path: root/include/linux/regulator
2012-01-09ENGR00160797-2 Add Anatop regulator driverNancy Chen
Add Anatop regulator driver. Signed-off-by: Nancy Chen <Nancy.Chen@freescale.com>
2012-01-09ENGR00141391-1 PMIC: Add DA9053 source code from DialogZhou Jingyu
Add DA9053 original source code Signed-off-by: Zhou Jingyu <Jingyu.Zhou@freescale.com> Acked-by: Lily Zhang <r58066@freescale.com>
2011-05-27regulator: Support voltage offsets to compensate for drops in systemMark Brown
Some systems, particularly physically large systems used for early prototyping, may experience substantial voltage drops between the regulator and the consumers as a result of long traces in the system. With these systems voltages may need to be set higher than requested in order to ensure reliable system operation. Allow systems to work around such hardware issues by allowing constraints to supply an offset to be applied to any requested and reported voltages. This is not ideal, especially since the voltage drop may be load dependant, but is sufficient for most affected systems, it is not expected to be used in production hardware. The offset is applied after all constraint processing so constraints should be specified in terms of consumer values not physically configured values. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Liam Girdwood <lrg@slimlogic.co.uk>
2011-05-27regulator: Remove supply_regulator_dev from machine configurationMark Brown
supply_regulator_dev (using a struct pointer) has been deprecated in favour of supply_regulator (using a regulator name) for quite a few releases now with a warning generated if it is used and there are no current in tree users so just remove the code. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Liam Girdwood <lrg@slimlogic.co.uk>
2011-05-24mach-ux500: voltage domain regulators for DB8500Bengt Jonsson
The DB8500 has ePOD:s (electronic power domains) which are possible to switch on/off to deactivate silicon blocks on the DB8500 SoC by cutting their power without retention. We model these as simple regulators with one bit on/off settings. Acked-by: Liam Girdwood <lrg@slimlogic.co.uk> Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Bengt Jonsson <bengt.g.jonsson@stericsson.com> Signed-off-by: Sundar Iyer <sundar.iyer@stericsson.com> Signed-off-by: Jonas Aberg <jonas.aberg@stericsson.com> Signed-off-by: Virupax Sadashivpetimath <virupax.sadashivpetimath@stericsson.com> Signed-off-by: Martin Persson <martin.persson@stericsson.com> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2011-03-26regulator: provide consumer interface for fall/rise timeLinus Walleij
This exposes the functionality for rise/fall fime when setting voltage to the consumers. Cc: Bengt Jonsson <bengt.g.jonsson@stericsson.com> Signed-off-by: Linus Walleij <linus.walleij@linaro.org> Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Liam Girdwood <lrg@slimlogic.co.uk>
2011-03-26regulator: add set_voltage_time_sel infrastructureLinus Walleij
This makes it possible to set the stabilization time for voltage regulators in the same manner as enable_time(). The interface only supports regulators that implements fixed selectors. Cc: Bengt Jonsson <bengt.g.jonsson@stericsson.com> Signed-off-by: Linus Walleij <linus.walleij@linaro.org> Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Liam Girdwood <lrg@slimlogic.co.uk>
2011-03-26regulator: initialization for ab8500 regulatorsBengt Jonsson
The regulators on the AB8500 have a lot of custom hardware control settings pertaining to 8 external signals, settings which are board-specific and need be provided from the platform at startup. Initialization added for regulators Vana, VextSupply1, VextSupply2, VextSupply3, Vaux1, Vaux2, Vaux3, VTVout, Vintcore12, Vaudio, Vdmic, Vamic1, Vamic2, VrefDDR. Signed-off-by: Bengt Jonsson <bengt.g.jonsson@stericsson.com> Reviewed-by: Rickard Andersson <rickard.andersson@stericsson.com> Reviewed-by: Jonas Aberg <jonas.aberg@stericsson.com> Signed-off-by: Linus Walleij <linus.walleij@linaro.org> Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Liam Girdwood <lrg@slimlogic.co.uk>
2011-03-26regulator: add support for USB voltage regulatorBengt Jonsson
Signed-off-by: Bengt Jonsson <bengt.g.jonsson@stericsson.com> Signed-off-by: Linus Walleij <linus.walleij@linaro.org> Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Liam Girdwood <lrg@slimlogic.co.uk>
2011-03-26Regulator: add suspend-finish API for regulator core.MyungJoo Ham
The regulator core had suspend-prepare that turns off the regulators when entering a system-wide suspend. However, it did not have suspend-finish that pairs with suspend-prepare and the regulator core has assumed that the regulator devices and their drivers support autonomous recover at resume. This patch adds regulator_suspend_finish that pairs with the previously-existed regulator_suspend_prepare. The function regulator_suspend_finish turns on the regulators that have always_on set or positive use_count so that we can reset the regulator states appropriately at resume. In regulator_suspend_finish, if has_full_constraints, it disables unnecessary regulators. Signed-off-by: MyungJoo Ham <myungjoo.ham@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com> -- Updates v3 comments corrected (Thanks to Igor) v2 disable unnecessary regulators (Thanks to Mark) Signed-off-by: Liam Girdwood <lrg@slimlogic.co.uk>
