path: root/include/linux/skbuff.h
2007-10-15Merge branch 'master' of ↵Linus Torvalds
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 * 'master' of master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6: (42 commits) [IPV6]: Consolidate the ip6_pol_route_(input|output) pair [TCP]: Make snd_cwnd_cnt 32-bit [TCP]: Update the /proc/net/tcp documentation [NETNS]: Don't panic on creating the namespace's loopback [NEIGH]: Ensure that pneigh_lookup is protected with RTNL [INET]: kmalloc+memset -> kzalloc in frag_alloc_queue [ISDN]: Fix compile with CONFIG_ISDN_X25 disabled. [IPV6]: Replace sk_buff ** with sk_buff * in input handlers [SELINUX]: Update for netfilter ->hook() arg changes. [INET]: Consolidate the xxx_put [INET]: Small cleanup for xxx_put after evictor consolidation [INET]: Consolidate the xxx_evictor [INET]: Consolidate the xxx_frag_destroy [INET]: Consolidate xxx_the secret_rebuild [INET]: Consolidate the xxx_frag_kill [INET]: Collect common frag sysctl variables together [INET]: Collect frag queues management objects together [INET]: Move common fields from frag_queues in one place. [TG3]: Fix performance regression on 5705. [ISDN]: Remove local copy of device name to make sure renames work. ...
2007-10-15[SKBUFF]: Add skb_morphHerbert Xu
This patch creates a new function skb_morph that's just like skb_clone except that it lets user provide the spare skb that will be overwritten by the one that's to be cloned. This will be used by IP fragment reassembly so that we get back the same skb that went in last (rather than the head skb that we get now which requires us to carry around double pointers all over the place). Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-15Add skb_is_gso_v6Brice Goglin
Add skb_is_gso_v6(). Signed-off-by: Brice Goglin <brice@myri.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-09-16[NET] skbuff: Add skb_cow_headHerbert Xu
This patch adds an optimised version of skb_cow that avoids the copy if the header can be modified even if the rest of the payload is cloned. This can be used in encapsulating paths where we only need to modify the header. As it is, this can be used in PPPOE and bridging. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-07-31[NET]: Page offsets and lengths need to be __u32.David S. Miller
Based upon a report from Stephen Rothwell. Signed-off-by: David S. Miller <davem@davemloft.net>
2007-07-15fix return type of skb_checksum_complete()Al Viro
It returns __sum16, not unsigned int Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-10[NET]: Update comments for skb checksumsHerbert Xu
Rusty (whose comments we should all study and emulate :) pointed out that our comments for skb checksums are no longer up-to-date. So here is a patch to 1) add the case of partial checksums on input; 2) update partial checksum case to mention csum_start/csum_offset; 3) mention the new IPv6 feature bit. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-07-10[NETFILTER]: x_tables: add TRACE targetJozsef Kadlecsik
The TRACE target can be used to follow IP and IPv6 packets through the ruleset. Signed-off-by: Jozsef Kadlecsik <kadlec@blackhole.kfki.hu> Signed-off-by: Patrick NcHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-07-10[CORE] Stack changes to add multiqueue hardware support APIPeter P Waskiewicz Jr
Add the multiqueue hardware device support API to the core network stack. Allow drivers to allocate multiple queues and manage them at the netdev level if they choose to do so. Added a new field to sk_buff, namely queue_mapping, for drivers to know which tx_ring to select based on OS classification of the flow. Signed-off-by: Peter P Waskiewicz Jr <peter.p.waskiewicz.jr@intel.com> Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-07-10[SKBUFF]: Keep track of writable header len of headerless clonesPatrick McHardy
