retransmit timeout. Note that disconnecting on a retransmit is in general not safe to do if the RPC client does not reuse the TCP port number when reconnecting. See http://bugzilla.linux-nfs.org/show_bug.cgi?id=6 Signed-off-by: Chuck Lever <chuck.lever@oracle.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2006-12-06SUNRPC: Give cloned RPC clients their own rpc_pipefs directoryTrond Myklebust
2006-09-22SUNRPC: Eliminate xprt_create_proto and rpc_create_clientChuck Lever
The two function call API for creating a new RPC client is now obsolete. Remove it. Also, remove an unnecessary check to see whether the caller is capable of using privileged network services. The kernel RPC client always uses a privileged ephemeral port by default; callers are responsible for checking the authority of users to make use of any RPC service, or for specifying that a nonprivileged port is acceptable. Test plan: Repeated runs of Connectathon locking suite. Check network trace to ensure correctness of NLM requests and replies. Signed-off-by: Chuck Lever <chuck.lever@oracle.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2006-09-22SUNRPC: use sockaddr + size when creating remote transport endpointsChuck Lever
Prepare for more generic transport endpoint handling needed by transports that might use different forms of addressing, such as IPv6. Introduce a single function call to replace the two-call xprt_create_proto/rpc_create_client API. Define a new rpc_create_args structure that allows callers to pass in remote endpoint addresses of varying length. Test-plan: Compile kernel with CONFIG_NFS enabled. Signed-off-by: Chuck Lever <chuck.lever@oracle.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2006-09-22SUNRPC: Clean-up after previous patches.Chuck Lever
Remove some unused macros related to accessing an RPC peer address Test plan: Compile kernel with CONFIG_NFS option enabled. Signed-off-by: Chuck Lever <chuck.lever@oracle.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2006-09-22SUNRPC: Create API for displaying remote peer addressChuck Lever
Provide an API for formatting the remote peer address for printing without exposing its internal structure. The address could be dynamic, so we support a function call to get the address rather than reading it straight out of a structure. Test-plan: Destructive testing (unplugging the network temporarily). Probably need to rig a server where certain services aren't running, or that returns an error for some typical operation. Signed-off-by: Chuck Lever <chuck.lever@oracle.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2006-09-22SUNRPC: create API for getting remote peer addressChuck Lever
Provide an API for retrieving the remote peer address without allowing direct access to the rpc_xprt struct. Test-plan: Compile kernel with CONFIG_NFS enabled. Signed-off-by: Chuck Lever <chuck.lever@oracle.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2006-09-22SUNRPC: Introduce transport switch callout for pluggable rpcbindChuck Lever
Introduce a clean transport switch API for plugging in different types of rpcbind mechanisms. For instance, rpcbind can cleanly replace the existing portmapper client, or a transport can choose to implement RPC binding any way it likes. Test plan: Destructive testing (unplugging the network temporarily). Connectathon with UDP and TCP. NFSv2/3 and NFSv4 mounting should be carefully checked. Probably need to rig a server where certain services aren't running, or that returns an error for some typical operation. Signed-off-by: Chuck Lever <chuck.lever@oracle.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2006-09-22SUNRPC: Make RPC portmapper use per-transport storageChuck Lever
Move connection and bind state that was maintained in the rpc_clnt structure to the rpc_xprt structure. This will allow the creation of a clean API for plugging in different types of bind mechanisms. This brings improvements such as the elimination of a single spin lock to control serialization for all in-kernel RPC binding. A set of per-xprt bitops is used to serialize tasks during RPC binding, just like it now works for making RPC transport connections. Test-plan: Destructive testing (unplugging the network temporarily). Connectathon with UDP and TCP. NFSv2/3 and NFSv4 mounting should be carefully checked. Probably need to rig a server where certain services aren't running, or that returns an error for some typical operation. Signed-off-by: Chuck Lever <chuck.lever@oracle.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2006-03-20SUNRPC: Fix a 'Busy inodes' error in rpc_pipefsTrond Myklebust
2006-03-20SUNRPC: eliminate rpc_call()Chuck Lever
Clean-up: replace rpc_call() helper with direct call to rpc_call_sync. This makes NFSv2 and NFSv3 synchronous calls more computationally efficient, and reduces stack consumption in functions that used to invoke rpc_call more than once. Test plan: Compile kernel with CONFIG_NFS enabled. Connectathon on NFS version 2, version 3, and version 4 mount points. Signed-off-by: Chuck Lever <cel@netapp.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2006-03-20SUNRPC: display human-readable procedure name in rpc_iostats outputChuck Lever
Add fields to the rpc_procinfo struct that allow the display of a human-readable name for each procedure in the rpc_iostats output. Also fix it so that the NFSv4 stats are broken up correctly by sub-procedure number. NFSv4 uses only two real RPC procedures: NULL, and COMPOUND. Test plan: Mount with NFSv2, NFSv3, and NFSv4, and do "cat /proc/self/mountstats". Signed-off-by: Chuck Lever <cel@netapp.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2006-03-20SUNRPC: provide a mechanism for collecting stats in the RPC clientChuck Lever
Add a simple mechanism for collecting stats in the RPC client. Stats are tabulated during xprt_release. Note that per_cpu shenanigans are not required here because the RPC client already serializes on the transport write lock. Test plan: Compile kernel with CONFIG_NFS enabled. Basic performance regression testing with high-speed networking and high performance server. Signed-off-by: Chuck Lever <cel@netapp.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2006-01-06SUNRPC: get rid of cl_chattyChuck Lever
Clean up: Every ULP that uses the in-kernel RPC client, except the NLM client, sets cl_chatty. There's no reason why NLM shouldn't set it, so just get rid of cl_chatty and always be verbose. Test-plan: Compile with CONFIG_NFS enabled. Signed-off-by: Chuck Lever <cel@netapp.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2006-01-06SUNRPC: new interface to force an RPC rebindChuck Lever
We'd like to hide fields in rpc_xprt and rpc_clnt from upper layer protocols. Start by creating an API to force RPC rebind, replacing logic that simply sets cl_port to zero. Test-plan: Destructive testing (unplugging the network temporarily). Connectathon with UDP and TCP. NFSv2/3 and NFSv4 mounting should be carefully checked. Probably need to rig a server where certain services aren't running, or that returns an error for some typical operation. Signed-off-by: Chuck Lever <cel@netapp.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2006-01-06RPC: Clean up RPC task structureTrond Myklebust
Shrink the RPC task structure. Instead of storing separate pointers for task->tk_exit and task->tk_release, put them in a structure. Also pass the user data pointer as a parameter instead of passing it via task->tk_calldata. This enables us to nest callbacks. Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2005-06-22[PATCH] RPC: Allow multiple RPC client programs to share the same transportAndreas Gruenbacher
Signed-off-by: Andreas Gruenbacher <agruen@suse.de> Acked-by: Olaf Kirch <okir@suse.de> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2005-06-22[PATCH] RPC: Make rpc_create_client() probe server for RPC program+version ↵Trond Myklebust
support Ensure that we don't create an RPC client without checking that the server does indeed support the RPC program + version that we are trying to set up. This enables us to immediately return an error to "mount" if it turns out that the server is only supporting NFSv2, when we requested NFSv3 or NFSv4. Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
