path: root/include/linux/pci.h
2010-02-16Merge branch 'master' of ↵David S. Miller
2010-02-12pci: Add SR-IOV convenience functions and macrosWilliams, Mitch A
Add and export pci_num_vf to allow other subsystems to determine how many virtual function devices are associated with an SR-IOV physical function device. Add macros dev_is_pci, dev_is_ps, and dev_num_vf to make it easier for non-PCI specific code to determine SR-IOV capabilities. Signed-off-by: Mitch Williams <mitch.a.williams@intel.com> Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-01-29powerpc/pci: Add calls to set_pcie_port_type() and set_pcie_hotplug_bridge()Benjamin Herrenschmidt
We are missing these when building the pci_dev from scratch off the Open Firmware device-tree Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Acked-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2010-01-04PCI/PM: Use per-device D3 delaysRafael J. Wysocki
It turns out that some PCI devices require extra delays when changing power state from D3 to D0 (and the other way around). Although this is against the PCI specification, we can handle it quite easily by allowing drivers to define arbitrary D3 delays for devices known to require extra time for switching power states. Introduce additional field d3_delay in struct pci_dev and use it to store the value of the device's D0->D3 delay, in miliseconds. Make the PCI PM core code use the per-device d3_delay unless pci_pm_d3_delay is greater (in which case the latter is used). [This also allows the driver to specify d3_delay shorter than the 10 ms required by the PCI standard if the device is known to be able to handle that.] Make the sky2 driver set d3_delay to 150 for devices handled by it. Fixes http://bugzilla.kernel.org/show_bug.cgi?id=14730 which is a listed regression from 2.6.30. Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2009-12-16PCI/cardbus: Add a fixup hook and fix powerpcBenjamin Herrenschmidt
The cardbus code creates PCI devices without ever going through the necessary fixup bits and pieces that normal PCI devices go through. There's in fact a commented out call to pcibios_fixup_bus() in there, it's commented because ... it doesn't work. I could make pcibios_fixup_bus() do the right thing on powerpc easily but I felt it cleaner instead to provide a specific hook pci_fixup_cardbus for which a weak empty implementation is provided by the PCI core. This fixes cardbus on powerbooks and probably all other PowerPC platforms which was broken completely for ever on some platforms and since 2.6.31 on others such as PowerBooks when we made the DMA ops mandatory (since those are setup by the fixups). Acked-by: Dominik Brodowski <linux@dominikbrodowski.net> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2009-12-14PCI: Global variable decls must match the defs in section attributesDavid Howells
Global variable declarations must match the definitions in section attributes as the compiler is at liberty to vary the method it uses to access a variable, depending on the section it is in. When building the FRV arch, I now see: drivers/built-in.o: In function `pci_apply_final_quirks': drivers/pci/quirks.c:2606: relocation truncated to fit: R_FRV_GPREL12 against symbol `pci_dfl_cache_line_size' defined in .devinit.data section in drivers/built-in.o drivers/pci/quirks.c:2623: relocation truncated to fit: R_FRV_GPREL12 against symbol `pci_dfl_cache_line_size' defined in .devinit.data section in drivers/built-in.o drivers/pci/quirks.c:2630: relocation truncated to fit: R_FRV_GPREL12 against symbol `pci_dfl_cache_line_size' defined in .devinit.data section in drivers/built-in.o because the declaration of pci_dfl_cache_line_size in linux/pci.h does not match the definition in drivers/pci/pci.c. Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-12-04PCI: add pci_request_acsChris Wright
Commit ae21ee65e8bc228416bbcc8a1da01c56a847a60c "PCI: acs p2p upsteram forwarding enabling" doesn't actually enable ACS. Add a function to pci core to allow an IOMMU to request that ACS be enabled. The existing mechanism of using iommu_found() in the pci core to know when ACS should be enabled doesn't actually work due to initialization order; iommu has only been detected not initialized. Have Intel and AMD IOMMUs request ACS, and Xen does as well during early init of dom0. Cc: Allen Kay <allen.m.kay@intel.com> Cc: David Woodhouse <dwmw2@infradead.org> Cc: Jeremy Fitzhardinge <jeremy@goop.org> Cc: Joerg Roedel <joerg.roedel@amd.com> Signed-off-by: Chris Wright <chrisw@sous-sol.org> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2009-11-24PCI: introduce pci_is_pcie()Kenji Kaneshige
