path: root/include/linux/soc
2015-11-10Merge tag 'armsoc-drivers' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc Pull ARM SoC driver updates from Olof Johansson: "As we've enabled multiplatform kernels on ARM, and greatly done away with the contents under arch/arm/mach-*, there's still need for SoC-related drivers to go somewhere. Many of them go in through other driver trees, but we still have drivers/soc to hold some of the "doesn't fit anywhere" lowlevel code that might be shared between ARM and ARM64 (or just in general makes sense to not have under the architecture directory). This branch contains mostly such code: - Drivers for qualcomm SoCs for SMEM, SMD and SMD-RPM, used to communicate with power management blocks on these SoCs for use by clock, regulator and bus frequency drivers. - Allwinner Reduced Serial Bus driver, again used to communicate with PMICs. - Drivers for ARM's SCPI (System Control Processor). Not to be confused with PSCI (Power State Coordination Interface). SCPI is used to communicate with the assistant embedded cores doing power management, and we have yet to see how many of them will implement this for their hardware vs abstracting in other ways (or not at all like in the past). - To make confusion between SCPI and PSCI more likely, this release also includes an update of PSCI to interface version 1.0. - Rockchip support for power domains. - A driver to talk to the firmware on Raspberry Pi" * tag 'armsoc-drivers' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (57 commits) soc: qcom: smd-rpm: Correct size of outgoing message bus: sunxi-rsb: Add driver for Allwinner Reduced Serial Bus bus: sunxi-rsb: Add Allwinner Reduced Serial Bus (RSB) controller bindings ARM: bcm2835: add mutual inclusion protection drivers: psci: make PSCI 1.0 functions initialization version dependent dt-bindings: Correct paths in Rockchip power domains binding document soc: rockchip: power-domain: don't try to print the clock name in error case soc: qcom/smem: add HWSPINLOCK dependency clk: berlin: add cpuclk ARM: berlin: dts: add CLKID_CPU for BG2Q ARM: bcm2835: Add the Raspberry Pi firmware driver soc: qcom: smem: Move RPM message ram out of smem DT node soc: qcom: smd-rpm: Correct the active vs sleep state flagging soc: qcom: smd: delete unneeded of_node_put firmware: qcom-scm: build for correct architecture level soc: qcom: smd: Correct SMEM items for upper channels qcom-scm: add missing prototype for qcom_scm_is_available() qcom-scm: fix endianess issue in __qcom_scm_is_call_available soc: qcom: smd: Reject send of too big packets soc: qcom: smd: Handle big endian CPUs ...
2015-10-14soc: qcom: Make qcom_smem_get() return a pointerStephen Boyd
Passing a void ** almost always requires a cast at the call site. Instead of littering the code with casts every time this function is called, have qcom_smem_get() return a void pointer to the location of the smem item. This frees the caller from having to cast the pointer. Cc: Bjorn Andersson <bjorn.andersson@sonymobile.com> Signed-off-by: Stephen Boyd <sboyd@codeaurora.org> Reviewed-by: Bjorn Andersson <bjorn.andersson@sonymobile.com> Signed-off-by: Andy Gross <agross@codeaurora.org>
2015-10-14soc: qcom: smd: Implement id_table driver matchingBjorn Andersson
Implement a id_table based driver maching mechanism for drivers that binds to fixed channels and doesn't need any additional configuration, e.g. IPCRTR and DIAG. Signed-off-by: Bjorn Andersson <bjorn.andersson@sonymobile.com> Signed-off-by: Andy Gross <agross@codeaurora.org>
2015-10-09soc: brcmstb: Add Bus Interface Unit control setupFlorian Fainelli
Broadcom STB SoCs (brcmstb) require an early setup of their Bus Interface Unit control register, this needs to happen before SMP is brought up because it affects how the CPU complex will be interfaced to the memory controller. Add support code which properly initializes the BIU registers based on whether "brcm,write-pairing" is present in Device Tree, and take care of saving and restoring credit register settings during system-wide suspend/resume operations. Acked-by: Gregory Fong <gregory.0xf0@gmail.com> Signed-off-by: Florian Fainelli <f.fainelli@gmail.com>