2011-01-12regulator: Add initial per-regulator debugfs supportMark Brown
We only expose the use and open counts to userspace, providing a tiny bit of insight into what the API is up to. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Liam Girdwood <lrg@slimlogic.co.uk>
2011-01-12regulator: Add API to re-apply voltage to hardwareMark Brown
When cooperating with an external control source the regulator setup may be changed underneath the API. Currently consumers can just redo the regulator_set_voltage() to restore a previously set configuration but provide an explicit API for doing this as optimsations in the regulator_set_voltage() implementation will shortly prevent that. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Liam Girdwood <lrg@slimlogic.co.uk>
2011-01-12regulator: Provide a selector based set_voltage_sel() operationMark Brown
Many regulator drivers implement voltage setting by looping through a table of possible values, normally because the set of available voltages can't be mapped onto selectors with simple calcuation. Factor out these loops by providing a variant of set_voltage() which takes a selector rather than a voltage range as an argument and implementing a loop through the available selectors in the core. This is not going to be suitable for use with all devices as when the regulator voltage can be mapped onto selector values with a simple calculation the linear scan through the available values will be more expensive than just doing the calculation, especially for regulators that provide fine grained voltage control. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Liam Girdwood <lrg@slimlogic.co.uk>
2011-01-12regulators: Moved define for number of regulators in ab8500Bengt Jonsson
The define for number of regulators is moved from ab8500-core to ab8500-regulator so that the regulator driver can be updated independently of ab8500-core. This also changes the platform configuration structure of ab8500-core so that it contains a pointer to the regulator_init_data array plus number of regulators instead of an fixed size array of pointers to regulator_init_data. Signed-off-by: Bengt Jonsson <bengt.g.jonsson@stericsson.com> Acked-by: Linus Walleij <linus.walleij@stericsson.com> Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Liam Girdwood <lrg@slimlogic.co.uk>
2011-01-12regulator: Allow drivers to report voltages as selectorsMark Brown
Since drivers already have to provide an API for translating selectors into voltages they may as well just report the selector values directly to the core API rather than implement the lookup themselves. The old interface is left in place for now, but may be removed in future. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Liam Girdwood <lrg@slimlogic.co.uk>
2011-01-12regulator: Copy constraints from regulators when initialising themMark Brown
Currently the regulator API uses the constraints structure passed in to the core throughout the lifetime of the object. This means that it is not possible to mark the constraints as __initdata so if the kernel supports many boards the constraints for all of them are kept around throughout the lifetime of the system, consuming memory needlessly. By copying constraints that are actually used we allow the use of __initdata, saving memory when multiple boards are supported. This also means the constraints can be const. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Liam Girdwood <lrg@slimlogic.co.uk>
2011-01-12regulator: Report actual configured voltage to set_voltage()Mark Brown
Change the interface used by set_voltage() to report the selected value to the regulator core in terms of a selector used by list_voltage(). This allows the regulator core to know the voltage that was chosen without having to do an explict get_voltage(), which would be much more expensive as it will generally access hardware. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Liam Girdwood <lrg@slimlogic.co.uk>
2010-10-28regulator: Add option for machine drivers to enable the dummy regulatorMark Brown
Allow machine drivers to explicitly enable the use of the dummy regulator, enabling simpler support for systems with only a few specific supplies visible to software. It is strongly recommended that this is not used on systems with substantial software control over their PMICs, for maximum functionality constrints should be as fully specified as possible. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Liam Girdwood <lrg@slimlogic.co.uk>
2010-10-28Regulator: LP3972 PMIC regulator driverAxel Lin
This patch adds regulator drivers for National Semiconductors LP3972 PMIC. This LP3972 PMIC controller has 3 DC/DC voltage converters and 5 low drop-out (LDO) regulators. LP3972 PMIC controller uses I2C interface. Signed-off-by: Axel Lin <axel.lin@gmail.com> Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Liam Girdwood <lrg@slimlogic.co.uk>