Introduce pci_is_pcie() which returns true if the specified PCI device is PCI Express capable, false otherwise. The purpose of pci_is_pcie() is removing 'is_pcie' flag in the struct pci_dev, which is not needed because we can check it using 'pcie_cap' field. To remove 'is_pcie', we need to update user of 'is_pcie' to use pci_is_pcie() instead first. Signed-off-by: Kenji Kaneshige <kaneshige.kenji@jp.fujitsu.com> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2009-11-24PCI: introduce pci_pcie_cap()Kenji Kaneshige
Introduce pci_pcie_cap() API that returns saved PCIe capability offset (currently it is saved in 'pcie_cap' field in the struct PCI dev). Using pci_pcie_cap() instead of pci_find_capability() avoids unnecessary search in PCI configuration space. Signed-off-by: Kenji Kaneshige <kaneshige.kenji@jp.fujitsu.com> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2009-11-06PCI: cache PCIe capability offsetKenji Kaneshige
There are a lot of codes that searches PCI express capability offset in the PCI configuration space using pci_find_capability(). Caching it in the struct pci_dev will reduce unncecessary search. This patch adds an additional 'pcie_cap' fields into struct pci_dev, which is initialized at pci device scan time (in set_pcie_port_type()). Signed-off-by: Kenji Kaneshige <kaneshige.kenji@jp.fujitsu.com> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2009-11-04PCI: add pci_get_domain_bus_and_slot functionAndrew Patterson
Added the pci_get_domain_and_slot_function which is analogous to pci_get_bus_and_slot. It returns a pci_dev given a domain (segment) number, bus number, and devnr. Like pci_get_bus_and_slot, pci_get_domain_bus_and_slot holds a reference to the returned pci_dev. Converted pci_get_bus_and_slot to a wrapper that calls pci_get_domain_bus_and_slot with the domain hard-coded to 0. This routine was patterned off code suggested by Bjorn Helgaas. Acked-by: Huang Ying <ying.huang@intel.com> Signed-off-by: Andrew Patterson <andrew.patterson@hp.com> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2009-11-04PCI: PCIe AER: honor ACPI HEST FIRMWARE FIRST modeMatt Domsch
Feedback from Hidetoshi Seto and Kenji Kaneshige incorporated. This correctly handles PCI-X bridges, PCIe root ports and endpoints, and prints debug messages when invalid/reserved types are found in the HEST. PCI devices not in domain/segment 0 are not represented in HEST, thus will be ignored. Today, the PCIe Advanced Error Reporting (AER) driver attaches itself to every PCIe root port for which BIOS reports it should, via ACPI _OSC. However, _OSC alone is insufficient for newer BIOSes. Part of ACPI 4.0 is the new APEI (ACPI Platform Error Interfaces) which is a way for OS and BIOS to handshake over which errors for which components each will handle. One table in ACPI 4.0 is the Hardware Error Source Table (HEST), where BIOS can define that errors for certain PCIe devices (or all devices), should be handled by BIOS ("Firmware First mode"), rather than be handled by the OS. Dell PowerEdge 11G server BIOS defines Firmware First mode in HEST, so that it may manage such errors, log them to the System Event Log, and possibly take other actions. The aer driver should honor this, and not attach itself to devices noted as such. Furthermore, Kenji Kaneshige reminded us to disallow changing the AER registers when respecting Firmware First mode. Platform firmware is expected to manage these, and if changes to them are allowed, it could break that firmware's behavior. The HEST parsing code may be replaced in the future by a more feature-rich implementation. This patch provides the minimum needed to prevent breakage until that implementation is available. Reviewed-by: Kenji Kaneshige <kaneshige.kenji@jp.fujitsu.com> Reviewed-by: Hidetoshi Seto <seto.hidetoshi@jp.fujitsu.com> Signed-off-by: Matt Domsch <Matt_Domsch@dell.com> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2009-11-04pccard: configure CLS on attachTejun Heo
