path: root/include/linux/page-flags.h
2010-10-25[S390] add support for nonquiescing sskeMartin Schwidefsky
Improve performance of the sske operation by using the nonquiescing variant if the affected page has no mappings established. On machines with no support for the new sske variant the mask bit will be ignored. Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2010-07-16slub: Use kmem_cache flags to detect if slab is in debugging mode.Christoph Lameter
The cacheline with the flags is reachable from the hot paths after the percpu allocator changes went in. So there is no need anymore to put a flag into each slab page. Get rid of the SlubDebug flag and use the flags in kmem_cache instead. Acked-by: David Rientjes <rientjes@google.com> Signed-off-by: Christoph Lameter <cl@linux-foundation.org> Signed-off-by: Pekka Enberg <penberg@cs.helsinki.fi>
2009-12-17Merge branch 'for-33' of git://repo.or.cz/linux-kbuildLinus Torvalds
* 'for-33' of git://repo.or.cz/linux-kbuild: (29 commits) net: fix for utsrelease.h moving to generated gen_init_cpio: fixed fwrite warning kbuild: fix make clean after mismerge kbuild: generate modules.builtin genksyms: properly consider EXPORT_UNUSED_SYMBOL{,_GPL}() score: add asm/asm-offsets.h wrapper unifdef: update to upstream revision 1.190 kbuild: specify absolute paths for cscope kbuild: create include/generated in silentoldconfig scripts/package: deb-pkg: use fakeroot if available scripts/package: add KBUILD_PKG_ROOTCMD variable scripts/package: tar-pkg: use tar --owner=root Kbuild: clean up marker net: add net_tstamp.h to headers_install kbuild: move utsrelease.h to include/generated kbuild: move autoconf.h to include/generated drop explicit include of autoconf.h kbuild: move compile.h to include/generated kbuild: drop include/asm kbuild: do not check for include/asm-$ARCH ... Fixed non-conflicting clean merge of modpost.c as per comments from Stephen Rothwell (modpost.c had grown an include of linux/autoconf.h that needed to be changed to generated/autoconf.h)
2009-12-16mm: export stable page flagsWu Fengguang
Rename get_uflags() to stable_page_flags() and make it a global function for use in the hwpoison page flags filter, which need to compare user page flags with the value provided by user space. Also move KPF_* to kernel-page-flags.h for use by user space tools. Acked-by: Matt Mackall <mpm@selenic.com> Signed-off-by: Andi Kleen <ak@linux.intel.com> CC: Nick Piggin <npiggin@suse.de> CC: Christoph Lameter <cl@linux-foundation.org> Signed-off-by: Wu Fengguang <fengguang.wu@intel.com> Signed-off-by: Andi Kleen <ak@linux.intel.com>
2009-12-16HWPOISON: Add unpoisoning supportWu Fengguang
The unpoisoning interface is useful for stress testing tools to reclaim poisoned pages (to prevent OOM) There is no hardware level unpoisioning, so this cannot be used for real memory errors, only for software injected errors. Note that it may leak pages silently - those who have been removed from LRU cache, but not isolated from page cache/swap cache at hwpoison time. Especially the stress test of dirty swap cache pages shall reboot system before exhausting memory. AK: Fix comments, add documentation, add printks, rename symbol Signed-off-by: Wu Fengguang <fengguang.wu@intel.com> Signed-off-by: Andi Kleen <ak@linux.intel.com>
2009-12-15mm: CONFIG_MMU for PG_mlockedHugh Dickins
Remove three degrees of obfuscation, left over from when we had CONFIG_UNEVICTABLE_LRU. MLOCK_PAGES is CONFIG_HAVE_MLOCKED_PAGE_BIT is CONFIG_HAVE_MLOCK is CONFIG_MMU. rmap.o (and memory-failure.o) are only built when CONFIG_MMU, so don't need such conditions at all. Somehow, I feel no compulsion to remove the CONFIG_HAVE_MLOCK* lines from 169 defconfigs: leave those to evolve in due course. Signed-off-by: Hugh Dickins <hugh.dickins@tiscali.co.uk> Cc: Izik Eidus <ieidus@redhat.com> Cc: Andrea Arcangeli <aarcange@redhat.com> Cc: Nick Piggin <npiggin@suse.de> Reviewed-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Cc: Rik van Riel <riel@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com> Cc: Andi Kleen <andi@firstfloor.org> Cc: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Wu Fengguang <fengguang.wu@intel.com> Cc: Minchan Kim <minchan.kim@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-12-12kbuild: move bounds.h to include/generatedSam Ravnborg
Signed-off-by: Sam Ravnborg <sam@ravnborg.org> Cc: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Michal Marek <mmarek@suse.cz>
2009-09-24Merge branch 'hwpoison' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/ak/linux-mce-2.6 * 'hwpoison' of git://git.kernel.org/pub/scm/linux/kernel/git/ak/linux-mce-2.6: (21 commits) HWPOISON: Enable error_remove_page on btrfs HWPOISON: Add simple debugfs interface to inject hwpoison on arbitary PFNs HWPOISON: Add madvise() based injector for hardware poisoned pages v4 HWPOISON: Enable error_remove_page for NFS HWPOISON: Enable .remove_error_page for migration aware file systems HWPOISON: The high level memory error handler in the VM v7 HWPOISON: Add PR_MCE_KILL prctl to control early kill behaviour per process HWPOISON: shmem: call set_page_dirty() with locked page HWPOISON: Define a new error_remove_page address space op for async truncation HWPOISON: Add invalidate_inode_page HWPOISON: Refactor truncate to allow direct truncating of page v2 HWPOISON: check and isolate corrupted free pages v2 HWPOISON: Handle hardware poisoned pages in try_to_unmap HWPOISON: Use bitmask/action code for try_to_unmap behaviour HWPOISON: x86: Add VM_FAULT_HWPOISON handling to x86 page fault handler v2 HWPOISON: Add poison check to page fault handling HWPOISON: Add basic support for poisoned pages in fault handler v3 HWPOISON: Add new SIGBUS error codes for hardware poison signals HWPOISON: Add support for poison swap entries v2 HWPOISON: Export some rmap vma locking to outside world ...
