path: root/include/linux/snmp.h
2012-01-22tcp: detect loss above high_seq in recoveryYuchung Cheng
Correctly implement a loss detection heuristic: New sequences (above high_seq) sent during the fast recovery are deemed lost when higher sequences are SACKed. Current code does not catch these losses, because tcp_mark_head_lost() does not check packets beyond high_seq. The fix is straight-forward by checking packets until the highest sacked packet. In addition, all the FLAG_DATA_LOST logic are in-effective and redundant and can be removed. Update the loss heuristic comments. The algorithm above is documented as heuristic B, but it is redundant too because heuristic A already covers B. Note that this change only marks some forward-retransmitted packets LOST. It does NOT forbid TCP performing further CWR on new losses. A potential follow-up patch under preparation is to perform another CWR on "new" losses such as 1) sequence above high_seq is lost (by resetting high_seq to snd_nxt) 2) retransmission is lost. Signed-off-by: Yuchung Cheng <ycheng@google.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-09-15tcp: Change possible SYN flooding messagesEric Dumazet
"Possible SYN flooding on port xxxx " messages can fill logs on servers. Change logic to log the message only once per listener, and add two new SNMP counters to track : TCPReqQFullDoCookies : number of times a SYNCOOKIE was replied to client TCPReqQFullDrop : number of times a SYN request was dropped because syncookies were not enabled. Based on a prior patch from Tom Herbert, and suggestions from David. Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> CC: Tom Herbert <therbert@google.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-12-08tcp: Replace time wait bucket msg by counterTom Herbert
Rather than printing the message to the log, use a mib counter to keep track of the count of occurences of time wait bucket overflow. Reduces spam in logs. Signed-off-by: Tom Herbert <therbert@google.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-06-03ipv4: add LINUX_MIB_IPRPFILTER snmp counterEric Dumazet
Christoph Lameter mentioned that packets could be dropped in input path because of rp_filter settings, without any SNMP counter being incremented. System administrator can have a hard time to track the problem. This patch introduces a new counter, LINUX_MIB_IPRPFILTER, incremented each time we drop a packet because Reverse Path Filter triggers. (We receive an IPv4 datagram on a given interface, and find the route to send an answer would use another interface) netstat -s | grep IPReversePathFilter IPReversePathFilter: 21714 Reported-by: Christoph Lameter <cl@linux-foundation.org> Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-04-03icmp: Account for ICMP out errorsEric Dumazet
When ip_append() fails because of socket limit or memory shortage, increment ICMP_MIB_OUTERRORS counter, so that "netstat -s" can report these errors. LANG=C netstat -s | grep "ICMP messages failed" 0 ICMP messages failed For IPV6, implement ICMP6_MIB_OUTERRORS counter as well. # grep Icmp6OutErrors /proc/net/dev_snmp6/* /proc/net/dev_snmp6/eth0:Icmp6OutErrors 0 /proc/net/dev_snmp6/lo:Icmp6OutErrors 0 Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-03-21tcp: Add SNMP counter for DEFER_ACCEPTEric Dumazet
Its currently hard to diagnose when ACK frames are dropped because an application set TCP_DEFER_ACCEPT on its listening socket. See http://bugzilla.kernel.org/show_bug.cgi?id=15507 This patch adds a SNMP value, named TCPDeferAcceptDrop netstat -s | grep TCPDeferAcceptDrop TCPDeferAcceptDrop: 0 This counter is incremented every time we drop a pure ACK frame received by a socket in SYN_RECV state because its SYNACK retrans count is lower than defer_accept value. Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-03-08tcp: Add SNMP counters for backlog and min_ttl dropsEric Dumazet
Commit 6b03a53a (tcp: use limited socket backlog) added the possibility of dropping frames when backlog queue is full. Commit d218d111 (tcp: Generalized TTL Security Mechanism) added the possibility of dropping frames when TTL is under a given limit. This patch adds new SNMP MIB entries, named TCPBacklogDrop and TCPMinTTLDrop, published in /proc/net/netstat in TcpExt: line netstat -s | egrep "TCPBacklogDrop|TCPMinTTLDrop" TCPBacklogDrop: 0 TCPMinTTLDrop: 0 Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-02-18xfrm: Introduce LINUX_MIB_XFRMFWDHDRERRORjamal
XFRMINHDRERROR counter is ambigous when validating forwarding path. It makes it tricky to debug when you have both in and fwd validation. Signed-off-by: Jamal Hadi Salim <hadi@cyberus.ca> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-04-27snmp: add missing counters for RFC 4293Neil Horman
The IP MIB (RFC 4293) defines stats for InOctets, OutOctets, InMcastOctets and OutMcastOctets: http://tools.ietf.org/html/rfc4293 But it seems we don't track those in any way that easy to separate from other protocols. This patch adds those missing counters to the stats file. Tested successfully by me With help from Eric Dumazet. Signed-off-by: Neil Horman <nhorman@tuxdriver.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-11-24tcp: add some mibs to track collapsingIlpo Järvinen