2010-10-28MAX8952 PMIC Driver Initial ReleaseMyungJoo Ham
MAX8952 PMIC is used to provide voltage output between 770mV - 1400mV with DVS support. In this initial release, users can set voltages for four DVS modes, RAMP delay values, and SYNC frequency. Controlling FPWM/SYNC_MODE/Pull-Down/Ramp Modes and reading CHIP_ID is not supported in this release. If GPIO of EN is not valid in platform data, the driver assumes that it is always-on. If GPIO of VID0 or VID1 is invalid, the driver pulls down VID0 and VID1 to fix DVS mode as 0 and disables DVS support. We assume that V_OUT is capable to provide every voltage from 770mV to 1.40V in 10mV steps although the data sheet has some ambiguity on it. Signed-off-by: MyungJoo Ham <myungjoo.ham@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com> -- v2: - Style correction - Can accept platform_data with invalid GPIOs - Removed unnecessary features - Improved error handling Signed-off-by: Liam Girdwood <lrg@slimlogic.co.uk>
2010-08-11ab8500-mfd: add regulator support to ab8500 mfd deviceSundar R Iyer
Acked-by: Linus Walleij <linus.walleij@stericsson.com> Acked-By: Mattias Wallin <mattias.wallin@stericsson.com> Acked-By: Bengt JONSSON <bengt.g.jonsson@stericsson.com> Signed-off-by: Sundar R Iyer <sundar.iyer@stericsson.com> Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Acked-by: Samuel Ortiz <sameo@linux.intel.com> Signed-off-by: Liam Girdwood <lrg@slimlogic.co.uk>
2010-07-28regulator: tps6507x: allow driver to use DEFDCDC{2,3}_HIGH registerAnuj Aggarwal
Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com> In TPS6507x, depending on the status of DEFDCDC{2,3} pin either DEFDCDC{2,3}_LOW or DEFDCDC{2,3}_HIGH register needs to be read or programmed to change the output voltage. The current driver assumes DEFDCDC{2,3} pins are always tied low and thus operates only on DEFDCDC{2,3}_LOW register. This need not always be the case (as is found on OMAP-L138 EVM). Unfortunately, software cannot read the status of DEFDCDC{2,3} pins. So, this information is passed through platform data depending on how the board is wired. Signed-off-by: Anuj Aggarwal <anuj.aggarwal@ti.com> Signed-off-by: Sekhar Nori <nsekhar@ti.com> Signed-off-by: Liam Girdwood <lrg@slimlogic.co.uk>
2010-05-25regulator: Allow regulator-regulator supplies to be specified by nameMark Brown
When one regulator supplies another allow the relationship to be specified using names rather than struct regulators, in a similar manner to that allowed for consumer supplies. This allows static configuration at compile time, reducing the need for dynamic init code. Also change the references to LINE supply to be system supply since line is sometimes used for actual supplies and therefore potentially confusing. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Liam Girdwood <lrg@slimlogic.co.uk>
2010-04-19regulator: Let drivers know when they use the stub APIJean Delvare
Have the stub variant of regulator_get() return NULL, so that drivers can (but still don't have to) handle this case specifically. Signed-off-by: Jean Delvare <khali@linux-fr.org> Cc: Mark Brown <broonie@opensource.wolfsonmicro.com> Cc: Jerome Oufella <jerome.oufella@savoirfairelinux.com> Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Liam Girdwood <lrg@slimlogic.co.uk>
2010-03-03regulator: enable max8649 regulator driverHaojian Zhuang
Signed-off-by: Haojian Zhuang <haojian.zhuang@marvell.com> Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Liam Girdwood <lrg@slimlogic.co.uk>
2010-03-03regulator: Add 'start-up time' to fixed voltage regulatorsAdrian Hunter
Add a field to specify a delay for the start-up time of a fixed voltage regulator. Signed-off-by: Adrian Hunter <adrian.hunter@nokia.com> Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Liam Girdwood <lrg@slimlogic.co.uk>
2010-03-03regulator: Allow regulators to specify the time taken to ramp on enableMark Brown
Regulators may sometimes take longer to enable than the control operation used to do so, either because the regulator has ramp rate control used to limit inrush current or because the control operation is very fast (GPIO being the most common example of this). In order to ensure that consumers do not rely on the regulator before it is enabled provide an enable_time() operation and have the core delay for that time before returning to the caller. This is implemented as a function since the ramp rate may be specified in voltage per unit time and therefore the time depend on the configuration. In future it would be desirable to allow the bulk operations to run the delays for multiple enables in parallel but this is not currently supported. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2010-03-03regulator: Add notifier event on regulator disableMark Brown
The intended use case is for drivers which disable regulators to save power but need to do some work to restore the hardware state when restarting. If the supplies are not actually disabled due to board limits or sharing with other active devices this notifier allows the driver to avoid unneeded reinitialisation, particularly when used with runtime PM. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2009-12-17regulator: consumer.h - fix build when consumer.h is #included first.Liam Girdwood