2009-09-22mm: return boolean from page_has_private()Johannes Weiner
Make page_has_private() return a true boolean value and remove the double negations from the two callsites using it for arithmetic. Signed-off-by: Johannes Weiner <hannes@cmpxchg.org> Cc: Christoph Lameter <cl@linux-foundation.org> Reviewed-by: Christoph Lameter <cl@linux-foundation.org> Reviewed-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-09-22mm: perform non-atomic test-clear of PG_mlocked on freeJohannes Weiner
By the time PG_mlocked is cleared in the page freeing path, nobody else is looking at our page->flags anymore. It is thus safe to make the test-and-clear non-atomic and thereby removing an unnecessary and expensive operation from a hotpath. Signed-off-by: Johannes Weiner <hannes@cmpxchg.org> Reviewed-by: Christoph Lameter <cl@linux-foundation.org> Reviewed-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Cc: Christoph Lameter <cl@linux-foundation.org> Cc: Mel Gorman <mel@csn.ul.ie> Cc: Nick Piggin <nickpiggin@yahoo.com.au> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-09-16HWPOISON: Add page flag for poisoned pagesAndi Kleen
Hardware poisoned pages need special handling in the VM and shouldn't be touched again. This requires a new page flag. Define it here. The page flags wars seem to be over, so it shouldn't be a problem to get a new one. v2: Add TestSetHWPoison (suggested by Johannes Weiner) Acked-by: Christoph Lameter <cl@linux.com> Signed-off-by: Andi Kleen <ak@linux.intel.com>
2009-08-26x86, pat: Generalize the use of page flag PG_uncachedVenkatesh Pallipadi
Only IA64 was using PG_uncached as of now. We now intend to use this bit in x86 as well, to keep track of memory type of those addresses that have page struct for them. So, generalize the use of that bit across ia64 and x86. Signed-off-by: Venkatesh Pallipadi <venkatesh.pallipadi@intel.com> Signed-off-by: Suresh Siddha <suresh.b.siddha@intel.com> Signed-off-by: H. Peter Anvin <hpa@zytor.com>
2009-06-17Merge branches 'slab/documentation', 'slab/fixes', 'slob/cleanups' and ↵Pekka Enberg
'slub/fixes' into for-linus
2009-06-16mm: remove CONFIG_UNEVICTABLE_LRU config optionKOSAKI Motohiro
Currently, nobody wants to turn UNEVICTABLE_LRU off. Thus this configurability is unnecessary. Signed-off-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Cc: Johannes Weiner <hannes@cmpxchg.org> Cc: Andi Kleen <andi@firstfloor.org> Acked-by: Minchan Kim <minchan.kim@gmail.com> Cc: David Woodhouse <dwmw2@infradead.org> Cc: Matt Mackall <mpm@selenic.com> Cc: Rik van Riel <riel@redhat.com> Cc: Lee Schermerhorn <lee.schermerhorn@hp.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-05-11slob: use PG_slab for identifying SLOB pagesWu Fengguang
For the sake of consistency. Signed-off-by: Wu Fengguang <fengguang.wu@intel.com> Cc: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Cc: Andi Kleen <andi@firstfloor.org> Acked-by: Matt Mackall <mpm@selenic.com> Cc: Alexey Dobriyan <adobriyan@gmail.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Christoph Lameter <cl@linux-foundation.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Pekka Enberg <penberg@cs.helsinki.fi>
2009-04-03FS-Cache: Recruit a page flags for cache managementDavid Howells
Recruit a page flag to aid in cache management. The following extra flag is defined: (1) PG_fscache (PG_private_2) The marked page is backed by a local cache and is pinning resources in the cache driver. If PG_fscache is set, then things that checked for PG_private will now also check for that. This includes things like truncation and page invalidation. The function page_has_private() had been added to make the checks for both PG_private and PG_private_2 at the same time. Signed-off-by: David Howells <dhowells@redhat.com> Acked-by: Steve Dickson <steved@redhat.com> Acked-by: Trond Myklebust <Trond.Myklebust@netapp.com> Acked-by: Rik van Riel <riel@redhat.com> Acked-by: Al Viro <viro@zeniv.linux.org.uk> Tested-by: Daire Byrne <Daire.Byrne@framestore.com>
2009-04-03FS-Cache: Release page->private after failed readaheadDavid Howells
The attached patch causes read_cache_pages() to release page-private data on a page for which add_to_page_cache() fails. If the filler function fails, then the problematic page is left attached to the pagecache (with appropriate flags set, one presumes) and the remaining to-be-attached pages are invalidated and discarded. This permits pages with caching references associated with them to be cleaned up. The invalidatepage() address space op is called (indirectly) to do the honours. Signed-off-by: David Howells <dhowells@redhat.com> Acked-by: Steve Dickson <steved@redhat.com> Acked-by: Trond Myklebust <Trond.Myklebust@netapp.com> Acked-by: Rik van Riel <riel@redhat.com> Acked-by: Al Viro <viro@zeniv.linux.org.uk> Tested-by: Daire Byrne <Daire.Byrne@framestore.com>
