path: root/include/linux/rmap.h
2015-01-08mm: prevent endless growth of anon_vma hierarchyKonstantin Khlebnikov
Constantly forking task causes unlimited grow of anon_vma chain. Each next child allocates new level of anon_vmas and links vma to all previous levels because pages might be inherited from any level. This patch adds heuristic which decides to reuse existing anon_vma instead of forking new one. It adds counter anon_vma->degree which counts linked vmas and directly descending anon_vmas and reuses anon_vma if counter is lower than two. As a result each anon_vma has either vma or at least two descending anon_vmas. In such trees half of nodes are leafs with alive vmas, thus count of anon_vmas is no more than two times bigger than count of vmas. This heuristic reuses anon_vmas as few as possible because each reuse adds false aliasing among vmas and rmap walker ought to scan more ptes when it searches where page is might be mapped. Link: http://lkml.kernel.org/r/20120816024610.GA5350@evergreen.ssec.wisc.edu Fixes: 5beb49305251 ("mm: change anon_vma linking to fix multi-process server scalability issue") [akpm@linux-foundation.org: fix typo, per Rik] Signed-off-by: Konstantin Khlebnikov <koct9i@gmail.com> Reported-by: Daniel Forrest <dan.forrest@ssec.wisc.edu> Tested-by: Michal Hocko <mhocko@suse.cz> Tested-by: Jerome Marchand <jmarchan@redhat.com> Reviewed-by: Michal Hocko <mhocko@suse.cz> Reviewed-by: Rik van Riel <riel@redhat.com> Cc: <stable@vger.kernel.org> [2.6.34+] Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-10-09mm: convert a few VM_BUG_ON callers to VM_BUG_ON_VMASasha Levin
Trivially convert a few VM_BUG_ON calls to VM_BUG_ON_VMA to extract more information when they trigger. [akpm@linux-foundation.org: coding-style fixes] Signed-off-by: Sasha Levin <sasha.levin@oracle.com> Reviewed-by: Naoya Horiguchi <n-horiguchi@ah.jp.nec.com> Cc: Kirill A. Shutemov <kirill.shutemov@linux.intel.com> Cc: Konstantin Khlebnikov <khlebnikov@openvz.org> Cc: Rik van Riel <riel@redhat.com> Cc: Mel Gorman <mgorman@suse.de> Cc: Michal Hocko <mhocko@suse.cz> Cc: Hugh Dickins <hughd@google.com> Cc: Vlastimil Babka <vbabka@suse.cz> Cc: Michel Lespinasse <walken@google.com> Cc: Minchan Kim <minchan@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-06-04mm/rmap.c: cleanup ttu_flagsKonstantin Khlebnikov
Transform action part of ttu_flags into individiual bits. These flags aren't part of any uses-space visible api or even trace events. Signed-off-by: Konstantin Khlebnikov <koct9i@gmail.com> Cc: Rik van Riel <riel@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-06-04mm/rmap.c: make page_referenced_one() and try_to_unmap_one() staticKirill A. Shutemov
KSM was converted to use rmap_walk() and now nobody uses these functions outside mm/rmap.c. Let's covert them back to static. Signed-off-by: Kirill A. Shutemov <kirill.shutemov@linux.intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-03-20mm: fix swapops.h:131 bug if remap_file_pages raced migrationHugh Dickins
Add remove_linear_migration_ptes_from_nonlinear(), to fix an interesting little include/linux/swapops.h:131 BUG_ON(!PageLocked) found by trinity: indicating that remove_migration_ptes() failed to find one of the migration entries that was temporarily inserted. The problem comes from remap_file_pages()'s switch from vma_interval_tree (good for inserting the migration entry) to i_mmap_nonlinear list (no good for locating it again); but can only be a problem if the remap_file_pages() range does not cover the whole of the vma (zap_pte() clears the range). remove_migration_ptes() needs a file_nonlinear method to go down the i_mmap_nonlinear list, applying linear location to look for migration entries in those vmas too, just in case there was this race. The file_nonlinear method does need rmap_walk_control.arg to do this; but it never needed vma passed in - vma comes from its own iteration. Reported-and-tested-by: Dave Jones <davej@redhat.com> Reported-and-tested-by: Sasha Levin <sasha.levin@oracle.com> Signed-off-by: Hugh Dickins <hughd@google.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-01-21mm/rmap: use rmap_walk() in page_referenced()Joonsoo Kim
Now, we have an infrastructure in rmap_walk() to handle difference from variants of rmap traversing functions. So, just use it in page_referenced(). In this patch, I change following things. 1. remove some variants of rmap traversing functions. cf> page_referenced_ksm, page_referenced_anon, page_referenced_file 2. introduce new struct page_referenced_arg and pass it to page_referenced_one(), main function of rmap_walk, in order to count reference, to store vm_flags and to check finish condition. 3. mechanical change to use rmap_walk() in page_referenced(). [liwanp@linux.vnet.ibm.com: fix BUG at rmap_walk] Signed-off-by: Joonsoo Kim <iamjoonsoo.kim@lge.com> Reviewed-by: Naoya Horiguchi <n-horiguchi@ah.jp.nec.com> Cc: Mel Gorman <mgorman@suse.de> Cc: Hugh Dickins <hughd@google.com> Cc: Rik van Riel <riel@redhat.com> Cc: Ingo Molnar <mingo@kernel.org> Cc: Hillf Danton <dhillf@gmail.com> Signed-off-by: Wanpeng Li <liwanp@linux.vnet.ibm.com> Cc: Sasha Levin <sasha.levin@oracle.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-01-21mm/rmap: use rmap_walk() in try_to_unmap()Joonsoo Kim
Now, we have an infrastructure in rmap_walk() to handle difference from variants of rmap traversing functions. So, just use it in try_to_unmap(). In this patch, I change following things. 1. enable rmap_walk() if !CONFIG_MIGRATION. 2. mechanical change to use rmap_walk() in try_to_unmap(). Signed-off-by: Joonsoo Kim <iamjoonsoo.kim@lge.com> Reviewed-by: Naoya Horiguchi <n-horiguchi@ah.jp.nec.com> Cc: Mel Gorman <mgorman@suse.de> Cc: Hugh Dickins <hughd@google.com> Cc: Rik van Riel <riel@redhat.com> Cc: Ingo Molnar <mingo@kernel.org> Cc: Hillf Danton <dhillf@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-01-21mm/rmap: extend rmap_walk_xxx() to cope with different casesJoonsoo Kim
There are a lot of common parts in traversing functions, but there are also a little of uncommon parts in it. By assigning proper function pointer on each rmap_walker_control, we can handle these difference correctly. Following are differences we should handle. 1. difference of lock function in anon mapping case 2. nonlinear handling in file mapping case 3. prechecked condition: checking memcg in page_referenced(), checking VM_SHARE in page_mkclean() checking temporary vma in try_to_unmap() 4. exit condition: checking page_mapped() in try_to_unmap() So, in this patch, I introduce 4 function pointers to handle above differences. Signed-off-by: Joonsoo Kim <iamjoonsoo.kim@lge.com> Cc: Naoya Horiguchi <n-horiguchi@ah.jp.nec.com> Cc: Mel Gorman <mgorman@suse.de> Cc: Hugh Dickins <hughd@google.com> Cc: Rik van Riel <riel@redhat.com> Cc: Ingo Molnar <mingo@kernel.org> Cc: Hillf Danton <dhillf@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-01-21mm/rmap: make rmap_walk to get the rmap_walk_control argumentJoonsoo Kim
In each rmap traverse case, there is some difference so that we need function pointers and arguments to them in order to handle these For this purpose, struct rmap_walk_control is introduced in this patch, and will be extended in following patch. Introducing and extending are separate, because it clarify changes. Signed-off-by: Joonsoo Kim <iamjoonsoo.kim@lge.com> Reviewed-by: Naoya Horiguchi <n-horiguchi@ah.jp.nec.com> Cc: Mel Gorman <mgorman@suse.de> Cc: Hugh Dickins <hughd@google.com> Cc: Rik van Riel <riel@redhat.com> Cc: Ingo Molnar <mingo@kernel.org> Cc: Hillf Danton <dhillf@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-02-23mm/rmap: rename anon_vma_unlock() => anon_vma_unlock_write()Konstantin Khlebnikov
The comment in commit 4fc3f1d66b1e ("mm/rmap, migration: Make rmap_walk_anon() and try_to_unmap_anon() more scalable") says: | Rename anon_vma_[un]lock() => anon_vma_[un]lock_write(), | to make it clearer that it's an exclusive write-lock in | that case - suggested by Rik van Riel. But that commit renames only anon_vma_lock() Signed-off-by: Konstantin Khlebnikov <khlebnikov@openvz.org> Cc: Ingo Molnar <mingo@kernel.org> Reviewed-by: Rik van Riel <riel@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-12-11mm/rmap, migration: Make rmap_walk_anon() and try_to_unmap_anon() more scalableIngo Molnar
