git://git.kernel.org/pub/scm/linux/kernel/git/viro/signal
Pull signal handling cleanups from Al Viro:
"sigaltstack infrastructure + conversion for x86, alpha and um,
COMPAT_SYSCALL_DEFINE infrastructure.
Note that there are several conflicts between "unify
SS_ONSTACK/SS_DISABLE definitions" and UAPI patches in mainline;
resolution is trivial - just remove definitions of SS_ONSTACK and
SS_DISABLED from arch/*/uapi/asm/signal.h; they are all identical and
include/uapi/linux/signal.h contains the unified variant."
Fixed up conflicts as per Al.
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/signal:
alpha: switch to generic sigaltstack
new helpers: __save_altstack/__compat_save_altstack, switch x86 and um to those
generic compat_sys_sigaltstack()
introduce generic sys_sigaltstack(), switch x86 and um to it
new helper: compat_user_stack_pointer()
new helper: restore_altstack()
unify SS_ONSTACK/SS_DISABLE definitions
new helper: current_user_stack_pointer()
missing user_stack_pointer() instances
Bury the conditionals from kernel_thread/kernel_execve series
COMPAT_SYSCALL_DEFINE: infrastructure
Cross-architecture equivalent of rdusp(); default is
user_stack_pointer(current_pt_regs()) - that works for almost all
platforms that have usp saved in pt_regs. The only exception from
that is ia64 - we want memory stack, not the backing store for
register one.
Ptrace jailers want to be sure that the tracee can never escape
from the control. However if the tracer dies unexpectedly the
tracee continues to run in potentially unsafe mode.
Add the new ptrace option PTRACE_O_EXITKILL. If the tracer exits
it sends SIGKILL to every tracee which has this bit set.
Note that the new option is not equal to the last-option << 1. Because
currently all options have an event, and the new one starts the eventless
group. It uses the random 20 bit, so we have the room for 12 more events,
but we can also add the new eventless options below this one.
Suggested by Amnon Shiloh.
Tested-by: Amnon Shiloh <u3557@miso.sublimeip.com>
Cc: Denys Vlasenko <dvlasenk@redhat.com>
Cc: Michael Kerrisk <mtk.manpages@gmail.com>
Cc: Serge Hallyn <serge.hallyn@canonical.com>
Cc: Chris Evans <scarybeasts@gmail.com>
Cc: "Eric W. Biederman" <ebiederm@xmission.com>
the first one is equal to signal_pt_regs(), the second is never used
(and always NULL, while we are at it).
Always equal to task_pt_regs(current); defined only when we are in
signal delivery. It may be different from current_pt_regs() - e.g.
architectures like m68k may have pt_regs location on exception
different from that on a syscall and signals (just as ptrace handling)
may happen on exceptions as well as on syscalls.
When they are equal, it's often better to have signal_pt_regs
defined (in asm/ptrace.h) as current_pt_regs - that tends to be
optimized better than default would be. However, optimisation is
the only reason why we might want an arch-specific definition;
if current_pt_regs() and task_pt_regs(current) have different
values, the latter one is right.
Acked-by: Michael Kerrisk <mtk.manpages@gmail.com>
Acked-by: Dave Jones <davej@redhat.com>
Pull generic execve() changes from Al Viro:
"This introduces the generic kernel_thread() and kernel_execve()
functions, and switches x86, arm, alpha, um and s390 over to them."
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/signal: (26 commits)
s390: convert to generic kernel_execve()
s390: switch to generic kernel_thread()
s390: fold kernel_thread_helper() into ret_from_fork()
s390: fold execve_tail() into start_thread(), convert to generic sys_execve()
um: switch to generic kernel_thread()
x86, um/x86: switch to generic sys_execve and kernel_execve
x86: split ret_from_fork
alpha: introduce ret_from_kernel_execve(), switch to generic kernel_execve()
alpha: switch to generic kernel_thread()
alpha: switch to generic sys_execve()
arm: get rid of execve wrapper, switch to generic execve() implementation
arm: optimized current_pt_regs()
arm: introduce ret_from_kernel_execve(), switch to generic kernel_execve()
arm: split ret_from_fork, simplify kernel_thread() [based on patch by rmk]
new helper: current_pt_regs()
preparation for generic kernel_thread()
um: kill thread->forking
um: let signal_delivered() do SIGTRAP on singlestepping into handler
Normally (and that's the default) it's just task_pt_regs(current).
However, if an architecture can optimize that, it can do so by
making a macro of its own available from asm/ptrace.h. More
importantly, some architectures have task_pt_regs() working only
for traced tasks blocked on signal delivery. current_pt_regs()
needs to work for *all* processes, so before those architectures
start using stuff relying on current_pt_regs() they'll need a
properly working variant.
__ptrace_may_access() is used within only kernel/ptrace.c.
Signed-off-by: James Morris <james.l.morris@oracle.com>
This change adds support for a new ptrace option, PTRACE_O_TRACESECCOMP,
and a new return value for seccomp BPF programs, SECCOMP_RET_TRACE.
