path: root/include/linux/regmap.h
2014-01-09Merge remote-tracking branch 'regmap/topic/ack' into regmap-nextMark Brown
2014-01-09regmap: fix a couple of typosLaszlo Papp
These sentences are not proper English due to the typos. I had initially caught one of them while trying to understand the regmap feature, and then I just ran the vim spell checker, and went through all the items that would need to be fixed for this header file. Signed-off-by: Laszlo Papp <lpapp@kde.org> Signed-off-by: Mark Brown <broonie@linaro.org>
2013-12-16regmap: irq: Allow using zero value for ack_baseAlexander Shiyan
In some cases, clear interrupt register may be at address 0. This patch allows to use such configurations by adding additional configuration bit to indicate this. [With doc fix from Levente Kurusa <levex@linux.com> -- broonie] Signed-off-by: Alexander Shiyan <shc_work@mail.ru> Signed-off-by: Mark Brown <broonie@linaro.org>
2013-10-28Merge remote-tracking branch 'regmap/topic/spmi' into regmap-nextMark Brown
2013-10-28Merge remote-tracking branch 'regmap/topic/range' into regmap-nextMark Brown
2013-10-28Merge remote-tracking branch 'regmap/topic/multi' into regmap-nextMark Brown
2013-10-28Merge remote-tracking branch 'regmap/topic/field' into regmap-nextMark Brown
2013-10-28regmap: add SPMI supportJosh Cartwright
Add basic support for the System Power Management Interface (SPMI) bus. This is a simple implementation which only implements register accesses via the Extended Register Read/Write Long commands. Signed-off-by: Josh Cartwright <joshc@codeaurora.org> Signed-off-by: Mark Brown <broonie@linaro.org>
2013-10-14regmap: new API regmap_multi_reg_write() definitionAnthony Olech
New API regmap_multi_reg_write() is defined that allows a set of reg,val pairs to be written to a I2C client device as one block transfer from the point of view of a single I2C master system. A simple demonstration implementation is included that just splits the block write request into a sequence of single register writes. The implementation will be modified later to support those I2C clients that implement the alternative non-standard MULTIWRITE block write mode so to achieve a single I2C transfer that will be atomic even in multiple I2C master systems. Signed-off-by: Anthony Olech <anthony.olech.opensource@diasemi.com> Signed-off-by: David Dajun Chen <david.chen@diasemi.com> Signed-off-by: Mark Brown <broonie@linaro.org>
2013-10-09regmap: Provide asynchronous write and update bits operationsMark Brown
Make it easier for drivers to include single register writes in asynchronous sequences by providing async versions of the write and update bits operations. The update bits operations are only likely to be effective when used with devices that have caches but this is common enough to be useful. Signed-off-by: Mark Brown <broonie@linaro.org>
2013-09-20regmap: add helper macro to set min/max range of registerLaxman Dewangan
Add helper macro to set the min and max value of the register range. This is useful when initialising the register ranges of the device like static const struct regmap_range readable_ranges[] = { regmap_reg_range(DEVICE_REG0, DEVICE_REG10), }; Signed-off-by: Laxman Dewangan <ldewangan@nvidia.com> Signed-off-by: Mark Brown <broonie@linaro.org>
2013-09-17regmap: Add regmap_fields APIsKuninori Morimoto
Current Linux kernel is supporting regmap_field method and it is very useful feature. It needs one regmap_filed for one register access. OTOH, there is multi port device which has many same registers in the market. The difference for each register access is only its address offset. Current API needs many regmap_field for such device, but it is not good. This patch adds new regmap_fileds API which can care about multi port/offset access via regmap. Signed-off-by: Kuninori Morimoto <kuninori.morimoto.gx@renesas.com> Signed-off-by: Mark Brown <broonie@linaro.org>
2013-09-17regmap: add regmap_field_update_bits()Kuninori Morimoto
Current regmap_field is supporting read/write functions. This patch adds new update_bits function for it. Signed-off-by: Kuninori Morimoto <kuninori.morimoto.gx@renesas.com> Signed-off-by: Mark Brown <broonie@linaro.org>