2009-04-01nommu: there is no mlock() for NOMMU, so don't provide the bitsDavid Howells
The mlock() facility does not exist for NOMMU since all mappings are effectively locked anyway, so we don't make the bits available when they're not useful. Signed-off-by: David Howells <dhowells@redhat.com> Reviewed-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Greg Ungerer <gerg@snapgear.com> Cc: Johannes Weiner <hannes@cmpxchg.org> Cc: Rik van Riel <riel@redhat.com> Cc: Lee Schermerhorn <lee.schermerhorn@hp.com> Cc: Enrik Berkhan <Enrik.Berkhan@ge.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-06badpage: simplify page_alloc flag check+clearHugh Dickins
Simplify the PAGE_FLAGS checking and clearing when freeing and allocating a page: check the same flags as before when freeing, clear ALL the flags (unless PageReserved) when freeing, check ALL flags off when allocating. Signed-off-by: Hugh Dickins <hugh@veritas.com> Cc: Nick Piggin <nickpiggin@yahoo.com.au> Cc: Christoph Lameter <cl@linux-foundation.org> Cc: Mel Gorman <mel@csn.ul.ie> Cc: Rik van Riel <riel@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-06mm: add Set,ClearPageSwapCache stubsHugh Dickins
If we add NOOP stubs for SetPageSwapCache() and ClearPageSwapCache(), then we can remove the #ifdef CONFIG_SWAPs from mm/migrate.c. Signed-off-by: Hugh Dickins <hugh@veritas.com> Acked-by: Christoph Lameter <cl@linux-foundation.org> Cc: Nick Piggin <nickpiggin@yahoo.com.au> Cc: Mel Gorman <mel@csn.ul.ie> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-20mlock: mlocked pages are unevictableNick Piggin
Make sure that mlocked pages also live on the unevictable LRU, so kswapd will not scan them over and over again. This is achieved through various strategies: 1) add yet another page flag--PG_mlocked--to indicate that the page is locked for efficient testing in vmscan and, optionally, fault path. This allows early culling of unevictable pages, preventing them from getting to page_referenced()/try_to_unmap(). Also allows separate accounting of mlock'd pages, as Nick's original patch did. Note: Nick's original mlock patch used a PG_mlocked flag. I had removed this in favor of the PG_unevictable flag + an mlock_count [new page struct member]. I restored the PG_mlocked flag to eliminate the new count field. 2) add the mlock/unevictable infrastructure to mm/mlock.c, with internal APIs in mm/internal.h. This is a rework of Nick's original patch to these files, taking into account that mlocked pages are now kept on unevictable LRU list. 3) update vmscan.c:page_evictable() to check PageMlocked() and, if vma passed in, the vm_flags. Note that the vma will only be passed in for new pages in the fault path; and then only if the "cull unevictable pages in fault path" patch is included. 4) add try_to_unlock() to rmap.c to walk a page's rmap and ClearPageMlocked() if no other vmas have it mlocked. Reuses as much of try_to_unmap() as possible. This effectively replaces the use of one of the lru list links as an mlock count. If this mechanism let's pages in mlocked vmas leak through w/o PG_mlocked set [I don't know that it does], we should catch them later in try_to_unmap(). One hopes this will be rare, as it will be relatively expensive. Original mm/internal.h, mm/rmap.c and mm/mlock.c changes: Signed-off-by: Nick Piggin <npiggin@suse.de> splitlru: introduce __get_user_pages(): New munlock processing need to GUP_FLAGS_IGNORE_VMA_PERMISSIONS. because current get_user_pages() can't grab PROT_NONE pages theresore it cause PROT_NONE pages can't munlock. [akpm@linux-foundation.org: fix this for pagemap-pass-mm-into-pagewalkers.patch] [akpm@linux-foundation.org: untangle patch interdependencies] [akpm@linux-foundation.org: fix things after out-of-order merging] [hugh@veritas.com: fix page-flags mess] [lee.schermerhorn@hp.com: fix munlock page table walk - now requires 'mm'] [kosaki.motohiro@jp.fujitsu.com: build fix] [kosaki.motohiro@jp.fujitsu.com: fix truncate race and sevaral comments] [kosaki.motohiro@jp.fujitsu.com: splitlru: introduce __get_user_pages()] Signed-off-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Signed-off-by: Rik van Riel <riel@redhat.com> Signed-off-by: Lee Schermerhorn <lee.schermerhorn@hp.com> Cc: Nick Piggin <npiggin@suse.de> Cc: Dave Hansen <dave@linux.vnet.ibm.com> Cc: Matt Mackall <mpm@selenic.com> Signed-off-by: Hugh Dickins <hugh@veritas.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-20Unevictable LRU InfrastructureLee Schermerhorn