2015-09-01Merge tag 'armsoc-drivers' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc Pull ARM SoC driver updates from Olof Johansson: "Some releases this branch is nearly empty, others we have more stuff. It tends to gather drivers that need SoC modification or dependencies such that they have to (also) go in through our tree. For this release, we have merged in part of the reset controller tree (with handshake that the parts we have merged in will remain stable), as well as dependencies on a few clock branches. In general, new items here are: - Qualcomm driver for SMM/SMD, which is how they communicate with the coprocessors on (some) of their platforms - memory controller work for ARM's PL172 memory controller - reset drivers for various platforms - PMU power domain support for Marvell platforms - Tegra support for T132/T210 SoCs: PMC, fuse, memory controller per-SoC support" * tag 'armsoc-drivers' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (49 commits) ARM: tegra: cpuidle: implement cpuidle_state.enter_freeze() ARM: tegra: Disable cpuidle if PSCI is available soc/tegra: pmc: Use existing pclk reference soc/tegra: pmc: Remove unnecessary return statement soc: tegra: Remove redundant $(CONFIG_ARCH_TEGRA) in Makefile memory: tegra: Add Tegra210 support memory: tegra: Add support for a variable-size client ID bitfield clk: shmobile: rz: Add CPG/MSTP Clock Domain support clk: shmobile: rcar-gen2: Add CPG/MSTP Clock Domain support clk: shmobile: r8a7779: Add CPG/MSTP Clock Domain support clk: shmobile: r8a7778: Add CPG/MSTP Clock Domain support clk: shmobile: Add CPG/MSTP Clock Domain support ARM: dove: create a proper PMU driver for power domains, PMU IRQs and resets reset: reset-zynq: Adding support for Xilinx Zynq reset controller. docs: dts: Added documentation for Xilinx Zynq Reset Controller bindings. MIPS: ath79: Add the reset controller to the AR9132 dtsi reset: Add a driver for the reset controller on the AR71XX/AR9XXX devicetree: Add bindings for the ATH79 reset controller reset: socfpga: Update reset-socfpga to read the altr,modrst-offset property doc: dt: add documentation for lpc1850-rgu reset driver ...
2015-08-13Merge tag 'qcom-soc-for-4.3' of git://codeaurora.org/quic/kernel/agross-msm ↵Olof Johansson
into next/drivers Qualcomm ARM Based SoC Updates for 4.3 * Add SMEM driver * Add SMD driver * Add RPM over SMD driver * Select QCOM_SCM by default * tag 'qcom-soc-for-4.3' of git://codeaurora.org/quic/kernel/agross-msm: devicetree: soc: Add Qualcomm SMD based RPM DT binding soc: qcom: Driver for the Qualcomm RPM over SMD soc: qcom: Add Shared Memory Driver soc: qcom: Add device tree binding for Shared Memory Device drivers: qcom: Select QCOM_SCM unconditionally for QCOM_PM soc: qcom: Add Shared Memory Manager driver Signed-off-by: Olof Johansson <olof@lixom.net>
2015-08-05ARM: dove: create a proper PMU driver for power domains, PMU IRQs and resetsRussell King
The PMU device contains an interrupt controller, power control and resets. The interrupt controller is a little sub-standard in that there is no race free way to clear down pending interrupts, so we try to avoid problems by reducing the window as much as possible, and clearing as infrequently as possible. The interrupt support is implemented using an IRQ domain, and the parent interrupt referenced in the standard DT way. The power domains and reset support is closely related - there is a defined sequence for powering down a domain which is tightly coupled with asserting the reset. Hence, it makes sense to group these two together, and in order to avoid any locking contention disrupting this sequence, we avoid the use of syscon or regmap. This patch adds the core PMU driver: power domains must be defined in the DT file in order to make use of them. The reset controller can be referenced in the standard way for reset controllers. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk> Signed-off-by: Andrew Lunn <andrew@lunn.ch> Signed-off-by: Gregory CLEMENT <gregory.clement@free-electrons.com>
2015-07-29soc: qcom: Driver for the Qualcomm RPM over SMDBjorn Andersson
Driver for the Resource Power Manager (RPM) found in Qualcomm 8974 based devices. The driver exposes resources that child drivers can operate on; to implementing regulator, clock and bus frequency drivers. Signed-off-by: Bjorn Andersson <bjorn.andersson@sonymobile.com> Signed-off-by: Andy Gross <agross@codeaurora.org>
2015-07-29soc: qcom: Add Shared Memory DriverBjorn Andersson
This adds the Qualcomm Shared Memory Driver (SMD) providing communication channels to remote processors, ontop of SMEM. Signed-off-by: Bjorn Andersson <bjorn.andersson@sonymobile.com> Signed-off-by: Andy Gross <agross@codeaurora.org>
2015-07-28soc: qcom: Add Shared Memory Manager driverBjorn Andersson
The Shared Memory Manager driver implements an interface for allocating and accessing items in the memory area shared among all of the processors in a Qualcomm platform. Signed-off-by: Bjorn Andersson <bjorn.andersson@sonymobile.com> Acked-by: Andy Gross <agross@codeaurora.org> Signed-off-by: Andy Gross <agross@codeaurora.org>
2015-07-06soc: mediatek: Add infracfg misc driver supportSascha Hauer
