path: root/include/linux/radix-tree.h
2007-10-16radix-tree: use indirect bitNick Piggin
Rather than sign direct radix-tree pointers with a special bit, sign the indirect one that hangs off the root. This means that, given a lookup_slot operation, the invalid result will be differentiated from the valid (previously, valid results could have the bit either set or clear). This does not affect slot lookups which occur under lock -- they can never return an invalid result. Is needed in future for lockless pagecache. Signed-off-by: Nick Piggin <npiggin@suse.de> Acked-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Hugh Dickins <hugh@veritas.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-16radixtree: introduce radix_tree_next_hole()Fengguang Wu
Introduce radix_tree_next_hole(root, index, max_scan) to scan radix tree for the first hole. It will be used in interleaved readahead. The implementation is dumb and obviously correct. It can help debug(and document) the possible smart one in future. Cc: Nick Piggin <nickpiggin@yahoo.com.au> Signed-off-by: Fengguang Wu <wfg@mail.ustc.edu.cn> Cc: Rusty Russell <rusty@rustcorp.com.au> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-09Fix occurrences of "the the "Michael Opdenacker
Signed-off-by: Michael Opdenacker <michael@free-electrons.com> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2006-12-07[PATCH] radix-tree: RCU lockless readsideNick Piggin
Make radix tree lookups safe to be performed without locks. Readers are protected against nodes being deleted by using RCU based freeing. Readers are protected against new node insertion by using memory barriers to ensure the node itself will be properly written before it is visible in the radix tree. Each radix tree node keeps a record of their height (above leaf nodes). This height does not change after insertion -- when the radix tree is extended, higher nodes are only inserted in the top. So a lookup can take the pointer to what is *now* the root node, and traverse down it even if the tree is concurrently extended and this node becomes a subtree of a new root. "Direct" pointers (tree height of 0, where root->rnode points directly to the data item) are handled by using the low bit of the pointer to signal whether rnode is a direct pointer or a pointer to a radix tree node. When a reader wants to traverse the next branch, they will take a copy of the pointer. This pointer will be either NULL (and the branch is empty) or non-NULL (and will point to a valid node). [akpm@osdl.org: cleanups] [Lee.Schermerhorn@hp.com: bugfixes, comments, simplifications] [clameter@sgi.com: build fix] Signed-off-by: Nick Piggin <npiggin@suse.de> Cc: "Paul E. McKenney" <paulmck@us.ibm.com> Signed-off-by: Lee Schermerhorn <lee.schermerhorn@hp.com> Cc: Christoph Lameter <clameter@engr.sgi.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-04[PATCH] severing fs.h, radix-tree.h -> sched.hAl Viro
2006-06-23[PATCH] radix-tree: direct dataNick Piggin
The ability to have height 0 radix trees (a direct pointer to the data item rather than going through a full node->slot) quietly disappeared with old-2.6-bkcvs commit ffee171812d51652f9ba284302d9e5c5cc14bdfd. On 64-bit machines this causes nearly 600 bytes to be used for every <= 4K file in pagecache. Re-introduce this feature, root tags stored in spare ->gfp_mask bits. Simplify radix_tree_delete's complex tag clearing arrangement (which would become even more complex) by just falling back to tag clearing functions (the pagecache radix-tree never uses this path anyway, so the icache savings will mean it's actually a speedup). On my 4GB G5, this saves 8MB RAM per kernel kernel source+object tree in pagecache. Pagecache lookup, insertion, and removal speed for small files will also be improved. This makes RCU radix tree harder, but it's worth it. Signed-off-by: Nick Piggin <npiggin@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-25[PATCH] radix-tree documentation cleanupsJonathan Corbet
Documentation changes to help radix tree users avoid overrunning the tags array. RADIX_TREE_TAGS moves to linux/radix-tree.h and is now known as RADIX_TREE_MAX_TAGS (Nick Piggin's idea). Tag parameters are changed to unsigned, and some comments are updated. Signed-off-by: Jonathan Corbet <corbet@lwn.net> Cc: Nick Piggin <nickpiggin@yahoo.com.au> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-08[PATCH] rcu file: use atomic primitivesNick Piggin
Use atomic_inc_not_zero for rcu files instead of special case rcuref. Signed-off-by: Nick Piggin <npiggin@suse.de> Cc: "Paul E. McKenney" <paulmck@us.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-07[PATCH] reiser4: add radix_tree_lookup_slot()Hans Reiser
Reiser4 uses radix trees to solve a trouble reiser4_readdir has serving nfs requests. Unfortunately, radix tree api lacks an operation suitable for modifying existing entry. This patch adds radix_tree_lookup_slot which returns pointer to found item within the tree. That location can be then updated. Both Nick and Christoph Lameter have patches which need this as well. Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-10-28[PATCH] gfp_t: lib/*Al Viro
2005-10-08[PATCH] gfp flags annotations - part 1Al Viro
- added typedef unsigned int __nocast gfp_t; - replaced __nocast uses for gfp flags with gfp_t - it gives exactly the same warnings as far as sparse is concerned, doesn't change generated code (from gcc point of view we replaced unsigned int with typedef) and documents what's going on far better. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-10[PATCH] lib/radix-tree: Fix "nocast type" warningsVictor Fusco
Fix the sparse warning "implicit cast to nocast type" Signed-off-by: Victor Fusco <victor@cetuc.puc-rio.br> Signed-off-by: Domen Puncer <domen@coderock.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