Currently NAT (and others) that want to modify cloned skbs copy them, even if in the vast majority of cases its not necessary because the skb is a clone made by TCP and the portion NAT wants to modify is actually writable because TCP release the header reference before cloning. The problem is that there is no clean way for NAT to find out how long the writable header area is, so this patch introduces skb->hdr_len to hold this length. When a headerless skb is cloned skb->hdr_len is set to the current headroom, for regular clones it is copied from the original. A new function skb_clone_writable(skb, len) returns whether the skb is writable up to len bytes from skb->data. To avoid enlarging the skb the mac_len field is reduced to 16 bit and the new hdr_len field is put in the remaining 16 bit. I've done a few rough benchmarks of NAT (not with this exact patch, but a very similar one). As expected it saves huge amounts of system time in case of sendfile, bringing it down to basically the same amount as without NAT, with sendmsg it only helps on loopback, probably because of the large MTU. Transmit a 1GB file using sendfile/sendmsg over eth0/lo with and without NAT: - sendfile eth0, no NAT: sys 0m0.388s - sendfile eth0, NAT: sys 0m1.835s - sendfile eth0: NAT + path: sys 0m0.370s (~ -80%) - sendfile lo, no NAT: sys 0m0.258s - sendfile lo, NAT: sys 0m2.609s - sendfile lo, NAT + patch: sys 0m0.260s (~ -90%) - sendmsg eth0, no NAT: sys 0m2.508s - sendmsg eth0, NAT: sys 0m2.539s - sendmsg eth0, NAT + patch: sys 0m2.445s (no change) - sendmsg lo, no NAT: sys 0m2.151s - sendmsg lo, NAT: sys 0m3.557s - sendmsg lo, NAT + patch: sys 0m2.159s (~ -40%) I expect other users can see a similar performance improvement, packet mangling iptables targets, ipip and ip_gre come to mind .. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-06-15[TCP]: Congestion control API RTT sampling fixIlpo Järvinen
Commit 164891aadf1721fca4dce473bb0e0998181537c6 broke RTT sampling of congestion control modules. Inaccurate timestamps could be fed to them without providing any way for them to identify such cases. Previously RTT sampler was called only if FLAG_RETRANS_DATA_ACKED was not set filtering inaccurate timestamps nicely. In addition, the new behavior could give an invalid timestamp (zero) to RTT sampler if only skbs with TCPCB_RETRANS were ACKed. This solves both problems. Signed-off-by: Ilpo Järvinen <ilpo.jarvinen@helsinki.fi> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-05-03[NET] skbuff: fix kernel-docRandy Dunlap
Fix skbuff.h kernel-doc: linux-2.6.21-git4//include/linux/skbuff.h:316): No description found for parameter 'transport_header' Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-30[SKB]: Introduce skb_queue_walk_safe()James Chapman
This patch provides a method for walking skb lists while inserting or removing skbs from the list. Signed-off-by: James Chapman <jchapman@katalix.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-25[TCP]: Congestion control API update.Stephen Hemminger
Do some simple changes to make congestion control API faster/cleaner. * use ktime_t rather than timeval * merge rtt sampling into existing ack callback this means one indirect call versus two per ack. * use flags bits to store options/settings Signed-off-by: Stephen Hemminger <shemminger@linux-foundation.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-25[NET] skbuff: skb_store_bits const is backwardsStephen Hemminger
Getting warnings becuase skb_store_bits has skb as constant, but the function overwrites it. Looks like const was on the wrong side. Signed-off-by: Stephen Hemminger <shemminger@linux-foundation.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-25[NET]: Treat CHECKSUM_PARTIAL as CHECKSUM_UNNECESSARYHerbert Xu
When a transmitted packet is looped back directly, CHECKSUM_PARTIAL maps to the semantics of CHECKSUM_UNNECESSARY. Therefore we should treat it as such in the stack. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-25[NET]: Use csum_start offset instead of skb_transport_headerHerbert Xu