rmap_walk_anon() and try_to_unmap_anon() appears to be too careful about locking the anon vma: while it needs protection against anon vma list modifications, it does not need exclusive access to the list itself. Transforming this exclusive lock to a read-locked rwsem removes a global lock from the hot path of page-migration intense threaded workloads which can cause pathological performance like this: 96.43% process 0 [kernel.kallsyms] [k] perf_trace_sched_switch | --- perf_trace_sched_switch __schedule schedule schedule_preempt_disabled __mutex_lock_common.isra.6 __mutex_lock_slowpath mutex_lock | |--50.61%-- rmap_walk | move_to_new_page | migrate_pages | migrate_misplaced_page | __do_numa_page.isra.69 | handle_pte_fault | handle_mm_fault | __do_page_fault | do_page_fault | page_fault | __memset_sse2 | | | --100.00%-- worker_thread | | | --100.00%-- start_thread | --49.39%-- page_lock_anon_vma try_to_unmap_anon try_to_unmap migrate_pages migrate_misplaced_page __do_numa_page.isra.69 handle_pte_fault handle_mm_fault __do_page_fault do_page_fault page_fault __memset_sse2 | --100.00%-- worker_thread start_thread With this change applied the profile is now nicely flat and there's no anon-vma related scheduling/blocking. Rename anon_vma_[un]lock() => anon_vma_[un]lock_write(), to make it clearer that it's an exclusive write-lock in that case - suggested by Rik van Riel. Suggested-by: Linus Torvalds <torvalds@linux-foundation.org> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Paul Turner <pjt@google.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com> Cc: Christoph Lameter <cl@linux.com> Cc: Rik van Riel <riel@redhat.com> Cc: Mel Gorman <mgorman@suse.de> Cc: Andrea Arcangeli <aarcange@redhat.com> Cc: Johannes Weiner <hannes@cmpxchg.org> Cc: Hugh Dickins <hughd@google.com> Signed-off-by: Ingo Molnar <mingo@kernel.org> Signed-off-by: Mel Gorman <mgorman@suse.de>
2012-12-11mm/rmap: Convert the struct anon_vma::mutex to an rwsemIngo Molnar
Convert the struct anon_vma::mutex to an rwsem, which will help in solving a page-migration scalability problem. (Addressed in a separate patch.) The conversion is simple and straightforward: in every case where we mutex_lock()ed we'll now down_write(). Suggested-by: Linus Torvalds <torvalds@linux-foundation.org> Reviewed-by: Rik van Riel <riel@redhat.com> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Paul Turner <pjt@google.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com> Cc: Christoph Lameter <cl@linux.com> Cc: Mel Gorman <mgorman@suse.de> Cc: Andrea Arcangeli <aarcange@redhat.com> Cc: Johannes Weiner <hannes@cmpxchg.org> Cc: Hugh Dickins <hughd@google.com> Signed-off-by: Ingo Molnar <mingo@kernel.org> Signed-off-by: Mel Gorman <mgorman@suse.de>
2012-10-09mm: cma: discard clean pages during contiguous allocation instead of migrationMinchan Kim
Drop clean cache pages instead of migration during alloc_contig_range() to minimise allocation latency by reducing the amount of migration that is necessary. It's useful for CMA because latency of migration is more important than evicting the background process's working set. In addition, as pages are reclaimed then fewer free pages for migration targets are required so it avoids memory reclaiming to get free pages, which is a contributory factor to increased latency. I measured elapsed time of __alloc_contig_migrate_range() which migrates 10M in 40M movable zone in QEMU machine. Before - 146ms, After - 7ms [akpm@linux-foundation.org: fix nommu build] Signed-off-by: Mel Gorman <mgorman@suse.de> Signed-off-by: Minchan Kim <minchan@kernel.org> Reviewed-by: Mel Gorman <mgorman@suse.de> Cc: Marek Szyprowski <m.szyprowski@samsung.com> Acked-by: Michal Nazarewicz <mina86@mina86.com> Cc: Rik van Riel <riel@redhat.com> Tested-by: Kyungmin Park <kyungmin.park@samsung.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-10-09mm: add CONFIG_DEBUG_VM_RB build optionMichel Lespinasse
Add a CONFIG_DEBUG_VM_RB build option for the previously existing DEBUG_MM_RB code. Now that Andi Kleen modified it to avoid using recursive algorithms, we can expose it a bit more. Also extend this code to validate_mm() after stack expansion, and to check that the vma's start and last pgoffs have not changed since the nodes were inserted on the anon vma interval tree (as it is important that the nodes be reindexed after each such update). Signed-off-by: Michel Lespinasse <walken@google.com> Cc: Andrea Arcangeli <aarcange@redhat.com> Cc: Rik van Riel <riel@redhat.com> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Daniel Santos <daniel.santos@pobox.com> Cc: Hugh Dickins <hughd@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-10-09mm anon rmap: replace same_anon_vma linked list with an interval tree.Michel Lespinasse
When a large VMA (anon or private file mapping) is first touched, which will populate its anon_vma field, and then split into many regions through the use of mprotect(), the original anon_vma ends up linking all of the vmas on a linked list. This can cause rmap to become inefficient, as we have to walk potentially thousands of irrelevent vmas before finding the one a given anon page might fall into. By replacing the same_anon_vma linked list with an interval tree (where each avc's interval is determined by its vma's start and last pgoffs), we can make rmap efficient for this use case again. While the change is large, all of its pieces are fairly simple. Most places that were walking the same_anon_vma list were looking for a known pgoff, so they can just use the anon_vma_interval_tree_foreach() interval tree iterator instead. The exception here is ksm, where the page's index is not known. It would probably be possible to rework ksm so that the index would be known, but for now I have decided to keep things simple and just walk the entirety of the interval tree there. When updating vma's that already have an anon_vma assigned, we must take care to re-index the corresponding avc's on their interval tree. This is done through the use of anon_vma_interval_tree_pre_update_vma() and anon_vma_interval_tree_post_update_vma(), which remove the avc's from their interval tree before the update and re-insert them after the update. The anon_vma stays locked during the update, so there is no chance that rmap would miss the vmas that are being updated. Signed-off-by: Michel Lespinasse <walken@google.com> Cc: Andrea Arcangeli <aarcange@redhat.com> Cc: Rik van Riel <riel@redhat.com> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Daniel Santos <daniel.santos@pobox.com> Cc: Hugh Dickins <hughd@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-10-09mm anon rmap: remove anon_vma_moveto_tailMichel Lespinasse
mremap() had a clever optimization where move_ptes() did not take the anon_vma lock to avoid a race with anon rmap users such as page migration. Instead, the avc's were ordered in such a way that the origin vma was always visited by rmap before the destination. This ordering and the use of page table locks rmap usage safe. However, we want to replace the use of linked lists in anon rmap with an interval tree, and this will make it harder to impose such ordering as the interval tree will always be sorted by the avc->vma->vm_pgoff value. For now, let's replace the anon_vma_moveto_tail() ordering function with proper anon_vma locking in move_ptes(). Once we have the anon interval tree in place, we will re-introduce an optimization to avoid taking these locks in the most common cases. Signed-off-by: Michel Lespinasse <walken@google.com> Cc: Andrea Arcangeli <aarcange@redhat.com> Cc: Rik van Riel <riel@redhat.com> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Daniel Santos <daniel.santos@pobox.com> Cc: Hugh Dickins <hughd@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-05-29mm: move is_vma_temporary_stack() declaration to huge_mm.hAlex Shi
When transparent_hugepage_enabled() is used outside mm/, such as in arch/x86/xx/tlb.c: + if (!cpu_has_invlpg || vma->vm_flags & VM_HUGETLB + || transparent_hugepage_enabled(vma)) { + flush_tlb_mm(vma->vm_mm); is_vma_temporary_stack() isn't referenced in huge_mm.h, so it has compile errors: arch/x86/mm/tlb.c: In function `flush_tlb_range': arch/x86/mm/tlb.c:324:4: error: implicit declaration of function `is_vma_temporary_stack' [-Werror=implicit-function-declaration] Since is_vma_temporay_stack() is just used in rmap.c and huge_memory.c, it is better to move it to huge_mm.h from rmap.h to avoid such errors. Signed-off-by: Alex Shi <alex.shi@intel.com> Cc: Andrea Arcangeli <aarcange@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-03-21rmap: remove __anon_vma_link() declarationXiao Guangrong
This declaration is not used anymore, remove it. Signed-off-by: Xiao Guangrong <xiaoguangrong@linux.vnet.ibm.com> Acked-by: David Rientjes <rientjes@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-01-12mm: unify remaining mem_cont, mem, etc. variable names to memcgJohannes Weiner
Signed-off-by: Johannes Weiner <jweiner@redhat.com> Acked-by: David Rientjes <rientjes@google.com> Acked-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Acked-by: Michal Hocko <mhocko@suse.cz> Cc: Balbir Singh <bsingharora@gmail.com> Cc: Hugh Dickins <hughd@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-01-10mremap: enforce rmap src/dst vma ordering in case of vma_merge() succeeding ↵Andrea Arcangeli