For non hotplug PCI devices, the system firmware usually configures CLS correctly. For pccard devices system firmware can't do it and Linux PCI layer doesn't do it either. Unfortunately this leads to poor performance for certain devices (sata_sil). Unless MWI, which requires separate configuration, is to be used, CLS doesn't affect correctness, so the configuration should be harmless. This patch makes pci_set_cacheline_size() always built and export it and make pccard call it during attach. Please note that some other PCI hotplug drivers (shpchp and pciehp) also configure CLS on hotplug. Signed-off-by: Tejun Heo <tj@kernel.org> Cc: Daniel Ritz <daniel.ritz@gmx.ch> Cc: Dominik Brodowski <linux@dominikbrodowski.net> Cc: Greg KH <greg@kroah.com> Cc: Kenji Kaneshige <kaneshige.kenji@jp.fujitsu.com> Cc: Axel Birndt <towerlexa@gmx.de> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2009-11-04PCI: determine CLS more intelligentlyJesse Barnes
Till now, CLS has been determined either by arch code or as L1_CACHE_BYTES. Only x86 and ia64 set CLS explicitly and x86 doesn't always get it right. On most configurations, the chance is that firmware configures the correct value during boot. This patch makes pci_init() determine CLS by looking at what firmware has configured. It scans all devices and if all non-zero values agree, the value is used. If none is configured or there is a disagreement, pci_dfl_cache_line_size is used. arch can set the dfl value (via PCI_CACHE_LINE_BYTES or pci_dfl_cache_line_size) or override the actual one. ia64, x86 and sparc64 updated to set the default cls instead of the actual one. While at it, declare pci_cache_line_size and pci_dfl_cache_line_size in pci.h and drop private declarations from arch code. Signed-off-by: Tejun Heo <tj@kernel.org> Acked-by: David Miller <davem@davemloft.net> Acked-by: Greg KH <gregkh@suse.de> Cc: Ingo Molnar <mingo@elte.hu> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Tony Luck <tony.luck@intel.com> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2009-09-09PCI PM: Introduce device flag wakeup_preparedRafael J. Wysocki
Introduce a new PCI device flag, wakeup_prepared, to prevent PCI wake-up preparation code from being executed twice in a row for the same device and for the same purpose. Reviewed-by: Matthew Garrett <mjg59@srcf.ucam.org> Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2009-09-09PCI: pcie: Ensure hotplug ports have a minimum number of resourcesEric W. Biederman
In general a BIOS may goof or we may hotplug in a hotplug controller. In either case the kernel needs to reserve resources for plugging in more devices in the future instead of creating a minimal resource assignment. We already do this for cardbus bridges I am just adding a variant for pcie bridges. v2: Make testing for pcie hotplug bridges based on a flag. So far we only set the flag for pcie but a header_quirk could easily be added for the non-standard pci hotplug bridges. Signed-off-by: Eric W. Biederman <ebiederm@aristanetworks.com> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2009-09-09PCI: separate out pci_add_dynid()Tejun Heo
Separate out pci_add_dynid() from store_new_id() and export it so that in-kernel code can add PCI IDs dynamically. As the function will be available regardless of HOTPLUG, put it and pull pci_free_dynids() outside of CONFIG_HOTPLUG. This will be used by pci-stub to initialize initial IDs via module param. While at it, remove bogus get_driver() failure check. Signed-off-by: Tejun Heo <tj@kernel.org> Acked-by: Greg Kroah-Hartman <gregkh@suse.de> Reviewed-by: Grant Grundler <grundler@parisc-linux.org> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2009-09-09PCI: support for PCI Express fundamental resetMike Mason
This is the first of three patches that implement a bit field that PCI Express device drivers can use to indicate they need a fundamental reset during error recovery. By default, the EEH framework on powerpc does what's known as a "hot reset" during recovery of a PCI Express device. We've found a case where the device needs a "fundamental reset" to recover properly. The current PCI error recovery and EEH frameworks do not support this distinction. The attached patch (courtesy of Richard Lary) adds a bit field to pci_dev that indicates whether the device requires a fundamental reset during recovery. These patches supersede the previously submitted patch that implemented a fundamental reset bit field. Signed-off-by: Mike Mason <mmlnx@us.ibm.com> Signed-off-by: Richard Lary <rlary@us.ibm.com> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2009-09-09PCI/GPU: implement VGA arbitration on LinuxBenjamin Herrenschmidt