The skb transport pointer is currently used to specify the start of the checksum region for transmit checksum offload. Unfortunately, the same pointer is also used during receive side processing. This creates a problem when we want to retransmit a received packet with partial checksums since the skb transport pointer would be overwritten. This patch solves this problem by creating a new 16-bit csum_start offset value to replace the skb transport header for the purpose of checksums. This offset is calculated from skb->head so that it does not have to change when skb->data changes. No extra space is required since csum_offset itself fits within a 16-bit word so we can use the other 16 bits for csum_start. For backwards compatibility, just before we push a packet with partial checksums off into the device driver, we set the skb transport header to what it would have been under the old scheme. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-25[NET]: Move generic skbuff stuff from XFRM code to generic codeDavid Howells
Move generic skbuff stuff from XFRM code to generic code so that AF_RXRPC can use it too. The kdoc comments I've attached to the functions needs to be checked by whoever wrote them as I had to make some guesses about the workings of these functions. Signed-off-By: David Howells <dhowells@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-25[SK_BUFF]: Introduce skb_copy_to_linear_data{_offset}Arnaldo Carvalho de Melo
To clearly state the intent of copying to linear sk_buffs, _offset being a overly long variant but interesting for the sake of saving some bytes. Signed-off-by: Arnaldo Carvalho de Melo <acme@ghostprotocols.net>
2007-04-25[SK_BUFF]: Introduce skb_copy_from_linear_data{_offset}Arnaldo Carvalho de Melo
To clearly state the intent of copying from linear sk_buffs, _offset being a overly long variant but interesting for the sake of saving some bytes. Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2007-04-25[NET]: Allow forwarding of ip_summed except CHECKSUM_COMPLETEHerbert Xu
Right now Xen has a horrible hack that lets it forward packets with partial checksums. One of the reasons that CHECKSUM_PARTIAL and CHECKSUM_COMPLETE were added is so that we can get rid of this hack (where it creates two extra bits in the skbuff to essentially mirror ip_summed without being destroyed by the forwarding code). I had forgotten that I've already gone through all the deivce drivers last time around to make sure that they're looking at ip_summed == CHECKSUM_PARTIAL rather than ip_summed != 0 on transmit. In any case, I've now done that again so it should definitely be safe. Unfortunately nobody has yet added any code to update CHECKSUM_COMPLETE values on forward so we I'm setting that to CHECKSUM_NONE. This should be safe to remove for bridging but I'd like to check that code path first. So here is the patch that lets us get rid of the hack by preserving ip_summed (mostly) on forwarded packets. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-25[NETFILTER]: nf_conntrack: kill destroy() in struct nf_conntrack for dietYasuyuki Kozakai
The destructor per conntrack is unnecessary, then this replaces it with system wide destructor. Signed-off-by: Yasuyuki Kozakai <yasuyuki.kozakai@toshiba.co.jp> Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-25[NETFILTER]: nf_conntrack: don't use nfct in skb if conntrack is disabledYasuyuki Kozakai
2007-04-25[SK_BUFF]: Remove skb_add_mtu() leftoversArnaldo Carvalho de Melo
2007-04-25[SK_BUFF]: Convert skb->end to sk_buff_data_tArnaldo Carvalho de Melo
Now to convert the last one, skb->data, that will allow many simplifications and removal of some of the offset helpers. Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-25[SK_BUFF]: Convert skb->tail to sk_buff_data_tArnaldo Carvalho de Melo
So that it is also an offset from skb->head, reduces its size from 8 to 4 bytes on 64bit architectures, allowing us to combine the 4 bytes hole left by the layer headers conversion, reducing struct sk_buff size to 256 bytes, i.e. 4 64byte cachelines, and since the sk_buff slab cache is SLAB_HWCACHE_ALIGN... :-) Many calculations that previously required that skb->{transport,network, mac}_header be first converted to a pointer now can be done directly, being meaningful as offsets or pointers. Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-25[SK_BUFF]: Use offsets for skb->{mac,network,transport}_header on 64bit ↵Arnaldo Carvalho de Melo
