path: root/include/linux/shmem_fs.h
2011-05-25tmpfs: implement generic xattr supportEric Paris
Implement generic xattrs for tmpfs filesystems. The Feodra project, while trying to replace suid apps with file capabilities, realized that tmpfs, which is used on the build systems, does not support file capabilities and thus cannot be used to build packages which use file capabilities. Xattrs are also needed for overlayfs. The xattr interface is a bit odd. If a filesystem does not implement any {get,set,list}xattr functions the VFS will call into some random LSM hooks and the running LSM can then implement some method for handling xattrs. SELinux for example provides a method to support security.selinux but no other security.* xattrs. As it stands today when one enables CONFIG_TMPFS_POSIX_ACL tmpfs will have xattr handler routines specifically to handle acls. Because of this tmpfs would loose the VFS/LSM helpers to support the running LSM. To make up for that tmpfs had stub functions that did nothing but call into the LSM hooks which implement the helpers. This new patch does not use the LSM fallback functions and instead just implements a native get/set/list xattr feature for the full security.* and trusted.* namespace like a normal filesystem. This means that tmpfs can now support both security.selinux and security.capability, which was not previously possible. The basic implementation is that I attach a: struct shmem_xattr { struct list_head list; /* anchored by shmem_inode_info->xattr_list */ char *name; size_t size; char value[0]; }; Into the struct shmem_inode_info for each xattr that is set. This implementation could easily support the user.* namespace as well, except some care needs to be taken to prevent large amounts of unswappable memory being allocated for unprivileged users. [mszeredi@suse.cz: new config option, suport trusted.*, support symlinks] Signed-off-by: Eric Paris <eparis@redhat.com> Signed-off-by: Miklos Szeredi <mszeredi@suse.cz> Acked-by: Serge Hallyn <serge.hallyn@ubuntu.com> Tested-by: Serge Hallyn <serge.hallyn@ubuntu.com> Cc: Kyle McMartin <kyle@mcmartin.ca> Acked-by: Hugh Dickins <hughd@google.com> Tested-by: Jordi Pujol <jordipujolp@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-08-09tmpfs: make tmpfs scalable with percpu_counter for used blocksTim Chen
The current implementation of tmpfs is not scalable. We found that stat_lock is contended by multiple threads when we need to get a new page, leading to useless spinning inside this spin lock. This patch makes use of the percpu_counter library to maintain local count of used blocks to speed up getting and returning of pages. So the acquisition of stat_lock is unnecessary for getting and returning blocks, improving the performance of tmpfs on system with large number of cpus. On a 4 socket 32 core NHM-EX system, we saw improvement of 270%. The implementation below has a slight chance of race between threads causing a slight overshoot of the maximum configured blocks. However, any overshoot is small, and is bounded by the number of cpus. This happens when the number of used blocks is slightly below the maximum configured blocks when a thread checks the used block count, and another thread allocates the last block before the current thread does. This should not be a problem for tmpfs, as the overshoot is most likely to be a few blocks and bounded. If a strict limit is really desired, then configured the max blocks to be the limit less the number of cpus in system. Signed-off-by: Tim Chen <tim.c.chen@linux.intel.com> Cc: Hugh Dickins <hughd@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-12-16make generic_acl slightly more genericChristoph Hellwig
Now that we cache the ACL pointers in the generic inode all the generic_acl cruft can go away and generic_acl.c can directly implement xattr handlers dealing with the full Posix ACL semantics for in-memory filesystems. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2009-09-15Driver Core: devtmpfs - kernel-maintained tmpfs-based /devKay Sievers
Devtmpfs lets the kernel create a tmpfs instance called devtmpfs very early at kernel initialization, before any driver-core device is registered. Every device with a major/minor will provide a device node in devtmpfs. Devtmpfs can be changed and altered by userspace at any time, and in any way needed - just like today's udev-mounted tmpfs. Unmodified udev versions will run just fine on top of it, and will recognize an already existing kernel-created device node and use it. The default node permissions are root:root 0600. Proper permissions and user/group ownership, meaningful symlinks, all other policy still needs to be applied by userspace. If a node is created by devtmps, devtmpfs will remove the device node when the device goes away. If the device node was created by userspace, or the devtmpfs created node was replaced by userspace, it will