When a tracer specifies the PTRACE_O_TRACESECCOMP ptrace option, the
tracer will be notified, via PTRACE_EVENT_SECCOMP, for any syscall that
results in a BPF program returning SECCOMP_RET_TRACE. The 16-bit
SECCOMP_RET_DATA mask of the BPF program return value will be passed as
the ptrace_message and may be retrieved using PTRACE_GETEVENTMSG.
If the subordinate process is not using seccomp filter, then no
system call notifications will occur even if the option is specified.
If there is no tracer with PTRACE_O_TRACESECCOMP when SECCOMP_RET_TRACE
is returned, the system call will not be executed and an -ENOSYS errno
will be returned to userspace.
This change adds a dependency on the system call slow path. Any future
efforts to use the system call fast path for seccomp filter will need to
address this restriction.
Signed-off-by: Will Drewry <wad@chromium.org>
Acked-by: Eric Paris <eparis@redhat.com>
v18: - rebase
- comment fatal_signal check
- acked-by
- drop secure_computing_int comment
v17: - ...
v16: - update PT_TRACE_MASK to 0xbf4 so that STOP isn't clear on SETOPTIONS call (indan@nul.nu)
[note PT_TRACE_MASK disappears in linux-next]
v15: - add audit support for non-zero return codes
- clean up style (indan@nul.nu)
v14: - rebase/nochanges
v13: - rebase on to 88ebdda6159ffc15699f204c33feb3e431bf9bdc
(Brings back a change to ptrace.c and the masks.)
v12: - rebase to linux-next
- use ptrace_event and update arch/Kconfig to mention slow-path dependency
- drop all tracehook changes and inclusion (oleg@redhat.com)
v11: - invert the logic to just make it a PTRACE_SYSCALL accelerator
(indan@nul.nu)
v10: - moved to PTRACE_O_SECCOMP / PT_TRACE_SECCOMP
v9: - n/a
v8: - guarded PTRACE_SECCOMP use with an ifdef
v7: - introduced
git://git.kernel.org/pub/scm/linux/kernel/git/paulg/linux
Pull <linux/bug.h> cleanup from Paul Gortmaker:
"The changes shown here are to unify linux's BUG support under the one
<linux/bug.h> file. Due to historical reasons, we have some BUG code
in bug.h and some in kernel.h -- i.e. the support for BUILD_BUG in
linux/kernel.h predates the addition of linux/bug.h, but old code in
kernel.h wasn't moved to bug.h at that time. As a band-aid, kernel.h
was including <asm/bug.h> to pseudo link them.
This has caused confusion[1] and general yuck/WTF[2] reactions. Here
is an example that violates the principle of least surprise:
CC lib/string.o
lib/string.c: In function 'strlcat':
lib/string.c:225:2: error: implicit declaration of function 'BUILD_BUG_ON'
make[2]: *** [lib/string.o] Error 1
$ grep linux/bug.h lib/string.c
#include <linux/bug.h>
We've included <linux/bug.h> for the BUG infrastructure and yet we
still get a compile fail! [We've not kernel.h for BUILD_BUG_ON.] Ugh -
very confusing for someone who is new to kernel development.
With the above in mind, the goals of this changeset are:
1) find and fix any include/*.h files that were relying on the
implicit presence of BUG code.
2) find and fix any C files that were consuming kernel.h and hence
relying on implicitly getting some/all BUG code.
3) Move the BUG related code living in kernel.h to <linux/bug.h>
4) remove the asm/bug.h from kernel.h to finally break the chain.
During development, the order was more like 3-4, build-test, 1-2. But
to ensure that git history for bisect doesn't get needless build
failures introduced, the commits have been reorderd to fix the problem
areas in advance.
[1] https://lkml.org/lkml/2012/1/3/90
[2] https://lkml.org/lkml/2012/1/17/414"
Fix up conflicts (new radeon file, reiserfs header cleanups) as per Paul
and linux-next.
* tag 'bug-for-3.4' of git://git.kernel.org/pub/scm/linux/kernel/git/paulg/linux:
kernel.h: doesn't explicitly use bug.h, so don't include it.
bug: consolidate BUILD_BUG_ON with other bug code
BUG: headers with BUG/BUG_ON etc. need linux/bug.h
bug.h: add include of it to various implicit C users
lib: fix implicit users of kernel.h for TAINT_WARN
spinlock: macroize assert_spin_locked to avoid bug.h dependency
x86: relocate get/set debugreg fcns to include/asm/debugreg.
PTRACE_SEIZE code is tested and ready for production use, remove the
code which requires special bit in data argument to make PTRACE_SEIZE
work.
Strace team prepares for a new release of strace, and we would like to
ship the code which uses PTRACE_SEIZE, preferably after this change goes
into released kernel.
Signed-off-by: Denys Vlasenko <vda.linux@googlemail.com>
Acked-by: Tejun Heo <tj@kernel.org>
Acked-by: Oleg Nesterov <oleg@redhat.com>
Cc: Pedro Alves <palves@redhat.com>
Cc: Jan Kratochvil <jan.kratochvil@redhat.com>
match
PTRACE_EVENT_foo and PTRACE_O_TRACEfoo used to match.