architectures With this we save 8 bytes per network packet, leaving a 4 bytes hole to be used in further shrinking work, likely with the offsetization of other pointers, such as ->{data,tail,end}, at the cost of adds, that were minimized by the usual practice of setting skb->{mac,nh,n}.raw to a local variable that is then accessed multiple times in each function, it also is not more expensive than before with regards to most of the handling of such headers, like setting one of these headers to another (transport to network, etc), or subtracting, adding to/from it, comparing them, etc. Now we have this layout for sk_buff on a x86_64 machine: [acme@mica net-2.6.22]$ pahole vmlinux sk_buff struct sk_buff { struct sk_buff * next; /* 0 8 */ struct sk_buff * prev; /* 8 8 */ struct rb_node rb; /* 16 24 */ struct sock * sk; /* 40 8 */ ktime_t tstamp; /* 48 8 */ struct net_device * dev; /* 56 8 */ /* --- cacheline 1 boundary (64 bytes) --- */ struct net_device * input_dev; /* 64 8 */ sk_buff_data_t transport_header; /* 72 4 */ sk_buff_data_t network_header; /* 76 4 */ sk_buff_data_t mac_header; /* 80 4 */ /* XXX 4 bytes hole, try to pack */ struct dst_entry * dst; /* 88 8 */ struct sec_path * sp; /* 96 8 */ char cb[48]; /* 104 48 */ /* cacheline 2 boundary (128 bytes) was 24 bytes ago*/ unsigned int len; /* 152 4 */ unsigned int data_len; /* 156 4 */ unsigned int mac_len; /* 160 4 */ union { __wsum csum; /* 4 */ __u32 csum_offset; /* 4 */ }; /* 164 4 */ __u32 priority; /* 168 4 */ __u8 local_df:1; /* 172 1 */ __u8 cloned:1; /* 172 1 */ __u8 ip_summed:2; /* 172 1 */ __u8 nohdr:1; /* 172 1 */ __u8 nfctinfo:3; /* 172 1 */ __u8 pkt_type:3; /* 173 1 */ __u8 fclone:2; /* 173 1 */ __u8 ipvs_property:1; /* 173 1 */ /* XXX 2 bits hole, try to pack */ __be16 protocol; /* 174 2 */ void (*destructor)(struct sk_buff *); /* 176 8 */ struct nf_conntrack * nfct; /* 184 8 */ /* --- cacheline 3 boundary (192 bytes) --- */ struct sk_buff * nfct_reasm; /* 192 8 */ struct nf_bridge_info *nf_bridge; /* 200 8 */ __u16 tc_index; /* 208 2 */ __u16 tc_verd; /* 210 2 */ dma_cookie_t dma_cookie; /* 212 4 */ __u32 secmark; /* 216 4 */ __u32 mark; /* 220 4 */ unsigned int truesize; /* 224 4 */ atomic_t users; /* 228 4 */ unsigned char * head; /* 232 8 */ unsigned char * data; /* 240 8 */ unsigned char * tail; /* 248 8 */ /* --- cacheline 4 boundary (256 bytes) --- */ unsigned char * end; /* 256 8 */ }; /* size: 264, cachelines: 5 */ /* sum members: 260, holes: 1, sum holes: 4 */ /* bit holes: 1, sum bit holes: 2 bits */ /* last cacheline: 8 bytes */ On 32 bits nothing changes, and pointers continue to be used with the compiler turning all this abstraction layer into dust. But there are some sk_buff validation tricks that are now possible, humm... :-) Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-25[SK_BUFF]: unions of just one member don't get anything done, kill themArnaldo Carvalho de Melo
Renaming skb->h to skb->transport_header, skb->nh to skb->network_header and skb->mac to skb->mac_header, to match the names of the associated helpers (skb[_[re]set]_{transport,network,mac}_header). Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-25[SK_BUFF]: Introduce skb_network_header_lenArnaldo Carvalho de Melo
For the common sequence "skb->h.raw - skb->nh.raw", similar to skb->mac_len, that is precalculated tho, don't think we need to bloat skb with one more member, so just use this new helper, reducing the number of non-skbuff.h references to the layer headers even more. Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-25[NETFILTER]: nf_conntrack: add nf_copy() to safely copy members in skbYasuyuki Kozakai
This unifies the codes to copy netfilter related datas. Before copying, nf_copy() puts original members in destination skb. Signed-off-by: Yasuyuki Kozakai <yasuyuki.kozakai@toshiba.co.jp> Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-25[NETFILTER]: nf_conntrack: add __nf_copy() to copy members in skbYasuyuki Kozakai
This unifies the codes to copy netfilter related datas. Note that __nf_copy() assumes destination skb doesn't have any netfilter related members. Signed-off-by: Yasuyuki Kozakai <yasuyuki.kozakai@toshiba.co.jp> Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-25[SK_BUFF]: Introduce skb_transport_header(skb)Arnaldo Carvalho de Melo