in copy_vma() migrate was doing an rmap_walk with speculative lock-less access on pagetables. That could lead it to not serializing properly against mremap PT locks. But a second problem remains in the order of vmas in the same_anon_vma list used by the rmap_walk. If vma_merge succeeds in copy_vma, the src vma could be placed after the dst vma in the same_anon_vma list. That could still lead to migrate missing some pte. This patch adds an anon_vma_moveto_tail() function to force the dst vma at the end of the list before mremap starts to solve the problem. If the mremap is very large and there are a lots of parents or childs sharing the anon_vma root lock, this should still scale better than taking the anon_vma root lock around every pte copy practically for the whole duration of mremap. Update: Hugh noticed special care is needed in the error path where move_page_tables goes in the reverse direction, a second anon_vma_moveto_tail() call is needed in the error path. This program exercises the anon_vma_moveto_tail: === int main() { static struct timeval oldstamp, newstamp; long diffsec; char *p, *p2, *p3, *p4; if (posix_memalign((void **)&p, 2*1024*1024, SIZE)) perror("memalign"), exit(1); if (posix_memalign((void **)&p2, 2*1024*1024, SIZE)) perror("memalign"), exit(1); if (posix_memalign((void **)&p3, 2*1024*1024, SIZE)) perror("memalign"), exit(1); memset(p, 0xff, SIZE); printf("%p\n", p); memset(p2, 0xff, SIZE); memset(p3, 0x77, 4096); if (memcmp(p, p2, SIZE)) printf("error\n"); p4 = mremap(p+SIZE/2, SIZE/2, SIZE/2, MREMAP_FIXED|MREMAP_MAYMOVE, p3); if (p4 != p3) perror("mremap"), exit(1); p4 = mremap(p4, SIZE/2, SIZE/2, MREMAP_FIXED|MREMAP_MAYMOVE, p+SIZE/2); if (p4 != p+SIZE/2) perror("mremap"), exit(1); if (memcmp(p, p2, SIZE)) printf("error\n"); printf("ok\n"); return 0; } === $ perf probe -a anon_vma_moveto_tail Add new event: probe:anon_vma_moveto_tail (on anon_vma_moveto_tail) You can now use it on all perf tools, such as: perf record -e probe:anon_vma_moveto_tail -aR sleep 1 $ perf record -e probe:anon_vma_moveto_tail -aR ./anon_vma_moveto_tail 0x7f2ca2800000 ok [ perf record: Woken up 1 times to write data ] [ perf record: Captured and wrote 0.043 MB perf.data (~1860 samples) ] $ perf report --stdio 100.00% anon_vma_moveto [kernel.kallsyms] [k] anon_vma_moveto_tail Signed-off-by: Andrea Arcangeli <aarcange@redhat.com> Reported-by: Nai Xia <nai.xia@gmail.com> Acked-by: Mel Gorman <mgorman@suse.de> Cc: Hugh Dickins <hughd@google.com> Cc: Pawel Sikora <pluto@agmk.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-05-25mm: convert anon_vma->lock to a mutexPeter Zijlstra
Straightforward conversion of anon_vma->lock to a mutex. Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Acked-by: Hugh Dickins <hughd@google.com> Reviewed-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: David Miller <davem@davemloft.net> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Russell King <rmk@arm.linux.org.uk> Cc: Paul Mundt <lethal@linux-sh.org> Cc: Jeff Dike <jdike@addtoit.com> Cc: Richard Weinberger <richard@nod.at> Cc: Tony Luck <tony.luck@intel.com> Cc: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Mel Gorman <mel@csn.ul.ie> Cc: Nick Piggin <npiggin@kernel.dk> Cc: Namhyung Kim <namhyung@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-05-25mm: revert page_lock_anon_vma() lock annotationPeter Zijlstra
Its beyond ugly and gets in the way. Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Acked-by: Hugh Dickins <hughd@google.com> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: David Miller <davem@davemloft.net> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Russell King <rmk@arm.linux.org.uk> Cc: Paul Mundt <lethal@linux-sh.org> Cc: Jeff Dike <jdike@addtoit.com> Cc: Richard Weinberger <richard@nod.at> Cc: Tony Luck <tony.luck@intel.com> Cc: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Mel Gorman <mel@csn.ul.ie> Cc: Namhyung Kim <namhyung@gmail.com> Cc: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Cc: Nick Piggin <npiggin@kernel.dk> Cc: Namhyung Kim <namhyung@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-03-22mm: simplify anon_vma refcountsPeter Zijlstra
This patch changes the anon_vma refcount to be 0 when the object is free. It does this by adding 1 ref to being in use in the anon_vma structure (iow. the anon_vma->head list is not empty). This allows a simpler release scheme without having to check both the refcount and the list as well as avoids taking a ref for each entry on the list. Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Reviewed-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Acked-by: Hugh Dickins <hughd@google.com> Acked-by: Mel Gorman <mel@csn.ul.ie> Acked-by: Rik van Riel <riel@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-03-22mm: move anon_vma ref out from under CONFIG_fooPeter Zijlstra
We need the anon_vma refcount unconditionally to simplify the anon_vma lifetime rules. Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Acked-by: Mel Gorman <mel@csn.ul.ie> Reviewed-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Acked-by: Hugh Dickins <hughd@google.com> Acked-by: Rik van Riel <riel@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-03-22mm: rename drop_anon_vma() to put_anon_vma()Peter Zijlstra
The normal code pattern used in the kernel is: get/put. Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Reviewed-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Acked-by: Hugh Dickins <hughd@google.com> Reviewed-by: Rik van Riel <riel@redhat.com> Acked-by: Mel Gorman <mel@csn.ul.ie> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-01-13thp: transparent hugepage coreAndrea Arcangeli
Lately I've been working to make KVM use hugepages transparently without the usual restrictions of hugetlbfs. Some of the restrictions I'd like to see removed: 1) hugepages have to be swappable or the guest physical memory remains locked in RAM and can't be paged out to swap 2) if a hugepage allocation fails, regular pages should be allocated instead and mixed in the same vma without any failure and without userland noticing 3) if some task quits and more hugepages become available in the buddy, guest physical memory backed by regular pages should be relocated on hugepages automatically in regions under madvise(MADV_HUGEPAGE) (ideally event driven by waking up the kernel deamon if the order=HPAGE_PMD_SHIFT-PAGE_SHIFT list becomes not null) 4) avoidance of reservation and maximization of use of hugepages whenever possible. Reservation (needed to avoid runtime fatal faliures) may be ok for 1 machine with 1 database with 1 database cache with 1 database cache size known at boot time. It's definitely not feasible with a virtualization hypervisor usage like RHEV-H that runs an unknown number of virtual machines with an unknown size of each virtual machine with an unknown amount of pagecache that could be potentially useful in the host for guest not using O_DIRECT (aka cache=off). hugepages in the virtualization hypervisor (and also in the guest!) are much more important than in a regular host not using virtualization, becasue with NPT/EPT they decrease the tlb-miss cacheline accesses from 24 to 19 in case only the hypervisor uses transparent hugepages, and they decrease the tlb-miss cacheline accesses from 19 to 15 in case both the linux hypervisor and the linux guest both uses this patch (though the guest will limit the addition speedup to anonymous regions only for now...). Even more important is that the tlb miss handler is much slower on a NPT/EPT guest than for a regular shadow paging or no-virtualization scenario. So maximizing the amount of virtual memory cached by the TLB pays off significantly more with NPT/EPT than without (even if there would be no significant speedup in the tlb-miss runtime). The first (and more tedious) part of this work requires allowing the VM to handle anonymous hugepages mixed with regular pages transparently on regular anonymous vmas. This is what this patch tries to achieve in the least intrusive possible way. We want hugepages and hugetlb to be used in a way so that all applications can benefit without changes (as usual we leverage the KVM virtualization design: by improving the Linux VM at large, KVM gets the performance boost too). The most important design choice is: always fallback to 4k allocation if the hugepage allocation fails! This is the _very_ opposite of some large pagecache patches that failed with -EIO back then if a 64k (or similar) allocation failed... Second important decision (to reduce the impact of the feature on the existing pagetable handling code) is that at any time we can split an hugepage into 512 regular pages and it has to be done with an operation that can't fail. This way the reliability of the swapping isn't decreased (no need to allocate memory when we are short on memory to swap) and it's trivial to plug a split_huge_page* one-liner where needed without polluting the VM. Over time we can teach mprotect, mremap and friends to handle pmd_trans_huge natively without calling split_huge_page*. The fact it can't fail isn't just for swap: if split_huge_page would return -ENOMEM (instead of the current void) we'd need to rollback the mprotect from the middle of