path: root/include/linux/smp_lock.h
2010-10-21BKL: introduce CONFIG_BKL.Arnd Bergmann
With all the patches we have queued in the BKL removal tree, only a few dozen modules are left that actually rely on the BKL, and even there are lots of low-hanging fruit. We need to decide what to do about them, this patch illustrates one of the options: Every user of the BKL is marked as 'depends on BKL' in Kconfig, and the CONFIG_BKL becomes a user-visible option. If it gets disabled, no BKL using module can be built any more and the BKL code itself is compiled out. The one exception is file locking, which is practically always enabled and does a 'select BKL' instead. This effectively forces CONFIG_BKL to be enabled until we have solved the fs/lockd mess and can apply the patch that removes the BKL from fs/locks.c. Signed-off-by: Arnd Bergmann <arnd@arndb.de>
2009-09-28tracing: Pushdown the bkl tracepoints callsFrederic Weisbecker
Currently we are calling the bkl tracepoint callbacks just before the bkl lock/unlock operations, ie the tracepoint call is not inside a lock_kernel() function but inside a lock_kernel() macro. Hence the bkl trace event header must be included from smp_lock.h. This raises some nasty circular header dependencies: linux/smp_lock.h -> trace/events/bkl.h -> trace/define_trace.h -> trace/ftrace.h -> linux/ftrace_event.h -> linux/hardirq.h -> linux/smp_lock.h This results in incomplete event declarations, spurious event definitions and other kind of funny behaviours. This is hardly fixable without ugly workarounds. So instead, we push the file name, line number and function name as lock_kernel() parameters, so that we only deal with the trace event header from lib/kernel_lock.c This adds two parameters to lock_kernel() and unlock_kernel() but it should be fine wrt to performances because this pair dos not seem to be called in fast paths. Signed-off-by: Frederic Weisbecker <fweisbec@gmail.com> Cc: Steven Rostedt <rostedt@goodmis.org> Cc: Ingo Molnar <mingo@elte.hu> Cc: Li Zefan <lizf@cn.fujitsu.com>
2009-09-24tracing/bkl: Add bkl ftrace eventsFrederic Weisbecker
Add two events lock_kernel and unlock_kernel() to trace the bkl uses. This opens the door for userspace tools to perform statistics about the callsites that use it, dependencies with other locks (by pairing the trace with lock events), use with recursivity and so on... The {__reacquire,release}_kernel_lock() events are not traced because these are called from schedule, thus the sched events are sufficient to trace them. Example of a trace: hald-addon-stor-4152 [000] 165.875501: unlock_kernel: depth: 0, fs/block_dev.c:1358 __blkdev_put() hald-addon-stor-4152 [000] 167.832974: lock_kernel: depth: 0, fs/block_dev.c:1167 __blkdev_get() How to get the callsites that acquire it recursively: cd /debug/tracing/events/bkl echo "lock_depth > 0" > filter firefox-4951 [001] 206.276967: unlock_kernel: depth: 1, fs/reiserfs/super.c:575 reiserfs_dirty_inode() You can also filter by file and/or line. v2: Use of FILTER_PTR_STRING attribute for files and lines fields to make them traceable. Signed-off-by: Frederic Weisbecker <fweisbec@gmail.com> Cc: Steven Rostedt <rostedt@goodmis.org> Cc: Li Zefan <lizf@cn.fujitsu.com>
2008-06-20Add cycle_kernel_lock()Jonathan Corbet
A number of driver functions are so obviously trivial that they do not need the big kernel lock - at least not overtly. It turns out that the acquisition of the BKL in driver open() functions can perform a sort of poor-hacker's serialization function, delaying the open operation until the driver is certain to have completed its initialization. Add a simple cycle_kernel_lock() function for these cases to make it clear that there is no need to *hold* the BKL, just to be sure that we can acquire it. Signed-off-by: Jonathan Corbet <corbet@lwn.net>
2008-01-25sched: remove the !PREEMPT_BKL codeIngo Molnar
remove the !PREEMPT_BKL code. this removes 160 lines of legacy code. Signed-off-by: Ingo Molnar <mingo@elte.hu>
2007-07-16Remove unnecessary includes of spinlock.h under include/linuxRobert P. J. Day
Remove the obviously unnecessary includes of <linux/spinlock.h> under the include/linux/ directory, and fix the couple errors that are introduced as a result of that. Signed-off-by: Robert P. J. Day <rpjday@mindspring.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2006-04-26Don't include linux/config.h from anywhere else in include/David Woodhouse
2005-11-13[PATCH] m68k: thread_info header cleanupAl Viro
a) in smp_lock.h #include of sched.h and spinlock.h moved under #ifdef CONFIG_LOCK_KERNEL. b) interrupt.h now explicitly pulls sched.h (not via smp_lock.h from hardirq.h as it used to) c) in three more places we need changes to compensate for (a) - one place in arch/sparc needs string.h now, hardirq.h needs forward declaration of task_struct and preempt.h needs direct include of thread_info.h. d) thread_info-related helpers in sched.h and thread_info.h put under ifndef __HAVE_THREAD_FUNCTIONS. Obviously safe. Signed-off-by: Al Viro <viro@parcelfarce.linux.theplanet.co.uk> Signed-off-by: Roman Zippel <zippel@linux-m68k.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