Signed-off-by: Ilpo Järvinen <ilpo.jarvinen@helsinki.fi> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-07-30tcp: MD5: Use MIB counter instead of warning for MD5 mismatch.David S. Miller
From a report by Matti Aarnio, and preliminary patch by Adam Langley. Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-31[XFRM]: Fix statistics.Masahide NAKAMURA
o Outbound sequence number overflow error status is counted as XfrmOutStateSeqError. o Additionaly, it changes inbound sequence number replay error name from XfrmInSeqOutOfWindow to XfrmInStateSeqError to apply name scheme above. o Inbound IPv4 UDP encapsuling type mismatch error is wrongly mapped to XfrmInStateInvalid then this patch fiex the error to XfrmInStateMismatch. Signed-off-by: Masahide NAKAMURA <nakam@linux-ipv6.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-28[XFRM]: Define packet dropping statistics.Masahide NAKAMURA
This statistics is shown factor dropped by transformation at /proc/net/xfrm_stat for developer. It is a counter designed from current transformation source code and defined as linux private MIB. See Documentation/networking/xfrm_proc.txt for the detail. Signed-off-by: Masahide NAKAMURA <nakam@linux-ipv6.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-10[TCP] MIB: Count FRTO's successfully detected spurious RTOsIlpo Järvinen
2007-10-10[IPV4]: Add ICMPMsgStats MIB (RFC 4293)David L Stevens
Background: RFC 4293 deprecates existing individual, named ICMP type counters to be replaced with the ICMPMsgStatsTable. This table includes entries for both IPv4 and IPv6, and requires counting of all ICMP types, whether or not the machine implements the type. These patches "remove" (but not really) the existing counters, and replace them with the ICMPMsgStats tables for v4 and v6. It includes the named counters in the /proc places they were, but gets the values for them from the new tables. It also counts packets generated from raw socket output (e.g., OutEchoes, MLD queries, RA's from radvd, etc). Changes: 1) create icmpmsg_statistics mib 2) create icmpv6msg_statistics mib 3) modify existing counters to use these 4) modify /proc/net/snmp to add "IcmpMsg" with all ICMP types listed by number for easy SNMP parsing 5) modify /proc/net/snmp printing for "Icmp" to get the named data from new counters. Signed-off-by: David L Stevens <dlstevens@us.ibm.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-10[IPV6]: Add ICMPMsgStats MIB (RFC 4293) [rev 2]David L Stevens
Background: RFC 4293 deprecates existing individual, named ICMP type counters to be replaced with the ICMPMsgStatsTable. This table includes entries for both IPv4 and IPv6, and requires counting of all ICMP types, whether or not the machine implements the type. These patches "remove" (but not really) the existing counters, and replace them with the ICMPMsgStats tables for v4 and v6. It includes the named counters in the /proc places they were, but gets the values for them from the new tables. It also counts packets generated from raw socket output (e.g., OutEchoes, MLD queries, RA's from radvd, etc). Changes: 1) create icmpmsg_statistics mib 2) create icmpv6msg_statistics mib 3) modify existing counters to use these 4) modify /proc/net/snmp to add "IcmpMsg" with all ICMP types listed by number for easy SNMP parsing 5) modify /proc/net/snmp printing for "Icmp" to get the named data from new counters. [new to 2nd revision] 6) support per-interface ICMP stats 7) use common macro for per-device stat macros Signed-off-by: David L Stevens <dlstevens@us.ibm.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-10[TCP] MIB: Add counters for discarded SACK blocksIlpo Järvinen
In DSACK case, some events are not extraordinary, such as packet duplication generated DSACK. They can arrive easily below snd_una when undo_marker is not set (TCP being in CA_Open), counting such DSACKs amoung SACK discards will likely just mislead if they occur in some scenario when there are other problems as well. Similarly, excessively delayed packets could cause "normal" DSACKs. Therefore, separate counters are allocated for DSACK events. Signed-off-by: Ilpo Järvinen <ilpo.jarvinen@helsinki.fi> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-30[SNMP]: Add definitions for {In,Out}BcastPktsMitsuru Chinen
The updated IP-MIB RFC (RFC4293) specifys new objects, InBcastPkts and OutBcastPkts. This adds definitions for them. Signed-off-by: Mitsuru Chinen <mitch@linux.vnet.ibm.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-09-22[SCTP]: Extend /proc/net/sctp/snmp to provide more statistics.Sridhar Samudrala
This patch adds more statistics info under /proc/net/sctp/snmp that should be useful for debugging. The additional events that are counted now include timer expirations, retransmits, packet and data chunk discards. The Data chunk discards include all the cases where a data chunk is discarded including high tsn, bad stream, dup tsn and the most useful one(out of receive buffer/rwnd). Also moved the SCTP MIB data structures from the generic include directories to include/sctp/sctp.h. Signed-off-by: Sridhar Samudrala <sri@us.ibm.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-09-22[IPV4]: add the UdpSndbufErrors and UdpRcvbufErrors MIBsMartin Bligh
Signed-off-by: Martin Bligh <mbligh@google.com> Signed-off-by: Andrew Morton <akpm@osdl.org>