it (ideally including undoing the split_vma) which would be a big change and in the very wrong direction (it'd likely be simpler not to call split_huge_page at all and to teach mprotect and friends to handle hugepages instead of rolling them back from the middle). In short the very value of split_huge_page is that it can't fail. The collapsing and madvise(MADV_HUGEPAGE) part will remain separated and incremental and it'll just be an "harmless" addition later if this initial part is agreed upon. It also should be noted that locking-wise replacing regular pages with hugepages is going to be very easy if compared to what I'm doing below in split_huge_page, as it will only happen when page_count(page) matches page_mapcount(page) if we can take the PG_lock and mmap_sem in write mode. collapse_huge_page will be a "best effort" that (unlike split_huge_page) can fail at the minimal sign of trouble and we can try again later. collapse_huge_page will be similar to how KSM works and the madvise(MADV_HUGEPAGE) will work similar to madvise(MADV_MERGEABLE). The default I like is that transparent hugepages are used at page fault time. This can be changed with /sys/kernel/mm/transparent_hugepage/enabled. The control knob can be set to three values "always", "madvise", "never" which mean respectively that hugepages are always used, or only inside madvise(MADV_HUGEPAGE) regions, or never used. /sys/kernel/mm/transparent_hugepage/defrag instead controls if the hugepage allocation should defrag memory aggressively "always", only inside "madvise" regions, or "never". The pmd_trans_splitting/pmd_trans_huge locking is very solid. The put_page (from get_user_page users that can't use mmu notifier like O_DIRECT) that runs against a __split_huge_page_refcount instead was a pain to serialize in a way that would result always in a coherent page count for both tail and head. I think my locking solution with a compound_lock taken only after the page_first is valid and is still a PageHead should be safe but it surely needs review from SMP race point of view. In short there is no current existing way to serialize the O_DIRECT final put_page against split_huge_page_refcount so I had to invent a new one (O_DIRECT loses knowledge on the mapping status by the time gup_fast returns so...). And I didn't want to impact all gup/gup_fast users for now, maybe if we change the gup interface substantially we can avoid this locking, I admit I didn't think too much about it because changing the gup unpinning interface would be invasive. If we ignored O_DIRECT we could stick to the existing compound refcounting code, by simply adding a get_user_pages_fast_flags(foll_flags) where KVM (and any other mmu notifier user) would call it without FOLL_GET (and if FOLL_GET isn't set we'd just BUG_ON if nobody registered itself in the current task mmu notifier list yet). But O_DIRECT is fundamental for decent performance of virtualized I/O on fast storage so we can't avoid it to solve the race of put_page against split_huge_page_refcount to achieve a complete hugepage feature for KVM. Swap and oom works fine (well just like with regular pages ;). MMU notifier is handled transparently too, with the exception of the young bit on the pmd, that didn't have a range check but I think KVM will be fine because the whole point of hugepages is that EPT/NPT will also use a huge pmd when they notice gup returns pages with PageCompound set, so they won't care of a range and there's just the pmd young bit to check in that case. NOTE: in some cases if the L2 cache is small, this may slowdown and waste memory during COWs because 4M of memory are accessed in a single fault instead of 8k (the payoff is that after COW the program can run faster). So we might want to switch the copy_huge_page (and clear_huge_page too) to not temporal stores. I also extensively researched ways to avoid this cache trashing with a full prefault logic that would cow in 8k/16k/32k/64k up to 1M (I can send those patches that fully implemented prefault) but I concluded they're not worth it and they add an huge additional complexity and they remove all tlb benefits until the full hugepage has been faulted in, to save a little bit of memory and some cache during app startup, but they still don't improve substantially the cache-trashing during startup if the prefault happens in >4k chunks. One reason is that those 4k pte entries copied are still mapped on a perfectly cache-colored hugepage, so the trashing is the worst one can generate in those copies (cow of 4k page copies aren't so well colored so they trashes less, but again this results in software running faster after the page fault). Those prefault patches allowed things like a pte where post-cow pages were local 4k regular anon pages and the not-yet-cowed pte entries were pointing in the middle of some hugepage mapped read-only. If it doesn't payoff substantially with todays hardware it will payoff even less in the future with larger l2 caches, and the prefault logic would blot the VM a lot. If one is emebdded transparent_hugepage can be disabled during boot with sysfs or with the boot commandline parameter transparent_hugepage=0 (or transparent_hugepage=2 to restrict hugepages inside madvise regions) that will ensure not a single hugepage is allocated at boot time. It is simple enough to just disable transparent hugepage globally and let transparent hugepages be allocated selectively by applications in the MADV_HUGEPAGE region (both at page fault time, and if enabled with the collapse_huge_page too through the kernel daemon). This patch supports only hugepages mapped in the pmd, archs that have smaller hugepages will not fit in this patch alone. Also some archs like power have certain tlb limits that prevents mixing different page size in the same regions so they will not fit in this framework that requires "graceful fallback" to basic PAGE_SIZE in case of physical memory fragmentation. hugetlbfs remains a perfect fit for those because its software limits happen to match the hardware limits. hugetlbfs also remains a perfect fit for hugepage sizes like 1GByte that cannot be hoped to be found not fragmented after a certain system uptime and that would be very expensive to defragment with relocation, so requiring reservation. hugetlbfs is the "reservation way", the point of transparent hugepages is not to have any reservation at all and maximizing the use of cache and hugepages at all times automatically. Some performance result: vmx andrea # LD_PRELOAD=/usr/lib64/libhugetlbfs.so HUGETLB_MORECORE=yes HUGETLB_PATH=/mnt/huge/ ./largep ages3 memset page fault 1566023 memset tlb miss 453854 memset second tlb miss 453321 random access tlb miss 41635 random access second tlb miss 41658 vmx andrea # LD_PRELOAD=/usr/lib64/libhugetlbfs.so HUGETLB_MORECORE=yes HUGETLB_PATH=/mnt/huge/ ./largepages3 memset page fault 1566471 memset tlb miss 453375 memset second tlb miss 453320 random access tlb miss 41636 random access second tlb miss 41637 vmx andrea # ./largepages3 memset page fault 1566642 memset tlb miss 453417 memset second tlb miss 453313 random access tlb miss 41630 random access second tlb miss 41647 vmx andrea # ./largepages3 memset page fault 1566872 memset tlb miss 453418 memset second tlb miss 453315 random access tlb miss 41618 random access second tlb miss 41659 vmx andrea # echo 0 > /proc/sys/vm/transparent_hugepage vmx andrea # ./largepages3 memset page fault 2182476 memset tlb miss 460305 memset second tlb miss 460179 random access tlb miss 44483 random access second tlb miss 44186 vmx andrea # ./largepages3 memset page fault 2182791 memset tlb miss 460742 memset second tlb miss 459962 random access tlb miss 43981 random access second tlb miss 43988 ============ #include <stdio.h> #include <stdlib.h> #include <string.h> #include <sys/time.h> #define SIZE (3UL*1024*1024*1024) int main() { char *p = malloc(SIZE), *p2; struct timeval before, after; gettimeofday(&before, NULL); memset(p, 0, SIZE); gettimeofday(&after, NULL); printf("memset page fault %Lu\n", (after.tv_sec-before.tv_sec)*1000000UL + after.tv_usec-before.tv_usec); gettimeofday(&before, NULL); memset(p, 0, SIZE); gettimeofday(&after, NULL); printf("memset tlb miss %Lu\n", (after.tv_sec-before.tv_sec)*1000000UL + after.tv_usec-before.tv_usec); gettimeofday(&before, NULL); memset(p, 0, SIZE); gettimeofday(&after, NULL); printf("memset second tlb miss %Lu\n", (after.tv_sec-before.tv_sec)*1000000UL + after.tv_usec-before.tv_usec); gettimeofday(&before, NULL); for (p2 = p; p2 < p+SIZE; p2 += 4096) *p2 = 0; gettimeofday(&after, NULL); printf("random access tlb miss %Lu\n", (after.tv_sec-before.tv_sec)*1000000UL + after.tv_usec-before.tv_usec); gettimeofday(&before, NULL); for (p2 = p; p2 < p+SIZE; p2 += 4096) *p2 = 0; gettimeofday(&after, NULL); printf("random access second tlb miss %Lu\n", (after.tv_sec-before.tv_sec)*1000000UL + after.tv_usec-before.tv_usec); return 0; } ============ Signed-off-by: Andrea Arcangeli <aarcange@redhat.com> Acked-by: Rik van Riel <riel@redhat.com> Signed-off-by: Johannes Weiner <hannes@cmpxchg.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-10-26rmap: wrap page_check_address() using __cond_lock()Namhyung Kim