When the system contains lots of mlocked or otherwise unevictable pages, the pageout code (kswapd) can spend lots of time scanning over these pages. Worse still, the presence of lots of unevictable pages can confuse kswapd into thinking that more aggressive pageout modes are required, resulting in all kinds of bad behaviour. Infrastructure to manage pages excluded from reclaim--i.e., hidden from vmscan. Based on a patch by Larry Woodman of Red Hat. Reworked to maintain "unevictable" pages on a separate per-zone LRU list, to "hide" them from vmscan. Kosaki Motohiro added the support for the memory controller unevictable lru list. Pages on the unevictable list have both PG_unevictable and PG_lru set. Thus, PG_unevictable is analogous to and mutually exclusive with PG_active--it specifies which LRU list the page is on. The unevictable infrastructure is enabled by a new mm Kconfig option [CONFIG_]UNEVICTABLE_LRU. A new function 'page_evictable(page, vma)' in vmscan.c tests whether or not a page may be evictable. Subsequent patches will add the various !evictable tests. We'll want to keep these tests light-weight for use in shrink_active_list() and, possibly, the fault path. To avoid races between tasks putting pages [back] onto an LRU list and tasks that might be moving the page from non-evictable to evictable state, the new function 'putback_lru_page()' -- inverse to 'isolate_lru_page()' -- tests the "evictability" of a page after placing it on the LRU, before dropping the reference. If the page has become unevictable, putback_lru_page() will redo the 'putback', thus moving the page to the unevictable list. This way, we avoid "stranding" evictable pages on the unevictable list. [akpm@linux-foundation.org: fix fallout from out-of-order merge] [riel@redhat.com: fix UNEVICTABLE_LRU and !PROC_PAGE_MONITOR build] [nishimura@mxp.nes.nec.co.jp: remove redundant mapping check] [kosaki.motohiro@jp.fujitsu.com: unevictable-lru-infrastructure: putback_lru_page()/unevictable page handling rework] [kosaki.motohiro@jp.fujitsu.com: kill unnecessary lock_page() in vmscan.c] [kosaki.motohiro@jp.fujitsu.com: revert migration change of unevictable lru infrastructure] [kosaki.motohiro@jp.fujitsu.com: revert to unevictable-lru-infrastructure-kconfig-fix.patch] [kosaki.motohiro@jp.fujitsu.com: restore patch failure of vmstat-unevictable-and-mlocked-pages-vm-events.patch] Signed-off-by: Lee Schermerhorn <lee.schermerhorn@hp.com> Signed-off-by: Rik van Riel <riel@redhat.com> Signed-off-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Debugged-by: Benjamin Kidwell <benjkidwell@yahoo.com> Signed-off-by: Daisuke Nishimura <nishimura@mxp.nes.nec.co.jp> Signed-off-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-20pageflag helpers for configed-out flagsLee Schermerhorn
Define proper false/noop inline functions for noreclaim page flags when !defined(CONFIG_UNEVICTABLE_LRU) Signed-off-by: Lee Schermerhorn <lee.schermerhorn@hp.com> Signed-off-by: Rik van Riel <riel@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-20define page_file_cache() functionRik van Riel
Define page_file_cache() function to answer the question: is page backed by a file? Originally part of Rik van Riel's split-lru patch. Extracted to make available for other, independent reclaim patches. Moved inline function to linux/mm_inline.h where it will be needed by subsequent "split LRU" and "noreclaim" patches. Unfortunately this needs to use a page flag, since the PG_swapbacked state needs to be preserved all the way to the point where the page is last removed from the LRU. Trying to derive the status from other info in the page resulted in wrong VM statistics in earlier split VM patchsets. The total number of page flags in use on a 32 bit machine after this patch is 19. [akpm@linux-foundation.org: fix up out-of-order merge fallout] [hugh@veritas.com: splitlru: shmem_getpage SetPageSwapBacked sooner[ Signed-off-by: Rik van Riel <riel@redhat.com> Signed-off-by: Lee Schermerhorn <lee.schermerhorn@hp.com> Signed-off-by: MinChan Kim <minchan.kim@gmail.com> Signed-off-by: Hugh Dickins <hugh@veritas.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-08-04mm: rename page trylockNick Piggin
Converting page lock to new locking bitops requires a change of page flag operation naming, so we might as well convert it to something nicer (!TestSetPageLocked_Lock => trylock_page, SetPageLocked => set_page_locked). This also facilitates lockdeping of page lock. Signed-off-by: Nick Piggin <npiggin@suse.de> Acked-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Acked-by: Peter Zijlstra <peterz@infradead.org> Acked-by: Andrew Morton <akpm@linux-foundation.org> Acked-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-08-01[S390] Optimize storage key operations for anon pagesMartin Schwidefsky
For anonymous pages without a swap cache backing the check in page_remove_rmap for the physical dirty bit in page_remove_rmap is unnecessary. The instructions that are used to check and reset the dirty bit are expensive. Removing the check noticably speeds up process exit. In addition the clearing of the dirty bit in __SetPageUptodate is pointless as well. With these two changes there is no storage key operation for an anonymous page anymore if it does not hit the swap space. The micro benchmark which repeatedly executes an empty shell script gets about 5% faster. Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2008-07-24slob: record page flag overlays explicitlyAndy Whitcroft