2013-09-03Merge tag 'regmap-v3.12' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/broonie/regmap Pull regmap updates from Mark Brown: "A quiet release for regmap, some cleanups, fixes and: - Improved node coalescing for rbtree, reducing memory usage and improving performance during syncs. - Support for registering multiple register patches. - A quirk for handling interrupts that need to be clear when masked in regmap-irq" * tag 'regmap-v3.12' of git://git.kernel.org/pub/scm/linux/kernel/git/broonie/regmap: regmap: rbtree: Make cache_present bitmap per node regmap: rbtree: Reduce number of nodes, take 2 regmap: rbtree: Simplify adjacent node look-up regmap: debugfs: Fix continued read from registers file regcache-rbtree: Fix reg_stride != 1 regmap: Allow multiple patches to be registered regmap: regcache: allow read-only regs to be cached regmap: fix regcache_reg_present() for empty cache regmap: core: allow a virtual range to cover its own data window regmap: irq: document mask/wake_invert flags regmap: irq: make flags bool and put them in a bitfield regmap: irq: Allow to acknowledge masked interrupts during initialization regmap: Provide __acquires/__releases annotations
2013-08-31Merge remote-tracking branch 'regmap/topic/irq' into regmap-nextMark Brown
2013-08-15regmap: Add another missing header for !CONFIG_REGMAP stubsKevin Hilman
The use of WARN_ON() needs the definitions from bug.h, without it you can get: include/linux/regmap.h: In function 'regmap_write': include/linux/regmap.h:525:2: error: implicit declaration of function 'WARN_ONCE' [-Werror=implicit-function-declaration] Signed-off-by: Kevin Hilman <khilman@linaro.org> Signed-off-by: Mark Brown <broonie@linaro.org> Cc: stable@vger.kernel.org
2013-08-06regmap: Add missing header for !CONFIG_REGMAP stubsMateusz Krawczuk
regmap.h requires linux/err.h if CONFIG_REGMAP is not defined. Without it I get error. CC drivers/media/platform/exynos4-is/fimc-reg.o In file included from drivers/media/platform/exynos4-is/fimc-reg.c:14:0: include/linux/regmap.h: In function ‘regmap_write’: include/linux/regmap.h:525:10: error: ‘EINVAL’ undeclared (first use in this function) include/linux/regmap.h:525:10: note: each undeclared identifier is reported only once for each function it appears in Signed-off-by: Mateusz Krawczuk <m.krawczuk@partner.samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Signed-off-by: Mark Brown <broonie@linaro.org> Cc: stable@kernel.org
2013-07-24regmap: irq: document mask/wake_invert flagsPhilipp Zabel
Signed-off-by: Philipp Zabel <p.zabel@pengutronix.de> Signed-off-by: Mark Brown <broonie@linaro.org>
2013-07-24regmap: irq: make flags bool and put them in a bitfieldPhilipp Zabel
This patch makes mask/wake_invert bool and puts all flags into a bitfield for consistency and to save some space. Signed-off-by: Philipp Zabel <p.zabel@pengutronix.de> Signed-off-by: Mark Brown <broonie@linaro.org>
2013-07-23regmap: irq: Allow to acknowledge masked interrupts during initializationPhilipp Zabel
In case the hardware interrupt mask register does not prevent the chip level irq from being asserted by the corresponding interrupt status bit, already set interrupt bits should to be cleared once after masking them during initialization. Add a flag to let drivers enable this behavior. Signed-off-by: Philipp Zabel <p.zabel@pengutronix.de> Signed-off-by: Mark Brown <broonie@linaro.org>
2013-06-30Merge remote-tracking branch 'regmap/topic/field' into regmap-nextMark Brown
2013-06-12regmap: Add regmap_field APIsSrinivas Kandagatla
It is common to access regmap registers at bit level, using regmap_update_bits or regmap_read functions, however the end user has to take care of a mask or shifting. This becomes overhead when such use cases are high. Having a common function to do this is much convenient and less error prone. The idea of regmap_field is simple, regmap_field gives a logical structure to bits of the regmap register, and the driver can use this logical entity without the knowledge of the bit positions and masks all over the code. This way code looks much neat and it need not handle the masks, shifts every time it access the those entities. With this new regmap_field_read/write apis the end user can setup a regmap field using regmap_field_init and use the return regmap_field to read write the register field without worrying about the masks or shifts. Also this apis will be useful for drivers which are based on regmaps, like some clocks or pinctrls which can work on the regmap_fields directly without having to worry about bit positions. Signed-off-by: Srinivas Kandagatla <srinivas.kandagatla@st.com> Signed-off-by: Mark Brown <broonie@linaro.org>