The page_check_address() conditionally grabs *@ptlp in case of returning non-NULL. Rename and wrap it using __cond_lock() removes following warnings from sparse: mm/rmap.c:472:9: warning: context imbalance in 'page_mapped_in_vma' - unexpected unlock mm/rmap.c:524:9: warning: context imbalance in 'page_referenced_one' - unexpected unlock mm/rmap.c:706:9: warning: context imbalance in 'page_mkclean_one' - unexpected unlock mm/rmap.c:1066:9: warning: context imbalance in 'try_to_unmap_one' - unexpected unlock Signed-off-by: Namhyung Kim <namhyung@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-10-26rmap: annotate lock context change on page_[un]lock_anon_vma()Namhyung Kim
The page_lock_anon_vma() conditionally grabs RCU and anon_vma lock but page_unlock_anon_vma() releases them unconditionally. This leads sparse to complain about context imbalance. Annotate them. Signed-off-by: Namhyung Kim <namhyung@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-10-26mm: remove alignment padding from anon_vma on (some) 64 bit buildsRichard Kennedy
Reorder structure anon_vma to remove alignment padding on 64 builds when (CONFIG_KSM || CONFIG_MIGRATION). This will shrink the size of the anon_vma structure from 40 to 32 bytes & allow more objects per slab in its kmem_cache. Under slub the objects in the anon_vma kmem_cache will then be 40 bytes with 102 objects per slab. (On v2.6.36 without this patch,the size is 48 bytes and 85 objects/slab.) Signed-off-by: Richard Kennedy <richard@rsk.demon.co.uk> Reviewed-by: Rik van Riel <riel@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-08-12Merge branch 'hwpoison' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/ak/linux-mce-2.6 * 'hwpoison' of git://git.kernel.org/pub/scm/linux/kernel/git/ak/linux-mce-2.6: hugetlb: add missing unlock in avoidcopy path in hugetlb_cow() hwpoison: rename CONFIG HWPOISON, hugetlb: support hwpoison injection for hugepage HWPOISON, hugetlb: detect hwpoison in hugetlb code HWPOISON, hugetlb: isolate corrupted hugepage HWPOISON, hugetlb: maintain mce_bad_pages in handling hugepage error HWPOISON, hugetlb: set/clear PG_hwpoison bits on hugepage HWPOISON, hugetlb: enable error handling path for hugepage hugetlb, rmap: add reverse mapping for hugepage hugetlb: move definition of is_vm_hugetlb_page() to hugepage_inline.h Fix up trivial conflicts in mm/memory-failure.c
2010-08-11hugetlb, rmap: add reverse mapping for hugepageNaoya Horiguchi
This patch adds reverse mapping feature for hugepage by introducing mapcount for shared/private-mapped hugepage and anon_vma for private-mapped hugepage. While hugepage is not currently swappable, reverse mapping can be useful for memory error handler. Without this patch, memory error handler cannot identify processes using the bad hugepage nor unmap it from them. That is: - for shared hugepage: we can collect processes using a hugepage through pagecache, but can not unmap the hugepage because of the lack of mapcount. - for privately mapped hugepage: we can neither collect processes nor unmap the hugepage. This patch solves these problems. This patch include the bug fix given by commit 23be7468e8, so reverts it. Dependency: "hugetlb: move definition of is_vm_hugetlb_page() to hugepage_inline.h" ChangeLog since May 24. - create hugetlb_inline.h and move is_vm_hugetlb_index() in it. - move functions setting up anon_vma for hugepage into mm/rmap.c. ChangeLog since May 13. - rebased to 2.6.34 - fix logic error (in case that private mapping and shared mapping coexist) - move is_vm_hugetlb_page() into include/linux/mm.h to use this function from linear_page_index() - define and use linear_hugepage_index() instead of compound_order() - use page_move_anon_rmap() in hugetlb_cow() - copy exclusive switch of __set_page_anon_rmap() into hugepage counterpart. - revert commit 24be7468 completely Signed-off-by: Naoya Horiguchi <n-horiguchi@ah.jp.nec.com> Cc: Andi Kleen <andi@firstfloor.org> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Mel Gorman <mel@csn.ul.ie> Cc: Andrea Arcangeli <aarcange@redhat.com> Cc: Larry Woodman <lwoodman@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com> Acked-by: Fengguang Wu <fengguang.wu@intel.com> Acked-by: Mel Gorman <mel@csn.ul.ie> Signed-off-by: Andi Kleen <ak@linux.intel.com>
2010-08-09rmap: add exclusive page to private anon_vma on swapinRik van Riel
On swapin it is fairly common for a page to be owned exclusively by one process. In that case we want to add the page to the anon_vma of that process's VMA, instead of to the root anon_vma. This will reduce the amount of rmap searching that the swapout code needs to do. Signed-off-by: Rik van Riel <riel@redhat.com> Cc: Andrea Arcangeli <aarcange@redhat.com> Cc: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-08-09mm: extend KSM refcounts to the anon_vma rootRik van Riel
KSM reference counts can cause an anon_vma to exist after the processe it belongs to have already exited. Because the anon_vma lock now lives in the root anon_vma, we need to ensure that the root anon_vma stays around until after all the "child" anon_vmas have been freed. The obvious way to do this is to have a "child" anon_vma take a reference to the root in anon_vma_fork. When the anon_vma is freed at munmap or process exit, we drop the refcount in anon_vma_unlink and possibly free the root anon_vma. The KSM anon_vma reference count function also needs to be modified to deal with the possibility of freeing 2 levels of anon_vma. The easiest way to do this is to break out the KSM magic and make it generic. When compiling without CONFIG_KSM, this code is compiled out. Signed-off-by: Rik van Riel <riel@redhat.com> Tested-by: Larry Woodman <lwoodman@redhat.com> Acked-by: Larry Woodman <lwoodman@redhat.com> Reviewed-by: Minchan Kim <minchan.kim@gmail.com> Cc: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Acked-by: Mel Gorman <mel@csn.ul.ie> Acked-by: Linus Torvalds <torvalds@linux-foundation.org> Tested-by: Dave Young <hidave.darkstar@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-08-09mm: always lock the root (oldest) anon_vmaRik van Riel
Always (and only) lock the root (oldest) anon_vma whenever we do something in an anon_vma. The recently introduced anon_vma scalability is due to the rmap code scanning only the VMAs that need to be scanned. Many common operations still took the anon_vma lock on the root anon_vma, so always taking that lock is not expected to introduce any scalability issues. However, always taking the same lock does mean we only need to take one lock, which means rmap_walk on pages from any anon_vma in the vma is excluded from occurring during an munmap, expand_stack or other operation that needs to exclude rmap_walk and similar functions. Also add the proper locking to vma_adjust. Signed-off-by: Rik van Riel <riel@redhat.com> Tested-by: Larry Woodman <lwoodman@redhat.com> Acked-by: Larry Woodman <lwoodman@redhat.com> Reviewed-by: Minchan Kim <minchan.kim@gmail.com> Reviewed-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Acked-by: Mel Gorman <mel@csn.ul.ie> Acked-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-08-09mm: track the root (oldest) anon_vmaRik van Riel
Track the root (oldest) anon_vma in each anon_vma tree. Because we only take the lock on the root anon_vma, we cannot use the lock on higher-up anon_vmas to lock anything. This makes it impossible to do an indirect lookup of the root anon_vma, since the data structures could go away from under us. However, a direct pointer is safe because the root anon_vma is always the last one that gets freed on munmap or exit, by virtue of the same_vma list order and unlink_anon_vmas walking the list forward. [akpm@linux-foundation.org: fix typo] Signed-off-by: Rik van Riel <riel@redhat.com> Acked-by: Mel Gorman <mel@csn.ul.ie> Acked-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Tested-by: Larry Woodman <lwoodman@redhat.com> Acked-by: Larry Woodman <lwoodman@redhat.com> Reviewed-by: Minchan Kim <minchan.kim@gmail.com> Acked-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-08-09mm: change direct call of spin_lock(anon_vma->lock) to inline functionRik van Riel
Subsitute a direct call of spin_lock(anon_vma->lock) with an inline function doing exactly the same. This makes it easier to do the substitution to the root anon_vma lock in a following patch. We will deal with the handful of special locks (nested, dec_and_lock, etc) separately. Signed-off-by: Rik van Riel <riel@redhat.com> Acked-by: Mel Gorman <mel@csn.ul.ie> Acked-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Tested-by: Larry Woodman <lwoodman@redhat.com> Acked-by: Larry Woodman <lwoodman@redhat.com> Reviewed-by: Minchan Kim <minchan.kim@gmail.com> Acked-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-08-09mm: rename anon_vma_lock to vma_lock_anon_vmaRik van Riel
