path: root/include/linux/string.h
2007-04-26[STRING]: Move strcasecmp/strncasecmp to lib/string.cDavid S. Miller
We have several platforms using local copies of identical code. Signed-off-by: David S. Miller <davem@davemloft.net>
2006-10-01[PATCH] kmemdup: introduceAlexey Dobriyan
One of idiomatic ways to duplicate a region of memory is dst = kmalloc(len, GFP_KERNEL); if (!dst) return -ENOMEM; memcpy(dst, src, len); which is neat code except a programmer needs to write size twice. Which sometimes leads to mistakes. If len passed to kmalloc is smaller that len passed to memcpy, it's straight overwrite-beyond-end. If len passed to memcpy is smaller than len passed to kmalloc, it's either a) legit behaviour ;-), or b) cloned buffer will contain garbage in second half. Slight trolling of commit lists shows several duplications bugs done exactly because of diverged lenghts: Linux: [CRYPTO]: Fix memcpy/memset args. [PATCH] memcpy/memset fixes OpenBSD: kerberosV/src/lib/asn1: der_copy.c:1.4 If programmer is given only one place to play with lengths, I believe, such mistakes could be avoided. With kmemdup, the snippet above will be rewritten as: dst = kmemdup(src, len, GFP_KERNEL); if (!dst) return -ENOMEM; This also leads to smaller code (kzalloc effect). Quick grep shows 200+ places where kmemdup() can be used. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-23[PATCH] strstrip() APIPekka Enberg
Add a new strstrip() function to lib/string.c for removing leading and trailing whitespace from a string. Cc: Michael Holzheu <holzheu@de.ibm.com> Acked-by: Ingo Oeser <ioe-lkml@rameria.de> Acked-by: Joern Engel <joern@wohnheim.fh-wedel.de> Cc: Corey Minyard <minyard@acm.org> Signed-off-by: Pekka Enberg <penberg@cs.helsinki.fi> Acked-by: Michael Holzheu <HOLZHEU@de.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-04-11[PATCH] Clean up arch-overrides in linux/string.hKyle McMartin
Some string functions were safely overrideable in lib/string.c, but their corresponding declarations in linux/string.h were not. Correct this, and make strcspn overrideable. Odds of someone wanting to do optimized assembly of these are small, but for the sake of cleanliness, might as well bring them into line with the rest of the file. Signed-off-by: Kyle McMartin <kyle@parisc-linux.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-24[PATCH] strndup_user()Davi Arnaut
This patch series creates a strndup_user() function to easy copying C strings from userspace. Also we avoid common pitfalls like userspace modifying the final \0 after the strlen_user(). Signed-off-by: Davi Arnaut <davi.arnaut@gmail.com> Cc: David Howells <dhowells@redhat.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-10-08[PATCH] gfp flags annotations - part 1Al Viro
- added typedef unsigned int __nocast gfp_t; - replaced __nocast uses for gfp flags with gfp_t - it gives exactly the same warnings as far as sparse is concerned, doesn't change generated code (from gcc point of view we replaced unsigned int with typedef) and documents what's going on far better. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-07-07[PATCH] propagate __nocast annotationsAlexey Dobriyan
2005-06-23[PATCH] create a kstrdup library functionPaulo Marques
This patch creates a new kstrdup library function and changes the "local" implementations in several places to use this function. Most of the changes come from the sound and net subsystems. The sound part had already been acknowledged by Takashi Iwai and the net part by David S. Miller. I left UML alone for now because I would need more time to read the code carefully before making changes there. Signed-off-by: Paulo Marques <pmarques@grupopie.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