SLOB reuses two page bits for internal purposes, it overlays PG_active and PG_private. This is hidden away in slob.c. Document these overlays explicitly in the main page-flags enum along with all the others. Signed-off-by: Andy Whitcroft <apw@shadowen.org> Cc: Pekka Enberg <penberg@cs.helsinki.fi> Cc: Christoph Lameter <cl@linux-foundation.org> Cc: Matt Mackall <mpm@selenic.com> Cc: Nick Piggin <nickpiggin@yahoo.com.au> Reviewed-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Cc: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Cc: Rik van Riel <riel@redhat.com> Cc: Jeremy Fitzhardinge <jeremy@goop.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-24slub: record page flag overlays explicitlyAndy Whitcroft
SLUB reuses two page bits for internal purposes, it overlays PG_active and PG_error. This is hidden away in slub.c. Document these overlays explicitly in the main page-flags enum along with all the others. Signed-off-by: Andy Whitcroft <apw@shadowen.org> Cc: Pekka Enberg <penberg@cs.helsinki.fi> Cc: Christoph Lameter <cl@linux-foundation.org> Cc: Matt Mackall <mpm@selenic.com> Cc: Nick Piggin <nickpiggin@yahoo.com.au> Tested-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Cc: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Cc: Rik van Riel <riel@redhat.com> Cc: Jeremy Fitzhardinge <jeremy@goop.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-24page-flags: record page flag overlays explicitlyAndy Whitcroft
With the recent page flag reorganisation we have a single enum which defines the valid page flags and their values, nice and clear. However there are a number of bits which are overloaded by different subsystems. Firstly there is PG_owner_priv_1 which is used by filesystems and by XEN. Secondly both SLOB and SLUB use a couple of extra page bits to manage internal state for pages they own; both overlay other bits. All of these "aliases" are scattered about the source making it very hard for a reader to know if the bits are safe to rely on in all contexts; confusion here is bad. As we now have a single place where the bits are clearly assigned it makes sense to clarify the reuse of bits by making the aliases explicit and visible with the original bit assignments. This patch creates explicit aliases within the enum itself for the overloaded bits, creates standard bit accessors PageFoo etc. and uses those throughout. This version pulls the bit manipulation out to standard named page bit accessors as suggested by Christoph, it retains the explicit mapping to the overlayed bits. A fusion of both ideas. This has been SLUB and SLOB have been compile tested on x86_64 only, and SLUB boot tested. If people feel this is worth doing then I can run a fuller set of testing. This patch: Some page flags are used for more than one purpose, for example PG_owner_priv_1. Currently there are individual accessors for each user, each built using the common flag name far away from the bit definitions. This makes it hard to see all possible uses of these bits. Now that we have a single enum to generate the bit orders it makes sense to express overlays in the same place. So create per use aliases for this bit in the main page-flags enum and use those in the accessors. [akpm@linux-foundation.org: fix xen] Signed-off-by: Andy Whitcroft <apw@shadowen.org> Cc: Pekka Enberg <penberg@cs.helsinki.fi> Cc: Christoph Lameter <cl@linux-foundation.org> Cc: Matt Mackall <mpm@selenic.com> Cc: Nick Piggin <nickpiggin@yahoo.com.au> Cc: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Reviewed-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Cc: Rik van Riel <riel@redhat.com> Cc: Jeremy Fitzhardinge <jeremy@goop.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-06-16Merge branch 'linus' into x86/xentip-x86-xen-2008-06-16_09.21_MonIngo Molnar
2008-06-09mm: Minor clean-up of page flags in mm/page_alloc.cRuss Anderson
Minor source code cleanup of page flags in mm/page_alloc.c. Move the definition of the groups of bits to page-flags.h. The purpose of this clean up is that the next patch will conditionally add a page flag to the groups. Doing that in a header file is cleaner than adding #ifdefs to the C code. Signed-off-by: Russ Anderson <rja@sgi.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-05-27xen: implement save/restoreJeremy Fitzhardinge