no longer be removed by devtmpfs. If it is requested to auto-mount it, it makes init=/bin/sh work without any further userspace support. /dev will be fully populated and dynamic, and always reflect the current device state of the kernel. With the commonly used dynamic device numbers, it solves the problem where static devices nodes may point to the wrong devices. It is intended to make the initial bootup logic simpler and more robust, by de-coupling the creation of the inital environment, to reliably run userspace processes, from a complex userspace bootstrap logic to provide a working /dev. Signed-off-by: Kay Sievers <kay.sievers@vrfy.org> Signed-off-by: Jan Blunck <jblunck@suse.de> Tested-By: Harald Hoyer <harald@redhat.com> Tested-By: Scott James Remnant <scott@ubuntu.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-09-08shmfs: use 'check_acl' instead of 'permission'Linus Torvalds
shmfs wants purely standard POSIX ACL semantics, so we can use the new generic VFS layer POSIX ACL checking rather than cooking our own 'permission()' function. Reviewed-by: James Morris <jmorris@namei.org> Acked-by: Serge Hallyn <serue@us.ibm.com> Acked-by: Hugh Dickins <hugh.dickins@tiscali.co.uk> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-06-24switch shmem to inode->i_aclAl Viro
2008-07-26[PATCH] sanitize ->permission() prototypeAl Viro
* kill nameidata * argument; map the 3 bits in ->flags anybody cares about to new MAY_... ones and pass with the mask. * kill redundant gfs2_iop_permission() * sanitize ecryptfs_permission() * fix remaining places where ->permission() instances might barf on new MAY_... found in mask. The obvious next target in that direction is permission(9) folded fix for nfs_permission() breakage from Miklos Szeredi <mszeredi@suse.cz> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2008-04-28mempolicy: use struct mempolicy pointer in shmem_sb_infoLee Schermerhorn
This patch replaces the mempolicy mode, mode_flags, and nodemask in the shmem_sb_info struct with a struct mempolicy pointer, initialized to NULL. This removes dependency on the details of mempolicy from shmem.c and hugetlbfs inode.c and simplifies the interfaces. mpol_parse_str() in mempolicy.c is changed to return, via a pointer to a pointer arg, a struct mempolicy pointer on success. For MPOL_DEFAULT, the returned pointer is NULL. Further, mpol_parse_str() now takes a 'no_context' argument that causes the input nodemask to be stored in the w.user_nodemask of the created mempolicy for use when the mempolicy is installed in a tmpfs inode shared policy tree. At that time, any cpuset contextualization is applied to the original input nodemask. This preserves the previous behavior where the input nodemask was stored in the superblock. We can think of the returned mempolicy as "context free". Because mpol_parse_str() is now calling mpol_new(), we can remove from mpol_to_str() the semantic checks that mpol_new() already performs. Add 'no_context' parameter to mpol_to_str() to specify that it should format the nodemask in w.user_nodemask for 'bind' and 'interleave' policies. Change mpol_shared_policy_init() to take a pointer to a "context free" struct mempolicy and to create a new, "contextualized" mempolicy using the mode, mode_flags and user_nodemask from the input mempolicy. Note: we know that the mempolicy passed to mpol_to_str() or mpol_shared_policy_init() from a tmpfs superblock is "context free". This is currently the only instance thereof. However, if we found more uses for this concept, and introduced any ambiguity as to whether a mempolicy was context free or not, we could add another internal mode flag to identify context free mempolicies. Then, we could remove the 'no_context' argument from mpol_to_str(). Added shmem_get_sbmpol() to return a reference counted superblock mempolicy, if one exists, to pass to mpol_shared_policy_init(). We must add the reference under the sb stat_lock to prevent races with replacement of the mpol by remount. This reference is removed in mpol_shared_policy_init(). [akpm@linux-foundation.org: build fix] [akpm@linux-foundation.org: another build fix] [akpm@linux-foundation.org: yet another build fix] Signed-off-by: Lee Schermerhorn <lee.schermerhorn@hp.com> Cc: Christoph Lameter <clameter@sgi.com> Cc: David Rientjes <rientjes@google.com> Cc: Mel Gorman <mel@csn.ul.ie> Cc: Andi Kleen <ak@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-28mempolicy: support optional mode flagsDavid Rientjes
