path: root/include/linux/spi-tegra.h
2011-03-08spi: tegra: Fixing misc issues.Laxman Dewangan
Following are the fixes; - Supportng half duplex. - Only using SW based CS. - Write to readback with command register does not work. Fixing issue. - Using cpu based transfer for smaller size and dma based for larger size. - reading proper transfer status after every transaction. bug 791149 bug 791780 Change-Id: I293b3f1b571276f5d8fe4ad4da67f827926e4b73 Reviewed-on: http://git-master/r/20581 Reviewed-by: Laxman Dewangan <ldewangan@nvidia.com> Tested-by: Laxman Dewangan <ldewangan@nvidia.com> Reviewed-by: Bharat Nihalani <bnihalani@nvidia.com> Reviewed-by: Amit Kamath <akamath@nvidia.com>
