path: root/include/linux/security.h
2005-10-30[PATCH] SELinux: canonicalize getxattr()James Morris
This patch allows SELinux to canonicalize the value returned from getxattr() via the security_inode_getsecurity() hook, which is called after the fs level getxattr() function. The purpose of this is to allow the in-core security context for an inode to override the on-disk value. This could happen in cases such as upgrading a system to a different labeling form (e.g. standard SELinux to MLS) without needing to do a full relabel of the filesystem. In such cases, we want getxattr() to return the canonical security context that the kernel is using rather than what is stored on disk. The implementation hooks into the inode_getsecurity(), adding another parameter to indicate the result of the preceding fs-level getxattr() call, so that SELinux knows whether to compare a value obtained from disk with the kernel value. We also now allow getxattr() to work for mountpoint labeled filesystems (i.e. mount with option context=foo_t), as we are able to return the kernel value to the user. Signed-off-by: James Morris <jmorris@namei.org> Signed-off-by: Stephen Smalley <sds@tycho.nsa.gov> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-10-28[PATCH] gfp_t: net/*Al Viro
2005-10-08[PATCH] gfp flags annotations - part 1Al Viro
- added typedef unsigned int __nocast gfp_t; - replaced __nocast uses for gfp flags with gfp_t - it gives exactly the same warnings as far as sparse is concerned, doesn't change generated code (from gcc point of view we replaced unsigned int with typedef) and documents what's going on far better. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-13Merge master.kernel.org:/pub/scm/linux/kernel/git/chrisw/lsm-2.6 Linus Torvalds
2005-09-09[PATCH] remove the inode_post_link and inode_post_rename LSM hooksStephen Smalley
This patch removes the inode_post_link and inode_post_rename LSM hooks as they are unused (and likely useless). Signed-off-by: Stephen Smalley <sds@tycho.nsa.gov> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-09[PATCH] Remove security_inode_post_create/mkdir/symlink/mknod hooksStephen Smalley
This patch removes the inode_post_create/mkdir/mknod/symlink LSM hooks as they are obsoleted by the new inode_init_security hook that enables atomic inode security labeling. If anyone sees any reason to retain these hooks, please speak now. Also, is anyone using the post_rename/link hooks; if not, those could also be removed. Signed-off-by: Stephen Smalley <sds@tycho.nsa.gov> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-09[PATCH] security: enable atomic inode security labelingStephen Smalley
The following patch set enables atomic security labeling of newly created inodes by altering the fs code to invoke a new LSM hook to obtain the security attribute to apply to a newly created inode and to set up the incore inode security state during the inode creation transaction. This parallels the existing processing for setting ACLs on newly created inodes. Otherwise, it is possible for new inodes to be accessed by another thread via the dcache prior to complete security setup (presently handled by the post_create/mkdir/... LSM hooks in the VFS) and a newly created inode may be left unlabeled on the disk in the event of a crash. SELinux presently works around the issue by ensuring that the incore inode security label is initialized to a special SID that is inaccessible to unprivileged processes (in accordance with policy), thereby preventing inappropriate access but potentially causing false denials on legitimate accesses. A simple test program demonstrates such false denials on SELinux, and the patch solves the problem. Similar such false denials have been encountered in real applications. This patch defines a new inode_init_security LSM hook to obtain the security attribute to apply to a newly created inode and to set up the incore inode security state for it, and adds a corresponding hook function implementation to SELinux. Signed-off-by: Stephen Smalley <sds@tycho.nsa.gov> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-08-29[NET]: Fix sparse warningsArnaldo Carvalho de Melo
Of this type, mostly: CHECK net/ipv6/netfilter.c net/ipv6/netfilter.c:96:12: warning: symbol 'ipv6_netfilter_init' was not declared. Should it be static? net/ipv6/netfilter.c:101:6: warning: symbol 'ipv6_netfilter_fini' was not declared. Should it be static? Signed-off-by: Arnaldo Carvalho de Melo <acme@mandriva.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-07-08[PATCH] add securityfs for all LSMs to useGreg KH
Here's a small patch against 2.6.13-rc2 that adds securityfs, a virtual fs that all LSMs can use instead of creating their own. The fs should be mounted at /sys/kernel/security, and the fs creates that mount point. This will make the LSB people happy that we aren't creating a new /my_lsm_fs directory in the root for every different LSM. It has changed a bit since the last version, thanks to comments from Mike Waychison. Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de> Signed-off-by: Chris Wright <chrisw@osdl.org>