Background: Graphic devices are accessed through ranges in I/O or memory space. While most modern devices allow relocation of such ranges, some "Legacy" VGA devices implemented on PCI will typically have the same "hard-decoded" addresses as they did on ISA. For more details see "PCI Bus Binding to IEEE Std 1275-1994 Standard for Boot (Initialization Configuration) Firmware Revision 2.1" Section 7, Legacy Devices. The Resource Access Control (RAC) module inside the X server currently does the task of arbitration when more than one legacy device co-exists on the same machine. But the problem happens when these devices are trying to be accessed by different userspace clients (e.g. two server in parallel). Their address assignments conflict. Therefore an arbitration scheme _outside_ of the X server is needed to control the sharing of these resources. This document introduces the operation of the VGA arbiter implemented for Linux kernel. Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Tiago Vignatti <tiago.vignatti@nokia.com> Signed-off-by: Dave Airlie <airlied@redhat.com> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2009-09-09PCI: expose function reset capability in sysfsMichael S. Tsirkin
Some devices allow an individual function to be reset without affecting other functions in the same device: that's what pci_reset_function does. For devices that have this support, expose reset attribite in sysfs. This is useful e.g. for virtualization, where a qemu userspace process wants to reset the device when the guest is reset, to emulate machine reboot as closely as possible. Acked-by: Greg Kroah-Hartman <gregkh@suse.de> Signed-off-by: Michael S. Tsirkin <mst@redhat.com> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2009-06-29PCI: make pci_name() take const argumentAlexey Zaytsev
Since this function should never modify it (saves warnings when called with const args too). Signed-off-by: Alexey Zaytsev <zaytsev@altell.ru> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2009-06-22Merge git://git.infradead.org/~dwmw2/iommu-2.6.31Linus Torvalds
* git://git.infradead.org/~dwmw2/iommu-2.6.31: intel-iommu: Fix one last ia64 build problem in Pass Through Support VT-d: support the device IOTLB VT-d: cleanup iommu_flush_iotlb_psi and flush_unmaps VT-d: add device IOTLB invalidation support VT-d: parse ATSR in DMA Remapping Reporting Structure PCI: handle Virtual Function ATS enabling PCI: support the ATS capability intel-iommu: dmar_set_interrupt return error value intel-iommu: Tidy up iommu->gcmd handling intel-iommu: Fix tiny theoretical race in write-buffer flush. intel-iommu: Clean up handling of "caching mode" vs. IOTLB flushing. intel-iommu: Clean up handling of "caching mode" vs. context flushing. VT-d: fix invalid domain id for KVM context flush Fix !CONFIG_DMAR build failure introduced by Intel IOMMU Pass Through Support Intel IOMMU Pass Through Support Fix up trivial conflicts in drivers/pci/{intel-iommu.c,intr_remapping.c}
2009-06-22Merge branch 'linux-next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jbarnes/pci-2.6 * 'linux-next' of git://git.kernel.org/pub/scm/linux/kernel/git/jbarnes/pci-2.6: (74 commits) PCI: make msi_free_irqs() to use msix_mask_irq() instead of open coded write PCI: Fix the NIU MSI-X problem in a better way PCI ASPM: remove get_root_port_link PCI ASPM: cleanup pcie_aspm_sanity_check PCI ASPM: remove has_switch field PCI ASPM: cleanup calc_Lx_latency PCI ASPM: cleanup pcie_aspm_get_cap_device PCI ASPM: cleanup clkpm checks PCI ASPM: cleanup __pcie_aspm_check_state_one PCI ASPM: cleanup initialization PCI ASPM: cleanup change input argument of aspm functions PCI ASPM: cleanup misc in struct pcie_link_state PCI ASPM: cleanup clkpm state in struct pcie_link_state PCI ASPM: cleanup latency field in struct pcie_link_state PCI ASPM: cleanup aspm state field in struct pcie_link_state PCI ASPM: fix typo in struct pcie_link_state PCI: drivers/pci/slot.c should depend on CONFIG_SYSFS PCI: remove redundant __msi_set_enable() PCI PM: consistently use type bool for wake enable variable x86/ACPI: Correct maximum allowed _CRS returned resources and warn if exceeded ...