consumer.h requires device.h for stand alone build. Signed-off-by: Liam Girdwood <lrg@slimlogic.co.uk>
2009-12-17regulator: Handle regulators without suspend mode configurationMark Brown
Since some regulators in the system may not support suspend mode configuration we need to allow some regulators to have a missing suspend mode configuration. Do this by requiring that disabled regulators are explicitly flagged and then skip over regulators that have no state specified. Try to avoid surprises by warning the if we could set the state but no configuration is provided. This also ensures that an all zeros configuration generates a warning rather than silently disabling the regulator. Reported-by: Joonyoung Shim <jy0922.shim@samsung.com> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Liam Girdwood <lrg@slimlogic.co.uk>
2009-12-17regulator: add driver for MAX8660/8661Wolfram Sang
Tested with a MX25-based custom board. Signed-off-by: Wolfram Sang <w.sang@pengutronix.de> Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Liam Girdwood <lrg@slimlogic.co.uk>
2009-09-22regulator/driver: be more specific in nanodoc for is_enabledWolfram Sang
Document the possibility that is_enabled may also return with negative errorcodes. Signed-off-by: Wolfram Sang <w.sang@pengutronix.de> Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Liam Girdwood <lrg@slimlogic.co.uk>
2009-09-22regulator: fix typosWolfram Sang
Fix a couple of typos I found while working with this subsystem. Signed-off-by: Wolfram Sang <w.sang@pengutronix.de> Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Liam Girdwood <lrg@slimlogic.co.uk>
2009-09-22regulator: Add GPIO enable control to fixed voltage regulator driverRoger Quadros
Now fixed regulators that have their enable pin connected to a GPIO line can use the fixed regulator driver for regulator enable/disable control. The GPIO number and polarity information is passed through platform data. GPIO enable control is achieved using gpiolib. Signed-off-by: Roger Quadros <ext-roger.quadros@nokia.com> Reviewed-by: Philipp Zabel <philipp.zabel@gmail.com> Reviewed-by: Felipe Balbi <felipe.balbi@nokia.com> Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Liam Girdwood <lrg@slimlogic.co.uk>
2009-09-22regulator: Add regulator voltage range check APIMark Brown
Simplify checking of support for voltage ranges by providing an API which wraps the existing count and list operations. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Liam Girdwood <lrg@slimlogic.co.uk>
2009-09-22regulator: Add regulator_get_exclusive() APIMark Brown
Some consumers require complete control of the regulator and can't tolerate sharing it with other consumers, most commonly because they need to have the regulator actually disabled so can't have other consumers forcing it on. This new regulator_get_exclusive() API call allows these consumers to explicitly request this, documenting the assumptions that they are making. In order to simplify coding of such consumers the use count for regulators they request is forced to match the enabled state of the regulator when it is requested. This is not possible for consumers which can share regulators due to the need to keep track of the ownership of use counts. A new API call is used rather than an additional argument to the existing regulator_get() in order to avoid merge headaches with driver code in other trees. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Liam Girdwood <lrg@slimlogic.co.uk>
2009-09-22regulator: add initialization macro of regulator supplyroald
2009-09-22regulator: Define full constraints function with REGULATOR disabledMark Brown
This allows machine drivers to build without ifdefs if they have full constraints. Suggested by machine drivers contributed by Haojian Zhuang <haojian.zhuang@gmail.com>. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Liam Girdwood <lrg@slimlogic.co.uk>
2009-09-22regulator: Allow consumer supplies to be set up with dev_name()Mark Brown
Follow the approach suggested by Russell King and implemented by him in the clkdev API and allow consumer device supply mapings to be set up using the dev_name() for the consumer instead of the struct device. In order to avoid making existing machines instabuggy and creating merge issues the use of struct device is still supported for the time being. This resolves problems working with buses such as I2C which make the struct device available late providing that the final device name is known, which is the case for most embedded systems with fixed setups. Consumers must still use the struct device when calling regulator_get(). Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Liam Girdwood <lrg@slimlogic.co.uk>
2009-09-17regulator: Provide mode to status conversion functionMark Brown
This is useful for implementing get_status() in terms of get_mode(). Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2009-06-15regulator/max1586: support increased V3 voltage rangePhilipp Zabel