This patch implements Xen save/restore and migration. Saving is triggered via xenbus, which is polled in drivers/xen/manage.c. When a suspend request comes in, the kernel prepares itself for saving by: 1 - Freeze all processes. This is primarily to prevent any partially-completed pagetable updates from confusing the suspend process. If CONFIG_PREEMPT isn't defined, then this isn't necessary. 2 - Suspend xenbus and other devices 3 - Stop_machine, to make sure all the other vcpus are quiescent. The Xen tools require the domain to run its save off vcpu0. 4 - Within the stop_machine state, it pins any unpinned pgds (under construction or destruction), performs canonicalizes various other pieces of state (mostly converting mfns to pfns), and finally 5 - Suspend the domain Restore reverses the steps used to save the domain, ending when all the frozen processes are thawed. Signed-off-by: Jeremy Fitzhardinge <jeremy.fitzhardinge@citrix.com> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2008-04-28PAGEFLAGS_EXTENDED and separate page flags for Head and TailChristoph Lameter
Having separate page flags for the head and the tail of a compound page allows the compiler to use bitops instead of operations on a word to check for a tail page. That is f.e. important for virt_to_head_page() which is used in various critical code paths (kfree for example): Code for PageTail(page) Before: mov (%rdi),%rdx page->flags mov %rdx,%rax 3 bytes and $0x12000,%eax 5 bytes cmp $0x12000,%rax 6 bytes je 897 <kfree+0xa7> After: mov (%rdi),%rax test $0x40,%ah (3 bytes) jne 887 <kfree+0x97> So we go from 14 bytes to 3 bytes and from 3 instructions to one. From the use of 2 registers we go to none. We can only use page flags for this if we have page flags available. This patch introduces CONFIG_PAGEFLAGS_EXTENDED that is set if pageflags are not scarce due to SPARSEMEM using page flags for its sectionid on 32 bit NUMA platforms. Additional page flag definitions can be added to the CONFIG_PAGEFLAGS_EXTENDED section in page-flags.h if the functionality depends on PAGEFLAGS_EXTENDED or if more page flag overlapping tricks are used for the !PAGEFLAGS_EXTENDED fallback (the upcoming virtual compound patch may hook in here and Rik's/Lee's additional page flags to solve the reclaim issues could also be added there [hint... hint... where are these patchsets?]). Avoiding the overlaying of Pg_reclaim also clears the way for possible use of compound pages for the pagecache or on the LRU. Signed-off-by: Christoph Lameter <clameter@sgi.com> Cc: Nick Piggin <nickpiggin@yahoo.com.au> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-28page flags: add PAGEFLAGS_FALSE for flags that are always falseChristoph Lameter
Turns out that there are a number of times that a flag is simply always returning 0. Define a macro for that. Signed-off-by: Christoph Lameter <clameter@sgi.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-28page flags: handle PG_uncached like all other flagsChristoph Lameter
Remove the special setup for PG_uncached and simply make it part of the enum. The page flag will only be allocated when the kernel build includes the uncached allocator. Acked-by: Dean Nelson <dcn@sgi.com> Cc: Jes Sorensen <jes@trained-monkey.org> Signed-off-by: Christoph Lameter <clameter@sgi.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-28pageflags: eliminate PG_xxx aliasesChristoph Lameter
Remove aliases of PG_xxx. We can easily drop those now and alias by specifying the PG_xxx flag in the macro that generates the functions. Signed-off-by: Christoph Lameter <clameter@sgi.com> Cc: Andy Whitcroft <apw@shadowen.org> Cc: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Cc: Rik van Riel <riel@redhat.com> Cc: Mel Gorman <mel@csn.ul.ie> Cc: Jeremy Fitzhardinge <jeremy@goop.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-28pageflags: use proper page flag functions in XenChristoph Lameter
Xen uses bitops to manipulate page flags. Make it use proper page flag functions. Signed-off-by: Christoph Lameter <clameter@sgi.com> Cc: Andy Whitcroft <apw@shadowen.org> Cc: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Cc: Rik van Riel <riel@redhat.com> Cc: Mel Gorman <mel@csn.ul.ie> Cc: Jeremy Fitzhardinge <jeremy@goop.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-28pageflags: convert to the use of new macrosChristoph Lameter
Replace explicit definitions of page flags through the use of macros. Significantly reduces the size of the definitions and removes a lot of opportunity for errors. Additonal page flags can typically be generated with a single line. Signed-off-by: Christoph Lameter <clameter@sgi.com> Cc: Andy Whitcroft <apw@shadowen.org> Cc: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Cc: Rik van Riel <riel@redhat.com> Cc: Mel Gorman <mel@csn.ul.ie> Cc: Jeremy Fitzhardinge <jeremy@goop.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-28pageflags: introduce macros to generate page flag functionsChristoph Lameter