Rename anon_vma_lock to vma_lock_anon_vma. This matches the naming style used in page_lock_anon_vma and will come in really handy further down in this patch series. Signed-off-by: Rik van Riel <riel@redhat.com> Acked-by: Mel Gorman <mel@csn.ul.ie> Acked-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Tested-by: Larry Woodman <lwoodman@redhat.com> Acked-by: Larry Woodman <lwoodman@redhat.com> Reviewed-by: Minchan Kim <minchan.kim@gmail.com> Acked-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-05-25mm: migration: share the anon_vma ref counts between KSM and page migrationMel Gorman
For clarity of review, KSM and page migration have separate refcounts on the anon_vma. While clear, this is a waste of memory. This patch gets KSM and page migration to share their toys in a spirit of harmony. Signed-off-by: Mel Gorman <mel@csn.ul.ie> Reviewed-by: Minchan Kim <minchan.kim@gmail.com> Reviewed-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Reviewed-by: Christoph Lameter <cl@linux-foundation.org> Reviewed-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Rik van Riel <riel@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-05-25mm: migration: take a reference to the anon_vma before migratingMel Gorman
This patchset is a memory compaction mechanism that reduces external fragmentation memory by moving GFP_MOVABLE pages to a fewer number of pageblocks. The term "compaction" was chosen as there are is a number of mechanisms that are not mutually exclusive that can be used to defragment memory. For example, lumpy reclaim is a form of defragmentation as was slub "defragmentation" (really a form of targeted reclaim). Hence, this is called "compaction" to distinguish it from other forms of defragmentation. In this implementation, a full compaction run involves two scanners operating within a zone - a migration and a free scanner. The migration scanner starts at the beginning of a zone and finds all movable pages within one pageblock_nr_pages-sized area and isolates them on a migratepages list. The free scanner begins at the end of the zone and searches on a per-area basis for enough free pages to migrate all the pages on the migratepages list. As each area is respectively migrated or exhausted of free pages, the scanners are advanced one area. A compaction run completes within a zone when the two scanners meet. This method is a bit primitive but is easy to understand and greater sophistication would require maintenance of counters on a per-pageblock basis. This would have a big impact on allocator fast-paths to improve compaction which is a poor trade-off. It also does not try relocate virtually contiguous pages to be physically contiguous. However, assuming transparent hugepages were in use, a hypothetical khugepaged might reuse compaction code to isolate free pages, split them and relocate userspace pages for promotion. Memory compaction can be triggered in one of three ways. It may be triggered explicitly by writing any value to /proc/sys/vm/compact_memory and compacting all of memory. It can be triggered on a per-node basis by writing any value to /sys/devices/system/node/nodeN/compact where N is the node ID to be compacted. When a process fails to allocate a high-order page, it may compact memory in an attempt to satisfy the allocation instead of entering direct reclaim. Explicit compaction does not finish until the two scanners meet and direct compaction ends if a suitable page becomes available that would meet watermarks. The series is in 14 patches. The first three are not "core" to the series but are important pre-requisites. Patch 1 reference counts anon_vma for rmap_walk_anon(). Without this patch, it's possible to use anon_vma after free if the caller is not holding a VMA or mmap_sem for the pages in question. While there should be no existing user that causes this problem, it's a requirement for memory compaction to be stable. The patch is at the start of the series for bisection reasons. Patch 2 merges the KSM and migrate counts. It could be merged with patch 1 but would be slightly harder to review. Patch 3 skips over unmapped anon pages during migration as there are no guarantees about the anon_vma existing. There is a window between when a page was isolated and migration started during which anon_vma could disappear. Patch 4 notes that PageSwapCache pages can still be migrated even if they are unmapped. Patch 5 allows CONFIG_MIGRATION to be set without CONFIG_NUMA Patch 6 exports a "unusable free space index" via debugfs. It's a measure of external fragmentation that takes the size of the allocation request into account. It can also be calculated from userspace so can be dropped if requested Patch 7 exports a "fragmentation index" which only has meaning when an allocation request fails. It determines if an allocation failure would be due to a lack of memory or external fragmentation. Patch 8 moves the definition for LRU isolation modes for use by compaction Patch 9 is the compaction mechanism although it's unreachable at this point Patch 10 adds a means of compacting all of memory with a proc trgger Patch 11 adds a means of compacting a specific node with a sysfs trigger Patch 12 adds "direct compaction" before "direct reclaim" if it is determined there is a good chance of success. Patch 13 adds a sysctl that allows tuning of the threshold at which the kernel will compact or direct reclaim Patch 14 temporarily disables compaction if an allocation failure occurs after compaction. Testing of compaction was in three stages. For the test, debugging, preempt, the sleep watchdog and lockdep were all enabled but nothing nasty popped out. min_free_kbytes was tuned as recommended by hugeadm to help fragmentation avoidance and high-order allocations. It was tested on X86, X86-64 and PPC64. Ths first test represents one of the easiest cases that can be faced for lumpy reclaim or memory compaction. 1. Machine freshly booted and configured for hugepage usage with a) hugeadm --create-global-mounts b) hugeadm --pool-pages-max DEFAULT:8G c) hugeadm --set-recommended-min_free_kbytes d) hugeadm --set-recommended-shmmax The min_free_kbytes here is important. Anti-fragmentation works best when pageblocks don't mix. hugeadm knows how to calculate a value that will significantly reduce the worst of external-fragmentation-related events as reported by the mm_page_alloc_extfrag tracepoint. 2. Load up memory a) Start updatedb b) Create in parallel a X files of pagesize*128 in size. Wait until files are created. By parallel, I mean that 4096 instances of dd were launched, one after the other using &. The crude objective being to mix filesystem metadata allocations with the buffer cache. c) Delete every second file so that pageblocks are likely to have holes d) kill updatedb if it's still running At this point, the system is quiet, memory is full but it's full with clean filesystem metadata and clean buffer cache that is unmapped. This is readily migrated or discarded so you'd expect lumpy reclaim to have no significant advantage over compaction but this is at the POC stage. 3. In increments, attempt to allocate 5% of memory as hugepages. Measure how long it took, how successful it was, how many direct reclaims took place and how how many compactions. Note the compaction figures might not fully add up as compactions can take place for orders other than the hugepage size X86 vanilla compaction Final page count 913 916 (attempted 1002) pages reclaimed 68296 9791 X86-64 vanilla compaction Final page count: 901 902 (attempted 1002) Total pages reclaimed: 112599 53234 PPC64 vanilla compaction Final page count: 93 94 (attempted 110) Total pages reclaimed: 103216 61838 There was not a dramatic improvement in success rates but it wouldn't be expected in this case either. What was important is that fewer pages were reclaimed in all cases reducing the amount of IO required to satisfy a huge page allocation. The second tests were all performance related - kernbench, netperf, iozone and sysbench. None showed anything too remarkable. The last test was a high-order allocation stress test. Many kernel compiles are started to fill memory with a pressured mix of unmovable and movable allocations. During this, an attempt is made to allocate 90% of memory as huge pages - one at a time with small delays between attempts to avoid flooding the IO queue. vanilla compaction Percentage of request allocated X86 98 99 Percentage of request allocated X86-64 95 98 Percentage of request allocated PPC64 55 70 This patch: rmap_walk_anon() does not use page_lock_anon_vma() for looking up and locking an anon_vma and it does not appear to have sufficient locking to ensure the anon_vma does not disappear from under it. This patch copies an approach used by KSM to take a reference on the anon_vma while pages are being migrated. This should prevent rmap_walk() running into nasty surprises later because anon_vma has been freed. Signed-off-by: Mel Gorman <mel@csn.ul.ie> Acked-by: Rik van Riel <riel@redhat.com> Cc: Minchan Kim <minchan.kim@gmail.com> Cc: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Cc: Christoph Lameter <cl@linux-foundation.org> Cc: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-03-06vmscan: detect mapped file pages used only onceJohannes Weiner