New PTRACE_EVENT_STOP is the first event which has no corresponding
PTRACE_O_TRACE option. If we will ever want to add another such option,
its PTRACE_EVENT's value will collide with PTRACE_EVENT_STOP's value.
This patch changes PTRACE_EVENT_STOP value to prevent this.
While at it, added a comment - the one atop PTRACE_EVENT block, saying
"Wait extended result codes for the above trace options", is not true
for PTRACE_EVENT_STOP.
Cc: Tejun Heo <tj@kernel.org>
Reviewed-by: Oleg Nesterov <oleg@redhat.com>
Exchange PT_TRACESYSGOOD and PT_PTRACE_CAP bit positions, which makes
PT_option bits contiguous and therefore makes code in
ptrace_setoptions() much simpler.
Every PTRACE_O_TRACEevent is defined to (1 << PTRACE_EVENT_event)
instead of using explicit numeric constants, to ensure we don't mess up
relationship between bit positions and event ids.
PT_EVENT_FLAG_SHIFT was not particularly useful, PT_OPT_FLAG_SHIFT with
value of PT_EVENT_FLAG_SHIFT-1 is easier to use.
PT_TRACE_MASK constant is nuked, the only its use is replaced by
(PTRACE_O_MASK << PT_OPT_FLAG_SHIFT).
ptrace_event(PTRACE_EVENT_EXEC) sends SIGTRAP if PT_TRACE_EXEC is not
set. This is because this SIGTRAP predates PTRACE_O_TRACEEXEC option,
we do not need/want this with PT_SEIZED which can set the options during
attach.
Suggested-by: Pedro Alves <palves@redhat.com>
Cc: Indan Zupancic <indan@nul.nu>
Cc: Denys Vlasenko <vda.linux@googlemail.com>
If a header file is making use of BUG, BUG_ON, BUILD_BUG_ON, or any
other BUG variant in a static inline (i.e. not in a #define) then
that header really should be including <linux/bug.h> and not just
expecting it to be implicitly present.
We can make this change risk-free, since if the files using these
headers didn't have exposure to linux/bug.h already, they would have
been causing compile failures/warnings.
git://git.kernel.org/pub/scm/linux/kernel/git/viro/audit
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/audit: (29 commits)
audit: no leading space in audit_log_d_path prefix
audit: treat s_id as an untrusted string
audit: fix signedness bug in audit_log_execve_info()
audit: comparison on interprocess fields
audit: implement all object interfield comparisons
audit: allow interfield comparison between gid and ogid
audit: complex interfield comparison helper
audit: allow interfield comparison in audit rules
Kernel: Audit Support For The ARM Platform
audit: do not call audit_getname on error
audit: only allow tasks to set their loginuid if it is -1
audit: remove task argument to audit_set_loginuid
audit: allow audit matching on inode gid
audit: allow matching on obj_uid
audit: remove audit_finish_fork as it can't be called
audit: reject entry,always rules
audit: inline audit_free to simplify the look of generic code
audit: drop audit_set_macxattr as it doesn't do anything
audit: inline checks for not needing to collect aux records
audit: drop some potentially inadvisable likely notations
Use evil merge to fix up grammar mistakes in Kconfig file.
Bad speling and horrible grammar (and copious swearing) is to be
expected, but let's keep it to commit messages and comments, rather than
expose it to users in config help texts or printouts.
The audit system previously expected arches calling to audit_syscall_exit to
supply as arguments if the syscall was a success and what the return code was.
Audit also provides a helper AUDITSC_RESULT which was supposed to simplify things
by converting from negative retcodes to an audit internal magic value stating
success or failure. This helper was wrong and could indicate that a valid
pointer returned to userspace was a failed syscall. The fix is to fix the
layering foolishness. We now pass audit_syscall_exit a struct pt_reg and it
in turns calls back into arch code to collect the return value and to
determine if the syscall was a success or failure. We also define a generic
is_syscall_success() macro which determines success/failure based on if the
value is < -MAX_ERRNO. This works for arches like x86 which do not use a
separate mechanism to indicate syscall failure.
We make both the is_syscall_success() and regs_return_value() static inlines
instead of macros. The reason is because the audit function must take a void*
for the regs. (uml calls theirs struct uml_pt_regs instead of just struct
pt_regs so audit_syscall_exit can't take a struct pt_regs). Since the audit
function takes a void* we need to use static inlines to cast it back to the
arch correct structure to dereference it.
The other major change is that on some arches, like ia64, MIPS and ppc, we
change regs_return_value() to give us the negative value on syscall failure.
THE only other user of this macro, kretprobe_example.c, won't notice and it
makes the value signed consistently for the audit functions across all archs.
In arch/sh/kernel/ptrace_64.c I see that we were using regs[9] in the old
audit code as the return value. But the ptrace_64.h code defined the macro
regs_return_value() as regs[3]. I have no idea which one is correct, but this
patch now uses the regs_return_value() function, so it now uses regs[3].