2009-06-16PCI PM: consistently use type bool for wake enable variableFrans Pop
Other functions use type bool, so use that for pci_enable_wake as well. Signed-off-by: Frans Pop <elendil@planet.nl> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2009-06-16PCI: cleanup Function Level ResetYu Zhao
This patch enhances the FLR functions: 1) remove disable_irq() so the shared IRQ won't be disabled. 2) replace the 1s wait with 100, 200 and 400ms wait intervals for the Pending Transaction. 3) replace mdelay() with msleep(). 4) add might_sleep(). 5) lock the device to prevent PM suspend from accessing the CSRs during the reset. 6) coding style fixes. Reviewed-by: Kenji Kaneshige <kaneshige.kenji@jp.fujitsu.com> Signed-off-by: Yu Zhao <yu.zhao@intel.com> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2009-06-16PCI AER: support Multiple Error Received and no error source idZhang, Yanmin
Based on PCI Express AER specs, a root port might receive multiple TLP errors while it could only save a correctable error source id and an uncorrectable error source id at the same time. In addition, some root port hardware might be unable to provide a correct source id, i.e., the source id, or the bus id part of the source id provided by root port might be equal to 0. The patchset implements the support in kernel by searching the device tree under the root port. Patch 1 changes parameter cb of function pci_walk_bus to return a value. When cb return non-zero, pci_walk_bus stops more searching on the device tree. Reviewed-by: Andrew Patterson <andrew.patterson@hp.com> Signed-off-by: Zhang Yanmin <yanmin_zhang@linux.intel.com> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2009-06-16PCI hotplug: create symlink to hotplug driver moduleKenji Kaneshige
Create symbolic link to hotplug driver module in the PCI slot directory (/sys/bus/pci/slots/<SLOT#>). In the past, we need to load hotplug drivers one by one to identify the hotplug driver that handles the slot, and it was very inconvenient especially for trouble shooting. With this change, we can easily identify the hotplug driver. Signed-off-by: Taku Izumi <izumi.taku@jp.fujitsu.com> Signed-off-by: Kenji Kaneshige <kaneshige.kenji@jp.fujitsu.com> Reviewed-by: Alex Chiang <achiang@hp.com> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2009-06-16PCI: Add pci_bus_set_opsHuang Ying
pci_bus_set_ops changes pci_ops associated with a pci_bus. This can be used by debug tools such as PCIE AER error injection to fake some PCI configuration registers. Acked-by: Kenji Kaneshige <kaneshige.kenji@jp.fujitsu.com> Signed-off-by: Huang Ying <ying.huang@intel.com> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2009-06-15PCI: add power-state name stringsAlan Stern
This patch (as1235) adds an array of PCI power-state names, together with a simple inline accessor routine. Signed-off-by: Alan Stern <stern@rowland.harvard.edu> Acked-by: Rafael J. Wysocki <rjw@sisk.pl> Acked-by: Jesse Barnes <jbarnes@virtuousgeek.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-06-11PCI: Add support for turning PCIe ECRC on or offAndrew Patterson
Adds support for PCI Express transaction layer end-to-end CRC checking (ECRC). This patch will enable/disable ECRC checking by setting/clearing the ECRC Check Enable and/or ECRC Generation Enable bits for devices that support ECRC. The ECRC setting is controlled by the "pci=ecrc=<policy>" command-line option. If this option is not set or is set to 'bios", the enable and generation bits are left in whatever state that firmware/BIOS set them to. The "off" setting turns them off, and the "on" option turns them on (if the device supports it). Turning ECRC on or off can be a data integrity versus performance tradeoff. In theory, turning it on will catch more data errors, turning it off means possibly better performance since CRC does not need to be calculated by the PCIe hardware and packet sizes are reduced. Signed-off-by: Andrew Patterson <andrew.patterson@hp.com> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2009-06-11PCI: remove deprecated pci_find_slot() interfaceAlex Chiang
The last in-tree caller of pci_find_slot has been converted, so let's get rid of this deprecated interface. Signed-off-by: Alex Chiang <achiang@hp.com> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2009-06-11PCI/x86: don't assume prefetchable ranges are 64bitYinghai Lu
We should not assign 64bit ranges to PCI devices that only take 32bit prefetchable addresses. Try to set IORESOURCE_MEM_64 in 64bit resource of pci_device/pci_bridge and make the bus resource only have that bit set when all devices under it support 64bit prefetchable memory. Use that flag to allocate resources from that range. Reported-by: Yannick <yannick.roehlly@free.fr> Reviewed-by: Ivan Kokshaysky <ink@jurassic.park.msu.ru> Signed-off-by: Yinghai Lu <yinghai@kernel.org> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2009-05-18PCI: support the ATS capabilityYu Zhao