The V3 regulator can be configured with an external resistor connected to the feedback pin (R24 in the data sheet) to increase the voltage range. For example, hx4700 has R24 = 3.32 kOhm to achieve a maximum V3 voltage of 1.55 V which is needed for 624 MHz CPU frequency. Signed-off-by: Philipp Zabel <philipp.zabel@gmail.com> Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Acked-by: Robert Jarzmik <robert.jarzmik@free.fr> Signed-off-by: Liam Girdwood <lrg@slimlogic.co.uk>
2009-06-15LP3971 PMIC regulator driver (updated and combined version)Marek Szyprowski
This patch adds regulator drivers for National Semiconductors LP3971 PMIC. This LP3971 PMIC controller has 3 DC/DC voltage converters and 5 low drop-out (LDO) regulators. LP3971 PMIC controller uses I2C interface. Reviewed-by: Kyungmin Park <kyungmin.park@samsung.com> Signed-off-by: Marek Szyprowski <m.szyprowski@samsung.com> Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Liam Girdwood <lrg@slimlogic.co.uk>
2009-06-15regulator: add userspace-consumer driverMike Rapoport
The userspace-consumer driver allows control of voltage and current regulator state from userspace. This is required for fine-grained power management of devices that are completely controller by userspace applications, e.g. a GPS transciever connected to a serial port. Signed-off-by: Mike Rapoport <mike@compulab.co.il> Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Liam Girdwood <lrg@slimlogic.co.uk>
2009-06-15Maxim 1586 regulator driverRobert Jarzmik
The Maxim 1586 regulator is a voltage regulator with 2 voltage outputs, specially suitable for Marvell PXA chips. One output is in the range of required VCC_CORE by the PXA27x chips, the other in the VCC_USIM required as well by PXA27x chips. The chip is controlled through the I2C bus. Signed-off-by: Robert Jarzmik <robert.jarzmik@free.fr> Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Liam Girdwood <lrg@slimlogic.co.uk>
2009-04-28regulator: fix header file missing kernel-docRandy Dunlap
Add regulator header file missing kernel-doc: Warning(include/linux/regulator/driver.h:117): No description found for parameter 'set_mode' Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> cc: Liam Girdwood <lrg@slimlogic.co.uk> cc: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Liam Girdwood <lrg@slimlogic.co.uk>
2009-03-31regulator: Support disabling of unused regulators by machinesMark Brown
At present it is not possible for machine constraints to disable regulators which have been left on when the system starts, for example as a result of fixed default configurations in hardware. This means that power may be wasted by these regulators if they are not in use. Provide intial support for this with a late_initcall which will disable any unused regulators if the machine has enabled this feature by calling regulator_has_full_constraints(). If this has not been called then print a warning to encourage users to fully specify their constraints so that we can change this to be the default behaviour in future. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Liam Girdwood <lrg@slimlogic.co.uk>
2009-03-31regulator: Allow boot_on regulators to be disabled by clientsMark Brown
Rather than incrementing the reference count for boot_on regulators (which prevents them being disabled later on) simply force the regulator to be enabled when applying the constraints. Previously boot_on was essentially equivalent to always_on. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Liam Girdwood <lrg@slimlogic.co.uk>
2009-03-31regulator: get_status() grows kerneldocDavid Brownell
Add kerneldoc for the new get_status() message. Fix the existing kerneldoc for that struct in two ways: (a) Syntax, making sure parameter descriptions immediately follow the one-line struct description and that the first blank lines is before any more expansive description; (b) Presentation for a few points, to highlight the fact that the previous "get" methods exist only to report the current configuration, not to display actual status. Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Liam Girdwood <lrg@slimlogic.co.uk>
2009-03-31regulator: enumerate voltages (v2)David Brownell
Add a basic mechanism for regulators to report the discrete voltages they support: list_voltage() enumerates them using selectors numbered from 0 to an upper bound. Use those methods to force machine-level constraints into bounds. (Example: regulator supports 1.8V, 2.4V, 2.6V, 3.3V, and board constraints for that rail are 2.0V to 3.6V ... so the range of voltages is then 2.4V to 3.3V on this board.) Export those voltages to the regulator consumer interface, so for example regulator hooked up to an MMC/SD/SDIO slot can report the actual voltage options available to cards connected there. Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Liam Girdwood <lrg@slimlogic.co.uk>
2009-03-31regulator: Allow regulators to set the initial operating modeMark Brown
This is useful when wishing to run in a fixed operating mode that isn't the default. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Liam Girdwood <lrg@slimlogic.co.uk>