For powerpc we previously used regs->result but now use the
regs_return_value() function which uses regs->gprs[3]. regs->gprs[3] is
always positive so the regs_return_value(), much like ia64 makes it negative
before calling the audit code when appropriate.
Signed-off-by: Eric Paris <eparis@redhat.com>
Acked-by: H. Peter Anvin <hpa@zytor.com> [for x86 portion]
Acked-by: Tony Luck <tony.luck@intel.com> [for ia64]
Acked-by: Richard Weinberger <richard@nod.at> [for uml]
Acked-by: David S. Miller <davem@davemloft.net> [for sparc]
Acked-by: Ralf Baechle <ralf@linux-mips.org> [for mips]
Acked-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> [for ppc]
Reading /proc/pid/stat of another process checks if one has ptrace permissions
on that process. If one does have permissions it outputs some data about the
process which might have security and attack implications. If the current
task does not have ptrace permissions the read still works, but those fields
are filled with inocuous (0) values. Since this check and a subsequent denial
is not a violation of the security policy we should not audit such denials.
This can be quite useful to removing ptrace broadly across a system without
flooding the logs when ps is run or something which harmlessly walks proc.
Acked-by: Serge E. Hallyn <serge.hallyn@canonical.com>
The fake SIGSTOP during attach has numerous problems. PTRACE_SEIZE
is already fine, but we have basically the same problems is SIGSTOP
is sent on auto-attach, the tracer can't know if this signal signal
should be cancelled or not.
Change ptrace_event() to set JOBCTL_TRAP_STOP if the new child is
PT_SEIZED, this triggers the PTRACE_EVENT_STOP report.
Thereafter a PT_SEIZED task can never report the bogus SIGSTOP.
Test-case:
#define PTRACE_SEIZE 0x4206
#define PTRACE_SEIZE_DEVEL 0x80000000
#define PTRACE_EVENT_STOP 7
#define WEVENT(s) ((s & 0xFF0000) >> 16)
int main(void)
int child, grand_child, status;
long message;
child = fork();
if (!child) {
kill(getpid(), SIGSTOP);
fork();
assert(0);
return 0x23;
assert(ptrace(PTRACE_SEIZE, child, 0,PTRACE_SEIZE_DEVEL) == 0);
assert(wait(&status) == child);
assert(WIFSTOPPED(status) && WSTOPSIG(status) == SIGSTOP);
assert(ptrace(PTRACE_SETOPTIONS, child, 0, PTRACE_O_TRACEFORK) == 0);
assert(ptrace(PTRACE_CONT, child, 0,0) == 0);
assert(waitpid(child, &status, 0) == child);
assert(WIFSTOPPED(status) && WSTOPSIG(status) == SIGTRAP);
assert(WEVENT(status) == PTRACE_EVENT_FORK);
assert(ptrace(PTRACE_GETEVENTMSG, child, 0, &message) == 0);
grand_child = message;
assert(waitpid(grand_child, &status, 0) == grand_child);
assert(WEVENT(status) == PTRACE_EVENT_STOP);
kill(child, SIGKILL);
kill(grand_child, SIGKILL);
return 0;
If the new child is traced, do_fork() adds the pending SIGSTOP.
It assumes that either it is traced because of auto-attach or the
tracer attached later, in both cases sigaddset/set_thread_flag is
correct even if SIGSTOP is already pending.
Now that we have PTRACE_SEIZE this is no longer right in the latter
case. If the tracer does PTRACE_SEIZE after copy_process() makes the
child visible the queued SIGSTOP is wrong.
We could check PT_SEIZED bit and change ptrace_attach() to set both
PT_PTRACED and PT_SEIZED bits simultaneously but see the next patch,
we need to know whether this child was auto-attached or not anyway.
So this patch simply moves this code to ptrace_init_task(), this
way we can never race with ptrace_attach().
new_child->jobctl is not initialized during the fork, it is copied
from parent->jobctl. Currently this is harmless, the forking task
is running and copy_process() can't succeed if signal_pending() is
true, so only JOBCTL_STOP_DEQUEUED can be copied. Still this is a
bit fragile, it would be more clean to set ->jobctl = 0 explicitly.
Also, check ->ptrace != 0 instead of PT_PTRACED, move the
CONFIG_HAVE_HW_BREAKPOINT code up.
ptrace_reparented() naively does parent != real_parent, this means
it returns true even if the tracer _is_ the real parent. This is per
process thing, not per-thread. The only reason ->real_parent can
point to the non-leader thread is that we have __WNOTHREAD.
Change it to check !same_thread_group(parent, real_parent).
It has two callers, and in both cases the current check does not
look right.
exit_notify: we should respect ->exit_signal if the exiting leader
is traced by any thread from the parent thread group. It is the
child of the whole group, and we are going to send the signal to
the whole group.
wait_task_zombie: without __WNOTHREAD do_wait() should do the same
for any thread, only sys_ptrace() is "bound" to the single thread.
