path: root/include/linux/rcutiny.h
2010-05-10rcu: slim down rcutiny by removing rcu_scheduler_active and friendsPaul E. McKenney
TINY_RCU does not need rcu_scheduler_active unless CONFIG_DEBUG_LOCK_ALLOC. So conditionally compile rcu_scheduler_active in order to slim down rcutiny a bit more. Also gets rid of an EXPORT_SYMBOL_GPL, which is responsible for most of the slimming. Signed-off-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com>
2010-05-10rcu: refactor RCU's context-switch handlingPaul E. McKenney
The addition of preemptible RCU to treercu resulted in a bit of confusion and inefficiency surrounding the handling of context switches for RCU-sched and for RCU-preempt. For RCU-sched, a context switch is a quiescent state, pure and simple, just like it always has been. For RCU-preempt, a context switch is in no way a quiescent state, but special handling is required when a task blocks in an RCU read-side critical section. However, the callout from the scheduler and the outer loop in ksoftirqd still calls something named rcu_sched_qs(), whose name is no longer accurate. Furthermore, when rcu_check_callbacks() notes an RCU-sched quiescent state, it ends up unnecessarily (though harmlessly, aside from the performance hit) enqueuing the current task if it happens to be running in an RCU-preempt read-side critical section. This not only increases the maximum latency of scheduler_tick(), it also needlessly increases the overhead of the next outermost rcu_read_unlock() invocation. This patch addresses this situation by separating the notion of RCU's context-switch handling from that of RCU-sched's quiescent states. The context-switch handling is covered by rcu_note_context_switch() in general and by rcu_preempt_note_context_switch() for preemptible RCU. This permits rcu_sched_qs() to handle quiescent states and only quiescent states. It also reduces the maximum latency of scheduler_tick(), though probably by much less than a microsecond. Finally, it means that tasks within preemptible-RCU read-side critical sections avoid incurring the overhead of queuing unless there really is a context switch. Suggested-by: Lai Jiangshan <laijs@cn.fujitsu.com> Acked-by: Lai Jiangshan <laijs@cn.fujitsu.com> Signed-off-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Peter Zijlstra <peterz@infradead.org>
2010-05-10rcu: shrink rcutiny by making synchronize_rcu_bh() be inlinePaul E. McKenney
Because synchronize_rcu_bh() is identical to synchronize_sched(), make the former a static inline invoking the latter, saving the overhead of an EXPORT_SYMBOL_GPL() and the duplicate code. Signed-off-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com>
2010-02-26rcu: Make rcu_read_lock_sched_held() take boot time into accountPaul E. McKenney
Before the scheduler starts, all tasks are non-preemptible by definition. So, during that time, rcu_read_lock_sched_held() needs to always return "true". This patch makes that be so. Signed-off-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Cc: laijs@cn.fujitsu.com Cc: dipankar@in.ibm.com Cc: mathieu.desnoyers@polymtl.ca Cc: josh@joshtriplett.org Cc: dvhltc@us.ibm.com Cc: niv@us.ibm.com Cc: peterz@infradead.org Cc: rostedt@goodmis.org Cc: Valdis.Kletnieks@vt.edu Cc: dhowells@redhat.com LKML-Reference: <1267135607-7056-2-git-send-email-paulmck@linux.vnet.ibm.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2010-01-13rcu: Add force_quiescent_state() testing to rcutorturePaul E. McKenney