Introduce a set of macros that generate functions to handle page flags. A page flag function group typically starts with either SETPAGEFLAG(<part of function name>,<part of PG_ flagname>) to create a set of page flag operations that are atomic. Or __SETPAGEFLAG(<part of function name>,<part of PG_ flagname) to create a set of page flag operations that are not atomic. Then additional operations can be added using the following macros TESTSCFLAG Create additional atomic test-and-set and test-and-clear functions TESTSETFLAG Create additional test and set function TESTCLEARFLAG Create additional test and clear function SETPAGEFLAG Create additional atomic set function CLEARPAGEFLAG Create additional atomic clear function __TESTPAGEFLAG Create additional non atomic set function __SETPAGEFLAG Create additional non atomic clear function Signed-off-by: Christoph Lameter <clameter@sgi.com> Cc: Andy Whitcroft <apw@shadowen.org> Cc: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Cc: Rik van Riel <riel@redhat.com> Cc: Mel Gorman <mel@csn.ul.ie> Cc: Jeremy Fitzhardinge <jeremy@goop.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-28pageflags: get rid of FLAGS_RESERVEDChristoph Lameter
NR_PAGEFLAGS specifies the number of page flags we are using. From that we can calculate the number of bits leftover that can be used for zone, node (and maybe the sections id). There is no need anymore for FLAGS_RESERVED if we use NR_PAGEFLAGS. Use the new methods to make NR_PAGEFLAGS available via the preprocessor. NR_PAGEFLAGS is used to calculate field boundaries in the page flags fields. These field widths have to be available to the preprocessor. Signed-off-by: Christoph Lameter <clameter@sgi.com> Cc: David Miller <davem@davemloft.net> Cc: Andy Whitcroft <apw@shadowen.org> Cc: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Cc: Rik van Riel <riel@redhat.com> Cc: Mel Gorman <mel@csn.ul.ie> Cc: Jeremy Fitzhardinge <jeremy@goop.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-28pageflags: use an enum for the flagsChristoph Lameter
Use an enum to ease the maintenance of page flags. This is going to change the numbering from 0 to 18. Signed-off-by: Christoph Lameter <clameter@sgi.com> Cc: Andy Whitcroft <apw@shadowen.org> Cc: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Cc: Rik van Riel <riel@redhat.com> Cc: Mel Gorman <mel@csn.ul.ie> Cc: Jeremy Fitzhardinge <jeremy@goop.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-21MM: Fix macro argument substitution in PageHead() and PageTail()David Howells
Fix macro argument substitution in PageHead() and PageTail() - 'page' should have brackets surrounding it (commit 6d7779538f765963ced45a3fa4bed7ba8d2c277d). Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-05mm: fix PageUptodate data raceNick Piggin
After running SetPageUptodate, preceeding stores to the page contents to actually bring it uptodate may not be ordered with the store to set the page uptodate. Therefore, another CPU which checks PageUptodate is true, then reads the page contents can get stale data. Fix this by having an smp_wmb before SetPageUptodate, and smp_rmb after PageUptodate. Many places that test PageUptodate, do so with the page locked, and this would be enough to ensure memory ordering in those places if SetPageUptodate were only called while the page is locked. Unfortunately that is not always the case for some filesystems, but it could be an idea for the future. Also bring the handling of anonymous page uptodateness in line with that of file backed page management, by marking anon pages as uptodate when they _are_ uptodate, rather than when our implementation requires that they be marked as such. Doing allows us to get rid of the smp_wmb's in the page copying functions, which were especially added for anonymous pages for an analogous memory ordering problem. Both file and anonymous pages are handled with the same barriers. FAQ: Q. Why not do this in flush_dcache_page? A. Firstly, flush_dcache_page handles only one side (the smb side) of the ordering protocol; we'd still need smp_rmb somewhere. Secondly, hiding away memory barriers in a completely unrelated function is nasty; at least in the PageUptodate macros, they are located together with (half) the operations involved in the ordering. Thirdly, the smp_wmb is only required when first bringing the page uptodate, wheras flush_dcache_page should be called each time it is written to through the kernel mapping. It is logically the wrong place to put it. Q. Why does this increase my text size / reduce my performance / etc. A. Because it is adding the necessary instructions to eliminate the data-race. Q. Can it be improved? A. Yes, eg. if you were to create a rule that all SetPageUptodate operations run under the page lock, we could avoid the smp_rmb places where PageUptodate is queried under the page lock. Requires audit of all filesystems and at least some would need reworking. That's great you're interested, I'm eagerly awaiting your patches. Signed-off-by: Nick Piggin <npiggin@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-19move page writeback acounting out of macrosAndrew Morton