The PCIe ATS capability makes the Endpoint be able to request the DMA address translation from the IOMMU and cache the translation in the device side, thus alleviate IOMMU pressure and improve the hardware performance in the I/O virtualization environment. Signed-off-by: Yu Zhao <yu.zhao@intel.com> Acked-by: Jesse Barnes <jbarnes@virtuousgeek.org> Signed-off-by: David Woodhouse <David.Woodhouse@intel.com>
2009-04-06PCI: Setup disabled bridges even if buses are addedYuji Shimada
This patch sets up disabled bridges even if buses have already been added. pci_assign_unassigned_resources is called after buses are added. pci_assign_unassigned_resources calls pci_bus_assign_resources. pci_bus_assign_resources calls pci_setup_bridge to configure BARs of bridges. Currently pci_setup_bridge returns immediately if the bus have already been added. So pci_assign_unassigned_resources can't configure BARs of bridges that were added in a disabled state; this patch fixes the issue. On logical hot-add, we need to prevent the kernel from re-initializing bridges that have already been initialized. To achieve this, pci_setup_bridge returns immediately if the bridge have already been enabled. We don't need to check whether the specified bus is a root bus or not. pci_setup_bridge is not called on a root bus, because a root bus does not have a bridge. The patch adds a new helper function, pci_is_enabled. I made the function name similar to pci_is_managed. The codes which use enable_cnt directly are changed to use pci_is_enabled. Acked-by: Alex Chiang <achiang@hp.com> Signed-off-by: Yuji Shimada <shimada-yxb@necst.nec.co.jp> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2009-04-01Merge branch 'linux-next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jbarnes/pci-2.6 * 'linux-next' of git://git.kernel.org/pub/scm/linux/kernel/git/jbarnes/pci-2.6: (88 commits) PCI: fix HT MSI mapping fix PCI: don't enable too much HT MSI mapping x86/PCI: make pci=lastbus=255 work when acpi is on PCI: save and restore PCIe 2.0 registers PCI: update fakephp for bus_id removal PCI: fix kernel oops on bridge removal PCI: fix conflict between SR-IOV and config space sizing powerpc/PCI: include pci.h in powerpc MSI implementation PCI Hotplug: schedule fakephp for feature removal PCI Hotplug: rename legacy_fakephp to fakephp PCI Hotplug: restore fakephp interface with complete reimplementation PCI: Introduce /sys/bus/pci/devices/.../rescan PCI: Introduce /sys/bus/pci/devices/.../remove PCI: Introduce /sys/bus/pci/rescan PCI: Introduce pci_rescan_bus() PCI: do not enable bridges more than once PCI: do not initialize bridges more than once PCI: always scan child buses PCI: pci_scan_slot() returns newly found devices PCI: don't scan existing devices ... Fix trivial append-only conflict in Documentation/feature-removal-schedule.txt
2009-03-30PCI PM: Introduce __pci_[start|complete]_power_transition() (rev. 2)Rafael J. Wysocki
The radeonfb driver needs to program the device's PMCSR directly due to some quirky hardware it has to handle (see http://bugzilla.kernel.org/show_bug.cgi?id=12846 for details) and after doing that it needs to call the platform (usually ACPI) to finish the power transition of the device. Currently it uses pci_set_power_state() for this purpose, however making a specific assumption about the internal behavior of this function, which has changed recently so that this assumption is no longer satisfied. For this reason, introduce __pci_complete_power_transition() that may be called by the radeonfb driver to complete the power transition of the device. For symmetry, introduce __pci_start_power_transition(). Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Acked-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2009-03-20PCI: Introduce pci_rescan_bus()Alex Chiang
This API is used by the PCI core to rescan a bus and rediscover newly added devices. Over time, it is expected that the various PCI hotplug drivers will migrate to this interface and away from the old pci_do_scan_bus() interface. Signed-off-by: Alex Chiang <achiang@hp.com> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2009-03-20PCI: pci_is_root_bus helperKenji Kaneshige
Introduce pci_is_root_bus helper function. This will help make code more consistent, as well as prevent incorrect assumptions (such as pci_bus->self == NULL on a root bus, which is not always true). Signed-off-by: Kenji Kaneshige <kaneshige.kenji@jp.fujitsu.com> Signed-off-by: Alex Chiang <achiang@hp.com> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2009-03-20PCI: handle SR-IOV Virtual Function MigrationYu Zhao
Add or remove a Virtual Function after receiving a Migrate In or Out Request. Reviewed-by: Matthew Wilcox <willy@linux.intel.com> Signed-off-by: Yu Zhao <yu.zhao@intel.com> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2009-03-20PCI: add SR-IOV API for Physical Function driverYu Zhao