Add force_quiescent_state() testing to rcutorture, with a separate thread that repeatedly invokes force_quiescent_state() in bursts. This can greatly increase the probability of encountering certain types of race conditions. Suggested-by: Josh Triplett <josh@joshtriplett.org> Signed-off-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Cc: laijs@cn.fujitsu.com Cc: dipankar@in.ibm.com Cc: mathieu.desnoyers@polymtl.ca Cc: josh@joshtriplett.org Cc: dvhltc@us.ibm.com Cc: niv@us.ibm.com Cc: peterz@infradead.org Cc: rostedt@goodmis.org Cc: Valdis.Kletnieks@vt.edu Cc: dhowells@redhat.com LKML-Reference: <1262646551116-git-send-email-> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-12-17sched: Teach might_sleep() about preemptible RCUFrederic Weisbecker
In practice, it is harmless to voluntarily sleep in a rcu_read_lock() section if we are running under preempt rcu, but it is illegal if we build a kernel running non-preemptable rcu. Currently, might_sleep() doesn't notice sleepable operations under rcu_read_lock() sections if we are running under preemptable rcu because preempt_count() is left untouched after rcu_read_lock() in this case. But we want developers who test their changes under such config to notice the "sleeping while atomic" issues. So we add rcu_read_lock_nesting to prempt_count() in might_sleep() checks. [ v2: Handle rcu-tiny ] Signed-off-by: Frederic Weisbecker <fweisbec@gmail.com> Reviewed-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Cc: Peter Zijlstra <peterz@infradead.org> LKML-Reference: <1260991265-8451-1-git-send-regression-fweisbec@gmail.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-11-22rcu: Re-arrange code to reduce #ifdef painPaul E. McKenney
Remove #ifdefs from kernel/rcupdate.c and include/linux/rcupdate.h by moving code to include/linux/rcutiny.h, include/linux/rcutree.h, and kernel/rcutree.c. Also remove some definitions that are no longer used. Signed-off-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Cc: laijs@cn.fujitsu.com Cc: dipankar@in.ibm.com Cc: mathieu.desnoyers@polymtl.ca Cc: josh@joshtriplett.org Cc: dvhltc@us.ibm.com Cc: niv@us.ibm.com Cc: peterz@infradead.org Cc: rostedt@goodmis.org Cc: Valdis.Kletnieks@vt.edu Cc: dhowells@redhat.com LKML-Reference: <1258908830885-git-send-email-> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-11-22rcu: Eliminate unneeded function wrappingPaul E. McKenney
The functions rcu_init() is a wrapper for __rcu_init(), and also sets up the CPU-hotplug notifier for rcu_barrier_cpu_hotplug(). But TINY_RCU doesn't need CPU-hotplug notification, and the rcu_barrier_cpu_hotplug() is a simple wrapper for rcu_cpu_notify(). So push rcu_init() out to kernel/rcutree.c and kernel/rcutiny.c and get rid of the wrapper function rcu_barrier_cpu_hotplug(). Signed-off-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Cc: laijs@cn.fujitsu.com Cc: dipankar@in.ibm.com Cc: mathieu.desnoyers@polymtl.ca Cc: josh@joshtriplett.org Cc: dvhltc@us.ibm.com Cc: niv@us.ibm.com Cc: peterz@infradead.org Cc: rostedt@goodmis.org Cc: Valdis.Kletnieks@vt.edu Cc: dhowells@redhat.com LKML-Reference: <12589088302320-git-send-email-> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-10-26rcu: Do tiny cleanups in rcutinyIngo Molnar
No change in functionality - just straighten out a few small stylistic details. Cc: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Cc: David Howells <dhowells@redhat.com> Cc: Josh Triplett <josh@joshtriplett.org> Cc: laijs@cn.fujitsu.com Cc: dipankar@in.ibm.com Cc: mathieu.desnoyers@polymtl.ca Cc: dvhltc@us.ibm.com Cc: niv@us.ibm.com Cc: peterz@infradead.org Cc: rostedt@goodmis.org Cc: Valdis.Kletnieks@vt.edu Cc: avi@redhat.com Cc: mtosatti@redhat.com LKML-Reference: <12565226351355-git-send-email-> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-10-26rcu: "Tiny RCU", The Bloatwatch EditionPaul E. McKenney