The VM currently assumes that an inactive, mapped and referenced file page is in use and promotes it to the active list. However, every mapped file page starts out like this and thus a problem arises when workloads create a stream of such pages that are used only for a short time. By flooding the active list with those pages, the VM quickly gets into trouble finding eligible reclaim canditates. The result is long allocation latencies and eviction of the wrong pages. This patch reuses the PG_referenced page flag (used for unmapped file pages) to implement a usage detection that scales with the speed of LRU list cycling (i.e. memory pressure). If the scanner encounters those pages, the flag is set and the page cycled again on the inactive list. Only if it returns with another page table reference it is activated. Otherwise it is reclaimed as 'not recently used cache'. This effectively changes the minimum lifetime of a used-once mapped file page from a full memory cycle to an inactive list cycle, which allows it to occur in linear streams without affecting the stable working set of the system. Signed-off-by: Johannes Weiner <hannes@cmpxchg.org> Reviewed-by: Rik van Riel <riel@redhat.com> Cc: Minchan Kim <minchan.kim@gmail.com> Cc: OSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Cc: Lee Schermerhorn <lee.schermerhorn@hp.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-03-06rmap: move exclusively owned pages to own anon_vma in do_wp_page()Rik van Riel
When the parent process breaks the COW on a page, both the original which is mapped at child and the new page which is mapped parent end up in that same anon_vma. Generally this won't be a problem, but for some workloads it could preserve the O(N) rmap scanning complexity. A simple fix is to ensure that, when a page which is mapped child gets reused in do_wp_page, because we already are the exclusive owner, the page gets moved to our own exclusive child's anon_vma. Signed-off-by: Rik van Riel <riel@redhat.com> Cc: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Cc: Larry Woodman <lwoodman@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com> Reviewed-by: Minchan Kim <minchan.kim@gmail.com> Cc: Andrea Arcangeli <aarcange@redhat.com> Cc: Hugh Dickins <hugh.dickins@tiscali.co.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-03-06mm: change anon_vma linking to fix multi-process server scalability issueRik van Riel
The old anon_vma code can lead to scalability issues with heavily forking workloads. Specifically, each anon_vma will be shared between the parent process and all its child processes. In a workload with 1000 child processes and a VMA with 1000 anonymous pages per process that get COWed, this leads to a system with a million anonymous pages in the same anon_vma, each of which is mapped in just one of the 1000 processes. However, the current rmap code needs to walk them all, leading to O(N) scanning complexity for each page. This can result in systems where one CPU is walking the page tables of 1000 processes in page_referenced_one, while all other CPUs are stuck on the anon_vma lock. This leads to catastrophic failure for a benchmark like AIM7, where the total number of processes can reach in the tens of thousands. Real workloads are still a factor 10 less process intensive than AIM7, but they are catching up. This patch changes the way anon_vmas and VMAs are linked, which allows us to associate multiple anon_vmas with a VMA. At fork time, each child process gets its own anon_vmas, in which its COWed pages will be instantiated. The parents' anon_vma is also linked to the VMA, because non-COWed pages could be present in any of the children. This reduces rmap scanning complexity to O(1) for the pages of the 1000 child processes, with O(N) complexity for at most 1/N pages in the system. This reduces the average scanning cost in heavily forking workloads from O(N) to 2. The only real complexity in this patch stems from the fact that linking a VMA to anon_vmas now involves memory allocations. This means vma_adjust can fail, if it needs to attach a VMA to anon_vma structures. This in turn means error handling needs to be added to the calling functions. A second source of complexity is that, because there can be multiple anon_vmas, the anon_vma linking in vma_adjust can no longer be done under "the" anon_vma lock. To prevent the rmap code from walking up an incomplete VMA, this patch introduces the VM_LOCK_RMAP VMA flag. This bit flag uses the same slot as the NOMMU VM_MAPPED_COPY, with an ifdef in mm.h to make sure it is impossible to compile a kernel that needs both symbolic values for the same bitflag. Some test results: Without the anon_vma changes, when AIM7 hits around 9.7k users (on a test box with 16GB RAM and not quite enough IO), the system ends up running >99% in system time, with every CPU on the same anon_vma lock in the pageout code. With these changes, AIM7 hits the cross-over point around 29.7k users. This happens with ~99% IO wait time, there never seems to be any spike in system time. The anon_vma lock contention appears to be resolved. [akpm@linux-foundation.org: cleanups] Signed-off-by: Rik van Riel <riel@redhat.com> Cc: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Cc: Larry Woodman <lwoodman@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com> Cc: Minchan Kim <minchan.kim@gmail.com> Cc: Andrea Arcangeli <aarcange@redhat.com> Cc: Hugh Dickins <hugh.dickins@tiscali.co.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-12-15ksm: rmap_walk to remove_migation_ptesHugh Dickins
A side-effect of making ksm pages swappable is that they have to be placed on the LRUs: which then exposes them to isolate_lru_page() and hence to page migration. Add rmap_walk() for remove_migration_ptes() to use: rmap_walk_anon() and rmap_walk_file() in rmap.c, but rmap_walk_ksm() in ksm.c. Perhaps some consolidation with existing code is possible, but don't attempt that yet (try_to_unmap needs to handle nonlinears, but migration pte removal does not). rmap_walk() is sadly less general than it appears: rmap_walk_anon(), like remove_anon_migration_ptes() which it replaces, avoids calling page_lock_anon_vma(), because that includes a page_mapped() test which fails when all migration ptes are in place. That was valid when NUMA page migration was introduced (holding mmap_sem provided the missing guarantee that anon_vma's slab had not already been destroyed), but I believe not valid in the memory hotremove case added since. For now do the same as before, and consider the best way to fix that unlikely race later on. When fixed, we can probably use rmap_walk() on hwpoisoned ksm pages too: for now, they remain among hwpoison's various exceptions (its PageKsm test comes before the page is locked, but its page_lock_anon_vma fails safely if an anon gets upgraded). Signed-off-by: Hugh Dickins <hugh.dickins@tiscali.co.uk> Cc: Izik Eidus <ieidus@redhat.com> Cc: Andrea Arcangeli <aarcange@redhat.com> Cc: Chris Wright <chrisw@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-12-15ksm: hold anon_vma in rmap_itemHugh Dickins
For full functionality, page_referenced_one() and try_to_unmap_one() need to know the vma: to pass vma down to arch-dependent flushes, or to observe VM_LOCKED or VM_EXEC. But KSM keeps no record of vma: nor can it, since vmas get split and merged without its knowledge. Instead, note page's anon_vma in its rmap_item when adding to stable tree: all the vmas which might map that page are listed by its anon_vma. page_referenced_ksm() and try_to_unmap_ksm() then traverse the anon_vma, first to find the probable vma, that which matches rmap_item's mm; but if that is not enough to locate all instances, traverse again to try the others. This catches those occasions when fork has duplicated a pte of a ksm page, but ksmd has not yet come around to assign it an rmap_item. But each rmap_item in the stable tree which refers to an anon_vma needs to take a reference to it. Andrea's anon_vma design cleverly avoided a reference count (an anon_vma was free when its list of vmas was empty), but KSM now needs to add that. Is a 32-bit count sufficient? I believe so - the anon_vma is only free when both count is 0 and list is empty. Signed-off-by: Hugh Dickins <hugh.dickins@tiscali.co.uk> Cc: Izik Eidus <ieidus@redhat.com> Cc: Andrea Arcangeli <aarcange@redhat.com> Cc: Chris Wright <chrisw@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-12-15ksm: let shared pages be swappableHugh Dickins