However do_wait(WEXITED) succeeds but does not release a traced
natural child unless the caller is the tracer.
Test-case:
void *tfunc(void *arg)
assert(ptrace(PTRACE_ATTACH, (long)arg, 0,0) == 0);
pause();
return NULL;
int main(void)
pthread_t thr;
pid_t pid, stat, ret;
pid = fork();
if (!pid) {
pause();
assert(0);
assert(pthread_create(&thr, NULL, tfunc, (void*)(long)pid) == 0);
assert(waitpid(-1, &stat, 0) == pid);
assert(WIFSTOPPED(stat));
kill(pid, SIGKILL);
assert(WIFSIGNALED(stat) && WTERMSIG(stat) == SIGKILL);
ret = waitpid(pid, &stat, 0);
if (ret < 0)
return 0;
printf("WTF? %d is dead, but: wait=%d stat=%x\n",
pid, ret, stat);
return 1;
Note that the main thread simply does
pid = fork();
kill(pid, SIGKILL);
and then without the patch wait4(WEXITED) succeeds twice and reports
WTERMSIG(stat) == SIGKILL.
tracehook.h is on the way out. Rename tracehook_tracer_task() to
ptrace_parent() and move it from tracehook.h to ptrace.h.
Cc: John Johansen <john.johansen@canonical.com>
Cc: Stephen Smalley <sds@tycho.nsa.gov>
Move SIGTRAP on exec(2) logic from tracehook_report_exec() to
ptrace_event(). This is part of changes to make ptrace_event()
smarter and handle ptrace event related details in one place.
This doesn't introduce any behavior change.
tracehook_prepare_clone()
This patch implements ptrace_event_enabled() which tests whether a
given PTRACE_EVENT_* is enabled and use it to simplify ptrace_event()
and tracehook_prepare_clone().
PT_EVENT_FLAG() macro is added which calculates PT_TRACE_* flag from
PTRACE_EVENT_*. This is used to define PT_TRACE_* flags and by
ptrace_event_enabled() to find the matching flag.
This is used to make ptrace_event() and tracehook_prepare_clone()
simpler.
* ptrace_event() callers were responsible for providing mask to test
whether the event was enabled. This patch implements
ptrace_event_enabled() and make ptrace_event() drop @mask and
determine whether the event is enabled from @event. Note that
@event is constant and this conversion doesn't add runtime overhead.
All conversions except tracehook_report_clone_complete() are
trivial. tracehook_report_clone_complete() used to use 0 for @mask
(always enabled) but now tests whether the specified event is
enabled. This doesn't cause any behavior difference as it's
guaranteed that the event specified by @trace is enabled.
* tracehook_prepare_clone() now only determines which event is
applicable and use ptrace_event_enabled() for enable test.
task_ptrace(task) simply dereferences task->ptrace and isn't even used
consistently only adding confusion. Kill it and directly access
->ptrace instead.
The previous patch implemented async notification for ptrace but it
only worked while trace is running. This patch introduces
PTRACE_LISTEN which is suggested by Oleg Nestrov.
It's allowed iff tracee is in STOP trap and puts tracee into
quasi-running state - tracee never really runs but wait(2) and
ptrace(2) consider it to be running. While ptracer is listening,
tracee is allowed to re-enter STOP to notify an async event.
Listening state is cleared on the first notification. Ptracer can
also clear it by issuing INTERRUPT - tracee will re-trap into STOP
with listening state cleared.
This allows ptracer to monitor group stop state without running tracee
- use INTERRUPT to put tracee into STOP trap, issue LISTEN and then
wait(2) to wait for the next group stop event. When it happens,
PTRACE_GETSIGINFO provides information to determine the current state.
Test program follows.
#define PTRACE_INTERRUPT 0x4207
#define PTRACE_LISTEN 0x4208
static const struct timespec ts1s = { .tv_sec = 1 };
int main(int argc, char **argv)
pid_t tracee, tracer;
int i;
tracee = fork();
if (!tracee)
while (1)
pause();
tracer = fork();
if (!tracer) {
siginfo_t si;
ptrace(PTRACE_SEIZE, tracee, NULL,
(void *)(unsigned long)PTRACE_SEIZE_DEVEL);
ptrace(PTRACE_INTERRUPT, tracee, NULL, NULL);
repeat:
waitid(P_PID, tracee, NULL, WSTOPPED);
ptrace(PTRACE_GETSIGINFO, tracee, NULL, &si);
if (!si.si_code) {
printf("tracer: SIG %d\n", si.si_signo);
ptrace(PTRACE_CONT, tracee, NULL,
(void *)(unsigned long)si.si_signo);
goto repeat;
printf("tracer: stopped=%d signo=%d\n",
si.si_signo != SIGTRAP, si.si_signo);
if (si.si_signo != SIGTRAP)
ptrace(PTRACE_LISTEN, tracee, NULL, NULL);
else
ptrace(PTRACE_CONT, tracee, NULL, NULL);
goto repeat;
for (i = 0; i < 3; i++) {
nanosleep(&ts1s, NULL);
printf("mother: SIGSTOP\n");
kill(tracee, SIGSTOP);
printf("mother: SIGCONT\n");
kill(tracee, SIGCONT);
kill(tracer, SIGKILL);
kill(tracee, SIGKILL);
return 0;
This is identical to the program to test TRAP_NOTIFY except that
tracee is PTRACE_LISTEN'd instead of PTRACE_CONT'd when group stopped.