page-writeback accounting is presently performed in the page-flags macros. This is inconsistent and a bit ugly and makes it awkward to implement per-backing_dev under-writeback page accounting. So move this accounting down to the callsite(s). Acked-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-19mm: share PG_readahead and PG_reclaimFengguang Wu
Share the same page flag bit for PG_readahead and PG_reclaim. One is used only on file reads, another is only for emergency writes. One is used mostly for fresh/young pages, another is for old pages. Combinations of possible interactions are: a) clear PG_reclaim => implicit clear of PG_readahead it will delay an asynchronous readahead into a synchronous one it actually does _good_ for readahead: the pages will be reclaimed soon, it's readahead thrashing! in this case, synchronous readahead makes more sense. b) clear PG_readahead => implicit clear of PG_reclaim one(and only one) page will not be reclaimed in time it can be avoided by checking PageWriteback(page) in readahead first c) set PG_reclaim => implicit set of PG_readahead will confuse readahead and make it restart the size rampup process it's a trivial problem, and can mostly be avoided by checking PageWriteback(page) first in readahead d) set PG_readahead => implicit set of PG_reclaim PG_readahead will never be set on already cached pages. PG_reclaim will always be cleared on dirtying a page. so not a problem. In summary, a) we get better behavior b,d) possible interactions can be avoided c) racy condition exists that might affect readahead, but the chance is _really_ low, and the hurt on readahead is trivial. Compound pages also use PG_reclaim, but for now they do not interact with reclaim/readahead code. Signed-off-by: Fengguang Wu <wfg@mail.ustc.edu.cn> Cc: Rusty Russell <rusty@rustcorp.com.au> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-19readahead: introduce PG_readaheadFengguang Wu
Introduce a new page flag: PG_readahead. It acts as a look-ahead mark, which tells the page reader: Hey, it's time to invoke the read-ahead logic. For the sake of I/O pipelining, don't wait until it runs out of cached pages! Signed-off-by: Fengguang Wu <wfg@mail.ustc.edu.cn> Cc: Steven Pratt <slpratt@austin.ibm.com> Cc: Ram Pai <linuxram@us.ibm.com> Cc: Rusty Russell <rusty@rustcorp.com.au> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-18xen: add pinned page flagJeremy Fitzhardinge
Add a new definition for PG_owner_priv_1 to define PG_pinned on Xen pagetable pages. Signed-off-by: Jeremy Fitzhardinge <jeremy@xensource.com> Signed-off-by: Chris Wright <chrisw@sous-sol.org>
2007-05-07mm: remove unused page flagsRafael J. Wysocki
Remove the two page flags that were previously used by swsusp and are no longer needed. Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Acked-by: Pavel Machek <pavel@ucw.cz> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-07mm: optimize compound_head() by avoiding a shared page flagChristoph Lameter
The patch adds PageTail(page) and PageHead(page) to check if a page is the head or the tail of a compound page. This is done by masking the two bits describing the state of a compound page and then comparing them. So one comparision and a branch instead of two bit checks and two branches. Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-07Make page->private usable in compound pagesChristoph Lameter
If we add a new flag so that we can distinguish between the first page and the tail pages then we can avoid to use page->private in the first page. page->private == page for the first page, so there is no real information in there. Freeing up page->private makes the use of compound pages more transparent. They become more usable like real pages. Right now we have to be careful f.e. if we are going beyond PAGE_SIZE allocations in the slab on i386 because we can then no longer use the private field. This is one of the issues that cause us not to support debugging for page size slabs in SLAB. Having page->private available for SLUB would allow more meta information in the page struct. I can probably avoid the 16 bit ints that I have in there right now. Also if page->private is available then a compound page may be equipped with buffer heads. This may free up the way for filesystems to support larger blocks than page size. We add PageTail as an alias of PageReclaim. Compound pages cannot currently be reclaimed. Because of the alias one needs to check PageCompound first. The RFC for the this approach was discussed at http://marc.info/?t=117574302800001&r=1&w=2 [nacc@us.ibm.com: fix hugetlbfs] Signed-off-by: Christoph Lameter <clameter@sgi.com> Signed-off-by: Nishanth Aravamudan <nacc@us.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