2013-05-12regmap: Make regmap_check_range_table() a public APIMark Brown
Allow drivers to use an access table as part of their implementation. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2013-05-12regmap: Add support for discarding parts of the register cacheMark Brown
Allow drivers to discard parts of the register cache, for example if part of the hardware has been reset. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2013-03-27regmap: core: Provide regmap_can_raw_write() operationMark Brown
Mainly useful internally but exported since this is a public API that's being checked for. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2013-02-14Merge remote-tracking branch 'regmap/topic/no-bus' into regmap-nextMark Brown
2013-02-14Merge remote-tracking branch 'regmap/topic/mmio' into regmap-nextMark Brown
2013-02-14Merge remote-tracking branch 'regmap/topic/irq' into regmap-nextMark Brown
2013-02-14Merge remote-tracking branch 'regmap/topic/flat' into regmap-nextMark Brown
2013-02-14regmap: mmio: add register clock supportPhilipp Zabel
Some mmio devices have a dedicated interface clock that needs to be enabled to access their registers. This patch optionally enables a clock before accessing registers in the regmap_bus callbacks. I added (devm_)regmap_init_mmio_clk variants of the init functions that have an added clk_id string parameter. This is passed to clk_get to request the clock from the clk framework. Signed-off-by: Philipp Zabel <p.zabel@pengutronix.de> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2013-01-29regmap: Add asynchronous I/O supportMark Brown
Some use cases like firmware download can transfer a lot of data in quick succession. With high speed buses these use cases can benefit from having multiple transfers scheduled at once since this allows the bus to minimise the delay between transfers. Support this by adding regmap_raw_write_async(), allowing raw transfers to be scheduled, and regmap_async_complete() to wait for them to finish. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2013-01-29regmap: Add "no-bus" option for regmap APIAndrey Smirnov
This commit adds provision for "no-bus" usage of the regmap API. In this configuration user can provide API with two callbacks 'reg_read' and 'reg_write' which are to be called when reads and writes to one of device's registers is performed. This is useful for devices that expose registers but whose register access sequence does not fit the 'bus' abstraction. Signed-off-by: Andrey Smirnov <andrew.smirnov@gmail.com> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2013-01-04regmap: irq: Support wake IRQ mask inversionMark Brown
Support devices which have an enable rather than mask register for wake sources. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2013-01-02regmap: flat: Add flat cache typeMark Brown
While for I2C and SPI devices the overhead of using rbtree for devices with only one block of registers is negligible the same isn't always going to be true for MMIO devices where the I/O costs are very much lower. Cater for these devices by adding a simple flat array type for them where the lookups are simple array accesses, taking us right back to the original ASoC cache implementation. Thanks to Magnus Damm for the discussion which prompted this. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2012-12-11Merge remote-tracking branch 'regmap/topic/table' into regmap-nextMark Brown
2012-12-11Merge remote-tracking branch 'regmap/topic/lock' into regmap-nextMark Brown
2012-12-11Merge remote-tracking branch 'regmap/topic/domain' into regmap-nextMark Brown
2012-11-21regmap: introduce tables for readable/writeable/volatile/precious checksDavide Ciminaghi
Many of the regmap enabled drivers implementing one or more of the readable, writeable, volatile and precious methods use the same code pattern: return ((reg >= X && reg <= Y) || (reg >= W && reg <= Z) || ...) Switch to a data driven approach, using tables to describe readable/writeable/volatile and precious registers ranges instead. The table based check can still be overridden by passing the usual function pointers via struct regmap_config. Signed-off-by: Davide Ciminaghi <ciminaghi@gnudd.com> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2012-11-21Merge branch 'topic/lock' of ↵Mark Brown