This allows ptracer to monitor when group stop ends without running
tracee.
# ./test-listen
tracer: stopped=0 signo=5
mother: SIGSTOP
tracer: SIG 19
tracer: stopped=1 signo=19
mother: SIGCONT
tracer: SIG 18
mother: SIGSTOP
tracer: SIG 19
mother: SIGCONT
tracer: SIG 18
mother: SIGSTOP
tracer: SIG 19
mother: SIGCONT
tracer: SIG 18
-v2: Moved JOBCTL_LISTENING check in wait_task_stopped() into
task_stopped_code() as suggested by Oleg.
Currently, there's no way to trap a running ptracee short of sending a
signal which has various side effects. This patch implements
PTRACE_INTERRUPT which traps ptracee without any signal or job control
related side effect.
The implementation is almost trivial. It uses the group stop trap -
SIGTRAP | PTRACE_EVENT_STOP << 8. A new trap flag
JOBCTL_TRAP_INTERRUPT is added, which is set on PTRACE_INTERRUPT and
cleared when any trap happens. As INTERRUPT should be useable
regardless of the current state of tracee, task_is_traced() test in
ptrace_check_attach() is skipped for INTERRUPT.
PTRACE_INTERRUPT is available iff tracee is attached with
PTRACE_SEIZE.
static const struct timespec ts100ms = { .tv_nsec = 100000000 };
static const struct timespec ts3s = { .tv_sec = 3 };
pid_t tracee;
tracee = fork();
if (tracee == 0) {
nanosleep(&ts100ms, NULL);
while (1) {
printf("tracee: alive pid=%d\n", getpid());
if (argc > 1)
if (argc > 1) {
nanosleep(&ts3s, NULL);
printf("tracer: INTERRUPT and DETACH\n");
ptrace(PTRACE_DETACH, tracee, NULL, NULL);
printf("tracer: exiting\n");
return 0;
When called without argument, tracee is seized from running state,
interrupted and then detached back to running state.
# ./test-interrupt
tracee: alive pid=4546
tracer: exiting
When called with argument, tracee is seized from stopped state,
continued, interrupted and then detached back to stopped state.
# ./test-interrupt 1
tracee: alive pid=4548
tracer: exiting
Before PTRACE_INTERRUPT, once the tracee was running, there was no way
to trap tracee and do PTRACE_DETACH without causing side effect.
-v2: Updated to use task_set_jobctl_pending() so that it doesn't end
up scheduling TRAP_STOP if child is dying which may make the
child unkillable. Spotted by Oleg.
PTRACE_ATTACH implicitly issues SIGSTOP on attach which has side
effects on tracee signal and job control states. This patch
implements a new ptrace request PTRACE_SEIZE which attaches a tracee
without trapping it or affecting its signal and job control states.
The usage is the same with PTRACE_ATTACH but it takes PTRACE_SEIZE_*
flags in @data. Currently, the only defined flag is
PTRACE_SEIZE_DEVEL which is a temporary flag to enable PTRACE_SEIZE.
PTRACE_SEIZE will change ptrace behaviors outside of attach itself.
The changes will be implemented gradually and the DEVEL flag is to
prevent programs which expect full SEIZE behavior from using it before
all the behavior modifications are complete while allowing unit
testing. The flag will be removed once SEIZE behaviors are completely
implemented.
* PTRACE_SEIZE, unlike ATTACH, doesn't force tracee to trap. After
attaching tracee continues to run unless a trap condition occurs.
* PTRACE_SEIZE doesn't affect signal or group stop state.
* If PTRACE_SEIZE'd, group stop uses PTRACE_EVENT_STOP trap which uses
exit_code of (signr | PTRACE_EVENT_STOP << 8) where signr is one of
the stopping signals if group stop is in effect or SIGTRAP
otherwise, and returns usual trap siginfo on PTRACE_GETSIGINFO
instead of NULL.
Seizing sets PT_SEIZED in ->ptrace of the tracee. This flag will be
used to determine whether new SEIZE behaviors should be enabled.
pid_t tracee;
tracee = fork();
if (tracee == 0) {
while (1) {
printf("tracee: alive\n");
if (argc > 1)
if (argc > 1) {
return 0;
When the above program is called w/o argument, tracee is seized while
running and remains running. When tracer exits, tracee continues to
run and print out messages.
# ./test-seize-simple
tracee: alive
tracee: alive
tracee: alive
tracer: exiting
tracee: alive
tracee: alive
When called with an argument, tracee is seized from stopped state and
continued, and returns to stopped state when tracer exits.