This patch is a version of RCU designed for !SMP provided for a small-footprint RCU implementation. In particular, the implementation of synchronize_rcu() is extremely lightweight and high performance. It passes rcutorture testing in each of the four relevant configurations (combinations of NO_HZ and PREEMPT) on x86. This saves about 1K bytes compared to old Classic RCU (which is no longer in mainline), and more than three kilobytes compared to Hierarchical RCU (updated to 2.6.30): CONFIG_TREE_RCU: text data bss dec filename 183 4 0 187 kernel/rcupdate.o 2783 520 36 3339 kernel/rcutree.o 3526 Total (vs 4565 for v7) CONFIG_TREE_PREEMPT_RCU: text data bss dec filename 263 4 0 267 kernel/rcupdate.o 4594 776 52 5422 kernel/rcutree.o 5689 Total (6155 for v7) CONFIG_TINY_RCU: text data bss dec filename 96 4 0 100 kernel/rcupdate.o 734 24 0 758 kernel/rcutiny.o 858 Total (vs 848 for v7) The above is for x86. Your mileage may vary on other platforms. Further compression is possible, but is being procrastinated. Changes from v7 (http://lkml.org/lkml/2009/10/9/388) o Apply Lai Jiangshan's review comments (aside from might_sleep() in synchronize_sched(), which is covered by SMP builds). o Fix up expedited primitives. Changes from v6 (http://lkml.org/lkml/2009/9/23/293). o Forward ported to put it into the 2.6.33 stream. o Added lockdep support. o Make lightweight rcu_barrier. Changes from v5 (http://lkml.org/lkml/2009/6/23/12). o Ported to latest pre-2.6.32 merge window kernel. - Renamed rcu_qsctr_inc() to rcu_sched_qs(). - Renamed rcu_bh_qsctr_inc() to rcu_bh_qs(). - Provided trivial rcu_cpu_notify(). - Provided trivial exit_rcu(). - Provided trivial rcu_needs_cpu(). - Fixed up the rcu_*_enter/exit() functions in linux/hardirq.h. o Removed the dependence on EMBEDDED, with a view to making TINY_RCU default for !SMP at some time in the future. o Added (trivial) support for expedited grace periods. Changes from v4 (http://lkml.org/lkml/2009/5/2/91) include: o Squeeze the size down a bit further by removing the ->completed field from struct rcu_ctrlblk. o This permits synchronize_rcu() to become the empty function. Previous concerns about rcutorture were unfounded, as rcutorture correctly handles a constant value from rcu_batches_completed() and rcu_batches_completed_bh(). Changes from v3 (http://lkml.org/lkml/2009/3/29/221) include: o Changed rcu_batches_completed(), rcu_batches_completed_bh() rcu_enter_nohz(), rcu_exit_nohz(), rcu_nmi_enter(), and rcu_nmi_exit(), to be static inlines, as suggested by David Howells. Doing this saves about 100 bytes from rcutiny.o. (The numbers between v3 and this v4 of the patch are not directly comparable, since they are against different versions of Linux.) Changes from v2 (http://lkml.org/lkml/2009/2/3/333) include: o Fix whitespace issues. o Change short-circuit "||" operator to instead be "+" in order to fix performance bug noted by "kraai" on LWN. (http://lwn.net/Articles/324348/) Changes from v1 (http://lkml.org/lkml/2009/1/13/440) include: o This version depends on EMBEDDED as well as !SMP, as suggested by Ingo. o Updated rcu_needs_cpu() to unconditionally return zero, permitting the CPU to enter dynticks-idle mode at any time. This works because callbacks can be invoked upon entry to dynticks-idle mode. o Paul is now OK with this being included, based on a poll at the Kernel Miniconf at linux.conf.au, where about ten people said that they cared about saving 900 bytes on single-CPU systems. o Applies to both mainline and tip/core/rcu. Signed-off-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Acked-by: David Howells <dhowells@redhat.com> Acked-by: Josh Triplett <josh@joshtriplett.org> Reviewed-by: Lai Jiangshan <laijs@cn.fujitsu.com> Cc: dipankar@in.ibm.com Cc: mathieu.desnoyers@polymtl.ca Cc: dvhltc@us.ibm.com Cc: niv@us.ibm.com Cc: peterz@infradead.org Cc: rostedt@goodmis.org Cc: Valdis.Kletnieks@vt.edu Cc: avi@redhat.com Cc: mtosatti@redhat.com LKML-Reference: <12565226351355-git-send-email-> Signed-off-by: Ingo Molnar <mingo@elte.hu>
