path: root/include/linux/page-flags.h
2006-01-06[PATCH] mm: page_state opt docsNick Piggin
Comment the new locking rules for page_state statistics. Signed-off-by: Nick Piggin <npiggin@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-06[PATCH] mm: page_state optNick Piggin
Optimise page_state manipulations by introducing interrupt unsafe accessors to page_state fields. Callers must provide their own locking (either disable interrupts or not update from interrupt context). Switch over the hot callsites that can easily be moved under interrupts off sections. Signed-off-by: Nick Piggin <npiggin@suse.de> Cc: Hugh Dickins <hugh@veritas.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-06[PATCH] mm: dma32 zone statisticsNick Piggin
Add dma32 to zone statistics. Also attempt to arrange struct page_state a bit better (visually). Signed-off-by: Nick Piggin <npiggin@suse.de> Cc: Andi Kleen <ak@muc.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-22[PATCH] unpaged: unifdefed PageCompoundHugh Dickins
It looks like snd_xxx is not the only nopage to be using PageReserved as a way of holding a high-order page together: which no longer works, but is masked by our failure to free from VM_RESERVED areas. We cannot fix that bug without first substituting another way to hold the high-order page together, while farming out the 0-order pages from within it. That's just what PageCompound is designed for, but it's been kept under CONFIG_HUGETLB_PAGE. Remove the #ifdefs: which saves some space (out- of-line put_page), doesn't slow down what most needs to be fast (already using hugetlb), and unifies the way we handle high-order pages. Signed-off-by: Hugh Dickins <hugh@veritas.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-05[PATCH] VM: add page_state info to per-node meminfoMartin Hicks
Add page_state info to the per-node meminfo file in sysfs. This is mostly just for informational purposes. The lack of this information was brought up recently during a discussion regarding pagecache clearing, and I put this patch together to test out one of the suggestions. It seems like interesting info to have, so I'm submitting the patch. Signed-off-by: Martin Hicks <mort@sgi.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-05[PATCH] mm: remove atomicNick Piggin
This bitop does not need to be atomic because it is performed when there will be no references to the page (ie. the page is being freed). Signed-off-by: Nick Piggin <npiggin@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-21[PATCH] __read_page_state(): pass unsigned long instead of unsignedBenjamin LaHaise
By making the offset argument of __read_page_state an unsigned long instead of unsigned, we can avoid forcing the compiler to sign extend a usually constant argument. This saves 1 instruction on x86-64. Signed-off-by: Benjamin LaHaise <benjamin.c.lahaise@intel.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-21[PATCH] __mod_page_state(): pass unsigned long instead of unsignedBenjamin LaHaise
By making the offset argument of __mod_page_state an unsigned long instead of unsigned, we can avoid forcing the compiler to sign extend a usually constant argument. This saves 1 instruction on x86-64. Signed-off-by: Benjamin LaHaise <benjamin.c.lahaise@intel.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-21[PATCH] mm: remove PG_highmemBadari Pulavarty
Remove PG_highmem, to save a page flag. Use is_highmem() instead. It'll generate a little more code, but we don't use PageHigheMem() in many places. Signed-off-by: Badari Pulavarty <pbadari@us.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-05-01[PATCH] count bounce buffer pages in vmstatKAMEZAWA Hiroyuki
This is a patch for counting the number of pages for bounce buffers. It's shown in /proc/vmstat. Currently, the number of bounce pages are not counted anywhere. So, if there are many bounce pages, it seems that there are leaked pages. And it's difficult for a user to imagine the usage of bounce pages. So, it's meaningful to show # of bouce pages. Signed-off-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