This adds support for some miscellaneous bits of the infracfg controller. The mtk_infracfg_set/clear_bus_protection functions are necessary for the scpsys power domain driver to handle the bus protection bits which are contained in the infacfg register space. Signed-off-by: Sascha Hauer <s.hauer@pengutronix.de> Reviewed-by: Daniel Kurtz <djkurtz@chromium.org> Signed-off-by: Matthias Brugger <matthias.bgg@gmail.com>
2015-06-01drivers: soc: sunxi: Introduce SoC driver to map SRAMsMaxime Ripard
The Allwinner SoCs have a handful of SRAM that can be either mapped to be accessible by devices or the CPU. That mapping is controlled by an SRAM controller, and that mapping might not be set by the bootloader, for example if the device wasn't used at all, or if we're using solutions like the U-Boot's Falcon Boot. We could also imagine changing this at runtime for example to change the mapping of these SRAMs to use them for suspend/resume or runtime memory rate change, if that ever happens. These use cases require some API in the kernel to control that mapping, exported through a drivers/soc driver. This driver also implement a debugfs file that shows the SRAM found in the system, the current mapping and the SRAM that have been claimed by some drivers in the kernel. Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com> Acked-by: Arnd Bergmann <arnd@arndb.de> Acked-by: Hans de Goede <hdegoede@redhat.com> Tested-by: Hans de Goede <hdegoede@redhat.com> Signed-off-by: Arnd Bergmann <arnd@arndb.de>
2014-09-24drivers/soc: ti: fix build break with modulesOlof Johansson
Fixes below build break by not switching to stubs when the driver is a module: drivers/soc/ti/knav_dma.c:418:7: error: redefinition of 'knav_dma_open_channel' void *knav_dma_open_channel(struct device *dev, const char *name, ^ In file included from drivers/soc/ti/knav_dma.c:26:0: include/linux/soc/ti/knav_dma.h:165:21: note: previous definition of 'knav_dma_open_channel' was here static inline void *knav_dma_open_channel(struct device *dev, const char *name, ^ Cc: Santosh Shilimkar <santosh.shilimkar@ti.com> Signed-off-by: Olof Johansson <olof@lixom.net>
2014-09-24soc: ti: add Keystone Navigator DMA supportSantosh Shilimkar
The Keystone Navigator DMA driver sets up the dma channels and flows for the QMSS(Queue Manager SubSystem) who triggers the actual data movements across clients using destination queues. Every client modules like NETCP(Network Coprocessor), SRIO(Serial Rapid IO) and CRYPTO Engines has its own instance of packet dma hardware. QMSS has also an internal packet DMA module which is used as an infrastructure DMA with zero copy. Initially this driver was proposed as DMA engine driver but since the hardware is not typical DMA engine and hence doesn't comply with typical DMA engine driver needs, that approach was naked. Link to that discussion - https://lkml.org/lkml/2014/3/18/340 As aligned, now we pair the Navigator DMA with its companion Navigator QMSS subsystem driver. Cc: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Cc: Kumar Gala <galak@codeaurora.org> Cc: Olof Johansson <olof@lixom.net> Cc: Arnd Bergmann <arnd@arndb.de> Cc: Grant Likely <grant.likely@linaro.org> Cc: Rob Herring <robh+dt@kernel.org> Cc: Mark Rutland <mark.rutland@arm.com> Signed-off-by: Sandeep Nair <sandeep_n@ti.com> Signed-off-by: Santosh Shilimkar <santosh.shilimkar@ti.com>
2014-09-24soc: ti: add Keystone Navigator QMSS driverSandeep Nair
The QMSS (Queue Manager Sub System) found on Keystone SOCs is one of the main hardware sub system which forms the backbone of the Keystone Multi-core Navigator. QMSS consist of queue managers, packed-data structure processors(PDSP), linking RAM, descriptor pools and infrastructure Packet DMA. The Queue Manager is a hardware module that is responsible for accelerating management of the packet queues. Packets are queued/de-queued by writing or reading descriptor address to a particular memory mapped location. The PDSPs perform QMSS related functions like accumulation, QoS, or event management. Linking RAM registers are used to link the descriptors which are stored in descriptor RAM. Descriptor RAM is configurable as internal or external memory. The QMSS driver manages the PDSP setups, linking RAM regions, queue pool management (allocation, push, pop and notify) and descriptor pool management. The specifics on the device tree bindings for QMSS can be found in: Documentation/devicetree/bindings/soc/keystone-navigator-qmss.txt Cc: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Cc: Kumar Gala <galak@codeaurora.org> Cc: Olof Johansson <olof@lixom.net> Cc: Arnd Bergmann <arnd@arndb.de> Cc: Grant Likely <grant.likely@linaro.org> Cc: Rob Herring <robh+dt@kernel.org> Cc: Mark Rutland <mark.rutland@arm.com> Signed-off-by: Sandeep Nair <sandeep_n@ti.com> Signed-off-by: Santosh Shilimkar <santosh.shilimkar@ti.com>