With the evolution of mempolicies, it is necessary to support mempolicy mode flags that specify how the policy shall behave in certain circumstances. The most immediate need for mode flag support is to suppress remapping the nodemask of a policy at the time of rebind. Both the mempolicy mode and flags are passed by the user in the 'int policy' formal of either the set_mempolicy() or mbind() syscall. A new constant, MPOL_MODE_FLAGS, represents the union of legal optional flags that may be passed as part of this int. Mempolicies that include illegal flags as part of their policy are rejected as invalid. An additional member to struct mempolicy is added to support the mode flags: struct mempolicy { ... unsigned short policy; unsigned short flags; } The splitting of the 'int' actual passed by the user is done in sys_set_mempolicy() and sys_mbind() for their respective syscalls. This is done by intersecting the actual with MPOL_MODE_FLAGS, rejecting the syscall of there are additional flags, and storing it in the new 'flags' member of struct mempolicy. The intersection of the actual with ~MPOL_MODE_FLAGS is stored in the 'policy' member of the struct and all current users of pol->policy remain unchanged. The union of the policy mode and optional mode flags is passed back to the user in get_mempolicy(). This combination of mode and flags within the same actual does not break userspace code that relies on get_mempolicy(&policy, ...) and either switch (policy) { case MPOL_BIND: ... case MPOL_INTERLEAVE: ... }; statements or if (policy == MPOL_INTERLEAVE) { ... } statements. Such applications would need to use optional mode flags when calling set_mempolicy() or mbind() for these previously implemented statements to stop working. If an application does start using optional mode flags, it will need to mask the optional flags off the policy in switch and conditional statements that only test mode. An additional member is also added to struct shmem_sb_info to store the optional mode flags. [hugh@veritas.com: shmem mpol: fix build warning] Cc: Paul Jackson <pj@sgi.com> Cc: Christoph Lameter <clameter@sgi.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com> Cc: Andi Kleen <ak@suse.de> Signed-off-by: David Rientjes <rientjes@google.com> Signed-off-by: Hugh Dickins <hugh@veritas.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-28mempolicy: convert MPOL constants to enumDavid Rientjes
The mempolicy mode constants, MPOL_DEFAULT, MPOL_PREFERRED, MPOL_BIND, and MPOL_INTERLEAVE, are better declared as part of an enum since they are sequentially numbered and cannot be combined. The policy member of struct mempolicy is also converted from type short to type unsigned short. A negative policy does not have any legitimate meaning, so it is possible to change its type in preparation for adding optional mode flags later. The equivalent member of struct shmem_sb_info is also changed from int to unsigned short. For compatibility, the policy formal to get_mempolicy() remains as a pointer to an int: int get_mempolicy(int *policy, unsigned long *nmask, unsigned long maxnode, unsigned long addr, unsigned long flags); although the only possible values is the range of type unsigned short. Cc: Paul Jackson <pj@sgi.com> Cc: Christoph Lameter <clameter@sgi.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com> Cc: Andi Kleen <ak@suse.de> Signed-off-by: David Rientjes <rientjes@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-08mount options: fix tmpfsakpm@linux-foundation.org
Add .show_options super operation to tmpfs. Signed-off-by: Hugh Dickins <hugh@veritas.com> Signed-off-by: Miklos Szeredi <mszeredi@suse.cz> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2006-09-29[PATCH] Access Control Lists for tmpfsAndreas Gruenbacher
Add access control lists for tmpfs. Signed-off-by: Andreas Gruenbacher <agruen@suse.de> Cc: Hugh Dickins <hugh@veritas.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-14[PATCH] Add tmpfs options for memory placement policiesRobin Holt
Anything that writes into a tmpfs filesystem is liable to disproportionately decrease the available memory on a particular node. Since there's no telling what sort of application (e.g. dd/cp/cat) might be dropping large files there, this lets the admin choose the appropriate default behavior for their site's situation. Introduce a tmpfs mount option which allows specifying a memory policy and a second option to specify the nodelist for that policy. With the default policy, tmpfs will behave as it does today. This patch adds support for preferred, bind, and interleave policies. The default policy will cause pages to be added to tmpfs files on the node which is doing the writing. Some jobs expect a single process to create and manage the tmpfs files. This results in a node which has a significantly reduced number of free pages. With this patch, the administrator can specify the policy and nodes for that policy where they would prefer allocations. This patch was originally written by Brent Casavant and Hugh Dickins. I added support for the bind and preferred policies and the mpol_nodelist mount option. Signed-off-by: Brent Casavant <bcasavan@sgi.com> Signed-off-by: Hugh Dickins <hugh@veritas.com> Signed-off-by: Robin Holt <holt@sgi.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