# ./test-seize
tracee: alive
tracee: alive
tracee: alive
tracer: exiting
# ps -el|grep test-seize
1 T 0 4720 1 0 80 0 - 941 signal ttyS0 00:00:00 test-seize
-v2: SEIZE doesn't schedule TRAP_STOP and leaves tracee running as Jan
suggested.
-v3: PTRACE_EVENT_STOP traps now report group stop state by signr. If
group stop is in effect the stop signal number is returned as
part of exit_code; otherwise, SIGTRAP. This was suggested by
Denys and Oleg.
PTRACE_INTERRUPT is going to be added which should also skip
task_is_traced() check in ptrace_check_attach(). Rename @kill to
@ignore_state and make it bool. Add function comment while at it.
This patch doesn't introduce any behavior difference.
When a task is traced and is in a stopped state, the tracer
may execute a ptrace request to examine the tracee state and
get its task struct. Right after, the tracee can be killed
and thus its breakpoints released.
This can happen concurrently when the tracer is in the middle
of reading or modifying these breakpoints, leading to dereferencing
a freed pointer.
Hence, to prepare the fix, create a generic breakpoint reference
holding API. When a reference on the breakpoints of a task is
held, the breakpoints won't be released until the last reference
is dropped. After that, no more ptrace request on the task's
breakpoints can be serviced for the tracer.
Reported-by: Oleg Nesterov <oleg@redhat.com>
Cc: Prasad <prasad@linux.vnet.ibm.com>
Cc: v2.6.33.. <stable@kernel.org>
Link: http://lkml.kernel.org/r/1302284067-7860-2-git-send-email-fweisbec@gmail.com
They are only used inside kernel/ptrace.c, and have been for a long
time. We don't want to go back to the bad-old-days when architectures
did things on their own, so make them static and private.
Fix up the arguments to arch_ptrace() to take account of the fact that
@addr and @data are now unsigned long rather than long as of a preceding
patch in this series.
Signed-off-by: Namhyung Kim <namhyung@gmail.com>
Cc: <linux-arch@vger.kernel.org>
Acked-by: Roland McGrath <roland@redhat.com>
Acked-by: Geert Uytterhoeven <geert@linux-m68k.org>
Since userspace API of ptrace syscall defines @addr and @data as void
pointers, it would be more appropriate to define them as unsigned long in
kernel. Therefore related functions are changed also.
'unsigned long' is typically used in other places in kernel as an opaque
data type and that using this helps cleaning up a lot of warnings from
sparse.
Suggested-by: Arnd Bergmann <arnd@arndb.de>
Support for the PMU's BTS features has been upstreamed in
v2.6.32, but we still have the old and disabled ptrace-BTS,
as Linus noticed it not so long ago.
It's buggy: TIF_DEBUGCTLMSR is trampling all over that MSR without
regard for other uses (perf) and doesn't provide the flexibility
needed for perf either.
Its users are ptrace-block-step and ptrace-bts, since ptrace-bts
was never used and ptrace-block-step can be implemented using a
much simpler approach.
So axe all 3000 lines of it. That includes the *locked_memory*()
APIs in mm/mlock.c as well.
Reported-by: Linus Torvalds <torvalds@linux-foundation.org>
Cc: Roland McGrath <roland@redhat.com>
Cc: Markus Metzger <markus.t.metzger@intel.com>
LKML-Reference: <20100325135413.938004390@chello.nl>
While in theory user_enable_single_step/user_disable_single_step/
user_enable_blockstep could also be provided as an inline or macro there's
no good reason to do so, and having the prototype in one places keeps code
size and confusion down.
Roland said:
The original thought there was that user_enable_single_step() et al
might well be only an instruction or three on a sane machine (as if we
have any of those!), and since there is only one call site inlining
would be beneficial. But I agree that there is no strong reason to care
about inlining it.
As to the arch changes, there is only one thought I'd add to the
record. It was always my thinking that for an arch where
PTRACE_SINGLESTEP does text-modifying breakpoint insertion,
user_enable_single_step() should not be provided. That is,
arch_has_single_step()=>true means that there is an arch facility with
"pure" semantics that does not have any unexpected side effects.
Inserting a breakpoint might do very unexpected strange things in
multi-threaded situations. Aside from that, it is a peculiar side
effect that user_{enable,disable}_single_step() should cause COW
de-sharing of text pages and so forth. For PTRACE_SINGLESTEP, all these
peculiarities are the status quo ante for that arch, so having
arch_ptrace() itself do those is one thing. But for building other
things in the future, it is nicer to have a uniform "pure" semantics
that arch-independent code can expect.
OTOH, all such arch issues are really up to the arch maintainer. As
of today, there is nothing but ptrace using user_enable_single_step() et
al so it's a distinction without a practical difference. If/when there
are other facilities that use user_enable_single_step() and might care,
the affected arch's can revisit the question when someone cares about
the quality of the arch support for said new facility.
Return -EINVAL for the bad size and for unrecognized NT_* type in
ptrace_regset() instead of -EIO.
Also update the comments for this ptrace interface with more clarifications.