Add or remove the Virtual Function when the SR-IOV is enabled or disabled by the device driver. This can happen anytime rather than only at the device probe stage. Reviewed-by: Matthew Wilcox <willy@linux.intel.com> Signed-off-by: Yu Zhao <yu.zhao@intel.com> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2009-03-20PCI: initialize and release SR-IOV capabilityYu Zhao
If a device has the SR-IOV capability, initialize it (set the ARI Capable Hierarchy in the lowest numbered PF if necessary; calculate the System Page Size for the VF MMIO, probe the VF Offset, Stride and BARs). A lock for the VF bus allocation is also initialized if a PF is the lowest numbered PF. Reviewed-by: Matthew Wilcox <willy@linux.intel.com> Signed-off-by: Yu Zhao <yu.zhao@intel.com> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2009-03-20PCI MSI: Add support for multiple MSIMatthew Wilcox
Add the new API pci_enable_msi_block() to allow drivers to request multiple MSI and reimplement pci_enable_msi in terms of pci_enable_msi_block. Ensure that the architecture back ends don't have to know about multiple MSI. Signed-off-by: Matthew Wilcox <willy@linux.intel.com> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2009-03-19PCI: constify pci_bus_assign_resources()Andrew Morton
drivers/pci/hotplug/fakephp.c: In function 'pci_rescan_bus': drivers/pci/hotplug/fakephp.c:271: warning: passing argument 1 of 'pci_bus_assign_resources' discards qualifiers from pointer target type Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2009-03-19PCI: constify pci_bus_add_devices()akpm@linux-foundation.org
drivers/pci/hotplug/fakephp.c:283: warning: passing argument 1 of 'pci_bus_add_devices' discards qualifiers from pointer target type Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2009-03-19PCI/MSI: Introduce pci_msix_table_size()Rafael J. Wysocki
Introduce new function pci_msix_table_size() returning the size of the MSI-X table of given PCI device or 0 if the device doesn't support MSI-X. Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Reviewed-by: Hidetoshi Seto <seto.hidetoshi@jp.fujitsu.com> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2009-02-04PCI: return error on failure to read PCI ROMsTimothy S. Nelson
This patch makes the ROM reading code return an error to user space if the size of the ROM read is equal to 0. The patch also emits a warnings if the contents of the ROM are invalid, and documents the effects of the "enable" file on ROM reading. Signed-off-by: Timothy S. Nelson <wayland@wayland.id.au> Acked-by: Alex Villacis-Lasso <a_villacis@palosanto.com> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2009-01-16PCI PM: Restore standard config registers of all devices earlyRafael J. Wysocki
There is a problem in our handling of suspend-resume of PCI devices that many of them have their standard config registers restored with interrupts enabled and they are put into the full power state with interrupts enabled as well. This may lead to the following scenario: * an interrupt vector is shared between two or more devices * one device is resumed earlier and generates an interrupt * the interrupt handler of another device tries to handle it and attempts to access the device the config space of which hasn't been restored yet and/or which still is in a low power state * the system crashes as a result To prevent this from happening we should restore the standard configuration registers of all devices with interrupts disabled and we should put them into the D0 power state right after that. Unfortunately, this cannot be done using the existing pci_set_power_state(), because it can sleep. Also, to do it we have to make sure that the config spaces of all devices were actually saved during suspend. Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Acked-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2009-01-07x86/PCI: Do not use interrupt links for devices using MSI-XRafael J. Wysocki
pcibios_enable_device() and pcibios_disable_device() don't handle IRQs for devices that have MSI enabled and it should treat the devices with MSI-X enabled in the same way. Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Acked-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2009-01-07PCI: Add pci_clear_master() as opposite of pci_set_master()Ben Hutchings
During an online device reset it may be useful to disable bus-mastering. pci_disable_device() does that, and far more besides, so is not suitable for an online reset. Add pci_clear_master() which does just this. Signed-off-by: Ben Hutchings <bhutchings@solarflare.com> Reviewed-by: Matthew Wilcox <willy@linux.intel.com> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2009-01-07PCI: add interface to set visible size of VPDStephen Hemminger
The VPD on all devices may not be 32K. Unfortunately, there is no generic way to find the size, so this adds a simple API hook to reset it. Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