For the places where we need a pointer to the transport header, it is still legal to touch skb->h.raw directly if just adding to, subtracting from or setting it to another layer header. Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-25[SK_BUFF]: Introduce ipipv6_hdr(), remove skb->h.ipv6hArnaldo Carvalho de Melo
2007-04-25[SK_BUFF]: Introduce ipip_hdr(), remove skb->h.ipiphArnaldo Carvalho de Melo
2007-04-25[SK_BUFF]: Introduce tcp_hdr(), remove skb->h.thArnaldo Carvalho de Melo
2007-04-25[SK_BUFF]: Introduce icmp_hdr(), remove skb->h.icmphArnaldo Carvalho de Melo
2007-04-25[SK_BUFF]: Introduce udp_hdr(), remove skb->h.uhArnaldo Carvalho de Melo
2007-04-25[SK_BUFF]: Introduce igmp_hdr() & friends, remove skb->h.igmphArnaldo Carvalho de Melo
2007-04-25[SK_BUFF]: Introduce skb_set_transport_headerArnaldo Carvalho de Melo
For the cases where the transport header is being set to a offset from skb->data. Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-25[SK_BUFF]: Introduce skb_transport_offset()Arnaldo Carvalho de Melo
For the quite common 'skb->h.raw - skb->data' sequence. Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-25[SK_BUFF]: Introduce skb_reset_transport_header(skb)Arnaldo Carvalho de Melo
For the common, open coded 'skb->h.raw = skb->data' operation, so that we can later turn skb->h.raw into a offset, reducing the size of struct sk_buff in 64bit land while possibly keeping it as a pointer on 32bit. This one touches just the most simple cases: skb->h.raw = skb->data; skb->h.raw = {skb_push|[__]skb_pull}() The next ones will handle the slightly more "complex" cases. Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-25[SK_BUFF]: Introduce ipv6_hdr(), remove skb->nh.ipv6hArnaldo Carvalho de Melo
Now the skb->nh union has just one member, .raw, i.e. it is just like the skb->mac union, strange, no? I'm just leaving it like that till the transport layer is done with, when we'll rename skb->mac.raw to skb->mac_header (or ->mac_header_offset?), ditto for ->{h,nh}. Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-25[SK_BUFF]: Introduce arp_hdr(), remove skb->nh.arphArnaldo Carvalho de Melo
2007-04-25[SK_BUFF]: Introduce ip_hdr(), remove skb->nh.iphArnaldo Carvalho de Melo
2007-04-25[SK_BUFF]: Introduce skb_set_network_headerArnaldo Carvalho de Melo
For the cases where the network header is being set to a offset from skb->data. Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-25[SK_BUFF]: Introduce skb_network_header()Arnaldo Carvalho de Melo
For the places where we need a pointer to the network header, it is still legal to touch skb->nh.raw directly if just adding to, subtracting from or setting it to another layer header. Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-25[SK_BUFF]: Introduce skb_network_offset()Arnaldo Carvalho de Melo
For the quite common 'skb->nh.raw - skb->data' sequence. Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-25[SK_BUFF]: Introduce skb_reset_network_header(skb)Arnaldo Carvalho de Melo
For the common, open coded 'skb->nh.raw = skb->data' operation, so that we can later turn skb->nh.raw into a offset, reducing the size of struct sk_buff in 64bit land while possibly keeping it as a pointer on 32bit. This one touches just the most simple case, next will handle the slightly more "complex" cases. Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-25[SK_BUFF]: Introduce skb_mac_header()Arnaldo Carvalho de Melo
For the places where we need a pointer to the mac header, it is still legal to touch skb->mac.raw directly if just adding to, subtracting from or setting it to another layer header. This one also converts some more cases to skb_reset_mac_header() that my regex missed as it had no spaces before nor after '=', ugh. Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-25[SK_BUFF]: Introduce skb_set_mac_header()Arnaldo Carvalho de Melo
For the cases where we want to set skb->mac.raw to an offset from skb->data. Simple cases first, the memmove ones and specially pktgen will be left for later. Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