Requested-by: Roland McGrath <roland@redhat.com>
Requested-by: Oleg Nesterov <oleg@redhat.com>
Signed-off-by: Suresh Siddha <suresh.b.siddha@intel.com>
LKML-Reference: <20100222225240.397523600@sbs-t61.sc.intel.com>
Signed-off-by: H. Peter Anvin <hpa@zytor.com>
Generic support for PTRACE_GETREGSET/PTRACE_SETREGSET commands which
export the regsets supported by each architecture using the correponding
NT_* types. These NT_* types are already part of the userland ABI, used
in representing the architecture specific register sets as different NOTES
in an ELF core file.
'addr' parameter for the ptrace system call encode the REGSET type (using
the corresppnding NT_* type) and the 'data' parameter points to the
struct iovec having the user buffer and the length of that buffer.
struct iovec iov = { buf, len};
ret = ptrace(PTRACE_GETREGSET/PTRACE_SETREGSET, pid, NT_XXX_TYPE, &iov);
On successful completion, iov.len will be updated by the kernel specifying
how much the kernel has written/read to/from the user's iov.buf.
x86 extended state registers are primarily exported using this interface.
LKML-Reference: <20100211195614.886724710@sbs-t61.sc.intel.com>
Acked-by: Hongjiu Lu <hjl.tools@gmail.com>
Suggested by Roland.
Currently there is no way to synthesize a single-stepping trap in the
arch-independent manner. This patch adds the default helper which fills
siginfo_t, arch/ can can override it.
Architetures which implement user_enable_single_step() should add
user_single_step_siginfo() also.
No functional changes.
ptrace_init_task() looks confusing, as if we always auto-attach when "bool
ptrace" argument is true, while in fact we attach only if current is
traced.
Make the code more explicit and kill now unused ptrace_link().
- Use rcu_read_lock() instead of tasklist_lock to find/get the task
in ptrace_get_task_struct().
- Make it static, it has no callers outside of ptrace.c.
- The comment doesn't match the reality, this helper does not do
any checks. Beacuse it is really trivial and static I removed the
whole comment.
Add the ptrace bts context field to task_struct unconditionally.
Initialize the field directly in copy_process().
Remove all the unneeded functionality used to initialize that field.
Signed-off-by: Markus Metzger <markus.t.metzger@intel.com>
Cc: roland@redhat.com
Cc: eranian@googlemail.com
Cc: oleg@redhat.com
Cc: juan.villacis@intel.com
Cc: ak@linux.jf.intel.com
LKML-Reference: <20090403144603.292754000@intel.com>
By discussion with Roland.
- Rename ptrace_exit() to exit_ptrace(), and change it to do all the
necessary work with ->ptraced list by its own.
- Move this code from exit.c to ptrace.c
- Update the comment in ptrace_detach() to explain the rechecking of
the child->ptrace.
Cc: "Metzger, Markus T" <markus.t.metzger@intel.com>
When ptrace_detach() takes tasklist, the tracee can be SIGKILL'ed. If it
has already passed exit_notify() we can leak a zombie, because a) ptracing
disables the auto-reaping logic, and b) ->real_parent was not notified
about the child's death.
ptrace_detach() should follow the ptrace_exit's logic, change the code
accordingly.
Cc: Jerome Marchand <jmarchan@redhat.com>
Tested-by: Denys Vlasenko <dvlasenk@redhat.com>
Impact: introduce new ptrace facility
Add arch_ptrace_untrace() function that is called when the tracer
detaches (either voluntarily or when the tracing task dies);
ptrace_disable() is only called on a voluntary detach.
Add ptrace_fork() and arch_ptrace_fork(). They are called when a
traced task is forked.
Clear DS and BTS related fields on fork.
Release DS resources and reclaim memory in ptrace_untrace(). This
releases resources already when the tracing task dies. We used to do
that when the traced task dies.
ptrace_untrace() can now become static.
Signed-off-by: Adrian Bunk <bunk@kernel.org>
Cc: Oleg Nesterov <oleg@tv-sign.ru>
In the change in commit 09a05394fe2448a4139b014936330af23fa7ec83, I
overlooked two nits in the logic and this broke using CLONE_PTRACE
when PTRACE_O_TRACE* are not being used.
A parent that is itself traced at all but not using PTRACE_O_TRACE*,
using CLONE_PTRACE would have its new child fail to be traced.
A parent that is not itself traced at all that uses CLONE_PTRACE
(which should be a no-op in this case) would confuse the bookkeeping
and lead to a crash at exit time.
This restores the missing checks and fixes both failure modes.
Reported-by: Eduardo Habkost <ehabkost@redhat.com>
Signed-off-by: Roland McGrath <roland@redhat.com>
This adds the new function task_current_syscall() on machines where the
asm/syscall.h interface is supported (CONFIG_HAVE_ARCH_TRACEHOOK). It's
exported for modules to use in the future. This function safely samples
the state of a blocked thread to collect what system call it is blocked
in, and the six system call argument registers.
Reviewed-by: Ingo Molnar <mingo@elte.hu>