git://git.kernel.org/pub/scm/linux/kernel/git/broonie/regmap into regmap-table
2012-10-17regmap: make lock/unlock functions customizableDavide Ciminaghi
It is sometimes convenient for a regmap user to override the standard regmap lock/unlock functions with custom functions. For instance this can be useful in case an already existing spinlock or mutex has to be used for locking a set of registers instead of the internal regmap spinlock/mutex. Note that the fast_io field of struct regmap_bus is ignored in case custom locking functions are used. Signed-off-by: Davide Ciminaghi <ciminaghi@gnudd.com> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2012-10-15regmap: Allow ranges to be namedMark Brown
For more useful diagnostics. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2012-10-15regmap: Rename n_ranges to num_rangesMark Brown
This makes things consistent with the rest of the API and is actually what the documentation says. We don't currently have any in tree users so low cost. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2012-10-15regmap: irq: Allow users to retrieve the irq_domainMark Brown
This is useful for integration with other subsystems, especially MFD, and provides an alternative API for users that request their own IRQs. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2012-08-30regmap: irq: Add mask invert flag for enable registerXiaofan Tian
Currently, regmap will write 1 to mask_base to mask an interrupt and write 0 to unmask it. But some chips do not have an interrupt mask register, and only have interrupt enable register. Then we should write 0 to disable interrupt and 1 to enable. So add an mask_invert flag to handle this. If it is not set, behavior is same as previous. If set it to 1, the mask value will be inverted before written to mask_base Signed-off-by: Xiaofan Tian <tianxf@marvell.com> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2012-08-07regmap: irq: Enable devices for runtime PM while handling interruptsMark Brown
Some devices need to have a runtime PM reference while handling interrupts to ensure that the register I/O is available. Support this with a flag in the chip. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2012-07-22Merge branches 'regmap-core', 'regmap-irq' and 'regmap-page' into regmap-nextMark Brown
Conflicts (trivial context stuff): drivers/base/regmap/regmap.c include/linux/regmap.h
2012-06-17regmap: Add support for register indirect addressing.Krystian Garbaciak
Devices with register paging or indirectly accessed registers can configure register mapping to map those on virtual address range. During access to virtually mapped register range, indirect addressing is processed automatically, in following steps: 1. selector for page or indirect register is updated (when needed); 2. register in data window is accessed. Configuration should provide minimum and maximum register for virtual range, details of selector field for page selection, minimum and maximum register of data window for indirect access. Virtual range registers are managed by cache as well as direct access registers. In order to make indirect access more efficient, selector register should be declared as non-volatile, if possible. struct regmap_config is extended with the following: struct regmap_range_cfg *ranges; unsigned int n_ranges; [Also reordered debugfs init to later on since the cleanup code was conflicting with the new cleanup code for ranges anyway -- broonie] Signed-off-by: Krystian Garbaciak <krystian.garbaciak@diasemi.com> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2012-06-13regmap: Remove warning on stubbed dev_get_regmap()Mark Brown
It's perfectly sensible to ask if there's a regmap for a device which doesn't have one so the stubbed version shouldn't complain, the caller should be prepared for this. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2012-06-05regmap: Implement support for wake IRQsMark Brown
Allow chips to provide a bank of registers for controlling the wake state in a similar fashion to the masks and propagate the wake count to the parent interrupt controller. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2012-06-03regmap: Constify regmap_irq_chipMark Brown
We should never be modifying it and it lets drivers declare it const. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