Initial implementation for swapping out KSM's shared pages: add page_referenced_ksm() and try_to_unmap_ksm(), which rmap.c calls when faced with a PageKsm page. Most of what's needed can be got from the rmap_items listed from the stable_node of the ksm page, without discovering the actual vma: so in this patch just fake up a struct vma for page_referenced_one() or try_to_unmap_one(), then refine that in the next patch. Add VM_NONLINEAR to ksm_madvise()'s list of exclusions: it has always been implicit there (being only set with VM_SHARED, already excluded), but let's make it explicit, to help justify the lack of nonlinear unmap. Rely on the page lock to protect against concurrent modifications to that page's node of the stable tree. The awkward part is not swapout but swapin: do_swap_page() and page_add_anon_rmap() now have to allow for new possibilities - perhaps a ksm page still in swapcache, perhaps a swapcache page associated with one location in one anon_vma now needed for another location or anon_vma. (And the vma might even be no longer VM_MERGEABLE when that happens.) ksm_might_need_to_copy() checks for that case, and supplies a duplicate page when necessary, simply leaving it to a subsequent pass of ksmd to rediscover the identity and merge them back into one ksm page. Disappointingly primitive: but the alternative would have to accumulate unswappable info about the swapped out ksm pages, limiting swappability. Remove page_add_ksm_rmap(): page_add_anon_rmap() now has to allow for the particular case it was handling, so just use it instead. Signed-off-by: Hugh Dickins <hugh.dickins@tiscali.co.uk> Cc: Izik Eidus <ieidus@redhat.com> Cc: Andrea Arcangeli <aarcange@redhat.com> Cc: Chris Wright <chrisw@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-12-15mm: define PAGE_MAPPING_FLAGSHugh Dickins
At present we define PageAnon(page) by the low PAGE_MAPPING_ANON bit set in page->mapping, with the higher bits a pointer to the anon_vma; and have defined PageKsm(page) as that with NULL anon_vma. But KSM swapping will need to store a pointer there: so in preparation for that, now define PAGE_MAPPING_FLAGS as the low two bits, including PAGE_MAPPING_KSM (always set along with PAGE_MAPPING_ANON, until some other use for the bit emerges). Declare page_rmapping(page) to return the pointer part of page->mapping, and page_anon_vma(page) to return the anon_vma pointer when that's what it is. Use these in a few appropriate places: notably, unuse_vma() has been testing page->mapping, but is better to be testing page_anon_vma() (cases may be added in which flag bits are set without any pointer). Signed-off-by: Hugh Dickins <hugh.dickins@tiscali.co.uk> Cc: Izik Eidus <ieidus@redhat.com> Cc: Andrea Arcangeli <aarcange@redhat.com> Cc: Nick Piggin <npiggin@suse.de> Cc: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Reviewed-by: Rik van Riel <riel@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com> Cc: Andi Kleen <andi@firstfloor.org> Cc: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Wu Fengguang <fengguang.wu@intel.com> Cc: Minchan Kim <minchan.kim@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-09-24Merge branch 'hwpoison' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/ak/linux-mce-2.6 * 'hwpoison' of git://git.kernel.org/pub/scm/linux/kernel/git/ak/linux-mce-2.6: (21 commits) HWPOISON: Enable error_remove_page on btrfs HWPOISON: Add simple debugfs interface to inject hwpoison on arbitary PFNs HWPOISON: Add madvise() based injector for hardware poisoned pages v4 HWPOISON: Enable error_remove_page for NFS HWPOISON: Enable .remove_error_page for migration aware file systems HWPOISON: The high level memory error handler in the VM v7 HWPOISON: Add PR_MCE_KILL prctl to control early kill behaviour per process HWPOISON: shmem: call set_page_dirty() with locked page HWPOISON: Define a new error_remove_page address space op for async truncation HWPOISON: Add invalidate_inode_page HWPOISON: Refactor truncate to allow direct truncating of page v2 HWPOISON: check and isolate corrupted free pages v2 HWPOISON: Handle hardware poisoned pages in try_to_unmap HWPOISON: Use bitmask/action code for try_to_unmap behaviour HWPOISON: x86: Add VM_FAULT_HWPOISON handling to x86 page fault handler v2 HWPOISON: Add poison check to page fault handling HWPOISON: Add basic support for poisoned pages in fault handler v3 HWPOISON: Add new SIGBUS error codes for hardware poison signals HWPOISON: Add support for poison swap entries v2 HWPOISON: Export some rmap vma locking to outside world ...
2009-09-22ksm: no debug in page_dup_rmap()Hugh Dickins
page_dup_rmap(), used on each mapped page when forking, was originally just an inline atomic_inc of mapcount. 2.6.22 added CONFIG_DEBUG_VM out-of-line checks to it, which would need to be ever-so-slightly complicated to allow for the PageKsm() we're about to define. But I think these checks never caught anything. And if it's coding errors we're worried about, such checks should be in page_remove_rmap() too, not just when forking; whereas if it's pagetable corruption we're worried about, then they shouldn't be limited to CONFIG_DEBUG_VM. Oh, just revert page_dup_rmap() to an inline atomic_inc of mapcount. Signed-off-by: Hugh Dickins <hugh.dickins@tiscali.co.uk> Signed-off-by: Chris Wright <chrisw@redhat.com> Signed-off-by: Izik Eidus <ieidus@redhat.com> Cc: Nick Piggin <npiggin@suse.de> Cc: Andrea Arcangeli <aarcange@redhat.com> Cc: Rik van Riel <riel@redhat.com> Cc: Wu Fengguang <fengguang.wu@intel.com> Cc: Balbir Singh <balbir@in.ibm.com> Cc: Hugh Dickins <hugh.dickins@tiscali.co.uk> Cc: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Lee Schermerhorn <lee.schermerhorn@hp.com> Cc: Avi Kivity <avi@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-09-16HWPOISON: The high level memory error handler in the VM v7Andi Kleen
Add the high level memory handler that poisons pages that got corrupted by hardware (typically by a two bit flip in a DIMM or a cache) on the Linux level. The goal is to prevent everyone from accessing these pages in the future. This done at the VM level by marking a page hwpoisoned and doing the appropriate action based on the type of page it is. The code that does this is portable and lives in mm/memory-failure.c To quote the overview comment: High level machine check handler. Handles pages reported by the hardware as being corrupted usually due to a 2bit ECC memory or cache failure. This focuses on pages detected as corrupted in the background. When the current CPU tries to consume corruption the currently running process can just be killed directly instead. This implies that if the error cannot be handled for some reason it's safe to just ignore it because no corruption has been consumed yet. Instead when that happens another machine check will happen. Handles page cache pages in various states. The tricky part here is that we can access any page asynchronous to other VM users, because memory failures could happen anytime and anywhere, possibly violating some of their assumptions. This is why this code has to be extremely careful. Generally it tries to use normal locking rules, as in get the standard locks, even if that means the error handling takes potentially a long time. Some of the operations here are somewhat inefficient and have non linear algorithmic complexity, because the data structures have not been optimized for this case. This is in particular the case for the mapping from a vma to a process. Since this case is expected to be rare we hope we can get away with this. There are in principle two strategies to kill processes on poison: - just unmap the data and wait for an actual reference before killing - kill as soon as corruption is detected. Both have advantages and disadvantages and should be used in different situations. Right now both are implemented and can be switched with a new sysctl vm.memory_failure_early_kill The default is early kill. The patch does some rmap data structure walking on its own to collect processes to kill. This is unusual because normally all rmap data structure knowledge is in rmap.c only. I put it here for now to keep everything together and rmap knowledge has been seeping out anyways Includes contributions from Johannes Weiner, Chris Mason, Fengguang Wu, Nick Piggin (who did a lot of great work) and others. Cc: npiggin@suse.de Cc: riel@redhat.com Signed-off-by: Andi Kleen <ak@linux.intel.com> Acked-by: Rik van Riel <riel@redhat.com> Reviewed-by: Hidehiro Kawai <hidehiro.kawai.ez@hitachi.com>
2009-09-16HWPOISON: Handle hardware poisoned pages in try_to_unmapAndi Kleen
When a page has the poison bit set replace the PTE with a poison entry. This causes the right error handling to be done later when a process runs into it. v2: add a new flag to not do that (needed for the memory-failure handler later) (Fengguang) v3: remove unnecessary is_migration_entry() test (Fengguang, Minchan) Reviewed-by: Minchan Kim <minchan.kim@gmail.com> Reviewed-by: Wu Fengguang <fengguang.wu@intel.com> Signed-off-by: Andi Kleen <ak@linux.intel.com>
